  4. KNX Adapter überholt
1.0k Beiträge 123 Kommentatoren 510.8k Aufrufe 26 Beobachtet
    TheBigS
    #617
    @Chefkoch009:
    Leider hat dein Tipp bei mir nichts verändert. Nach der Ausführung
    root@iobroker:/opt/iobroker# iobroker u knx
    got /opt/iobroker/node_modules/iobroker.knx/admin
    upload [7] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip.js zip/zip.js application/javascript
    upload [6] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/zip-ext.js zip/zip-ext.js application/javascript
    upload [5] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/z-worker.js zip/z-worker.js application/javascript
    upload [4] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/zip/inflate.js zip/inflate.js application/javascript
    upload [3] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/words.js words.js application/javascript
    upload [2] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/knx.png knx.png image/png
    upload [1] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/index_m.html index_m.html text/html
    upload [0] knx.admin /opt/iobroker/node_modules/iobroker.knx/admin/index.html index.html text/html
    Adapter "system.adapter.knx.0" restarted.
    erhalte ich immer noch diese Fehlermeldung:
    2018-06-03 10:53:05.097  - ^[[31merror^[[39m: knx.0 TypeError: Cannot read property 'nodeType' of undefined
        at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:2087
        at _0x36bf7e (/opt/iobroker/node_modules/iobroker.knx/knx.js:87:450)
        at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:213
        at null.matches (/opt/iobroker/node_modules/iobroker.knx/knx.js:87:1728)
        at Function._0x47f16b.(anonymous function) [as applyStep] (/opt/iobroker/node_modules/iobroker.knx/knx.js:87:58843)
        at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:59243
        at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:1080
        at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:654
        at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:1019
    Wichtigste Adapter: KNX, Phillips Hue, z-wave, Unifi
    Host: Individueller Homeserver mit Proxmox, ioBroker in einem LXC-Container
      mathschut
      #618
      Habe es gerade mit allen Browsern getestet, leider genau das selbe. Der Upload funktioniert nicht
      • P Offline
        peer6969
        #619
        Hilft zwar nicht wirklich, aber bei mir funktioniert der Upload einwandfrei. Als Browser verwende ich Safari 11.1.1.
          mathschut
          #620
          wie groß ist deine Projektdatei und welche ETS Version hast du?
          • P Offline
            peer6969
            #621
            Meine Datei ist nur 259 KB groß, aktuell sind da nur Rolläden drin.
            ETS ist 5.6.3.
              KNXbroker
              #622
              @chefkoch009:
              Führt mal bitte ein Adapter Upload durch.
              Folgenden Befehl ausführen :
              cd /opt/iobroker
              iobroker u knx
              Anschliessen bitte den Import nocheinmal versuchen. `
              Bringt auch bei mir nichts.
              Meine ETS ist ebenfalls die 5.6.4
              • chefkoch009C Offline
                chefkoch009
                #623
                Ich glaube ich muss meine ETS (wegen euch ;) ) auch Mal upgraden. Das werde ich demnächst Mal in Angriff nehmen.
                chefkoch009
                  mathschut
                  #624
                  was haben die anderen für eine ETS Version, dass es bei ihnen geht?
                  • Merlin123M Offline
                    Merlin123M Offline
                    Merlin123
                    #625
                    Ich habe die aktuellste. Keine Ahnung, welche das ist. Kann jetzt auch nicht nachschauen.
                    Beta-Tester
                    • P Offline
                      peer6969
                      #626
                      Die Version steht doch unten rechts im Fenster.
                        Merlin123M Offline
                        Merlin123
                        #627
                        Ja, da steht die… Aber im Büro hab ich keinen Zugriff auf die ETS zu Hause ;)
                        Beta-Tester
                          chefkoch009
                          #628
                          Hallo @all,
                          es liegt eine neue Erkenntnis bezüglich des import Problems vor. Ich durfte mal bei mathschut draufschauen. (Danke nochmal)
                          Da lag es an der node und npm Version. Es wurde node ist nun die 8er installiert und npm 6.1.0 und der Import lief problemlos durch.
                          chefkoch009
                            mathschut
                            #629
                            Danke dir nochmal
                            • P Offline
                              peer6969
                              #630
                              Das sind meine Versionen, damit hat es funktioniert:
                              Node.js: v8.11.2
                              NPM: 4.6.1
                                chefkoch009
                                #631
                                Achso…bevor ich es vergesse:
                                in der npm Version 5.6.0 ist ein riesen Bug....nach dem Upgrade darauf ist euer node_modules Verzeichnis leer.
                                Also
                                npm i npm@6.1.0 -g
                                chefkoch009
                                  TheBigS
                                  #632
                                  Ui super. Nach dem Update und anschließendem````
                                  iobroker u knx
                                  Jetzt sind mir in der aktuellen Version keine Bugs mehr bekannt und alles funktioniert wie es soll. :mrgreen:
                                  Perfekt!
                                  Danke @chefkoch009.
                                    KNXbroker
                                    #633
                                    Bei mir klappt nun auch wieder alles. Danke, da wäre ich nie draufgekommen…
                                      chefkoch009
                                      #634
                                      Hi @all,
                                      vielen Dank für das Feedback.
                                      @KNXBroker: Das war auch eher ein Zufallsfund….Gott sei Dank. Deshalb konnte ich die Fehler wohl bei mir auch nicht nachstellen.
                                      Gibt es nun noch Anwender, die mit aktueller node Version ( neuer als 8.x ) Probleme haben ?
                                      chefkoch009
                                        Merlin123M Offline
                                        Merlin123
                                        #635
                                        Mir ist jetzt über die Zeit aufgefallen, dass der KNX Adapter noch nicht 100% zuverlässig läuft. Es kommt immer mal wieder vor, dass Schaltvorgänge nicht durchgeführt werden. Teilweise wird nur ein Befehl geschickt ( z.B. Umschaltung Tag/Nacht) der nicht ankommt, teilweise ist es so, dass eine Gruppe von Rollläden via Alexa geschaltet werden soll und dann ein oder zwei von den 5 nichts machen.
                                        Ist aber nicht reproduzierbar. Passiert aber immer mal wieder.
                                        Irgendwelche Ideen, woran das liegen könnte? Hab V1.0.11 am laufen.
                                        Beta-Tester
                                          chefkoch009
                                          #636
                                          Hallo Merlin123,
                                          Wie viele kommunikationsobjekt befinden sich in deiner Gruppe für das Jalousie zentral fahren?
                                          chefkoch009
