<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Frage] Problem Installation OpenZWave]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">ich habe ioBroker 3.2.3 auf meinen Windows 10 Server installiert. Angeschlossen den zwave UZB USB Stick und den Windows Treiber installiert.</p>
<p dir="auto">Danach wollte ich den zwave Adapter installieren und bekomme ihn mit verschiedensten Fehlern sowie dem Fehlercode 13 zum Schluss nicht installiert.</p>
<p dir="auto">Logfile:</p>
<blockquote>
<p dir="auto">! ````<br />
$ ./iobroker add zwave<br />
NPM version: 2.15.9<br />
npm install iobroker.zwave --unsafe-perm --production --save --prefix "C:/ioBroker" (System call)<br />
win32 is currently not supported<br />
npm WARN deprecated wrench@1.5.9: wrench.js is deprecated! You should check out fs-extra (<a href="https://github.com/jprichardson/node-fs-extra" rel="nofollow ugc">https://github.com/jprichardson/node-fs-extra</a>) for any operations you were using wrench for. Thanks for all the usage over the years.npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js<br />
! C:\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:147<br />
throw err;<br />
^<br />
! Error: Can't find Python executable "python", you can set the PYTHON env variable.<br />
at Object.failNoPython (C:\WINDOWS\TEMP\ozwinstall-pbxx0f6r\node_modules\node-gyp\lib\configure.js:483:19)<br />
at Object. &lt;anonymous&gt;(C:\WINDOWS\TEMP\ozwinstall-pbxx0f6r\node_modules\node-gyp\lib\configure.js:508:16)<br />
at C:\WINDOWS\TEMP\ozwinstall-pbxx0f6r\node_modules\node-gyp\node_modules\graceful-fs\polyfills.js:284:29<br />
at FSReqWrap.oncomplete (fs.js:82:15)<br />
! npm<br />
ERR! Windows_NT 10.0.16299<br />
npm ERR! argv "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.zwave" "--unsafe-perm" "--production" "--save" "--prefix" "C:/ioBroker"<br />
npm<br />
ERR! node v4.5.0npm</p>
</blockquote>
<p dir="auto">ERR!</p>
<p dir="auto">npm  v2.15.9<br />
npm</p>
<p dir="auto">ERR! code ELIFECYCLE<br />
npm ERR!<br />
openzwave-shared@1.4.1 preinstall: <code>node lib/install-ozw.js</code>npm</p>
<p dir="auto">ERR!<br />
Exit status 1<br />
npm</p>
<p dir="auto">ERR! npm ERR! Failed at the openzwave-shared@1.4.1 preinstall script 'node lib/install-ozw.js'.<br />
npm ERR! This is most likely a problem with the openzwave-shared package,<br />
npm</p>
<p dir="auto">ERR! not with npm itself.<br />
npm<br />
ERR! Tell the author that this fails on your system:npm<br />
ERR!<br />
node lib/install-ozw.js<br />
npm<br />
ERR! You can get information on how to open an issue for this project with:npm ERR!     npm bugs openzwave-shared<br />
npm ERR! Or if that isn't available, you can get their info via:<br />
npm ERR!</p>
<p dir="auto">npm ERR!     npm owner ls openzwave-sharednpm ERR! There is likely additional logging output above.</p>
<blockquote>
<p dir="auto">! npm</p>
</blockquote>
<p dir="auto">ERR! Please include the following file with any support request:<br />
npm<br />
ERR!     C:\ioBroker\node_modules\iobroker\npm-debug.log<br />
host.HL-HOME install adapter zwave<br />
npm WARN deprecated wrench@1.5.9: wrench.js is deprecated! You should check out fs-extra (<a href="https://github.com/jprichardson/node-fs-extra" rel="nofollow ugc">https://github.com/jprichardson/node-fs-extra</a>) for any operations you were using wrench for. Thanks for all the usage over the years.npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js</p>
<blockquote>
<p dir="auto">! C:\ioBroker\node_modules\iobroker.zwave\node_modules\openzwave-shared\lib\install-ozw.js:147<br />
throw err;<br />
^<br />
at Object.failNoPython (C:\WINDOWS\TEMP\ozwinstall-98s8u9jm7vi\node_modules\node-gyp\lib\configure.js:483:19)<br />
at Object. &lt;anonymous&gt;(C:\WINDOWS\TEMP\ozwinstall-98s8u9jm7vi\node_modules\node-gyp\lib\configure.js:508:16)<br />
at C:\WINDOWS\TEMP\ozwinstall-98s8u9jm7vi\node_modules\node-gyp\node_modules\graceful-fs\polyfills.js:284:29<br />
! npm<br />
npm</p>
</blockquote>
<p dir="auto">node<br />
v4.5.0<br />
npm<br />
ERR! npm  v2.15.9npm</p>
code ELIFECYCLE</p>
<blockquote>
</blockquote>
<p dir="auto">ERR! openzwave-shared@1.4.1 preinstall: <code>node lib/install-ozw.js</code>npm ERR! Exit status 1</p>
<blockquote>
<p dir="auto">! npm<br />
ERR!<br />
npm</p>
</blockquote>
<p dir="auto">ERR! Failed at the openzwave-shared@1.4.1 preinstall script 'node lib/install-ozw.js'.npm ERR! This is most likely a problem with the openzwave-shared package,<br />
npm ERR! not with npm itself.</p>
