  3. Einsteigerfragen
  4. Installation
  5. [Gelöst] IO Broker auf neuer Hardware
    6.7k
23 Beiträge 4 Kommentatoren 360 Aufrufe 5 Beobachtet
    MiFuFli
    Ich habe die Anweisungen wie genannt durchgeführt. Leider immer noch das selbe Ergebnis. Die Log-Daten findet Ihr oben.
    Hier noch die Log.-Datei (ich hoffe im richtigen Format)
    iobroker.2026-08-20.html
    • M MiFuFli
      Script v.2026-06-06
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: raspberry-5-1
             Icon name: computer
                Kernel: Linux 6.18.34+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      System was installed 63 days ago (on 2026-06-18).
      Systemuptime and Load:
       21:04:27 up 1 min,  2 users,  load average: 1.22, 0.58, 0.22
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2026-08-20 21:04:27 CEST
                 Universal time: Thu 2026-08-20 19:04:27 UTC
                       RTC time: Thu 2026-08-20 19:04:27
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev lpadmin gpio i2c spi render input iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         Unknown
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
      Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.5G        1.8G        5.6G         38M        1.1G        6.6G
      Swap:           2.1G          0B        2.1G
      Total:           10G        1.8G        7.7G
      Active iob-Instances:   12
               8062 M total memory
               1759 M used memory
               1741 M active memory
                654 M inactive memory
               5332 M free memory
                 93 M buffer memory
               1000 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      top - 21:04:27 up 1 min,  2 users,  load average: 1.22, 0.58, 0.22
      Tasks: 222 total,   2 running, 220 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 26.9 us,  7.7 sy,  0.0 ni, 61.5 id,  3.8 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8062.4 total,   5323.4 free,   1767.8 used,   1094.9 buff/cache
      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   6294.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     1.6G   14M  1.6G   1% /run
      /dev/mmcblk0p2 ext4       58G  8.8G   47G  16% /
      tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     4.0G  2.6M  4.0G   1% /tmp
      /dev/mmcblk0p1 vfat      505M   87M  418M  18% /boot/firmware
      tmpfs          tmpfs     807M  256K  806M   1% /run/user/1000
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
      Messages concerning filesystems in dmesg:
      [Thu Aug 20 21:02:34 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Thu Aug 20 21:02:34 2026] EXT4-fs (mmcblk0p2): mounted filesystem 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 ro with ordered data mode. Quota mode: none.
      [Thu Aug 20 21:02:36 2026] EXT4-fs (mmcblk0p2): re-mounted 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 r/w.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.5G    /var/
      216M    /var/lib
      215M    /var/cache
      211M    /var/cache/apt
      150M    /var/lib/apt
      Archived and active journals take up 8M in the file system.
      /opt/iobroker/backups:
      2.8M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      208M    /opt/iobroker/iobroker-data/
      113M    /opt/iobroker/iobroker-data/node-red
      111M    /opt/iobroker/iobroker-data/node-red/node_modules
      87M     /opt/iobroker/iobroker-data/files
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      8.3M    /opt/iobroker/iobroker-data/objects.jsonl
      7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.js
      3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-Byv11PyV.js
      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      *** ZigBee Settings ***
      ⚠ HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'.
      Please check your setting:
      tcp
      Zigbee Network Settings on your coordinator / in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      === ZigBee Port Overview ===
      Instance        Configured Port                     Available by-id Port                Status
      zigbee.0        tcp://192.168.178.203:7638          -                                   tcp
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.23.2
      /usr/bin/node           v22.23.2
      /usr/bin/npm            10.9.8
      /usr/bin/npx            10.9.8
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.23.2-1nodesource1
        Candidate: 22.23.2-1nodesource1
        Version table:
       *** 22.23.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
           22.23.1-1nodesource1 1001
           22.23.0-1nodesource1 1001
           22.22.3-1nodesource1 1001
           22.22.2-1nodesource1 1001
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
              500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      No known Vulnerabilities detected!
