  3. Einsteigerfragen
  4. Installation
  5. Umzug von Bullseye auf Trixie, Probleme mit Backup
58 Beiträge 5 Kommentatoren 2.6k Aufrufe 5 Beobachtet
  • D DiMe
    Hab die Datei gelöscht und die neue Quelle angelegt
    Neuer Diag
    ```bash
    Script v.2026-06-06
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Raspberry
           Icon name: computer
              Kernel: Linux 6.18.34+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Unknown
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 67 days ago (on 2026-04-21).
    Systemuptime and Load:
     13:43:19 up 16 min,  2 users,  load average: 0.58, 0.84, 0.96
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2026-06-27 13:43:19 CEST
               Universal time: Sat 2026-06-27 11:43:19 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c        spi render input iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        Not found
    Desktop:
    Session:                tty
    Boot Target:            multi-user.target
    *** MEMORY ***
    Mem:            4.0G        3.0G        337M        7.0M        704M        952M
    Swap:           2.1G         27M        2.1G
    Total:          6.1G        3.1G        2.5G
    Active iob-Instances:   12
             3795 M total memory
             2887 M used memory
              992 M active memory
             2299 M inactive memory
              321 M free memory
               41 M buffer memory
              631 M swap cache
             2047 M total swap
               26 M used swap
             2021 M free swap
    top - 13:43:20 up 16 min,  2 users,  load average: 0.58, 0.84, 0.96
    Tasks: 187 total,   1 running, 186 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.8 total,    319.7 free,   2888.6 used,    672.5 buff/cache
    MiB Swap:   2048.0 total,   2021.8 free,     26.2 used.    907.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  9.1M  751M   2% /run
    /dev/mmcblk0p2 ext4       28G   11G   16G  42% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald        .service
    tmpfs          tmpfs     1.9G  432K  1.9G   1% /tmp
    /dev/mmcblk0p1 vfat      505M   66M  439M  14% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.servi        ce
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@tty        S0.service
    tmpfs          tmpfs     380M  8.0K  380M   1% /run/user/1000
    Messages concerning filesystems in dmesg:
    [Sat Jun 27 13:26:25 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
    [Sat Jun 27 13:26:25 2026] EXT4-fs (mmcblk0p2): mounted filesystem e634e0a4-a958        -46cb-abad-862d2102573f ro with ordered data mode. Quota mode: none.
    [Sat Jun 27 13:26:28 2026] EXT4-fs (mmcblk0p2): re-mounted e634e0a4-a958-46cb-ab        ad-862d2102573f r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.3G    /var/
    1.5G    /var/lib
    873M    /var/lib/influxdb
    835M    /var/lib/influxdb/data
    814M    /var/lib/influxdb/data/iobroker/autogen
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    1013M   /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    159M    /opt/iobroker/iobroker-data/
    116M    /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.j        s
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescrip        t/tsWorker.js
    3.7M    /opt/iobroker/iobroker-data/files/javascript.admin/custom/assets/index-C        npybLRW.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.23.1
    /usr/bin/node           v22.23.1
    /usr/bin/npm            10.9.8
    /usr/bin/npx            10.9.8
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.23.1-1nodesource1
      Candidate: 22.23.1-1nodesource1
      Version table:
     *** 22.23.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.23.0-1nodesource1 1001
         22.22.3-1nodesource1 1001
         22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Pac        kages
            500 https://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Raspberry           Raspberry (version: 7.2.2, hostname: Raspberry     , alive,        uptime: 1018)
    Core adapters versions
    js-controller:  7.2.2
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspberry        -  enabled, port: 8081, bind: 0.0.0.0, run as: admi        n
    + system.adapter.alexa2.0                 : alexa2                : Raspberry        -  enabled
    + system.adapter.backitup.0               : backitup              : Raspberry        -  enabled
