  4. Test Adapter Tidy - Latest
    6.3k
datenpflegecursor aiinventwo
8 Beiträge 2 Kommentatoren 980 Aufrufe 6 Beobachtet
  • skvarelS Offline
    skvarelS Offline
    skvarel
    schrieb am zuletzt editiert von skvarel
    Aktuelle Lastes Version 0.3.x
    Aktuelle Stable Version 0.3.3
    Veröffentlichungsdatum 14.04.2026
    Github Link https://github.com/inventwo/ioBroker.tidy
    npm Link https://www.npmjs.com/package/iobroker.tidy
    Tidy ... helps to find unused objects and states to clean up your system
    Der Einstieg ist hier zu finden:
    Tidy Adapter - Alpha
    #TeamInventwo
    Unsere Adapter:
    • skvarelS Offline
      skvarelS Offline
      skvarel
      Changelog
      (Dieser Beitrag wird laufend erweitert/editiert)
      0.3.3 (2026-06-18)
      • Fixed complete scan failing with "Invalid string length" on large instances
      • Modified complete scan to load states in bulk instead of one-by-one
      0.3.2 (2026-06-18)
      • Removed accidentally committed local dev-server data directory from repository (fixes #14)
      0.3.1 (2026-06-16)
      • Added admin UI help text explaining "Check alias targets" on Scan Paths tab (boxed info panel)
      • Fixed alias target check for read/write split aliases (common.alias.id with read and write)
      0.3.0 (2026-06-13)
      • Added wildcard patterns for exception list (* matches any suffix, ? matches one character)
      #TeamInventwo
      Unsere Adapter:
      • skvarelS Offline
        skvarelS Offline
        skvarel
        .. reserviert
        #TeamInventwo
        Unsere Adapter:
        • skvarelS skvarel
          sigi234S Online
          sigi234S Online
          @skvarel
          der Adapter arbeitet gut wenn man keinen Complet Scan macht.
          Dann stürzt er ab und blockiert mein System.
          tidy.0
          2026-06-18 12:30:42.761	warn	Cannot parse "QUEUED"
          tidy.0
          2026-06-18 12:30:42.760	warn	Cannot parse "OK"
          tidy.0
          2026-06-18 12:30:27.763	warn	Cannot parse "QUEUED"
          tidy.0
          2026-06-18 12:30:27.762	warn	Cannot parse "OK"
          tidy.0
          2026-06-18 12:30:12.752	warn	Cannot parse "QUEUED"
          tidy.0
          2026-06-18 12:30:12.751	warn	Cannot parse "OK"
          tidy.0
          2026-06-18 12:29:57.724	warn	Cannot parse "QUEUED"
          tidy.0
          2026-06-18 12:29:57.723	warn	Cannot parse "OK"
          tidy.0
          2026-06-18 12:29:57.716	info	Automatic scanning enabled: Every 24 hour(s)
          tidy.0
          2026-06-18 12:29:57.715	error	Error during complete scan: Invalid string length
          tidy.0
          2026-06-18 12:29:40.025	info	Scanning entire object tree (complete scan) ...
          tidy.0
          2026-06-18 12:29:40.024	info	Scan completed for 0_userdata.0: 1940 datapoints (471 dead, 548 stale, 0 orphaned, 0 excluded) in 1.30s
          tidy.0
          2026-06-18 12:29:38.727	info	Scanning path: 0_userdata.0
          tidy.0
          2026-06-18 12:29:38.708	info	Starting Tidy adapter...
          tidy.0
          2026-06-18 12:29:38.699	info	starting. Version 0.3.2 in C:/SmartHome/node_modules/iobroker.tidy, node: v22.23.0, js-controller: 7.2.2
          tidy.0
          2026-06-18 12:29:33.607	warn	redis get 0_userdata.0.allestoerungen.Hot.disruption_desc_2, error - Connection is closed.
          tidy.0
          2026-06-18 12:29:33.605	warn	redis get 0_userdata.0.allestoerungen.Hot.disruption_2, error - Connection is closed.
          tidy.0
          2026-06-18 12:29:33.601	info	terminating
          tidy.0
          tidy.0
          2026-06-18 12:29:33.155	info	Scanning path: 0_userdata.0
          tidy.0
          2026-06-18 12:29:33.102	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          tidy.0
          2026-06-18 12:29:33.100	info	terminating
          tidy.0
          2026-06-18 12:29:33.099	info	Got terminate signal TERMINATE_YOURSELF
          tidy.0
          2026-06-18 12:29:33.098	info	Configuration updated — reloading paths and rescanning
          tidy.0
          2026-06-18 12:28:40.956	info	Automatic scanning enabled: Every 24 hour(s)
          tidy.0
          2026-06-18 12:28:40.955	info	Scan completed for 0_userdata.0: 1940 datapoints (471 dead, 548 stale, 0 orphaned, 0 excluded) in 1.51s
          tidy.0
          2026-06-18 12:28:39.441	info	Scanning path: 0_userdata.0
          Plattform: Windows
          RAM: 15.9 GB
          Node.js: v22.23.0
          NPM: 10.9.8
          Tidy: 0.3.2
          JS: 7.2.2
          Admin: 7.9.2
          skvarelS 2 Antworten Letzte Antwort
          • sigi234S sigi234
            @skvarel
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            tidy.0
            Plattform: Windows
            RAM: 15.9 GB
            Node.js: v22.23.0
            NPM: 10.9.8
            Tidy: 0.3.2
            JS: 7.2.2
            Admin: 7.9.2
            skvarelS Offline
            skvarelS Offline
            skvarel
            @sigi234 .. ok, schaue ich mir genauer an!
            #TeamInventwo
            Unsere Adapter:
            • sigi234S sigi234
              @skvarel
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              tidy.0
              Plattform: Windows
              RAM: 15.9 GB
              Node.js: v22.23.0
              NPM: 10.9.8
              Tidy: 0.3.2
              JS: 7.2.2
              Admin: 7.9.2
              skvarelS Offline
              skvarelS Offline
              skvarel
              @sigi234 ..
              Der Fehler Invalid string length tritt auf, wenn der Complete Scan versucht, alle Datenpunkte mit ihren vollen Werten in einem einzigen JSON-State zu speichern – bei großen Installationen überschreitet das das Node.js-Limit.
              In der nächsten Version (0.3.3) ist das behoben: Werte werden gekürzt, States werden gebündelt geladen, und bei extrem großen Instanzen gibt es einen Fallback ohne Wert-Feld.
              Bis dahin: Complete Scan vorübergehend deaktivieren und stattdessen gezielte Pfad-Scans nutzen (z. B. alias, hm-rpc, 0_userdata.0).
              Bitte testen und mir eine kurze Rückmeldung geben 😊
              EDIT:
              Die 0.3.3 ist online
              #TeamInventwo
              Unsere Adapter:
              • skvarelS skvarel
                @sigi234 ..
                EDIT:
                sigi234S Online
                sigi234S Online
                @skvarel sagte:
                Ja, schaut besser aus.
                tidy.0
                2026-06-18 16:02:49.758	info	Automatic scanning enabled: Every 24 hour(s)
                tidy.0
                2026-06-18 16:02:49.756	info	Complete scan finished: 20866 datapoints (4739 dead, 1245 stale, 0 orphaned, 0 excluded) in 10.53s
                tidy.0
                2026-06-18 16:02:39.224	info	Scanning entire object tree (complete scan) ...
                tidy.0
                2026-06-18 16:02:39.223	info	Scan completed for 0_userdata.0: 1940 datapoints (471 dead, 548 stale, 0 orphaned, 0 excluded) in 0.41s
                tidy.0
                2026-06-18 16:02:38.816	info	Scanning path: 0_userdata.0
                tidy.0
                2026-06-18 16:02:38.795	info	Starting Tidy adapter...
                tidy.0
                2026-06-18 16:02:38.786	info	starting. Version 0.3.3 in C:/SmartHome/node_modules/iobroker.tidy, node: v22.23.0, js-controller: 7.2.2
                • skvarelS Offline
                  skvarelS Offline
                  skvarel
                  Der Adapter ist nun auch mit der aktuellen Version im Stable 🚀
                  #TeamInventwo
                  Unsere Adapter:
