  4. Maxcul ist komplett unbrauchbar (geloest mit 0.5.2)
maxculmaxcul error
133 Beiträge 9 Kommentatoren 23.2k Aufrufe
  • apollon77A Offline
    Hab nochmal was geändert und ne zeile von früher entfernt. Jetzt?
      skraw.iobroker
      Wieder tot… auch nach Reboot das gleiche Bild
      maxcul.0	2018-02-22 12:42:45.424	debug	enable MAX! Mode of the CUL868
      maxcul.0	2018-02-22 12:42:44.402	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519299764396,"q":0,"from":"system.adapter.maxcul.0","lc":1519299764396}
      maxcul.0	2018-02-22 12:42:44.399	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519299764393,"q":0,"from":"system.adapter.maxcul.0","lc":1519208208071}
      maxcul.0	2018-02-22 12:42:41.460	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519299761449,"q":0,"from":"system.adapter.maxcul.0","lc":1519299761449}
      maxcul.0	2018-02-22 12:42:41.454	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519299761447,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
      maxcul.0	2018-02-22 12:42:41.441	info	CUL FW Version: V 1.67 nanoCUL868
      maxcul.0	2018-02-22 12:42:41.437	debug	incoming raw data from CUL: V 1.67 nanoCUL868
      maxcul.0	2018-02-22 12:42:41.418	debug	Requested CUL Version...
      maxcul.0	2018-02-22 12:42:41.410	debug	check CUL Firmware version
      maxcul.0	2018-02-22 12:42:39.415	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519299759411,"q":0,"from":"system.adapter.maxcul.0","lc":1519299153998}
      maxcul.0	2018-02-22 12:42:39.404	info	serialPort /dev/ttyUSB0 is open!
      maxcul.0	2018-02-22 12:42:39.371	info	using serial device /dev/ttyUSB0@38400
      maxcul.0	2018-02-22 12:42:38.789	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
      maxcul.0	2018-02-22 12:42:38.725	info	States connected to redis: 127.0.0.1:6379
      Meinst Du nicht es waere einfacher den ganzen "neuen" Code wegzuwerfen und mit dem 0.3.0 einfach nochmal anzufangen?
      Was fuer Aenderungen brauchen wir denn in dem Adapter unbedingt? 0.3.0 geht echt gut bei mir und auch anderen die ich kenne…
      geändert: Code in Code-Tags; Homoran (Mod)
        skraw.iobroker
        @booehmemaik:
        @skraw.iobroker:
        Was fuer Typen/Hersteller? `
        eq-3 MAX! Wandthermostat….. ich bekomme meine nicht über den nanocul (bus) + maxcul ausgelesen, bzw angelernt.
        Maik `
        Ich hab mir jetzt mal so ein Ding bestellt, mal sehen wie das geht wenns da ist …
        Das Wandthermostat ist heute gekommen. Es kann nicht so viel, aber was es kann kann der maxcul Adapter leider nicht, naemlich dieses Kommando:
        A 0C 5804 42 029D99 000000 00 A2 22 -> SetPointAndCurrentTemperature
        42 - SetPointAndCurrentTemperature
        029D99 - eigene Adresse
        000000 - Zieladresse == Broadcast
        00 - Zielraum
        A2 - Aktuelle Temperatur ? hex(A2) = 162 / 8 = 20,25°C? oder 162 /10 + 4,5(festes Offset) = 20,7°C
        22 - Sollwert 17°C (hex(22)/2) eingestellt
        Bei mir saehe ein solches Kommando wie folgt aus:
        2018-02-23 19:49:25.094 - [[34mdebug[[39m: maxcul.0 incoming raw data from CUL: Z0C07044217FAB200000000A80342M
        2018-02-23 19:49:25.094 - [[34mdebug[[39m: maxcul.0 decoding Message Z0C07044217FAB200000000A80342
        2018-02-23 19:49:25.095 - [[34mdebug[[39m: maxcul.0 RSSI for Message: -41
        2018-02-23 19:49:25.095 - [[34mdebug[[39m: maxcul.0 received unknown command id 42
        • YellowballY Offline
          YellowballY Offline
          Yellowball
          Wo wir gerade beim CUL sind:
          Wie sieht's mit einem funktionierenden Adapter für den Cube aus?
          Ich hatte mal einen über einen Github-Link installiert, aber der lies permanent meinen ioBroker abstürzen…
          ioBroker | Raspberry Pi Zero,1,2,3,4 | Proxmox | Philips HUE | AVM | Broadlink Pro| Amazon Echo Dot, Echo, Echo Show | KODI | u.v.m
            @Yellowball:
            Wie sieht's mit einem funktionierenden Adapter für den Cube aus? `
            Wo ist denn da der Zusammenhang??
            Dies ist ein Thread zu MaxCul.
            • und der verbindet sich über einen Busware Cul zu den Max-Geräten
            • die einbindung eines Selbstbau-CUL wird gerade versucht zu implementieren.
              booehmemaik
              @Yellowball:
              Ich hatte mal einen über einen Github-Link installiert, aber der lies permanent meinen ioBroker abstürzen… `
              der Maxcube adapter funktioniert auf meine Pi ohne Problem. Das einzige Problem ist der Cube selbst ;-) wenn man ihn fremd steuert. aber auch das ist gelöst mit einiger hilfe von leute aus dem Forum oder der FB Gruppe.
                @Yellowball:
                Es gibt wohl einen ioBroker.maxcube Adapter … mehr weiss ich aber nicht.
                Gff testen und neuen Thread mit genauen Fehlerinfos auf machen. "ioBroker abstützen lassen" kann ich nicht glauben :-)
                  @skraw.iobroker:
                  Was fuer Aenderungen brauchen wir denn in dem Adapter unbedingt? 0.3.0 geht echt gut bei mir und auch anderen die ich kenne… `
                  Es gibt ausser Serial Kommunikationsupdate und andere Library/Dependency-Updates keinerlei Änderungen. Ich hab jetzt den Kommunikationscode von 0.3.0 wiederhergestellt in der 0.5.0. Bitte nochmal versuchen.
                  Wenn es immer noch nicht tut muss ich noch mehr reverten …
                  Das Problem daran alles wieder zurückzustellen ist das wir im Notfall an einem Punkt landen wo wir keine Updates mehr machen können. Das wäre schlecht.
                    @skraw.iobroker:
                    00 - Zielraum
                    2018-02-23 19:49:25.095 - [[34mdebug[[39m: maxcul.0 received unknown command id 42 `
                    Also ich habe Code gefunden der das implementieren würde … aber bevor nicht die kommunikation nicht sauber läuft mach ich gar nix. `
                      @apollon77:
                      @skraw.iobroker:
                      Das Problem daran alles wieder zurückzustellen ist das wir im Notfall an einem Punkt landen wo wir keine Updates mehr machen können. Das wäre schlecht. `
                      gab noch einen Fehler. Aber ab jetzt (0:42 Uhr) bitte nochmal versuchen.
                      PS: DIe kommunikation war in der 0.3.0 auf "serialport 3.0". Das ist offiziell nur bis nodejs 4 unterstützt. Ich habe es jetzt auf "Serialport 4", wodurch grundsätzlich bis nodejs 8.x unterstützt ist.
                        skraw.iobroker
                        Es tut mir leid, aber:
                        maxcul.0	2018-02-24 01:25:43.593	debug	enable MAX! Mode of the CUL868
                        maxcul.0	2018-02-24 01:25:42.593	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519431942588,"q":0,"from":"system.adapter.maxcul.0","lc":1519431942588}
                        maxcul.0	2018-02-24 01:25:42.591	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519431942585,"q":0,"from":"system.adapter.maxcul.0","lc":1519431770879}
                        maxcul.0	2018-02-24 01:25:39.631	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519431939624,"q":0,"from":"system.adapter.maxcul.0","lc":1519431939624}
                        maxcul.0	2018-02-24 01:25:39.629	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519431939622,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
                        maxcul.0	2018-02-24 01:25:39.614	info	CUL FW Version: V 1.67 nanoCUL868
                        maxcul.0	2018-02-24 01:25:39.611	debug	incoming raw data from CUL: V 1.67 nanoCUL868
                        maxcul.0	2018-02-24 01:25:39.589	debug	Requested CUL Version...
                        maxcul.0	2018-02-24 01:25:39.581	debug	check CUL Firmware version
                        maxcul.0	2018-02-24 01:25:37.585	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519431937582,"q":0,"from":"system.adapter.maxcul.0","lc":1519431809659}
                        maxcul.0	2018-02-24 01:25:37.575	info	serialPort /dev/ttyUSB0 is open!
                        maxcul.0	2018-02-24 01:25:37.554	info	using serial device /dev/ttyUSB0@38400
                        maxcul.0	2018-02-24 01:25:37.025	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
                        maxcul.0	2018-02-24 01:25:36.967	info	States connected to redis: 127.0.0.1:6379
                        maxcul.0	2018-02-24 01:25:36.955	debug	statesDB connected
                        maxcul.0	2018-02-24 01:25:36.903	debug	objectDB connected
                        host.ioBroker-Pi	2018-02-24 01:25:35.225	info	instance system.adapter.maxcul.0 started with pid 25975
                        host.ioBroker-Pi	2018-02-24 01:25:35.171	info	object change system.adapter.maxcul.0
                        und steht …
                        Auch nach einem Reset das gleiche Bild. Nach dem "enable MAX mode" ists aus ...
                          ich kapiere es nicht … Ich hab nochmal Debug eingebaut. Bitte schick nochmal log.
                          Ansonsten muss ich wirklich auf serialport 3 zurück und verlieren damit halt node8 support ...
                            skraw.iobroker
                            Ok, da geht mehr. Das hat es bisher noch nie getan. Hast Du ausser dem Debug noch was geaendert?
                            Ich bin erst morgen wieder zum Testen in der Lage, Du kannst noch ueberlegen :-)
                            maxcul.0	2018-02-24 12:58:17.516	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":383,"ack":true,"ts":1519473497506,"q":0,"from":"system.adapter.maxcul.0","lc":1519473497506}
                            maxcul.0	2018-02-24 12:58:12.494	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":378,"ack":true,"ts":1519473492488,"q":0,"from":"system.adapter.maxcul.0","lc":1519473492488}
                            maxcul.0	2018-02-24 12:58:07.858	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":374,"ack":true,"ts":1519473487853,"q":0,"from":"system.adapter.maxcul.0","lc":1519473487853}
                            maxcul.0	2018-02-24 12:58:07.840	debug	got OK-ACK Packet from 16fb8f
                            maxcul.0	2018-02-24 12:58:07.840	debug	RSSI for Message: -40.5
                            maxcul.0	2018-02-24 12:58:07.839	debug	decoding Message Z0E01020216FB8F123456000139643443
                            maxcul.0	2018-02-24 12:58:07.839	debug	incoming raw data from CUL: Z0E01020216FB8F123456000139643443
                            maxcul.0	2018-02-24 12:58:06.739	debug	serial port buffer have been drained
                            maxcul.0	2018-02-24 12:58:06.723	debug	Send Packet to CUL: 0b01004012345616fb8f0074, awaiting drain event
                            maxcul.0	2018-02-24 12:58:06.701	debug	sendTemperature(maxcul.0.NKF0003406, 26, 1)
                            maxcul.0	2018-02-24 12:58:05.686	debug	redis pmessage io.maxcul.0.* io.maxcul.0.NKF0003406.desiredTemperature {"val":26,"ack":false,"ts":1519473485684,"q":0,"from":"system.adapter.admin.0","lc":1519473485684}
                            maxcul.0	2018-02-24 12:58:02.494	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":478,"ack":true,"ts":1519473482490,"q":0,"from":"system.adapter.maxcul.0","lc":1519473482490}
                            maxcul.0	2018-02-24 12:57:57.507	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":473,"ack":true,"ts":1519473477499,"q":0,"from":"system.adapter.maxcul.0","lc":1519473477499}
                            maxcul.0	2018-02-24 12:57:52.480	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":468,"ack":true,"ts":1519473472478,"q":0,"from":"system.adapter.maxcul.0","lc":1519473472478}
                            maxcul.0	2018-02-24 12:57:47.478	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":463,"ack":true,"ts":1519473467475,"q":0,"from":"system.adapter.maxcul.0","lc":1519473467475}
                            maxcul.0	2018-02-24 12:57:42.476	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":458,"ack":true,"ts":1519473462474,"q":0,"from":"system.adapter.maxcul.0","lc":1519473462474}
                            maxcul.0	2018-02-24 12:57:38.502	debug	Za drained
                            maxcul.0	2018-02-24 12:57:38.496	debug	Za written
                            maxcul.0	2018-02-24 12:57:38.492	debug	Zr drained
                            maxcul.0	2018-02-24 12:57:38.488	debug	Zr written
                            maxcul.0	2018-02-24 12:57:38.485	debug	X20 drained
                            maxcul.0	2018-02-24 12:57:38.481	debug	X20 written
                            maxcul.0	2018-02-24 12:57:38.477	debug	enable MAX! Mode of the CUL868
                            maxcul.0	2018-02-24 12:57:37.484	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519473457478,"q":0,"from":"system.adapter.maxcul.0","lc":1519473457478}
                            maxcul.0	2018-02-24 12:57:37.482	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519473457475,"q":0,"from":"system.adapter.maxcul.0","lc":1519464560648}
                            maxcul.0	2018-02-24 12:57:34.510	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519473454502,"q":0,"from":"system.adapter.maxcul.0","lc":1519473454502}
                            maxcul.0	2018-02-24 12:57:34.508	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519473454500,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
                            maxcul.0	2018-02-24 12:57:34.492	info	CUL FW Version: V 1.67 nanoCUL868
                            maxcul.0	2018-02-24 12:57:34.489	debug	incoming raw data from CUL: V 1.67 nanoCUL868
                            maxcul.0	2018-02-24 12:57:34.473	debug	Requested CUL Version...
                            maxcul.0	2018-02-24 12:57:34.465	debug	check CUL Firmware version
                            maxcul.0	2018-02-24 12:57:32.470	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519473452466,"q":0,"from":"system.adapter.maxcul.0","lc":1519473339719}
                            maxcul.0	2018-02-24 12:57:32.458	info	serialPort /dev/ttyUSB0 is open!
                            maxcul.0	2018-02-24 12:57:32.438	info	using serial device /dev/ttyUSB0@38400
                            maxcul.0	2018-02-24 12:57:31.923	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
                            maxcul.0	2018-02-24 12:57:31.862	info	States connected to redis: 127.0.0.1:6379
                            maxcul.0	2018-02-24 12:57:31.850	debug	statesDB connected
                            maxcul.0	2018-02-24 12:57:31.796	debug	objectDB connected
                            Nachtrag Thema Wandthermostat:
                            Abgesehen von dem Kommando 42 habe ich noch nicht verstanden wie man dieses Thermostat mit dem Broker pairt. Mir scheint naemlich diese Broadcasts an "000000" bringen die in der Naehe befindlichen Heizungsthermostate durcheinander, die versuchen dann dieser Anweisung zu folgen und nicht den Broker-Einstellungen…
                              skraw.iobroker
                              Jetzt ist was passiert, das hatten wir noch nie:
                              host.ioBroker-Pi	2018-02-24 13:02:36.028	error	instance system.adapter.maxcul.0 terminated with code 0 (OK)
                              host.ioBroker-Pi	2018-02-24 13:02:36.028	error	Caught by controller[0]: at FSReqWrap.wrapper [as oncomplete] (fs.js:683:17)
                              host.ioBroker-Pi	2018-02-24 13:02:36.028	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/serialport.js:306:7)
                              host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/serialport.js:293:14)
                              host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort._emitData (/opt/iobroker/node_modules/serialport/lib/serialport.js:313:18)
                              host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/parsers.js:23:13)
                              host.ioBroker-Pi	2018-02-24 13:02:36.026	error	Caught by controller[0]: at Array.forEach (native)
                              host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at /opt/iobroker/node_modules/serialport/lib/parsers.js:24:17
                              host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at SerialPort.emit (events.js:188:7)
                              host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at emitOne (events.js:96:13)
                              host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/iobroker.maxcul/lib/communication-layer.js:93:42)
                              host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at CommunicationServiceLayer.emit (events.js:188:7)
                              host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at emitOne (events.js:96:13)