    + system.adapter.discovery.0              : discovery             : Raspberry        -  enabled
    + system.adapter.influxdb.0               : influxdb              : Raspberry        -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : Raspberry        -  enabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : Raspberry        -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : Raspberry        -  enabled
    + system.adapter.senec.0                  : senec                 : Raspberry        -  enabled
    + system.adapter.tuya.0                   : tuya                  : Raspberry        -  enabled
    + system.adapter.unifi.0                  : unifi                 : Raspberry        -  enabled
      system.adapter.vis.0                    : vis                   : Raspberry        -  enabled
    + system.adapter.web.0                    : web                   : Raspberry        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                                     │        auto upgrade │
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │        false        │
    │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │        false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                                  │ name                 │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'              │ 'admin'              │ '7.8.23' │ 'none'         │
    │ 1       │ 'system.adapter.alexa2'             │ 'alexa2'             │ '3.27.4' │ 'none'         │
    │ 2       │ 'system.adapter.backitup'           │ 'backitup'           │ '3.3.17' │ 'none'         │
    │ 3       │ 'system.adapter.daswetter'          │ 'daswetter'          │ '3.1.10' │ 'none'         │
    │ 4       │ 'system.adapter.discovery'          │ 'discovery'          │ '5.0.0'  │ 'none'         │
    │ 5       │ 'system.adapter.dwd'                │ 'dwd'                │ '2.8.5'  │ 'none'         │
    │ 6       │ 'system.adapter.influxdb'           │ 'influxdb'           │ '4.0.2'  │ 'none'         │
    │ 7       │ 'system.adapter.javascript'         │ 'javascript'         │ '9.0.18' │ 'none'         │
    │ 8       │ 'system.adapter.netatmo-crawler'    │ 'netatmo-crawler'    │ '1.2.0'  │ 'none'         │
    │ 9       │ 'system.adapter.pvforecast'         │ 'pvforecast'         │ '6.1.0'  │ 'none'         │
    │ 10      │ 'system.adapter.senec'              │ 'senec'              │ '2.5.3'  │ 'none'         │
    │ 11      │ 'system.adapter.simple-api'         │ 'simple-api'         │ '3.0.7'  │ 'none'         │
    │ 12      │ 'system.adapter.socketio'           │ 'socketio'           │ '7.1.3'  │ 'none'         │
    │ 13      │ 'system.adapter.tuya'               │ 'tuya'               │ '3.17.0' │ 'none'         │
    │ 14      │ 'system.adapter.unifi'              │ 'unifi'              │ '0.7.0'  │ 'none'         │
    │ 15      │ 'system.adapter.vis'                │ 'vis'                │ '1.5.6'  │ 'none'         │
    │ 16      │ 'system.adapter.vis-timeandweather' │ 'vis-timeandweather' │ '1.2.2'  │ 'none'         │
    │ 17      │ 'system.adapter.weatherunderground' │ 'weatherunderground' │ '3.7.0'  │ 'none'         │
    │ 18      │ 'system.adapter.web'                │ 'web'                │ '8.0.0'  │ 'none'         │
    │ 19      │ 'system.adapter.ws'                 │ 'ws'                 │ '4.1.0'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.2.2    , installed 7.2.2
    Adapter    "netatmo-crawler": 1.2.0  , installed 1.2.0
    Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
    Adapter    "senec"        : 2.5.3    , installed 2.5.3
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Objects and States
    Objects:        10806
    States:         8790
    Hit:1 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:3 https://apt.glennr.nl/repo trixie InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 https://deb.debian.org/debian trixie InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Get:7 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Hit:8 https://packages.adoptium.net/artifactory/deb trixie InRelease
    Hit:9 https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 InRelease
    Fetched 6922 B in 5s (1529 B/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    Netid State  Recv-Q Send-Q         Local Address:Port     Peer Address:PortProcess
    udp   UNCONN 0      0                    0.0.0.0:sunrpc        0.0.0.0:*    users:(("rpcbind",pid=554,fd=5),("systemd",pid=1,fd=77))
    udp   UNCONN 0      0                    0.0.0.0:6666          0.0.0.0:*    users:(("io.tuya.0",pid=1596,fd=45))
    udp   UNCONN 0      0                    0.0.0.0:6667          0.0.0.0:*    users:(("io.tuya.0",pid=1596,fd=46))
    udp   UNCONN 0      0                    0.0.0.0:mdns          0.0.0.0:*    users:(("avahi-daemon",pid=611,fd=12))
    udp   UNCONN 0      0                    0.0.0.0:55273         0.0.0.0:*    users:(("avahi-daemon",pid=611,fd=14))
    udp   UNCONN 0      0                          *:sunrpc              *:*    users:(("rpcbind",pid=554,fd=7),("systemd",pid=1,fd=79))
    udp   UNCONN 0      0      [::ffff:192.168.0.20]:56250               *:*    users:(("java",pid=1157,fd=207))
    udp   UNCONN 0      0                          *:mdns                *:*    users:(("avahi-daemon",pid=611,fd=13))
    udp   UNCONN 0      0                          *:5514                *:*    users:(("java",pid=1157,fd=204))
    udp   UNCONN 0      0                          *:3478                *:*    users:(("java",pid=1157,fd=180))
    udp   UNCONN 0      0                          *:10001               *:*    users:(("java",pid=1157,fd=208))
    udp   UNCONN 0      0                          *:51178               *:*    users:(("avahi-daemon",pid=611,fd=15))
    tcp   LISTEN 0      511                127.0.0.1:9001          0.0.0.0:*    users:(("iobroker.js-con",pid=1091,fd=23))
    tcp   LISTEN 0      511                127.0.0.1:9000          0.0.0.0:*    users:(("iobroker.js-con",pid=1091,fd=29))
    tcp   LISTEN 0      4096               127.0.0.1:27117         0.0.0.0:*    users:(("mongod",pid=1241,fd=9))
    tcp   LISTEN 0      4096               127.0.0.1:omniorb       0.0.0.0:*    users:(("influxd",pid=1090,fd=3))
    tcp   LISTEN 0      511                  0.0.0.0:41713         0.0.0.0:*    users:(("io.alexa2.0",pid=1573,fd=37))
    tcp   LISTEN 0      128                  0.0.0.0:ssh           0.0.0.0:*    users:(("sshd",pid=1122,fd=6))
    tcp   LISTEN 0      4096                 0.0.0.0:sunrpc        0.0.0.0:*    users:(("rpcbind",pid=554,fd=4),("systemd",pid=1,fd=76))
    tcp   LISTEN 0      511                        *:8082                *:*    users:(("io.web.0",pid=1731,fd=34))
    tcp   LISTEN 0      511                        *:tproxy              *:*    users:(("io.admin.0",pid=1499,fd=36))
    tcp   LISTEN 0      200                        *:http-alt            *:*    users:(("java",pid=1157,fd=163))
    tcp   LISTEN 0      4096                       *:8086                *:*    users:(("influxd",pid=1090,fd=199))
    tcp   LISTEN 0      1000                       *:28082               *:*    users:(("java",pid=1157,fd=179))
    tcp   LISTEN 0      4096                       *:3000                *:*    users:(("grafana",pid=1198,fd=26))
    tcp   LISTEN 0      1000                       *:8843                *:*    users:(("java",pid=1157,fd=190))
    tcp   LISTEN 0      50                         *:6789                *:*    users:(("java",pid=1157,fd=203))
    tcp   LISTEN 0      1000                       *:8880                *:*    users:(("java",pid=1157,fd=174))
    tcp   LISTEN 0      1000                       *:8443                *:*    users:(("java",pid=1157,fd=183))
    tcp   LISTEN 0      128                     [::]:ssh              [::]:*    users:(("sshd",pid=1122,fd=7))
    tcp   LISTEN 0      4096                    [::]:sunrpc           [::]:*    users:(("rpcbind",pid=554,fd=6),("systemd",pid=1,fd=78))
    2026-06-27 13:44:47.546  - warn: javascript.0 (1554)     at processImmediate (node:internal/timers:452:9)
    2026-06-27 13:44:47.546  - warn: javascript.0 (1554)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
    2026-06-27 13:44:47.546  - info: javascript.0 (1554) script.js.common.Senec.Grid_Power_Bezug_und_Einspeisung: Einspeisung addiert. Neue Summe: 5427.11 Wh
    2026-06-27 13:44:47.556  - info: javascript.0 (1554) State value to set for "0_userdata.0.Energie.Senec.Tages_Einspeisung_Wh" has to be type "number" but received type "string"
    2026-06-27 13:44:47.597  - info: javascript.0 (1554) State value to set for "0_userdata.0.Energie.Senec.Tages_Einspeisung_kWh" has to be type "number" but received type "string"
