  3. Off Topic
  4. Pflege des Betriebssystems
  5. Backitup stört LAN Verbindung
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
48 Beiträge 5 Kommentatoren 3.0k Aufrufe 5 Beobachtet
  • L Offline
    Laser
    schrieb am zuletzt editiert von Laser
    tto@neuheizung:~ $ ls -lh /opt/iobroker/backups/
    total 4.4G
    -rw-rw-r--+ 1 iobroker iobroker  28K Feb 11 02:14 grafana_2026_02_11-02_14_22_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  26K Feb 22 02:14 grafana_2026_02_22-02_14_42_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  28K Feb 23 02:14 grafana_2026_02_23-02_14_30_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  28K Feb 23 16:07 grafana_2026_02_23-16_07_40_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  29K May 24 10:17 grafana_2026_05_24-10_17_04_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 509M Feb 22 02:14 historyDB_2026_02_22-02_06_53_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker    0 Feb 22 16:47 historyDB_2026_02_22-16_47_42_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 509M Feb 23 02:14 historyDB_2026_02_23-02_06_45_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 510M Feb 23 16:07 historyDB_2026_02_23-16_00_02_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 549M May 24 10:17 historyDB_2026_05_24-10_07_39_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 778M Feb 11 02:06 influxDB_2026_02_11-02_00_28_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 794M Feb 22 02:06 influxDB_2026_02_22-02_00_28_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 797M Feb 23 02:06 influxDB_2026_02_23-02_00_29_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 4.2M Feb 11 02:00 iobroker_2026_02_11-02_00_20_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 4.2M Feb 22 02:00 iobroker_2026_02_22-02_00_20_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 4.2M Feb 22 16:45 iobroker_2026_02_22-16_45_08_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker 4.2M Feb 23 02:00 iobroker_2026_02_23-02_00_20_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  19K Feb 11 02:14 javascripts_2026_02_11-02_14_28_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  19K Feb 22 02:14 javascripts_2026_02_22-02_14_48_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  19K Feb 23 02:14 javascripts_2026_02_23-02_14_36_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  19K Feb 23 16:07 javascripts_2026_02_23-16_07_45_backupiobroker.tar.gz
    -rw-rw-r--+ 1 iobroker iobroker  19K May 24 10:17 javascripts_2026_05_24-10_17_10_backupiobroker.tar.gz
    12 Uhr wird Backup noch mal gestartet...
    Anhang:
    [Mon May 25 11:52:44 2026] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
    [Mon May 25 11:54:14 2026] netfs: FS-Cache loaded
    [Mon May 25 11:54:14 2026] Key type cifs.spnego registered
    [Mon May 25 11:54:14 2026] Key type cifs.idmap registered
    [Mon May 25 11:54:14 2026] CIFS: Attempting to mount //192.168.2.10/backup
    [Mon May 25 11:56:35 2026] CIFS: Attempting to mount //192.168.2.10/backup
    [Mon May 25 12:00:20 2026] CIFS: Attempting to mount //192.168.2.10/backup
    • L Laser
      total 4.4G
      Anhang:
      @Laser
      Ich würd ja schauen, dass du die history und die influxDB kleiner bekommst.
      Klammer die mal bei einem Backup aus. Ich vermute, das ist einfach 'too much Zeug'.
      Du mountest da also per CIFS was in /opt/iobroker/backups rein. Ist der mount-Punkt leer, wenn das Datei-System gerade nicht gemountet ist?
      • L Offline
        Laser
        Wenn das Backup bis zur "Störung" gekommen ist, sehe ich mal nach, ob der Mountpoint leer ist.
        Die Influx ist groß. Habe ich aber schon enorm verkleinert...
        • L Offline
          Laser
          So, SSH reagiert wieder nicht. Raspi den Todesstoß versetzt und SSH neu gestartet.
          otto@neuheizung:~ $ sudo dmesg -wT
          [Mon May 25 12:12:29 2026] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
          [Mon May 25 12:12:29 2026] Linux version 6.18.29+rpt-rpi-v8 (serge@raspberrypi.com) (aarch64-linux-gnu-gcc-14 (Debian 14.2.0-19) 14.2.0, GNU ld (GNU Binutils for Debian) 2.44) #1 SMP PREEMPT Debian 1:6.18.29-1+rpt1 (2026-05-12)
          [Mon May 25 12:12:29 2026] KASLR enabled
          [Mon May 25 12:12:29 2026] random: crng init done
          [Mon May 25 12:12:29 2026] Machine model: Raspberry Pi 4 Model B Rev 1.5
          [Mon May 25 12:12:29 2026] efi: UEFI not found.
          [Mon May 25 12:12:29 2026] Reserved memory: created CMA memory pool at 0x000000000e000000, size 512 MiB
          [Mon May 25 12:12:29 2026] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
          [Mon May 25 12:12:29 2026] OF: reserved mem: 0x000000000e000000..0x000000002dffffff (524288 KiB) map reusable linux,cma
          [Mon May 25 12:12:29 2026] OF: reserved mem: 0x000000003ee74d20..0x000000003ee74d55 (0 KiB) nomap non-reusable nvram@0
          [Mon May 25 12:12:29 2026] OF: reserved mem: 0x000000003ee74ae0..0x000000003ee74cdf (0 KiB) nomap non-reusable nvram@1
          [Mon May 25 12:12:29 2026] NUMA: Faking a node at [mem 0x0000000000000000-0x00000001ffffffff]
          [Mon May 25 12:12:29 2026] Faking node 0 at [mem 0x0000000000000000-0x0000000103ffffff] (4160MB)
          [Mon May 25 12:12:29 2026] Faking node 1 at [mem 0x0000000104000000-0x00000001ffffffff] (4032MB)
          [Mon May 25 12:12:29 2026] NODE_DATA(0) allocated [mem 0x103ffd280-0x103ffffff]
          [Mon May 25 12:12:29 2026] NODE_DATA(1) allocated [mem 0x1feff6280-0x1feff8fff]
          [Mon May 25 12:12:29 2026] Zone ranges:
          [Mon May 25 12:12:29 2026]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
          [Mon May 25 12:12:29 2026]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
          [Mon May 25 12:12:29 2026]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
          [Mon May 25 12:12:29 2026] Movable zone start for each node
          [Mon May 25 12:12:29 2026] Early memory node ranges
          [Mon May 25 12:12:29 2026]   node   0: [mem 0x0000000000000000-0x000000003b2fffff]
          [Mon May 25 12:12:29 2026]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
          [Mon May 25 12:12:29 2026]   node   0: [mem 0x0000000100000000-0x0000000103ffffff]
          [Mon May 25 12:12:29 2026]   node   1: [mem 0x0000000104000000-0x00000001ffffffff]
          [Mon May 25 12:12:29 2026] Initmem setup node 0 [mem 0x0000000000000000-0x0000000103ffffff]
          [Mon May 25 12:12:29 2026] Initmem setup node 1 [mem 0x0000000104000000-0x00000001ffffffff]
          [Mon May 25 12:12:29 2026] On node 0, zone DMA32: 19712 pages in unavailable ranges
          [Mon May 25 12:12:29 2026] On node 0, zone Normal: 16384 pages in unavailable ranges
          [Mon May 25 12:12:29 2026] percpu: Embedded 33 pages/cpu s95448 r8192 d31528 u135168
          [Mon May 25 12:12:29 2026] pcpu-alloc: s95448 r8192 d31528 u135168 alloc=33*4096
          [Mon May 25 12:12:29 2026] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [Mon May 25 12:12:29 2026] Detected PIPT I-cache on CPU0
          [Mon May 25 12:12:29 2026] CPU features: detected: Spectre-v2
          [Mon May 25 12:12:29 2026] CPU features: detected: Spectre-v3a
          [Mon May 25 12:12:29 2026] CPU features: detected: Spectre-v4
          [Mon May 25 12:12:29 2026] CPU features: detected: Spectre-BHB
          [Mon May 25 12:12:29 2026] CPU features: kernel page table isolation forced ON by KASLR
          [Mon May 25 12:12:29 2026] CPU features: detected: Kernel page table isolation (KPTI)
          [Mon May 25 12:12:29 2026] CPU features: detected: ARM erratum 1742098
          [Mon May 25 12:12:29 2026] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
          [Mon May 25 12:12:29 2026] alternatives: applying boot alternatives
          [Mon May 25 12:12:29 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=32 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 iommu_dma_numa_policy=interleave smsc95xx.macaddr=D8:3A:DD:0D:3B:C5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=522926e5-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Mon May 25 12:12:29 2026] cgroup: Disabling memory control group subsystem
          [Mon May 25 12:12:29 2026] mempolicy: NUMA default policy overridden to 'interleave:0-1'
          [Mon May 25 12:12:29 2026] DMA IOMMU NUMA default policy overridden to 'interleave:0-1'
          [Mon May 25 12:12:29 2026] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
          [Mon May 25 12:12:29 2026] software IO TLB: area num 4.
          [Mon May 25 12:12:29 2026] software IO TLB: mapped [mem 0x0000000037300000-0x000000003b300000] (64MB)
          [Mon May 25 12:12:29 2026] Fallback order for Node 0: 0 1
          [Mon May 25 12:12:29 2026] Fallback order for Node 1: 1 0
          [Mon May 25 12:12:29 2026] Built 2 zonelists, mobility grouping on.  Total pages: 2061056
          [Mon May 25 12:12:29 2026] Policy zone: Normal
          [Mon May 25 12:12:29 2026] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
          [Mon May 25 12:12:29 2026] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=2
          [Mon May 25 12:12:29 2026] ftrace: allocating 46683 entries in 184 pages
          [Mon May 25 12:12:29 2026] ftrace: allocated 184 pages with 4 groups
          [Mon May 25 12:12:29 2026] rcu: Preemptible hierarchical RCU implementation.
          [Mon May 25 12:12:29 2026] rcu:         RCU event tracing is enabled.
          [Mon May 25 12:12:29 2026]      Trampoline variant of Tasks RCU enabled.
          [Mon May 25 12:12:29 2026]      Rude variant of Tasks RCU enabled.
          [Mon May 25 12:12:29 2026]      Tracing variant of Tasks RCU enabled.
          [Mon May 25 12:12:29 2026] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
          [Mon May 25 12:12:29 2026] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
          [Mon May 25 12:12:29 2026] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
          [Mon May 25 12:12:29 2026] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
          [Mon May 25 12:12:29 2026] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
          [Mon May 25 12:12:29 2026] Root IRQ handler: gic_handle_irq
          [Mon May 25 12:12:29 2026] GIC: Using split EOI/Deactivate mode
          [Mon May 25 12:12:29 2026] rcu: srcu_init: Setting srcu_struct sizes based on contention.
          [Mon May 25 12:12:29 2026] arch_timer: cp15 timer running at 54.00MHz (phys).
          [Mon May 25 12:12:29 2026] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
          [Mon May 25 12:12:29 2026] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
          [Mon May 25 12:12:29 2026] Console: colour dummy device 80x25
          [Mon May 25 12:12:29 2026] printk: legacy console [tty1] enabled
          [Mon May 25 12:12:29 2026] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
          [Mon May 25 12:12:29 2026] pid_max: default: 32768 minimum: 301
          [Mon May 25 12:12:29 2026] LSM: initializing lsm=capability
          [Mon May 25 12:12:29 2026] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, vmalloc hugepage)
          [Mon May 25 12:12:29 2026] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, vmalloc hugepage)
          [Mon May 25 12:12:29 2026] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, vmalloc hugepage)
          [Mon May 25 12:12:29 2026] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, vmalloc hugepage)
          [Mon May 25 12:12:29 2026] rcu: Hierarchical SRCU implementation.
          [Mon May 25 12:12:29 2026] rcu:         Max phase no-delay instances is 1000.
          [Mon May 25 12:12:29 2026] Timer migration: 2 hierarchy levels; 8 children per group; 1 crossnode level
          [Mon May 25 12:12:29 2026] EFI services will not be available.
          [Mon May 25 12:12:29 2026] smp: Bringing up secondary CPUs ...