                              host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at CommunicationServiceLayer. (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:46:34)
                              host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at MaxDriver.handleIncommingMessage (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:151:57)
                              host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at MaxDriver.ThermostatState (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:486:38)
                              host.ioBroker-Pi	2018-02-24 13:02:36.023	error	Caught by controller[0]: TypeError: rawBitData.getRange is not a function
                              maxcul.0	2018-02-24 13:02:35.969	error	TypeError: rawBitData.getRange is not a function at MaxDriver.ThermostatState (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:486:38) at MaxDriver.handleIncommingMessage (/opt/iobrok
                              maxcul.0	2018-02-24 13:02:35.969	error	uncaught exception: rawBitData.getRange is not a function
                              maxcul.0	2018-02-24 13:02:35.968	debug	got data from heatingelement 16fbae with payload 39002D00FB
                              maxcul.0	2018-02-24 13:02:35.967	debug	RSSI for Message: -80
                              maxcul.0	2018-02-24 13:02:35.967	debug	decoding Message Z0F00046016FBAE0000000039002D00FBF4
                              maxcul.0	2018-02-24 13:02:35.966	debug	incoming raw data from CUL: Z0F00046016FBAE0000000039002D00FBF4
                                @skraw.iobroker:
                                Ich bin erst morgen wieder zum Testen in der Lage, Du kannst noch ueberlegen :-) `
                                Ja ich habe noch ein was geändert: Es wird jetzt bei der Initialisierung nach jedem senden einer Nachricht gewartet das die auch wirklich gesendet wurde (draining). Das war vorher nicht so. Da wurde einfach alles direkt nacheinander gesendet.
                                @skraw.iobroker:
                                Jetzt ist was passiert, das hatten wir noch nie: `
                                Da ist scheinbar ein Bug im Code der eine Funktion aufruft die es nicht gibt. Habe bei der "Quelle" (ja habe inzwischen gefunden wo die Logik herkommt und könnte daher auch auf die aktuellste Version updaten) nachgesehen und fix ist auf Github.
                                Bitte versuchen und mal laufen lassen. Wenn das erstmal wieder so tut wie in der 0.3.0 dann machen wir es erstmal so live.
                                Dann kann ich in einer 0.6 mal die Logik aktualisieren auf den aktuellen Stand (Kommunikation nicht anfassen) und wir sehen was da so geht
                                  skraw.iobroker
                                  #66
                                  Hab die neue Version jetzt gerade installiert und laeuft. Auf die Schnelle kann ich keinen Absturz mehr produzieren wie beim letzten Mal. Ich lass es jetzt mal laufen, solange ich mich nicht melde kannst Du davon ausgehen dass es noch fehlerfrei laeuft…
                                    #67
                                    Ok dann veröffentliche ich die 0.5.0 heute Abend um erstmal was funktionierendes live zu haben. Dann versuche ich die Tage mal eine 0.6 mit Logikaktualisierungen
                                      skraw.iobroker
                                      #68
                                      Welchen?
                                        #69
                                        Mindestens Unterstützung für die Message 42 von oben und anderem Kram.
                                          Mickbaer
                                          #70
                                          @skraw.iobroker:
                                          Koennte es sein dass das sowas simples wie ein <cr><lf>Problem ist? (Also ein fehlendes <cr>oder andersherum)?
                                          (Ich hab den betreffenden Code bis dato nicht gelesen…)
                                          geändert: Code in Code-Tags; Homoran (Mod)</cr></lf></cr> `
                                          das befürchte Ich bei dem CUL-Adapter, der am naoCUL nicht initialisiert wird auch. 😢
                                          Das läßt sich mit mit Terminal PRG nur schwer debuggen.
                                          Aber mal sehen was apolon77 da antwortet.
                                          Gruß Mickbaer aus Berlin