    2026-06-27 13:44:58.123  - info: javascript.0 (1554) script.js.common.Senec.Hausverbrauch: Aktuelle Leistung: 860.99 W, Zeitdiff: 10.68 s, Berechnete Energie: 2.56 Wh
    2026-06-27 13:44:58.134  - info: javascript.0 (1554) script.js.common.Senec.Grid_Power_Bezug_und_Einspeisung: Aktuelle Leistung: -5769.22 W, Zeitdiff: 10.68 s, Berechnete Energie: -17.12 Wh
    2026-06-27 13:44:58.137  - warn: javascript.0 (1554) You are assigning a string to the state "0_userdata.0.Energie.Senec.Tages_Hausverbrauch_Wh" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2026-06-27 13:44:58.140  - warn: javascript.0 (1554)     at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
    2026-06-27 13:44:58.141  - warn: javascript.0 (1554)     at Object.<anonymous> (script.js.common.Senec.Hausverbrauch:111:5)
    2026-06-27 13:44:58.141  - warn: javascript.0 (1554) You are assigning a string to the state "0_userdata.0.Energie.Senec.Tages_Hausverbrauch_kWh" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2026-06-27 13:44:58.143  - warn: javascript.0 (1554)     at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
    2026-06-27 13:44:58.143  - warn: javascript.0 (1554)     at Object.<anonymous> (script.js.common.Senec.Hausverbrauch:112:5)
    2026-06-27 13:44:58.144  - info: javascript.0 (1554) script.js.common.Senec.Hausverbrauch: Hausverbrauch addiert. Neue Summe: 7883.92 Wh (7.884 kWh)
    2026-06-27 13:44:58.155  - info: javascript.0 (1554) State value to set for "0_userdata.0.Energie.Senec.Tages_Hausverbrauch_Wh" has to be type "number" but received type "string"
    2026-06-27 13:44:58.160  - info: javascript.0 (1554) State value to set for "0_userdata.0.Energie.Senec.Tages_Hausverbrauch_kWh" has to be type "number" but received type "string"
    2026-06-27 13:44:58.209  - warn: javascript.0 (1554) You are assigning a string to the state "0_userdata.0.Energie.Senec.Tages_Einspeisung_Wh" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2026-06-27 13:44:58.210  - warn: javascript.0 (1554)     at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
    2026-06-27 13:44:58.210  - warn: javascript.0 (1554)     at Object.<anonymous> (script.js.common.Senec.Grid_Power_Bezug_und_Einspeisung:123:9)
    2026-06-27 13:44:58.211  - warn: javascript.0 (1554) You are assigning a string to the state "0_userdata.0.Energie.Senec.Tages_Einspeisung_kWh" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    2026-06-27 13:44:58.211  - warn: javascript.0 (1554)     at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
    2026-06-27 13:44:58.212  - warn: javascript.0 (1554)     at Object.<anonymous> (script.js.common.Senec.Grid_Power_Bezug_und_Einspeisung:124:9)
    2026-06-27 13:44:58.212  - info: javascript.0 (1554) script.js.common.Senec.Grid_Power_Bezug_und_Einspeisung: Einspeisung addiert. Neue Summe: 5444.23 Wh
    2026-06-27 13:44:58.217  - info: javascript.0 (1554) State value to set for "0_userdata.0.Energie.Senec.Tages_Einspeisung_Wh" has to be type "number" but received type "string"
    2026-06-27 13:44:58.257  - info: javascript.0 (1554) State value to set for "0_userdata.0.Energie.Senec.Tages_Einspeisung_kWh" has to be type "number" but received type "string"
    ============= Mark until here for C&P =============
    iob diag has finished.
    pi@Raspberry:~ $
    @DiMe
    Ja, das sieht besser aus
    apt policy mongodb
    apt policy influxdb
    sagen?
      DiMe
      schrieb am zuletzt editiert von DiMe
      pi@Raspberry:~ $ apt policy mongodb
      apt policy influxdb
      mongodb:
        Installed: (none)
        Candidate: (none)
        Version table:
      influxdb:
        Installed: 1.6.7~rc0-2+b12
        Candidate: 1.12.4-1
        Version table:
           1.12.4-1 500
              500 https://repos.influxdata.com/debian stable/main arm64 Packages
           1.12.3-1 500
           1.12.2-4 500
           1.12.2-3 500
           1.12.2-1 500
           1.11.8-2 500
           1.11.8-1 500
           1.11.7-1 500
           1.8.10-1 500
       *** 1.6.7~rc0-2+b12 500
      lines 1-23...skipping...
      influxdb:
        Candidate: 1.12.4-1
        Version table:
           1.12.4-1 500
           1.12.3-1 500
           1.12.2-4 500
           1.12.2-3 500
           1.12.2-1 500
           1.11.8-2 500
           1.11.8-1 500
           1.11.7-1 500
           1.8.10-1 500
      mongodb nicht installiert?
