Vis startet nicht mehr
host.raspberrypi 2018-06-03 11:28:12.120 info Restart adapter system.adapter.wifilight.0 because enabled host.raspberrypi 2018-06-03 11:28:12.120 error instance system.adapter.wifilight.0 terminated with code 1 () Caught 2018-06-03 11:28:12.120 error by controller[0]: at startup (bootstrap_node.js:160:9) Caught 2018-06-03 11:28:12.120 error by controller[0]: at run (bootstrap_node.js:394:7) Caught 2018-06-03 11:28:12.119 error by controller[0]: at Module.runMain (module.js:611:10) Caught 2018-06-03 11:28:12.119 error by controller[0]: at Function.Module._load (module.js:445:3) Caught 2018-06-03 11:28:12.119 error by controller[0]: at tryModuleLoad (module.js:453:12) Caught 2018-06-03 11:28:12.119 error by controller[0]: at Module.load (module.js:494:32) Caught 2018-06-03 11:28:12.119 error by controller[0]: at Object.Module._extensions..js (module.js:586:10) Caught 2018-06-03 11:28:12.118 error by controller[0]: at Module._compile (module.js:577:32) Caught 2018-06-03 11:28:12.118 error by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20) Caught 2018-06-03 11:28:12.118 error by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23) Caught 2018-06-03 11:28:12.117 error by controller[0]: TypeError: fns.adapter is not a function Caught 2018-06-03 11:28:12.117 error by controller[0]: ^ Caught 2018-06-03 11:28:12.116 error by controller[0]: fns.adapter = fns.adapter(options); Caught 2018-06-03 11:28:12.116 error by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148 host.raspberrypi 2018-06-03 11:28:11.594 info instance system.adapter.wifilight.0 started with pid 24955 web.0 2018-06-03 11:28:04.588 info <==Disconnect system.user.defaultname from ::ffff:192.168.2.104 vis.0 host.raspberrypi 2018-06-03 11:27:41.572 info Restart adapter system.adapter.wifilight.0 because enabled</anonymous>geändert: Code in Code-Tags; Homoran (Admin)
2018-06-03 12:43:15.031 - info: cloud.0 Connection changed: connect 2018-06-03 12:43:15.222 - info: radar.0 Init item Ich with { name: 'Ich', ip: 'localhost', macs: '', bluetooth: '', id: 'Ich', hasBT: false, printer: false, hasECB: false, hasIP: true } 2018-06-03 12:43:15.816 - info: host.raspberrypi instance system.adapter.systeminfo.0 started with pid 963 2018-06-03 12:43:17.720 - info: radar.0 radar adapter initialized 1 devices, ExternalNetwork = 300. 2018-06-03 12:43:17.722 - info: radar.0 radar set use of noble(true), fping(false), doMac(false), doHci(true), doBtv(false) and doUwz(UWZDE57612,1800,0,de,false). 2018-06-03 12:43:17.902 - info: radar.0 UWZ found the following (changed) warnings: No warnings 2018-06-03 12:43:17.962 - info: radar.0 ScanAll: From all 1 devices dedected 1 are whoHere: Ich 2018-06-03 12:43:18.183 - info: radar.0 Adapter initialization finished! 2018-06-03 12:43:19.271 - info: systeminfo.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.systeminfo, node: v6.14.2 2018-06-03 12:43:20.021 - info: host.raspberrypi instance system.adapter.wifilight.0 started with pid 974 2018-06-03 12:43:20.656 - error: Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1148 2018-06-03 12:43:20.657 - error: Caught by controller[0]: fns.adapter = fns.adapter(options); 2018-06-03 12:43:20.658 - error: Caught by controller[0]: ^ 2018-06-03 12:43:20.659 - error: Caught by controller[0]: TypeError: fns.adapter is not a function 2018-06-03 12:43:20.659 - error: Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1148:23) 2018-06-03 12:43:20.660 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.wifilight/wifilight.js:20:20) 2018-06-03 12:43:20.661 - error: Caught by controller[0]: at Module._compile (module.js:577:32) 2018-06-03 12:43:20.662 - error: Caught by controller[0]: at Object.Module._extensions..js (module.js:586:10) 2018-06-03 12:43:20.663 - error: Caught by controller[0]: at Module.load (module.js:494:32) 2018-06-03 12:43:20.664 - error: Caught by controller[0]: at tryModuleLoad (module.js:453:12) 2018-06-03 12:43:20.665 - error: Caught by controller[0]: at Function.Module._load (module.js:445:3) 2018-06-03 12:43:20.666 - error: Caught by controller[0]: at Module.runMain (module.js:611:10) 2018-06-03 12:43:20.667 - error: Caught by controller[0]: at run (bootstrap_node.js:394:7) 2018-06-03 12:43:20.668 - error: Caught by controller[0]: at startup (bootstrap_node.js:160:9) 2018-06-03 12:43:20.669 - error: host.raspberrypi instance system.adapter.wifilight.0 terminated with code 1 () 2018-06-03 12:43:20.670 - info: host.raspberrypi Restart adapter system.adapter.wifilight.0 because enabled 2018-06-03 12:43:21.240 - info: systeminfo.0 Startup Systeminfo Adapter systeminfo.0: { startup: '#\ngpio mode 1 output\n#rpi: echo none >/sys/class/leds/led0/trigger\necho none >/sys/class/leds/green_led/trigger', items: [ { name: 'System.Temperature', type: 'file', source: '/sys/class/thermal/thermal_zone0/temp', regexp: '', conv: 'number', role: 'value.temperature|°C', write: '', sched: '*:/2' }, { name: '-System.Memory_[used, free, available]', type: 'exec', source: 'free -k', regexp: 'Mem\\:\\s+\\d+\\s+(\\d+)\\s+(\\d+)\\s+\\d+\\s+\\d+\\s+(\\d+)', conv: '@/1000', role: 'number|MB', write: '', sched: '1 * * * * ' }, { name: 'NAS.Space_[total, used, free]', type: 'exec', source: 'df -BK', regexp: '/lic\\s+(\\d+)K\\s+(\\d+)K\\s+(\\d+)/m', conv: 'parseInt(@*1000/1024)/1000', role: 'number|MB', write: '', sched: '1 * * * * ' }, { name: 'GPIO.1', type: 'exec', source: 'gpio read 1', regexp: '', conv: '!parseInt(@)', role: 'switch', write: 'gpio write 1 @(@ ? \'0\' : \'1\')', sched: '*/20 * * * * *' }, { name: 'System.Led_Green', type: 'file', source: '/sys/class/leds/green_led/brightness', regexp: '', conv: 'boolean', role: 'switch', write: '@ ? \'1\' : \'0\' ', sched: '*/6:1' }, { name: 'System.Led_Red', type: 'file', source: '/sys/class/leds/red_led/brightness', regexp: '', conv: 'boolean', role: 'switch', write: '@ ? \'1\' : \'0\'', sched: '*/6:1' }, { name: 'Currency.[currency/rate]', type: 'web', source: 'http://www.ecb.europa.eu/stats/eurofxref/eurofxref-daily.xml', regexp: 'Cube.Cube.Cube[?(@.currency==\'USD\' || @.currency==\'GBP\')]', conv: 'xml', role: 'number | €/?', write: '', sched: '19:10:10' }, { name: 'Currency.BTC_CNY', type: 'web', source: 'https://www.alphavantage.co/query?function=CURRENCY_EXCHANGE_RATE&from_currency=BTC&to_currency=CNY&apikey=demo', regexp: '[0][4]', conv: 'json', role: 'number | CNY', write: '', sched: '19:10:10' }, { name: 'HP_Photosmart_7520.[name/value]', type: 'web', source: 'http://HPC56C03-PS7520/DevMgmt/ConsumableConfigDyn.xml', regexp: 'ConsumableInfo[?(@.Capacity)][(@.res = {name:@.ConsumableLabelCode, value: @.ConsumablePercentageLevelRemaining + \', \'+@.ConsumableIcon.Shape+\', \'+@.Installation.Date+\', \'+@.ConsumableSelectibilityNumber},\'res\')]', conv: 'xml', role: 'json', write: '', sched: '*/6:3' }, { name: 'UWZ', type: 'web', source: 'http://feed.alertspro.meteogroup.com/AlertsPro/AlertsProPollService.php?method=getWarning&language=de&areaID=UWZAT02402', regexp: '..translationsShortText.DE', conv: 'json', role: 'json', write: '', sched: '*:1' }, { name: '-TestSystem.processes.[command/pcpu]', type: 'info', source: 'processes', regexp: 'list[?(@.user == \'pi\')]', conv: '', role: '', write: '', sched: '*:2' }, { name: '-XS2.[name/value]', type: 'web', source: 'http://xs1/control.html\'', regexp: '{"l[?(@.value !== null )]": {"l[tr]": { \'![@.children()]\':0, name: {_eq:1}, value: {_eq:2, _conv:"parseInt(@.slice(0,-1))"}}, _filter: ($) => $[0].childNodes.length==3}}', conv: 'html', role: '', write: '', sched: '::/20' }, { name: 'MSFT.[]', type: 'web', source: 'https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&symbol=MSFT&apikey=demo', regexp: '[1:2][0:1]', conv: 'json', role: 'number', write: '', sched: '19:10:10' }, { name: 'System.[Mem_used, Mem_free, Swap_used]', type: 'info', source: 'mem', regexp: '[used,free,swapused]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Software.[]', type: 'info', source: 'osInfo', regexp: '', conv: '', role: 'string', write: '', sched: '/3:58' }, { name: 'System.Software.[]', type: 'info', source: 'versions', regexp: '', conv: '', role: 'string', write: '', sched: '/3:58' }, { name: 'System.FileSystem.[fs/use]', type: 'info', source: 'fsSize', regexp: '', conv: '', role: 'number|%', write: '', sched: '/3:58' }, { name: 'System.FileSystem.IO_[Read,Write]', type: 'info', source: 'fsStats', regexp: '[rx,wx]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Network.[iface/]', type: 'info', source: 'networkInterfaces', regexp: '', conv: '', role: '', write: '', sched: '/3:58' }, { name: 'System.Network.Connections.[name/value]', type: 'info', source: 'networkConnections', regexp: '[][!(@.localaddress == @.peeraddress ? null : {name:${@.protocol}:${@.localaddress.replace(/\\./g,\'_\')}:${@.localport}, value:${@.state}:${@.peeraddress}:${@.peerport}})]', conv: '', role: 'string', write: '', sched: ':/1' }, { name: 'System.Network.MB_[Received,Sent]', type: 'info', source: 'networkStats', regexp: '[rx,tx]', conv: 'parseInt(@(1000/1024/1024))/1000', role: 'number|MB', write: '', sched: ':/1' }, { name: 'System.Network.FritzBox.[]', type: 'info', source: 'inetChecksite("http://fritz.box")', regexp: '', conv: '', role: '', write: '', sched: ':/1' }, { name: 'System.Network.Latency', type: 'info', source: 'inetLatency', regexp: '', conv: '', role: 'number|ms', write: '', sched: ':/1' }, { name: 'System.Load.[Load,User,System,Idle]', type: 'info', source: 'currentLoad', regexp: '[currentload, currentload_user, currentload_system, currentload_idle]', conv: 'parseInt(@_1000)/1000', role: 'number|ms', write: '', sched: '_::/10' }, { name: 'TankerKönig.[name/diesel]', type: 'web', source: 'https://creativecommons.tankerkoenig.de/json/list.php?lat=52.521&lng=13.438&rad=1.5&sort=dist&type=all&apikey=00000000-0000-0000-0000-000000000002', regexp: 'stations[?(@.name += ' ' + @.street, @.diesel)]', conv: 'json', role: 'number | €', write: '', sched: '/3:2' }, { name: 'TVProgramm.[name/text]', type: 'web', source: 'http://www.tvmovie.de/tv/programm-jetzt', regexp: '{"[0][][!(({name: @.name.split(' ')[0], text: @.name.split(' ').slice(@.name.slice(' ').indexOf('Seit')).join(' ')}))]":{'[section[class=item]]': {'name[span[class=h2]]':0}}}', conv: 'html', role: '', write: '', sched: '/1:0' } ], lang: 'de', latitude: 50.69386, longitude: 7.61537 }
2018-06-03 12:43:21.495 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Green
2018-06-03 12:43:21.501 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for System.Led_Red
2018-06-03 12:43:21.995 - info: vis.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.vis, node: v6.14.2
2018-06-03 12:43:22.253 - info: vis.0 vis license is OK.
2018-06-03 12:43:23.551 - warn: systeminfo.0 Error TypeError: Cannot read property 'toString' of null in doPoll for HP_Photosmart_7520.[name/value]
2018-06-03 12:43:30.100 - info: systeminfo.0 Adapter systeminfo.0 started and found 23/73 items/states to process.
2018-06-03 12:43:31.327 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once`
! ~~[b]~~geändert: Code in Spoiler und Code-Tags; ~~[color]~~Homoran (Admin)[/color][/b][/tr] -
Hallo zu früh gefreut vis geht wieder nicht
SCRIPT5022: Syntax error, unrecognized expression: #view_tab_[{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery_png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery_png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery_png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":" \n<audio_controls_autoplay=\"autoplay\"><source_src=\"http: mp3stream7_apasf_apa_at:8000/;stream_mp3\"_type="\"audio/mp3\"">ORF_"},"style":{"left":"902px","top":"376px","width":"324px","height":"72px"},"widgetSet":"basic"}] jquery-1.11.2.min.js (1,12710)</source_src=\"http:></audio_controls_autoplay=\"autoplay\">
