  4. Vis startet nicht mehr
    6.0k
59 Beiträge 4 Kommentatoren 7.1k Aufrufe
  • apollon77A Offline
    Und du hast das chmod mit einem sudo davor gemacht?!
      b.roeske
      mit sudo davor bekomme ich das
        Und dann nochmal neu starten bitte
          b.roeske
          2018-06-03 12:43:15.031 - info: cloud.0 Connection changed: connect 2018-06-03 12:43:15.222 - info: radar.0 Init item Ich with { name: 'Ich', ip: 'localhost', macs: '', bluetooth: '', id: 'Ich', hasBT: false, printer: false, hasECB: false, hasIP: true } 2018-06-03 12:43:15.816 - info: host.raspberrypi instance system.adapter.systeminfo.0 started with pid 963 2018-06-03 12:43:17.720 - info: radar.0 radar adapter initialized 1 devices, ExternalNetwork = 300. 2018-06-03 12:43:17.722 - info: radar.0 radar set use of noble(true), fping(false), doMac(false), doHci(true), doBtv(false) and doUwz(UWZDE57612,1800,0,de,false). 2018-06-03 12:43:17.902 - info: radar.0 UWZ found the following (changed) warnings: No warnings 2018-06-03 12:43:17.962 - info: radar.0 ScanAll: From all 1 devices dedected 1 are whoHere: Ich 2018-06-03 12:43:18.183 - info: radar.0 Adapter initialization finished! 2018-06-03 12:43:19.271 - info: systeminfo.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v6.14.2 2018-06-03 12:43:20.021 - info: host.raspberrypi instance system.adapter.wifilight.0 started with pid 974 2018-06-03 12:43:20.656 - error: Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148 2018-06-03 12:43:20.657 - error: Caught by controller[0]: fns.adapter = fns.adapter(options); 2018-06-03 12:43:20.658 - error: Caught by controller[0]: ^ 2018-06-03 12:43:20.659 - error: Caught by controller[0]: TypeError: fns.adapter is not a function 2018-06-03 12:43:20.659 - error: Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23) 2018-06-03 12:43:20.660 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20) 2018-06-03 12:43:20.661 - error: Caught by controller[0]: at Module._compile (module.js:577:32) 2018-06-03 12:43:20.662 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10) 2018-06-03 12:43:20.663 - error: Caught by controller[0]: at Module.load (module.js:494:32) 2018-06-03 12:43:20.664 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12) 2018-06-03 12:43:20.665 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3) 2018-06-03 12:43:20.666 - error: Caught by controller[0]: at Module.runMain (module.js:611:10) 2018-06-03 12:43:20.667 - error: Caught by controller[0]: at run (bootstrap_node.js:394:7) 2018-06-03 12:43:20.668 - error: Caught by controller[0]: at startup (bootstrap_node.js:160:9) 2018-06-03 12:43:20.669 - error: host.raspberrypi instance system.adapter.wifilight.0 terminated with code 1 () 2018-06-03 12:43:20.670 - info: host.raspberrypi Restart adapter system.adapter.wifilight.0 because enabled 2018-06-03 12:43:21.240 - info: systeminfo.0 Startup Systeminfo Adapter systeminfo.0: { startup: '#\ngpio mode 1 output\n#rpi: echo none >/sys/class/leds/led0/trigger\necho none >/sys/class/leds/green_led/trigger', items: [ { name: 'System.Temperature', type: 'file', source: '/sys/class/thermal/thermal_zone0/temp', regexp: '', conv: 'number', role: 'value.temperature|°C', write: '', sched: '*:/2' }, { name: '-System.Memory_[used, free, available]', type: 'exec', source: 'free -k', regexp: 'Mem\\:\\s+\\d+\\s+(\\d+)\\s+(\\d+)\\s+\\d+\\s+\\d+\\s+(\\d+)', conv: '@/1000', role: 'number|MB', write: '', sched: '1 * * * * ' }, { name: 'NAS.Space_[total, used, free]', type: 'exec', source: 'df -BK', regexp: '/lic\\s+(\\d+)K\\s+(\\d+)K\\s+(\\d+)/m', conv: 'parseInt(@*1000/1024)/1000', role: 'number|MB', write: '', sched: '1 * * * * ' }, { name: 'GPIO.1', type: 'exec', source: 'gpio read 1', regexp: '', conv: '!parseInt(@)', role: 'switch', write: 'gpio write 1 @(@ ? \'0\' : \'1\')', sched: '*/20 * * * * *' }, { name: 'System.Led_Green', type: 'file', source: '/sys/class/leds/green_led/brightness', regexp: '', conv: 'boolean', role: 'switch', write: '@ ? \'1\' : \'0\' ', sched: '*/6:1' }, { name: 'System.Led_Red', type: 'file', source: '/sys/class/leds/red_led/brightness', regexp: '', conv: 'boolean', role: 'switch', write: '@ ? \'1\' : \'0\'', sched: '*/6:1' }, { name: 'Currency.[currency/rate]', type: 'web', source: 'http://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml', regexp: 'Cube.Cube.Cube[?(@.currency==\'USD\' || @.currency==\'GBP\')]', conv: 'xml', role: 'number | €/?', write: '', sched: '19:10:10' }, { name: 'Currency.BTC_CNY', type: 'web', source: 'https://www.alphavantage.co/query?function=CURRENCY_EXCHANGE_RATE&from_currency=BTC&to_currency=CNY&apikey=demo', regexp: '[0][4]', conv: 'json', role: 'number | CNY', write: '', sched: '19:10:10' }, { name: 'HP_Photosmart_7520.[name/value]', type: 'web', source: 'http://HPC56C03-PS7520/DevMgmt/ConsumableConfigDyn.xml', regexp: 'ConsumableInfo[?(@.Capacity)][(@.res = {name:@.ConsumableLabelCode, value: @.ConsumablePercentageLevelRemaining + \', \'+@.ConsumableIcon.Shape+\', \'+@.Installation.Date+\', \'+@.ConsumableSelectibilityNumber},\'res\')]', conv: 'xml', role: 'json', write: '', sched: '*/6:3' }, { name: 'UWZ', type: 'web', source: 'http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=UWZAT02402', regexp: '..translationsShortText.DE', conv: 'json', role: 'json', write: '', sched: '*:1' }, { name: '-TestSystem.processes.[command/pcpu]', type: 'info', source: 'processes', regexp: 'list[?(@.user == \'pi\')]', conv: '', role: '', write: '', sched: '*:2' }, { name: '-XS2.[name/value]', type: 'web', source: 'http://xs1/control.html\'', regexp: '{"l[?(@.value !== null )]": {"l[tr]": { \'![@.children()]\':0, name: {_eq:1}, value: {_eq:2, _conv:"parseInt(@.slice(0,-1))"}}, _filter: ($) => $[0].childNodes.length==3}}', conv: 'html', role: '', write: '', sched: '::/20' }, { name: 'MSFT.[]', type: 'web', source: 'https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&symbol=MSFT&apikey=demo', regexp: '[1:2][0:1]', conv: 'json', role: 'number', write: '', sched: '19:10:10' }, { name: 'System.[Mem_used, Mem_free, Swap_used]', type: 'info', source: 'mem', regexp: '[used,free,swapused]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Software.[]', type: 'info', source: 'osInfo', regexp: '', conv: '', role: 'string', write: '', sched: '/3:58' }, { name: 'System.Software.[]', type: 'info', source: 'versions', regexp: '', conv: '', role: 'string', write: '', sched: '/3:58' }, { name: 'System.FileSystem.[fs/use]', type: 'info', source: 'fsSize', regexp: '', conv: '', role: 'number|%', write: '', sched: '/3:58' }, { name: 'System.FileSystem.IO_[Read,Write]', type: 'info', source: 'fsStats', regexp: '[rx,wx]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Network.[iface/]', type: 'info', source: 'networkInterfaces', regexp: '', conv: '', role: '', write: '', sched: '/3:58' }, { name: 'System.Network.Connections.[name/value]', type: 'info', source: 'networkConnections', regexp: '[][!(@.localaddress == @.peeraddress ? null : {name:${@.protocol}:${@.localaddress.replace(/\\./g,\'_\')}:${@.localport}, value:${@.state}:${@.peeraddress}:${@.peerport}})]', conv: '', role: 'string', write: '', sched: ':/1' }, { name: 'System.Network.MB_[Received,Sent]', type: 'info', source: 'networkStats', regexp: '[rx,tx]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Network.FritzBox.[]', type: 'info', source: 'inetChecksite("http://fritz.box")', regexp: '', conv: '', role: '', write: '', sched: ':/1' }, { name: 'System.Network.Latency', type: 'info', source: 'inetLatency', regexp: '', conv: '', role: 'number|ms', write: '', sched: ':/1' }, { name: 'System.Load.[Load,User,System,Idle]', type: 'info', source: 'currentLoad', regexp: '[currentload, currentload_user, currentload_system, currentload_idle]', conv: 'parseInt(@_1000)/1000', role: 'number|ms', write: '', sched: '_::/10' }, { name: 'TankerKönig.