  4. MQTT-Adapter (Server/Client/…)
    6.0k
13 Beiträge 2 Kommentatoren 3.8k Aufrufe
    Surfer2010
    Okay das klappt glaube ich soweit.
    Wie komme ich jetzt an die Daten?
    void loop()
      if (!client.connected()) {
        reconnect();
      client.loop();
      long now = millis();
      long duration, distance;
        // Distanzmessung
        if (now - lastMsg > 10000) {
          lastMsg = now;
          digitalWrite(TRIGGER, LOW);
          delayMicroseconds(2);
          digitalWrite(TRIGGER, HIGH);
          delayMicroseconds(10);
          duration = pulseIn(ECHO, HIGH);
          distance = (duration/2) / 29.1;
          String msg="";
          char MsgEntfernung[25];
          msg= distance;
          msg.toCharArray(MsgEntfernung,25);
          client.publish("Entfernung", MsgEntfernung);
          Serial.print(distance);
          Serial.println(" Centimeter aktuell:");
          data = distance;
          delay(1000);
          server.handleClient();
    Die sehe ich im ioBroker unter Instanzen nämlich nicht.
    mttq.0 –> info --> connections (mehr ist da nicht)?!
    P-S- (der Log)
    host.raspberrypi	2018-06-04 21:00:23.837	info	Restart adapter system.adapter.mqtt.0 because enabled
    host.raspberrypi	2018-06-04 21:00:23.837	error	instance system.adapter.mqtt.0 terminated with code 0 (OK)
    Caught	2018-06-04 21:00:23.837	error	by controller[0]: port: 1883 }
    Caught	2018-06-04 21:00:23.836	error	by controller[0]: address: '0.0.0.0',
    Caught	2018-06-04 21:00:23.836	error	by controller[0]: syscall: 'listen',
    Caught	2018-06-04 21:00:23.836	error	by controller[0]: errno: 'EADDRINUSE',
    Caught	2018-06-04 21:00:23.835	error	by controller[0]: code: 'EADDRINUSE',
    Caught	2018-06-04 21:00:23.835	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
    Caught	2018-06-04 21:00:23.835	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:83:11)
    Caught	2018-06-04 21:00:23.835	error	by controller[0]: at net.js:1417:9
    Caught	2018-06-04 21:00:23.834	error	by controller[0]: at listen (net.js:1307:10)
    Caught	2018-06-04 21:00:23.834	error	by controller[0]: at Server._listen2 (net.js:1271:14)
    Caught	2018-06-04 21:00:23.834	error	by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
    Caught	2018-06-04 21:00:23.833	error	by controller[0]: at Object.exports._errnoException (util.js:1020:11)
    Caught	2018-06-04 21:00:23.832	error	by controller[0]: { Error: listen EADDRINUSE 0.0.0.0:1883
    mqtt.0	2018-06-04 21:00:23.791	info	terminating
    mqtt.0	2018-06-04 21:00:23.269	error	at process._tickCallback (internal/process/next_tick.js:104:9)
    mqtt.0	2018-06-04 21:00:23.269	error	at _combinedTickCallback (internal/process/next_tick.js:83:11)
    mqtt.0	2018-06-04 21:00:23.269	error	at net.js:1417:9
    mqtt.0	2018-06-04 21:00:23.269	error	at listen (net.js:1307:10)
    mqtt.0	2018-06-04 21:00:23.269	error	at Server._listen2 (net.js:1271:14)
    mqtt.0	2018-06-04 21:00:23.269	error	at exports._exceptionWithHostPort (util.js:1043:20)
    mqtt.0	2018-06-04 21:00:23.269	error	at Object.exports._errnoException (util.js:1020:11)
    mqtt.0	2018-06-04 21:00:23.269	error	Error: listen EADDRINUSE 0.0.0.0:1883
    mqtt.0	2018-06-04 21:00:23.266	error	uncaught exception: listen EADDRINUSE 0.0.0.0:1883
    mqtt.0	2018-06-04 21:00:22.324	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v6.14.2
    host.raspberrypi	2018-06-04 21:00:20.827	info	instance system.adapter.mqtt.0 started with pid 23821
    host.raspberrypi	2018-06-04 21:00:08.568	info	instance system.adapter.daswetter.0 terminated with code 0 (OK)
      Hast du noch etwas auf dem port 1883 laufen?
      Gruß Rainer
        Surfer2010
        Nein
        Nicht dass ich wüsste.
          @Surfer2010:
          { Error: listen EADDRINUSE 0.0.0.0:1883 `
          Hast du ggf. den sonoff Adapter laufen, der baut auch auf mqtt auf und nutzt dessen port.
            Surfer2010
            Hi
            ja Sonos läuft … hab jetzt den MQTT Server auf 1888 gesetzt und bekomme Connection failed mit rc=-2
              @Surfer2010:
              ja Sonos läuft `
              ich frug nach
              @Homoran:
              den sonoff Adapter `
                Surfer2010
                ich meinte Sonoff ^^
                der läuft … Port vom MQTT habe ich auf 1893 gesetzt und auch im Code geändert aber da tut sich nichts :( Keine Connection mit dem "Error" rc= -2
                ioBroker:
                mqtt.0	2018-06-05 13:30:49.442	info	Starting MQTT server on port 1893
                mqtt.0	2018-06-05 13:30:48.765	info	starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.mqtt, node: v6.14.2
                host.raspberrypi	2018-06-05 13:30:47.327	info	instance system.adapter.mqtt.0 started with pid 30301
                host.raspberrypi	2018-06-05 13:30:45.334	info	instance system.adapter.mqtt.0 terminated with code 0 (OK)
                mqtt.0	2018-06-05 13:30:45.312	info	terminating
                host.raspberrypi	2018-06-05 13:30:44.793	info	stopInstance system.adapter.mqtt.0 killing pid 30257
                host.raspberrypi	2018-06-05 13:30:44.792	info	object change system.adapter.mqtt.0
                host.raspberrypi	2018-06-05 13:30:08.652	info	instance system.adapter.daswetter.0 terminated with code 0 (OK)
                  @Surfer2010:
                  Keine Connection mit dem "Error" `
                  davon sehe ich im log nichts.
                    Surfer2010
                    Im Device zeigt es mir das im Seriallog / Konsole
                    Serial.print("failed, rc=");
                          Serial.print(client.state());
                    Was könnte noch eine Problemursache sein?
                    Hier die Passage aus dem Code:
                    Serial.print("Attempting MQTT connection...");
                        // Create a random client ID
                        String clientId = "ESP8266ClientDistanzmessung";
                        //clientId += String(random(0xffff), HEX);
                        // Attempt to connect
                        if (client.connect(clientId.c_str(),userName,passWord))
                        //if (client.connect(clientId.c_str()))
                          Serial.println("connected");
                         //once connected to MQTT broker, subscribe command if any
                          client.subscribe("OsoyooCommand");
                        } else {
                          Serial.println(" try again in 5 seconds");
                          // Wait 6 seconds before retrying
                          delay(6000);
                      Das stand doch vorhin noch nicht alles da!
                      was bitte ist der state -2?
                        Surfer2010
                        Das weiß ich nicht … hatte gehofft da kann mir jemand helfen.
                        Das ist was die NodeMCU ausspuckt wenn sie sich versucht mit dem ioBroker-mqtt Server Adapter zu verbinden