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberry-5-1       raspberry-5-1 (version: 7.2.2, hostname: raspberry-5-1 , alive, uptime: 110)
      Core adapters versions
      js-controller:  7.2.2
      admin:          7.8.23
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberry-5-1                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : raspberry-5-1                            - disabled
      + system.adapter.backitup.0               : backitup              : raspberry-5-1                            -  enabled
      + system.adapter.discovery.0              : discovery             : raspberry-5-1                            -  enabled
      + system.adapter.mbus.0                   : mbus                  : raspberry-5-1                            -  enabled, port: 3493
      + system.adapter.node-red.0               : node-red              : raspberry-5-1                            -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.reolink.0                : reolink               : raspberry-5-1                            -  enabled
      + system.adapter.smartmeter.0             : smartmeter            : raspberry-5-1                            -  enabled
      + system.adapter.systeminfo.0             : systeminfo            : raspberry-5-1                            -  enabled
      + system.adapter.web.0                    : web                   : raspberry-5-1                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wireless-mbus.0          : wireless-mbus         : raspberry-5-1                            -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberry-5-1                            -  enabled, port: tcp://192.168.178.203:7638
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      │ (index) │ id                             │ name            │ version  │ upgrade policy │
      │ 0       │ 'system.adapter.admin'         │ 'admin'         │ '7.8.23' │ 'none'         │
      │ 1       │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0'  │ 'none'         │
      │ 2       │ 'system.adapter.backitup'      │ 'backitup'      │ '3.3.17' │ 'none'         │
      │ 3       │ 'system.adapter.discovery'     │ 'discovery'     │ '5.0.0'  │ 'none'         │
      │ 4       │ 'system.adapter.mbus'          │ 'mbus'          │ '2.7.0'  │ 'none'         │
      │ 5       │ 'system.adapter.node-red'      │ 'node-red'      │ '6.0.7'  │ 'none'         │
      │ 6       │ 'system.adapter.reolink'       │ 'reolink'       │ '1.4.2'  │ 'none'         │
      │ 7       │ 'system.adapter.smartmeter'    │ 'smartmeter'    │ '3.4.0'  │ 'none'         │
      │ 8       │ 'system.adapter.socketio'      │ 'socketio'      │ '7.1.3'  │ 'none'         │
      │ 9       │ 'system.adapter.systeminfo'    │ 'systeminfo'    │ '1.3.0'  │ 'none'         │
      │ 10      │ 'system.adapter.web'           │ 'web'           │ '8.0.0'  │ 'none'         │
      │ 11      │ 'system.adapter.wireless-mbus' │ 'wireless-mbus' │ '0.10.2' │ 'none'         │
      │ 12      │ 'system.adapter.ws'            │ 'ws'            │ '4.1.0'  │ 'none'         │
      │ 13      │ 'system.adapter.zigbee'        │ 'zigbee'        │ '3.4.5'  │ 'none'         │
      ioBroker-Adapter Versions and update status
      Used repository: stable
      Adapter    "admin"        : 7.8.23   , installed 7.8.23
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "backitup"     : 3.3.17   , installed 3.3.17
      Controller "js-controller": 7.2.2    , installed 7.2.2
      Adapter    "mbus"         : 2.7.0    , installed 2.7.0
      Adapter    "node-red"     : 6.0.7    , installed 6.0.7
      Adapter    "reolink"      : 1.4.2    , installed 1.4.2
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 7.1.3    , installed 7.1.3
      Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
      Adapter    "web"          : 8.0.0    , installed 8.0.0
      Adapter    "wireless-mbus": 0.10.2   , installed 0.10.2
      Adapter    "ws"           : 4.1.0    , installed 4.1.0
      Adapter    "zigbee"       : 3.5.5    , installed 3.4.5  [Updatable]
      Objects and States
      Objects:        772
      States:         606
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending systemupdates: 164
      *** Listening Ports ***
      Netid State  Recv-Q Send-Q                            Local Address:Port          Peer Address:PortProcess
      udp   UNCONN 0      0                                192.168.178.15:54399              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=12))
      udp   UNCONN 0      0                                       0.0.0.0:mdns               0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=8))
      udp   UNCONN 0      0                                       0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=680,fd=12))
      udp   UNCONN 0      0                                       0.0.0.0:59551              0.0.0.0:*    users:(("avahi-daemon",pid=680,fd=14))
      udp   UNCONN 0      0                                       0.0.0.0:59769              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=16))
      udp   UNCONN 0      0                                       0.0.0.0:36129              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=19))
      udp   UNCONN 0      0                                       0.0.0.0:36657              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=20))
      udp   UNCONN 0      0                                       0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=652,fd=5),("systemd",pid=1,fd=83))
      udp   UNCONN 0      0                                       0.0.0.0:45189              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=10))
      udp   UNCONN 0      0                                             *:mdns                     *:*    users:(("rpi-connectd",pid=1269,fd=9))
      udp   UNCONN 0      0                                             *:mdns                     *:*    users:(("avahi-daemon",pid=680,fd=13))
      udp   UNCONN 0      0                                             *:55432                    *:*    users:(("avahi-daemon",pid=680,fd=15))
      udp   UNCONN 0      0                                             *:55960                    *:*    users:(("rpi-connectd",pid=1269,fd=14))
      udp   UNCONN 0      0       [2003:f9:5718:8d00:8aa2:9eff:fef2:8ad1]:40902                    *:*    users:(("rpi-connectd",pid=1269,fd=15))
      udp   UNCONN 0      0                                             *:53299                    *:*    users:(("rpi-connectd",pid=1269,fd=11))
      udp   UNCONN 0      0                                             *:sunrpc                   *:*    users:(("rpcbind",pid=652,fd=7),("systemd",pid=1,fd=85))
      udp   UNCONN 0      0      [fd67:8f5c:ad89:9f4:8aa2:9eff:fef2:8ad1]:37169                    *:*    users:(("rpi-connectd",pid=1269,fd=17))
      udp   UNCONN 0      0                   [fe80::8aa2:9eff:fef2:8ad1]:dhcpv6-client            *:*    users:(("NetworkManager",pid=789,fd=24))
      udp   UNCONN 0      0                   [fe80::8aa2:9eff:fef2:8ad1]:49818                    *:*    users:(("rpi-connectd",pid=1269,fd=18))
      udp   UNCONN 0      0                                             *:58297                    *:*    users:(("rpi-connectd",pid=1269,fd=21))
      tcp   LISTEN 0      4096                                    0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=652,fd=4),("systemd",pid=1,fd=82))
      tcp   LISTEN 0      511                                     0.0.0.0:1880               0.0.0.0:*    users:(("node-red",pid=2907,fd=24))
      tcp   LISTEN 0      511                                   127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=1213,fd=29))
      tcp   LISTEN 0      511                                   127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=1213,fd=23))
      tcp   LISTEN 0      4096                                       [::]:sunrpc                [::]:*    users:(("rpcbind",pid=652,fd=6),("systemd",pid=1,fd=84))
      tcp   LISTEN 0      511                                           *:10001                    *:*    users:(("node-red",pid=2907,fd=47))
      tcp   LISTEN 0      511                                           *:tproxy                   *:*    users:(("io.admin.0",pid=1775,fd=39))
      tcp   LISTEN 0      511                                           *:8082                     *:*    users:(("io.web.0",pid=2323,fd=35))
      2026-08-20 21:04:50.148  - info: node-red.0 (2907) 31c1e62c564880b1: Automatic objects creation is not enabled. You can enable it in the node configuration
      2026-08-20 21:04:50.169  - info: node-red.0 (2907) 96c3a28711c8f018: "ioBroker in" Cannot set state of non-existing object "mbus.0.EMU-2748.data.3-0-Current".
      2026-08-20 21:04:50.169  - info: node-red.0 (2907) 96c3a28711c8f018: Automatic objects creation is not enabled. You can enable it in the node configuration
      2026-08-20 21:04:50.275  - info: node-red.0 (2907) d66daa294bed4485: "ioBroker in" Cannot set state of non-existing object "mbus.0.EMU-2768.data.5-0-Current".
      2026-08-20 21:04:50.276  - info: node-red.0 (2907) d66daa294bed4485: Automatic objects creation is not enabled. You can enable it in the node configuration
      2026-08-20 21:04:50.297  - info: node-red.0 (2907) 8437c76b3a6fcd57: "ioBroker in" Cannot set state of non-existing object "mbus.0.EMU-2768.data.3-0-Current".
      2026-08-20 21:04:50.297  - info: node-red.0 (2907) 8437c76b3a6fcd57: Automatic objects creation is not enabled. You can enable it in the node configuration
      2026-08-20 21:04:50.439  - error: node-red.0 (1814) Node-RED: 20 Aug 21:04:50 - [error] [ads-connection:b4573aee.d36498] Error on connect: check target NetId or routing
      2026-08-20 21:04:50.552  - error: node-red.0 (1814) Node-RED: 20 Aug 21:04:50 - [error] [function:5ed85a4eda4f2d46] TypeError: msg.payload.toFixed is not a function
          at Function node:5ed85a4eda4f2d46:2:26
          at Function node:5ed85a4eda4f2d46:5:3
          at Script.runInContext (node:vm:149:12)
          at processMessage (/opt/iobroker/node_modules/@node-red/nodes/core/function/10-function.js:430:37)
          at FunctionNode._inputCallback (/opt/iobroker/node_modules/@node-red/nodes/core/function/10-function.js:348:17)
          at /opt/iobroker/node_modules/@node-red/runtime/lib/nodes/Node.js:214:26
          at Object.trigger (/opt/iobroker/node_modules/@node-red/util/lib/hooks.js:166:13)
          at FunctionNode.Node._emitInput (/opt/iobroker/node_modules/@node-red/runtime/lib/nodes/Node.js:206:11)
          at FunctionNode.Node.emit (/opt/iobroker/node_modules/@node-red/runtime/lib/nodes/Node.js:190:25)
      2026-08-20 21:04:55.044  - warn: node-red.0 (1814) Node-RED: 20 Aug 21:04:55 - [warn] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Re-connecting to **priivate Daten entfernt!**
      2026-08-20 21:04:55.522  - info: smartmeter.0 (1949) Error: No or too long answer from Serial Device after last request.
      2026-08-20 21:04:55.522  - warn: smartmeter.0 (1949) No or too long answer from Serial Device after last request.
      2026-08-20 21:05:01.524  - info: smartmeter.0 (1949) Error: No or too long answer from Serial Device after last request.
      2026-08-20 21:05:01.525  - warn: smartmeter.0 (1949) No or too long answer from Serial Device after last request.
      2026-08-20 21:05:07.527  - info: smartmeter.0 (1949) Error: No or too long answer from Serial Device after last request.
      2026-08-20 21:05:07.527  - warn: smartmeter.0 (1949) No or too long answer from Serial Device after last request.
      ============= Mark until here for C&P =============
      HomoranH Offline
      HomoranH Offline
      @MiFuFli sagte:
      So viele sollten es nach Neuinstallation niemals sein!
      Zieh mal dein Trixie auf aktuellen Stand
      @MiFuFli sagte:
      > 2026-08-20 21:04:55.044  - warn: node-red.0 (1814) Node-RED: 20 Aug 21:04:55 - [warn] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Re-connecting to Alexa/ Google Home Skill MQTT server: .........., account username: xxxxxxx
      > 2026
      Gibts da noch mehr im log?
      • M MiFuFli
        @MiFuFli
        Ich weiß nicht, nach welcher Anleitung du das Ding aufgesetzt hast, bestimmt aber nicht danach:
        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
        • M MiFuFli
          HomoranH Offline
          HomoranH Offline
          @MiFuFli bitte keine gesamte Datei, lediglich relevante Zeilen.
          Dabei private Daten entfernen!
          Siehe verlinkten Thread
            MiFuFli
            Mhh.... eigentlich schon genau so. Aber ich kann es auch nochmal machen.
            • M MiFuFli
              @MiFuFli sagte:
              Mit Sicherheit nicht. Dann würde da kein user 'pi' existiern, kein grapical.traget geladen werden und du hättest keine 164 Updates verschludert.
                MiFuFli
                Ich habe das falsche Betriebssystem ausgewählt :-(
                Sorry....
                Bin gerade am neu aufsetzten.
                • M MiFuFli
                  Sorry....
                  @MiFuFli
                  Das OS ist schon das richtige:
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  • M MiFuFli
                    Script v.2026-06-06
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Unknown
                    Kernel          : aarch64
                    Userland        : 64bit
                    CPU threads     : 4
                    Current issues:
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Session:
                    *** MEMORY ***
                    Swap:           2.1G          0B        2.1G
                             8062 M total memory
                             1759 M used memory
                             5332 M free memory
                               93 M buffer memory
                             1000 M swap cache
                             2047 M total swap
                                0 M used swap
                             2047 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.5G    /var/
                    216M    /var/lib
                    215M    /var/cache
                    211M    /var/cache/apt
                    150M    /var/lib/apt
                    USB-Devices by-id:
                    ⚠ HINT:
                    tcp
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.9.8
                    /usr/bin/npx            10.9.8
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.8.23
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        772
                    States:         606
                    HomoranH Offline
                    HomoranH Offline
                    Aber nicht lite
                    @MiFuFli sagte:
                    Boot Target: graphical.target
                      Aber nicht lite
                      @MiFuFli sagte:
                      @Homoran
                      korinthenkackermodusan
                      Das Boottarget hat aber ja nun nix mit dem gebooteten OS zu tun. ;-)
                        MiFuFli
                        Jetzt stoppt der Fortschrittsbalken von Node-RED bei "Lade Plugins"
                        Das ist iob diag nach der Neuinstallation:
                        Script v.2026-06-06
                        *** BASE SYSTEM ***
                         Static hostname: raspberry5
                               Icon name: computer
                                  Kernel: Linux 6.18.39+rpt-rpi-2712
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Unknown
                        Kernel          : aarch64
                        Userland        : 64bit
                         22:15:58 up 8 min,  1 user,  load average: 0.37, 0.40, 0.23
                        CPU threads     : 4
                        Current issues:
                                       Local time: Thu 2026-08-20 22:15:58 CEST
                                   Universal time: Thu 2026-08-20 20:15:58 UTC
                                         RTC time: Thu 2026-08-20 20:15:58
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input lpadmin iobroker
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:        Not found
                        Desktop:
                        Session:                tty
                        Boot Target:            multi-user.target
                        *** MEMORY ***
                        Mem:            8.5G        1.7G        5.9G         23M        989M        6.7G
                        Swap:           2.1G          0B        2.1G
                        Total:           10G        1.7G        8.0G
                        Active iob-Instances:   10
                                 8062 M total memory
                                 1630 M used memory
                                 1441 M active memory
                                  680 M inactive memory
                                 5598 M free memory
                                  104 M buffer memory
                                  838 M swap cache
                                 2047 M total swap
                                    0 M used swap
                                 2047 M free swap
                        top - 22:15:58 up 8 min,  1 user,  load average: 0.37, 0.40, 0.23
                        Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   8062.4 total,   5597.2 free,   1631.6 used,    943.7 buff/cache
                        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   6430.8 avail Mem
                        *** FILESYSTEM ***
                        tmpfs          tmpfs     1.6G   13M  1.6G   1% /run
                        /dev/mmcblk0p2 ext4       58G  6.3G   49G  12% /
                        tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                        tmpfs          tmpfs     4.0G   11M  4.0G   1% /tmp
                        /dev/mmcblk0p1 vfat      505M   66M  439M  14% /boot/firmware
                        tmpfs          tmpfs     807M   32K  807M   1% /run/user/1000
                        [Thu Aug 20 22:07:14 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                        [Thu Aug 20 22:07:14 2026] EXT4-fs (mmcblk0p2): mounted filesystem 15f4c6be-1102-4331-9904-f78e78afd1fd ro with ordered data mode. Quota mode: none.
                        [Thu Aug 20 22:07:17 2026] EXT4-fs (mmcblk0p2): re-mounted 15f4c6be-1102-4331-9904-f78e78afd1fd r/w.