          [Mon May 25 12:12:29 2026] Detected PIPT I-cache on CPU1
          [Mon May 25 12:12:29 2026] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
          [Mon May 25 12:12:29 2026] Detected PIPT I-cache on CPU2
          [Mon May 25 12:12:29 2026] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
          [Mon May 25 12:12:29 2026] Detected PIPT I-cache on CPU3
          [Mon May 25 12:12:29 2026] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
          [Mon May 25 12:12:29 2026] smp: Brought up 2 nodes, 4 CPUs
          [Mon May 25 12:12:29 2026] SMP: Total of 4 processors activated.
          [Mon May 25 12:12:29 2026] CPU: All CPU(s) started at EL2
          [Mon May 25 12:12:29 2026] CPU features: detected: 32-bit EL0 Support
          [Mon May 25 12:12:29 2026] CPU features: detected: 32-bit EL1 Support
          [Mon May 25 12:12:29 2026] CPU features: detected: CRC32 instructions
          [Mon May 25 12:12:29 2026] CPU features: detected: PMUv3
          [Mon May 25 12:12:29 2026] alternatives: applying system-wide alternatives
          [Mon May 25 12:12:29 2026] Memory: 7446416K/8244224K available (15040K kernel code, 2442K rwdata, 5076K rodata, 2048K init, 505K bss, 255792K reserved, 524288K cma-reserved)
          [Mon May 25 12:12:29 2026] devtmpfs: initialized
          [Mon May 25 12:12:29 2026] Enabled cp15_barrier support
          [Mon May 25 12:12:29 2026] Enabled setend support
          [Mon May 25 12:12:29 2026] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
          [Mon May 25 12:12:29 2026] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, vmalloc)
          [Mon May 25 12:12:29 2026] futex hash table entries: 512 (32768 bytes on 2 NUMA nodes, total 64 KiB, linear).
          [Mon May 25 12:12:30 2026] 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
          [Mon May 25 12:12:30 2026] 0 pages in range for non-PLT usage
          [Mon May 25 12:12:30 2026] 517952 pages in range for PLT usage
          [Mon May 25 12:12:30 2026] pinctrl core: initialized pinctrl subsystem
          [Mon May 25 12:12:30 2026] DMI not present or invalid.
          [Mon May 25 12:12:30 2026] NET: Registered PF_NETLINK/PF_ROUTE protocol family
          [Mon May 25 12:12:30 2026] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
          [Mon May 25 12:12:30 2026] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
          [Mon May 25 12:12:30 2026] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
          [Mon May 25 12:12:30 2026] audit: initializing netlink subsys (disabled)
          [Mon May 25 12:12:30 2026] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
          [Mon May 25 12:12:30 2026] thermal_sys: Registered thermal governor 'step_wise'
          [Mon May 25 12:12:30 2026] cpuidle: using governor menu
          [Mon May 25 12:12:30 2026] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
          [Mon May 25 12:12:30 2026] ASID allocator initialised with 32768 entries
          [Mon May 25 12:12:30 2026] Serial: AMBA PL011 UART driver
          [Mon May 25 12:12:30 2026] /soc/interrupt-controller@40041000: Fixed dependency cycle(s) with /soc/interrupt-controller@40041000
          [Mon May 25 12:12:30 2026] bcm2835-mbox fe00b880.mailbox: mailbox enabled
          [Mon May 25 12:12:30 2026] raspberrypi-firmware soc:firmware: Attached to firmware from 2026-05-21T11:20:25, variant start
          [Mon May 25 12:12:30 2026] raspberrypi-firmware soc:firmware: Firmware hash is 288930ab4712b99596f32732664aaaeb881ef1e0
          [Mon May 25 12:12:30 2026] /scb/pcie@7d500000: Fixed dependency cycle(s) with /scb/pcie@7d500000
          [Mon May 25 12:12:30 2026] bcm2835-dma fe007000.dma-controller: DMA legacy API manager, dmachans=0x1
          [Mon May 25 12:12:30 2026] iommu: Default domain type: Translated
          [Mon May 25 12:12:30 2026] iommu: DMA domain TLB invalidation policy: strict mode
          [Mon May 25 12:12:30 2026] SCSI subsystem initialized
          [Mon May 25 12:12:30 2026] usbcore: registered new interface driver usbfs
          [Mon May 25 12:12:30 2026] usbcore: registered new interface driver hub
          [Mon May 25 12:12:30 2026] usbcore: registered new device driver usb
          [Mon May 25 12:12:30 2026] pps_core: LinuxPPS API ver. 1 registered
          [Mon May 25 12:12:30 2026] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
          [Mon May 25 12:12:30 2026] PTP clock support registered
          [Mon May 25 12:12:30 2026] vgaarb: loaded
          [Mon May 25 12:12:30 2026] clocksource: Switched to clocksource arch_sys_counter
          [Mon May 25 12:12:30 2026] VFS: Disk quotas dquot_6.6.0
          [Mon May 25 12:12:30 2026] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
          [Mon May 25 12:12:30 2026] NET: Registered PF_INET protocol family
          [Mon May 25 12:12:30 2026] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, vmalloc hugepage)
          [Mon May 25 12:12:30 2026] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, vmalloc hugepage)
          [Mon May 25 12:12:30 2026] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, vmalloc hugepage)
          [Mon May 25 12:12:30 2026] TCP established hash table entries: 65536 (order: 7, 524288 bytes, vmalloc hugepage)
          [Mon May 25 12:12:30 2026] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, vmalloc hugepage)
          [Mon May 25 12:12:30 2026] TCP: Hash tables configured (established 65536 bind 65536)
          [Mon May 25 12:12:30 2026] MPTCP token hash table entries: 8192 (order: 6, 196608 bytes, vmalloc hugepage)
          [Mon May 25 12:12:30 2026] UDP hash table entries: 4096 (order: 6, 262144 bytes, vmalloc hugepage)
          [Mon May 25 12:12:30 2026] UDP-Lite hash table entries: 4096 (order: 6, 262144 bytes, vmalloc hugepage)
          [Mon May 25 12:12:30 2026] NET: Registered PF_UNIX/PF_LOCAL protocol family
          [Mon May 25 12:12:30 2026] RPC: Registered named UNIX socket transport module.
          [Mon May 25 12:12:30 2026] RPC: Registered udp transport module.
