  3. Einsteigerfragen
  4. Installation
  5. Umzug von Bullseye auf Trixie, Probleme mit Backup
58 Beiträge 5 Kommentatoren 2.6k Aufrufe 5 Beobachtet
    DiMe
    pi@Raspberry:~ $ apt policy mongodb-org
    Notice: Unable to locate package mongodb-org
    pi@Raspberry:~ $ sudo apt update
    sudo apt full-upgrade
    [sudo] password for pi:
    Hit:1 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:3 https://apt.grafana.com stable InRelease
    Hit:4 https://deb.debian.org/debian trixie InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:6 https://apt.glennr.nl/repo trixie InRelease
    Get:7 https://repos.influxdata.com/debian stable InRelease [6,922 B]
    Hit:8 https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 InRelease
    Get:9 https://packages.adoptium.net/artifactory/deb trixie InRelease [7,503 B]
    Fetched 14.4 kB in 1s (23.3 kB/s)
    1 package can be upgraded. Run 'apt list --upgradable' to see it.
    Notice: Skipping acquire of configured file 'main/binary-armhf/Packages' as repository 'https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 InRelease' doesn't support architecture 'armhf'
    The following packages were automatically installed and are no longer required:
      gyp             libjs-is-typedarray  libjs-sprintf-js
      libcares2       libjs-prettify       libjs-typedarray-to-buffer
      libjs-events    libjs-regenerate     libssl-dev
      libjs-inherits  libjs-source-map     libuv1-dev
    Use 'sudo apt autoremove' to remove them.
    Upgrading:
      influxdb
    Installing dependencies:
      influxdata-archive-keyring
    Summary:
      Upgrading: 1, Installing: 1, Removing: 0, Not Upgrading: 0
      Download size: 37.4 MB / 37.4 MB
      Space needed: 106 MB / 16.5 GB available
    Continue? [Y/n] y
    Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb arm64 1.12.4-1 [37.4 MB]
    Fetched 37.4 MB in 14s (2,703 kB/s)
    Reading changelogs... Done
    Selecting previously unselected package influxdata-archive-keyring.
    (Reading database ... 126586 files and directories currently installed.)
    Preparing to unpack .../influxdata-archive-keyring_2026.01.09_all.deb ...
    Unpacking influxdata-archive-keyring (2026.01.09) ...
    Preparing to unpack .../influxdb_1.12.4-1_arm64.deb ...
    Unpacking influxdb (1.12.4-1) over (1.6.7~rc0-2+b12) ...
    Setting up influxdb (1.12.4-1) ...
    Installing new version of config file /etc/influxdb/influxdb.conf ...
    Synchronizing state of influxdb.service with SysV service script with /usr/lib/systemd/systemd-sysv-install.
    Executing: /usr/lib/systemd/systemd-sysv-install enable influxdb
    Setting up influxdata-archive-keyring (2026.01.09) ...
    Processing triggers for man-db (2.13.1-1) ...
    • D DiMe
      Upgrading:
        influxdb
      Summary:
      Continue? [Y/n] y
      @DiMe
      sudo apt autoremove
      Dann nochmal ein
      sudo apt update
        DiMe
        i@Raspberry:~ $ sudo apt autoremove
        REMOVING:
        Summary:
          Upgrading: 0, Installing: 0, Removing: 12, Not Upgrading: 0
          Freed space: 19.9 MB
        Continue? [Y/n] y
        (Reading database ... 126612 files and directories currently installed.)
        Removing gyp (0.16.2-2) ...
        Removing libcares2:arm64 (1.34.5-1+deb13u1) ...
        Removing libjs-events (3.3.0+~3.0.0-3) ...
        Removing libjs-inherits (2.0.4-6) ...
        Removing libjs-is-typedarray (1.0.0-4) ...
        Removing libjs-prettify (2015.12.04+dfsg-1.1) ...
        Removing libjs-regenerate (1.4.2-3) ...
        Removing libjs-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
        Removing libjs-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
        Removing libjs-typedarray-to-buffer (4.0.0-2) ...
        Removing libssl-dev:arm64 (3.5.6-1~deb13u2+rpt1) ...
        Removing libuv1-dev:arm64 (1.50.0-2) ...
        Processing triggers for libc-bin (2.41-12+rpt1+deb13u3) ...
        Get:6 https://repos.influxdata.com/debian stable InRelease [6,922 B]
        Hit:7 https://apt.glennr.nl/repo trixie InRelease
        Fetched 14.4 kB in 1s (24.2 kB/s)
        All packages are up to date.
        Summary:
          Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
        • D DiMe
          REMOVING:
          Summary:
          Continue? [Y/n] y
          Summary:
          @DiMe
          Das mongodb-Repo scheint im Moment nicht richtig befüllt zu sein.
          Denn laut deren eigener Anleitung muss da ein Paket namens mongodb-org vorhanden sein, isses aber nicht:
          thomas@testpi:~ $ apt policy mongodb
          mongodb:
            Installed: (none)
            Candidate: (none)
            Version table:
          thomas@testpi:~ $ apt policy mongodb-org
          thomas@testpi:~ $
          Keine Ahnung was da warum wie lange (noch) klemmt.
          BTW: Die Meldung
          kannst du abstellen, indem du die Datei /etc/apt/sources.list.d/mongodb-org-8.0.list so anpasst:
          deb [ arch=arm64 signed-by=/usr/share/keyrings/mongodb-server-8.0.gpg ] https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 main
            @DiMe
            mongodb:
              Installed: (none)
              Candidate: (none)
              Version table:
            thomas@testpi:~ $
            BTW: Die Meldung
            DiMe
            @Thomas-Braun sagte:
            Ah, wie ich sehe ist das auch so bei dir auf deinem Testpi
             pi@Raspberry:~ $ deb [ arch=arm64 signed-by=/usr/share/keyrings/mongodb-server-8                                  .0.gpg ] https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 main
            -bash: deb: command not found
            pi@Raspberry:~ $ deb[ arch=arm64 signed-by=/usr/share/keyrings/mongodb-server-8.                                  0.gpg ] https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 main
            -bash: deb[ arch=arm64 signed-by=/usr/share/keyrings/mongodb-server-8.0.gpg ]: N                                  o such file or directory
            Also beim genau kopieren kam, command not found
            Habe in meiner Ahnungslosigkeit das Leerzeichen nach deb entfernt.
            Dann kam Meldung das Datei nicht gefunden.
            Die datei ist aber da:
            pi@Raspberry:~ $ ls -lA /usr/share/keyrings
            total 240
            lrwxrwxrwx 1 root root    37 Apr 10  2025 debian-archive-bookworm-automatic.gpg -> debian-archive-bookworm-automat                                       ic.pgp
            -rw-r--r-- 1 root root  8700 Apr 10  2025 debian-archive-bookworm-automatic.pgp
            lrwxrwxrwx 1 root root    46 Apr 10  2025 debian-archive-bookworm-security-automatic.gpg -> debian-archive-bookwor                                       m-security-automatic.pgp
            -rw-r--r-- 1 root root  8709 Apr 10  2025 debian-archive-bookworm-security-automatic.pgp
            lrwxrwxrwx 1 root root    34 Apr 10  2025 debian-archive-bookworm-stable.gpg -> debian-archive-bookworm-stable.pgp
            -rw-r--r-- 1 root root   280 Apr 10  2025 debian-archive-bookworm-stable.pgp
            lrwxrwxrwx 1 root root    37 Apr 10  2025 debian-archive-bullseye-automatic.gpg -> debian-archive-bullseye-automat                                       ic.pgp
            -rw-r--r-- 1 root root  8700 Apr 10  2025 debian-archive-bullseye-automatic.pgp
            lrwxrwxrwx 1 root root    46 Apr 10  2025 debian-archive-bullseye-security-automatic.gpg -> debian-archive-bullsey                                       e-security-automatic.pgp
            -rw-r--r-- 1 root root  8709 Apr 10  2025 debian-archive-bullseye-security-automatic.pgp
            lrwxrwxrwx 1 root root    34 Apr 10  2025 debian-archive-bullseye-stable.gpg -> debian-archive-bullseye-stable.pgp
            -rw-r--r-- 1 root root  2453 Apr 10  2025 debian-archive-bullseye-stable.pgp
            lrwxrwxrwx 1 root root    26 Apr 10  2025 debian-archive-keyring.gpg -> debian-archive-keyring.pgp
            -rw-r--r-- 1 root root 55918 Apr 10  2025 debian-archive-keyring.pgp
            lrwxrwxrwx 1 root root    31 Apr 10  2025 debian-archive-removed-keys.gpg -> debian-archive-removed-keys.pgp
            -rw-r--r-- 1 root root 72636 Apr 10  2025 debian-archive-removed-keys.pgp
            lrwxrwxrwx 1 root root    35 Apr 10  2025 debian-archive-trixie-automatic.gpg -> debian-archive-trixie-automatic.p                                       gp
            -rw-r--r-- 1 root root  8698 Apr 10  2025 debian-archive-trixie-automatic.pgp
            lrwxrwxrwx 1 root root    44 Apr 10  2025 debian-archive-trixie-security-automatic.gpg -> debian-archive-trixie-se                                       curity-automatic.pgp
            -rw-r--r-- 1 root root  8707 Apr 10  2025 debian-archive-trixie-security-automatic.pgp
            lrwxrwxrwx 1 root root    32 Apr 10  2025 debian-archive-trixie-stable.gpg -> debian-archive-trixie-stable.pgp
            -rw-r--r-- 1 root root   962 Apr 10  2025 debian-archive-trixie-stable.pgp
            -rw-r--r-- 1 root root  2370 Jan  9 18:55 influxdata-archive_compat.gpg
            -rw-r--r-- 1 root root  4516 Jan  9 18:55 influxdata-archive.gpg
            -rw-r--r-- 1 root root  1178 Jun 27 13:40 mongodb-server-8.0.gpg
            -rw-r--r-- 1 root root  1207 Jun 27 10:53 nodesource.gpg
            lrwxrwxrwx 1 root root    33 Jun  6  2025 raspberrypi-archive-automatic.gpg -> raspberrypi-archive-automatic.pgp
            -rw-r--r-- 1 root root  1229 Jun  6  2025 raspberrypi-archive-automatic.pgp
            lrwxrwxrwx 1 root root    31 Jun  6  2025 raspberrypi-archive-keyring.gpg -> raspberrypi-archive-keyring.pgp
            -rw-r--r-- 1 root root  1229 Jun  6  2025 raspberrypi-archive-keyring.pgp
            • D DiMe
              total 240
              @DiMe sagte:
              Das ist der Eintrag in der Datei
              Diese musst du mit deinem bevorzugten Editor bearbeiten. Ich verwende meist nano dafür. Also per
              sudo nano /etc/apt/sources.list.d/mongodb-org-8.0.list
              anpassen. Speichern mit Strg-O, nano verlassen mit Strg-X.
                DiMe
                Done
                Hit:3 https://deb.debian.org/debian trixie InRelease
                Hit:4 https://apt.grafana.com stable InRelease
                Get:6 https://apt.glennr.nl/repo trixie InRelease [28.2 kB]
                Get:8 https://apt.glennr.nl/repo trixie/mongod/8.0 arm64 Packages [4,735 B]
                Hit:9 https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 InRelease
                Get:10 https://packages.adoptium.net/artifactory/deb trixie InRelease [7,503 B]
                Fetched 47.4 kB in 1s (57.9 kB/s)
                Upgrading:
                  mongod-armv8
                Summary:
                  Upgrading: 1, Installing: 0, Removing: 0, Not Upgrading: 0
                  Download size: 23.5 MB
                  Space needed: 0 B / 16.4 GB available
                Continue? [Y/n] y
                Get:1 https://apt.glennr.nl/repo trixie/mongod/8.0 arm64 mongod-armv8 arm64 8.0.26 [23.5 MB]
                Fetched 23.5 MB in 8s (2,871 kB/s)
                (Reading database ... 126267 files and directories currently installed.)
                Preparing to unpack .../mongod-armv8_8.0.26_arm64.deb ...
                Unpacking mongod-armv8 (8.0.26) over (8.0.23) ...
                Setting up mongod-armv8 (8.0.26) ...
                mongodb:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                • D DiMe
                  Done
                  Upgrading:
                    mongod-armv8
                  Summary:
                  Continue? [Y/n] y
                  mongodb:
                    Installed: (none)
                    Candidate: (none)
                    Version table:
                  @DiMe sagte:
                  mongod-armv8
                  Wo kommt denn das her? Finde ich auf meinem Test-System nicht.
                  apt policy mongod-armv8
                  mal anschauen.
                  BTW: Dir fehlt auch das trixie-updates Repo aus irgendeinem Grund.
                  Edit: Also aus diesem Repo kommt das:
                  Was beziehst du eigentlich von da?
                  • D DiMe
                    Done
                    Upgrading:
                      mongod-armv8
                    Summary:
                    Continue? [Y/n] y
                    mongodb:
                      Installed: (none)
                      Candidate: (none)
                      Version table:
                    @DiMe
                    Schau mal, wie die
                    /etc/apt/sources.list.d/debian.sources
                    bei dir aussieht. Da fehlt mit Sicherheit ein Eintrag. Siehe meine Version:
                    Types: deb
                    URIs: http://deb.debian.org/debian/
                    Suites: trixie trixie-updates
                    Components: main contrib non-free non-free-firmware
                    Signed-By: /usr/share/keyrings/debian-archive-keyring.pgp
                    Types: deb
                    URIs: http://deb.debian.org/debian-security/
                    Suites: trixie-security
                      DiMe
                      mongodb:
                        Installed: (none)
                        Candidate: (none)
                        Version table:
                      pi@Raspberry:~ $ ^C
                      pi@Raspberry:~ $ apt policy mongod-armv8
                      mongod-armv8:
                        Installed: 8.0.26
                        Candidate: 8.0.26
                        Version table:
                       *** 8.0.26 500
                              500 https://apt.glennr.nl/repo trixie/mongod/8.0 arm64 Packages
                           8.0.25 500
                           8.0.24 500
                           8.0.23 500
                           8.0.21 500
                           8.0.20 500
                           8.0.19 500
                           8.0.18 500
                           8.0.17 500
                           8.0.16 500
                           8.0.15 500
                           8.0.14 500
                           8.0.13 500
                           8.0.12 500
                           8.0.11 500
                           8.0.10 500
                           8.0.9 500
                           8.0.8 500
                           8.0.7 500
                           8.0.6 500
                           8.0.5 500
                           8.0.4 500
                           8.0.3 500
                      Das andere ist von meinem Unificontroller
                        DiMe
                        schrieb am zuletzt editiert von DiMe
                        Der Eintrag vom Debian.source
                        # Types: deb
                        # URIs: http://deb.debian.org/debian/
                        # Suites: trixie trixie-updates
                        # Components: main contrib non-free non-free-firmware
                        # Signed-By: /usr/share/keyrings/debian-archive-keyring.pgp
                        Types: deb
                        P.S. muss dann weg. Erstmal vielen Dank Thomas!