<blockquote>
</blockquote>
Tell the author that this fails on your system:<br />
npm<br />
ERR!<br />
node lib/install-ozw.jsnpm ERR! You can get information on how to open an issue for this project with:<br />
npm</p>
<p dir="auto">ERR! npm<br />
<blockquote>
<p dir="auto">! npm ERR! Please include the following file with any support request:npm ERR!     C:\ioBroker\node_modules\iobroker\npm-debug.log<br />
! host.HL-HOME install adapter zwave<br />
throw err;<br />
^<br />
at Object.failNoPython (C:\WINDOWS\TEMP\ozwinstall-d1y4jazia4i\node_modules\node-gyp\lib\configure.js:483:19)<br />
at Object. &lt;anonymous&gt;(C:\WINDOWS\TEMP\ozwinstall-d1y4jazia4i\node_modules\node-gyp\lib\configure.js:508:16)<br />
at C:\WINDOWS\TEMP\ozwinstall-d1y4jazia4i\node_modules\node-gyp\node_modules\graceful-fs\polyfills.js:284:29<br />
! npm<br />
npm<br />
ERR! node v4.5.0<br />
npm<br />
</blockquote>
<p dir="auto">code ELIFECYCLE</p>
<blockquote>
ERR!<br />
openzwave-shared@1.4.1 preinstall: <code>node lib/install-ozw.js</code><br />
npm</p>
</blockquote>
Exit status 1<br />
npm ERR! npm<br />
npm</p>
npm<br />
ERR!<br />
npm<br />
ERR!     node lib/install-ozw.js<br />
npm ERR! You can get information on how to open an issue for this project with:npm ERR!     npm bugs openzwave-shared<br />
npm ERR!<br />
npm ERR!     npm owner ls openzwave-shared<br />
<blockquote>
ERROR: host.HL-HOME Cannot install zwave<br />
ERROR: process exited with code 13&lt;/anonymous&gt;&lt;/anonymous&gt;&lt;/anonymous&gt;</p>
</blockquote>
<pre><code>
Jemand eine Idee?</code></pre>
]]></description><link>https://forum.iobroker.net/topic/11435/frage-problem-installation-openzwave</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Apr 2026 23:29:49 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/11435.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Mar 2018 09:06:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Sun, 11 Mar 2018 22:01:47 GMT]]></title><description><![CDATA[<p dir="auto">Kannst Dich ja hier (<a href="https://github.com/OpenZWave/node-openzwave-shared/issues/222" rel="nofollow ugc">https://github.com/OpenZWave/node-openz … issues/222</a>) subscriben ...</p>
]]></description><link>https://forum.iobroker.net/post/139041</link><guid isPermaLink="true">https://forum.iobroker.net/post/139041</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Sun, 11 Mar 2018 22:01:47 GMT</pubDate></item><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Sun, 11 Mar 2018 09:25:16 GMT]]></title><description><![CDATA[<p dir="auto">Ok. Dann schaue ich mal ab und an rein. Bin mir immer noch unschlüssig mit welcher Software ich weiter ,machen möchte</p>
]]></description><link>https://forum.iobroker.net/post/138797</link><guid isPermaLink="true">https://forum.iobroker.net/post/138797</guid><dc:creator><![CDATA[DubZ]]></dc:creator><pubDate>Sun, 11 Mar 2018 09:25:16 GMT</pubDate></item><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Fri, 09 Mar 2018 15:05:25 GMT]]></title><description><![CDATA[<p dir="auto">ZWAve und Windows passiert grade wieder was … mal schauen die nächsten Tage :-)</p>
]]></description><link>https://forum.iobroker.net/post/138431</link><guid isPermaLink="true">https://forum.iobroker.net/post/138431</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 09 Mar 2018 15:05:25 GMT</pubDate></item><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Fri, 09 Mar 2018 13:01:39 GMT]]></title><description><![CDATA[<p dir="auto">sorry, hab mich falsch ausgedrückt. Das node red (vermutlich) funktioniert war mir klar bzw. gehofft. Aber wenn ich die Geräte schon nicht angesprochen bekomme, hilft mir alles andere innherlab iobroker nicht wirklich weiter (zumindest für meinen Anwendungsfall).</p>
]]></description><link>https://forum.iobroker.net/post/138405</link><guid isPermaLink="true">https://forum.iobroker.net/post/138405</guid><dc:creator><![CDATA[DubZ]]></dc:creator><pubDate>Fri, 09 Mar 2018 13:01:39 GMT</pubDate></item><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Fri, 09 Mar 2018 12:26:34 GMT]]></title><description><![CDATA[<p dir="auto">Also ZWave und damit der ZWave Adapter tut nicht unter Windows. Der ganze Rest, node-red, Visualisierung und so tut.</p>
]]></description><link>https://forum.iobroker.net/post/138386</link><guid isPermaLink="true">https://forum.iobroker.net/post/138386</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 09 Mar 2018 12:26:34 GMT</pubDate></item><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Fri, 09 Mar 2018 11:48:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi apollon,</p>
