  4. Update Rpi 5 und Rpi 4 Master und Slave [Solved]
    6.3k
27 Beiträge 2 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • MichaelFM MichaelF
    Hi, habe heute den Master auf trixie gebracht.
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.18.29+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     21:49:00 up 12 min,  1 user,  load average: 0.95, 1.84, 1.47
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2026-05-16 21:49:00 CEST
               Universal time: Sat 2026-05-16 19:49:00 UTC
                     RTC time: Sat 2026-05-16 19:49:00
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/pi
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.5G        4.9G        2.0G         24M        1.6G        3.5G
    Swap:           536M          0B        536M
    Total:          9.0G        4.9G        2.6G
    Active iob-Instances:   59
             8062 M total memory
             4697 M used memory
             4392 M active memory
             1151 M inactive memory
             1927 M free memory
              202 M buffer memory
             1345 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 21:49:00 up 12 min,  1 user,  load average: 0.95, 1.84, 1.47
    Tasks: 223 total,   3 running, 220 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 28.6 us,  0.0 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8062.4 total,   1925.5 free,   4699.2 used,   1547.9 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3363.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M   15M  793M   2% /run
    /dev/nvme0n1p2 ext4      235G   18G  205G   8% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     4.0G  9.2M  4.0G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/nvme0n1p1 vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     807M   32K  807M   1% /run/user/1000
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    [Sat May 16 21:36:11 2026] EXT4-fs (nvme0n1p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sat May 16 21:36:12 2026] EXT4-fs (nvme0n1p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.4G    /var/
    499M    /var/log
    497M    /var/log/journal/ff5660355b0e4138b8b00244b401160e
    208M    /var/lib
    Archived and active journals take up 505.5M in the file system.
    /opt/iobroker/backups:
    8.3G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G    /opt/iobroker/iobroker-data/
    650M    /opt/iobroker/iobroker-data/sqlite
    379M    /opt/iobroker/iobroker-data/files
    142M    /opt/iobroker/iobroker-data/backup-objects
    73M     /opt/iobroker/iobroker-data/files/vis
    650M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    114M    /opt/iobroker/iobroker-data/states.jsonl
    64M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IoBroker64Bit       IoBroker64Bit (version: 7.0.7, hostname: IoBroker64Bit , alive, uptime: 700)
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 762)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.8.23
    javascript:     9.0.18
    nodejs modules from github:     8
    +-- iobroker.fully-tablet-control@0.3.8 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#ae07136c27d18a8b6ffa23763324d6f417e2ee97)
    +-- iobroker.niu@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.niu.git#bb6cc29dc1cea582643854c7b0183f3efc1aa6f4)
    +-- iobroker.nspanel-lovelace-ui@0.17.8 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#58bb65c680944e140dec6f22e98780b3fe3e35c1)
    +-- iobroker.parcel@0.3.1 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#c579b7c8e878e72c56ae1c30c2fed9292b469895)
    +-- iobroker.pioneer_sc_vsx@0.1.0 (git+ssh://git@github.com/okeck1982/ioBroker.pioneer_sc_vsx.git#b74d0f748835d2c1c4b860d43a8e6a24939039ce)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#056daf7c0911a454ee3f4a0f7f3b329cf70222c2)
    +-- iobroker.spritmonitor@0.0.3-beta.2 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#43ee460516dc02b2dab881f2b00b306cc6f54cf6)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
    + system.adapter.brightsky.0              : brightsky             : IoBroker64Bit                            -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8428
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
      system.adapter.luftdaten.0              : luftdaten             : IoBroker64Bit                            -  enabled
    + system.adapter.midea.0                  : midea                 : IoBroker64Bit                            -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.niu.0                    : niu                   : iobroker                                 -  enabled
    + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobroker                                 -  enabled
    + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
    + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
    + system.adapter.nuki.2                   : nuki                  : IoBroker64Bit                            -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
      system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
      system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
    + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
    + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartloadmanager.0       : smartloadmanager      : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : IoBroker64Bit                            -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.spritmonitor.0           : spritmonitor          : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                                  │ auto upgrade │
    │ 0       │ 'stable' │ 'http://iobroker.live/repo/sources-dist.json'        │ false        │
    │ 1       │ 'beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.8.23   , installed 7.8.23
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
    Adapter    "device-watcher": 2.15.5  , installed 2.15.5
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "ical"         : 1.20.0   , installed 1.20.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
    Adapter    "niu"          : 0.0.3    , installed 0.0.3
    Adapter    "nspanel-lovelace-ui": 0.16.2, installed 0.17.8
    Adapter    "nut"          : 1.7.0    , installed 1.7.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "pi-hole"      : 2.0.0    , installed 2.0.0
    Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
    Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
    Adapter    "rpi2"         : 3.0.2    , installed 2.4.0  [Updatable]