      • D DiMe
        apt policy influxdb
        mongodb:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb:
          Candidate: 1.12.4-1
          Version table:
             1.12.4-1 500
             1.12.3-1 500
             1.12.2-4 500
             1.12.2-3 500
             1.12.2-1 500
             1.11.8-2 500
             1.11.8-1 500
             1.11.7-1 500
             1.8.10-1 500
        influxdb:
          Candidate: 1.12.4-1
          Version table:
             1.12.4-1 500
             1.12.3-1 500
             1.12.2-4 500
             1.12.2-3 500
             1.12.2-1 500
             1.11.8-2 500
             1.11.8-1 500
             1.11.7-1 500
             1.8.10-1 500
        @DiMe sagte:
        Vermutlich hießt das Paket anders. Schau mal nach
        apt policy mongodb-org
        sudo apt update
        sudo apt full-upgrade
        sagt zu influxdb?
          DiMe
          pi@Raspberry:~ $ apt policy mongodb-org
          Notice: Unable to locate package mongodb-org
          pi@Raspberry:~ $ sudo apt update
          [sudo] password for pi:
          Hit:3 https://apt.grafana.com stable InRelease
          Hit:4 https://deb.debian.org/debian trixie InRelease
          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
          Hit:6 https://apt.glennr.nl/repo trixie InRelease
          Get:7 https://repos.influxdata.com/debian stable InRelease [6,922 B]
          Hit:8 https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 InRelease
          Get:9 https://packages.adoptium.net/artifactory/deb trixie InRelease [7,503 B]
          Fetched 14.4 kB in 1s (23.3 kB/s)
          1 package can be upgraded. Run 'apt list --upgradable' to see it.
          Notice: Skipping acquire of configured file 'main/binary-armhf/Packages' as repository 'https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 InRelease' doesn't support architecture 'armhf'
          The following packages were automatically installed and are no longer required:
            gyp             libjs-is-typedarray  libjs-sprintf-js
            libcares2       libjs-prettify       libjs-typedarray-to-buffer
            libjs-events    libjs-regenerate     libssl-dev
            libjs-inherits  libjs-source-map     libuv1-dev
          Use 'sudo apt autoremove' to remove them.
          Upgrading:
            influxdb
          Installing dependencies:
            influxdata-archive-keyring
          Summary:
            Upgrading: 1, Installing: 1, Removing: 0, Not Upgrading: 0
            Download size: 37.4 MB / 37.4 MB
            Space needed: 106 MB / 16.5 GB available
          Continue? [Y/n] y
          Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb arm64 1.12.4-1 [37.4 MB]
          Fetched 37.4 MB in 14s (2,703 kB/s)
          Reading changelogs... Done
          Selecting previously unselected package influxdata-archive-keyring.
          (Reading database ... 126586 files and directories currently installed.)
          Preparing to unpack .../influxdata-archive-keyring_2026.01.09_all.deb ...
          Unpacking influxdata-archive-keyring (2026.01.09) ...
          Preparing to unpack .../influxdb_1.12.4-1_arm64.deb ...
          Unpacking influxdb (1.12.4-1) over (1.6.7~rc0-2+b12) ...
          Setting up influxdb (1.12.4-1) ...
          Installing new version of config file /etc/influxdb/influxdb.conf ...
          Synchronizing state of influxdb.service with SysV service script with /usr/lib/systemd/systemd-sysv-install.
          Executing: /usr/lib/systemd/systemd-sysv-install enable influxdb
          Setting up influxdata-archive-keyring (2026.01.09) ...
          Processing triggers for man-db (2.13.1-1) ...
          • D DiMe
            Upgrading:
              influxdb
            Summary:
            Continue? [Y/n] y
            @DiMe
            sudo apt autoremove
            Dann nochmal ein
            sudo apt update
              DiMe
              i@Raspberry:~ $ sudo apt autoremove
              REMOVING:
              Summary:
                Upgrading: 0, Installing: 0, Removing: 12, Not Upgrading: 0
                Freed space: 19.9 MB
              Continue? [Y/n] y
              (Reading database ... 126612 files and directories currently installed.)
              Removing gyp (0.16.2-2) ...
              Removing libcares2:arm64 (1.34.5-1+deb13u1) ...
              Removing libjs-events (3.3.0+~3.0.0-3) ...
              Removing libjs-inherits (2.0.4-6) ...
              Removing libjs-is-typedarray (1.0.0-4) ...
              Removing libjs-prettify (2015.12.04+dfsg-1.1) ...
              Removing libjs-regenerate (1.4.2-3) ...
              Removing libjs-source-map (0.7.0++dfsg2+really.0.6.1-15) ...
              Removing libjs-sprintf-js (1.1.2+ds1+~1.1.2-1) ...
              Removing libjs-typedarray-to-buffer (4.0.0-2) ...
              Removing libssl-dev:arm64 (3.5.6-1~deb13u2+rpt1) ...
              Removing libuv1-dev:arm64 (1.50.0-2) ...
              Processing triggers for libc-bin (2.41-12+rpt1+deb13u3) ...
              Get:6 https://repos.influxdata.com/debian stable InRelease [6,922 B]
              Hit:7 https://apt.glennr.nl/repo trixie InRelease
              Fetched 14.4 kB in 1s (24.2 kB/s)
              All packages are up to date.
              Summary:
                Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
              • D DiMe
                REMOVING:
                Summary:
                Continue? [Y/n] y
                Summary:
                @DiMe
                Das mongodb-Repo scheint im Moment nicht richtig befüllt zu sein.
                Denn laut deren eigener Anleitung muss da ein Paket namens mongodb-org vorhanden sein, isses aber nicht:
                thomas@testpi:~ $ apt policy mongodb
                mongodb:
                  Installed: (none)
                  Candidate: (none)
                  Version table:
                thomas@testpi:~ $ apt policy mongodb-org
                thomas@testpi:~ $
                Keine Ahnung was da warum wie lange (noch) klemmt.
                BTW: Die Meldung
                kannst du abstellen, indem du die Datei /etc/apt/sources.list.d/mongodb-org-8.0.list so anpasst:
                deb [ arch=arm64 signed-by=/usr/share/keyrings/mongodb-server-8.0.gpg ] https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 main
                  @DiMe
                  mongodb:
                    Installed: (none)
                    Candidate: (none)
                    Version table:
                  thomas@testpi:~ $
                  BTW: Die Meldung
                  DiMe
                  @Thomas-Braun sagte:
                  Ah, wie ich sehe ist das auch so bei dir auf deinem Testpi
                   pi@Raspberry:~ $ deb [ arch=arm64 signed-by=/usr/share/keyrings/mongodb-server-8                                  .0.gpg ] https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 main
                  -bash: deb: command not found
                  pi@Raspberry:~ $ deb[ arch=arm64 signed-by=/usr/share/keyrings/mongodb-server-8.                                  0.gpg ] https://repo.mongodb.org/apt/debian trixie/mongodb-org/8.0 main
                  -bash: deb[ arch=arm64 signed-by=/usr/share/keyrings/mongodb-server-8.0.gpg ]: N                                  o such file or directory
                  Also beim genau kopieren kam, command not found
                  Habe in meiner Ahnungslosigkeit das Leerzeichen nach deb entfernt.
                  Dann kam Meldung das Datei nicht gefunden.
                  Die datei ist aber da:
                  pi@Raspberry:~ $ ls -lA /usr/share/keyrings
                  total 240
                  lrwxrwxrwx 1 root root    37 Apr 10  2025 debian-archive-bookworm-automatic.gpg -> debian-archive-bookworm-automat                                       ic.pgp
                  -rw-r--r-- 1 root root  8700 Apr 10  2025 debian-archive-bookworm-automatic.pgp
                  lrwxrwxrwx 1 root root    46 Apr 10  2025 debian-archive-bookworm-security-automatic.gpg -> debian-archive-bookwor                                       m-security-automatic.pgp
                  -rw-r--r-- 1 root root  8709 Apr 10  2025 debian-archive-bookworm-security-automatic.pgp
                  lrwxrwxrwx 1 root root    34 Apr 10  2025 debian-archive-bookworm-stable.gpg -> debian-archive-bookworm-stable.pgp
                  -rw-r--r-- 1 root root   280 Apr 10  2025 debian-archive-bookworm-stable.pgp
                  lrwxrwxrwx 1 root root    37 Apr 10  2025 debian-archive-bullseye-automatic.gpg -> debian-archive-bullseye-automat                                       ic.pgp
                  -rw-r--r-- 1 root root  8700 Apr 10  2025 debian-archive-bullseye-automatic.pgp
                  lrwxrwxrwx 1 root root    46 Apr 10  2025 debian-archive-bullseye-security-automatic.gpg -> debian-archive-bullsey                                       e-security-automatic.pgp
                  -rw-r--r-- 1 root root  8709 Apr 10  2025 debian-archive-bullseye-security-automatic.pgp
                  lrwxrwxrwx 1 root root    34 Apr 10  2025 debian-archive-bullseye-stable.gpg -> debian-archive-bullseye-stable.pgp
                  -rw-r--r-- 1 root root  2453 Apr 10  2025 debian-archive-bullseye-stable.pgp
                  lrwxrwxrwx 1 root root    26 Apr 10  2025 debian-archive-keyring.gpg -> debian-archive-keyring.pgp
                  -rw-r--r-- 1 root root 55918 Apr 10  2025 debian-archive-keyring.pgp
                  lrwxrwxrwx 1 root root    31 Apr 10  2025 debian-archive-removed-keys.gpg -> debian-archive-removed-keys.pgp
                  -rw-r--r-- 1 root root 72636 Apr 10  2025 debian-archive-removed-keys.pgp
                  lrwxrwxrwx 1 root root    35 Apr 10  2025 debian-archive-trixie-automatic.gpg -> debian-archive-trixie-automatic.p                                       gp
                  -rw-r--r-- 1 root root  8698 Apr 10  2025 debian-archive-trixie-automatic.pgp
                  lrwxrwxrwx 1 root root    44 Apr 10  2025 debian-archive-trixie-security-automatic.gpg -> debian-archive-trixie-se                                       curity-automatic.pgp
                  -rw-r--r-- 1 root root  8707 Apr 10  2025 debian-archive-trixie-security-automatic.pgp
                  lrwxrwxrwx 1 root root    32 Apr 10  2025 debian-archive-trixie-stable.gpg -> debian-archive-trixie-stable.pgp
                  -rw-r--r-- 1 root root   962 Apr 10  2025 debian-archive-trixie-stable.pgp
                  -rw-r--r-- 1 root root  2370 Jan  9 18:55 influxdata-archive_compat.gpg
                  -rw-r--r-- 1 root root  4516 Jan  9 18:55 influxdata-archive.gpg
                  -rw-r--r-- 1 root root  1178 Jun 27 13:40 mongodb-server-8.0.gpg
                  -rw-r--r-- 1 root root  1207 Jun 27 10:53 nodesource.gpg
                  lrwxrwxrwx 1 root root    33 Jun  6  2025 raspberrypi-archive-automatic.gpg -> raspberrypi-archive-automatic.pgp
                  -rw-r--r-- 1 root root  1229 Jun  6  2025 raspberrypi-archive-automatic.pgp
                  lrwxrwxrwx 1 root root    31 Jun  6  2025 raspberrypi-archive-keyring.gpg -> raspberrypi-archive-keyring.pgp
                  -rw-r--r-- 1 root root  1229 Jun  6  2025 raspberrypi-archive-keyring.pgp
                  • D DiMe
                    total 240
                    @DiMe sagte:
                    Das ist der Eintrag in der Datei
                    Diese musst du mit deinem bevorzugten Editor bearbeiten. Ich verwende meist nano dafür. Also per
                    sudo nano /etc/apt/sources.list.d/mongodb-org-8.0.list
                    anpassen. Speichern mit Strg-O, nano verlassen mit Strg-X.
                      DiMe
                      Done
                      Hit:3 https://deb.debian.org/debian trixie InRelease
                      Hit:4 https://apt.grafana.com stable InRelease
                      Get:6 https://apt.glennr.nl/repo trixie InRelease [28.2 kB]
                      Get:8 https://apt.glennr.nl/repo trixie/mongod/8.0 arm64 Packages [4,735 B]
                      Get:10 https://packages.adoptium.net/artifactory/deb trixie InRelease [7,503 B]
                      Fetched 47.4 kB in 1s (57.9 kB/s)
                      Upgrading:
                        mongod-armv8
                      Summary:
                        Upgrading: 1, Installing: 0, Removing: 0, Not Upgrading: 0
                        Download size: 23.5 MB
                        Space needed: 0 B / 16.4 GB available
                      Continue? [Y/n] y
                      Get:1 https://apt.glennr.nl/repo trixie/mongod/8.0 arm64 mongod-armv8 arm64 8.0.26 [23.5 MB]
                      Fetched 23.5 MB in 8s (2,871 kB/s)
                      (Reading database ... 126267 files and directories currently installed.)
                      Preparing to unpack .../mongod-armv8_8.0.26_arm64.deb ...
                      Unpacking mongod-armv8 (8.0.26) over (8.0.23) ...
                      Setting up mongod-armv8 (8.0.26) ...
                      mongodb:
                        Installed: (none)
                        Candidate: (none)
                        Version table:
                      • D DiMe
                        Done
                        Upgrading:
                          mongod-armv8
                        Summary:
                        Continue? [Y/n] y
                        mongodb:
                          Installed: (none)
                          Candidate: (none)
                          Version table:
                        @DiMe sagte:
                        mongod-armv8
                        Wo kommt denn das her? Finde ich auf meinem Test-System nicht.
                        apt policy mongod-armv8
                        mal anschauen.
                        BTW: Dir fehlt auch das trixie-updates Repo aus irgendeinem Grund.
                        Edit: Also aus diesem Repo kommt das:
                        Was beziehst du eigentlich von da?
                        • D DiMe
                          Done
                          Upgrading:
                            mongod-armv8
                          Summary:
                          Continue? [Y/n] y
                          mongodb:
                            Installed: (none)
                            Candidate: (none)
                            Version table:
                          @DiMe
                          Schau mal, wie die
                          /etc/apt/sources.list.d/debian.sources
                          bei dir aussieht. Da fehlt mit Sicherheit ein Eintrag. Siehe meine Version:
                          Types: deb
                          URIs: http://deb.debian.org/debian/
                          Suites: trixie trixie-updates
                          Components: main contrib non-free non-free-firmware
                          Signed-By: /usr/share/keyrings/debian-archive-keyring.pgp
                          Types: deb
                          URIs: http://deb.debian.org/debian-security/
                          Suites: trixie-security
                            DiMe
                            mongodb:
                              Installed: (none)
                              Candidate: (none)
                              Version table:
                            pi@Raspberry:~ $ ^C
                            pi@Raspberry:~ $ apt policy mongod-armv8
                            mongod-armv8:
                              Installed: 8.0.26
                              Candidate: 8.0.26
                              Version table:
                             *** 8.0.26 500
                                    500 https://apt.glennr.nl/repo trixie/mongod/8.0 arm64 Packages
                                 8.0.25 500
                                 8.0.24 500
                                 8.0.23 500
                                 8.0.21 500
                                 8.0.20 500
                                 8.0.19 500
                                 8.0.18 500
                                 8.0.17 500
                                 8.0.16 500
                                 8.0.15 500
                                 8.0.14 500
                                 8.0.13 500
                                 8.0.12 500
                                 8.0.11 500
                                 8.0.10 500
                                 8.0.9 500
                                 8.0.8 500
                                 8.0.7 500
                                 8.0.6 500
                                 8.0.5 500
                                 8.0.4 500
                                 8.0.3 500
                            Das andere ist von meinem Unificontroller
                              DiMe
                              Der Eintrag vom Debian.source
                              # Types: deb
                              # URIs: http://deb.debian.org/debian/
                              # Suites: trixie trixie-updates
                              # Components: main contrib non-free non-free-firmware
                              # Signed-By: /usr/share/keyrings/debian-archive-keyring.pgp
                              Types: deb
                              P.S. muss dann weg. Erstmal vielen Dank Thomas!