<p dir="auto">vielen Dank für deine ausführliche Antwort.</p>
<p dir="auto">Dann wird iobroker leider nichts für mich. Wollte es schon auf meinem Windows Server laufen lassen statt bspw. auf einem raspi oder in einer linux VM. Hauptgrund warum ich mir auch iobroker angucken wollte ist die Visualiserungsmöglichkeit sowie node-red. Es geht auch nicht darum kaum Zeit investieren zu müssen in denen man bspw. ohne Programmierkentnisse zum Ziel kommen könnte, sondern die grundlegenden Dinge wie eben Installation und Grundkonfiguration, dass diese einfach so klappen müssen.</p>
<p dir="auto">Geht aber natürlich nicht, wenn es aktuell (offiziell/inoffiziell?!) nicht funktioniert.</p>
]]></description><link>https://forum.iobroker.net/post/138373</link><guid isPermaLink="true">https://forum.iobroker.net/post/138373</guid><dc:creator><![CDATA[DubZ]]></dc:creator><pubDate>Fri, 09 Mar 2018 11:48:39 GMT</pubDate></item><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Fri, 09 Mar 2018 11:08:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Also hier ist gar nichts zu alt!</p>
<p dir="auto">Nodejs 4 ist noch vollständig als LTS supportet. Daran liegt es nicht.</p>
<p dir="auto">Ja nodejs 4 sollte im April ggf. nicht mehr Mittel der Wahl sein, aber aktuell und auch danach noch ne Weile vollkommen ok.</p>
<p dir="auto">Das Problem liegt egher daran das die im zWave-Adapter verwendete Library unter WIndows nicht funktioniert. Es tat irgendwann mal ist aber dann bei denen kaputt gegangen und die Owner der Library ignorieren das aktuell (z.B. <a href="https://github.com/OpenZWave/node-openzwave-shared/issues/211" rel="nofollow ugc">https://github.com/OpenZWave/node-openz … issues/211</a>). Häng dich gern an den thread dran um die Wichtigkeit zu erhöhen.</p>
<p dir="auto">Ich denke inzwischen ist der Punkt erreicht wo man mal offiziell auch beim Adapter schreiben sollte das WIndows unsupportet ist - denke bisher hatten wir noch Hoffnung.</p>
<p dir="auto">Zu Deiner zweiten Frage:</p>
<p dir="auto">Wenn Du ioBroker mit anderen Open-Source Lösungen vergleichst dann wirst Du denke ggf bei allen Themen haben die du dir genauer ansehen musst. Die Herausforderung bei IoT und Home-Automation ist das so viele Dinge mitspielen. Wenn Du ioBroker gegen kommerzielle Systeme vergleichen willst dann hör gleich auf weil da ioBroker nur verlieren kann. WICHTIG: Das meine ich nicht auf der Funktionalen ebene, sondern auf der "Rundum sorglos Paket wo man nur User sein kann und sich nie mit DIngen auseinandersetzen muss"-Thematik.</p>
<p dir="auto">Also kurz: ZWave kann ioBroker unter Windows gerade nicht supporten. Linux und macOS tun aber</p>
]]></description><link>https://forum.iobroker.net/post/138363</link><guid isPermaLink="true">https://forum.iobroker.net/post/138363</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Fri, 09 Mar 2018 11:08:42 GMT</pubDate></item><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Fri, 09 Mar 2018 10:14:22 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, ich muss nachfragen… bin neu im Heimautomatisierung aber IT und Etechnik versiert. Aber ich muss mir hier die Frage stellen, ob ich mit iobroker richtig aufgehoben bin oder nicht. Es scheitert ja schon an der Basis Installation dass ich den latest windows installer vorgestern heruntergeladen habe und da irgendwelche Module zu alt sind um den standard zwave Controller anzubinden?!</p>
<p dir="auto">Daher die Frage, ist das nun aus diversen Gründen ein Zufall oder werde ich öfters mit iobroker anecken wo ich mich tief einarbeiten muss um Fehler zu fixen? Ich wollte nämlich iobroker mit 2 anderen Programmen testen und vergleichen.</p>
]]></description><link>https://forum.iobroker.net/post/138352</link><guid isPermaLink="true">https://forum.iobroker.net/post/138352</guid><dc:creator><![CDATA[DubZ]]></dc:creator><pubDate>Fri, 09 Mar 2018 10:14:22 GMT</pubDate></item><item><title><![CDATA[Reply to [Frage] Problem Installation OpenZWave on Fri, 09 Mar 2018 09:45:51 GMT]]></title><description><![CDATA[<pre><code>npm
 ERR! node v4.5.0
npm
 ERR! npm  v2.15.9npm
</code></pre>
<p dir="auto">das ist bissel alt .. das wird nichts</p>
]]></description><link>https://forum.iobroker.net/post/138339</link><guid isPermaLink="true">https://forum.iobroker.net/post/138339</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Fri, 09 Mar 2018 09:45:51 GMT</pubDate></item></channel></rss>
