  4. Vis startet nicht mehr
    6.0k
59 Beiträge 4 Kommentatoren 7.1k Aufrufe
  • apollon77A Offline
    Wo ist „da“? Screenshot? Exakte Meldung?
    Mal „sudo“ davor gesetzt?
      b.roeske
        b.roeske
        das steht jetzt bei vis
          b.roeske
          host.raspberrypi
          2018-06-03 11:28:12.120
          info
          Restart adapter system.adapter.wifilight.0 because enabled
          host.raspberrypi
          error
          instance system.adapter.wifilight.0 terminated with code 1 ()
          Caught
          error
          by controller[0]: at startup (bootstrap_node.js:160:9)
          Caught
          error
          by controller[0]: at run (bootstrap_node.js:394:7)
          Caught
          2018-06-03 11:28:12.119
          error
          by controller[0]: at Module.runMain (module.js:611:10)
          Caught
          error
          by controller[0]: at Function.Module._load (module.js:445:3)
          Caught
          error
          by controller[0]: at tryModuleLoad (module.js:453:12)
          Caught
          error
          by controller[0]: at Module.load (module.js:494:32)
          Caught
          error
          by controller[0]: at Object.Module._extensions..js (module.js:586:10)
          Caught
          2018-06-03 11:28:12.118
          error
          by controller[0]: at Module._compile (module.js:577:32)
          Caught
          error
          by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20)
          Caught
          error
          by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23)
          Caught
          2018-06-03 11:28:12.117
          error
          by controller[0]: TypeError: fns.adapter is not a function
          Caught
          error
          by controller[0]: ^
          Caught
          2018-06-03 11:28:12.116
          error
          by controller[0]: fns.adapter = fns.adapter(options);
          Caught
          error
          by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148
          host.raspberrypi
          2018-06-03 11:28:11.594
          info
          instance system.adapter.wifilight.0 started with pid 24955
          web.0
          2018-06-03 11:28:04.588
          info
          <==Disconnect system.user.defaultname from ::ffff:192.168.2.104 vis.0
          host.raspberrypi
          2018-06-03 11:27:41.572
          info
          Restart adapter system.adapter.wifilight.0 because enabled</anonymous>
          geändert: Code in Code-Tags; Homoran (Admin)
            Und du hast das chmod mit einem sudo davor gemacht?!
              b.roeske
              mit sudo davor bekomme ich das
                Und dann nochmal neu starten bitte
                  b.roeske
                  2018-06-03 12:43:15.031 - info: cloud.0 Connection changed: connect 2018-06-03 12:43:15.222 - info: radar.0 Init item Ich with { name: 'Ich', ip: 'localhost', macs: '', bluetooth: '', id: 'Ich', hasBT: false, printer: false, hasECB: false, hasIP: true } 2018-06-03 12:43:15.816 - info: host.raspberrypi instance system.adapter.systeminfo.0 started with pid 963 2018-06-03 12:43:17.720 - info: radar.0 radar adapter initialized 1 devices, ExternalNetwork = 300. 2018-06-03 12:43:17.722 - info: radar.0 radar set use of noble(true), fping(false), doMac(false), doHci(true), doBtv(false) and doUwz(UWZDE57612,1800,0,de,false). 2018-06-03 12:43:17.902 - info: radar.0 UWZ found the following (changed) warnings: No warnings 2018-06-03 12:43:17.962 - info: radar.0 ScanAll: From all 1 devices dedected 1 are whoHere: Ich 2018-06-03 12:43:18.183 - info: radar.0 Adapter initialization finished! 2018-06-03 12:43:19.271 - info: systeminfo.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v6.14.2 2018-06-03 12:43:20.021 - info: host.raspberrypi instance system.adapter.wifilight.0 started with pid 974 2018-06-03 12:43:20.656 - error: Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148 2018-06-03 12:43:20.657 - error: Caught by controller[0]: fns.adapter = fns.adapter(options); 2018-06-03 12:43:20.658 - error: Caught by controller[0]: ^ 2018-06-03 12:43:20.659 - error: Caught by controller[0]: TypeError: fns.adapter is not a function 2018-06-03 12:43:20.659 - error: Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23) 2018-06-03 12:43:20.660 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20) 2018-06-03 12:43:20.661 - error: Caught by controller[0]: at Module._compile (module.js:577:32) 2018-06-03 12:43:20.662 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10) 2018-06-03 12:43:20.663 - error: Caught by controller[0]: at Module.load (module.js:494:32) 2018-06-03 12:43:20.664 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12) 2018-06-03 12:43:20.665 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3) 2018-06-03 12:43:20.666 - error: Caught by controller[0]: at Module.runMain (module.js:611:10) 2018-06-03 12:43:20.667 - error: Caught by controller[0]: at run (bootstrap_node.js:394:7) 2018-06-03 12:43:20.668 - error: Caught by controller[0]: at startup (bootstrap_node.js:160:9) 2018-06-03 12:43:20.669 - error: host.raspberrypi instance system.adapter.wifilight.0 terminated with code 1 () 2018-06-03 12:43:20.670 - info: host.raspberrypi Restart adapter system.adapter.wifilight.0 because enabled 2018-06-03 12:43:21.240 - info: systeminfo.0 Startup Systeminfo Adapter systeminfo.0: { startup: '#\ngpio mode 1 output\n#rpi: echo none >/sys/class/leds/led0/trigger\necho none >/sys/class/leds/green_led/trigger', items: [ { name: 'System.Temperature', type: 'file', source: '/sys/class/thermal/thermal_zone0/temp', regexp: '', conv: 'number', role: 'value.temperature|°C', write: '', sched: '*:/2' }, { name: '-System.Memory_[used, free, available]', type: 'exec', source: 'free -k', regexp: 'Mem\\:\\s+\\d+\\s+(\\d+)\\s+(\\d+)\\s+\\d+\\s+\\d+\\s+(\\d+)', conv: '@/1000', role: 'number|MB', write: '', sched: '1 * * * * ' }, { name: 'NAS.Space_[total, used, free]', type: 'exec', source: 'df -BK', regexp: '/lic\\s+(\\d+)K\\s+(\\d+)K\\s+(\\d+)/m', conv: 'parseInt(@*1000/1024)/1000', role: 'number|MB', write: '', sched: '1 * * * * ' }, { name: 'GPIO.1', type: 'exec', source: 'gpio read 1', regexp: '', conv: '!parseInt(@)', role: 'switch', write: 'gpio write 1 @(@ ? \'0\' : \'1\')', sched: '*/20 * * * * *' }, { name: 'System.Led_Green', type: 'file', source: '/sys/class/leds/green_led/brightness', regexp: '', conv: 'boolean', role: 'switch', write: '@ ? \'1\' : \'0\' ', sched: '*/6:1' }, { name: 'System.Led_Red', type: 'file', source: '/sys/class/leds/red_led/brightness', regexp: '', conv: 'boolean', role: 'switch', write: '@ ? \'1\' : \'0\'', sched: '*/6:1' }, { name: 'Currency.[currency/rate]', type: 'web', source: 'http://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml', regexp: 'Cube.Cube.Cube[?(@.currency==\'USD\' || @.currency==\'GBP\')]', conv: 'xml', role: 'number | €/?', write: '', sched: '19:10:10' }, { name: 'Currency.BTC_CNY', type: 'web', source: 'https://www.alphavantage.co/query?function=CURRENCY_EXCHANGE_RATE&from_currency=BTC&to_currency=CNY&apikey=demo', regexp: '[0][4]', conv: 'json', role: 'number | CNY', write: '', sched: '19:10:10' }, { name: 'HP_Photosmart_7520.[name/value]', type: 'web', source: 'http://HPC56C03-PS7520/DevMgmt/ConsumableConfigDyn.xml', regexp: 'ConsumableInfo[?(@.Capacity)][(@.res = {name:@.ConsumableLabelCode, value: @.ConsumablePercentageLevelRemaining + \', \'+@.ConsumableIcon.Shape+\', \'+@.Installation.Date+\', \'+@.ConsumableSelectibilityNumber},\'res\')]', conv: 'xml', role: 'json', write: '', sched: '*/6:3' }, { name: 'UWZ', type: 'web', source: 'http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=UWZAT02402', regexp: '..translationsShortText.DE', conv: 'json', role: 'json', write: '', sched: '*:1' }, { name: '-TestSystem.processes.[command/pcpu]', type: 'info', source: 'processes', regexp: 'list[?(@.user == \'pi\')]', conv: '', role: '', write: '', sched: '*:2' }, { name: '-XS2.[name/value]', type: 'web', source: 'http://xs1/control.html\'', regexp: '{"l[?(@.value !== null )]": {"l[tr]": { \'![@.children()]\':0, name: {_eq:1}, value: {_eq:2, _conv:"parseInt(@.slice(0,-1))"}}, _filter: ($) => $[0].childNodes.length==3}}', conv: 'html', role: '', write: '', sched: '::/20' }, { name: 'MSFT.[]', type: 'web', source: 'https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&symbol=MSFT&apikey=demo', regexp: '[1:2][0:1]', conv: 'json', role: 'number', write: '', sched: '19:10:10' }, { name: 'System.[Mem_used, Mem_free, Swap_used]', type: 'info', source: 'mem', regexp: '[used,free,swapused]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Software.[]', type: 'info', source: 'osInfo', regexp: '', conv: '', role: 'string', write: '', sched: '/3:58' }, { name: 'System.Software.[]', type: 'info', source: 'versions', regexp: '', conv: '', role: 'string', write: '', sched: '/3:58' }, { name: 'System.FileSystem.[fs/use]', type: 'info', source: 'fsSize', regexp: '', conv: '', role: 'number|%', write: '', sched: '/3:58' }, { name: 'System.FileSystem.IO_[Read,Write]', type: 'info', source: 'fsStats', regexp: '[rx,wx]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Network.[iface/]', type: 'info', source: 'networkInterfaces', regexp: '', conv: '', role: '', write: '', sched: '/3:58' }, { name: 'System.Network.Connections.[name/value]', type: 'info', source: 'networkConnections', regexp: '[][!