  3. Einsteigerfragen
  4. Installation
  5. Umzug von Bullseye auf Trixie, Probleme mit Backup
58 Beiträge 5 Kommentatoren 2.6k Aufrufe 5 Beobachtet
    DiMe
    schrieb am zuletzt editiert von DiMe
    Hallo Thomas.
    Meinst du das?
    pi@raspberrypi:~ $ pi@raspberrypi:~ $ sudo apt update
    Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [39.0 kB]
    Ign:3 http://archive.raspbian.org/raspbian stretch InRelease
    Err:4 http://archive.raspbian.org/raspbian stretch Release
      404  Not Found [IP: 2a00:1098:0:80:1000:75:0:2 80]
    Get:5 https://packages.grafana.com/oss/deb stable InRelease [7,661 B]
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Get:7 https://repos.influxdata.com/debian stretch InRelease [12.9 kB]
    Get:8 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [330 kB                                          ]
    Err:5 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not av                                          ailable: NO_PUBKEY 963FA27710458545
    Err:7 https://repos.influxdata.com/debian stretch InRelease
      The following signatures couldn't be verified because the public key is not av                                          ailable: NO_PUBKEY DA61C26A0585BD3B
    Reading package lists... Done
    E: The repository 'http://archive.raspbian.org/raspbian stretch Release' no long                                          er has a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disa                                          bled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration deta                                          ils.
    W: An error occurred during the signature verification. The repository is not up                                          dated and the previous index files will be used. GPG error: https://packages.gra                                          fana.com/oss/deb stable InRelease: The following signatures couldn't be verified                                           because the public key is not available: NO_PUBKEY 963FA27710458545
    W: GPG error: https://repos.influxdata.com/debian stretch InRelease: The followi                                          ng signatures couldn't be verified because the public key is not available: NO_P                                          UBKEY DA61C26A0585BD3B
    E: The repository 'https://repos.influxdata.com/debian stretch InRelease' is not                                           signed.
    • D DiMe
      Hallo Thomas.
      Meinst du das?
      @DiMe
      Genau so ein Chaos hatte ich vermutet.
      Und was sagt ein
      iob diag
      dazu?
        DiMe
        Ich habe letzte Woche als ich den neuen Senec Adapter installiert habe.
        Bereits iob fix ausgeführt. Hier die aktuelle iob diag
        ```bash
        Script v.2026-06-06
        *** BASE SYSTEM ***
        Operating System: Raspbian GNU/Linux 11 (bullseye)
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.1.21-v7l+
              Architecture: arm
        OS is similar to: debian
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Unknown
        Kernel          : armv7l
        Userland        : 32bit
        System was installed 1697 days ago (on 2021-10-30).
        Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
        Systemuptime and Load:
         19:24:59 up  1:39,  1 user,  load average: 5.00, 2.75, 1.28
        CPU threads     : 4
        *** LIFE CYCLE STATUS ***
        ERROR: Package 'distro-info' is not installed. Please do:
        sudo apt update && sudo apt install distro-info
        Alternatively execute the 'iob fix'
        • D DiMe
          ```bash
          Script v.2026-06-06
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Unknown
          Kernel          : armv7l
          Userland        : 32bit
          CPU threads     : 4
          @DiMe sagte:
          Kernel : armv7l
          Userland : 32bit
          Das System NEUINSTALLIEREN.
          In der 64Bit-Lite-Version.
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            DiMe
            Hi Thomas, das mache ich ja gerade. Ich habe eben Probleme mit dem Einspielen des Backups.
            Habe ja bereits alles installiert. Und jetzt möchte ich eben die Backups implemenieren
            • D DiMe
              @DiMe
              Da dürfte dir deine verkorkste Quellensammlung in die Suppe spucken.
              Weder influx noch grafana können darüber aktuell gehalten werden. Und die Versionen dürften mittlerweile zu weit auseinanderliegen.
                @DiMe
                DiMe
                @Thomas-Braun sagte:
                Das befürchte ich auch, deshalb habe ich die einzelnen Dashboards heruntergeladen.
                Jetzt bin ich auf die Influx gespannt.
                  DiMe
                  Hallo, ich wieder.
                  Habe jetzt schon mehrere Tage versucht meine Influxdb mit dem iobroker zu Verbinden. Mir fehlt aber immer "Verbunden mit Gerät oder Dienst" im Adapter.
                  Zuerst habe ich mein Influx und Iobroker backup zurück geholt (Backitup). iobroker hat eigentlich keine Probleme gemacht, das Influx Backup hat mir im Logger keine Fehler gebracht und mitgeteil succesfull. Konnte es bis jetzt aber nicht überprüfen ob die Daten wirklich vorhanden sind. Das ist eigentlich mein zweites Problem. Aber jetzt erstmal zur Verbindung.
