  4. [gelöst} NSPanel TypeScript v5.1.1.7 Fehler !!
3 Beiträge 2 Kommentatoren 1.3k Aufrufe 1 Beobachtet
  • GregorSG
    GregorSG
    GregorS
    schrieb am zuletzt editiert von GregorS
    Hallo Zusammen,
    habe in meinem Log folgernde Fehler:
    avascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at Object.<anonymous> (script.js.NSPanel_1_V5_1_1_7:4044:133)
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at __awaiter (script.js.NSPanel_1_V5_1_1_7:4:12)
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at new Promise (<anonymous>)
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at script.js.NSPanel_1_V5_1_1_7:8:71
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at Object.next (script.js.NSPanel_1_V5_1_1_7:14:53)
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at step (script.js.NSPanel_1_V5_1_1_7:33:23)
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at script.js.NSPanel_1_V5_1_1_7:4052:51
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at getState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2954:68)
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: at JSON.stringify (<anonymous>)
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: --- property '_idleNext' closes the circle
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: | property '_idlePrev' -> object with constructor 'TimersList'
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: --> starting at object with constructor 'Timeout'
    javascript.0
    	2026-07-06 14:00:23.242	error	script.js.NSPanel_1_V5_1_1_7: Error: TypeError: Converting circular structure to JSON
    javascript.0
    	2026-07-06 14:00:23.232	error	script.js.NSPanel_1_V5_1_1_7: at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at Object.<anonymous> (script.js.NSPanel_1_V5_1_1_7:4044:133)
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at __awaiter (script.js.NSPanel_1_V5_1_1_7:4:12)
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at new Promise (<anonymous>)
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at script.js.NSPanel_1_V5_1_1_7:8:71
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at Object.next (script.js.NSPanel_1_V5_1_1_7:14:53)
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at step (script.js.NSPanel_1_V5_1_1_7:33:23)
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at script.js.NSPanel_1_V5_1_1_7:4052:51
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at getState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2954:68)
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: at JSON.stringify (<anonymous>)
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: --- property '_idleNext' closes the circle
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: | property '_idlePrev' -> object with constructor 'TimersList'
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: --> starting at object with constructor 'Timeout'
    javascript.0
    	2026-07-06 14:00:23.231	error	script.js.NSPanel_1_V5_1_1_7: Error: TypeError: Converting circular structure to JSON
    Beim kompilieren wird nichts angezeigt.
    Das Panel ist komplett auf dem aktuellen Stand, ioBroker auch.
    Gregor
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      Hallo Zusammen,
      avascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Gregor
      paul53P
      paul53P
      @GregorS [sagte]: Error: TypeError: Converting circular structure to JSON
      Versuchst du, im Skript "NSPanel_1_V5_1_1_7" eine Timer-Variable zu loggen?
      Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
      • GregorSG
        GregorSG
        GregorS
        Nein, habe das Script so übernommen und angepasst.
        Allerdings komme ich gerade aus dem Urlaub und sehe, dass das Display dunkel bleibt.
        Bei Berühren des Displays kommt der Screensaver und danach wird es wieder dunkel.
        alias.0.NSPanel.1.ScreensaverInfo.activeBrightness.ACTUAL =100
        ActiveDimmodeBrightness und Trigger Dimmode gibt es nicht mehr
        War mein Fehler, gibt es doch.
        TriggerDimMode on, jetzt habe ich wieder eine Anzeige.
        84.1k
