  4. Hannah — Open Source Smart-Home-Sprachassistentin
    apollon77A
311 Beiträge 24 Kommentatoren 23.0k Aufrufe 36 Beobachtet
  • M
    M
    micklafisch
    #270
    ja, mich wundert nur die Aussage von @McBeath dass es bei Port 5000 nun bei ihm läuft. Danke, du bist echt flott
    • M
      M
      micklafisch
      #271
      der Container für die Core stürzt permanent ab, Fehlermeldung "access denied". Ich hatte aus der Doku die compose.yaml erstellt und verwendet.
      2026/09/23 15:42:34	stderr	mysql.connector.errors.ProgrammingError: 1045 (28000): Access denied for user 'hannah_user'@'172.22.0.4' (using password: YES)
      2026/09/23 15:42:34	stderr	    ) from err
      2026/09/23 15:42:34	stderr	        err.errno, msg=err.msg, sqlstate=err.sqlstate
      2026/09/23 15:42:34	stderr	    raise get_mysql_exception(
      2026/09/23 15:42:34	stderr	  File "/usr/local/lib/python3.14/site-packages/mysql/connector/connection_cext.py", line 360, in _open_connection
      2026/09/23 15:42:34	stderr	    ~~~~~~~~~~~~~~~~~~~~~^^
      2026/09/23 15:42:34	stderr	    self._open_connection()
      2026/09/23 15:42:34	stderr	  File "/usr/local/lib/python3.14/site-packages/mysql/connector/abstracts.py", line 1604, in connect
      2026/09/23 15:42:34	stderr	    ~~~~~~~~~~~~^^^^^^^^^^
      2026/09/23 15:42:34	stderr	    self.connect(**kwargs)
      2026/09/23 15:42:34	stderr	  File "/usr/local/lib/python3.14/site-packages/mysql/connector/connection_cext.py", line 142, in __init__
      2026/09/23 15:42:34	stderr	    return CMySQLConnection(*args, **kwargs)
      2026/09/23 15:42:34	stderr	  File "/usr/local/lib/python3.14/site-packages/mysql/connector/pooling.py", line 322, in connect
      2026/09/23 15:42:34	stderr	           ~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^
      2026/09/23 15:42:34	stderr	    return mysql.connector.connect(**kwargs)
      2026/09/23 15:42:34	stderr	  File "/usr/local/lib/python3.14/site-packages/pyorm/dialects/mysql.py", line 26, in connect
      2026/09/23 15:42:34	stderr	               ~~~~~~~~~~~~~~~^^^^^^^^^^
      2026/09/23 15:42:34	stderr	    return cls(dialect.connect(**kwargs), dialect)
      2026/09/23 15:42:34	stderr	  File "/usr/local/lib/python3.14/site-packages/pyorm/database.py", line 32, in mysql
      2026/09/23 15:42:34	stderr	    ^
      2026/09/23 15:42:34	stderr	        ^^^^^^^^^^^^^^^^^^^^^^^^^^
      2026/09/23 15:42:34	stderr	        database=_cfg["database"],
      2026/09/23 15:42:34	stderr	    ...<3 lines>...
      2026/09/23 15:42:34	stderr	        host=_cfg["host"],
      2026/09/23 15:42:34	stderr	           ~~~~~~~~~~~~~~^
      2026/09/23 15:42:34	stderr	    return Database.mysql(
      2026/09/23 15:42:34	stderr	  File "/app/hannah/utils/activity_db.py", line 50, in get_activity_db
      2026/09/23 15:42:34	stderr	    db = get_activity_db()
      2026/09/23 15:42:34	stderr	  File "/app/hannah/utils/activity_db.py", line 39, in init_activity_db
      2026/09/23 15:42:34	stderr	    ~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^
      2026/09/23 15:42:34	stderr	    init_activity_db(activity_log_cfg)
      2026/09/23 15:42:34	stderr	  File "/app/main.py", line 150, in main
      2026/09/23 15:42:34	stderr	    ~~~~^^
      2026/09/23 15:42:34	stderr	    main()
      2026/09/23 15:42:34	stderr	  File "/app/main.py", line 2696, in <module>
      2026/09/23 15:42:34	stderr	Traceback (most recent call last):
      2026/09/23 15:42:34	stderr	The above exception was the direct cause of the following exception:
      2026/09/23 15:42:34	stderr	_mysql_connector.MySQLInterfaceError: Access denied for user 'hannah_user'@'172.22.0.4' (using password: YES)
      2026/09/23 15:42:34	stderr	    ~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^
      2026/09/23 15:42:34	stderr	    self._cmysql.connect(**cnx_kwargs)
      2026/09/23 15:42:34	stderr	  File "/usr/local/lib/python3.14/site-packages/mysql/connector/connection_cext.py", line 354, in _open_connection
      2026/09/23 15:42:33	stderr	13:42:33 [INFO] hannah.main: Hannah Core dev
      • L
        L
        Leonie
        #272
        Zeige mir bitte die generierte compose.yaml. gerne auch per Chat
        • L
          L
          Leonie
          #273
          Heyy,
          ich habe gute Neuigkeiten für alle, die ihren Hannah-Account mit Telegram verbinden möchten!
          Bisher gab es da ja ein paar Hürden, aber das gehört ab sofort der Vergangenheit an: Es wird ab sofort weder HTTPS noch eine eigene Domain benötigt.
          Was ist neu?
          Mit der neuen Version entfallen die merkwürdigen Anforderungen seitens Telegram komplett. Der Ablauf ist jetzt extrem simpel:
          1. In der WebUI klickt ihr einfach auf „Verbinden“.
          2. Ihr werdet direkt zu Telegram weitergeleitet und erhaltet dort einen Einladungslink für den Chat mit dem Bot.
          3. Sobald ihr den Chat startet, wird euer Account automatisch verbunden.
          Kurzum: Für alle deutlich einfacher und unkomplizierter einzurichten!
          Voraussetzungen
          Damit das reibungslos funktioniert, müsst ihr folgende Versionen (oder neuer) einsetzen:
          • Hannah Core / Telegram: v0.85.0
          • Hannah WebUI: v2.8.0
          • Hinweis: hannah-telegram muss natürlich gestartet sein und über einen gültigen Bot-Token verfügen.
          Bezugsquellen
          Die aktuellen Versionen stehen ab sofort bereit:
          • Wie gewohnt auf meinem Update-Server
          • Für alle Docker-Nutzer als Image auf quay.io
          Testet es gerne aus und gebt Bescheid, falls Fragen oder Feedback auftauchen!
          Viel Spaß damit!
          • Walter.O.W
            Walter.O.W
            Walter.O.
            schrieb am zuletzt editiert von Walter.O.
            #274
            Krass Leonie, damit hat es auch bei mir Jetzt Funktioniert. Du Bist echt Super.👍
            • Walter.O.W
              Walter.O.W
              Walter.O.
              #275
              Mal eine Frage an euch.
              ist das alles so Richtig, das hannah dieses Gerät Finden müsste oder habe ich wieder einen Denkfehler?
              Oder muss ich die Einstellungen für ein Gerät noch woanders eingeben.
              • L
                L
                Leonie
                #276
                Zeig mal bitte die Adapter-Einstellungen. Ich denke da fehlt die die Raum- und Funktionsauswahl
                • Walter.O.W
                  Walter.O.W
                  Walter.O.
                  #277
                  • L
                    L
                    Leonie
                    schrieb am zuletzt editiert von Leonie
                    #278
                    Dir fehlt mindestens die Funktion Engine. Die hat dein State zugewiesen. Wähle die also noch aus, drücke auf Speichern und Hannah sollte das Gerät finden.
                    Walter.O.W 1 Antwort Letzte Antwort
                    • L Leonie
                      Walter.O.W
                      Walter.O.W
                      Walter.O.
                      #279
                      @Leonie
                      Sep 23 21:32:40 iob python[1959373]: 21:32:40 [INFO] hannah.grpc_server: [grpc] Channel-Adapter registriert: 'telegram' (version='', verknüpfbar=True)
                      Sep 23 21:33:00 iob python[1959373]: 21:33:00 [INFO] hannah.grpc_server: [grpc] SubmitText von telegram:5160868646 (user=2) — 'Schalte im Wohnzimmer Tablett laden ein'
                      Sep 23 21:33:00 iob python[1959373]: 21:33:00 [INFO] hannah.main: [textcmd] Text: 'Schalte im Wohnzimmer Tablett laden ein' → Intent: Unknown | Raum: Wohnzimmer | Gerät: Tablett laden | Wert: None | SpeakerUser: 2
                      Sep 23 21:33:00 iob python[1959373]: 21:33:00 [INFO] hannah.tool_agent: [tool_agent] Iteration 1/5 — payload 2 msgs / ~763 chars
                      Sep 23 21:33:00 iob python[1959373]: 21:33:00 [INFO] hannah.tool_agent: [tool_agent] finish_reason=stop tool_calls=0
                      Sep 23 21:33:00 iob python[1959373]: 21:33:00 [INFO] hannah.main: [2] Antwort (Unknown): 'Das kann ich leider nicht beantworten.'
                      • L
                        L
                        Leonie
                        #280
                        Das hat sie nicht verstanden. Probier bitte mal die Form "Schalte im Wohnzimmer Tablett laden an"
                        • Walter.O.W
                          Walter.O.W
                          Walter.O.
                          #281
                          Ja Stimmt kaum macht mans Richtig, Gehts...
                          • L
                            L
                            Leonie
                            #282
                            Wenn deine WebUI läuft, kannst du in der in den Settings die turn_on wörter bearbeiten und "ein" einfach dazuschreiben
                            • Walter.O.W
                              Walter.O.W
                              Walter.O.
                              #283
                              Weiß jemand was man bei einem Shelly: shellyplus2pm alles wo einstellen muss und wo solll das zahnrad hin
                              • L
                                L
                                Leonie
                                #284
                                Mir ist nicht ganz klar was du meinst? So speziell ist der shellyplus2pm doch nicht. Klappt was nicht? Was soll funktionieren und tut es nicht?
                                Das Zahnrad ist bei jedem State rechts bei den Aktionen, da wo auch die Mülltonne ist.
                                Übrigens: Ich habe einen kritischen Fehler in Hannah Core entdeckt und behoben.
                                • M
                                  M
                                  micklafisch
                                  #285
                                  wenn noch jemand mit PCBWay Erfahrung bestellen will, ich würde auch erstmal einen zum testen nehmen. Wenn das fluffig läuft dann später auch mehr (aktuell habe ich 6 Echo dots im Einsatz).
                                  • L
                                    L
                                    Leonie
                                    #286
                                    Ich habe eine Beschreibung zum Prozess bei PCBWay geschrieben: https://hannah-docs.leonie.network/components/satellite/pcb-order/
                                    Feedback gerne hierher.
                                    Ich empfehle eine Mindestbestellmenge von 5 Stück. Darunter ist es nicht wirtschaftlich.
                                    • Walter.O.W
                                      Walter.O.W
                                      Walter.O.
                                      #287
                                      Kann man hier eine Umfrage erstellen wer was haben möchte für pcbway?
                                      • L Leonie
                                        Walter.O.W
                                        Walter.O.W
                                        Walter.O.
                                        #288
                                        @Leonie Ich habe es noch nicht versucht, da ich noch nicht genau weiß welche Datenpunkte ich brauche um die Rolläden zu steuern. Z.B. um die Rolläden auf % zu fahren oder auf/zu.
                                        • L
                                          L
                                          Leonie
                                          #289
                                          Grundsätzlich kann Hannah das. Generell steht zu Rollläden auch was dort: https://hannah-docs.leonie.network/manual/smart-home-integration/
                                          Da ich aber nicht weiß welche Rollläden du hast bzw. welche States die haben, müsstest du mindestens einen Screenshot davon teilen
                                          83.9k
