  4. Test Adapter anker-solix V0.10.86
    6.8k
25 Beiträge 3 Kommentatoren 347 Aufrufe 6 Beobachtet
  • P plutek
    @Thomas-Braun
    gerne...
    Script v.2026-06-06
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: SmartHomeServer
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.12.101+deb13-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 12y 4month 3w 3d
    OS is similar to:
    model name	: Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64bit
    System was installed 1676 days ago (on 2022-01-21).
    Systemuptime and Load:
     10:34:01 up 14:37,  1 user,  load average: 15.86, 13.69, 6.20
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2026-08-25 10:34:02 CEST
               Universal time: Tue 2026-08-25 08:34:02 UTC
                     RTC time: Tue 2026-08-25 08:34:02
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    peter
    HOME=/home/peter
    GROUPS=peter cdrom floppy sudo audio dip video plugdev netdev iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev bluetooth
    *** DISPLAY-SERVER SETUP ***
    Display-Server:		Unknown
    Display-Manager: 	Not found
    Desktop:
    Session:		tty
    Boot Target: 		multi-user.target
    *** MEMORY ***
    Mem:            4.1G        2.4G        1.5G         61K        412M        1.7G
    Swap:           1.0G         53M        970M
    Total:          5.1G        2.4G        2.4G
    Active iob-Instances: 	5
             3921 M total memory
             2255 M used memory
             1989 M active memory
              323 M inactive memory
             1399 M free memory
               41 M buffer memory
              351 M swap cache
              975 M total swap
               50 M used swap
              925 M free swap
    top - 10:34:02 up 14:37,  1 user,  load average: 15.86, 13.69, 6.20
    Tasks: 214 total,   1 running, 213 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 91.7 id,  8.3 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3921.8 total,   1399.2 free,   2254.8 used,    394.2 buff/cache
    MiB Swap:    976.0 total,    925.2 free,     50.8 used.   1667.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     393M  604K  392M   1% /run
    /dev/sda1      ext4      6.2G  2.4G  3.5G  42% /
    tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/sda8      ext4       22G  4.4G   16G  22% /home
    /dev/sda3      ext4      9.8G  2.3G  7.1G  24% /opt
    /dev/sda7      ext4      472M  1.6M  441M   1% /tmp
    /dev/sda5      ext4      2.4G  1.2G  1.1G  52% /var
    tmpfs          tmpfs     393M  8.0K  393M   1% /run/user/1000
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    Messages concerning filesystems in dmesg:
    [Mon Aug 24 19:56:06 2026] EXT4-fs (sda1): mounted filesystem 64ee119e-2811-4a31-ba97-d453b67bcc25 ro with ordered data mode. Quota mode: none.
    [Mon Aug 24 19:56:07 2026] EXT4-fs (sda1): re-mounted 64ee119e-2811-4a31-ba97-d453b67bcc25 r/w.
    [Mon Aug 24 19:56:08 2026] EXT4-fs (sda8): mounted filesystem 20edcbf8-3c19-4465-b49b-0ff1eae28f71 r/w with ordered data mode. Quota mode: none.
    [Mon Aug 24 19:56:08 2026] EXT4-fs (sda3): mounted filesystem 03a53023-43f7-489a-a684-3f4ae9575c2a r/w with ordered data mode. Quota mode: none.
    [Mon Aug 24 19:56:08 2026] EXT4-fs (sda7): mounted filesystem 79ec992b-94b5-4cb0-8eaf-680fd6371644 r/w with ordered data mode. Quota mode: none.
    [Mon Aug 24 19:56:08 2026] EXT4-fs (sda5): mounted filesystem 5b697b0b-6c2b-44d4-99c4-12d0321bd1da r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda1 ext4   rw,relatime,errors=remount-ro
    |-/home /dev/sda8 ext4   rw,relatime
    |-/opt  /dev/sda3 ext4   rw,relatime
    |-/tmp  /dev/sda7 ext4   rw,relatime
    `-/var  /dev/sda5 ext4   rw,relatime
    /var:
    1.2G	/var/
    595M	/var/lib
    446M	/var/lib/apt/lists
    446M	/var/lib/apt
    301M	/var/cache
    Archived and active journals take up 73.7M in the file system.
    /opt/iobroker/backups:
    301M	/opt/iobroker/backups/influxDB_2024_10_20-02_40_10_backupiobroker
    /opt/iobroker/iobroker-data:
    622M	/opt/iobroker/iobroker-data/
    336M	/opt/iobroker/iobroker-data/files
    211M	/opt/iobroker/iobroker-data/backup-objects
    78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    47M	/opt/iobroker/iobroker-data/files/admin.admin
    37M	/opt/iobroker/iobroker-data/objects.jsonl
    14M	/opt/iobroker/iobroker-data/objects.json.migrated
    14M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    8.2M	/opt/iobroker/iobroker-data/files/modbus.admin/assets/index-6vd4TbNS.js
    8.0M	/opt/iobroker/iobroker-data/files/daswetter.admin/assets/index-84bRrRlB.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0055-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0070-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs		v22.23.2
    /usr/bin/node		v22.23.2
    /usr/bin/npm		10.9.8
    /usr/bin/npx		10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.23.2-1nodesource1
      Candidate: 22.23.2-1nodesource1
      Version table:
     *** 22.23.2-1nodesource1 1001
         22.23.1-1nodesource1 1001
         22.23.0-1nodesource1 1001
         22.22.3-1nodesource1 1001
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
            500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    SmartHomeServer     SmartHomeServer (version: 7.2.2, hostname: SmartHomeServer, alive, uptime: 33)
    Core adapters versions
    js-controller: 	7.2.2
    admin: 		7.8.23
    javascript: 	9.0.18
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : SmartHomeServer                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.anker-solix.0            : anker-solix           : SmartHomeServer                          -  enabled
      system.adapter.ankersolix2.0            : ankersolix2           : SmartHomeServer                          - disabled
      system.adapter.ankersolix2.1            : ankersolix2           : SmartHomeServer                          - disabled
    + system.adapter.backitup.0               : backitup              : SmartHomeServer                          -  enabled
      system.adapter.ble.0                    : ble                   : SmartHomeServer                          - disabled
      system.adapter.bmw.0                    : bmw                   : SmartHomeServer                          - disabled
      system.adapter.daswetter.0              : daswetter             : SmartHomeServer                          -  enabled
      system.adapter.discovery.0              : discovery             : SmartHomeServer                          -  enabled
      system.adapter.email.0                  : email                 : SmartHomeServer                          -  enabled
      system.adapter.flot.0                   : flot                  : SmartHomeServer                          -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : SmartHomeServer                          -  enabled
    + system.adapter.history.0                : history               : SmartHomeServer                          -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : SmartHomeServer                          - disabled, port: 0
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : SmartHomeServer                          -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : SmartHomeServer                          -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : SmartHomeServer                          -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : SmartHomeServer                          -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: SmartHomeServer                          -  enabled
    + system.adapter.influxdb.0               : influxdb              : SmartHomeServer                          -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : SmartHomeServer                          -  enabled
      system.adapter.mercedesme.0             : mercedesme            : SmartHomeServer                          - disabled
      system.adapter.modbus.0                 : modbus                : SmartHomeServer                          -  enabled
      system.adapter.modbus.1                 : modbus                : SmartHomeServer                          -  enabled
      system.adapter.modbus.2                 : modbus                : SmartHomeServer                          -  enabled
      system.adapter.modbus.3                 : modbus                : SmartHomeServer                          -  enabled
      system.adapter.mqtt.0                   : mqtt                  : SmartHomeServer                          -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : SmartHomeServer                          -  enabled, port: 1885, bind: 0.0.0.0
      system.adapter.mqtt.2                   : mqtt                  : SmartHomeServer                          -  enabled, port: 1887, bind: 0.0.0.0
      system.adapter.netatmo.0                : netatmo               : SmartHomeServer                          -  enabled
      system.adapter.reolink.0                : reolink               : SmartHomeServer                          -  enabled
      system.adapter.semp.0                   : semp                  : SmartHomeServer                          -  enabled
      system.adapter.shelly.0                 : shelly                : SmartHomeServer                          -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.smartmeter.0             : smartmeter            : SmartHomeServer                          -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : SmartHomeServer                          -  enabled
      system.adapter.smartmeter.2             : smartmeter            : SmartHomeServer                          -  enabled
      system.adapter.sonoff.0                 : sonoff                : SmartHomeServer                          -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.tr-064.0                 : tr-064                : SmartHomeServer                          - disabled
      system.adapter.vis-bars.0               : vis-bars              : SmartHomeServer                          -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : SmartHomeServer                          -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : SmartHomeServer                          -  enabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : SmartHomeServer                          -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : SmartHomeServer                          -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : SmartHomeServer                          -  enabled
      system.adapter.vis-map.0                : vis-map               : SmartHomeServer                          -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : SmartHomeServer                          -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : SmartHomeServer                          -  enabled
      system.adapter.vis-metro.0              : vis-metro             : SmartHomeServer                          -  enabled
      system.adapter.vis-players.0            : vis-players           : SmartHomeServer                          -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : SmartHomeServer                          -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : SmartHomeServer                          -  enabled
      system.adapter.vis-weather.0            : vis-weather           : SmartHomeServer                          -  enabled
      system.adapter.vis.0                    : vis                   : SmartHomeServer                          -  enabled
      system.adapter.web.0                    : web                   : SmartHomeServer                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                           │ name                          │ version   │ upgrade policy │
    │ 0       │ 'system.adapter.admin'                       │ 'admin'                       │ '7.8.23'  │ 'none'         │
    │ 1       │ 'system.adapter.anker-solix'                 │ 'anker-solix'                 │ '0.10.90' │ 'none'         │
    │ 2       │ 'system.adapter.ankersolix2'                 │ 'ankersolix2'                 │ '2.4.1'   │ 'none'         │
    │ 3       │ 'system.adapter.backitup'                    │ 'backitup'                    │ '3.3.17'  │ 'none'         │
    │ 4       │ 'system.adapter.ble'                         │ 'ble'                         │ '0.14.0'  │ 'none'         │
    │ 5       │ 'system.adapter.bmw'                         │ 'bmw'                         │ '5.0.0'   │ 'none'         │
    │ 6       │ 'system.adapter.daswetter'                   │ 'daswetter'                   │ '4.5.3'   │ 'none'         │
    │ 7       │ 'system.adapter.discovery'                   │ 'discovery'                   │ '5.0.0'   │ 'none'         │
    │ 8       │ 'system.adapter.email'                       │ 'email'                       │ '2.0.4'   │ 'none'         │
    │ 9       │ 'system.adapter.flot'                        │ 'flot'                        │ '1.12.0'  │ 'none'         │
    │ 10      │ 'system.adapter.fullybrowser'                │ 'fullybrowser'                │ '3.1.2'   │ 'none'         │
    │ 11      │ 'system.adapter.history'                     │ 'history'                     │ '4.0.0'   │ 'none'         │
    │ 12      │ 'system.adapter.hm-rpc'                      │ 'hm-rpc'                      │ '3.0.1'   │ 'none'         │
    │ 13      │ 'system.adapter.icons-fatcow-hosting'        │ 'icons-fatcow-hosting'        │ '0.1.0'   │ 'none'         │
    │ 14      │ 'system.adapter.icons-icons8'                │ 'icons-icons8'                │ '0.0.1'   │ 'none'         │
    │ 15      │ 'system.adapter.icons-mfd-png'               │ 'icons-mfd-png'               │ '1.2.1'   │ 'none'         │
    │ 16      │ 'system.adapter.icons-mfd-svg'               │ 'icons-mfd-svg'               │ '1.2.0'   │ 'none'         │
    │ 17      │ 'system.adapter.icons-open-icon-library-png' │ 'icons-open-icon-library-png' │ '0.1.2'   │ 'none'         │
    │ 18      │ 'system.adapter.influxdb'                    │ 'influxdb'                    │ '4.0.2'   │ 'none'         │
    │ 19      │ 'system.adapter.javascript'                  │ 'javascript'                  │ '9.0.18'  │ 'none'         │
    │ 20      │ 'system.adapter.mercedesme'                  │ 'mercedesme'                  │ '0.3.8'   │ 'none'         │
    │ 21      │ 'system.adapter.modbus'                      │ 'modbus'                      │ '8.0.3'   │ 'none'         │
    │ 22      │ 'system.adapter.mqtt'                        │ 'mqtt'                        │ '6.1.4'   │ 'none'         │
    │ 23      │ 'system.adapter.netatmo'                     │ 'netatmo'                     │ '3.1.0'   │ 'none'         │
    │ 24      │ 'system.adapter.reolink'                     │ 'reolink'                     │ '1.4.2'   │ 'none'         │
    │ 25      │ 'system.adapter.semp'                        │ 'semp'                        │ '2.0.12'  │ 'none'         │
    │ 26      │ 'system.adapter.shelly'                      │ 'shelly'                      │ '10.6.1'  │ 'none'         │
    │ 27      │ 'system.adapter.simple-api'                  │ 'simple-api'                  │ '3.0.7'   │ 'none'         │
    │ 28      │ 'system.adapter.smartmeter'                  │ 'smartmeter'                  │ '3.4.0'   │ 'none'         │
    │ 29      │ 'system.adapter.socketio'                    │ 'socketio'                    │ '7.1.3'   │ 'none'         │
    │ 30      │ 'system.adapter.sonoff'                      │ 'sonoff'                      │ '3.3.0'   │ 'none'         │
    │ 31      │ 'system.adapter.tr-064'                      │ 'tr-064'                      │ '4.3.0'   │ 'none'         │
    │ 32      │ 'system.adapter.tuya'                        │ 'tuya'                        │ '3.17.0'  │ 'none'         │
    │ 33      │ 'system.adapter.vis'                         │ 'vis'                         │ '1.5.6'   │ 'none'         │
    │ 34      │ 'system.adapter.vis-bars'                    │ 'vis-bars'                    │ '0.1.4'   │ 'none'         │
    │ 35      │ 'system.adapter.vis-canvas-gauges'           │ 'vis-canvas-gauges'           │ '1.0.1'   │ 'none'         │
    │ 36      │ 'system.adapter.vis-hqwidgets'               │ 'vis-hqwidgets'               │ '1.6.1'   │ 'none'         │
    │ 37      │ 'system.adapter.vis-inventwo'                │ 'vis-inventwo'                │ '4.1.1'   │ 'none'         │
    │ 38      │ 'system.adapter.vis-jqui-mfd'                │ 'vis-jqui-mfd'                │ '1.1.3'   │ 'none'         │
    │ 39      │ 'system.adapter.vis-justgage'                │ 'vis-justgage'                │ '2.1.7'   │ 'none'         │
    │ 40      │ 'system.adapter.vis-map'                     │ 'vis-map'                     │ '1.1.2'   │ 'none'         │
    │ 41      │ 'system.adapter.vis-material-advanced'       │ 'vis-material-advanced'       │ '1.7.4'   │ 'none'         │
    │ 42      │ 'system.adapter.vis-materialdesign'          │ 'vis-materialdesign'          │ '0.5.9'   │ 'none'         │
    │ 43      │ 'system.adapter.vis-metro'                   │ 'vis-metro'                   │ '1.2.0'   │ 'none'         │
    │ 44      │ 'system.adapter.vis-players'                 │ 'vis-players'                 │ '0.1.6'   │ 'none'         │
    │ 45      │ 'system.adapter.vis-rgraph'                  │ 'vis-rgraph'                  │ '0.0.2'   │ 'none'         │
    │ 46      │ 'system.adapter.vis-timeandweather'          │ 'vis-timeandweather'          │ '1.2.2'   │ 'none'         │
    │ 47      │ 'system.adapter.vis-weather'                 │ 'vis-weather'                 │ '2.5.13'  │ 'none'         │
    │ 48      │ 'system.adapter.web'                         │ 'web'                         │ '8.0.0'   │ 'none'         │
    │ 49      │ 'system.adapter.ws'                          │ 'ws'                          │ '4.1.0'   │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "bmw"          : 5.0.0    , installed 5.0.0
    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.2.2    , installed 7.2.2
    Adapter    "modbus"       : 8.0.3    , installed 8.0.3
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "reolink"      : 1.4.2    , installed 1.4.2
    Adapter    "semp"         : 2.0.12   , installed 2.0.12
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-inventwo" : 4.1.1    , installed 4.1.1
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Objects and States
    Objects: 	18368
    States: 	15601
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://repos.influxdata.com/debian stretch InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key AC10D7449F343ADCEFDDC6DA61C26A0585BD3B, which is needed to verify signature.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://packages.grafana.com/enterprise/deb stable InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B53AE77BADB630A6830460963FA27710458545, which is needed to verify signature.
    W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B53AE77BADB630A6830460963FA27710458545, which is needed to verify signature.
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key AC10D7449F343ADCEFDDC2B6D1C26A0585BD3B, which is needed to verify signature.
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://security.debian.org/debian-security trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Get:4 https://packages.grafana.com/enterprise/deb stable InRelease [7661 B]
    Err:4 https://packages.grafana.com/enterprise/deb stable InRelease
      Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B53AE77BADB630A68304600596327710458545, which is needed to verify signature.
    Get:5 https://repos.influxdata.com/debian stretch InRelease [12.9 kB]
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Err:5 https://repos.influxdata.com/debian stretch InRelease
      Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key AC10D7449F343ADCEFDDC2B6DA61C20585BD3B, which is needed to verify signature.
    Fetched 12.9 kB in 0s (50.2 kB/s)
    Reading package lists...
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://packages.grafana.com/enterprise/deb stable InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B53AE77BADB630A683046005963FA710458545, which is needed to verify signature.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://repos.influxdata.com/debian stretch InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key AC10D7449F343ADCEFDDC2B6DA616A0585BD3B, which is needed to verify signature.
    W: Failed to fetch https://packages.grafana.com/enterprise/deb/dists/stable/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B53AE77BADB630A683046005963FA270458545, which is needed to verify signature.
    W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key AC10D7449F343ADCEFDDC2B6DA61C26A0585BD3B, which is needed to verify signature.
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q Local Address:Port    Peer Address:PortProcess
    udp   UNCONN 0      0            0.0.0.0:sunrpc       0.0.0.0:*    users:(("rpcbind",pid=543,fd=5),("systemd",pid=1,fd=115))
    udp   UNCONN 0      0               [::]:sunrpc          [::]:*    users:(("rpcbind",pid=543,fd=7),("systemd",pid=1,fd=124))
    tcp   LISTEN 0      4096         0.0.0.0:sunrpc       0.0.0.0:*    users:(("rpcbind",pid=543,fd=4),("systemd",pid=1,fd=112))
    tcp   LISTEN 0      20         127.0.0.1:smtp         0.0.0.0:*    users:(("exim4",pid=917,fd=5))
    tcp   LISTEN 0      128          0.0.0.0:ssh          0.0.0.0:*    users:(("sshd",pid=679,fd=6))
    tcp   LISTEN 0      511        127.0.0.1:9000         0.0.0.0:*    users:(("iobroker.js-con",pid=42862,fd=29))
    tcp   LISTEN 0      511        127.0.0.1:9001         0.0.0.0:*    users:(("iobroker.js-con",pid=42862,fd=23))
    tcp   LISTEN 0      511          0.0.0.0:1887         0.0.0.0:*    users:(("io.mqtt.2",pid=43674,fd=35))
    tcp   LISTEN 0      511          0.0.0.0:1885         0.0.0.0:*    users:(("io.mqtt.1",pid=43642,fd=35))
    tcp   LISTEN 0      511          0.0.0.0:1884         0.0.0.0:*    users:(("io.shelly.0",pid=43600,fd=37))
    tcp   LISTEN 0      511          0.0.0.0:1883         0.0.0.0:*    users:(("io.sonoff.0",pid=43504,fd=40))
    tcp   LISTEN 0      511          0.0.0.0:1882         0.0.0.0:*    users:(("io.mqtt.0",pid=43555,fd=35))
    tcp   LISTEN 0      4096       127.0.0.1:omniorb      0.0.0.0:*    users:(("influxd",pid=647,fd=3))
    tcp   LISTEN 0      4096       127.0.0.1:6060         0.0.0.0:*    users:(("influxd",pid=647,fd=5))
    tcp   LISTEN 0      4096            [::]:sunrpc          [::]:*    users:(("rpcbind",pid=543,fd=6),("systemd",pid=1,fd=117))
    tcp   LISTEN 0      128             [::]:ssh             [::]:*    users:(("sshd",pid=679,fd=7))
    tcp   LISTEN 0      511                *:3001               *:*    users:(("io.fullybrowser",pid=43464,fd=30))
    tcp   LISTEN 0      4096               *:3000               *:*    users:(("grafana-server",pid=624,fd=11))
    tcp   LISTEN 0      20             [::1]:smtp            [::]:*    users:(("exim4",pid=917,fd=6))
    tcp   LISTEN 0      4096               *:8086               *:*    users:(("influxd",pid=647,fd=31))
    tcp   LISTEN 0      511                *:tproxy             *:*    users:(("io.admin.0",pid=42882,fd=39))
    2026-08-25 10:34:43.709  - info: host.SmartHomeServer instance system.adapter.modbus.2 in version "8.0.3" started with pid 43768
    2026-08-25 10:34:43.761  - info: smartmeter.2 (43305) Received 5 values, 2 updated
    2026-08-25 10:34:44.055  - info: mqtt.1 (43642) Client [iobroker-mqtt-client] connected with secret 1787646884053_9079
    2026-08-25 10:34:44.137  - info: mqtt.0 (43555) Client [Kaltwasseruhr] connected with secret 1787646884136_3451
    2026-08-25 10:34:44.169  - info: mqtt.0 (43555) Client [Kaltwasseruhr] subscribes on "mqtt.0.Kaltwasseruhr.Zaehlerstand.ctrl.flow_start"
    2026-08-25 10:34:44.180  - info: mqtt.0 (43555) Client [Kaltwasseruhr] subscribes on "mqtt.0.Kaltwasseruhr.Zaehlerstand.ctrl.set_prevalue"
    2026-08-25 10:34:44.370  - info: mqtt.0 (43555) Client [Kaltwasseruhr] publishOnSubscribe
    2026-08-25 10:34:44.384  - info: mqtt.0 (43555) Client [Kaltwasseruhr] publishOnSubscribe
    2026-08-25 10:34:46.370  - info: smartmeter.1 (43149) Received 5 values, 2 updated
    2026-08-25 10:34:48.006  - info: modbus.1 (43734) starting. Version 8.0.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v22.23.2, js-controller: 7.2.2
    2026-08-25 10:34:48.019  - info: host.SmartHomeServer instance system.adapter.modbus.3 in version "8.0.3" started with pid 43801
    2026-08-25 10:34:48.253  - info: smartmeter.0 (43102) Received 5 values, 1 updated
    2026-08-25 10:34:48.416  - info: modbus.1 (43734) Connected to slave 192.168.21.19
    2026-08-25 10:34:49.493  - info: smartmeter.2 (43305) Received 5 values, 2 updated
    2026-08-25 10:34:50.432  - info: modbus.2 (43768) starting. Version 8.0.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v22.23.2, js-controller: 7.2.2
    2026-08-25 10:34:51.673  - info: smartmeter.1 (43149) Received 5 values, 2 updated
    2026-08-25 10:34:51.803  - info: host.SmartHomeServer instance system.adapter.discovery.0 in version "5.0.0" started with pid 43843
    2026-08-25 10:34:52.148  - info: modbus.2 (43768) Connected to slave 192.168.21.137
    2026-08-25 10:34:52.882  - info: modbus.3 (43801) starting. Version 8.0.3 in /opt/iobroker/node_modules/iobroker.modbus, node: v22.23.2, js-controller: 7.2.2
    2026-08-25 10:34:53.228  - info: modbus.3 (43801) Connected to slave 192.168.21.207
    2026-08-25 10:34:54.191  - info: smartmeter.0 (43102) Received 5 values, 1 updated
    2026-08-25 10:34:55.819  - info: smartmeter.2 (43305) Received 5 values, 2 updated
    2026-08-25 10:34:55.860  - info: host.SmartHomeServer instance system.adapter.web.0 in version "8.0.0" started with pid 43910
    2026-08-25 10:34:56.063  - info: discovery.0 (43843) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v22.23.2, js-controller: 7.2.2
    2026-08-25 10:34:56.858  - info: smartmeter.1 (43149) Received 5 values, 2 updated
    ============= Mark until here for C&P =============
    iob diag has finished.
    @plutek sagte:
    Setz den 'peter' in die Gruppe 'adm'.
    Leg die Quellen für influxdb und grafana nochmal neu an.
    Bei 'sudo apt update' dürfen keine Meldungen erscheinen.
    Und ich würde auch nicht die Enterprise-Versionen sondern die OSS-Version heranziehen.
    In meiner Anleitung stand das mit Sicherheit aber auch so drin:
    Also alle bisherigen Quellen sind erreichbar und deren Schlüssel liegen sauber an Ort und Stelle und es werden auch keine sonstigen Fehler gemeldet.
    P 1 Antwort Letzte Antwort
    • M Online
      M Online
      MatthiasUlrich
      schrieb zuletzt editiert von
      @plutek kannst du bitte die instanz auf debug umstellen und dann noch mal heute Abend schauen ob was im Log steht.
      Statistik ist in den Einstellungen aktiviert? Nur um sicher zu gehen.
        @plutek sagte:
        P Online
        P Online
        plutek
        @Thomas-Braun ja,stimmt. Habe die Keys neu geholt und der peter ist jetzt auch in adm. 👍
        • M MatthiasUlrich
          P Online
          P Online
          plutek
          @MatthiasUlrich auf debug hätte ich Profi ja gestern schon stellen können.
          Habe mal aus jedem Abschnitt eins aktiviert. Morgen sehen wir mehr.
          • P plutek
            @plutek sagte:
            Hast du die influxdb-Quelle korrigiert?
              @plutek sagte:
              P Online
              P Online
              plutek
              @Thomas-Braun sagte:
              Was meinst du damit? Stehe auf dem Schlauch.
              • P plutek
                @plutek
                Da muss statt stretch trixie hin.
                Zeig nochmal dein
                iob diag
                  @plutek
                  Zeig nochmal dein
                  iob diag
                  P Online
                  P Online
                  plutek
                  stretch InRelease
                  hmm, da passt was nicht.
                  peter@SmartHomeServer:/etc/apt/sources.list.d$ cat influxdata.list
                  deb [signed-by=/usr/share/keyrings/influxdata-archive-keyring.gpg] https://repos.influxdata.com/debian stretch InRelease
                  peter@SmartHomeServer:/etc/apt/sources.list.d$ sudo apt update
                  OK:1 http://deb.debian.org/debian trixie InRelease
                  OK:2 http://deb.debian.org/debian trixie-updates InRelease
                  OK:3 http://security.debian.org/debian-security trixie-security InRelease
                  OK:4 https://apt.grafana.com stable InRelease
                  OK:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                  Holen:6 https://repos.influxdata.com/debian stretch InRelease [12,9 kB]
                  Es wurden 12,9 kB in 0 s geholt (42,4 kB/s).
                  Alle Pakete sind aktuell.
                  Warnung: Das Laden der konfigurierten Datei »InRelease/binary-amd64/Packages« wird übersprungen, da das Depot »https://repos.influxdata.com/debian stretch InRelease« die Komponente »InRelease« nicht enthält. (Schreibfehler bei der Angabe der Komponente in sources.list?)
                  Warnung: Das Laden der konfigurierten Datei »InRelease/i18n/Translation-en« wird übersprungen, da das Depot »https://repos.influxdata.com/debian stretch InRelease« die Komponente »InRelease« nicht enthält. (Schreibfehler bei der Angabe der Komponente in sources.list?)
                  Warnung: Das Laden der konfigurierten Datei »InRelease/i18n/Translation-de« wird übersprungen, da das Depot »https://repos.influxdata.com/debian stretch InRelease« die Komponente »InRelease« nicht enthält. (Schreibfehler bei der Angabe der Komponente in sources.list?)
                  Warnung: Das Laden der konfigurierten Datei »InRelease/i18n/Translation-de_DE« wird übersprungen, da das Depot »https://repos.influxdata.com/debian stretch InRelease« die Komponente »InRelease« nicht enthält. (Schreibfehler bei der Angabe der Komponente in sources.list?)
                  • P plutek
                    stretch InRelease
                    @plutek sagte:
                    War mir klar... ;-D
                    Mach es danach:
                    https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                      @plutek sagte:
                      War mir klar... ;-D
                      Mach es danach:
                      P Online
                      P Online
                      plutek
                      schrieb zuletzt editiert von plutek
                      @Thomas-Braun
                      danach habe ich es zuvor gemacht, hier wurde "stable main" eingetragen. Geändert auf "stretch InRelease" habe ich erst nach deinem Post.
                      Warum beim apt update "stable InRelease" ausgegeben wird, kann ich nicht erklären und warum es bei holen( get) bleibt und nicht OK ist kann ich auch nicht erklären. Du sicherlich.
                      OK:1 http://security.debian.org/debian-security trixie-security InRelease
                      OK:2 http://deb.debian.org/debian trixie InRelease
                      OK:3 http://deb.debian.org/debian trixie-updates InRelease
                      Holen:6 https://repos.influxdata.com/debian stable InRelease [6.922 B]
                      Es wurden 6.922 B in 0 s geholt (34,5 kB/s).
                      Aktualisierung für 5 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                      jetzt stehen noch mal 5 Pakete an > apt upgrade.
                      Es wurden 6.922 B in 0 s geholt (30,5 kB/s).
                      • P plutek
                        @Thomas-Braun
                        @plutek sagte:
                        Könnte ich. Führt aber hier zu weit (und ist auch unerheblich).
                        Jedenfalls sind deine Quellen jetzt korrekt. Das System regelmäßiger auf Stand bringen und rechtzeitig auf das jeweils gerade aktuelle stable-Release springen. Im Sommer kommt Debian 14 'Forky'.
                          @plutek sagte:
                          P Online
                          P Online
                          plutek
                          @Thomas-Braun ja das ist ok, und wie du schon sagst ist auch unerheblich. System läuft. 👍 Vielen Dank. Ich muss gestehen mein System war ordentlich alt.. aber lief problemlos und hat keine Probleme gemacht, bis jetzt, da der neue Anker Adapter noch nicht so richtig will.
                          • P plutek
                            @plutek
                            Und mit rechtzeitig gepflegten Kisten fährt man immer besser. Von Sicherheitsdingen fange ich gar nicht erst an...
                            • P plutek
                              P Online
                              P Online
                              plutek
                              auch heute keine Daten. Im log leider auch keine weiteren Einträge.. bis 23:59 Uhr
                              2026-08-25 21:00:52.577  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~5 polls)
                              2026-08-25 21:01:50.365  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:01:52.624  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~4 polls)
                              2026-08-25 21:02:50.356  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:02:52.622  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~3 polls)
                              2026-08-25 21:03:50.424  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:03:52.630  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~2 polls)
                              2026-08-25 21:04:50.363  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:04:52.611  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~1 polls)
                              2026-08-25 21:05:50.415  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:06:00.524  - debug: anker-solix.0 (67427) Poll OK (7 devices, devices+mqtt, next detail in ~10 polls)
                              2026-08-25 21:06:50.360  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:06:52.577  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~9 polls)
                              2026-08-25 21:07:50.360  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:07:52.609  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~8 polls)
                              2026-08-25 21:08:50.351  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:08:52.673  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~7 polls)
                              2026-08-25 21:09:50.355  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:09:52.681  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~6 polls)
                              2026-08-25 21:10:50.353  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:10:52.558  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~5 polls)
                              2026-08-25 21:11:50.351  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:11:52.663  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~4 polls)
                              2026-08-25 21:12:50.358  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:12:52.605  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~3 polls)
                              2026-08-25 21:13:50.366  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:13:52.639  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~2 polls)
                              2026-08-25 21:14:50.350  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:14:52.639  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~1 polls)
                              2026-08-25 21:15:50.351  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:16:00.464  - debug: anker-solix.0 (67427) Poll OK (7 devices, devices+mqtt, next detail in ~10 polls)
                              2026-08-25 21:16:50.348  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:16:52.569  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~9 polls)
                              2026-08-25 21:17:50.360  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:17:52.563  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~8 polls)
                              2026-08-25 21:18:50.362  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:18:52.552  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~7 polls)
                              2026-08-25 21:19:50.370  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:19:52.737  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~6 polls)
                              2026-08-25 21:20:50.394  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:20:52.700  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~5 polls)
                              2026-08-25 21:21:50.377  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:21:52.506  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~4 polls)
                              2026-08-25 21:22:50.385  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:22:52.628  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~3 polls)
                              2026-08-25 21:23:50.365  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:23:52.455  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~2 polls)
                              2026-08-25 21:24:50.384  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:24:52.593  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~1 polls)
                              2026-08-25 21:25:50.373  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:26:00.289  - debug: anker-solix.0 (67427) Poll OK (7 devices, devices+mqtt, next detail in ~10 polls)
                              2026-08-25 21:26:50.384  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:26:52.629  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~9 polls)
                              2026-08-25 21:27:50.377  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:27:52.688  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~8 polls)
                              2026-08-25 21:28:50.355  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:28:52.686  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~7 polls)
                              2026-08-25 21:29:50.400  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:29:52.715  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~6 polls)
                              2026-08-25 21:30:50.378  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:30:52.704  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~5 polls)
                              2026-08-25 21:31:50.373  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:31:52.597  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~4 polls)
                              2026-08-25 21:32:50.410  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
                              2026-08-25 21:32:52.665  - debug: anker-solix.0 (67427) Poll OK (7 devices, sites, next detail in ~3 polls)
                              2026-08-25 21:33:50.402  - info: anker-solix.0 (67427) [anker-solix] Python dependencies already OK.
