  4. Text2command stürzt ab
5 Beiträge 2 Kommentatoren 413 Aufrufe
    martinschm
    ich hab das Problem, das mein text2command abstürzt. Ich will über Telegram mit dem Befehl "Wohnzimmertemperatur" die Temperatur genannt bekommen, zum Einsatz kommt ein Mi Smart Home Temperatur Sensor
    text2command Version 1.2.1
    telegram 1.1.4
    Das Log
    host.ioPi	2018-05-21 17:36:56.527	error	instance system.adapter.text2command.0 terminated with code 0 (OK)
    Caught	2018-05-21 17:36:56.527	error	by controller[0]: at Socket.emit (events.js:188:7)
    Caught	2018-05-21 17:36:56.526	error	by controller[0]: at emitOne (events.js:96:13)
    Caught	2018-05-21 17:36:56.526	error	by controller[0]: at Socket. (/opt/iobroker/node_modules/redis/index.js:274:27)
    Caught	2018-05-21 17:36:56.525	error	by controller[0]: at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
    Caught	2018-05-21 17:36:56.525	error	by controller[0]: at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
    Caught	2018-05-21 17:36:56.525	error	by controller[0]: at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:824:9)
    Caught	2018-05-21 17:36:56.524	error	by controller[0]: at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
    Caught	2018-05-21 17:36:56.524	error	by controller[0]: at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:287:17)
    Caught	2018-05-21 17:36:56.524	error	by controller[0]: at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.text2command/lib/simpleControl.js:410:21)
    Caught	2018-05-21 17:36:56.523	error	by controller[0]: at parseTemplates (/opt/iobroker/node_modules/iobroker.text2command/lib/simpleControl.js:657:29)
    Caught	2018-05-21 17:36:56.522	error	by controller[0]: TypeError: Cannot read property 'length' of null
    text2command.0	2018-05-21 17:36:56.494	info	terminating
    text2command.0	2018-05-21 17:36:55.985	error	at Socket.emit (events.js:188:7)
    text2command.0	2018-05-21 17:36:55.985	error	at emitOne (events.js:96:13)
    text2command.0	2018-05-21 17:36:55.985	error	at Socket. (/opt/iobroker/node_modules/redis/index.js:274:27)
    text2command.0	2018-05-21 17:36:55.985	error	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
    text2command.0	2018-05-21 17:36:55.985	error	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
    text2command.0	2018-05-21 17:36:55.985	error	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:824:9)
    text2command.0	2018-05-21 17:36:55.985	error	at normal_reply (/opt/iobroker/node_modules/redis/index.js:726:21)
    text2command.0	2018-05-21 17:36:55.985	error	at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:287:17)
    text2command.0	2018-05-21 17:36:55.985	error	at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.text2command/lib/simpleControl.js:410:21)
    text2command.0	2018-05-21 17:36:55.985	error	at parseTemplates (/opt/iobroker/node_modules/iobroker.text2command/lib/simpleControl.js:657:29)
    text2command.0	2018-05-21 17:36:55.985	error	TypeError: Cannot read property 'length' of null
    text2command.0	2018-05-21 17:36:55.984	error	uncaught exception: Cannot read property 'length' of null
    text2command.0	2018-05-21 17:36:55.907	info	Say ID mihome.0.devices.weather_v1_158d0001fa5cab.temperature
    text2command.0	2018-05-21 17:36:55.900	warn	Timeout for external processor: telegram.0.communicate.users
    text2command.0	2018-05-21 17:36:55.898	info	processText: "Wohnzimmertemperatur"
      martinschm
      Ist mir grade noch in den Logs aufgefallen
      text2command.0	2018-05-21 17:50:18.097	warn	Timeout for external processor: telegram.0.communicate.users
      text2command.0	2018-05-21 17:50:18.095	info	processText: "aussen"
      text2command.0	2018-05-21 17:50:17.086	info	processText: "aussen"
      text2command.0	2018-05-21 17:50:17.069	info	processText: "aussen"
      • apollon77A Offline
        Wie sieht die konfig aus? Welchen Typ der Anfrage hast du genommen? Er wartet auf die Ausführung einer Funktion … nicht das du den falschen Typ nutzt
          martinschm
          Hier Screenshots
            Worum ist das „id bearbeiter“ so gesetzt wie es ist? Wenn du das nicht nutzt dann nimm das mal raus
