  4. Beispielskript gesucht
81 Beiträge 4 Kommentatoren 10.2k Aufrufe
    ich habe die Logik nicht verifizieren können, da ich die Datenpunkte, die du verwendest nicht kenne.
    Hier die Korrektur der offensichlichen Fehler:
    Export:
    <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="D2-i%o~h}[C(XOb!uy@W" x="-2062" y="-1687"><mutation items="1"></mutation>
    <value name="OID0"><shadow type="field_oid" id="xO2djiTabS@KS{GP@E#."><field name="oid">javascript.0.Bluetooth.Device.7c2f8099bb0f.details.address</field></shadow></value>
    <statement name="STATEMENT"><block type="controls_if" id=".2TLXB%Ihqc-Nz6h2pM5"><mutation elseif="1"></mutation>
        <value name="IF0"><block type="logic_operation" id="WX]:)kErZEWR~P/+8_qo" inline="false"><field name="OP">OR</field>
            <value name="A"><block type="logic_compare" id="`GUi=#sx:|j*-ENfTOls"><field name="OP">EQ</field>
                <value name="A"><block type="get_value" id="6upmqp@Z;aum/E9cRx36"><field name="ATTR">val</field>
                    <field name="OID">javascript.0.Bluetooth.Device.7c2f8099bb0f.lastState</field></block></value>
                <value name="B"><block type="logic_boolean" id="VUj{DZ@GZGGJ-Vi`^/r_"><field name="BOOL">TRUE</field></block></value></block></value>
            <value name="B"><block type="logic_compare" id="_x?KoYGn@yfWe~T~rk(Y"><field name="OP">EQ</field>
                <value name="A"><block type="get_value" id="`P**u99%9*P;3G;;XF!5"><field name="ATTR">val</field>
                    <field name="OID">javascript.1.Bluetooth.Device.7c2f8099bb0f.lastState</field></block></value>
                <value name="B"><block type="logic_boolean" id="oD2_4ON;VUZV4%5fM]s!"><field name="BOOL">TRUE</field></block></value></block></value></block></value>
        <statement name="DO0"><block type="control_ex" id="NC)x*;ROvB[{fM(},rQV"><field name="TYPE">false</field>
            <value name="OID"><shadow type="field_oid" id="Od_!11i~z}wdSJqf3QuK"><field name="oid">hm-rega.0.1687</field></shadow></value>
            <value name="VALUE"><shadow type="logic_boolean" id="NY[gH1t@k9RVRf#st-;j"><field name="BOOL">TRUE</field></shadow></value>
            <value name="DELAY_MS"><shadow type="math_number" id="}=Ic%oJ1lB/MV9ST?tgJ"><field name="NUM">0</field></shadow></value></block></statement>
        <value name="IF1"><block type="logic_operation" id=":w^:`0%(L..(6eM%qfjJ" inline="false"><field name="OP">AND</field>
            <value name="A"><block type="logic_compare" id="E)]tXcx:snc?gx1O~`O="><field name="OP">EQ</field>
                <value name="A"><block type="get_value" id="s7ktjeP/1!B[-z^(|U(j"><field name="ATTR">val</field>
                <value name="B"><block type="logic_boolean" id="4xE6d:_W{W{.5qiI-wY~"><field name="BOOL">FALSE</field></block></value></block></value>
            <value name="B"><block type="logic_compare" id="n1kiqJJa]GaUR|9.w^?s"><field name="OP">EQ</field>
                <value name="A"><block type="get_value" id="wjs78#p7)a}hV@B(MhYV"><field name="ATTR">val</field>
                <value name="B"><block type="logic_boolean" id="7?OvELFFOp*|eO}y[Gy."><field name="BOOL">FALSE</field></block></value></block></value></block></value>
        <statement name="DO1"><block type="control_ex" id="[F|F@%iemyK(/_0xYDsB"><field name="TYPE">false</field>
            <value name="OID"><shadow type="field_oid" id="|8Vux0v5{#ijYLLk]HDE"><field name="oid">hm-rega.0.1687</field></shadow></value>
            <value name="VALUE"><shadow type="logic_boolean" id="WUiWr]QvMwFa=]]2cHVN"><field name="BOOL">FALSE</field></shadow></value>
            <value name="DELAY_MS"><shadow type="math_number" id="^b]9Dx,]|?dIJ[l0eEU`"><field name="NUM">180000</field></shadow></value></block></statement></block></statement></block></xml>
    um das verifizieren zu können bitte noch die letzten Fragen beantworten:
    ~~@Homoran:~~
    > Womit erfasst du deinen G-Tag?
    > Wie sieht der Datenpunkt dazu aus?
    > - aktualisiert sich dieser korrekt?
    > - hast du das ggf. mal geloggt falsch sich der Zustand (zu) schnell ändert? `
    • MathiasJM Offline
      MathiasJM Offline
      MathiasJ
      nein, die Datenpunkte ändern sich nicht.
      Das ist ja das, warum ich auf dem Schlauch stehe.
      Wenn ich den Skript aktualisiere, dann sehe ich mich für eine Sekunde wieder als anwesend.
      Gruß,
      Mathias
      IObroker auf dem NUC als VM.
      • MathiasJM Offline
        MathiasJM Offline
        MathiasJ
        ach ja,
        als Datenlogger habe ich das hier genommen:
        viewtopic.php?f=21&t=2513&p=28266#p28266
        Gruß,
        Mathias
          @MathiasJ:
          nein, die Datenpunkte ändern sich nicht. `
          Dann kann das Skript auch nicht zaubern.
          Ich weiß zwar immer noch nicht wo die Infos für die G-Tag Datenpunkte (javascrript.0.BLuetooth.Device.7cxxxxx.detail….) herkommen, aber hast du es mal mit dem Radar Adapter versucht?
          da BT nicht immer stabil sein muss kann man da einstellen wann man als abwesend gelten will. Dazu müssen dan x aufeinanderfolgende Scans negativ sein. Einzelne Aussetzer haben dann keine Folgen.
            @MathiasJ:
            viewtopic.php?f=21&t=2513&p=28266#p28266 `
            Das ist nicht der Logger, das ist der Scanner.
            Ich fragte ob du den Zustand des ominösen Datenpunktes mal mit history o.a. geloggt hast um zu sehen ob und wie oft sich dieser Datenpunkt ändert.
            • MathiasJM Offline
              MathiasJM Offline
              MathiasJ
              Nein das habe ich noch nicht.
              Per Radar wird nichts erkannt.
              Per BLE wird leider keine Anwesenheit getriggert.
              Gruß,
              Mathias
                ich glaube ich weiß jetzt wo es bei dir gedanklich hakt :idea:
                und jetzt mit Tastatur geht es auch besser als heute nachmittag am Handy.
                Die Skripte arbeiten ereignisgesteuert.
                Es gibt zwei arten von Triggern, einmal ein "echtes" Ereignis - wenn sich etwas ändert und einmal zeitgesteuert.
                Da ändert sich dann die Zeit ;-)
                Das BLE Script von ruhr 70 arbeitet zeitgesteuert und scannt alle x Minuten nach Devices in der Umgebung. Sobald ein bekanntes Device in der Umgebung erkannt wird wird dieses auf "here" gesetzt. Wenn der Scan x-mal hintereinender das Device nicht mehr findet wird dieses Device auf "not here" gesetzt.
                Dein Skript reagiert jetzt auf diese Änderung!!!
                sollte sich der G-Tag nicht ausserhalb der Reichweite des Scanners befunden haben wird dein Skript niemals eine Pushnachricht senden. Das passiert erst, wenn du das Haus betreten hats. oder nach Anwesenheit das Haus verlassen hast.
                • MathiasJM Offline
                  MathiasJM Offline
                  MathiasJ
                  so soll es auch sein!
                  Ich will nur eine pushnachricht, wenn das haus betreten oder verlassen wird.
                  Aber:
                  Mit dem Blocky-Skript habe ich das Problem, dass ich nach bereits einer Sekunde wieder als abwesend gelistet bin, obwohl ich da bin.
                  das ist mein problem….....
                  Gruß,
                  Mathias
                    Passiert das immer wieder von selbst, oder nur wenn du das Skript startest?
                    Deswegen wäre ja das loggen dieses Datenpunktes interessant.
                    Dann wüsste man was passiert
                    • MathiasJM Offline
                      MathiasJM Offline
                      MathiasJ
                      Ich bin nur online, wenn ich den Skript starte bzw aktualisiere.
                      Ich habe nun wieder Radar installiert, aber ich sehe hier gar keine Objekte.
                      Nun deinstalliere ich radar wieder.
                      Gruß,
                      Mathias
                        @MathiasJ:
                        Ich habe nun wieder Radar installiert, aber ich sehe hier gar keine Objekte. `
                        jetzt wird das loggen des Wertes noch interessanter was ruhr70s Skript mit dem Datenpunkt anstellt.
                        (kann aber sein, dass zwei Skripte/Adapter nicht beide auf den BT zugreifen können)
                        Da ich bereits ganz zu Beginn geschrieben hab, dass ich nicht weiß, ob dein "schreibe" Block ok ist, probiere bitte mal das hier:
                        <block xmlns="http://www.w3.org/1999/xhtml" type="on_ext" id="D2-i%o~h}[C(XOb!uy@W" x="-2087" y="-1612"><mutation items="1"></mutation>
                        <value name="A"><block type="logic_compare" id="GUi=#sx:|j*-ENfTOls"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="6upmqp@Z;aum/E9cRx36"><field name="ATTR">val</field> <field name="OID">javascript.0.Bluetooth.Device.7c2f8099bb0f.lastState</field></block></value> <value name="B"><block type="logic_boolean" id="VUj{DZ@GZGGJ-Vi^/r_"><field name="BOOL">TRUE</field></block></value></block></value>
                        <value name="A"><block type="get_value" id="P**u99%9*P;3G;;XF!5"><field name="ATTR">val</field> <field name="OID">javascript.1.Bluetooth.Device.7c2f8099bb0f.lastState</field></block></value> <value name="B"><block type="logic_boolean" id="oD2_4ON;VUZV4%5fM]s!"><field name="BOOL">TRUE</field></block></value></block></value></block></value> <statement name="DO0"><block type="control" id="T[mGg14Xs,]PF6H_sS%d"><mutation delay_input="true"></mutation> <field name="OID">Object ID</field> <field name="WITH_DELAY">TRUE</field> <field name="DELAY_MS">180000</field> <field name="UNIT">ms</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="VALUE"><block type="logic_boolean" id="n;ZR(XW?9yk{fFyCYF?"><field name="BOOL">TRUE</field></block></value></block></statement>
                        <value name="IF1"><block type="logic_operation" id=":w^:0%(L..(6eM%qfjJ" inline="false"><field name="OP">AND</field> <value name="A"><block type="logic_compare" id="E)]tXcx:snc?gx1O~O="><field name="OP">EQ</field>
                        <statement name="DO1"><block type="control" id="O:/Db:znWh[1d3TDN3Z%"><mutation delay_input="true"></mutation>
                        <value name="VALUE"><block type="logic_boolean" id=";G6D5jjoe2G~ygIn/}-r"><field name="BOOL">FALSE</field></block></value></block></statement></block></statement></block>
                        Bitte an zwei Stellen noch deinen rega-Datenpunkt eintragen
                        Raiiner
                        • MathiasJM Offline
                          MathiasJM Offline
                          MathiasJ
                          wird das ein neues Script?
                          Werden da datenpunkte getriggert?
                          ich möchte nur wissen, wo ich das eingeben muß.
                          Gruß,
                          Mathias
                            Hast du meine letzte Änderungen von 21:45 noch nicht getestet?
                            Die solltest du doch auch importieren.
                            Das funktioniert jetzt genau so.
