  4. [Vorlage] todoist.com To-Do-Listen Script für VIS
    6.0k
133 Beiträge 29 Kommentatoren 32.4k Aufrufe 20 Beobachtet
    tempestas
    Also die Fehlermeldungen kommen leider weiter.
    Es bezieht sich aber augenscheinlich auf den Bereich, den ich NICHT geändert habe.
    host.iobrokerNUC 2018-03-16 07:55:01.368 error instance system.adapter.javascript.1 terminated with code 0 (OK)
    Caught 2018-03-16 07:55:01.368 error by controller[0]: at IncomingMessage.g (events.js:292:16)
    Caught 2018-03-16 07:55:01.367 error by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12)
    Caught 2018-03-16 07:55:01.367 error by controller[0]: at Request.emit (events.js:188:7)
    Caught 2018-03-16 07:55:01.367 error by controller[0]: at emitOne (events.js:96:13)
    Caught 2018-03-16 07:55:01.367 error by controller[0]: at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10)
    Caught 2018-03-16 07:55:01.367 error by controller[0]: at Request.emit (events.js:191:7)
    Caught 2018-03-16 07:55:01.367 error by controller[0]: at emitTwo (events.js:106:13)
    Caught 2018-03-16 07:55:01.367 error by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
    Caught 2018-03-16 07:55:01.366 error by controller[0]: at Request._callback (script.js.common.Einkauf.todoist_alexa_listen2:23:34)
    Caught 2018-03-16 07:55:01.366 error by controller[0]: at Object.parse (native)
    Caught 2018-03-16 07:55:01.364 error by controller[0]: SyntaxError: Unexpected token I in JSON at position 0
    javascript.1 2018-03-16 07:55:01.187 error at IncomingMessage.g (events.js:292:16)
    javascript.1 2018-03-16 07:55:01.187 error at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1085:12)
    javascript.1 2018-03-16 07:55:01.187 error at Request.emit (events.js:188:7)
    javascript.1 2018-03-16 07:55:01.187 error at emitOne (events.js:96:13)
    javascript.1 2018-03-16 07:55:01.187 error at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1163:10)
    javascript.1 2018-03-16 07:55:01.187 error at Request.emit (events.js:191:7)
    javascript.1 2018-03-16 07:55:01.187 error at emitTwo (events.js:106:13)
    javascript.1 2018-03-16 07:55:01.187 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:186:22)
    javascript.1 2018-03-16 07:55:01.187 error at Request._callback (script.js.common.Einkauf.todoist_alexa_listen2:23:34)
    javascript.1 2018-03-16 07:55:01.187 error at Object.parse (native)
    javascript.1 2018-03-16 07:55:01.187 error SyntaxError: Unexpected token I in JSON at position 0
    javascript.1 2018-03-16 07:55:01.171 error uncaught exception: Unexpected token I in JSON at position 0
    Seltsamerweise kommt dieser Fehler auch nicht dauernd, obwohl der Schedule auf 1 Minute eingestellt ist sondern eben hier um 7:55h und davor um 6:59h? Jemand ne Idee?
    Nachtrag: entgegen meiner gestrigen Vermutung kommt der Fehler offenbar auch, wenn die Liste befüllt ist.
    Abseits vom Fehler: das hinzufügen von Extern (ohne Alexa) scheitert glaube ich i.W. am uniquie identifier, der benötigt wird. Was das nun wieder ist (außer dem rein vom Namen her offensichtlichem) und wie ich damit umgehe muss ich noch versuchen zu finden und zu verstehen
    <size="85">ioBroker | 21 Adapter | Ubuntu Server | intel NUC | Homematic CCU2 | Hue | Osram Lightify| Sonos | 2x Instar Cam | Samsung Tab A 2016 im Holzrahmen| 3x Echo dot | 1x Echo | Neato Botvac D5</size>
      tempestas
      Guten morgen zusammen,
      ich habe das Thema weiter bearbeitet. Herausgekommen ist jetzt, dass ich die Zusammenführung meiner "manuellen" (d.h. am Tablet zu bedienenden) Liste und der todoist Alexa Liste soweit fertig habe, dass ich via Alexa Einkäufe hinzufügen kann und via Eingabe am Tablet auch. Diese Eingaben werden dann auch auf der TODOIST Liste berücksichtigt. Es funktioniert sowohl das hinzufügen als auch das löschen einzelner Dinge.
      Was noch fehlt ist jetzt die Rückkopplung in die andere Richtung, also ich füge etwas via Alexa hinzu und es wird entsprechend auf dem Tablet markiert (es soll ja nicht nur in die Liste gehen sondern der jeweilige Button muss auch true gehen). Dabei stellt sich mir neben der generellen Herausforderung aber noch das Problem, dass ich aktuell fürchte ich einen Zirkel schaffen würde, denn todoist lauscht jetzt auf Änderungen am Tablet. Wenn also das Tablet nun auf Änderungen bei Todoist lauscht, dann triggert sich beides gegenseitig. Dazu muss ich mir noch Gedanken machen.
      Aus Übersichtlichkeitsgründen habe ich derzeit drei Skripte.
      Skript 1 ist mein "manuelles Skript", visualisiert sieht das so aus:
      ! ![](</s><URL url=)<link_text text="download/file.php?id=22640&mode=view">https://forum.iobroker.net/download/file.php?id=22640&mode=view</link_text>" /> ~~das Skript:
      `// Einkaufsliste
      // Idee und Basis: dna909
      // http://forum.iobroker.net/viewtopic.php?f=21&t=8766
      // abgewandelt: tempestas, Datum 6.11.2017
      // status: v 1.0 - stable
      // status: v 1.1 - regex trigger über state verzögert, da sonst bei erstmaligem Ausführen ständig getriggert wird und damit Warnungen im LOG stehen;
      // - state für VIS Kategorienumschaltung eingefügt; Fehler bei PurchList.length korrigiert, die -1 entfernt.
      ! // SKRIPTEINSTELLUNGEN
      ! var debug = false;
      var force = true;
      var path = "javascript.0.Einkaufsliste."; // Pfad für generelle Variablen und States
      var pathItems = "javascript.0.Einkaufsliste.Items."; // Pfad für die zu kaufenden Gegenstände
      // ########## STATES ##########
      ! createState(path +'regex', false, force, {
      type: 'boolean',
      role: 'state',
      ! createState(path +'Liste', "", force, { // String, in dem die Einkaufsliste gespeichert wird
      type: 'string',
      role: 'string',
      ! createState(path +'clearBtn', false, force, { // löschen Button, damit man nicht alles manuell abwählen muss
      desc: 'Löscht die Liste',
      type: 'boolean',
      role: 'state',
      unit: ''
      ! createState(path +'telegramBtn', false, force, { // sendet die Liste via Telegram
      name: 'Send Telegram',
      desc: 'Sendet Telegram Einkaufsliste',
      type: 'boolean',
      role: 'state',
      unit: ''
      ! createState(path +'visCategory',0, force, { // für die verschiedenen Kategorien
      name: 'VIS Einkaufsliste',
      type: 'number',
      min: '0',
      max: '20',
      states: '0:Obst;1:Gemüse;2:Wurst/Fleisch; 3:Käse/Milchprodukte; 4: Brot/Getreide; 5: Saucen/Gewürze; 6: Getränke; 7: Drogerie 1; 8: Drogerie 2',
      desc: 'Einkaufskategorien'
      ! createState(path +'visBtn', false, force, { // trigger für Anzeige der Gesamtliste in Vis
      desc: 'Zeigt die Gesamtliste in Vis',
      type: 'boolean',
      role: 'state',
      unit: ''
      ! createState(path +'count',0, force, {
      name: 'VIS Einkaufsliste Anzahl Objekte',
      type: 'number',
      min: '0',
      max: '200',
      // ARRAY MIT INHALT DER KAUFGEGENSTÄNDE
      ! var PurchList= [ "Ananas", "Apfel", "Aprikose_Pfirsich","Banane", "Birne", "Datteln", "Erdbeeren","Kirschen",
      "Kiwi", "Mandarine","Mango", "Melone", "Orange", "Waldbeeren", "Weintrauben", "Zitrone_Limette",
                          "Chilis", "Chinakohl", "Erbsen", "Gurke","Karotten", "Kartoffeln",  "Kohlrabi", "Kürbis", "Lauch", "Mais", "Paprika",
                          "Pilze", "Radieschen", "Tomaten", "Zucchini", "Zwiebeln",
                          "Aufschnitt", "Geflügel", "Geschnetzeltes", "Hackfleisch", "Kabanossi", "Rind", "Schwein", "Wiener","Fischstäbchen", "Garnelen",
                          "Bratfix", "Butter", "Creme-Fraiche", "Dips", "Eier", "Frischkaese", "Joghurt", "Kaese", "Kochsahne", "Kraeuterquark", "Milch",
                          "Mozzarella", "Quark", "Sauerrahm", "Schmelzkäse",
                          "Brötchen", "Brot", "Couscous", "Haferflocken", "Kichererbsen", "Mehl", "Müsli", "Nudeln","Pizzateig", "Reis", "Sonnenblumenkerne", "Vollkornnudeln",
                          "Mandeln",
                          "Asiasauce", "Brühe","BBQ-Sauce", "Chili-Sauce", "Essig", "Ketchup", "Mayonaise", "Öl", "Paprikapulver", "Pesto", "Pfeffer", "Salz", "Tomatenmark", "Tomatensauce", "Senf", "Zucker",
                          "Saft", "Tonicwater", "Cola", "Fanta", "Sprite", "Bier", "Bier-alkoholfrei","Alsterwasser",
                          "Alsterwasser-alkoholfrei", "Weizenbier", "Sekt","Energydrink", "Wein", "Tee", "Kaffee", "Kaffee-entkoffiniert",
                          "Alufolie", "Backpapier", "Biomüllbeutel","Klopapier", "Küchenrolle", "Deo", "Haargel", "Rasierklingen", "Rasierschaum", "Zahnbürste", "Zahnpasta","Duschgel", "Raumduft", "Shampoo",  "Seife",  "Schwamm", "Bürste", "Spüli",
                          "Klarspüler", "Spülmaschinensalz", "Tabs","Badreiniger", "Glasreiniger","Fettlöser", "Bodenreiniger", "Ceranreiniger", "Weichspüler", "Waschmittel", "Fleckentferner"];
      // Variablen
      ! var idRegex = path + 'regex';
      ! var idListe = path + 'Liste';
      ! var idClear = path + 'clearBtn';
      ! var idTelegram = path + 'telegramBtn';
      ! var idCount = path + 'count';
      ! var lengthListPurch=(PurchList.length); // Variablen für Auslesen wieviele Inhalte in den jeweiligen Arrays stehen
      var regexTrigger = /^javascript.0.Einkaufsliste.Items..*$/;
      ! var listeTotal = [];
      // ###### STATES FÜR DIE GEGENSTÄNDE IN OBJEKTEN ERZEUGEN #######
      ! function createItems(){
      var i = 0;
      for (i = 0; i < lengthListPurch; i++){
      createState(pathItems +PurchList[i], false, {
      desc: PurchList[i],
      type: 'boolean',
      role: 'state',
      unit: ''
          createState(pathItems +(PurchList[i]) + ".Menge", 0, force, {           // hier könnte man Mengenangaben mit einbeziehen, brauche ich jedoch nicht.
              desc: PurchList[i],
              type: 'number',
              role: 'state',
              unit: ''
      // TRIGGER FÜR ERZEUGUNG, LÖSCHEN UND TELEGRAM
      ! on({ id:regexTrigger,
      change: 'ne'},
      function(data) { // regex trigger, löst immer aus sobald etwas an- oder abgewählt wird
      if(getState(idRegex).val === true) {
      purchlistCreate(); // if Bedingung, damit es nicht zu warnmeldungen kommt, wenn der regex trigger ausgeführt wird aber Objekte noch nicht angelegt sind
      count();
      ! on(idClear, function(obj){ // trigger fürs Löschen
      if(obj.state.val === true){
      clearPurch();
      ! on(idTelegram, function(obj){ // trigger für Telegram
      sendTelegram();
      // FUNCTIONS
      ! ///// Einkaufsliste erzeugen //////////////////////////////////////////////////////////////////
      ! function purchlistCreate(){
      var i = 0;
      var item;
          listeTotal = [];
              if(getState(pathItems +PurchList[i]).val === true) {
              item = PurchList[i];
              listeTotal.push(item);
              if(debug) log(item + " zur Einkaufsliste hinzugefügt ");
      setState(idListe, listeTotal.join('
      ')); // Liste wird für VIS formatiert
      ! function count(){
      var n = listeTotal.length;
      setState(idCount, n);
      ! function clearPurch(){
      var i = 0;
      ! for (i = 0; i < lengthListPurch; i++){
                  setState(pathItems +PurchList[i], false);
                  setState(idListe, "");
                  setStateDelayed(idClear, false, 2000);
      ! function sendTelegram() {
              var telegramtext = getState(idListe).val.replace(/
      /g , "\n"); // telegram Liste formatieren, entfernt den Zeilenumbruch für vis und ersettz mit Zeilenumbruch Telegram
              sendTo('telegram.0', {                                          // Nachricht per Telegram senden
              text: "Bitte mitbringen:\n\n" + telegramtext
              setStateDelayed(idTelegram, false, 2000);
      ! // Bei Start
      ! createItems();
      setStateDelayed(idRegex, true, 30000); // nachdem alle states angelegt sind, kann der regex trigger genutzt werden; ! Das Auslesen von todoist habe ich etwas abgewandelt und auf einen Schedule (für die verbalen Änderungen via Alexa) und einen Trigger (für die Änderungen via Tablet) abgewandelt. ! Das Skript sieht nun so aus ! >! ~~[spoiler]~~[code]// Todoist Script zur Erstellung eines HTML Codes zur Einbindung in VIS mittels "basic - String (unescaped)" Widget
      // Scriptversion: v0.2
      // Ergänzungen tempestas: Task IDs mit ausgelesen und angelegt, trigger eingebaut, Stand 17.3.2018
      // https://forum.iobroker.net/viewtopic.php?f=21&t=12563
      // https://forum.iobroker.net/viewtopic.php?f=21&p=133205#p133205
      ! //Erforderliche Angaben:
      var APItoken = "STRENG GEHEIM"; // API Token kann in den Todoist Settings auf der Webseite ausgelesen werden
      var debug = false;
      ! //Weitere Parameter ggf. anpassen:
      var instanz = 'javascript.0'; instanz = instanz + '.'; // Instanz fuer die Datenpunkte definieren
      var pfad = 'Todoist.'; // Pfad definieren
      var regexTrigger = /^javascript.0.Einkaufsliste.Items..$/; // Trigger analog der manuellen Einkaufsliste
      ! schedule("
      /1 * * * *", checkTODOIST); // Abfragezeit: jede Minute
      // Scriptbeginn - Ab hier nichts mehr ändern!