                        /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                        /var:
                        2.5G    /var/
                        240M    /var/cache
                        234M    /var/cache/apt
                        184M    /var/lib
                        148M    /var/lib/apt
                        2.7M    /opt/iobroker/backups/
                        229M    /opt/iobroker/iobroker-data/
                        30M     /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        ⚠ HINT:
                        tcp
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.8
                        /usr/bin/npx            10.9.8
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        raspberry5          raspberry5 (version: 7.2.2, hostname: raspberry5    , alive, uptime: 514)
                        admin:          7.8.23
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : raspberry5                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alias-manager.0          : alias-manager         : raspberry5                               - disabled
                        + system.adapter.backitup.0               : backitup              : raspberry5                               -  enabled
                        + system.adapter.discovery.0              : discovery             : raspberry5                               -  enabled
                          system.adapter.mbus.0                   : mbus                  : raspberry5                               - disabled, port: 3493
                        + system.adapter.node-red.0               : node-red              : raspberry5                               -  enabled, port: 1880, bind: 0.0.0.0
                        + system.adapter.reolink.0                : reolink               : raspberry5                               -  enabled
                          system.adapter.smartmeter.0             : smartmeter            : raspberry5                               - disabled
                        + system.adapter.systeminfo.0             : systeminfo            : raspberry5                               -  enabled
                        + system.adapter.web.0                    : web                   : raspberry5                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        + system.adapter.wireless-mbus.0          : wireless-mbus         : raspberry5                               -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : raspberry5                               -  enabled, port: tcp://192.168.178.203:7638
                        + instance is alive
                        Objects and States
                        Objects:        791
                        States:         607
                        Pending systemupdates: 0
                        udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=659,fd=12))
                        udp   UNCONN 0      0                          0.0.0.0:53170              0.0.0.0:*    users:(("avahi-daemon",pid=659,fd=14))
                        udp   UNCONN 0      0                          0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=634,fd=5),("systemd",pid=1,fd=118))
                        udp   UNCONN 0      0                                *:33767                    *:*    users:(("avahi-daemon",pid=659,fd=15))
                        udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=659,fd=13))
                        udp   UNCONN 0      0                                *:sunrpc                   *:*    users:(("rpcbind",pid=634,fd=7),("systemd",pid=1,fd=120))
                        udp   UNCONN 0      0      [fe80::8aa2:9eff:fef2:8ad1]:dhcpv6-client            *:*    users:(("NetworkManager",pid=718,fd=31))
                        tcp   LISTEN 0      4096                       0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=634,fd=4),("systemd",pid=1,fd=117))
                        tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=1148,fd=6))
                        tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=1134,fd=29))
                        tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=1134,fd=23))
                        tcp   LISTEN 0      511                        0.0.0.0:1880               0.0.0.0:*    users:(("node-red",pid=2728,fd=24))
                        tcp   LISTEN 0      4096                          [::]:sunrpc                [::]:*    users:(("rpcbind",pid=634,fd=6),("systemd",pid=1,fd=119))
                        tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=1148,fd=7))
                        tcp   LISTEN 0      511                              *:10001                    *:*    users:(("node-red",pid=2728,fd=48))
                        tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=1519,fd=35))
                        tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=1187,fd=40))
                            at processTimers (node:internal/timers:521:7)
                        2026-08-20 22:16:04.177  - error: node-red.0 (1425) Node-RED: 20 Aug 22:16:04 - [error] [google-home-conf:f760e8cf91b3705e] ErrorWithReasonCode: Connection refused: Not authorized
                            at handleConnack (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/mqtt/src/lib/handlers/connack.ts:47:15)
                            at handle (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/mqtt/src/lib/handlers/index.ts:49:17)
                            at work (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/mqtt/src/lib/client.ts:795:17)
                            at Writable.writable._write (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/mqtt/src/lib/client.ts:819:4)
                            at writeOrBuffer (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/readable-stream/lib/internal/streams/writable.js:336:12)
                            at _write (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/readable-stream/lib/internal/streams/writable.js:285:10)
                            at Writable.write (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/readable-stream/lib/internal/streams/writable.js:288:10)
                            at Socket.ondata (node:internal/streams/readable:1009:22)
                            at Socket.emit (node:events:519:28)
                            at addChunk (node:internal/streams/readable:561:12)
                        2026-08-20 22:16:09.725  - warn: node-red.0 (1425) Node-RED: 20 Aug 22:16:09 - [warn] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Re-connecting to Alexa/ Google Home Skill MQTT server: mq-red.cb-net.co.uk, account username: mfuss0601
                        2026-08-20 22:16:09.835  - error: node-red.0 (1425) Node-RED: 20 Aug 22:16:09 - [error] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Error: Connection refused: Not authorized
                            at MqttClient._handleConnack (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/lib/client.js:1388:17)
                            at MqttClient._handlePacket (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/lib/client.js:549:12)
                            at work (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/lib/client.js:438:12)
                            at Writable.writable._write (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/lib/client.js:452:5)
                            at doWrite (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139)
                            at writeOrBuffer (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5)
                            at Writable.write (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
                            at TLSSocket.ondata (node:internal/streams/readable:1009:22)
                            at TLSSocket.emit (node:events:519:28)
                        2026-08-20 22:16:14.844  - warn: node-red.0 (1425) Node-RED: 20 Aug 22:16:14 - [warn] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Re-connecting to Alexa/ Google Home Skill MQTT server: mq-red.cb-net.co.uk, account username: mfuss0601
                        • M MiFuFli
                          Script v.2026-06-06
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Unknown
                          Kernel          : aarch64
                          Userland        : 64bit
                          CPU threads     : 4
                          Current issues:
                                        NTP service: active
                                    RTC in local TZ: no
                          pi
                          HOME=/home/pi
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:           2.1G          0B        2.1G
                                   8062 M total memory
                                   1630 M used memory
                                   5598 M free memory
                                    104 M buffer memory
                                    838 M swap cache
                                   2047 M total swap
                                      0 M used swap
                                   2047 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.5G    /var/
                          240M    /var/cache
                          234M    /var/cache/apt
                          184M    /var/lib
                          148M    /var/lib/apt
                          USB-Devices by-id:
                          ⚠ HINT:
                          tcp
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.8
                          /usr/bin/npx            10.9.8
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.8.23
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        791
                          States:         607
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          ich sehe
                          @MiFuFli sagte:
                          du hast backup eingespielt?
                          da waren flows drin?
                          irgendwas was eine google authentifizierung benötigt?
                          meinem empfinden nach, sollte das den start von node red eigentlich nicht behindern. ob das korrekt abgefangen wird weiß ich allerdings nicht
                          ggfs als workaround:
                          node red adapter löschen
                          node red neu installieren
                          einmal clean den adapter starten und aufrufen
                          dann nochmal node-red backup einspielen
                          wenn das so funktioniert, dann einen issue auf github bei
                          iobroker.node-red
                          anlegen und das so beschreiben
                          Meine Adapter und Widgets
                          Links im Profil
                            MiFuFli
                            schrieb am zuletzt editiert von MiFuFli
                            Vielen Dank für die Idee....
                            Leider der gleiche Effekt. Node RED hängt beim starten auf "Lade Plugins...."
                            • M MiFuFli
                              @MiFuFli
                              Dann leg das LogIn nochmal neu an:
                              Da klemmt es für den user mfuss0601 wohl irgendwo.
                              Apropos username: Du solltest etwas anderes als 'pi' als user auf dem RaspberryOS verwenden. Steht auch ausdrücklich so in der Anleitung drin...
                                MiFuFli
                                schrieb zuletzt editiert von
                                Danke an alle für die Hinweis und Tips.
                                Es hat tatsächlich an den Alexa und GoogleHome Zugriffen gelegen.
                                Ich habe ein Backup von dem alten System ohne die beiden Zugänge erstellt und diese dann auf den Raspberry 5 geladen und damit ist Node RED gestartet.
                                Der neue PI5 läuft zwar immer noch icht, da ich noch ein paar andere Problemchen bei dem Aufsetzen haben, aber das ist dann ggf. ein separates Topic.
                                @thomas-braun - Danke für den Hinweis mit dem user "pi"!
                                OliverIOO Thomas BraunT 2 Antworten Letzte Antwort
                                • M MiFuFli
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @MiFuFli
                                  Mach mal bitte ein Issue auf GitHub beim Node Red Adapter.
                                  Auch wenn die Zugänge ungültig geworden sind, sollte der Adapter eigentlich starten und nicht abbrechen
                                  Links im Profil
                                  • M MiFuFli
                                    @MiFuFli sagte:
                                    Grundsetup:
