  3. Einsteigerfragen
  4. Installation
  5. [Gelöst] IO Broker auf neuer Hardware
    6.7k
23 Beiträge 4 Kommentatoren 360 Aufrufe 5 Beobachtet
  • M MiFuFli
    Meinst Du mit log diag das?
    @MiFuFli sagte:
    Bitte keine Screenshots von Konsolentexten.
    Und zuerst mal
    iob stop
    iob fix
    sudo reboot
    durchführen. Danach nochmal
    iob diag
    Kann aber auch sein, dass nodered dann schon läuft.
      MiFuFli
      Script v.2026-06-06
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: raspberry-5-1
             Icon name: computer
                Kernel: Linux 6.18.34+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Unknown
      Kernel          : aarch64
      Userland        : 64bit
      System was installed 63 days ago (on 2026-06-18).
      Systemuptime and Load:
       21:04:27 up 1 min,  2 users,  load average: 1.22, 0.58, 0.22
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2026-08-20 21:04:27 CEST
                 Universal time: Thu 2026-08-20 19:04:27 UTC
                       RTC time: Thu 2026-08-20 19:04:27
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev lpadmin gpio i2c spi render input iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         Unknown
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'.
      Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.5G        1.8G        5.6G         38M        1.1G        6.6G
      Swap:           2.1G          0B        2.1G
      Total:           10G        1.8G        7.7G
      Active iob-Instances:   12
               8062 M total memory
               1759 M used memory
               1741 M active memory
                654 M inactive memory
               5332 M free memory
                 93 M buffer memory
               1000 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      top - 21:04:27 up 1 min,  2 users,  load average: 1.22, 0.58, 0.22
      Tasks: 222 total,   2 running, 220 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 26.9 us,  7.7 sy,  0.0 ni, 61.5 id,  3.8 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8062.4 total,   5323.4 free,   1767.8 used,   1094.9 buff/cache
      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   6294.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     1.6G   14M  1.6G   1% /run
      /dev/mmcblk0p2 ext4       58G  8.8G   47G  16% /
      tmpfs          tmpfs     4.0G  400K  4.0G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     4.0G  2.6M  4.0G   1% /tmp
      /dev/mmcblk0p1 vfat      505M   87M  418M  18% /boot/firmware
      tmpfs          tmpfs     807M  256K  806M   1% /run/user/1000
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
      Messages concerning filesystems in dmesg:
      [Thu Aug 20 21:02:34 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Thu Aug 20 21:02:34 2026] EXT4-fs (mmcblk0p2): mounted filesystem 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 ro with ordered data mode. Quota mode: none.
      [Thu Aug 20 21:02:36 2026] EXT4-fs (mmcblk0p2): re-mounted 8abab6b9-ef90-4fee-ae3d-91079bfae7c1 r/w.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.5G    /var/
      216M    /var/lib
      215M    /var/cache
      211M    /var/cache/apt
      150M    /var/lib/apt
      Archived and active journals take up 8M in the file system.
      /opt/iobroker/backups:
      2.8M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      208M    /opt/iobroker/iobroker-data/
      113M    /opt/iobroker/iobroker-data/node-red
      111M    /opt/iobroker/iobroker-data/node-red/node_modules
      87M     /opt/iobroker/iobroker-data/files
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      8.3M    /opt/iobroker/iobroker-data/objects.jsonl
      7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.js
      3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-Byv11PyV.js
      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
      3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      *** ZigBee Settings ***
      ⚠ HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'.
      Please check your setting:
      tcp
      Zigbee Network Settings on your coordinator / in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      === ZigBee Port Overview ===
      Instance        Configured Port                     Available by-id Port                Status
      zigbee.0        tcp://192.168.178.203:7638          -                                   tcp
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.23.2
      /usr/bin/node           v22.23.2
      /usr/bin/npm            10.9.8
      /usr/bin/npx            10.9.8
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.23.2-1nodesource1
        Candidate: 22.23.2-1nodesource1
        Version table:
       *** 22.23.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
           22.23.1-1nodesource1 1001
           22.23.0-1nodesource1 1001
           22.22.3-1nodesource1 1001
           22.22.2-1nodesource1 1001
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
              500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      No known Vulnerabilities detected!
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberry-5-1       raspberry-5-1 (version: 7.2.2, hostname: raspberry-5-1 , alive, uptime: 110)
      Core adapters versions
      js-controller:  7.2.2
      admin:          7.8.23
      javascript:     "javascript" not found
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberry-5-1                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : raspberry-5-1                            - disabled
      + system.adapter.backitup.0               : backitup              : raspberry-5-1                            -  enabled
      + system.adapter.discovery.0              : discovery             : raspberry-5-1                            -  enabled
      + system.adapter.mbus.0                   : mbus                  : raspberry-5-1                            -  enabled, port: 3493
      + system.adapter.node-red.0               : node-red              : raspberry-5-1                            -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.reolink.0                : reolink               : raspberry-5-1                            -  enabled
      + system.adapter.smartmeter.0             : smartmeter            : raspberry-5-1                            -  enabled
      + system.adapter.systeminfo.0             : systeminfo            : raspberry-5-1                            -  enabled
      + system.adapter.web.0                    : web                   : raspberry-5-1                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wireless-mbus.0          : wireless-mbus         : raspberry-5-1                            -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberry-5-1                            -  enabled, port: tcp://192.168.178.203:7638
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      │ (index) │ id                             │ name            │ version  │ upgrade policy │
      │ 0       │ 'system.adapter.admin'         │ 'admin'         │ '7.8.23' │ 'none'         │
      │ 1       │ 'system.adapter.alias-manager' │ 'alias-manager' │ '2.1.0'  │ 'none'         │
      │ 2       │ 'system.adapter.backitup'      │ 'backitup'      │ '3.3.17' │ 'none'         │
      │ 3       │ 'system.adapter.discovery'     │ 'discovery'     │ '5.0.0'  │ 'none'         │
      │ 4       │ 'system.adapter.mbus'          │ 'mbus'          │ '2.7.0'  │ 'none'         │
      │ 5       │ 'system.adapter.node-red'      │ 'node-red'      │ '6.0.7'  │ 'none'         │
      │ 6       │ 'system.adapter.reolink'       │ 'reolink'       │ '1.4.2'  │ 'none'         │
      │ 7       │ 'system.adapter.smartmeter'    │ 'smartmeter'    │ '3.4.0'  │ 'none'         │
      │ 8       │ 'system.adapter.socketio'      │ 'socketio'      │ '7.1.3'  │ 'none'         │
      │ 9       │ 'system.adapter.systeminfo'    │ 'systeminfo'    │ '1.3.0'  │ 'none'         │
      │ 10      │ 'system.adapter.web'           │ 'web'           │ '8.0.0'  │ 'none'         │
      │ 11      │ 'system.adapter.wireless-mbus' │ 'wireless-mbus' │ '0.10.2' │ 'none'         │
      │ 12      │ 'system.adapter.ws'            │ 'ws'            │ '4.1.0'  │ 'none'         │
      │ 13      │ 'system.adapter.zigbee'        │ 'zigbee'        │ '3.4.5'  │ 'none'         │
      ioBroker-Adapter Versions and update status
      Used repository: stable
      Adapter    "admin"        : 7.8.23   , installed 7.8.23
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "backitup"     : 3.3.17   , installed 3.3.17
      Controller "js-controller": 7.2.2    , installed 7.2.2
      Adapter    "mbus"         : 2.7.0    , installed 2.7.0
      Adapter    "node-red"     : 6.0.7    , installed 6.0.7
      Adapter    "reolink"      : 1.4.2    , installed 1.4.2
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 7.1.3    , installed 7.1.3
      Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
      Adapter    "web"          : 8.0.0    , installed 8.0.0
      Adapter    "wireless-mbus": 0.10.2   , installed 0.10.2
      Adapter    "ws"           : 4.1.0    , installed 4.1.0
      Adapter    "zigbee"       : 3.5.5    , installed 3.4.5  [Updatable]
      Objects and States
      Objects:        772
      States:         606
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending systemupdates: 164
      *** Listening Ports ***
      Netid State  Recv-Q Send-Q                            Local Address:Port          Peer Address:PortProcess