                  Ich habe jetzt die Sache mal so probiert, wie wenn ich es komplett neu installiert hätte, d.h. ich hole mir kein Backup her, sondern versuch einfach mit der nackten Installation (Habe ja ein Image in dem iobroker und Influx frisch installiert wurden) also influx setup durchgeführt:
                  pi@Raspberry:~ $ influx setup
                  > Welcome to InfluxDB 2.0!
                  ? Please type your primary username admin
                  ? Please type your password ************
                  ? Please type your password again ************
                  ? Please type your primary organization name DM
                  ? Please type your primary bucket name iobroker
                  ? Please type your retention period in hours, or 0 for infinite 0
                  ? Setup with these parameters?
                    Username:          admin
                    Organization:      DM
                    Bucket:            iobroker
                    Retention Period:  infinite
                   Yes
                  User    Organization    Bucket
                  admin   DM              iobroker
                  Jetzt im iobroker den Infuxadapter runtergeladen und eingerichtet:
                  Beim Verbindungstest dies hier:
                  "Error: {"code":"unauthorized","message":"Unauthorized"}"
                  Und im Adapter wird wie bereits beschrieben das hier gemeldet:
                  Name und Passwort passen, ich find es einfach nicht. Bin gerade am verzweifeln da dies ja eigentlich ohne Probleme zu bewerkstelligen sein sollte, ich meine damals habe ich es ja hin bekommen.
                  • D DiMe
                    Hallo, ich wieder.
                      Username:          admin
                      Organization:      DM
                      Bucket:            iobroker
                     Yes
                    admin   DM              iobroker
                    @DiMe
                    Bist du wirklich noch mit influxdb 1.x unterwegs?
                      DiMe
                      Hallo Thomas,
                      ja, habe damals die 1.x auch benutzt. mit der 2er kann man anscheindend noch mehr. Mein Backup basiert ja auch auf der 1. und ich weis nicht ob ich das von der 1 zur 2 emigrieren kann. Wenn es natürlich sinnvoller wäre die 2.x zu benutzen und ihr sagt das (ich bin in diesem Thema leider noch so versiert und bewundere euch wie ihr immer die Befehle raushaut), werde ich die 2er nehmen. Mittlerweile wird mir meinBackup der Influx immer egaler, will einfach nur wieder Grafan mit meinem Senec und andere Sachen wieder angezeigt haben.
                      • D DiMe
                        Hallo Thomas,
                        @DiMe
                        Mir ist immer noch nicht klar, wie groß da jeweils die Versionssprünge sind.
                        influx hat im Altsystem? Und im neuen System?
                        Gleiches für Grafana und was da sonst noch installiert ist.
                          @DiMe
                          Meister MopperM Online
                          Meister Mopper
                          schrieb am zuletzt editiert von Meister Mopper
                          @DiMe
                          Warum nicht, damit kann man bei InfluxQl bleiben, ohne auf die jungfräuliche 3er-Version schwenken zu müssen. Bis diese soweit ist, kann man auch die 1.x aus meiner Sicht weiter nutzen.
                          Der Wechsel auf InfluxDB2 (ich habe ihn gemacht) bedeutet ja, dass alle Queries auf Flux überarbeitet werden müssen.
                          Ich bleibe jetzt erstmal bei v2.x und finde nebenbei die Entwicklungsstrategie von InfluxDB gelinde gesagt fragwürdig.
                          Proxmox und HA ...
                          Thomas BraunT fuzzy1955F 2 Antworten Letzte Antwort
                            @DiMe
                            @Meister-Mopper
                            Mir geht es primär um Versionssprünge ,da ein Backup einer influxdb1 mit Sicherheit nicht ohne Klimmzüge in eine influxdb2 geladen werden kann
                              @Meister-Mopper
                              Meister Mopper
                              @Meister-Mopper
                              Na ja, das habe ich auch mit schwachen Armen geschafft, es gibt ja entsprechende Anleitungen im Netz. Wenn ich mich richtig erinnere sogar hier im Forum.
                              Proxmox und HA ...
                              • D DiMe
                                Hallo, ich wieder.
                                  Username:          admin
                                  Organization:      DM
                                  Bucket:            iobroker
                                 Yes
                                admin   DM              iobroker
                                @DiMe sagte:
                                Aber in deinem Screenshot steht DB-Version 1.x.
                                Kann also nicht passen.
                                  DiMe
                                  Ja da gebe ich dir absolut recht 🤦 , danke Thomas.
                                  Habe im Influx ein Token erstellt , und habe im iobroker auf 2.x umgestellt.
                                  jetzt habe ich Verbindung.
