  4. [ESPHome] Beta release 0.5.0-beta.1 ready
    6.7k
adapter entwicklungadapter updateesphome
134 Beiträge 17 Kommentatoren 21.0k Aufrufe 17 Beobachtet
  • T Tontechniker
    Log.txt
    simonf04S Offline
    simonf04S Offline
    simonf04
    #125
    @Tontechniker sagte in [ESPHome] Beta release 0.5.0-beta.1 ready:
    Log.txt
    ERROR: Cannot install esphome==2026.3.1 and pillow==11.3.0 because these package versions have conflicting dependencies.
    The conflict is caused by:
    The user requested pillow==11.3.0
    esphome 2026.3.1 depends on pillow==12.1.1
    Wennst die aktuellste Version hast, kannst in den Instanz Einstellungen pillow Version auch konfigurieren. ("immer neuste" Setting funktioniert da leider nicht)
    Eventuell gleich Dashboard auch auf eine fixe Version setzen und nur updaten wenn notwendig. Dann hast nicht das Problem immer wieder.
      Tontechniker
      #126
      Danke, hat funktioniert!
      • C Online
        C Online
        c1olli
        schrieb am zuletzt editiert von c1olli
        #127
        Ich habe folgende Meldung:
        	esphome has an invalid jsonConfig: [{"instancePath":"/items/yamlFiles/items/uploadContent/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["accordion","alive","autocomplete","autocompleteSendTo","certificate","certificates","checkDocker","checkLicense","checkbox","chips","color","coordinates","cron","custom","datePicker","deviceManager","divider","file","fileSelector","func","header","icon","iframe","iframeSendTo","image","imageSendTo","infoBox","instance","interface","ip","jsonEditor","language","number","oauth2","objectId","panel","password","pattern","port","qrCode","qrCodeSendTo","room","select","selectSendTo","sendTo","setState","slider","state","staticImage","staticInfo","staticLink","staticText","table","text","textSendTo","timePicker","user","uuid","yamlEditor"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/yamlFiles","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/11/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
        Das Dashboard startet nicht
        Edit:
        Nach einen Upload unter Adapter klappt es jetzt.
        Olli
        mcm1957M simonf04S 2 Antworten Letzte Antwort
        • C c1olli
          Edit:
          mcm1957M Online
          mcm1957M Online
          mcm1957
          #128
          @c1olli sagte:
          Leg ein Issue an.
          Entweder ist da ein Fehler in der jsonConfig des Adapters oder es fehlt etwas im Prüfschema. Letzteres sollte aber auch der Maintainer einmelden.
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • C c1olli
            Edit:
            simonf04S Offline
            simonf04S Offline
            simonf04
            schrieb am zuletzt editiert von simonf04
            #129
            @c1olli sagte:
            Edit:
            Die Meldung hat nix mit dem dashboard zu tun... Ist ja auch nur eine Warning.
            Und auch bekannt. Copilot hat da mal wieder mehrfach sachen zusammenhalluziniert bei @dutchman .
            Der upload hat vermutlich auch nur " schein geholfen."
            Adapter braucht einfach beim 1. Mal etwad zum dashboard starten, da es da erst installiert wurd. Steht aber auch im log (und im adapter readme)
            Aber ok, 👍 funktioniert ja jetzt.
              Tontechniker
              schrieb am zuletzt editiert von Tontechniker
              #130
              NodeMCU_ESP32_mit_OLED_Display_868Mhz_LoRa in ESP-Home
              Ich habe oben genannte Hardware in Betrieb genommen.
              Kann mir jemand ein Beispiel geben, wie ich auf der Anzeige z.B. einen Messwert darstellen kann.
              Habe mir die Arduino-Beispiele angesehen und mit Erfolg die Demos herunter geladen.
              P.S.
              Kann mir jemand sagen, wie ich hier einen neuen Beitrag mit neuem Thema verfasse?
              Falls der jetztzige Beitrag hier an falscher Stelle ist, bitte verschieben!
              Problem hat sich erledigt!
                Tontechniker
                #131
                Nach einer Neuinstallation habe ich wieder das Problem, dass ich das Dashboard nich ausführen kann.
                ESP-Home: 1.0.0-beta2
                Dashboard: 2026.8.0b4
                Pillow: 12.3.0
                Kann mir jemand mitteilen, welche Versionen zusammenpassen (siehe #125)?
                Mit "always last awaylable" für Dashboard und Pillow getestet: gleiches Ergebnis.
                Es kommen keine Fehlermeldungen.
                simonf04S 1 Antwort Letzte Antwort
                • T Tontechniker
                  Pillow: 12.3.0
                  simonf04S Offline
                  simonf04S Offline
                  simonf04
                  #132
                  @Tontechniker sagte:
                  Pillow: 12.3.0
                  Ist bekannt das latest nicht geht.
                  Erstmal beim standard belassen: Dashboard 2026.6.5 and Pillow 12.2.0
                  • simonf04S Offline
                    simonf04S Offline
                    simonf04
                    #133
                    Warum eigentlich scho wieder neuinstallation?
                    • simonf04S simonf04
                      Pillow: 12.3.0
                      Tontechniker
                      #134
                      @simonf04
                      Vielen Dank für Deine Antwort!
                      Habe ein Update von Linux vorgenommen.
                      Habe die angegebenen Versionen installiert und es funktioniert wieder.
                      Hans
