  4. Test Adapter Fiat Jeep v0.0.x
    6.8k
204 Beiträge 38 Kommentatoren 45.4k Aufrufe 36 Beobachtet
  • H hvb
    Iob diag muss ich nachliefern - bin grad mobil unterwegs.
    Grundsätzlich:
    Iob in docker (orbstack) auf einem Mac mini
    #174
    @hvb
    Da wird dann vermutlich nicht viel bei herumkommen, iob diag ist auf Linux ausgelegt.
    • H hvb
      Grundsätzlich:
      tombox
      #175
      @hvb nochmal die GitHub version installieren und testen
      H 1 Antwort Letzte Antwort
      • T tombox
        hvb
        #176
        @tombox
        Hier das log:
        fiat.0
        2026-06-28 23:01:03.378	error	Login failed
        fiat.0
        2026-06-28 23:01:03.378	error	Error: sessionInfo missing
        fiat.0
        2026-06-28 23:01:03.378	error	sessionInfo missing
        fiat.0
        2026-06-28 23:01:03.378	error	Gigya blocked the login (errorCode 400006, "Your request is blocked because of security issues."). This usually means the GMID cookie from the bootstrap was not sent back. Cookies for the login host: (empty)
        fiat.0
        2026-06-28 23:01:03.375	debug	{"callId":"019f100927de7253ba5c0c0bcdf67ad9","errorCode":400006,"errorDetails":"Your request is blocked because of security issues.","errorMessage":"Invalid parameter value","apiVersion":2,"statusCode":400,"statusReason":"Bad Request","time":"2026-06-28T21:01:03.367Z","errorFlags":"missingKey"}
        fiat.0
        2026-06-28 23:01:03.374	info	Step 2/5: accounts.login: {"statusCode":400,"errorCode":400006,"errorMessage":"Invalid parameter value","errorDetails":"Your request is blocked because of security issues.","errorFlags":"missingKey","callId":"019f100927de7253ba5c0c0bcdf67ad9"}
        fiat.0
        2026-06-28 23:01:03.252	info	Step 2/5: Gigya accounts.login
        fiat.0
        2026-06-28 23:01:03.252	info	Step 1/5: bootstrap body: {"statusCode":200,"errorCode":0,"callId":"019f1009277474d5a40525c11b20cd93"}
        fiat.0
        2026-06-28 23:01:03.252	info	Cookies after bootstrap: (empty)
        fiat.0
        2026-06-28 23:01:03.244	debug	Set-Cookie: ["gmid=gmid.ver4.AtLtQdsBtA.VaKjN0tiEY2N_3tTsl_E67NDbU1gC20jBO317daDRcit3M5y5mZu2G343VxlmEB2.HcMIDn5QZkCsIJp86gHnosyXGaltXOvCtNwxpwwlGEM2aHjmEbC5olhuNHLJxomOTfN-YbUy2SzEwkU-KQk5kA.sc3; expires=Mon, 28 Jun 2027 21:01:03 GMT; domain=.loginmyuconnect.fiat.com; path=/; secure; httponly","ucid=xMdlQ2k_7-QbRaJqiX_HPw; expires=Mon, 28 Jun 2027 21:01:03 GMT; domain=.loginmyuconnect.fiat.com; path=/; secure; httponly","hasGmid=ver2; expires=Mon, 28 Dec 2026 21:01:03 GMT; domain=.loginmyuconnect.fiat.com; path=/; secure"]
        fiat.0
        2026-06-28 23:01:03.244	info	Step 1/5: bootstrap http=200 set-cookie-count=3
        fiat.0
        2026-06-28 23:01:03.047	info	Step 1/5: Gigya bootstrap
        fiat.0
        2026-06-28 23:01:03.047	info	login() type=fiat brand=FIAT loginUrl=https://loginmyuconnect.fiat.com myuUrl=https://myuconnect.fiat.com loginApiKey=3_mOx_J2… apiKey=2wGyL6PH…
        fiat.0
        2026-06-28 23:01:03.029	info	starting. Version 0.0.11 (non-npm: TA2k/ioBroker.fiat) in /opt/iobroker/node_modules/iobroker.fiat, node: v22.22.2, js-controller: 7.2.2
        fiat.0
        2026-06-28 23:01:02.929	debug	States connected to redis: 127.0.0.1:9000
        fiat.0
        2026-06-28 23:01:02.874	debug	States create User PubSub Client
        fiat.0
        2026-06-28 23:01:02.873	debug	States create System PubSub Client
        fiat.0
        2026-06-28 23:01:02.823	debug	Redis States: Use Redis connection: 127.0.0.1:9000
        fiat.0
        2026-06-28 23:01:02.797	debug	Objects connected to redis: 127.0.0.1:9001
        fiat.0
        2026-06-28 23:01:02.795	debug	Objects client initialize lua scripts
        fiat.0
        2026-06-28 23:01:02.777	debug	Objects create User PubSub Client
        fiat.0
        2026-06-28 23:01:02.776	debug	Objects create System PubSub Client
        fiat.0
        2026-06-28 23:01:02.776	debug	Objects client ready ... initialize now
        fiat.0
        2026-06-28 23:01:02.761	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
        fiat.0
        2026-06-28 23:00:59.875	info	terminating
        fiat.0
        2026-06-28 23:00:59.874	info	terminating
        fiat.0
        2026-06-28 23:00:59.373	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fiat.0
        2026-06-28 23:00:59.370	info	terminating
        fiat.0
        2026-06-28 23:00:59.351	info	Got terminate signal TERMINATE_YOURSELF
        • H hvb
          @tombox
          Hier das log:
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          fiat.0
          tombox
          #177
          @hvb nochmal installieren und testen
          • T tombox
            hvb
            #178
            @tombox
            Läuft. Keine Fehlermeldungen mehr.
            Kurzer Test aller verfügbaren Funktionen -> alles prima.
            Herzlichen Dank!
            • rku2003R Offline
              rku2003R Offline
              rku2003
              schrieb am zuletzt editiert von rku2003
              #179
              • rku2003R rku2003
                tombox
                #180
                @rku2003 auch bei der GitHub version?
                • rku2003R Offline
                  rku2003R Offline
                  rku2003
                  #181
                  • sigma415S Offline
                    sigma415S Offline
                    sigma415
                    #182
                    Die neueste Github Version ist von heute, 02.07.26, 20:54. Nicht von der Chore-Versionsnummer täuschen lassen !
                    • rku2003R Offline
                      rku2003R Offline
                      rku2003
                      #183
                      Fiat Adapter von GitHub reinstallt.
                      • rku2003R Offline
                        rku2003R Offline
                        rku2003
                        #184
                        • rku2003R Offline
                          rku2003R Offline
                          rku2003
                          #185
                          • rku2003R Offline
                            rku2003R Offline
                            rku2003
                            #186
                            • rku2003R Offline
                              rku2003R Offline
                              rku2003
                              #187
                              • rku2003R rku2003
                                tombox
                                #188
                                @rku2003 auch mit der aktuellen GitHub versionß
                                • rku2003R Offline
                                  rku2003R Offline
                                  rku2003
                                  #189
                                  • rku2003R rku2003
                                    tombox
                                    #190
                                    @rku2003 kannst den debug log zeigen?
                                    • rku2003R Offline
                                      rku2003R Offline
                                      rku2003
                                      #191
                                      • rku2003R rku2003
                                        tombox
                                        #192
                                        ok kannst den debug log jetzt wieder löschen
                                        • T tombox
                                          tombox
                                          #193
                                          Teste nochmal die GitHub version