      udp   UNCONN 0      0                                192.168.178.15:54399              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=12))
      udp   UNCONN 0      0                                       0.0.0.0:mdns               0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=8))
      udp   UNCONN 0      0                                       0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=680,fd=12))
      udp   UNCONN 0      0                                       0.0.0.0:59551              0.0.0.0:*    users:(("avahi-daemon",pid=680,fd=14))
      udp   UNCONN 0      0                                       0.0.0.0:59769              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=16))
      udp   UNCONN 0      0                                       0.0.0.0:36129              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=19))
      udp   UNCONN 0      0                                       0.0.0.0:36657              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=20))
      udp   UNCONN 0      0                                       0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=652,fd=5),("systemd",pid=1,fd=83))
      udp   UNCONN 0      0                                       0.0.0.0:45189              0.0.0.0:*    users:(("rpi-connectd",pid=1269,fd=10))
      udp   UNCONN 0      0                                             *:mdns                     *:*    users:(("rpi-connectd",pid=1269,fd=9))
      udp   UNCONN 0      0                                             *:mdns                     *:*    users:(("avahi-daemon",pid=680,fd=13))
      udp   UNCONN 0      0                                             *:55432                    *:*    users:(("avahi-daemon",pid=680,fd=15))
      udp   UNCONN 0      0                                             *:55960                    *:*    users:(("rpi-connectd",pid=1269,fd=14))
      udp   UNCONN 0      0       [2003:f9:5718:8d00:8aa2:9eff:fef2:8ad1]:40902                    *:*    users:(("rpi-connectd",pid=1269,fd=15))
      udp   UNCONN 0      0                                             *:53299                    *:*    users:(("rpi-connectd",pid=1269,fd=11))
      udp   UNCONN 0      0                                             *:sunrpc                   *:*    users:(("rpcbind",pid=652,fd=7),("systemd",pid=1,fd=85))
      udp   UNCONN 0      0      [fd67:8f5c:ad89:9f4:8aa2:9eff:fef2:8ad1]:37169                    *:*    users:(("rpi-connectd",pid=1269,fd=17))
      udp   UNCONN 0      0                   [fe80::8aa2:9eff:fef2:8ad1]:dhcpv6-client            *:*    users:(("NetworkManager",pid=789,fd=24))
      udp   UNCONN 0      0                   [fe80::8aa2:9eff:fef2:8ad1]:49818                    *:*    users:(("rpi-connectd",pid=1269,fd=18))
      udp   UNCONN 0      0                                             *:58297                    *:*    users:(("rpi-connectd",pid=1269,fd=21))
      tcp   LISTEN 0      4096                                    0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=652,fd=4),("systemd",pid=1,fd=82))
      tcp   LISTEN 0      511                                     0.0.0.0:1880               0.0.0.0:*    users:(("node-red",pid=2907,fd=24))
      tcp   LISTEN 0      511                                   127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=1213,fd=29))
      tcp   LISTEN 0      511                                   127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=1213,fd=23))
      tcp   LISTEN 0      4096                                       [::]:sunrpc                [::]:*    users:(("rpcbind",pid=652,fd=6),("systemd",pid=1,fd=84))
      tcp   LISTEN 0      511                                           *:10001                    *:*    users:(("node-red",pid=2907,fd=47))
      tcp   LISTEN 0      511                                           *:tproxy                   *:*    users:(("io.admin.0",pid=1775,fd=39))
      tcp   LISTEN 0      511                                           *:8082                     *:*    users:(("io.web.0",pid=2323,fd=35))
      2026-08-20 21:04:50.148  - info: node-red.0 (2907) 31c1e62c564880b1: Automatic objects creation is not enabled. You can enable it in the node configuration
      2026-08-20 21:04:50.169  - info: node-red.0 (2907) 96c3a28711c8f018: "ioBroker in" Cannot set state of non-existing object "mbus.0.EMU-2748.data.3-0-Current".
      2026-08-20 21:04:50.169  - info: node-red.0 (2907) 96c3a28711c8f018: Automatic objects creation is not enabled. You can enable it in the node configuration
      2026-08-20 21:04:50.275  - info: node-red.0 (2907) d66daa294bed4485: "ioBroker in" Cannot set state of non-existing object "mbus.0.EMU-2768.data.5-0-Current".
      2026-08-20 21:04:50.276  - info: node-red.0 (2907) d66daa294bed4485: Automatic objects creation is not enabled. You can enable it in the node configuration
      2026-08-20 21:04:50.297  - info: node-red.0 (2907) 8437c76b3a6fcd57: "ioBroker in" Cannot set state of non-existing object "mbus.0.EMU-2768.data.3-0-Current".
      2026-08-20 21:04:50.297  - info: node-red.0 (2907) 8437c76b3a6fcd57: Automatic objects creation is not enabled. You can enable it in the node configuration
      2026-08-20 21:04:50.439  - error: node-red.0 (1814) Node-RED: 20 Aug 21:04:50 - [error] [ads-connection:b4573aee.d36498] Error on connect: check target NetId or routing
      2026-08-20 21:04:50.552  - error: node-red.0 (1814) Node-RED: 20 Aug 21:04:50 - [error] [function:5ed85a4eda4f2d46] TypeError: msg.payload.toFixed is not a function
          at Function node:5ed85a4eda4f2d46:2:26
          at Function node:5ed85a4eda4f2d46:5:3
          at Script.runInContext (node:vm:149:12)
          at processMessage (/opt/iobroker/node_modules/@node-red/nodes/core/function/10-function.js:430:37)
          at FunctionNode._inputCallback (/opt/iobroker/node_modules/@node-red/nodes/core/function/10-function.js:348:17)
          at /opt/iobroker/node_modules/@node-red/runtime/lib/nodes/Node.js:214:26
          at Object.trigger (/opt/iobroker/node_modules/@node-red/util/lib/hooks.js:166:13)
          at FunctionNode.Node._emitInput (/opt/iobroker/node_modules/@node-red/runtime/lib/nodes/Node.js:206:11)
          at FunctionNode.Node.emit (/opt/iobroker/node_modules/@node-red/runtime/lib/nodes/Node.js:190:25)
      2026-08-20 21:04:55.044  - warn: node-red.0 (1814) Node-RED: 20 Aug 21:04:55 - [warn] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Re-connecting to **priivate Daten entfernt!**
      2026-08-20 21:04:55.522  - info: smartmeter.0 (1949) Error: No or too long answer from Serial Device after last request.
      2026-08-20 21:04:55.522  - warn: smartmeter.0 (1949) No or too long answer from Serial Device after last request.
      2026-08-20 21:05:01.524  - info: smartmeter.0 (1949) Error: No or too long answer from Serial Device after last request.
      2026-08-20 21:05:01.525  - warn: smartmeter.0 (1949) No or too long answer from Serial Device after last request.
      2026-08-20 21:05:07.527  - info: smartmeter.0 (1949) Error: No or too long answer from Serial Device after last request.
      2026-08-20 21:05:07.527  - warn: smartmeter.0 (1949) No or too long answer from Serial Device after last request.
      ============= Mark until here for C&P =============
        MiFuFli
        Ich habe die Anweisungen wie genannt durchgeführt. Leider immer noch das selbe Ergebnis. Die Log-Daten findet Ihr oben.
        Hier noch die Log.-Datei (ich hoffe im richtigen Format)
        iobroker.2026-08-20.html
        • M MiFuFli
          Script v.2026-06-06
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Unknown
          Kernel          : aarch64
          Userland        : 64bit
          CPU threads     : 4
          Current issues:
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   8062 M total memory
                   1759 M used memory
                   5332 M free memory
                     93 M buffer memory
                   1000 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G    /var/
          216M    /var/lib
          215M    /var/cache
          211M    /var/cache/apt
          150M    /var/lib/apt
          USB-Devices by-id:
          ⚠ HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.8
          /usr/bin/npx            10.9.8
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.8.23
          Adapter State
          + instance is alive
          Objects and States
          Objects:        772
          States:         606
          HomoranH Offline
          HomoranH Offline
          @MiFuFli sagte:
          So viele sollten es nach Neuinstallation niemals sein!
          Zieh mal dein Trixie auf aktuellen Stand
          @MiFuFli sagte:
          > 2026-08-20 21:04:55.044  - warn: node-red.0 (1814) Node-RED: 20 Aug 21:04:55 - [warn] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Re-connecting to Alexa/ Google Home Skill MQTT server: .........., account username: xxxxxxx
          > 2026
          Gibts da noch mehr im log?
          • M MiFuFli
            @MiFuFli
            Ich weiß nicht, nach welcher Anleitung du das Ding aufgesetzt hast, bestimmt aber nicht danach:
            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            • M MiFuFli
              HomoranH Offline
              HomoranH Offline
              @MiFuFli bitte keine gesamte Datei, lediglich relevante Zeilen.
              Dabei private Daten entfernen!
              Siehe verlinkten Thread
                MiFuFli
                Mhh.... eigentlich schon genau so. Aber ich kann es auch nochmal machen.
                • M MiFuFli
                  @MiFuFli sagte:
                  Mit Sicherheit nicht. Dann würde da kein user 'pi' existiern, kein grapical.traget geladen werden und du hättest keine 164 Updates verschludert.
                    MiFuFli
                    Ich habe das falsche Betriebssystem ausgewählt :-(
                    Sorry....
                    Bin gerade am neu aufsetzten.
                    • M MiFuFli
                      Sorry....
                      @MiFuFli
                      Das OS ist schon das richtige:
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      • M MiFuFli
                        Script v.2026-06-06
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Unknown
                        Kernel          : aarch64
                        Userland        : 64bit
                        CPU threads     : 4
                        Current issues:
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        iobroker
                        HOME=/home/iobroker
                        Desktop:
                        Session:
                        *** MEMORY ***
                        Swap:           2.1G          0B        2.1G
                                 8062 M total memory
                                 1759 M used memory
                                 5332 M free memory
                                   93 M buffer memory
                                 1000 M swap cache
                                 2047 M total swap
                                    0 M used swap
                                 2047 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.5G    /var/
                        216M    /var/lib
                        215M    /var/cache
                        211M    /var/cache/apt
                        150M    /var/lib/apt
                        USB-Devices by-id:
                        ⚠ HINT:
                        tcp
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.8
                        /usr/bin/npx            10.9.8
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.8.23
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        772
                        States:         606
                        HomoranH Offline
                        HomoranH Offline
                        Aber nicht lite
                        @MiFuFli sagte:
                        Boot Target: graphical.target
                          Aber nicht lite
                          @MiFuFli sagte:
                          @Homoran
                          korinthenkackermodusan
                          Das Boottarget hat aber ja nun nix mit dem gebooteten OS zu tun. ;-)
                            MiFuFli
                            Jetzt stoppt der Fortschrittsbalken von Node-RED bei "Lade Plugins"
                            Das ist iob diag nach der Neuinstallation:
                            Script v.2026-06-06
                            *** BASE SYSTEM ***
                             Static hostname: raspberry5
                                   Icon name: computer
                                      Kernel: Linux 6.18.39+rpt-rpi-2712
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Unknown
                            Kernel          : aarch64
                            Userland        : 64bit
                             22:15:58 up 8 min,  1 user,  load average: 0.37, 0.40, 0.23
