  4. iobroker startet nicht
    6.3k
32 Beiträge 4 Kommentatoren 733 Aufrufe 2 Beobachtet
  • I Offline
    I Offline
    IbizaGT
    Halle in die Runde,
    ich bin ratlos weil mein iobroker nicht mehr funktioniert.
    Kann mir jemand einen Tipp geben?
    Bin leider nicht so der Experte aber das Thema Smarthome finde ich total spannend.
    login as: pi
    pi@192.168.2.46's password:
    Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
    permitted by applicable law.
    Last login: Sat Jun 20 08:56:12 2026 from 192.168.2.20
    pi@raspberrypi:~ $ iobroker status
    sudo: node: command not found
    pi@raspberrypi:~ $ iobroker fix
    library: loaded
    Library version=2026-04-11
        Welcome to the ioBroker installation fixer!
        Script version: 2025-09-18
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Reading package lists... Done
    E: Unable to locate package polkitd
    Installed polkitd
    readlink: missing operand
    Try 'readlink --help' for more information.
    Failed to set capabilities on file `' (No such file or directory)
    The value of the capability argument is not permitted for a file. Or the file is not a regular (non-symlink) file
        Checking ioBroker user and directory permissions (2/5)
    ACL enabled: true
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    usage: sudo -h | -K | -k | -V
    usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
    usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
                [command]
    usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                [-h host] [-p prompt] [-R directory] [-T timeout] [-u user]
                [VAR=value] [-i|-s] [<command>]
    usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
    /home/iobroker/.fix.sh: line 14: [: -lt: unary operator expected
    sudo: npm: command not found
        Checking autostart (5/5)
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
    Authentication is required to stop 'iobroker.service'.
    Authenticating as: ,,, (pi)
    Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $ ^C
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $
    • I IbizaGT
      Halle in die Runde,
      login as: pi
      library: loaded
      Installed polkitd
      ACL enabled: true
      Done.
                  [command]
      Autostart enabled!
      pi@raspberrypi:~ $
      haselchenH Offline
      haselchenH Offline
      haselchen
      @IbizaGT
      Dein Bullseye (Debian Version) ist seit 2 Jahren EOL.
      Installier ein aktuelles OS.
      • I Offline
        I Offline
        IbizaGT
        das sollte doch über die Konsole mit
        sudo apt update
        funktionieren oder?
        • I Offline
          I Offline
          IbizaGT
          es passiert dann aber das...
          pi@raspberrypi:~ $ sudo apt update
          All packages are up to date.
          pi@raspberrypi:~ $ sudo apt full-upgrade
          Calculating upgrade... Done
          The following packages were automatically installed and are no longer required:
            gyp libauthen-sasl-perl libc-ares2 libclone-perl libdata-dump-perl
            libdrm-amdgpu1 libdrm-nouveau2 libdrm-radeon1 libencode-locale-perl
            libfile-basedir-perl libfile-desktopentry-perl libfile-listing-perl
            libfile-mimeinfo-perl libfont-afm-perl libfontenc1 libgl1 libgl1-mesa-dri
            libglapi-mesa libglvnd0 libglx-mesa0 libglx0 libhtml-form-perl
            libhtml-format-perl libhtml-parser-perl libhtml-tagset-perl
            libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl
            libhttp-message-perl libhttp-negotiate-perl libio-html-perl
            libio-socket-ssl-perl libio-stringy-perl libipc-system-simple-perl
            libjs-highlight.js libjs-inherits libjs-is-typedarray libjs-psl
            libjs-typedarray-to-buffer libllvm11 liblwp-mediatypes-perl
            liblwp-protocol-https-perl libmailtools-perl libnet-dbus-perl
            libnet-http-perl libnet-smtp-ssl-perl libnet-ssleay-perl libsensors-config
            libsensors5 libssl-dev libtie-ixhash-perl libtimedate-perl libtry-tiny-perl
            liburi-perl libuv1-dev libvulkan1 libwayland-client0 libwww-perl
            libwww-robotrules-perl libx11-protocol-perl libx11-xcb1 libxaw7
            libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-randr0
            libxcb-shape0 libxcb-sync1 libxcb-xfixes0 libxcomposite1 libxcursor1
            libxdamage1 libxfixes3 libxi6 libxinerama1 libxkbfile1 libxml-parser-perl
            libxml-twig-perl libxml-xpathengine-perl libxmu6 libxrandr2 libxshmfence1
            libxt6 libxtst6 libxv1 libxxf86dga1 libxxf86vm1 libz3-4 mesa-vulkan-drivers
            perl-openssl-defaults x11-utils x11-xserver-utils xdg-utils
          Use 'sudo apt autoremove' to remove them.
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          pi@raspberrypi:~ $
          • I IbizaGT
            pi@raspberrypi:~ $
            @IbizaGT
            sudo apt update && sudo apt full-upgrade && sudo reboot
            Und dann
            iob diag
            anschauen.
            Das ganze Ding wirst du aber vermutlich besser neu aufsetzen, dann OHNE den Desktop-Krempel.
            • I Offline
              I Offline
              IbizaGT
              geht das neu aufsetzen ohne das ich den iobroker komplett neu machen muss?
              • I IbizaGT
                @IbizaGT sagte:
                Dafür hast du ja ein Backup.
                • I Offline
                  I Offline
                  IbizaGT
                  das Backup habe ich leider nicht
                  also komme ich an die alten Sachen nicht mehr dran?
                  • I Offline
                    I Offline
                    IbizaGT
                    Script v.2026-06-01
                    *** BASE SYSTEM ***
                    Operating System: Raspbian GNU/Linux 11 (bullseye)
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.1.21-v8+
                          Architecture: arm64
                    OS is similar to: debian
                    Model           : Raspberry Pi 4 Model B Rev 1.1
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 32bit
                    System was installed 1693 days ago (on 2021-10-30).
                    Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
                    Systemuptime and Load:
                     10:09:08 up 1 min,  1 user,  load average: 0.37, 0.30, 0.12
                    CPU threads     : 4
                    *** LIFE CYCLE STATUS ***
                    ERROR: Package 'distro-info' is not installed. Please do:
                    sudo apt update && sudo apt install distro-info
                    Alternatively execute the 'iob fix'
                    pi@raspberrypi:~ $
                    • I IbizaGT
                      @IbizaGT sagte:
                      Warum nicht????
                      Wichtigstes Ding überhaupt.
                      iob diag
                      sagt nun? Dir fehlt nodejs, bzw war/ist das falsch installiert.
                      • I IbizaGT
                        Script v.2026-06-01
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 32bit
                        CPU threads     : 4
                        pi@raspberrypi:~ $
                        @IbizaGT sagte:
                        Userland : 32bit
                        Damit MUSST du das neuinstallieren. Diesmal dann in der 64Bit-Lite-Version.
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                        • I Offline
                          I Offline
                          IbizaGT
                          ich wollte das mal alles auf aktuellen Stand bringen und wollte nodejs, npm aktualisieren aber dabei ist irgendwas schief gegangen und das Backup vorher habe ich vergessen.
                          • I IbizaGT
                            @IbizaGT
                            I 1 Antwort Letzte Antwort
                              @IbizaGT
                              I Offline
                              I Offline
                              IbizaGT
                              @Thomas-Braun
                              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              pi@raspberrypi:~ $ sudo apt install distro-info
                              distro-info is already the newest version (1.0+deb11u1).
                              pi@raspberrypi:~ $
                              • I IbizaGT
                                @Thomas-Braun
                                pi@raspberrypi:~ $
                                @IbizaGT
                                sudo apt autoremove
                                iob nodejs-update 22
                                Rückfragen mit y bestätigen.
                                Und bitte für Texte aus der Konsole die CodeTags </> verwenden.
                                • I Offline
                                  I Offline
                                  IbizaGT
                                  ioBroker nodejs fixer 2026-03-05
                                  You requested to install latest version from nodejs v22 tree.
                                  Your current setup is:
                                  /home/iobroker/.nodejs-update.sh: line 214: node: command not found
                                  /home/iobroker/.nodejs-update.sh: line 215: npm: command not found
                                  /home/iobroker/.nodejs-update.sh: line 216: npx: command not found
                                  /home/iobroker/.nodejs-update.sh: line 227: node: command not found
                                  /home/iobroker/.nodejs-update.sh: line 228: npm: command not found
                                  /home/iobroker/.nodejs-update.sh: line 229: npx: command not found
                                  *** nodejs is NOT correctly installed ***
                                  We found these nodejs versions available for installation:
                                  nodejs:
                                    Installed: (none)
                                    Candidate: 12.22.12~dfsg-1~deb11u8
                                    Version table:
                                       12.22.12~dfsg-1~deb11u8 500
                                  Your nodejs-Installation seems to be faulty. Shall we try to fix it?
                                  Press <y> to continue or any other key to quit
                                  Fixing your nodejs setup
                                  *** Deleting  ***
                                  *** Deleting  ***
                                  *** Deleting  ***
                                  Wrong paths have been fixed. Run 'iob diag' or 'iob nodejs-update' again to check if your installation is fine now
                                  /home/iobroker/.nodejs-update.sh: line 317: node: command not found
                                  You are missing the nodesource repo file or
                                  you want to change your current nodejs version:  ?
                                  Trying to fix your installation now. Please be patient.
                                  You are running nodejs . Do you want to install latest version from nodejs v.22 tree?
                                  rm: cannot remove '': No such file or directory
                                  Stopping ioBroker now
                                  ioBroker has been stopped
                                  Removing any previously installed nodejs version
                                  *** The following repos are active on your system:
                                  *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                                  *** Creating new /etc/apt/sources.list.d/nodesource.sources and pinning source
                                  /home/iobroker/.nodejs-update.sh: line 87: log: command not found
                                  pi@raspberrypi:~ $
                                  • I IbizaGT
                                    nodejs:
                                      Installed: (none)
                                      Version table:
                                    *** Deleting  ***
                                    *** Deleting  ***
                                    *** Deleting  ***
                                    pi@raspberrypi:~ $
                                    @IbizaGT
                                    Alles komplett veraltet und falsch installiert...
                                    sudo apt update && apt policy nodejs
                                    sagt?
                                      @IbizaGT
                                      sagt?
                                      I Offline
                                      I Offline
                                      IbizaGT
                                      @Thomas-Braun
                                      pi@raspberrypi:~ $ apt policy nodejs
                                      nodejs:
                                       Installed: (none)
                                       Version table:
                                      pi@raspberrypi:~ $
                                      • I IbizaGT
                                        @Thomas-Braun
                                        nodejs:
                                         Installed: (none)
                                         Version table:
                                        pi@raspberrypi:~ $
                                        @IbizaGT wo kommt die uralte dfsg version her?
                                        • I IbizaGT
                                          @Thomas-Braun
                                          nodejs:
                                           Installed: (none)
                                           Version table:
                                          pi@raspberrypi:~ $
                                          @IbizaGT
                                          sudo apt-get install -y curl
                                          curl -fsSL https://deb.nodesource.com/setup_22.x | sudo -E bash -
                                          sudo apt-get install -y nodejs
                                          node -v