                                  Jetzt nur mal zum Verständnis. Ich habe die 2.x installiert. Früher hatte ich dann wohl nur 1.x
                                  Ich bin immer davon ausgegangen das allein die Datenbank entweder 1.x oder 2.x.
                                  Da ich 2.x von Influx jetzt drauf habe, kann ich wohl keine 1.x Datenbank laufen lassen.
                                  Also habe ich mal gegoogle wie ich mein backup von 1.x auf eine 2.x hochjagen kann.
                                  Bin dabei auf eine Video von
                                  "EddyD's SmartHome", ich weis jetzt nicht ob ich ein Youtube link posten darf.
                                  Das Video ist zwar von 2022 aber ich werde es mal damit probieren.
                                  Falls ihr eine andere Idee habe, gebt mir gerne Bescheid.
                                  Eine andere Alternative wäre natürlich das ich die 2er deinstalliere und die 1.8 draufmache
                                  • D DiMe
                                    @DiMe
                                    Du kannst ja auch influxdb1 installieren.
                                    Jedenfalls, wenn du da das passende Repo am Start hast.
                                    echad@chet:~ $ apt policy influxdb
                                    influxdb:
                                      Installiert:           (keine)
                                      Installationskandidat: 1.12.4-1
                                      Versionstabelle:
                                         1.12.4-1 500
                                            500 https://repos.influxdata.com/debian stable/main arm64 Packages
                                         1.12.3-1 500
                                         1.12.2-4 500
                                         1.12.2-3 500
                                         1.12.2-1 500
                                         1.11.8-2 500
                                         1.11.8-1 500
                                         1.11.7-1 500
                                         1.8.10-1 500
                                         1.6.7~rc0-2+b12 500
                                            500 http://deb.debian.org/debian trixie/main arm64 Packages
                                    echad@chet:~ $
                                      DiMe
                                      Die letzte Version ist die 1.12? dachte die 1.8. Okay?
                                      Also deinstalliere ich die 2.x
                                      Auch dazu eine Frage, da ich jetzt oft gelesen habe das es Probleme beim deinstallieren gab bin ich über folgende Programmzeilen in diesem Forum (ich meine) gestoßen:
                                      sudo service influxdb stop
                                      sudo apt remove influxdb
                                      sudo apt remove influxdb-client
                                      sudo apt remove influxdb2
                                      sudo apt autoclean && sudo apt autoremove
                                      sudo rm -rf /var/lib/influxdb/
                                      sudo rm -rf /var/log/influxdb/
                                      sudo rm -rf /etc/influxdb/
                                      sudo rm -rf ~/.influxdbv2/configs
                                      Und die KI sagt mir eine 1.8 würde so installiert:
                                      1. System aktualisieren
                                      sudo apt update && sudo apt upgrade -y
                                      2. Repository-Schlüssel hinzufügen
                                      wget -qO- https://repos.influxdata.com/influxdb.key | gpg --dearmor | sudo tee /usr/share/keyrings/influx-archive-keyring.gpg >/dev/null
                                      3. Paketquelle für InfluxDB einrichten
                                      echo "deb [signed-by=/usr/share/keyrings/influx-archive-keyring.gpg] https://repos.influxdata.com/debian $(lsb_release -cs) stable" | sudo tee /etc/apt/sources.list.d/influxdb.list
                                      4. Paketlisten aktualisieren und InfluxDB installieren
                                      sudo apt update && sudo apt install -y influxdb
                                      5. Dienst starten und Autostart aktivieren
                                      sudo systemctl unmask influxdb.service
                                      sudo systemctl start influxdb
                                      sudo systemctl enable influxdb.service
                                      6. Installation prüfen
                                      sudo systemctl status influxdb
                                      • D DiMe
                                        @DiMe
                                        Immer diese KIs...
                                        https://docs.influxdata.com/influxdb3/core/install/#linux-deb-or-rpm
                                        Also:
                                        curl --silent --location -O https://repos.influxdata.com/influxdata-archive.key
                                        gpg --show-keys --with-fingerprint --with-colons ./influxdata-archive.key 2>&1 \
                                        | grep -q '^fpr:\+24C975CBA61A024EE1B631787C3D57159FC2F927:$' \
                                        && cat influxdata-archive.key \
                                        | gpg --dearmor \
                                        | sudo tee /usr/share/keyrings/influxdata-archive.gpg > /dev/null \
                                        && echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive.gpg] https://repos.influxdata.com/debian stable main' \
                                        | sudo tee /etc/apt/sources.list.d/influxdata.list
                                        sudo apt-get update
                                        Und man frickelt auch nicht so im Dateibaum herum....
                                          DiMe
                                          Immer diese KIs...
                                          Aber das ist doch die DB3?
                                          Muss doch erst noch die 2.x deinstallieren