                            CPU threads     : 4
                            Current issues:
                                           Local time: Thu 2026-08-20 22:15:58 CEST
                                       Universal time: Thu 2026-08-20 20:15:58 UTC
                                             RTC time: Thu 2026-08-20 20:15:58
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            HOME=/home/pi
                            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input lpadmin iobroker
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:        Not found
                            Desktop:
                            Session:                tty
                            Boot Target:            multi-user.target
                            *** MEMORY ***
                            Mem:            8.5G        1.7G        5.9G         23M        989M        6.7G
                            Swap:           2.1G          0B        2.1G
                            Total:           10G        1.7G        8.0G
                            Active iob-Instances:   10
                                     8062 M total memory
                                     1630 M used memory
                                     1441 M active memory
                                      680 M inactive memory
                                     5598 M free memory
                                      104 M buffer memory
                                      838 M swap cache
                                     2047 M total swap
                                        0 M used swap
                                     2047 M free swap
                            top - 22:15:58 up 8 min,  1 user,  load average: 0.37, 0.40, 0.23
                            Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   8062.4 total,   5597.2 free,   1631.6 used,    943.7 buff/cache
                            MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   6430.8 avail Mem
                            *** FILESYSTEM ***
                            tmpfs          tmpfs     1.6G   13M  1.6G   1% /run
                            /dev/mmcblk0p2 ext4       58G  6.3G   49G  12% /
                            tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                            tmpfs          tmpfs     4.0G   11M  4.0G   1% /tmp
                            /dev/mmcblk0p1 vfat      505M   66M  439M  14% /boot/firmware
                            tmpfs          tmpfs     807M   32K  807M   1% /run/user/1000
                            [Thu Aug 20 22:07:14 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
                            [Thu Aug 20 22:07:14 2026] EXT4-fs (mmcblk0p2): mounted filesystem 15f4c6be-1102-4331-9904-f78e78afd1fd ro with ordered data mode. Quota mode: none.
                            [Thu Aug 20 22:07:17 2026] EXT4-fs (mmcblk0p2): re-mounted 15f4c6be-1102-4331-9904-f78e78afd1fd r/w.
                            /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                            /var:
                            2.5G    /var/
                            240M    /var/cache
                            234M    /var/cache/apt
                            184M    /var/lib
                            148M    /var/lib/apt
                            2.7M    /opt/iobroker/backups/
                            229M    /opt/iobroker/iobroker-data/
                            30M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            ⚠ HINT:
                            tcp
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.8
                            /usr/bin/npx            10.9.8
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            raspberry5          raspberry5 (version: 7.2.2, hostname: raspberry5    , alive, uptime: 514)
                            admin:          7.8.23
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : raspberry5                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.alias-manager.0          : alias-manager         : raspberry5                               - disabled
                            + system.adapter.backitup.0               : backitup              : raspberry5                               -  enabled
                            + system.adapter.discovery.0              : discovery             : raspberry5                               -  enabled
                              system.adapter.mbus.0                   : mbus                  : raspberry5                               - disabled, port: 3493
                            + system.adapter.node-red.0               : node-red              : raspberry5                               -  enabled, port: 1880, bind: 0.0.0.0
                            + system.adapter.reolink.0                : reolink               : raspberry5                               -  enabled
                              system.adapter.smartmeter.0             : smartmeter            : raspberry5                               - disabled
                            + system.adapter.systeminfo.0             : systeminfo            : raspberry5                               -  enabled
                            + system.adapter.web.0                    : web                   : raspberry5                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.wireless-mbus.0          : wireless-mbus         : raspberry5                               -  enabled
                            + system.adapter.zigbee.0                 : zigbee                : raspberry5                               -  enabled, port: tcp://192.168.178.203:7638
                            + instance is alive
                            Objects and States
                            Objects:        791
                            States:         607
                            Pending systemupdates: 0
                            udp   UNCONN 0      0                          0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=659,fd=12))
                            udp   UNCONN 0      0                          0.0.0.0:53170              0.0.0.0:*    users:(("avahi-daemon",pid=659,fd=14))
                            udp   UNCONN 0      0                          0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=634,fd=5),("systemd",pid=1,fd=118))
                            udp   UNCONN 0      0                                *:33767                    *:*    users:(("avahi-daemon",pid=659,fd=15))
                            udp   UNCONN 0      0                                *:mdns                     *:*    users:(("avahi-daemon",pid=659,fd=13))
                            udp   UNCONN 0      0                                *:sunrpc                   *:*    users:(("rpcbind",pid=634,fd=7),("systemd",pid=1,fd=120))
                            udp   UNCONN 0      0      [fe80::8aa2:9eff:fef2:8ad1]:dhcpv6-client            *:*    users:(("NetworkManager",pid=718,fd=31))
                            tcp   LISTEN 0      4096                       0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=634,fd=4),("systemd",pid=1,fd=117))
                            tcp   LISTEN 0      128                        0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=1148,fd=6))
                            tcp   LISTEN 0      511                      127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=1134,fd=29))
                            tcp   LISTEN 0      511                      127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=1134,fd=23))
                            tcp   LISTEN 0      511                        0.0.0.0:1880               0.0.0.0:*    users:(("node-red",pid=2728,fd=24))
                            tcp   LISTEN 0      4096                          [::]:sunrpc                [::]:*    users:(("rpcbind",pid=634,fd=6),("systemd",pid=1,fd=119))
                            tcp   LISTEN 0      128                           [::]:ssh                   [::]:*    users:(("sshd",pid=1148,fd=7))
                            tcp   LISTEN 0      511                              *:10001                    *:*    users:(("node-red",pid=2728,fd=48))
                            tcp   LISTEN 0      511                              *:8082                     *:*    users:(("io.web.0",pid=1519,fd=35))
                            tcp   LISTEN 0      511                              *:tproxy                   *:*    users:(("io.admin.0",pid=1187,fd=40))
                                at processTimers (node:internal/timers:521:7)
                            2026-08-20 22:16:04.177  - error: node-red.0 (1425) Node-RED: 20 Aug 22:16:04 - [error] [google-home-conf:f760e8cf91b3705e] ErrorWithReasonCode: Connection refused: Not authorized
                                at handleConnack (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/mqtt/src/lib/handlers/connack.ts:47:15)
                                at handle (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/mqtt/src/lib/handlers/index.ts:49:17)
                                at work (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/mqtt/src/lib/client.ts:795:17)
                                at Writable.writable._write (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/mqtt/src/lib/client.ts:819:4)
                                at writeOrBuffer (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/readable-stream/lib/internal/streams/writable.js:336:12)
                                at _write (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/readable-stream/lib/internal/streams/writable.js:285:10)
                                at Writable.write (/opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-googlehome/node_modules/readable-stream/lib/internal/streams/writable.js:288:10)
                                at Socket.ondata (node:internal/streams/readable:1009:22)
                                at Socket.emit (node:events:519:28)
                                at addChunk (node:internal/streams/readable:561:12)
                            2026-08-20 22:16:09.725  - warn: node-red.0 (1425) Node-RED: 20 Aug 22:16:09 - [warn] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Re-connecting to Alexa/ Google Home Skill MQTT server: mq-red.cb-net.co.uk, account username: mfuss0601
                            2026-08-20 22:16:09.835  - error: node-red.0 (1425) Node-RED: 20 Aug 22:16:09 - [error] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Error: Connection refused: Not authorized
                                at MqttClient._handleConnack (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/lib/client.js:1388:17)
                                at MqttClient._handlePacket (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/lib/client.js:549:12)
                                at work (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/lib/client.js:438:12)
                                at Writable.writable._write (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/lib/client.js:452:5)
                                at doWrite (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:409:139)
                                at writeOrBuffer (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:398:5)
                                at Writable.write (/opt/iobroker/iobroker-data/node-red/node_modules/mqtt/node_modules/readable-stream/lib/_stream_writable.js:307:11)
                                at TLSSocket.ondata (node:internal/streams/readable:1009:22)
                                at TLSSocket.emit (node:events:519:28)
                            2026-08-20 22:16:14.844  - warn: node-red.0 (1425) Node-RED: 20 Aug 22:16:14 - [warn] [alexa-smart-home-v3-conf:bb58532e7d7403dd] Re-connecting to Alexa/ Google Home Skill MQTT server: mq-red.cb-net.co.uk, account username: mfuss0601
                            • M MiFuFli
                              Script v.2026-06-06
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Unknown
                              Kernel          : aarch64
                              Userland        : 64bit
                              CPU threads     : 4
                              Current issues:
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           2.1G          0B        2.1G
                                       8062 M total memory
                                       1630 M used memory
                                       5598 M free memory
                                        104 M buffer memory
                                        838 M swap cache
                                       2047 M total swap
                                          0 M used swap
                                       2047 M free swap
                              *** FILESYSTEM ***
                              /var:
                              2.5G    /var/
                              240M    /var/cache
                              234M    /var/cache/apt
                              184M    /var/lib
                              148M    /var/lib/apt
                              USB-Devices by-id:
                              ⚠ HINT:
                              tcp
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.9.8
                              /usr/bin/npx            10.9.8
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.8.23
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        791
                              States:         607
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              ich sehe
                              @MiFuFli sagte:
                              du hast backup eingespielt?
                              da waren flows drin?
                              irgendwas was eine google authentifizierung benötigt?
                              meinem empfinden nach, sollte das den start von node red eigentlich nicht behindern. ob das korrekt abgefangen wird weiß ich allerdings nicht
                              ggfs als workaround:
                              node red adapter löschen
                              node red neu installieren
                              einmal clean den adapter starten und aufrufen
                              dann nochmal node-red backup einspielen
                              wenn das so funktioniert, dann einen issue auf github bei
                              iobroker.node-red
                              anlegen und das so beschreiben
                              Meine Adapter und Widgets
                              Links im Profil
                                MiFuFli
                                schrieb am zuletzt editiert von MiFuFli
                                Vielen Dank für die Idee....
                                Leider der gleiche Effekt. Node RED hängt beim starten auf "Lade Plugins...."
                                • M MiFuFli
                                  @MiFuFli
                                  Dann leg das LogIn nochmal neu an:
                                  Da klemmt es für den user mfuss0601 wohl irgendwo.
                                  Apropos username: Du solltest etwas anderes als 'pi' als user auf dem RaspberryOS verwenden. Steht auch ausdrücklich so in der Anleitung drin...
                                    MiFuFli
                                    schrieb zuletzt editiert von
                                    Danke an alle für die Hinweis und Tips.
                                    Es hat tatsächlich an den Alexa und GoogleHome Zugriffen gelegen.
                                    Ich habe ein Backup von dem alten System ohne die beiden Zugänge erstellt und diese dann auf den Raspberry 5 geladen und damit ist Node RED gestartet.
                                    Der neue PI5 läuft zwar immer noch icht, da ich noch ein paar andere Problemchen bei dem Aufsetzen haben, aber das ist dann ggf. ein separates Topic.
                                    @thomas-braun - Danke für den Hinweis mit dem user "pi"!
                                    OliverIOO Thomas BraunT 2 Antworten Letzte Antwort
                                    • M MiFuFli
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      @MiFuFli
                                      Mach mal bitte ein Issue auf GitHub beim Node Red Adapter.
                                      Auch wenn die Zugänge ungültig geworden sind, sollte der Adapter eigentlich starten und nicht abbrechen
                                      Links im Profil
                                      • M MiFuFli
                                        @MiFuFli sagte:
                                        Grundsetup:
