  4. Test Adapter Midea Geräten v1.x.x
    6.3k
mideadimstalnethomenethome plus
434 Beiträge 68 Kommentatoren 124.5k Aufrufe 67 Beobachtet
  • Holger EtzelH Holger Etzel
    hallo zusammen,
    ich versuche gerade meine midea Waschmaschine in den Adapter zu bekommen. Anmeldung im Adapter scheint zu funktionieren, aber er findet keine Waschmaschine.
    hier das Debug-Protokoll. Vielleicht kann jemand etwas damit anfangen.
    Ach so, Router ist eine Fritzbox und iobroker läuft auf einer VM auf Synology.
    Holger
    midea.0
    2026-06-01 20:35:26.352	info	Discovery summary: cloud=1, lan=0, both=0, registered=0 cloud-only=[153931629356384]
    midea.0
    2026-06-01 20:35:26.352	warn	Appliance 153931629356384 (Trommelwaschmaschine) is bound to the cloud account but did not respond to LAN discovery — control requires a local broadcast domain, or UDP/6445 is firewalled.
    midea.0
    2026-06-01 20:35:26.351	warn	LAN discovery found 0 appliance(s) — your ioBroker host is not on the same broadcast domain as the appliance, or UDP 6445 is firewalled. Across VLANs you need a UDP broadcast relay (e.g. udpbroadcastrelay).
    midea.0
    2026-06-01 20:35:26.350	debug	discover: finished, 0 appliance(s)
    midea.0
    2026-06-01 20:35:21.354	debug	discover: tx 72B -> 192.168.178.170:20086 via ens3(192.168.178.67/24)
    midea.0
    2026-06-01 20:35:21.354	debug	discover: tx 72B -> 192.168.178.170:6445 via ens3(192.168.178.67/24)
    midea.0
    2026-06-01 20:35:21.354	debug	discover: tx 72B -> 192.168.178.255:20086 via ens3(192.168.178.67/24)
    midea.0
    2026-06-01 20:35:21.352	debug	discover: tx 72B -> 192.168.178.255:6445 via ens3(192.168.178.67/24)
    midea.0
    2026-06-01 20:35:21.347	debug	discover: starting UDP broadcast targets=[192.168.178.255,192.168.178.170] ports=[6445,20086] timeoutMs=5000
    midea.0
    2026-06-01 20:35:21.346	debug	discover: local interfaces: ens3(192.168.178.67/24->192.168.178.255)
    midea.0
    2026-06-01 20:35:21.341	info	LAN discovery: also unicast-probing configured device IPs [192.168.178.170]
    midea.0
    2026-06-01 20:35:21.340	debug	LAN discovery: broadcasting to [192.168.178.255] on UDP/6445+20086
    midea.0
    2026-06-01 20:35:21.335	debug	cloud: id=153931629356384 name="Trommelwaschmaschine" type=0xdb online=false
    midea.0
    2026-06-01 20:35:21.329	info	Cloud listing: 1 appliance(s)
    midea.0
    2026-06-01 20:35:21.315	debug	CloudClient: listAppliances -> 1 appliance(s)
    midea.0
    2026-06-01 20:35:21.315	debug	CloudClient: /v1/appliance/user/list/get reply code=0 msg=ok
    midea.0
    2026-06-01 20:35:20.838	debug	CloudClient: POST /v1/appliance/user/list/get bodyLen=142 hasToken=true
    midea.0
    2026-06-01 20:35:20.837	debug	CloudClient: listAppliances()
    midea.0
    2026-06-01 20:35:20.837	debug	CloudClient: authenticated (uid=413423784d0150b8bb37c0c3540a78ef)
    midea.0
    2026-06-01 20:35:20.836	debug	CloudClient: /mj/user/login reply code=0 msg=成功
    midea.0
    2026-06-01 20:35:15.390	debug	CloudClient: POST /mj/user/login bodyLen=729 hasToken=false
    midea.0
    2026-06-01 20:35:15.388	debug	CloudClient: /v1/user/login/id/get reply code=0 msg=OK
    midea.0
    2026-06-01 20:35:15.045	debug	CloudClient: POST /v1/user/login/id/get bodyLen=211 hasToken=false
    midea.0
    2026-06-01 20:35:15.044	debug	CloudClient: re-route confirmed mp-prod.appsmb.com
    midea.0
    2026-06-01 20:35:15.044	debug	CloudClient: /v1/multicloud/platform/user/route reply code=0 msg=ok
    midea.0
    2026-06-01 20:35:14.599	debug	CloudClient: POST /v1/multicloud/platform/user/route bodyLen=239 hasToken=false
    midea.0
    2026-06-01 20:35:14.595	debug	Midea adapter starting up, poll interval=30 s
    midea.0
    2026-06-01 20:35:13.230	info	starting. Version 1.8.3 (non-npm: TA2k/ioBroker.midea) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
    #419
    @Holger-Etzel
    Da wirst du wohl den genannten Port erreichbar machen müssen.
    • Holger EtzelH Offline
      Holger Etzel
      #420
      habe ich mit schon gedacht, aber wo? Fritzbox oder wo anders?
        #421
        @Holger-Etzel
        Schau dir das Log an. Am besten aber halt das richtige, chronologisch sinnvoll aufgeführte
        iob logs
        Dann müsstest du dir das selber beantworten können.
          hallo zusammen,
          Holger
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          midea.0
          tombox
          #422
          @Holger-Etzel Selbst die cloud meldet das Gerät als offline. ist es denn wirklich aktiv erreichbar?
            triotec
            #423
            Ich versuche gerade meine Klimaanlagen im Adapter zum laufen zu bekommen.
            ich bekomme immer die Fehlermeldung
            • Cloud listAppliances failed: CloudClient: Account or password incorrect, please re-enter (code=3102) -
            • die Zugangsdaten sind korrekt
            • Klimaanlagen sind sehr wahrscheinlich V1
            • ich benutze die SmartHome App > da sind die beiden Klimaanlagen zu sehen und können gesteuert werden
            hat jemand noch eine Idee woran es liegen könnte?
            • T triotec
              triotec
              #424
              Ich antworte mir mal selber.
              Das Problem mit dem Account lag an der MSmartHome App.
              Den Account habe ich migriert von der MideaAir App > geht alles automatisch.
              In meinem Profil wurde der "Registrierungsbereich" auf USA gestellt.
              Das kann man in der App nicht selber ändern.
              Lösung: neuen Account einrichten und auf Deutschland stellen.
              • nicht die "Region" sondern "Registrierungsbereich" im Profil
                triotec
                #425
                ich bekomme meine Midea Klimaanlagen nicht in den Adapter eingebunden.
                • Klimaanlagen sind wohl V1
                • Midea Air, MSmartHome und NetHome
                  -- in allen App´s sind die Klimaanlagen erreichbar und steuerbar
                • Im Adapter steht "V1-Firmware-Geräte im LAN werden nicht unterstützt"
                • in GitHub steht "V1 and V2 appliances run cloudless"
                  Wie werden die V1 den jetzt angesprochen?
                der Objektbaum baut sich nicht wirklich auf. Nur den Ordner Info gibt es.
                midea.0
                2026-06-13 12:27:35.175	info	Discovery summary: cloud=1, lan=0, both=0, registered=0 cloud-only=[31885837210977]
                midea.0
                2026-06-13 12:27:35.175	warn	Appliance 31885837210977 (Wohnzimmer) is bound to the cloud account but did not respond to LAN discovery — control requires a local broadcast domain, or UDP/6445 is firewalled.
                midea.0
                2026-06-13 12:27:35.175	warn	LAN discovery found 0 appliance(s) — your ioBroker host is not on the same broadcast domain as the appliance, or UDP 6445 is firewalled. Across VLANs you need a UDP broadcast relay (e.g. udpbroadcastrelay).
                midea.0
                2026-06-13 12:27:35.175	debug	discover: finished, 0 appliance(s)
                midea.0
                2026-06-13 12:27:30.433	debug	discover: rx 120B from 192.168.0.160:6445 via eth0(192.168.0.53/24)
                midea.0
                2026-06-13 12:27:30.175	debug	discover: tx 72B -> 192.168.0.255:20086 via eth0(192.168.0.53/24)
                midea.0
                2026-06-13 12:27:30.174	debug	discover: tx 72B -> 192.168.0.255:6445 via eth0(192.168.0.53/24)
                midea.0
                2026-06-13 12:27:30.173	debug	discover: starting UDP broadcast targets=[192.168.0.255] ports=[6445,20086] timeoutMs=5000
                midea.0
                2026-06-13 12:27:30.173	debug	discover: local interfaces: eth0(192.168.0.53/24->192.168.0.255)
                midea.0
                2026-06-13 12:27:30.172	debug	LAN discovery: broadcasting to [192.168.0.255] on UDP/6445+20086
                midea.0
                2026-06-13 12:27:30.172	debug	cloud: id=31885837210977 name="Wohnzimmer" type=0xac online=true
                midea.0
                2026-06-13 12:27:30.172	info	Cloud listing: 1 appliance(s)
                midea.0
                2026-06-13 12:27:30.087	debug	CloudClientV1: POST /v1/appliance/user/list/get hasToken=true
                midea.0
                2026-06-13 12:27:30.087	debug	CloudClientV1: listAppliances()
                midea.0
                2026-06-13 12:27:30.087	debug	CloudClientV1: authenticated (app=nethome)
                midea.0
                2026-06-13 12:27:30.042	debug	CloudClientV1: POST /v1/user/login hasToken=false
                midea.0
                2026-06-13 12:27:29.972	debug	CloudClientV1: POST /v1/user/login/id/get hasToken=false
                midea.0
                2026-06-13 12:27:29.971	debug	Midea adapter starting up, poll interval=30 s
                midea.0
                2026-06-13 12:27:29.873	info	starting. Version 1.8.4 in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.1.2
                code_text
                • T triotec
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  midea.0
                  code_text
                  BananaJoeB Offline
                  BananaJoeB Offline
                  BananaJoe
                  #426
                  @triotec also laut deinem Log hat er ein Gerät "Wohnzimmer" gefunden.
                  Siehst du in den Adaptereinstellungen denn nun das Gerät?
                    triotec
                    #427
                    nein. da ist nichts zu sehen
                    • T triotec
                      tombox
                      #428
                      @triotec ich bräuchte den debug log von der GitHub version bitte installieren..
                      brauch den "reply did not parse" log
                      beste Ergebnisse werden mit msmarthome app erreicht
                        triotec
                        #429
                        • GitHub Version
                        • "Klimaanlage" in der msmarthome APP erreichbar
                        midea.0
                        2026-06-13 17:05:49.459	info	Discovery summary: cloud=1, lan=0, both=0, registered=0 cloud-only=[144036023342557]
                        midea.0
                        2026-06-13 17:05:49.458	warn	Appliance 144036023342557 (Klimaanlage) is bound to the cloud account but did not respond to LAN discovery — control requires a local broadcast domain, or UDP/6445 is firewalled.
                        midea.0
                        2026-06-13 17:05:49.458	warn	LAN discovery found 0 appliance(s) — your ioBroker host is not on the same broadcast domain as the appliance, or UDP 6445 is firewalled. Across VLANs you need a UDP broadcast relay (e.g. udpbroadcastrelay).
                        midea.0
                        2026-06-13 17:05:49.458	debug	discover: finished, 0 appliance(s)
                        midea.0
                        2026-06-13 17:05:44.722	debug	discover: 192.168.0.161 reply did not parse (120B: 5a5a011178007a80000000000000000000000000dd95010000830000000000000000000001000000507b9a27e35e27978a358406f701a1a3321c19aed5fd2d6029de39ae75d6b7342f416c931f2ee9abaccf208248babb92bfd9d588cf12701a7e327db8abfcbd5c054eef08cbb4d754b32088f84dca15e1)
                        midea.0
                        2026-06-13 17:05:44.721	debug	discover: rx 120B from 192.168.0.161:6445 via eth0(192.168.0.53/24)
                        midea.0
                        2026-06-13 17:05:44.651	debug	discover: 192.168.0.160 reply did not parse (120B: 5a5a011178007a8000000000000000000000000061150000001d0000000000000000000001000000b535c19029e56c5fc48483815fcb2f363b8d9005b4dff2c93252bd142b8b2d2ace86c93ea999c62926f9b450cb84ee462e9c46009d788297559ce5ad405efd60ad131bf9d0a523dcebd0bb7c7319ee2e)
                        midea.0
                        2026-06-13 17:05:44.650	debug	discover: rx 120B from 192.168.0.160:6445 via eth0(192.168.0.53/24)
                        midea.0
                        2026-06-13 17:05:44.458	debug	discover: tx 72B -> 192.168.0.255:20086 via eth0(192.168.0.53/24)
                        midea.0
                        2026-06-13 17:05:44.458	debug	discover: tx 72B -> 192.168.0.255:6445 via eth0(192.168.0.53/24)
                        midea.0
                        2026-06-13 17:05:44.457	debug	discover: starting UDP broadcast targets=[192.168.0.255] ports=[6445,20086] timeoutMs=5000
                        midea.0
                        2026-06-13 17:05:44.457	debug	discover: local interfaces: eth0(192.168.0.53/24->192.168.0.255)
                        midea.0
                        2026-06-13 17:05:44.456	debug	LAN discovery: broadcasting to [192.168.0.255] on UDP/6445+20086
                        midea.0
                        2026-06-13 17:05:44.456	debug	cloud: id=144036023342557 name="Klimaanlage" type=0xac online=true
                        midea.0
                        2026-06-13 17:05:44.455	info	Cloud listing: 1 appliance(s)
                        midea.0
                        2026-06-13 17:05:44.453	debug	CloudClient: listAppliances -> 1 appliance(s)
                        midea.0
                        2026-06-13 17:05:44.453	debug	CloudClient: /v1/appliance/user/list/get reply code=0 msg=ok
                        midea.0
                        2026-06-13 17:05:43.984	debug	CloudClient: POST /v1/appliance/user/list/get bodyLen=142 hasToken=true
                        midea.0
                        2026-06-13 17:05:43.983	debug	CloudClient: listAppliances()
                        midea.0
                        2026-06-13 17:05:43.983	debug	CloudClient: authenticated (uid=083e61dfb887ad99d871fe873824025b)
                        midea.0
                        2026-06-13 17:05:43.983	debug	CloudClient: /mj/user/login reply code=0 msg=成功
                        midea.0
                        2026-06-13 17:05:38.634	debug	CloudClient: POST /mj/user/login bodyLen=739 hasToken=false
                        midea.0
                        2026-06-13 17:05:38.633	debug	CloudClient: /v1/user/login/id/get reply code=0 msg=OK
                        midea.0
                        2026-06-13 17:05:38.331	debug	CloudClient: POST /v1/user/login/id/get bodyLen=221 hasToken=false
                        midea.0
                        2026-06-13 17:05:38.331	debug	CloudClient: re-route confirmed mp-prod.appsmb.com
                        midea.0
                        2026-06-13 17:05:38.330	debug	CloudClient: /v1/multicloud/platform/user/route reply code=0 msg=ok
                        midea.0
                        2026-06-13 17:05:36.813	debug	CloudClient: POST /v1/multicloud/platform/user/route bodyLen=249 hasToken=false
                        midea.0
                        2026-06-13 17:05:36.811	debug	Midea adapter starting up, poll interval=30 s
                        midea.0
                        2026-06-13 17:05:36.728	info	starting. Version 1.8.4 (non-npm: TA2k/ioBroker.midea) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.1.2
                        midea.0
                        2026-06-13 17:05:36.660	debug	States connected to redis: 127.0.0.1:9000
                        midea.0
                        2026-06-13 17:05:36.610	debug	States create User PubSub Client
                        midea.0
                        2026-06-13 17:05:36.609	debug	States create System PubSub Client
                        midea.0
                        2026-06-13 17:05:36.603	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                        midea.0
                        2026-06-13 17:05:36.591	debug	Objects connected to redis: 127.0.0.1:9001
                        midea.0
                        2026-06-13 17:05:36.587	debug	Objects client initialize lua scripts
                        midea.0
                        2026-06-13 17:05:36.569	debug	Objects create User PubSub Client
                        midea.0
                        2026-06-13 17:05:36.569	debug	Objects create System PubSub Client
                        midea.0
                        2026-06-13 17:05:36.568	debug	Objects client ready ... initialize now
                        midea.0
                        2026-06-13 17:05:36.552	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                        host.iobroker
                        2026-06-13 17:05:36.042	info	instance system.adapter.midea.0 in version "1.8.4" (non-npm: TA2k/ioBroker.midea) started with pid 25182
                        host.iobroker
                        2026-06-13 17:05:35.701	info	"system.adapter.midea.0" enabled
                        • T triotec
                          • GitHub Version
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          midea.0
                          host.iobroker
                          host.iobroker
                          tombox
                          #430
                          @triotec GitHub version sollte jetzt gehen
                            triotec
                            #431
                            Funktioniert.
                            Vielen Dank für deine Arbeit und Unterstützung.
                            • Tom10webT Tom10web
                              Hi, ich wollte nur meine Erfahrungen einbringen.
                              Habe mir jetzt einen Slwf01pro zugelegt um meine Dimstal (midea-clon) ohne Cloud zu steuern.
                              Esphome ist vorinstalliert für Homeassistent.
                              Ich nutze aber den Mqtt Adapter im Iobroker.
                              Alle wichtigen Funktionen funktionieren ohne Probleme.
                              Man muss vom Hersteller des USB Stick die Yaml - Datei runterladen, da die "Platform" esp8266 ändern, die Zeilen für Mqtt einfügen und wieder mit "Esphome Dashboard" auf den Stick Flashen.
                              ! Geht nicht im Gerät über WLAN. Ich hab's am PC geflasht, da muss beim gesamten Flashen der Knopf am SLWF gedrückt werden. (Beim Kompilieren noch nicht).
                              Das gleiche ist zwar weiter oben mit einer angepassten .Yaml beschrieben, da ging aber bei mir nichts.
                              mika84
                              #432
                              @Tom10web sagte:
                              Hi Tom,
                              kannst du mal deine YAML ohne confidential data :) zur Verfügung stellen? In der Originaldatei steht ja mehrfach platform. Ich habe auch kein sinnvolles Beispiel gefunden. Stehe vor der gleichen Herausforderung.
                              Danke für deine Hilfe!
                              • T Nicht stören
                                T Nicht stören
                                toralt
                                #433
                                Ich mach das direkt in iobroker mit dem esphome adapter. Ich habe die Klimaanlagen mit Slwf01pro sowohl in HA als auch in ioBroker direkt verbunden.
                                https://github.com/DrozmotiX/ioBroker.esphome/
                                << ioBroker im Docker auf Synology DS1821+, 10GBit, 32GB RAM>>
                                  mika84
                                  #434
                                  Funktioniert das zuverlässig? Also Adapter aus github installieren Klimagerät mit IP des Slwf01pro hinzufügen und ab geht's mit der Steuerung? Musstest du in der yaml was verändern?
                                  https://github.com/genebean/smartlight-slwf-01pro/blob/main/slwf-01pro.yaml
