  4. Test Adapter LG ThinQ
    6.8k
950 Beiträge 72 Kommentatoren 416.2k Aufrufe 69 Beobachtet
  • Thomas DiederichsT Offline
    Thomas Diederichs
    #935
    @lucky Vielen Dank für deinen Hinweis.
    1. Stündliche Abfrage:
    Ergibt leider auch 0-Werte:
    [{"usedDate":"2026-01-01 00:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 01:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 02:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 03:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 04:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 05:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 06:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 07:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 08:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 09:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 10:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 11:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 12:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 13:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 14:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 15:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 16:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 17:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 18:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 19:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 20:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 21:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 22:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"},{"usedDate":"2026-01-01 23:00:00","energyData":"0","operationTime":"0","periodicEnergyData":"0","periodicTimeData":"0"}]
    Andere Tage auch, zu den Tagen liegen Daten in der App vor.
    "Müsste man sich die Daten aus dem Link unter appModuleUri runterladen und dort nach.sehen."
    appModukeUri hat folgenden Inhalt:
    https://objectcontent.lgthinq.com/6c1a78d3-0404-4712-a5bc-2bc3d9e072b8?hdnts=exp=1805961654~hmac=eb97e8bc194b7d7510623c92631f34838045614dafac3b683911951479ba8f7e
    Also, dass habe ich mir mal heruntergeladen, und das zip-Archiv entpackt. Nun stehe ich vor einer Fülle von Informationen. Die Verzeichnisse:
    \wpm\GAM\GAM_ENM02_Weekly
    \wpm\GAM\GAM_ENM03_Monthly
    sehen vom Namen einigermaßen interessant aus, aber das ist reines raten meinerseits.
    Hättest du einen Hinweis für mich, wie ich mich da geschickt der Lösung nähern könnte?
    Vielen Dank
    Thomas Diederichs
    L 1 Antwort Letzte Antwort
    • Thomas DiederichsT Thomas Diederichs
      Vielen Dank
      Thomas Diederichs
      Lucky_ESA
      #936
      @Thomas-Diederichs Da könnte man mal nachschauen wie die APP die Daten berechnet.
      Dazu musst du aber erstmal Daten bekommen. Das Thema hatten wir hier im Thread schon einmal, finde aber die Posts nicht.
      Die APP fragt beim öffnen den aktuellen Monat ab.
      Beispiel:
      täglich
      2026.01.01
      2026.01.31
      Versuche auch mal monatlich oder jährlich
      Gruß//Lucky
        s.reihle
        #937
        erst mal Danke, der Adapter funktioniert prächtig mit meinem LG-Kühlschrank, will heißen Datenpunkte auslesen und ändern funktioniert.
        Nur bekomme ich seit einiger Zeit einen Fehler im Log:
        lg-thinq.0
        2026-08-14 12:59:27.661 error TypeError: Cannot read properties of undefined (reading 'privKey') at LgThinq.start_mqtt (/opt/iobroker/node_modules/iobroker.lg-thinq/main.js:2633:35) at processTicksAndRejections (node:internal/process/task_queues:103:5)
        lg-thinq.0
        2026-08-14 12:59:27.659 error getMqttInfo: AxiosError: Request failed with status code 403
        Wie kann ich das beheben?
        Stephan
        S JLegJ L 3 Antworten Letzte Antwort
        • S s.reihle
          lg-thinq.0
          lg-thinq.0
          Stephan
          S Nicht stören
          S Nicht stören
          stenmic
          #938
          @s.reihle
          ist bei mir auch so. Ich hoffe auf eine Lösung.
          • S s.reihle
            lg-thinq.0
            lg-thinq.0
            Stephan
            JLegJ Offline
            JLegJ Offline
            JLeg
            #939
            @s.reihle diese Meldungen habe ich seit ~4 Tagen auch - allerdings mit noch einigen "Nebenwirkungen".
            Die Meldungen sind bei mir mit einer BWWP WH20STR2.FA:
            2026-08-14 16:26:53.108  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) refreshToken
            2026-08-14 16:26:53.119  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) "https://de.lgeapi.com/oauth/1.0/oauth2/token"
            2026-08-14 16:26:53.122  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) {"x-lge-app-os":"ADR","x-lge-appkey":"LGAO221A02","x-lge-oauth-signature":"KT3nuMM0kKHZNC0OZkHp6QJFyzo=","x-lge-oauth-date":"Fri, 14 Aug 2026 14:26:53 +0000","Acce
            pt":"application/json","Content-Type":"application/x-www-form-urlencoded"}
            2026-08-14 16:26:53.123  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) {"grant_type":"refresh_token","refresh_token":"xxxxxxxxxxxxxxxxxx4c7111e80b120a5c29556f9ee350949c7905633a506689ac74fc9bf638c671d042ca09"}
            2026-08-14 16:26:53.242  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) {"access_token":"xxxxxxxxxxxxxxxxxxxxxx9729508e261a12c905e478e","expires_in":"3600"}
            2026-08-14 16:26:53.348  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) "3A87D3A4725EBF3A7C19A57AB04FA8EC.node_sadap_vmss-ne-tIHCMTT"
            2026-08-14 16:26:53.349  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) Restart MQTT Connection
            2026-08-14 16:26:53.349  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) Start refreshTokenInterval!
            2026-08-14 16:26:53.350  - ESC[34mdebugESC[39m: lg-thinq.0 (431062) 3600
            2026-08-14 16:26:55.420  - ESC[32minfoESC[39m: lg-thinq.0 (431062) Found MQTT Host
            2026-08-14 16:26:55.513  - ESC[32minfoESC[39m: lg-thinq.0 (431062) Found AWS CER
            2026-08-14 16:26:55.922  - ESC[31merrorESC[39m: lg-thinq.0 (431062) getMqttInfo: AxiosError: Request failed with status code 403
            2026-08-14 16:26:55.923  - ESC[31merrorESC[39m: lg-thinq.0 (431062) TypeError: Cannot read properties of undefined (reading 'privKey')
            2026-08-14 16:26:55.923  - ESC[32minfoESC[39m: lg-thinq.0 (431062) New term agreement is starting...
            und danach werden keine Werte mehr aktualisiert (vor allem der der aktuellen Wassertemperatur).
            Das oben passiert so alle Stunde, plus minus - und kurios dabei: Im selben Moment erhalte ich auf meine E-Mail-Adresse des LG-Accounts eine Meldung, ich hätte den LG-Newsletter bestellt, und möge dies nun durch Klick auf den Button bestätigen...
            Nach einem Neustart der Instanz kommen ebenfalls diese Meldungen, manchmal (zuletzt nicht mehr) wurden dann die Werte einmalig aktualisiert.
            Vielleicht hat der Adapter-Autor @lucky_esa eine Idee? :-)
              s.reihle
              #940
              Ergänzend für die Fehlersuche:
              Die Meldung erscheint ziemlich genau einmal pro Stunde, gefühlt nach einem Komplett-update des IoBrokers mit allen Adaptern.
              LG TinQ ist Version 1.2.0
              • S s.reihle
                lg-thinq.0
                lg-thinq.0
                Stephan
                Lucky_ESA
                #941
                @s.reihle sagte:
                privKey
                Danke für die Info. Auf GIT gibt es auch ein Issue aber leider bekomme ich da kein Mailevent.
                Release 1.2.1 ist unterwegs
                @JLeg
                Das ist normal. Jede Stunde muss der Token aktualisiert werden.
                Gruß//Lucky
                JLegJ 1 Antwort Letzte Antwort
                • L Offline
                  Lucky_ESA
                  #942
                  Das Release 1.2.1 ist unter latest zur Verfügung. Könnt ihr bitte mal laden und kurz testen.
                  Wenn alles OK ist muss ich das Release in Stable bringen.
                  Gruß//Lucky
                    s.reihle
                    #943
                    Danke, das ging ja schnell.
                    Hab den Adapter eben installiert, nach reboot und Neustart des Adapters treten keine Fehler mehr auf.
                    In einer Stunde wissen wir mehr ;-)
                    STephan
                    • S s.reihle
                      STephan
                      s.reihle
                      #944
                      Die Stunde ist um, kein Fehler im Log - chapeau!
                      Schönes WE
                      Stephan
                      • L Lucky_ESA
                        @s.reihle sagte:
                        privKey
                        @JLeg
                        Gruß//Lucky
                        JLegJ Offline
                        JLegJ Offline
                        JLeg
                        #945
                        @Lucky_ESA sagte:
                        Vielen Dank für den schnellen Fix! BWWP löpt wieder…
                        @JLeg
                        Ok, eher nicht normal aber dürfte gewesen sein, dass ich bei dieser Meldung (jede Stunde) bzw. jedem Adapterstart eine Email von LG bekommen habe, um eine nie getätigte Newsletterbestellung zu bestätigen… ;)
                        Gruß//Lucky
                          aleks-83
                          schrieb am zuletzt editiert von aleks-83
                          #946
                          Hi zusammen,
                          Ich habe die 1.2.1 gestern mit meinem neuen LG Klimagerät installiert und eingerichtet.
                          Allerdings bekomme ich direkt nach dem Start diesen Logeintrag und es werden keine Daten synchronisiert.
                          (Log ist rückwärtschronologisch)
                          lg-thinq.0 - 2026-08-23 09:18:01.803	warn	Missing Session Infos!
                          lg-thinq.0 - 2026-08-23 09:18:01.802	error	AxiosError: Request failed with status code 403
                          lg-thinq.0 - 2026-08-23 09:18:01.416	info	starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.lg-thinq, node: v22.22.2, js-controller: 7.2.2
                          = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
                          = Node.js v20.19.6 = NPM 22.22.2 = JS Controller 7.2.2 =
                          Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
                          Glasfaser 400
                          • A aleks-83
                            Hi zusammen,
                            Lucky_ESA
                            #947
                            @aleks-83 sagte:
                            Du musst auf latest umstellen und die 1.2.2 installieren.
                            Weißt du wie das geht?
                            Gruß//Lucky
                              aleks-83
                              #948
                              Ja, das weiß ich. aber latest war mir in der Vergangenheit zu instabil.
                              Gibt es keine andere Möglichkeit, da ran zu kommen?
                              Oder kann ich nach der Installation wieder zurück auf stable?
                              Glasfaser 400
                              • L Offline
                                Lucky_ESA
                                #949
                                Du musst sogar nach der Installation zurück auf Stable. Du solltest auch NUR den lg-thinq kurz aktualisieren.
                                Gruß//Lucky
                                • A aleks-83
                                  #950
                                  @aleks-83
                                  Geht in dem Fall ganz ohne Herumstellerei an den Repos:
