  4. Log error admin.0 empty Object
    6.3k
12 Beiträge 3 Kommentatoren 303 Aufrufe 3 Beobachtet
  • R rewenode
    Mein iobroker (docker) läuft scheinbar ohne Auffälligkeiten. Allerdings bekomme ich vermehrt folgenden Fehler im Log:
    admin.0
    2026-06-18 07:50:12.515	error	empty object!
    admin.0
    admin.0
    2026-06-18 07:39:29.153	info	<== Disconnect system.user.admin from ::ffff:192.168.65.1 admin
    Im ioBroker container Log sehe ich :
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    ================================== > LOG REDIRECT system.adapter.admin.0 => true [system.adapter.admin.0.logging]
    (node:24568) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
    (Use `node --trace-warnings ...` to show where the warning was created)
    Die Fehler treten häufig auf (siehe Ausgabe iob diag)
    Leider habe ich das erst jetzt bemerkt. Kann also nicht sagen, ob es mit dem letzen admin Adapter Update zusammenhängt.
    iob diag Ausgabe:
    Script v.2026-06-01
    *** BASE SYSTEM ***cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
    Hardware Vendor :
    Kernel          : aarch64
    Userland        : 64bit
    Docker          : v11.1.0
    Virtualization  : Docker
    Kernel          : aarch64
    Userland        : 64bit
    System was installed 66 days ago (on 2026-04-12).
    Systemuptime and Load:
     11:03:29 up 6 days, 21:53,  0 user,  load average: 1.71, 1.69, 1.75
    CPU threads     : 10
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
    Thu Jun 18 09:03:29 UTC 2026
    Thu Jun 18 11:03:29 CEST 2026
    CEST +0200
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         Unknown
    Display-Manager:        System has not been booted with systemd as init system (PID 1). Can't operate.
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            8.3G        4.6G        1.5G        110K        2.2G        3.7G
    Swap:           2.1G         44M        2.1G
    Total:           10G        4.6G        3.6G
    Active iob-Instances:   23
             7936 M total memory
             4381 M used memory
             3194 M active memory
             2442 M inactive memory
             1436 M free memory
               44 M buffer memory
             2078 M swap cache
             2047 M total swap
               42 M used swap
             2005 M free swap
    top - 11:03:29 up 6 days, 21:53,  0 user,  load average: 1.71, 1.69, 1.75
    Tasks:  31 total,   1 running,  30 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7936.0 total,   1436.2 free,   4381.6 used,   2123.0 buff/cache
    MiB Swap:   2048.0 total,   2005.6 free,     42.4 used.   3554.5 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem           Type       Size  Used Avail Use% Mounted on
    overlay              overlay    224G   40G  173G  19% /
    tmpfs                tmpfs       64M     0   64M   0% /dev
    shm                  tmpfs       64M     0   64M   0% /dev/shm
    /run/host_mark/Users fakeowner  229G  171G   58G  75% /scripte
    /dev/vda1            ext4       224G   40G  173G  19% /etc/hosts
    Messages concerning filesystems in dmesg:
    [Thu Jun 11 13:09:54 2026] SGI XFS with security attributes, no debug enabled
    [Thu Jun 11 13:09:54 2026] Btrfs loaded, zoned=no, fsverity=no
    [Thu Jun 11 13:09:56 2026] EXT4-fs (vda1): mounted filesystem be3ffe22-e957-41b9-93f5-79edcb4279ef r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE        FSTYPE    OPTIONS
    /scripte         /run/host_mark/Users[/reiner/docker_iob/iob_scripte]                                                       fakeowner rw,nosuid,nodev,relatime,fakeowner
    /opt/iobroker    /run/host_mark/Users[/reiner/docker_iob/iobroker]                                                          fakeowner rw,nosuid,nodev,relatime,fakeowner
    /etc/resolv.conf /dev/vda1[/docker/containers/9753616e2adf9c56084433407f37c97a38c2a50410a358993ca5d32d2c575b68/resolv.conf] ext4      rw,relatime,discard
    /etc/hostname    /dev/vda1[/docker/containers/9753616e2adf9c56084433407f37c97a38c2a50410a358993ca5d32d2c575b68/hostname]    ext4      rw,relatime,discard
    /etc/hosts       /dev/vda1[/docker/containers/9753616e2adf9c56084433407f37c97a38c2a50410a358993ca5d32d2c575b68/hosts]       ext4      rw,relatime,discard
    /var:
    35M     /var/
    33M     /var/lib
    19M     /var/lib/apt/lists
    19M     /var/lib/apt
    14M     /var/lib/dpkg
    /opt/iobroker/backups:
    1.2G    /opt/iobroker/backups/
    0       /opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    842M    /opt/iobroker/iobroker-data/
    540M    /opt/iobroker/iobroker-data/files
    367M    /opt/iobroker/iobroker-data/files/javascript.admin
    350M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    349M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    9.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.f6fd0e72.chunk.js.map
    9.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0ffea560.chunk.js.map
    9.3M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.b6edad9e.chunk.js.map
    9.2M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.b4411182.chunk.js.map
    9.2M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.30c08d07.chunk.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    tcp
    ⚠ HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'.
    /dev/ttyUSB0
    Zigbee Network Settings on your coordinator / in nvbackup are:
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    === ZigBee Port Overview ===
    Instance        Configured Port                     Available by-id Port                Status
    zigbee.0        tcp://192.168.99.177:6638           -                                   tcp
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.3-1nodesource1
      Version table:
         22.22.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
     *** 22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u2 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    No known Vulnerabilities detected!
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Hosts:
    iobroker            iobroker (version: 7.1.2, hostname: iobroker      , alive, uptime: 42700)
    Core adapters versions
    js-controller:  7.1.2
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     2
    | `-- bluelinky@10.0.0 invalid: "https://github.com/arteck/bluelinky/tarball/d8a3344dad06cafbbc5b83b04c17073fd7798201" from node_modules/iobroker.bluelink
    |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
      system.adapter.autodoc.0                : autodoc               : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bluelink.0               : bluelink              : iobroker                                 -  enabled
      system.adapter.bring.0                  : bring                 : iobroker                                 - disabled
    + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      system.adapter.js2fs.0                  : js2fs                 : iobroker                                 - disabled
      system.adapter.kecontact.0              : kecontact             : iobroker                                 - disabled
      system.adapter.modbus.0                 : modbus                : iobroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      system.adapter.simple-api.0             : simple-api            : iobroker                                 - disabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      system.adapter.webcal.0                 : webcal                : iobroker                                 - disabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.99.177:6638
      system.adapter.zigbee.1                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    │ (index) │ id                               │ name              │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'           │ 'admin'           │ '7.8.23' │ 'none'         │
    │ 1       │ 'system.adapter.alexa2'          │ 'alexa2'          │ '3.27.4' │ 'none'         │
    │ 2       │ 'system.adapter.alias-manager'   │ 'alias-manager'   │ '2.1.0'  │ 'none'         │
    │ 3       │ 'system.adapter.autodoc'         │ 'autodoc'         │ '0.9.20' │ 'none'         │
    │ 4       │ 'system.adapter.backitup'        │ 'backitup'        │ '3.3.17' │ 'none'         │
    │ 5       │ 'system.adapter.bluelink'        │ 'bluelink'        │ '3.1.28' │ 'none'         │
    │ 6       │ 'system.adapter.bring'           │ 'bring'           │ '1.8.4'  │ 'none'         │
    │ 7       │ 'system.adapter.device-reminder' │ 'device-reminder' │ '3.1.2'  │ 'none'         │
    │ 8       │ 'system.adapter.discovery'       │ 'discovery'       │ '5.0.0'  │ 'none'         │
    │ 9       │ 'system.adapter.email'           │ 'email'           │ '2.0.4'  │ 'none'         │
    │ 10      │ 'system.adapter.hm-rega'         │ 'hm-rega'         │ '5.1.0'  │ 'none'         │
    │ 11      │ 'system.adapter.hm-rpc'          │ 'hm-rpc'          │ '3.0.1'  │ 'none'         │
    │ 12      │ 'system.adapter.influxdb'        │ 'influxdb'        │ '4.0.2'  │ 'none'         │
    │ 13      │ 'system.adapter.iot'             │ 'iot'             │ '6.0.3'  │ 'none'         │
    │ 14      │ 'system.adapter.javascript'      │ 'javascript'      │ '9.0.18' │ 'none'         │
    │ 15      │ 'system.adapter.kecontact'       │ 'kecontact'       │ '3.6.0'  │ 'none'         │
    │ 16      │ 'system.adapter.modbus'          │ 'modbus'          │ '8.0.3'  │ 'none'         │
    │ 17      │ 'system.adapter.mqtt'            │ 'mqtt'            │ '6.1.4'  │ 'none'         │
    │ 18      │ 'system.adapter.node-red'        │ 'node-red'        │ '6.0.7'  │ 'none'         │
    │ 19      │ 'system.adapter.openweathermap'  │ 'openweathermap'  │ '1.4.0'  │ 'none'         │
    │ 20      │ 'system.adapter.proxy'           │ 'proxy'           │ '1.3.2'  │ 'none'         │
    │ 21      │ 'system.adapter.pushover'        │ 'pushover'        │ '5.0.0'  │ 'none'         │
    │ 22      │ 'system.adapter.rest-api'        │ 'rest-api'        │ '4.0.1'  │ 'none'         │
    │ 23      │ 'system.adapter.scenes'          │ 'scenes'          │ '4.0.4'  │ 'none'         │
    │ 24      │ 'system.adapter.simple-api'      │ 'simple-api'      │ '3.0.7'  │ 'none'         │
    │ 25      │ 'system.adapter.socketio'        │ 'socketio'        │ '7.1.3'  │ 'none'         │
    │ 26      │ 'system.adapter.tr-064'          │ 'tr-064'          │ '4.3.0'  │ 'none'         │
    │ 27      │ 'system.adapter.tuya'            │ 'tuya'            │ '3.17.0' │ 'none'         │
    │ 28      │ 'system.adapter.web'             │ 'web'             │ '8.0.0'  │ 'none'         │
    │ 29      │ 'system.adapter.webcal'          │ 'webcal'          │ '1.4.0'  │ 'none'         │
    │ 30      │ 'system.adapter.ws'              │ 'ws'              │ '4.1.0'  │ 'none'         │
    │ 31      │ 'system.adapter.zigbee'          │ 'zigbee'          │ '3.3.5'  │ 'none'         │
    ioBroker-Adapter Versions and update status
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "bluelink"     : 3.1.26   , installed 3.1.28
    Adapter    "bring"        : 1.8.4    , installed 1.8.4
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "iot"          : 6.0.3    , installed 6.0.3
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.1.2    , installed 7.1.2
    Adapter    "kecontact"    : 3.6.0    , installed 3.6.0
    Adapter    "modbus"       : 8.0.3    , installed 8.0.3
    Adapter    "node-red"     : 6.0.7    , installed 6.0.7
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "pushover"     : 5.0.0    , installed 5.0.0
    Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "webcal"       : 1.4.0    , installed 1.4.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        9542
    States:         8603
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Reading package lists...
    Pending systemupdates: 60
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      390/node-red
    tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      752/io.hm-rpc.0
    tcp        0      0 127.0.0.11:41195        0.0.0.0:*               LISTEN      -
    tcp6       0      0 :::8093                 :::*                    LISTEN      1168/io.rest-api.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1212/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      24568/io.admin.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1196/io.socketio.0
    udp        0      0 172.19.0.9:5353         0.0.0.0:*                           1009/io.tr-064.0
    udp        0      0 127.0.0.11:59707        0.0.0.0:*                           -
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1068/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1068/io.tuya.0
    2026-06-18 10:49:01.033  - info: mqtt.1 (953) send2Server mqtt.1.tasmotas.stTasmota-gosund-01.cmnd.POWER[tasmotas/stTasmota-gosund-01/cmnd/POWER]
    2026-06-18 10:50:12.648  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:12.649  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:12.840  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:12.841  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:12.843  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:12.846  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:19.891  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:19.955  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:29.896  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:29.965  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:39.896  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:39.959  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:49.899  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:49.961  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:59.908  - error: admin.0 (24568) empty object!
    2026-06-18 10:50:59.975  - error: admin.0 (24568) empty object!
    2026-06-18 10:51:09.904  - error: admin.0 (24568) empty object!
    2026-06-18 10:51:09.970  - error: admin.0 (24568) empty object!
    2026-06-18 10:51:19.904  - error: admin.0 (24568) empty object!
    2026-06-18 10:51:19.972  - error: admin.0 (24568) empty object!
    2026-06-18 10:57:40.506  - info: admin.0 (24568) ==> Connected system.user.admin from ::ffff:192.168.65.1
    2026-06-18 10:57:42.727  - info: admin.0 (24568) ==> Connected system.user.admin from ::ffff:192.168.65.1
    ============= Mark until here for C&P =============
    Nach einer halben Stunde googeln habe ich erstmal aufgegeben.
    Wie kann ich dem Fehler auf die Spur kommen?
    rewenode
    Etwas ist mir noch aufgefallen. Ich habe mit das komplette Log runtergeladen. Die Fehlermeldungen kommen schnell hintereinander immer so 20 error meldungen innerhalb einer Minute.
    Das Merkwürdige, Diese error-Blöcke wiederholen sich genau stündlich.
    • R rewenode
      admin.0
      admin.0
      admin.0
      iob diag Ausgabe:
      Script v.2026-06-01
      Hardware Vendor :
      Kernel          : aarch64
      Userland        : 64bit
      Docker          : v11.1.0
      Kernel          : aarch64
      Userland        : 64bit
      CPU threads     : 10
      CEST +0200
      Etc/UTC
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/opt/iobroker
      Desktop:
      Session:
      *** MEMORY ***
      Swap:           2.1G         44M        2.1G
               7936 M total memory
               4381 M used memory
               1436 M free memory
                 44 M buffer memory
               2078 M swap cache
               2047 M total swap
                 42 M used swap
               2005 M free swap
      *** FILESYSTEM ***
      /var:
      35M     /var/
      33M     /var/lib
      19M     /var/lib/apt
      14M     /var/lib/dpkg
      USB-Devices by-id:
      ⚠ HINT:
      tcp
      ⚠ HINT:
      /dev/ttyUSB0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      nodejs:
        Version table:
      ioBroker Status
      Objects type: redis
      States  type: redis
      Hosts:
      admin:          7.8.23
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        9542
      States:         8603
      rewenode
      Ok, da ich irgendwie weiterkommen wollte und eine Containersicherung habe;-)
      habe ich mein Log mal der KI (in meinem Fall deepseek v4) in den Rachen geworfen.
      Behoben
      • Stündliche "empty object!" Fehler im admin.0 Log: Ursache war eine Race-Condition in @iobroker/db-objects-redis (objectsInRedisClient.js:3069). Der getObjectView-Lua-Scan iteriert per Redis SCAN-Cursor über Objekt-Keys. Wenn ein Key zwischen SCAN und FETCH per TTL ausläuft, gibt Redis nil zurück → JSON.parse(null) = null → if (!obj) feuert this.log.error(...).
        Timing: Session-Timeout (ttl: 3600 = 1h) löste stündlich einen DB-Scan aus → ~22 Fehler-Einträge über ~1 Minute alle 10s. Betroffen waren alle Adapter, die @iobroker/db-objects-redis nutzen (admin.0, node-red.0, javascript.0, rest-api.0).
        Fix (2 Maßnahmen):
        • Log-Level gesenkt: log.error → log.debug in beiden Build-Varianten (ESM + CJS) von objectsInRedisClient.js – die Meldung ist eine harmlose Race-Condition, kein echter Fehler.
        • TTL erhöht: Admin-Session-Timeout von 3600 auf 14400 (1h → 4h) – reduziert die DB-Scan-Frequenz auf 1/4.
        Analyse-Belege: TS-Quellcode (objectsInRedisClient.ts:3922), kompilierte JS (objectsInRedisClient.js:3056), Admin-Konfiguration (system.adapter.admin.0, native.ttl). Kein upstream-Fix in @iobroker/db-objects-redis v7.2.2 (latest). Keine korrupten Redis-Objekte – die Keys laufen korrekt per TTL ab, der SCAN-Cursor erwischt sie nur vorher.
      Die gute Nachricht ist, es ist Ruhe im Log.
      Die schlechte, ich weis nicht so recht warum...
      Der hat ca. 10min in meinem Container rumgewuselt und ich war schon erstaunt, dass er sich dann automatisch den Quellcode vorgenommen hat.
      Vlt. kann einer der sich da besser auskennt als ich mal drüberschauen, ob das Sinn ergibt, was deepseek hier gemacht hat, oder ob er nur dafür gesorgt hat, dass die Log-Einträge unterdrückt werden;-)
      • mcm1957M Online
        mcm1957M Online
        mcm1957
        Ich kann da nur sagen:
        DIREKTE Änderungen im REDIS Code - MUTIG von dir
        Von einer Nachahmung auf produktiven System ist meines Erachtens dringend abzuraten
        Ersell doch ggF ein Issue mit deinen Infos damit sich das ein admin Maintainer ansehen kann.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        R 1 Antwort Letzte Antwort
        • mcm1957M mcm1957
          rewenode
          @mcm1957 sagte:
          Da stimme ich voll und ganz zu! Und nicht nur, weil es mit dem nächsten Update sicher wieder weg ist.
          @mcm1957 sagte:
          Erstell doch ggF ein Issue mit deinen Infos damit sich das ein admin Maintainer ansehen kann.
          Ich weiß ja, dass KI generierte Issues nicht gern gesehen werden. Und ich selbst kann es nicht wirklich einschätzen, deshalb hoffe ich ja, dass der Beitrag hier im Forum von einem (fachlich versierterem) überflogen wird.
          • R rewenode
            @mcm1957 sagte:
            @mcm1957 sagte:
            mcm1957M Online
            mcm1957M Online
            mcm1957
            @rewenode sagte:
            @mcm1957 sagte:
            @mcm1957 sagte:
            Erstell einfach ein Issue mit dem Problem / Logdaten admin Repo. Gib alle relevanten Versionen an.
            Und verweis ggF auf eine AI Bwertung hir im Forum.
            HIER lesen die Core Entwickler nur eingeschränkt mit.
            • mcm1957M mcm1957
              @rewenode sagte:
              @mcm1957 sagte:
              @mcm1957 sagte:
              rewenode
              @mcm1957 sagte:
              Issue erstellt
              Will mal hoffen, dass ich nicht gelyncht werde 😅
              • mcm1957M Online
                mcm1957M Online
                mcm1957
                Ich schick dir ein Messer zum Seildurchtrennen :-)
                • R rewenode
                  Behoben
                    Fix (2 Maßnahmen):
                  Marc BergM Offline
                  Marc BergM Offline
                  Marc Berg
                  @rewenode sagte:
                  Ganz ehrlich, ich glaube, die KI hat dir da Unsinn erzählt. Die angemeckerten Meldungen kommen von echten defekten Objekten und nicht von irgendwelchen "Race conditions".
                  Ein Migrieren von Redis zu Jsonl und zurück (via iob setup custom) entfernt die defekte Objekte.
                  • Marc BergM Marc Berg
                    @rewenode sagte:
                    rewenode
                    @Marc-Berg sagte:
                    Ja, da bin ich mir auch fast sicher. Allerdings habe ich keine Möglichkeit gefunden, dahinter zu kommen, um welche Objekte es sich handelt. Allerdings sind die Zyklen schon sonderbar. Ich habe jedenfalls nirgends adapter/flows/scripts gefunden, die einen solchen Zyklus machen.
                    Die Idee mit der Migration ist Klasse. Wird die Redis db bei der Umstellung zu Jsonl plattgemacht?
                    • R rewenode
                      @Marc-Berg sagte:
                      Marc BergM Offline
                      Marc BergM Offline
                      Marc Berg
                      @rewenode sagte:
                      jep, wenn ich mich recht erinnere, kommt auch eine entsprechende Warnmeldung.
                      EDIT: also das "Plattmachen" erfolgt beim Zurückspielen in Richtung Redis
                      Ich hatte mir seinerzeit auch die Zähne daran ausgebissen, herauszufinden, welche Objekte betroffen waren.
