  4. [Frage] Problem Installation OpenZWave
    5.9k
10 Beiträge 3 Kommentatoren 1.0k Aufrufe
    DubZ
    ich habe ioBroker 3.2.3 auf meinen Windows 10 Server installiert. Angeschlossen den zwave UZB USB Stick und den Windows Treiber installiert.
    Danach wollte ich den zwave Adapter installieren und bekomme ihn mit verschiedensten Fehlern sowie dem Fehlercode 13 zum Schluss nicht installiert.
    Logfile:
    $ ./iobroker add zwave
    NPM version: 2.15.9
    npm install iobroker.zwave --unsafe-perm --production --save --prefix "C:/ioBroker" (System call)
    win32 is currently not supported
    npm WARN deprecated wrench@1.5.9: wrench.js is deprecated! You should check out fs-extra (https://github.com/jprichardson/node-fs-extra) for any operations you were using wrench for. Thanks for all the usage over the years.npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    ! C:\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:147
    throw err;
    ! Error: Can't find Python executable "python", you can set the PYTHON env variable.
    at Object.failNoPython (C:\WINDOWS\TEMP\ozwinstall-pbxx0f6r\node_modules\node-gyp\lib\configure.js:483:19)
    at Object. <anonymous>(C:\WINDOWS\TEMP\ozwinstall-pbxx0f6r\node_modules\node-gyp\lib\configure.js:508:16)
    at C:\WINDOWS\TEMP\ozwinstall-pbxx0f6r\node_modules\node-gyp\node_modules\graceful-fs\polyfills.js:284:29
    at FSReqWrap.oncomplete (fs.js:82:15)
    ! npm
    ERR! Windows_NT 10.0.16299
    npm ERR! argv "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--save" "--prefix" "C:/ioBroker"
    npm
    ERR! node v4.5.0npm
    ERR!
    npm v2.15.9
    npm
    ERR! code ELIFECYCLE
    npm ERR!
    openzwave-shared@1.4.1 preinstall: node lib/install-ozw.jsnpm
    ERR!
    Exit status 1
    npm
    ERR! npm ERR! Failed at the openzwave-shared@1.4.1 preinstall script 'node lib/install-ozw.js'.
    npm ERR! This is most likely a problem with the openzwave-shared package,
    npm
    ERR! not with npm itself.
    npm
    ERR! Tell the author that this fails on your system:npm
    ERR!
    npm
    ERR! You can get information on how to open an issue for this project with:npm ERR! npm bugs openzwave-shared
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls openzwave-sharednpm ERR! There is likely additional logging output above.
    ! npm
    ERR! Please include the following file with any support request:
    npm
    ERR! C:\ioBroker\node_modules\iobroker\npm-debug.log
    host.HL-HOME install adapter zwave
    NPM version: 2.15.9
    throw err;
    at Object.failNoPython (C:\WINDOWS\TEMP\ozwinstall-98s8u9jm7vi\node_modules\node-gyp\lib\configure.js:483:19)
    at Object. <anonymous>(C:\WINDOWS\TEMP\ozwinstall-98s8u9jm7vi\node_modules\node-gyp\lib\configure.js:508:16)
    at C:\WINDOWS\TEMP\ozwinstall-98s8u9jm7vi\node_modules\node-gyp\node_modules\graceful-fs\polyfills.js:284:29
    ! npm
    npm
    ERR!
    node
    v4.5.0
    npm
    ERR! npm v2.15.9npm
    ERR!
    code ELIFECYCLE
    ! npm
    ERR! openzwave-shared@1.4.1 preinstall: node lib/install-ozw.jsnpm ERR! Exit status 1
    ! npm
    ERR!
    npm
    ERR! Failed at the openzwave-shared@1.4.1 preinstall script 'node lib/install-ozw.js'.npm ERR! This is most likely a problem with the openzwave-shared package,
    npm ERR! not with npm itself.
    ! npm
    ERR!
    npm
    ERR!
    node lib/install-ozw.jsnpm ERR! You can get information on how to open an issue for this project with:
    npm
    ERR! npm
    ! npm ERR! Please include the following file with any support request:npm ERR! C:\ioBroker\node_modules\iobroker\npm-debug.log
    ! host.HL-HOME install adapter zwave
    NPM version: 2.15.9
    throw err;
    at Object.failNoPython (C:\WINDOWS\TEMP\ozwinstall-d1y4jazia4i\node_modules\node-gyp\lib\configure.js:483:19)
    at Object. <anonymous>(C:\WINDOWS\TEMP\ozwinstall-d1y4jazia4i\node_modules\node-gyp\lib\configure.js:508:16)
    at C:\WINDOWS\TEMP\ozwinstall-d1y4jazia4i\node_modules\node-gyp\node_modules\graceful-fs\polyfills.js:284:29
    ! npm
    npm
    ERR! node v4.5.0
    npm
    ERR! npm v2.15.9npm
    ERR!
    code ELIFECYCLE
    ! npm
    ERR!
    npm
    ERR!