          [Mon May 25 12:12:30 2026] RPC: Registered tcp transport module.
          [Mon May 25 12:12:30 2026] RPC: Registered tcp-with-tls transport module.
          [Mon May 25 12:12:30 2026] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [Mon May 25 12:12:30 2026] PCI: CLS 0 bytes, default 64
          [Mon May 25 12:12:30 2026] Trying to unpack rootfs image as initramfs...
          [Mon May 25 12:12:30 2026] kvm [1]: nv: 568 coarse grained trap handlers
          [Mon May 25 12:12:30 2026] kvm [1]: IPA Size Limit: 44 bits
          [Mon May 25 12:12:30 2026] kvm [1]: vgic interrupt IRQ9
          [Mon May 25 12:12:30 2026] kvm [1]: Hyp nVHE mode initialized successfully
          [Mon May 25 12:12:30 2026] Freeing initrd memory: 15956K
          [Mon May 25 12:12:30 2026] Initialise system trusted keyrings
          [Mon May 25 12:12:30 2026] workingset: timestamp_bits=42 max_order=21 bucket_order=0
          [Mon May 25 12:12:30 2026] NFS: Registering the id_resolver key type
          [Mon May 25 12:12:30 2026] Key type id_resolver registered
          [Mon May 25 12:12:30 2026] Key type id_legacy registered
          [Mon May 25 12:12:30 2026] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [Mon May 25 12:12:30 2026] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
          [Mon May 25 12:12:30 2026] Key type asymmetric registered
          [Mon May 25 12:12:30 2026] Asymmetric key parser 'x509' registered
          [Mon May 25 12:12:30 2026] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
          [Mon May 25 12:12:30 2026] io scheduler mq-deadline registered
          [Mon May 25 12:12:30 2026] io scheduler kyber registered
          [Mon May 25 12:12:30 2026] io scheduler bfq registered
          [Mon May 25 12:12:30 2026] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 23)
          [Mon May 25 12:12:30 2026] pinctrl-bcm2835 fe200000.gpio: GPIO_OUT persistence: yes
          [Mon May 25 12:12:30 2026] ledtrig-cpu: registered to indicate activity on CPUs
          [Mon May 25 12:12:30 2026] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
          [Mon May 25 12:12:30 2026] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
          [Mon May 25 12:12:30 2026] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x01ffffffff -> 0x0400000000
          [Mon May 25 12:12:30 2026] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
          [Mon May 25 12:12:30 2026] pci_bus 0000:00: root bus resource [bus 00-ff]
          [Mon May 25 12:12:30 2026] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
          [Mon May 25 12:12:30 2026] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400 PCIe Root Port
          [Mon May 25 12:12:30 2026] pci 0000:00:00.0: PCI bridge to [bus 00]
          [Mon May 25 12:12:30 2026] pci 0000:00:00.0:   bridge window [mem 0x80000000-0xbfffffff]
          [Mon May 25 12:12:30 2026] pci 0000:00:00.0: PME# supported from D0 D3hot
          [Mon May 25 12:12:30 2026] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
          [Mon May 25 12:12:30 2026] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
          [Mon May 25 12:12:30 2026] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
          [Mon May 25 12:12:30 2026] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
          [Mon May 25 12:12:30 2026] brcm-pcie fd500000.pcie: clkreq-mode set to default
          [Mon May 25 12:12:30 2026] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
          [Mon May 25 12:12:30 2026] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330 PCIe Endpoint
          [Mon May 25 12:12:30 2026] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
          [Mon May 25 12:12:30 2026] pci 0000:01:00.0: ASPM: VL805 fixup applied
          [Mon May 25 12:12:30 2026] pci 0000:01:00.0: PME# supported from D0 D3hot
          [Mon May 25 12:12:30 2026] pci 0000:01:00.0: ASPM: default states L0s L1
          [Mon May 25 12:12:30 2026] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
          [Mon May 25 12:12:30 2026] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]: assigned
          [Mon May 25 12:12:30 2026] pci 0000:01:00.0: BAR 0 [mem 0x600000000-0x600000fff 64bit]: assigned
          [Mon May 25 12:12:30 2026] pci 0000:00:00.0: PCI bridge to [bus 01]
          [Mon May 25 12:12:30 2026] pci_bus 0000:00: resource 4 [mem 0x600000000-0x63fffffff]
          [Mon May 25 12:12:30 2026] pci_bus 0000:01: resource 1 [mem 0x600000000-0x6000fffff]
          [Mon May 25 12:12:30 2026] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
          [Mon May 25 12:12:30 2026] pcieport 0000:00:00.0: PME: Signaling with IRQ 27
          [Mon May 25 12:12:30 2026] pcieport 0000:00:00.0: AER: enabled with IRQ 27
          [Mon May 25 12:12:30 2026] iproc-rng200 fe104000.rng: hwrng registered
          [Mon May 25 12:12:30 2026] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
          [Mon May 25 12:12:30 2026] brd: module loaded
          [Mon May 25 12:12:30 2026] loop: module loaded
          [Mon May 25 12:12:30 2026] Loading iSCSI transport class v2.0-870.
          [Mon May 25 12:12:30 2026] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
          [Mon May 25 12:12:30 2026] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
          [Mon May 25 12:12:30 2026] usbcore: registered new interface driver lan78xx
          [Mon May 25 12:12:30 2026] usbcore: registered new interface driver smsc95xx
          [Mon May 25 12:12:30 2026] xhci_hcd 0000:01:00.0: xHCI Host Controller
          [Mon May 25 12:12:30 2026] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
          [Mon May 25 12:12:30 2026] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0300240000000890
          [Mon May 25 12:12:30 2026] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
          [Mon May 25 12:12:30 2026] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
          [Mon May 25 12:12:30 2026] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.18
          [Mon May 25 12:12:30 2026] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Mon May 25 12:12:30 2026] usb usb1: Product: xHCI Host Controller
          [Mon May 25 12:12:30 2026] usb usb1: Manufacturer: Linux 6.18.29+rpt-rpi-v8 xhci-hcd
          [Mon May 25 12:12:30 2026] usb usb1: SerialNumber: 0000:01:00.0
          [Mon May 25 12:12:30 2026] hub 1-0:1.0: USB hub found
          [Mon May 25 12:12:30 2026] hub 1-0:1.0: 1 port detected
          [Mon May 25 12:12:30 2026] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.18
          [Mon May 25 12:12:30 2026] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Mon May 25 12:12:30 2026] usb usb2: Product: xHCI Host Controller
          [Mon May 25 12:12:30 2026] usb usb2: Manufacturer: Linux 6.18.29+rpt-rpi-v8 xhci-hcd
          [Mon May 25 12:12:30 2026] usb usb2: SerialNumber: 0000:01:00.0
          [Mon May 25 12:12:30 2026] hub 2-0:1.0: USB hub found
          [Mon May 25 12:12:30 2026] hub 2-0:1.0: 4 ports detected
          [Mon May 25 12:12:30 2026] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [Mon May 25 12:12:30 2026] dwc_otg: FIQ enabled
          [Mon May 25 12:12:30 2026] dwc_otg: NAK holdoff enabled
          [Mon May 25 12:12:30 2026] dwc_otg: FIQ split-transaction FSM enabled
          [Mon May 25 12:12:30 2026] Module dwc_common_port init
          [Mon May 25 12:12:30 2026] usbcore: registered new interface driver uas
          [Mon May 25 12:12:30 2026] usbcore: registered new interface driver usb-storage
          [Mon May 25 12:12:30 2026] mousedev: PS/2 mouse device common for all mice
          [Mon May 25 12:12:30 2026] sdhci: Secure Digital Host Controller Interface driver
          [Mon May 25 12:12:30 2026] sdhci: Copyright(c) Pierre Ossman
          [Mon May 25 12:12:30 2026] sdhci-pltfm: SDHCI platform and OF driver helper
          [Mon May 25 12:12:30 2026] hid: raw HID events driver (C) Jiri Kosina
          [Mon May 25 12:12:30 2026] usbcore: registered new interface driver usbhid
          [Mon May 25 12:12:30 2026] usbhid: USB HID core driver
          [Mon May 25 12:12:30 2026] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 (0,8000003f) counters available
          [Mon May 25 12:12:30 2026] NET: Registered PF_PACKET protocol family
          [Mon May 25 12:12:30 2026] Key type dns_resolver registered
          [Mon May 25 12:12:30 2026] registered taskstats version 1
          [Mon May 25 12:12:30 2026] Loading compiled-in X.509 certificates
          [Mon May 25 12:12:30 2026] Demotion targets for Node 0: null
          [Mon May 25 12:12:30 2026] Demotion targets for Node 1: null
          [Mon May 25 12:12:30 2026] Key type .fscrypt registered
          [Mon May 25 12:12:30 2026] Key type fscrypt-provisioning registered
          [Mon May 25 12:12:30 2026] uart-pl011 fe201000.serial: there is not valid maps for state default
          [Mon May 25 12:12:30 2026] uart-pl011 fe201000.serial: cts_event_workaround enabled
          [Mon May 25 12:12:30 2026] fe201000.serial: ttyAMA1 at MMIO 0xfe201000 (irq = 39, base_baud = 0) is a PL011 rev3
          [Mon May 25 12:12:30 2026] serial serial0: tty port ttyAMA1 registered
          [Mon May 25 12:12:30 2026] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [Mon May 25 12:12:30 2026] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
          [Mon May 25 12:12:30 2026] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [Mon May 25 12:12:30 2026] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
          [Mon May 25 12:12:30 2026] of_cfs_init
          [Mon May 25 12:12:30 2026] of_cfs_init: OK
          [Mon May 25 12:12:30 2026] clk: Disabling unused clocks
          [Mon May 25 12:12:30 2026] PM: genpd: Disabling unused power domains
          [Mon May 25 12:12:30 2026] mmc1: Controller never released inhibit bit(s).
          [Mon May 25 12:12:30 2026] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
          [Mon May 25 12:12:30 2026] Freeing unused kernel memory: 2048K
          [Mon May 25 12:12:30 2026] Run /init as init process
          [Mon May 25 12:12:30 2026]   with arguments:
          [Mon May 25 12:12:30 2026]     /init
          [Mon May 25 12:12:30 2026]   with environment:
          [Mon May 25 12:12:30 2026]     HOME=/
          [Mon May 25 12:12:30 2026]     TERM=linux
          [Mon May 25 12:12:31 2026] mmc1: new high speed SDIO card at address 0001
          [Mon May 25 12:12:31 2026] usb 1-1: new high-speed USB device number 2 using xhci_hcd
          [Mon May 25 12:12:31 2026] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
          [Mon May 25 12:12:31 2026] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
          [Mon May 25 12:12:31 2026] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
          [Mon May 25 12:12:31 2026] usb 1-1: Product: USB2.0 Hub
          [Mon May 25 12:12:31 2026] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
          [Mon May 25 12:12:31 2026] hub 1-1:1.0: USB hub found
          [Mon May 25 12:12:31 2026] hub 1-1:1.0: 4 ports detected
          [Mon May 25 12:12:31 2026] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
          [Mon May 25 12:12:31 2026] usb 1-1.2: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.54
          [Mon May 25 12:12:31 2026] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
          [Mon May 25 12:12:31 2026] usb 1-1.2: Product: USB2.0-Ser!
          [Mon May 25 12:12:31 2026] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
          [Mon May 25 12:12:31 2026] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
          [Mon May 25 12:12:31 2026] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
          [Mon May 25 12:12:31 2026] usb 1-1.3: Product: VE Direct cable
          [Mon May 25 12:12:31 2026] usb 1-1.3: Manufacturer: VictronEnergy BV
          [Mon May 25 12:12:31 2026] usb 1-1.3: SerialNumber: VE82E1IJ
          [Mon May 25 12:12:31 2026] usb 1-1.4: new high-speed USB device number 5 using xhci_hcd
          [Mon May 25 12:12:32 2026] usb 1-1.4: New USB device found, idVendor=14cd, idProduct=6116, bcdDevice= 2.20
          [Mon May 25 12:12:32 2026] usb 1-1.4: New USB device strings: Mfr=1, Product=3, SerialNumber=2
          [Mon May 25 12:12:32 2026] usb 1-1.4: Product: USB Mass Storage Device
          [Mon May 25 12:12:32 2026] usb 1-1.4: Manufacturer: Generic
          [Mon May 25 12:12:32 2026] usb 1-1.4: SerialNumber: 116AC2101219
          [Mon May 25 12:12:32 2026] usb-storage 1-1.4:1.0: USB Mass Storage device detected
          [Mon May 25 12:12:32 2026] scsi host0: usb-storage 1-1.4:1.0
          [Mon May 25 12:12:33 2026] scsi 0:0:0:0: Direct-Access        Mass  Storage Device        PQ: 0 ANSI: 0
          [Mon May 25 12:12:33 2026] sd 0:0:0:0: [sda] 234441646 512-byte logical blocks: (120 GB/112 GiB)
          [Mon May 25 12:12:33 2026] sd 0:0:0:0: [sda] Write Protect is off
          [Mon May 25 12:12:33 2026] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
          [Mon May 25 12:12:33 2026] sd 0:0:0:0: [sda] No Caching mode page found
          [Mon May 25 12:12:33 2026] sd 0:0:0:0: [sda] Assuming drive cache: write through
          [Mon May 25 12:12:33 2026]  sda: sda1 sda2
          [Mon May 25 12:12:33 2026] sd 0:0:0:0: [sda] Attached SCSI disk
          [Mon May 25 12:12:34 2026] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
          [Mon May 25 12:12:35 2026] systemd[1]: System time advanced to timestamp on /var/lib/systemd/timesync/clock: Mon 2026-05-25 12:11:29 CEST
          [Mon May 25 12:12:35 2026] NET: Registered PF_INET6 protocol family
          [Mon May 25 12:12:35 2026] Segment Routing with IPv6
          [Mon May 25 12:12:35 2026] In-situ OAM (IOAM) with IPv6
          [Mon May 25 12:12:35 2026] systemd[1]: systemd 257.13-1~deb13u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
          [Mon May 25 12:12:35 2026] systemd[1]: Detected architecture arm64.
          [Mon May 25 12:12:35 2026] systemd[1]: Hostname set to <neuheizung>.
          [Mon May 25 12:12:35 2026] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
          [Mon May 25 12:12:35 2026] systemd[1]: Using hardware watchdog 'Broadcom BCM2835 Watchdog timer', version 0, device /dev/watchdog0
          [Mon May 25 12:12:35 2026] systemd[1]: Watchdog running with a hardware timeout of 1min.
          [Mon May 25 12:12:36 2026] systemd[1]: Queued start job for default target multi-user.target.
          [Mon May 25 12:12:36 2026] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
          [Mon May 25 12:12:36 2026] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
          [Mon May 25 12:12:36 2026] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
          [Mon May 25 12:12:36 2026] systemd[1]: Created slice user.slice - User and Session Slice.
          [Mon May 25 12:12:36 2026] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
          [Mon May 25 12:12:36 2026] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
          [Mon May 25 12:12:36 2026] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
          [Mon May 25 12:12:36 2026] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-522926e5\x2d01.device - /dev/disk/by-partuuid/522926e5-01...
          [Mon May 25 12:12:36 2026] systemd[1]: Reached target paths.target - Path Units.
          [Mon May 25 12:12:36 2026] systemd[1]: Reached target slices.target - Slice Units.
          [Mon May 25 12:12:36 2026] systemd[1]: Reached target swap.target - Swaps.
          [Mon May 25 12:12:36 2026] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
          [Mon May 25 12:12:36 2026] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
          [Mon May 25 12:12:36 2026] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
          [Mon May 25 12:12:36 2026] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements skipped, unmet condition check ConditionSecurity=measured-uki
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy skipped, unmet condition check ConditionSecurity=measured-uki
          [Mon May 25 12:12:36 2026] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
          [Mon May 25 12:12:36 2026] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
          [Mon May 25 12:12:36 2026] systemd[1]: dev-hugepages.mount - Huge Pages File System skipped, unmet condition check ConditionPathExists=/sys/kernel/mm/hugepages
          [Mon May 25 12:12:36 2026] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
          [Mon May 25 12:12:36 2026] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
          [Mon May 25 12:12:36 2026] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
          [Mon May 25 12:12:36 2026] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
          [Mon May 25 12:12:36 2026] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
          [Mon May 25 12:12:36 2026] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
          [Mon May 25 12:12:36 2026] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS skipped, unmet condition check ConditionPathExists=/etc/krb5.keytab
          [Mon May 25 12:12:36 2026] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info skipped, unmet condition check ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67
          [Mon May 25 12:12:36 2026] systemd[1]: Starting systemd-journald.service - Journal Service...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement skipped, unmet condition check ConditionSecurity=measured-uki
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
          [Mon May 25 12:12:36 2026] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
          [Mon May 25 12:12:36 2026] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
          [Mon May 25 12:12:36 2026] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
          [Mon May 25 12:12:36 2026] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
          [Mon May 25 12:12:36 2026] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
          [Mon May 25 12:12:36 2026] systemd[1]: Mounted tmp.mount - Temporary Directory /tmp.
          [Mon May 25 12:12:36 2026] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
          [Mon May 25 12:12:36 2026] systemd[1]: modprobe@configfs.service: Deactivated successfully.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
          [Mon May 25 12:12:36 2026] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
          [Mon May 25 12:12:36 2026] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-fsck-root.service - File System Check on Root Device skipped, unmet condition check ConditionPathExists=!/run/initramfs/fsck-root
          [Mon May 25 12:12:36 2026] fuse: init (API version 7.45)
          [Mon May 25 12:12:36 2026] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
          [Mon May 25 12:12:36 2026] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
          [Mon May 25 12:12:36 2026] systemd[1]: modprobe@drm.service: Deactivated successfully.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
          [Mon May 25 12:12:36 2026] systemd[1]: modprobe@fuse.service: Deactivated successfully.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
          [Mon May 25 12:12:36 2026] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
          [Mon May 25 12:12:36 2026] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
          [Mon May 25 12:12:36 2026] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
          [Mon May 25 12:12:36 2026] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
          [Mon May 25 12:12:36 2026] systemd-journald[240]: Collecting audit messages is disabled.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
          [Mon May 25 12:12:36 2026] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
          [Mon May 25 12:12:36 2026] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database skipped, unmet condition check ConditionNeedsUpdate=/etc
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival skipped, unmet condition check ConditionDirectoryNotEmpty=/sys/fs/pstore
          [Mon May 25 12:12:36 2026] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
          [Mon May 25 12:12:36 2026] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup skipped, unmet condition check ConditionSecurity=measured-uki
          [Mon May 25 12:12:36 2026] systemd[1]: Started systemd-journald.service - Journal Service.
          [Mon May 25 12:12:36 2026] systemd-journald[240]: Received client request to flush runtime journal.
          [Mon May 25 12:12:37 2026] rpi-gpiomem fe200000.gpiomem: window base 0xfe200000 size 0x00001000
          [Mon May 25 12:12:37 2026] rpi-gpiomem fe200000.gpiomem: initialised 1 regions as /dev/gpiomem
          [Mon May 25 12:12:37 2026] v3d fec00000.v3d: [drm] Transparent Hugepage support is recommended for optimal performance on this platform!
          [Mon May 25 12:12:37 2026] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
          [Mon May 25 12:12:37 2026] [drm] Initialized v3d 1.0.0 for fec00000.v3d on minor 0
          [Mon May 25 12:12:37 2026] mc: Linux media interface: v0.10
          [Mon May 25 12:12:37 2026] bcm2835-audio bcm2835-audio: card created with 8 channels
          [Mon May 25 12:12:37 2026] videodev: Linux video capture interface: v2.00
          [Mon May 25 12:12:37 2026] Bluetooth: Core ver 2.22
          [Mon May 25 12:12:37 2026] NET: Registered PF_BLUETOOTH protocol family
          [Mon May 25 12:12:37 2026] Bluetooth: HCI device and connection manager initialized
          [Mon May 25 12:12:37 2026] Bluetooth: HCI socket layer initialized
          [Mon May 25 12:12:37 2026] Bluetooth: L2CAP socket layer initialized
          [Mon May 25 12:12:37 2026] Bluetooth: SCO socket layer initialized
          [Mon May 25 12:12:37 2026] sd 0:0:0:0: Attached scsi generic sg0 type 0
          [Mon May 25 12:12:37 2026] Bluetooth: HCI UART driver ver 2.3
          [Mon May 25 12:12:37 2026] Bluetooth: HCI UART protocol H4 registered
          [Mon May 25 12:12:37 2026] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [Mon May 25 12:12:37 2026] Bluetooth: HCI UART protocol Broadcom registered
          [Mon May 25 12:12:37 2026] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
          [Mon May 25 12:12:37 2026] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
          [Mon May 25 12:12:37 2026] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [Mon May 25 12:12:37 2026] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
          [Mon May 25 12:12:37 2026] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
          [Mon May 25 12:12:37 2026] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [Mon May 25 12:12:37 2026] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
          [Mon May 25 12:12:37 2026] usbcore: registered new interface driver usbserial_generic
          [Mon May 25 12:12:37 2026] usbserial: USB Serial support registered for generic
          [Mon May 25 12:12:37 2026] usbcore: registered new interface driver ch341
          [Mon May 25 12:12:37 2026] usbserial: USB Serial support registered for ch341-uart
          [Mon May 25 12:12:37 2026] ch341 1-1.2:1.0: ch341-uart converter detected
          [Mon May 25 12:12:37 2026] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [Mon May 25 12:12:37 2026] usbcore: registered new interface driver ftdi_sio
          [Mon May 25 12:12:37 2026] usbserial: USB Serial support registered for FTDI USB Serial Device
          [Mon May 25 12:12:37 2026] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
          [Mon May 25 12:12:37 2026] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [Mon May 25 12:12:37 2026] [vc_sm_connected_init]: start
          [Mon May 25 12:12:37 2026] usb 1-1.3: Detected FT-X
          [Mon May 25 12:12:37 2026] ch341-uart ttyUSB0: break control not supported, using simulated break
          [Mon May 25 12:12:37 2026] usb 1-1.2: ch341-uart converter now attached to ttyUSB0
          [Mon May 25 12:12:37 2026] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB1
          [Mon May 25 12:12:37 2026] [vc_sm_connected_init]: installed successfully
          [Mon May 25 12:12:37 2026] systemd-journald[240]: Time jumped backwards, rotating.
          [Mon May 25 12:12:37 2026] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [Mon May 25 12:12:38 2026] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
          [Mon May 25 12:12:38 2026] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
          [Mon May 25 12:12:38 2026] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
          [Mon May 25 12:12:38 2026] Bluetooth: hci0: BCM: chip id 107
          [Mon May 25 12:12:38 2026] Bluetooth: hci0: BCM: features 0x2f
          [Mon May 25 12:12:38 2026] Bluetooth: hci0: BCM4345C0
          [Mon May 25 12:12:38 2026] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
          [Mon May 25 12:12:38 2026] rpi-hevc-dec feb00000.codec: Device registered as /dev/video19
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
          [Mon May 25 12:12:38 2026] brcmfmac: F1 signature read @0x18000000=0x15264345
          [Mon May 25 12:12:38 2026] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,4-model-b.hcd' Patch
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
          [Mon May 25 12:12:38 2026] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
          [Mon May 25 12:12:38 2026] usbcore: registered new interface driver brcmfmac
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
          [Mon May 25 12:12:38 2026] Registered IR keymap rc-cec
          [Mon May 25 12:12:38 2026] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
          [Mon May 25 12:12:38 2026] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
          [Mon May 25 12:12:38 2026] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/fef00700.hdmi/sound/card1/input1
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
          [Mon May 25 12:12:38 2026] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
          [Mon May 25 12:12:38 2026] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
          [Mon May 25 12:12:38 2026] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
          [Mon May 25 12:12:38 2026] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input2
          [Mon May 25 12:12:38 2026] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/fef05700.hdmi/sound/card2/input3
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Mon May 25 12:12:38 2026] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
          [Mon May 25 12:12:38 2026] [drm] Initialized vc4 0.0.0 for gpu on minor 1
          [Mon May 25 12:12:38 2026] systemd-journald[240]: Time jumped backwards, rotating.