                            Edit: ich sehe gerade ich habe in beiden Fällen 3 Minuten Verzögerung drin, bitte auch anpassen.
                            Was soll die eigentlich?
                            • MathiasJM Offline
                              MathiasJM Offline
                              MathiasJ
                              die verzögerung soll bewirken, dass z.B. die heizung im Winter nicht gleich aus- und an geht, wenn man mal nicht im Scanbereich ist.
                              So hat die Heizsteuerung 3 Minuten Luft, wenn ein paar Scans daneben gehen.
                              Gruß,
                              Mathias
                                Das passiert aber nicht.
                                Die Änderung wird nur 3 Minuten verzögert, egal ob du nach zwei Minuten wieder da bist.
                                Und welche versionen hast du jetzt schon getestet?
                                Gruß Rainer
                                • MathiasJM Offline
                                  MathiasJM Offline
                                  MathiasJ
                                  ich habe beide Codes mal als Test-Skripte angelegt.
                                  Nun habe ich das gleiche Problem wieder.
                                  Eine Frage:
                                  Wenn ich alle Skripte deaktiviere, besteht dann die Möglichkeit, dass ich in Radar doch noch was sehe?
                                  Dann würde ich es wieder installieren.
                                  Ich habe nicht nur schreibe versucht. ich habe aber immer das Problem, dass ich nach der Aktualisierung des Skriptes für eine Sekunde da bin. Danach bin ich wieder weg…......
                                  Gruß,
                                  Mathias
                                  • MathiasJM Offline
                                    MathiasJM Offline
                                    MathiasJ
                                    Nun habe ich radar nochmals installiert.
                                    Im Log sehe ich, dass alle items auf true gesetzt sind. In den Objekten habe ich jedoch nichts.
                                    ich denke, ich werde mal Ruhr fragen, wie er Sysvar der HM auf An- bzw abwesend setzen will.
                                    Vllt geht das ja gar nicht bzw seine Skripte sind nur für IObroker gedacht.
                                    Gruß,
                                    Mathias
                                      @MathiasJ:
                                      Vllt geht das ja gar nicht bzw seine Skripte sind nur für IObroker gedacht. `
                                      Natürlich, wofür den sonst.
                                      Mit deinem Blockly verknüpfst du das dann mit hm.
                                      Aber so lange du mir nicht sagst wie sich die Datenpunkte fes BLE Scripts verändern kann ich dir nicht mehr helfen.
                                      • MathiasJM Offline
                                        MathiasJM Offline
                                        MathiasJ
                                        Dankeschön für Deine Hilfe.
                                        Wie soll ich feststellen, wie die Datenpunkte sich ändern?
                                        Ich kann Dir nur schreiben, wie sie sich ändern sollen.
                                        Wenn ich aus dem Haus gehe, nehme ich den G-Tag mit. Das heißt G-Tag nicht erreichbar. Somit bin ich abwesend.
                                        Mehr weiß ich auch nicht.
                                        Ich denke, ich werde den Wunsch nach einer anständigen Anwesenheitskennung der Homematic zu Grabe tragen.
                                        Anwesenheit per Fritzbox ist zu unsicher,
                                        Enocean Piotrackker nicht in der gesamten Wohnung erreichbar,
                                        BLE anscheinend nicht machbar..
                                        Beide PI 2B sind heruntergefahren. Morgen mache ich die SD-Karten platt. Was ich mit den Raspberries anstelle, weiß ich noch nicht.
                                        Trotzdem danke, Mathias
                                        P.S. kann bitte jemand den Treat als gelöst markieren? Für mich ist er gelöst bzw nicht machbar. Danke
                                        Gesendet von meinem SM-N915FY mit Tapatalk
                                          @MathiasJ:
                                          Wie soll ich feststellen, wie die Datenpunkte sich ändern? `
                                          Wie bereits mehrfach geschrieben könntest du sie mit history loggen und sehen ob und wann er sich geändert hat.
                                          Außerdem hast du mir immer noch nicht gesagt, was das für ein Datenpunkt ist.
                                          Gruß Rainer