    Exit status 1
    npm ERR! npm
    npm
    ERR!
    npm
    ERR!
    npm
    ERR! node lib/install-ozw.js
    npm ERR! You can get information on how to open an issue for this project with:npm ERR! npm bugs openzwave-shared
    npm ERR!
    ERROR: host.HL-HOME Cannot install zwave
    ERROR: process exited with code 13</anonymous></anonymous></anonymous>
    Jemand eine Idee?
    • arteckA Offline
      arteckA Offline
      arteck
      npm
       ERR! node v4.5.0
      npm
       ERR! npm  v2.15.9npm
      das ist bissel alt .. das wird nichts
        DubZ
        Sorry, ich muss nachfragen… bin neu im Heimautomatisierung aber IT und Etechnik versiert. Aber ich muss mir hier die Frage stellen, ob ich mit iobroker richtig aufgehoben bin oder nicht. Es scheitert ja schon an der Basis Installation dass ich den latest windows installer vorgestern heruntergeladen habe und da irgendwelche Module zu alt sind um den standard zwave Controller anzubinden?!
        Daher die Frage, ist das nun aus diversen Gründen ein Zufall oder werde ich öfters mit iobroker anecken wo ich mich tief einarbeiten muss um Fehler zu fixen? Ich wollte nämlich iobroker mit 2 anderen Programmen testen und vergleichen.
        • apollon77A Offline
          Also hier ist gar nichts zu alt!
          Nodejs 4 ist noch vollständig als LTS supportet. Daran liegt es nicht.
          Ja nodejs 4 sollte im April ggf. nicht mehr Mittel der Wahl sein, aber aktuell und auch danach noch ne Weile vollkommen ok.
          Das Problem liegt egher daran das die im zWave-Adapter verwendete Library unter WIndows nicht funktioniert. Es tat irgendwann mal ist aber dann bei denen kaputt gegangen und die Owner der Library ignorieren das aktuell (z.B. https://github.com/OpenZWave/node-openz … issues/211). Häng dich gern an den thread dran um die Wichtigkeit zu erhöhen.
          Ich denke inzwischen ist der Punkt erreicht wo man mal offiziell auch beim Adapter schreiben sollte das WIndows unsupportet ist - denke bisher hatten wir noch Hoffnung.
          Zu Deiner zweiten Frage:
          Wenn Du ioBroker mit anderen Open-Source Lösungen vergleichst dann wirst Du denke ggf bei allen Themen haben die du dir genauer ansehen musst. Die Herausforderung bei IoT und Home-Automation ist das so viele Dinge mitspielen. Wenn Du ioBroker gegen kommerzielle Systeme vergleichen willst dann hör gleich auf weil da ioBroker nur verlieren kann. WICHTIG: Das meine ich nicht auf der Funktionalen ebene, sondern auf der "Rundum sorglos Paket wo man nur User sein kann und sich nie mit DIngen auseinandersetzen muss"-Thematik.
          Also kurz: ZWave kann ioBroker unter Windows gerade nicht supporten. Linux und macOS tun aber
            DubZ
            Hi apollon,
            vielen Dank für deine ausführliche Antwort.
            Dann wird iobroker leider nichts für mich. Wollte es schon auf meinem Windows Server laufen lassen statt bspw. auf einem raspi oder in einer linux VM. Hauptgrund warum ich mir auch iobroker angucken wollte ist die Visualiserungsmöglichkeit sowie node-red. Es geht auch nicht darum kaum Zeit investieren zu müssen in denen man bspw. ohne Programmierkentnisse zum Ziel kommen könnte, sondern die grundlegenden Dinge wie eben Installation und Grundkonfiguration, dass diese einfach so klappen müssen.
            Geht aber natürlich nicht, wenn es aktuell (offiziell/inoffiziell?!) nicht funktioniert.
              Also ZWave und damit der ZWave Adapter tut nicht unter Windows. Der ganze Rest, node-red, Visualisierung und so tut.
                DubZ
                sorry, hab mich falsch ausgedrückt. Das node red (vermutlich) funktioniert war mir klar bzw. gehofft. Aber wenn ich die Geräte schon nicht angesprochen bekomme, hilft mir alles andere innherlab iobroker nicht wirklich weiter (zumindest für meinen Anwendungsfall).
                  ZWAve und Windows passiert grade wieder was … mal schauen die nächsten Tage :-)
                    DubZ
                    Ok. Dann schaue ich mal ab und an rein. Bin mir immer noch unschlüssig mit welcher Software ich weiter ,machen möchte
                      Kannst Dich ja hier (https://github.com/OpenZWave/node-openz … issues/222) subscriben ...