      ! function checkTODOIST() {
      var APIprojectsURL = "https://beta.todoist.com/API/v8/projects?token="+APItoken;
      var APItaskURL = "https://beta.todoist.com/API/v8/tasks?token="+APItoken;
      var request = require("request");
      var ToDoListen = []; // wird mit IDs der TO-DO Listen befuellt
      var ToDoListen_names = []; // wird mit Namen der TO-DO Listen befuellt
      request(APIprojectsURL, function (error, response, body) {
          try{
              var projects_json = JSON.parse(body);
              for (k = 0; k < projects_json.length; k++) {
                  var projects = parseInt(projects_json[k].id);
                  var projects_name = JSON.stringify(projects_json[k].name);
                  projects_name = projects_name.replace(/\"/g, ""); //entfernt die Anfuehrungszeichen aus dem quellstring
                  ToDoListen[ToDoListen.length] = projects;
                  ToDoListen_names[ToDoListen_names.length] = projects_name;
                  createState(instanz + pfad + ToDoListen_names[k], {def: 'false',type: 'string',role: 'html', name: ToDoListen_names[k]+' HTML String'});
                  if(debug) log("Datenpunkt "+ToDoListen_names[k]+" erstellt.", "info");
                  createState(instanz + pfad + ToDoListen_names[k]+'.TaskID', {def: 'false',type: 'string',role: 'string', name: ToDoListen_names[k]+' Task IDs'});
                  if(debug) log("Datenpunkt "+ToDoListen_names[k]+'.TaskID'+" erstellt.", "info");
          catch(err) {log (err.message)}
      setTimeout(function() {
          try{
              request(APItaskURL, function (error, response, body) {
                  var json = JSON.parse(body);
                  for (j = 0; j < ToDoListen.length; j++) {
                      var HTMLstring = "";
                      setState(instanz + pfad + ToDoListen_names[j], "leer");
                      for (i = 0; i < json.length; i++) {
                          var Liste = parseInt(json[i].project_id);
                          var content = JSON.stringify(json[i].content);
                          content = content.replace(/\"/g, ""); //entfernt die Anfuehrungszeichen aus dem quellstring
                          content = content[0].toUpperCase() + content.substring(1); // Macht den ersten Buchstaben des strings zu einem Grossbuchstaben
                          var taskurl = JSON.stringify(json[i].url);
                          taskurl = taskurl.replace(/\"/g, "");
                          if (Liste == ToDoListen[j])
                              if(debug) log ("["+content+"] in "+ToDoListen_names[j]+" gefunden", "info");
                              HTMLstring = HTMLstring+content+"
      "; // mit Link: HTMLstring = HTMLstring+"* "+content+"";
      setState(instanz + pfad + ToDoListen_names[j], HTMLstring); // "<>"+HTMLstring+"
      catch(err) {log(err.message)}
      }, 1000);
          setTimeout(function() {                                                 // legt IDs der einzelnen Tasks in Unterordnern an
                  setState(instanz + pfad + ToDoListen_names[j] +'.TaskID', "leer");
                      var taskid = JSON.stringify(json[i].id);
                          if(debug) log ("["+taskid+"] in "+ToDoListen_names[j]+" gefunden", "info");
                          HTMLstring = HTMLstring+taskid+"
      setState(instanz + pfad + ToDoListen_names[j]+'.TaskID', HTMLstring); // "<>"+HTMLstring+"
      }, 1000);
      // TRIGGER
      change: 'ne'},
      function() { // regex trigger, löst immer aus sobald etwas in der manuellen Liste an- oder abgewählt wird
      ! checkTODOIST();
      }); ! Der Abgleich, sprich hinzufügen und löschen in der todoist Liste bei Änderungen am Tablet funktioniert dann mit dm dritten Skript: ! >! ~~[spoiler]~~[code]// SKRIPT FÜGT DER ALEXA EINKAUFSLISTE BEI TODOIST EINEN GEGENSTAND HINZU; WENN DIESER IN DER MANUELLEN EINKAUFSLISTE HINZUGEFÜGT WIRD BZW LÖSCHT
      ! var debug = true;
      ! var APItoken = "STRENG GEHEIM"; // API Token kann in den Todoist Settings auf der Webseite ausgelesen werden
      var idProject = nicht ganz so geheim, aber trotzdem; // Projekt-ID der Alexa-Einkaufsliste aus todoist
      var idEinkaufsIDS = "javascript.0.Todoist.Alexa-Einkaufsliste.TaskID"; // hier stehen die Task IDs
      var idEinkaufsItems = "javascript.0.Todoist.Alexa-Einkaufsliste"/Alexa-Einkaufsliste HTML String/;
      ! var regexTrigger = /^javascript.0.Einkaufsliste.Items..*$/; // Trigger analog der manuellen Einkaufsliste
      ! var request = require("request");
      var uuid;
      var purchItem;
      // uuid erstellen
      ! function createUUID(){
      var dt = new Date().getTime();
      uuid = 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function(c) {
      var r = (dt + Math.random()*16)%16 | 0;
      dt = Math.floor(dt/16);
      return (c=='x' ? r :(r&0x3|0x8)).toString(16);
      return uuid;
      // "Aufgabe" bzw Einkaufsgegenstand zur todoist Alexa Liste hinzufügen
      ! function addTask(){
      ! createUUID();
      log(uuid);
      ! var options = { method: 'POST',
      url: 'https://beta.todoist.com/API/v8/tasks',
      headers:
      { 'Cache-Control': 'no-cache',
      Authorization: 'Bearer ' +APItoken,
      'X-Request-Id': uuid,
      'Content-Type': 'application/json' },
      body:
      { content: purchItem,
      project_id: +idProject,
      json: true };
          request(options, function (error, response, body) {
            if (error) throw new Error(error);
            if(debug) console.log(JSON.stringify(body));
      // "Aufgabe" bzw Einkaufsgegenstand von todoist entfernen
      ! function deleteTask(){
      ! // Array der IDs aufbereiten
      var idListIDsArray =[];
      var idListIDs;
      idListIDs = getState(idEinkaufsIDS).val;
      if(debug)log(idListIDs);
      idListIDsArray = idListIDs.split("
      idListIDsArray.pop(); // aufgrund meiner uneleganten Änderungen steht als letztes immer "
      " in der Liste. Damit würde ein Element zuviel ausgegeben werden (leer). Pop kürzt den array ums letzte Element
      ! // Array der Items aufbereiten
      ! var idListArray =[];
      var idList;
      idList = getState(idEinkaufsItems).val;
      if(debug)log(idList);
      idListArray = idList.split("
      idListArray.pop();
      ! // Bestimmen der ID Position im Array
      var arrayPosition = idListArray.indexOf(purchItem);
      // Den Gegenstand über die gefundene ID löschen
      ! var deleteURL = "https://beta.todoist.com/API/v8/tasks/"+idListIDsArray[arrayPosition]+"?token="+APItoken;
      if(debug) log("Delete URL ist "+deleteURL);
          request({
              uri: deleteURL,
              method: "DELETE",
              timeout: 5000,
                  function(error, response, body) {
                  if(debug) console.log(body);
      // Trigger und Wertübergabe
      ! on({ id:regexTrigger, change: 'ne'}, // regex trigger, löst immer aus sobald etwas an- oder abgewählt wird
      function(data) {
      var temporary;
      temporary = data.id;
      purchItem = temporary.substring(33); // Pfad bis zum Item ist 33 Stellen lang
                  if(data.state.val) {                                // wenn das item auf der manuellen Liste hinzugefügt wurde (state ist true) dann...
                      if (debug) log("Es wird hinzugefügt: "+purchItem);
                      setTimeout(addTask, 500); }
                  else {                                              // sonst wenn wenn das item auf der manuellen Liste entfernt wurde dann...
                      if (debug) log("Es wird entfernt: "+purchItem);
                      setTimeout(deleteTask, 500);
      ! [/code]`[/spoiler]
      ! Nun fehlen noch #Abgleiche beim Start und eben "verbal to manual" Angleichungen.
      ! Ich hoffe, der eine oder andere findet es vielleicht nützlich
      ! VG und schönes Wochenende[/i][/i][/i][/i][/i][/code][/spoiler][/i][/i][/i][/i][/i][/i][/i][/i]
      • haselchenH Offline
        haselchenH Offline
        haselchen
        Erstmal nen fettes Danke für Deine Arbeit,Mühen und Ausdauer.
        Diese ToDoList mit Alexa für VIS ist so das letzte I Tüpfelchen für die Tabletvisualisierung für mich.
        Nun kommt das aber :)
        Als blutiger Anfänger würde ich Dich um eine Anleitung bitten, wie welches Skript mit welchen Infos wo eingebunden werden muss.
        Ich habe von der Reihenfolge etc. leider null Plan.
        Ich möchte halt Alexa meinen Einkaufswunsch sagen, der soll dann auf dem Tablet erscheinen und nach Bedarf mit Telegram an meine Frau schicken.
        Wenn dann noch das löschen der Produkte per Sprache geht, lauf ich nackt durch den Ort :D
        P.S.: Wenn ich könnte, würde ich Dir 100 Danke geben.
        Kleine Nebenfrage noch: Funktioneren auch Mengenangaben? 3kg Äpfel oder 1Liter Milch?
          tempestas
          Hallo haselchen,
          also die erste Frage ist: willst du NUR via Spracheingabe deine Einkaufsliste erstellen? Dann reicht ein Skript.
          Folgende Einschränkungen gibt es, die von uns hier auch nicht behoben werden können, sondern an der Alexa Integration liegen:
          1. Alles, was du in einem Atemzug sagst, wird als ein String aufgeschrieben. D.h: Wenn du "Setze Äpfel, Bier und Weißbrot auf meine Einkaufsliste" sagst, dann erscheint das genau so auf deiner Liste. Genau genommen noch mit Rechtschreibfehlern, nämlich "Äpfel, bier und weißbrot". Dieser String ist dann eine "Einheit". Wenns nicht stört ist das ok, ich wollte dich nur drauf hinweisen.
          2. Ich habe es gerade getestet: man kann NICHT via Sprachbefehl Dinge löschen. Alexa sagt dann "gehe in die Alexa App". Das nur als Hinweis. Zum löschen der gesamten Liste gibt es aber das von mir oben genannte kleine Skript. Damit könntest du dann am Tablet zumindest alles löschen, ohne in die Alexa App reinzugehen.
          3. Du kannst "Setze 3kg Äpfel auf meine Einkaufsliste" sagen. Allerdings sieht das in der Liste dann so aus: "Drei kilogramm äpfel".
          Um todoist mit Alexa zu verknüpfen, schaue hier:
          https://support.todoist.com/hc/en-us/ar … azon-Echo-
          Als Skript nutzt du das zweite aus meinem obigen Posting.
          Zum Thema löschen und integration in vis melde ich mich morgen, muss nun los.
            haselchenH Offline
            haselchen
            Vielen Dank für die ersten Antworten :)
              tempestas
              Hallo haselchen,
              hier also die Step by Step Anleitung:
              1. bei todoist anmelden (eigener account, facebook, google)
              2. Alexa mit todoist verbinden https://blog.todoist.com/de/2017/03/01/ … tegration/
              3. deinen API Key auslesen auf der todoist Homepage (unter Einstellungen findest du den) und im Skript eintragen
              4. Dieses Skript ist das Hauptskript zum Visualisieren der todoist Liste
              `// Todoist Script zur Erstellung eines HTML Codes zur Einbindung in VIS mittels "basic - String (unescaped)" Widget
              // Ergänzungen tempestas, Stand 17.3.2018
              var APItoken = "xxxxxxxxxxxxxxxxxxx"; // API Token kann in den Todoist Settings auf der Webseite ausgelesen werden
              var debug = false;
              var idEinkaufsliste= "javascript.0.Todoist.Alexa-Einkaufsliste";
              var force = true;
              // var regexTrigger = /^javascript.0.Einkaufsliste.Items..$/; // Trigger analog der manuellen Einkaufsliste, brauchst du nicht, deaktiviert
              ! schedule("
              ! createState(instanz + pfad +'telegramBtn', false, force, { // sendet die Liste via Telegram
              type: 'boolean',
              role: 'state',
              unit: ''
              ! var idTelegram = instanz + pfad +"telegramBtn";
                      var telegramtext = getState(idEinkaufsliste).val.replace(/
              ! // Trigger Telegram
              sendTelegram();
                  try{
                  try{
              }, 1000);
              }, 1000);
              kopierst du in eine Javascript Instanz in ein neues Skript,speicherst und startest via Play Button. Du wirst im Log gelbe Warnmeldungen sehen, was daher kommt, dass die states noch nicht angelegt sind. Das Skript nochmal stoppen, nochmal starten.
              ! 5) mit diesem Widget
              ! [spoiler]~~[code]~~[{"tpl":"tplValueStringRaw","data":{"oid":"javascript.0.Todoist.Alexa-Einkaufsliste","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"**Einkaufsliste:** **","name":"Einkaufsliste"},"style":{"left":"492px","top":"81px","width":"260px","height":"350px","color":"rgba(250,250,250,1)","background":"rgba(150,150,150,0.5)","z-index":"2"},"widgetSet":"basic"}][/code][/spoiler]
              wird deine Einkaufsliste angezeigt (in vis auf widget importieren und diesen code eintragen, copy & paste)
              ! 6) ein neues Skript anlegen mit diesem Skript zum Löschen
              ! >! [spoiler]`[code]//Script zum Löschen aller todoist Einträge via Vis
              // Scriptversion: v0.1
              var APItoken = "XXXXXXXXXXXXXXXXXXXX"; // API Token kann in den Todoist Settings auf der Webseite ausgelesen werden
              var idEinkaufsliste = "javascript.0.Todoist.Alexa-Einkaufsliste.TaskID"/Alexa-Einkaufsliste HTML String/;
              var debug = false;
              var force = true;
              ! // Scriptbeginn - Ab hier nichts mehr ändern!
              ! createState(instanz + pfad +'clearBtn', false, force, { // löschen Button, damit man nicht alles manuell abwählen muss
              type: 'boolean',
              role: 'state',
              unit: ''
              ! var idClear = instanz + pfad + 'clearBtn';
              var idList;
              idList = getState(idEinkaufsliste).val;
              idListArray.pop(); // aufgrund meiner uneleganten Änderungen steht als letztes immer "
              if(debug)log("idList Array ist " +idListArray);
              if(debug)log("idList Array Länge ist "+idListArray.length);
              for (i = 0; i< idListArray.length; i++){
                  if(debug) log("Durchgang "+i);
                  var deleteURL = "https://beta.todoist.com/API/v8/tasks/"+idListArray[i]+"?token="+APItoken;
                  request({
                      uri: deleteURL,
                      method: "DELETE",
                      timeout: 5000,
              ! // Löschen der Liste
              deleteTask();
              setStateDelayed(idClear, false, 1000);
              }); ! 7) button in vis erstellen zum Löschen: ! >! ~~[spoiler]~~[code][{"tpl":"tplMetroTileToggle","data":{"oid":"javascript.0.Todoist.clearBtn","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","hover":"true","transform":"true","bg_class_false":"bg-crimson","bg_class_true":"bg-crimson","icon_class_false":"icon-cancel-2","icon_class_true":"icon-cancel-2","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_badge":true,"icon_badge_false":"","icon_badge_true":"","badge_bg_class_false":"","badge_bg_class_true":"","brand_bg_class_false":"","brand_bg_class_true":"","badge_top":"0","badge_left":"0","g_ccontrol":true,"label_false":"Liste löschen","label_true":"Liste löschen","icon_false":"","icon_true":"","icon_width":"75","icon_height":"75","icon_top":"15","icon_left":"28","name":"Löschen_btn"},"style":{"left":"1123px","top":"1px","width":"150px","height":"150px","z-index":"5"},"widgetSet":"metro"}][/code][/spoiler] ! 8) button zum Telegram senden: ! >! ~~[spoiler]~~[code][{"tpl":"tplMetroTileToggle","data":{"oid":"javascript.0.Todoist.telegramBtn","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","hover":"true","transform":"true","bg_class_false":"bg-dark","bg_class_true":"bg-steel","icon_class_false":"","icon_class_true":"","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_badge":true,"icon_badge_false":"","icon_badge_true":"","badge_bg_class_false":"","badge_bg_class_true":"","brand_bg_class_false":"","brand_bg_class_true":"","badge_top":"0","badge_left":"0","g_ccontrol":true,"label_false":"Sende Liste","label_true":"Sende Liste","icon_false":"/vis.0/main/img/telegram_transparent_neu.png","icon_true":"/vis.0/main/img/telegram_transparent_neu.png","icon_width":"75","icon_height":"67","icon_top":"33","icon_left":"28","name":"Telegram_btn"},"style":{"left":"1122px","top":"156px","width":"150px","height":"150px","z-index":"5"},"widgetSet":"metro"}][/code][/spoiler] ! 9) und als goodie: mit diesem Skript kannst du die Einkaufsliste nicht nur senden, sondern aktiv via Telegram auf dienem Handy abrufen. Dazu musst du dienen Bot mit "Einkauf" anschreiben und er wird antworten ! >! ~~[spoiler]~~~~[code]~~var idListe = "javascript.0.Todoist.Alexa-Einkaufsliste"/Liste/; // ggf anpassen
              ! on({id: 'telegram.0.communicate.request', change: 'any'}, function (obj) {
              var stateval = getState('telegram.0.communicate.request').val; // Statevalue in Variable schreiben
              var benutzer = stateval.substring(1,stateval.indexOf("]")); // Benutzer aus Statevalue extrahieren
              var befehl = stateval.substring(stateval.indexOf("]")+1,stateval.length); // Befehl/Text aus Statevalue extrahieren
              ! if (befehl.search(/(?=.*(\Einkauf\b)).+/ig) != -1) {
                  var einkaufsliste;
                  if(getState(idListe).val === "leer") {einkaufsliste = "Es muss nichts eingekauft werden";}
                      else {  einkaufsliste = "Bitte mitbringen:\n\n" + getState(idListe).val.replace(/
              /g , "\n");}
                  sendTo('telegram', {
                      user: benutzer,
                      text: einkaufsliste
              [/code]`[/spoiler]
              ! die buttons sind übrigens nur beispiele, aber sie sind schonmal korrekt verlinkt, so dass du testen kannst[/i][/code][/spoiler][/i][/i][/i][/i][/i]**
                tempestas
                hallo haselchen,
                hat soweit alles funktioniert?
                  dali3
                  Ich habe es getestet,
                  bei mir taucht jedoch folgender Fehler auf:
                  javascript.0 2018-03-20 11:23:03.403 error at ContextifyScript.Script.runInContext (vm.js:35:29)
                  javascript.0 2018-03-20 11:23:03.402 error at script.js.Todo.SkriptVisToDoIst:16:48
                  javascript.0 2018-03-20 11:23:03.402 error ReferenceError: force is not defined
                  javascript.0 2018-03-20 11:23:03.401 error ^
                  javascript.0 2018-03-20 11:23:03.401 error createState(instanz + pfad +'clearBtn', false, force, { // löschen Button, damit man nicht alles manuell abwählen muss
                  javascript.0 2018-03-20 11:23:03.400 error script.js.Todo.SkriptVisToDoIst: script.js.Todo.SkriptVisToDoIst:16
                  javascript.0 2018-03-20 11:23:03.387 info Start javascript script.js.Todo.SkriptVisToDoIst
                  javascript.0 2018-03-20 11:19:18.527 error at ContextifyScript.Script.runInContext (vm.js:35:29)
                  javascript.0 2018-03-20 11:19:18.526 error at script.js.Todo.SkriptToDoIst:24:51
                  javascript.0 2018-03-20 11:19:18.526 error ReferenceError: force is not defined
                  javascript.0 2018-03-20 11:19:18.525 error ^
                  javascript.0 2018-03-20 11:19:18.525 error createState(instanz + pfad +'telegramBtn', false, force,
                  javascript.0 2018-03-20 11:19:18.524 error script.js.Todo.SkriptToDoIst: script.js.Todo.SkriptToDoIst:24
                  javascript.0 2018-03-20 11:19:18.506 info Start javascript script.js.Todo.SkriptToDoIst
                  jedoch arbeite ich via "Fernzugriff", müsste es zu Hause heute Abend nochmals testen.
                  ~~@tempestas:~~
                  > hallo haselchen,
                  > hat soweit alles funktioniert? `
                  Systeminfo:
                  Iobroker Pro, Surface 3 (Mobil), Acer T272 (Wand), Raspberry Pi 3, NUC, Synology DS212j (BackUp), Google Home, Xiaomi Aqara (Sensoren, Fühler, Kamera, LED), Revo Superconnect, Philips Hue, IKEA Tradfri...
                    tempestas
                    Danke für den Hinweis.
                    Habe ich übersehen; ich habe in das Skript ein paar Dinge schnell eingebaut für haselchen, dabei ist wohl was durchgerutscht.
                    Passe ich gleich an.
                    Bitte im "Hauptskript" und im Löschen-Skript einfach das hier ergänzen bei den "erforderlichen Eingaben". Habs oben auch korrigiert.
                    var force = true;
                    Fernzugriff ist für das Skript natürlich nicht sinnvoll, da ich für haselchen ja nur die Version für Spracheingabe dargestellt habe. Da müsstest du wohl schon sehr, sehr laut rufen ;-)
                      dali3
                      Gibt es auch eine Google Home Version? ;)
                      Nun läuft es! Danke dir!
                      Einen Punkt habe ich noch..
                      Falls ich via Telegram "Einkauf" die Liste anfordere, erhalte ich zuerst "Ich verstehe "Einkauf" nicht…
                      gefolgt von der Liste "Bitte mitbringen..."
                      Wie krieg ich das "Ich vestehe ... nicht" weg?
                      Ergänzung: Ich versuche nun via IFTTT google Home mit einzubinden!
                      Systeminfo:
                        tempestas
                        Alexa sagt das? Ok, ich habs noch nicht in der Kombi getestet, das wäre ein unerwartete Nebenreaktion, deren Grund mir noch unklar ist.
                          dali3
                          Nein, nicht Alexa.
                          Wenn ich im Telegram am Bot die Nachricht "Einkauf" sende…
                          erhalte ich zuerst "Ich verstehe "Einkauf" nicht" und anschliessend die Einkaufsliste.
                          @tempestas:
                          Alexa sagt das? Ok, ich habs noch nicht in der Kombi getestet, das wäre ein unerwartete Nebenreaktion, deren Grund mir noch unklar ist. `
                          Systeminfo:
                            tempestas
                            ok, danke.
                            Moment; steht das "ich verstehe nicht…" mit auf der Einkaufsliste? mir ist unklar, wieso da überhaupt sowas kommen kann, denn der Bot redet ja gar nicht alleine.
                            Bei mir passiert das auch nicht.
                            Zu google home: das müsste genau so funktionieren, wenn sich google home mit todoist verbinden lässt.
                            Die API bleibt ja gleich, und die Integration google bzw alexa mit todoist erfolgt ja unabhängig vom ioBroker
                              dali3
                              Bilder sagen mehr als 1000 Worte.
                              Jedoch habe ich glaubs auch ein anderes Problem :)
                              siehe /start hmm
                              Systeminfo:
                                tempestas
                                ok, das liegt dann aber irgendwie an Telegram bzw dem Bot. Wenn er auch schon bei "/start" rummeckert ist das wohl eher extern induziert und hat nichts mit dem Skript zu tun.
                                Aber die "Leer"-Meldung hat zu einer kleinen Anpassung geführt, die ich gleich mal einbaue. Der State ist ja nie leer, sondern wenn er "leer" sein soll, eben mit "leer" beschrieben.
                                Habs im Skript angepasst
                                • E Offline
                                  eXTreMe
                                  blöde frage: aber warum nutzt ihr nicht einfach die offizielle todoist app zur anzeige der listen statt es euch aufwendig über telegram nach eingabe eines keywords zuzusenden?
                                    tempestas
                                    Ist ja die Frage, ob das aufwendig ist.
                                    Ich persönlich habe bei mir alles so gemacht, dass ich möglichst wenig verschiedene Apps brauche. Über Telegram kommuniziert mein Haus mit mir, daher habe ich die Einkaufsliste da mit eingebaut.
                                    Ich nutze ja nicht eine Integrationsplattform wie ioBroker, um dann auf meinem Handy doch wieder alles auf Einzelbasis mit zig Apps zu nutzen. Ich könnte ja auch meinen Neato D5 mit der passenden App steuern oder meine Hue Lampen oder meine Homematic Sachen mit cloudmatic usw usf.
                                    Aber natürlich kann man es anders machen. Der User wollte ja nur gerne sich die Liste schicken können und quasi als "on top" gab es dann eben, falls man das schicken vergessen hat, noch die Pull Option.
                                    Man kann natürlich auch einfach eine VIS mobile view erstellen (so hab ich es).
                                      haselchenH Offline
                                      haselchen
                                      Hi, da ist man mal auf Dienstreise und dann überschlagen sich hier die Ereignisse :D
                                      Ich konnte das Skript deswegen noch nicht testen.
                                      Welches ist denn jetzt überhaupt für meine Bedürfnisse das Richtige?
                                      Ist ja ein paar Mal geändert worden wie ich so überflogen habe? :?
                                        tempestas
                                        Das aus meiner Step by Step Anleitung. Da steht alles drin
                                          haselchenH Offline
                                          haselchen
                                          Sauber. Werde ich am WE mir zu Gemüte führen :)
                                          Wenn man komplett keine Ahnung von Skripten und Programmieren hat, ist man auf Cracks wie dich angewiesen und da Danke ich dir sehr für, dass dieses Projekt auf die Beine gestellt hast Daumen hoch