[name/diesel]', type: 'web', source: 'https://creativecommons.tankerkoenig.de/json/list.php?lat=52.521&lng=13.438&rad=1.5&sort=dist&type=all&apikey=00000000-0000-0000-0000-000000000002', regexp: 'stations[?(@.name += ' ' + @.street, @.diesel)]', conv: 'json', role: 'number | €', write: '', sched: '/3:2' }, { name: 'TVProgramm.[name/text]', type: 'web', source: 'http://www.tvmovie.de/tv/programm-jetzt', regexp: '{"[0][][!(({name: @.name.split(' ')[0], text: @.name.split(' ').slice(@.name.slice(' ').indexOf('Seit')).join(' ')}))]":{'[section[class=item]]': {'name[span[class=h2]]':0}}}', conv: 'html', role: '', write: '', sched: '/1:0' } ], lang: 'de', latitude: 50.69386, longitude: 7.61537 }
          2018-06-03 12:43:21.495 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Green
          2018-06-03 12:43:21.501 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Red
          2018-06-03 12:43:21.995 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.2
          2018-06-03 12:43:22.253 - info: vis.0 vis license is OK.
          2018-06-03 12:43:23.551 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for HP_Photosmart_7520.[name/value]
          2018-06-03 12:43:30.100 - info: systeminfo.0 Adapter systeminfo.0 started and found 23/73 items/states to process.
          2018-06-03 12:43:31.327 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once`
          ! ~~[b]~~geändert: Code in Spoiler und Code-Tags; ~~[color]~~Homoran (Admin)[/color][/b][/tr]
            Geht vis jetzt?
              b.roeske
              vis geht auf aber dann kommt das
                Nicht dass das das erste Anzeichen für den kommenden Tod der SD-Karte ist und diese nur noch ReadOnly ist
                  b.roeske
                  Das hoffe ich nicht bin am überlegen alles zu formatieren und noch mal von forne zu beginnen :(
                    b.roeske
                    Hallo also habe neue sdkarte genommen und alles neu aufgebaut aber vis geht nicht!!!!!
                      b.roeske
                        Diese Meldungen sind beim ersten Aufruf von vis normal.
                        ioBroker versichert sich ob der Ordner nicht eventuell schon existieren sollte und legt dann einen neuen an.
                          b.roeske
                          Danke scheint alles wieder zu gehen :lol:
                            Super!
                            Dann markiere den Thread bitte als [gelöst]
                              b.roeske
                              Hallo zu früh gefreut vis geht wieder nicht
                               SCRIPT5022: Syntax error, unrecognized expression: #view_tab_[{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery_png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery_png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery_png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":"
                              \n<audio_controls_autoplay=\"autoplay\"><source_src=\"http: mp3stream7_apasf_apa_at:8000/;stream_mp3\"_type="\&quot;audio/mp3\&quot;">ORF_"},"style":{"left":"902px","top":"376px","width":"324px","height":"72px"},"widgetSet":"basic"}]
                              jquery-1.11.2.min.js (1,12710)</source_src=\"http:></audio_controls_autoplay=\"autoplay\">
                              • wendy2702W Offline
                                wendy2702W Offline
                                Und was hast du als letztes vorher gemacht?
                                  b.roeske
                                  Habe in withges (radio) eingefügt
                                    b.roeske
                                    gb.error=function(a){throw new Error("Syntax error, unrecognized expression: "+a)},gb.uniqueSort=function
                                      wendy2702W Offline
                                        b.roeske
                                        das steht im browser wenn ich f12 drücke
                                          wendy2702W Offline
                                          Kannst du das Widget löschen