(@.localaddress == @.peeraddress ? null : {name:${@.protocol}:${@.localaddress.replace(/\\./g,\'_\')}:${@.localport}, value:${@.state}:${@.peeraddress}:${@.peerport}})]', conv: '', role: 'string', write: '', sched: ':/1' }, { name: 'System.Network.MB_[Received,Sent]', type: 'info', source: 'networkStats', regexp: '[rx,tx]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Network.FritzBox.[]', type: 'info', source: 'inetChecksite("http://fritz.box")', regexp: '', conv: '', role: '', write: '', sched: ':/1' }, { name: 'System.Network.Latency', type: 'info', source: 'inetLatency', regexp: '', conv: '', role: 'number|ms', write: '', sched: ':/1' }, { name: 'System.Load.[Load,User,System,Idle]', type: 'info', source: 'currentLoad', regexp: '[currentload, currentload_user, currentload_system, currentload_idle]', conv: 'parseInt(@_1000)/1000', role: 'number|ms', write: '', sched: '_::/10' }, { name: 'TankerKönig.[name/diesel]', type: 'web', source: 'https://creativecommons.tankerkoenig.de/json/list.php?lat=52.521&lng=13.438&rad=1.5&sort=dist&type=all&apikey=00000000-0000-0000-0000-000000000002', regexp: 'stations[?(@.name += ' ' + @.street, @.diesel)]', conv: 'json', role: 'number | €', write: '', sched: '/3:2' }, { name: 'TVProgramm.[name/text]', type: 'web', source: 'http://www.tvmovie.de/tv/programm-jetzt', regexp: '{"[0][][!(({name: @.name.split(' ')[0], text: @.name.split(' ').slice(@.name.slice(' ').indexOf('Seit')).join(' ')}))]":{'[section[class=item]]': {'name[span[class=h2]]':0}}}', conv: 'html', role: '', write: '', sched: '/1:0' } ], lang: 'de', latitude: 50.69386, longitude: 7.61537 }
                  2018-06-03 12:43:21.495 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Green
                  2018-06-03 12:43:21.501 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Red
                  2018-06-03 12:43:21.995 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.2
                  2018-06-03 12:43:22.253 - info: vis.0 vis license is OK.
                  2018-06-03 12:43:23.551 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for HP_Photosmart_7520.[name/value]
                  2018-06-03 12:43:30.100 - info: systeminfo.0 Adapter systeminfo.0 started and found 23/73 items/states to process.
                  2018-06-03 12:43:31.327 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once`
                  ! ~~[b]~~geändert: Code in Spoiler und Code-Tags; ~~[color]~~Homoran (Admin)[/color][/b][/tr]
                    Geht vis jetzt?
                      b.roeske
                      vis geht auf aber dann kommt das
                        Nicht dass das das erste Anzeichen für den kommenden Tod der SD-Karte ist und diese nur noch ReadOnly ist
                          b.roeske
                          Das hoffe ich nicht bin am überlegen alles zu formatieren und noch mal von forne zu beginnen :(
                            b.roeske
                            Hallo also habe neue sdkarte genommen und alles neu aufgebaut aber vis geht nicht!!!!!
                              b.roeske
                                Diese Meldungen sind beim ersten Aufruf von vis normal.
                                ioBroker versichert sich ob der Ordner nicht eventuell schon existieren sollte und legt dann einen neuen an.
                                  b.roeske
                                  Danke scheint alles wieder zu gehen :lol:
                                    Super!
                                    Dann markiere den Thread bitte als [gelöst]
                                      b.roeske
                                      Hallo zu früh gefreut vis geht wieder nicht
                                       SCRIPT5022: Syntax error, unrecognized expression: #view_tab_[{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery_png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery_png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery_png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":"
                                      \n<audio_controls_autoplay=\"autoplay\"><source_src=\"http: mp3stream7_apasf_apa_at:8000/;stream_mp3\"_type="\&quot;audio/mp3\&quot;">ORF_"},"style":{"left":"902px","top":"376px","width":"324px","height":"72px"},"widgetSet":"basic"}]
                                      jquery-1.11.2.min.js (1,12710)</source_src=\"http:></audio_controls_autoplay=\"autoplay\">
                                      • wendy2702W Online
                                        wendy2702W Online
                                        Und was hast du als letztes vorher gemacht?
                                          b.roeske
                                          Habe in withges (radio) eingefügt
