  4. Vis startet nicht mehr
    6.0k
59 Beiträge 4 Kommentatoren 7.1k Aufrufe
  • apollon77A Offline
    Und dann nochmal neu starten bitte
      b.roeske
      2018-06-03 12:43:15.031 - info: cloud.0 Connection changed: connect 2018-06-03 12:43:15.222 - info: radar.0 Init item Ich with { name: 'Ich', ip: 'localhost', macs: '', bluetooth: '', id: 'Ich', hasBT: false, printer: false, hasECB: false, hasIP: true } 2018-06-03 12:43:15.816 - info: host.raspberrypi instance system.adapter.systeminfo.0 started with pid 963 2018-06-03 12:43:17.720 - info: radar.0 radar adapter initialized 1 devices, ExternalNetwork = 300. 2018-06-03 12:43:17.722 - info: radar.0 radar set use of noble(true), fping(false), doMac(false), doHci(true), doBtv(false) and doUwz(UWZDE57612,1800,0,de,false). 2018-06-03 12:43:17.902 - info: radar.0 UWZ found the following (changed) warnings: No warnings 2018-06-03 12:43:17.962 - info: radar.0 ScanAll: From all 1 devices dedected 1 are whoHere: Ich 2018-06-03 12:43:18.183 - info: radar.0 Adapter initialization finished! 2018-06-03 12:43:19.271 - info: systeminfo.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v6.14.2 2018-06-03 12:43:20.021 - info: host.raspberrypi instance system.adapter.wifilight.0 started with pid 974 2018-06-03 12:43:20.656 - error: Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148 2018-06-03 12:43:20.657 - error: Caught by controller[0]: fns.adapter = fns.adapter(options); 2018-06-03 12:43:20.658 - error: Caught by controller[0]: ^ 2018-06-03 12:43:20.659 - error: Caught by controller[0]: TypeError: fns.adapter is not a function 2018-06-03 12:43:20.659 - error: Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23) 2018-06-03 12:43:20.660 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20) 2018-06-03 12:43:20.661 - error: Caught by controller[0]: at Module._compile (module.js:577:32) 2018-06-03 12:43:20.662 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10) 2018-06-03 12:43:20.663 - error: Caught by controller[0]: at Module.load (module.js:494:32) 2018-06-03 12:43:20.664 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12) 2018-06-03 12:43:20.665 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3) 2018-06-03 12:43:20.666 - error: Caught by controller[0]: at Module.runMain (module.js:611:10) 2018-06-03 12:43:20.667 - error: Caught by controller[0]: at run (bootstrap_node.js:394:7) 2018-06-03 12:43:20.668 - error: Caught by controller[0]: at startup (bootstrap_node.js:160:9) 2018-06-03 12:43:20.669 - error: host.raspberrypi instance system.adapter.wifilight.0 terminated with code 1 () 2018-06-03 12:43:20.670 - info: host.raspberrypi Restart adapter system.adapter.wifilight.0 because enabled 2018-06-03 12:43:21.240 - info: systeminfo.0 Startup Systeminfo Adapter systeminfo.0: { startup: '#\ngpio mode 1 output\n#rpi: echo none >/sys/class/leds/led0/trigger\necho none >/sys/class/leds/green_led/trigger', items: [ { name: 'System.Temperature', type: 'file', source: '/sys/class/thermal/thermal_zone0/temp', regexp: '', conv: 'number', role: 'value.temperature|°C', write: '', sched: '*:/2' }, { name: '-System.Memory_[used, free, available]', type: 'exec', source: 'free -k', regexp: 'Mem\\:\\s+\\d+\\s+(\\d+)\\s+(\\d+)\\s+\\d+\\s+\\d+\\s+(\\d+)', conv: '@/1000', role: 'number|MB', write: '', sched: '1 * * * * ' }, { name: 'NAS.Space_[total, used, free]', type: 'exec', source: 'df -BK', regexp: '/lic\\s+(\\d+)K\\s+(\\d+)K\\s+(\\d+)/m', conv: 'parseInt(@*1000/1024)/1000', role: 'number|MB', write: '', sched: '1 * * * * ' }, { name: 'GPIO.1', type: 'exec', source: 'gpio read 1', regexp: '', conv: '!parseInt(@)', role: 'switch', write: 'gpio write 1 @(@ ? \'0\' : \'1\')', sched: '*/20 * * * * *' }, { name: 'System.Led_Green', type: 'file', source: '/sys/class/leds/green_led/brightness', regexp: '', conv: 'boolean', role: 'switch', write: '@ ? \'1\' : \'0\' ', sched: '*/6:1' }, { name: 'System.Led_Red', type: 'file', source: '/sys/class/leds/red_led/brightness', regexp: '', conv: 'boolean', role: 'switch', write: '@ ? \'1\' : \'0\'', sched: '*/6:1' }, { name: 'Currency.[currency/rate]', type: 'web', source: 'http://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml', regexp: 'Cube.Cube.Cube[?(@.currency==\'USD\' || @.currency==\'GBP\')]', conv: 'xml', role: 'number | €/?', write: '', sched: '19:10:10' }, { name: 'Currency.BTC_CNY', type: 'web', source: 'https://www.alphavantage.co/query?function=CURRENCY_EXCHANGE_RATE&from_currency=BTC&to_currency=CNY&apikey=demo', regexp: '[0][4]', conv: 'json', role: 'number | CNY', write: '', sched: '19:10:10' }, { name: 'HP_Photosmart_7520.[name/value]', type: 'web', source: 'http://HPC56C03-PS7520/DevMgmt/ConsumableConfigDyn.xml', regexp: 'ConsumableInfo[?(@.Capacity)][(@.res = {name:@.ConsumableLabelCode, value: @.ConsumablePercentageLevelRemaining + \', \'+@.ConsumableIcon.Shape+\', \'+@.Installation.Date+\', \'+@.ConsumableSelectibilityNumber},\'res\')]', conv: 'xml', role: 'json', write: '', sched: '*/6:3' }, { name: 'UWZ', type: 'web', source: 'http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=UWZAT02402', regexp: '..translationsShortText.DE', conv: 'json', role: 'json', write: '', sched: '*:1' }, { name: '-TestSystem.processes.[command/pcpu]', type: 'info', source: 'processes', regexp: 'list[?(@.user == \'pi\')]', conv: '', role: '', write: '', sched: '*:2' }, { name: '-XS2.[name/value]', type: 'web', source: 'http://xs1/control.html\'', regexp: '{"l[?(@.value !== null )]": {"l[tr]": { \'![@.children()]\':0, name: {_eq:1}, value: {_eq:2, _conv:"parseInt(@.slice(0,-1))"}}, _filter: ($) => $[0].childNodes.length==3}}', conv: 'html', role: '', write: '', sched: '::/20' }, { name: 'MSFT.[]', type: 'web', source: 'https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&symbol=MSFT&apikey=demo', regexp: '[1:2][0:1]', conv: 'json', role: 'number', write: '', sched: '19:10:10' }, { name: 'System.[Mem_used, Mem_free, Swap_used]', type: 'info', source: 'mem', regexp: '[used,free,swapused]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Software.[]', type: 'info', source: 'osInfo', regexp: '', conv: '', role: 'string', write: '', sched: '/3:58' }, { name: 'System.Software.[]', type: 'info', source: 'versions', regexp: '', conv: '', role: 'string', write: '', sched: '/3:58' }, { name: 'System.FileSystem.[fs/use]', type: 'info', source: 'fsSize', regexp: '', conv: '', role: 'number|%', write: '', sched: '/3:58' }, { name: 'System.FileSystem.IO_[Read,Write]', type: 'info', source: 'fsStats', regexp: '[rx,wx]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Network.[iface/]', type: 'info', source: 'networkInterfaces', regexp: '', conv: '', role: '', write: '', sched: '/3:58' }, { name: 'System.Network.Connections.[name/value]', type: 'info', source: 'networkConnections', regexp: '[][!(@.localaddress == @.peeraddress ? null : {name:${@.protocol}:${@.localaddress.replace(/\\./g,\'_\')}:${@.localport}, value:${@.state}:${@.peeraddress}:${@.peerport}})]', conv: '', role: 'string', write: '', sched: ':/1' }, { name: 'System.Network.MB_[Received,Sent]', type: 'info', source: 'networkStats', regexp: '[rx,tx]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Network.FritzBox.[]', type: 'info', source: 'inetChecksite("http://fritz.box")', regexp: '', conv: '', role: '', write: '', sched: ':/1' }, { name: 'System.Network.Latency', type: 'info', source: 'inetLatency', regexp: '', conv: '', role: 'number|ms', write: '', sched: ':/1' }, { name: 'System.Load.[Load,User,System,Idle]', type: 'info', source: 'currentLoad', regexp: '[currentload, currentload_user, currentload_system, currentload_idle]', conv: 'parseInt(@_1000)/1000', role: 'number|ms', write: '', sched: '_::/10' }, { name: 'TankerKönig.[name/diesel]', type: 'web', source: 'https://creativecommons.tankerkoenig.de/json/list.php?lat=52.521&lng=13.438&rad=1.5&sort=dist&type=all&apikey=00000000-0000-0000-0000-000000000002', regexp: 'stations[?(@.name += ' ' + @.street, @.diesel)]', conv: 'json', role: 'number | €', write: '', sched: '/3:2' }, { name: 'TVProgramm.[name/text]', type: 'web', source: 'http://www.tvmovie.de/tv/programm-jetzt', regexp: '{"[0][][!(({name: @.name.split(' ')[0], text: @.name.split(' ').slice(@.name.slice(' ').indexOf('Seit')).join(' ')}))]":{'[section[class=item]]': {'name[span[class=h2]]':0}}}', conv: 'html', role: '', write: '', sched: '/1:0' } ], lang: 'de', latitude: 50.69386, longitude: 7.61537 }
      2018-06-03 12:43:21.495 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Green
      2018-06-03 12:43:21.501 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Red
      2018-06-03 12:43:21.995 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.2
      2018-06-03 12:43:22.253 - info: vis.0 vis license is OK.
      2018-06-03 12:43:23.551 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for HP_Photosmart_7520.[name/value]
      2018-06-03 12:43:30.100 - info: systeminfo.0 Adapter systeminfo.0 started and found 23/73 items/states to process.
      2018-06-03 12:43:31.327 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once`
      ! ~~[b]~~geändert: Code in Spoiler und Code-Tags; ~~[color]~~Homoran (Admin)[/color][/b][/tr]
        Geht vis jetzt?
          b.roeske
          vis geht auf aber dann kommt das
            Nicht dass das das erste Anzeichen für den kommenden Tod der SD-Karte ist und diese nur noch ReadOnly ist
              b.roeske
              Das hoffe ich nicht bin am überlegen alles zu formatieren und noch mal von forne zu beginnen :(
                b.roeske
                Hallo also habe neue sdkarte genommen und alles neu aufgebaut aber vis geht nicht!!!!!
                  b.roeske
                    Diese Meldungen sind beim ersten Aufruf von vis normal.
                    ioBroker versichert sich ob der Ordner nicht eventuell schon existieren sollte und legt dann einen neuen an.
                      b.roeske
                      Danke scheint alles wieder zu gehen :lol:
                        Super!
                        Dann markiere den Thread bitte als [gelöst]
                          b.roeske
                          Hallo zu früh gefreut vis geht wieder nicht
                           SCRIPT5022: Syntax error, unrecognized expression: #view_tab_[{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery_png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery_png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery_png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":"
                          \n<audio_controls_autoplay=\"autoplay\"><source_src=\"http: mp3stream7_apasf_apa_at:8000/;stream_mp3\"_type="\&quot;audio/mp3\&quot;">ORF_"},"style":{"left":"902px","top":"376px","width":"324px","height":"72px"},"widgetSet":"basic"}]
                          jquery-1.11.2.min.js (1,12710)</source_src=\"http:></audio_controls_autoplay=\"autoplay\">
                          • wendy2702W Online
                            wendy2702W Online
                            Und was hast du als letztes vorher gemacht?
                              b.roeske
                              Habe in withges (radio) eingefügt
                                b.roeske
                                gb.error=function(a){throw new Error("Syntax error, unrecognized expression: "+a)},gb.uniqueSort=function
                                • wendy2702W Online
                                  wendy2702W Online
                                    b.roeske
                                    das steht im browser wenn ich f12 drücke
                                    • wendy2702W Online
                                      wendy2702W Online
                                      Kannst du das Widget löschen
                                        b.roeske
                                        komme ja nicht auf vis
                                        • wendy2702W Online
                                          wendy2702W Online
                                          Also kommst du nicht auf den Editor!?
                                          Was genau macht der Browser?
                                          Welcher Browser?
                                          Was steht im iobroker log?
                                          Iobroker und/oder Rechner schon neu gestartet?