          [Mon May 25 12:12:38 2026] vc4-drm gpu: [drm] Cannot find any crtc or sizes
          [Mon May 25 12:12:38 2026] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
          [Mon May 25 12:12:38 2026] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
          [Mon May 25 12:12:38 2026] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
          [Mon May 25 12:12:38 2026] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
          [Mon May 25 12:12:39 2026] Adding 204796k swap on /var/swap.  Priority:-2 extents:12 across:483328k
          [Mon May 25 12:12:39 2026] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [Mon May 25 12:12:39 2026] Bluetooth: BNEP filters: protocol multicast
          [Mon May 25 12:12:39 2026] Bluetooth: BNEP socket layer initialized
          [Mon May 25 12:12:39 2026] Bluetooth: MGMT ver 1.23
          [Mon May 25 12:12:39 2026] NET: Registered PF_ALG protocol family
          [Mon May 25 12:12:39 2026] Bluetooth: RFCOMM TTY layer initialized
          [Mon May 25 12:12:39 2026] Bluetooth: RFCOMM socket layer initialized
          [Mon May 25 12:12:39 2026] Bluetooth: RFCOMM ver 1.11
          [Mon May 25 12:12:41 2026] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
          [Mon May 25 12:12:41 2026] bcmgenet fd580000.ethernet eth0: Link is Down
          [Mon May 25 12:12:41 2026] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
          [Mon May 25 12:12:44 2026] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
          [Mon May 25 12:14:19 2026] netfs: FS-Cache loaded
          [Mon May 25 12:14:19 2026] Key type cifs.spnego registered
          [Mon May 25 12:14:19 2026] Key type cifs.idmap registered
          [Mon May 25 12:14:19 2026] CIFS: Attempting to mount //192.168.2.10/backup
          • L Laser
            @Laser sagte:
            Ist das dein Zieldateisystem?
            Und das wird automatisch beim booten eingehängt?
            Und wie sehen die Einstellungen im Backitup-Adapter dazu aus? Wird da nochmal gemountet?
            • L Offline
              Laser
              Ja, dort hin soll das Backup auslagern. Beim manuellen Backup sehe ich auch, wie das gemountet wird. Vorher sollte das eigentlich abgehängt sein.
              Jetzt nachgesehen:
              otto@neuheizung:/opt/iobroker/backups $ ls
              • L Laser
                Jetzt nachgesehen:
                @Laser
                Starte die Kiste mal neu und dann als erstes mal
                mount | sort
                anschauen. Da darf kein mount des entfernten Dateisystems zu sehen sein.
                Jedenfalls nicht, wenn du später nochmal via Backitup-Adapter mountest.
                Und deine Netzwerkverbindung ist auch nicht die beste:
                Der Raspberri hat einen 1Gbps-Port. Auf meinem System z. B.:
                [   12.893533] bcmgenet fd580000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/tx
                • L Offline
                  Laser
                  Mount | sort- das NAS System ist nicht gemountet, ohne Start von BackItup.
                  Der Raspi ist über einen Switch angeschlossen, ist nicht schnell.
                  Habe mir gedacht, das System hat Zeit für das Backup. Ist offenbar nicht so.
                  • L Laser
                    @Laser
                    Ausgaben zeigen.
                    • L Offline
                      Laser
                      Mache gerade ein Backup ohne History. (12:40 Uhr)
                      Gemountet wird erst jetzt, beim Backup.
                      Woher dieser Mountversuch kommt, ist mir ein Rätsel.
                      • L Offline
                        Laser
                        Backup ohne "History"- Daten ist durch. Ohne Störung bisher. Das Problem ist offenbar das große Backup in Verbindung mit der langsamen Verbindung.
                        Die schnellen Ports an meinem Router sind Alle schon mit etwas belegt. Muß sehen, wie ich hier eine bessere Verbindung hinbekomme.
                        • L Offline
                          Laser
                          Wobei ich nicht verstehe, warum die Verbindung superschnell sein soll. Das Backup hat doch Nachts genug Zeit, fertig zu werden?
                          • L Laser
                            Ich schalte verbotenerweise durch Abziehen der Stromversorgung aus.
                            Das "Ausschalten" hilft mir (!) , IObroker wieder über das Netzwerk zu erreichen.
                            Nicht erreichen heißt, kein Ping auf die IP möglich, in FritzBox Ansicht nicht zu sehen.
                            Werde jetzt ein "Full-upgrade machen. Danach noch mal automatisches Backup starten.
                            @Laser sagte:
                            Also nicht nur ioBroker, sondern wahrscheinlich der ganze Host nicht erreichbar, auch nicht über SSH!??
                            Dann hängt er ggf. in einem überhöhten LOAD average fest.
                            Das kann länger dauern.
                            @Laser sagte:
                            Zerstört du sehr wahrscheinlich dein Dateisystem, i sbesondere wenn die LOAD average wegen Erhöhter i/o klemmt.
                            Seltsamerweise sehe ich davon nichts im diag
                            • L Offline
                              Laser
                              5 Stunden habe ich ja schon gewartet, ohne Erfolg. Irgend etwas passiert beim "Hängen". Die LAN LED am Raspi blinkt dauerhaft.
                              Die LED am NAS (Raspi mit OMV) geht nach ca 20 Min vom Blinken bei Datenübertragung in Dauerlicht über.
                              • L Laser
                                @Laser sagte:
                                Das passt!
                                Dann klemmt bei der Datenübertragung und die CPU / der NIC arbeitet sich durch dauernde Wiederholungen ins Koma
                                • L Offline
                                  Laser
                                  Was kann ich aber dagegen tun?
                                  • L Laser
                                    @Laser erst mal herausfinden warum das so ist.
                                    @thomas-braun hilft da ja schon intensiv.
                                    • L Offline
                                      Laser
                                      2 schnellere Switches habe ich schon bestellt.
                                      • Michael SchmittM Online
                                        Michael Schmitt
                                        welchen router nutzt du ?
                                        • L Offline
                                          Laser
                                          Fritzbox 7530
