  4. Verbindung zur (Free-) Cloud nicht möglich
10 Beiträge 4 Kommentatoren 1.2k Aufrufe
  • C Offline
    Cavaradossi
    Hallo Forum,
    ich nutze ioBroker seit ca. 4 Wochen auf dem Pi, um PCs mit dem Echo fernzusteuern. Heute morgen funktioniert das leider nicht mehr, weil vermutlich die Cloudverbindung streikt. Im Log finde ich eine ganze Reihe dieser Einträge ->
    cloud.0	2018-05-12 07:38:31.380	info	Connection changed: io client disconnect
    cloud.0	2018-05-12 07:38:31.379	error	Unknown api-key
    cloud.0	2018-05-12 07:38:31.261	info	Trying to connect as system.user.admin from undefined
    cloud.0	2018-05-12 07:37:37.661	info	Request enums
    cloud.0	2018-05-12 07:37:33.212	info	Request devices
    cloud.0	2018-05-12 07:37:33.207	info	Request devices
    cloud.0	2018-05-12 07:37:31.187	info	Connection changed: io client disconnect
    cloud.0	2018-05-12 07:37:31.179	info	Adapter redirected temporally to "https://iobroker.net:10560" in one minute. Reason: command from server
    cloud.0	2018-05-12 07:37:31.067	info	Trying to connect as system.user.admin from undefined
    cloud.0	2018-05-12 07:37:30.772	info	Connecting with https://iobroker.net:10555 with "xxxx@googlemail.com_c36290a0-461e-11e8-8d9b-f52bcd34a72"
    cloud.0	2018-05-12 07:37:30.618	info	starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.1
    cloud.0	2018-05-12 07:35:17.532	info	terminating
    cloud.0	2018-05-12 07:35:12.538	info	Connection changed: io client disconnect
    cloud.0	2018-05-12 07:35:12.535	error	Unknown api-key
    cloud.0	2018-05-12 07:35:12.384	info	Trying to connect as system.user.admin from undefined
    cloud.0	2018-05-12 07:34:12.525	info	Connection changed: io client disconnect
    cloud.0	2018-05-12 07:34:12.523	error	Unknown api-key
    cloud.0	2018-05-12 07:34:12.377	info	Trying to connect as system.user.admin from undefined
    cloud.0	2018-05-12 07:33:12.514	info	Connection changed: io client disconnect
    cloud.0	2018-05-12 07:33:12.512	error	Unknown api-key
    cloud.0	2018-05-12 07:33:12.363	info	Trying to connect as system.user.admin from undefined
    cloud.0	2018-05-12 07:32:12.499	info	Connection changed: io client disconnect
    cloud.0	2018-05-12 07:32:12.498	error	Unknown api-key
    cloud.0	2018-05-12 07:32:12.363	info	Trying to connect as system.user.admin from undefined
    cloud.0	2018-05-12 07:31:12.523	info	Connection changed: io client disconnect
    cloud.0	2018-05-12 07:31:12.520	error	Unknown api-key
    cloud.0	2018-05-12 07:31:12.343	info	Trying to connect as system.user.admin from undefined
    cloud.0	2018-05-12 07:30:12.477	info	Connection changed: io client disconnect
    cloud.0	2018-05-12 07:30:12.475	error	Unknown api-key
    Auf https://iobroker.net/ erhalte ich die Fehlermeldung "IOBROKER IST NOCH NICHT VERBUNDEN.
    DRÜCKEN SIE HIER, UM DIE VERBINDUNG HERZUSTELLEN."
    Ist der api-key zeitlich begrenzt oder liegt ein anderer Fehler vor. Ich hoffe, ihr könnt helfen?
    Danke und Gruß
    Cavaradossi
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Moin,
      @Cavaradossi:
      Die Zeile im Log hast Du gesehen?
      Prüfe mal den Key im Adapter.
      Gruß,
      Eric
      Von unterwegs getippert
      • C Offline
        Cavaradossi
        Mojn Eric,
        Danke für deine Antwort.
        Der api-key ist in der Adapterkonfiguration eingetragen mit der Instanz 'web [web.0]'. Deswegen meine Frage, ob der key zeitlich begrenz ist, denn auch eine Verbindung auf https://iobroker.net/ scheitert.
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Kann das Verhalten nachstellen.
          Starte den Adapter bitte mal neu, warte ein wenig und schau dann mal.
          Gruß,
          Eric
          • C Offline
            Cavaradossi
            Keine Änderung ->
            Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
            cloud.0	2018-05-12 08:16:05.812	info	Connection changed: io client disconnect
            cloud.0	2018-05-12 08:16:05.808	error	Unknown api-key
            cloud.0	2018-05-12 08:16:05.656	info	Trying to connect as system.user.admin from undefined
            cloud.0	2018-05-12 08:15:05.609	info	Connection changed: io client disconnect
            cloud.0	2018-05-12 08:15:05.604	info	Adapter redirected temporally to 'https://iobroker.net:10560' in one minute. Reason: command from server
            cloud.0	2018-05-12 08:15:05.460	info	Trying to connect as system.user.admin from undefined
            cloud.0	2018-05-12 08:15:05.193	info	Connecting with https://iobroker.net:10555 with 'xxxx@googlemail.com_c36290a0-461e-11e8-8d9b-f52bcd34a72'
            cloud.0	2018-05-12 08:15:05.063	info	starting. Version 2.5.0 in /opt/iobroker/node_modules/iobroker.cloud, node: v6.14.1
            host.raspberrypi	2018-05-12 08:15:02.982	info	instance system.adapter.cloud.0 started with pid 880
            Was mich ein wenig wundert, sind diese Zeilen ->
            Liegt möglicherweise ein temporärers Problem beim Server vor?
              Kampfratte
              Ich habe das selbe Problem, Cavaradossi. Und damit Eric nicht alles doppelt schreiben muss, werde ich nun auch hier weiter sein. Ich habe mit Eric im Facebook geschrieben wegen diesem Problem.
              • eric2905E Offline
                eric2905E Offline
                eric2905
                Ich brauche mal einen Tester :
                Ich habe mir auf der Webseite der Free-Cloud einen neuen API-Key erzeugt und den in den Adapter eingetragen. Seitdem läuft er bei mir wieder.
                Kann das mal bitte gegengetestet werden?
                Gruß,
                Eric
                • C Offline
                  Cavaradossi
                  Hallo Eric,
                  Danke für den Hinweis. Mit einem neuen api-key funktionioert es jetzt wieder.
                  Cavaradossi
                    Kampfratte
                    @eric2905:
                    Gruß,
                    Eric
                    Von unterwegs getippert `
                    Hallo Eric, habe dies auch getan. Und nun funktioniert es auch bei mir wieder. Vielen Dank für deine Mühe.
                    • L Offline
                      LJSven
                      neuen Key generiert, funktioniert wieder