    Adapter    "s7"           : 1.5.0    , installed 1.5.0
    Adapter    "sainlogic"    : 1.2.0    , installed 1.2.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "smartloadmanager": 0.1.0 , installed 0.1.0
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.17.0   , installed 3.17.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
    Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "worx"         : 3.3.0    , installed 3.3.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        50419
    States:         42673
    [3~
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    W: Failed to fetch https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:4 http://deb.debian.org/debian trixie-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Err:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Get:6 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Fetched 6922 B in 1s (12.7 kB/s)
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       10659      1508/io.hm-rpc.3
    tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       10090      1409/io.hm-rpc.1
    tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       10096      1435/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       10820      1545/io.mqtt.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       10819      1545/io.mqtt.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7398       779/sshd: /usr/sbin
    tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       12739      1397/io.hm-rpc.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       8496       1163/iobroker.js-co
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       6121       1163/iobroker.js-co
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7573       1047/exim4
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        9558       1099/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7400       779/sshd: /usr/sbin
    tcp6       0      0 :::8883                 :::*                    LISTEN      1001       26650      3147/io.nspanel-lov
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7574       1047/exim4
    tcp6       0      0 :::45000                :::*                    LISTEN      1001       16196      2465/io.sainlogic.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17195      2542/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        9594       1099/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19349      2774/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10266      1183/io.admin.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1993       593/avahi-daemon: r
    udp        0      0 0.0.0.0:59155           0.0.0.0:*                           104        1995       593/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       23221      2683/io.upnp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16573      1865/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16574      1865/io.tuya.0
    udp6       0      0 fe80::a154:eb9:60c4:546 :::*                                0          9617       617/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        1994       593/avahi-daemon: r
    udp6       0      0 :::56564                :::*                                104        1996       593/avahi-daemon: r
    2026-05-16 21:47:22.766  - info: host.iobroker iobroker gyp info spawn args   '-Dnode_engine=v8',gyp info spawn args   '--depth=.',gyp info spawn args   '--no-parallel',gyp info spawn args   '--generator-output',gyp info spawn args   'build',gyp info spawn args   '-Goutput_dir=.'gyp info spawn args ]
    2026-05-16 21:47:22.815  - info: host.iobroker iobroker Traceback (most recent call last):  File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>    import gyp  # noqa: E402    ^^^^^^^^^^  File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>    import gyp.input  File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>    from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'
    2026-05-16 21:47:22.834  - info: host.iobroker iobroker gyp ERR! configure error
    2026-05-16 21:47:22.834  - info: host.iobroker iobroker gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack     at ChildProcess.emit (node:events:519:28)gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)gyp ERR! System Linux 6.18.29+rpt-rpi-2712
    2026-05-16 21:47:22.835  - info: host.iobroker iobroker gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.22.2gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
    2026-05-16 21:47:22.863  - info: host.iobroker iobroker npm error code 1
    2026-05-16 21:47:22.864  - info: host.iobroker iobroker npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuild
    2026-05-16 21:47:22.866  - info: host.iobroker iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-16T19_47_19_128Z-debug-0.log
    2026-05-16 21:47:25.467  - info: host.iobroker iobroker Updating objects from io-package.json for adapter "rpi2" with version "2.4.0"
    2026-05-16 21:47:26.850  - info: host.iobroker iobroker upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
    2026-05-16 21:47:26.854  - info: host.iobroker iobroker upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
    2026-05-16 21:47:26.857  - info: host.iobroker iobroker upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
    2026-05-16 21:47:26.860  - info: host.iobroker iobroker upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    2026-05-16 21:47:26.863  - info: host.iobroker iobroker upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
    2026-05-16 21:47:26.866  - info: host.iobroker iobroker upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    2026-05-16 21:47:26.868  - info: host.iobroker iobroker upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    2026-05-16 21:47:26.871  - info: host.iobroker iobroker upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    2026-05-16 21:47:26.876  - info: host.iobroker iobroker upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    2026-05-16 21:47:26.882  - info: host.iobroker iobroker upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    2026-05-16 21:47:26.887  - info: host.iobroker iobroker upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    2026-05-16 21:47:26.889  - info: host.iobroker iobroker upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
    2026-05-16 21:47:26.893  - info: host.iobroker iobroker upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
    2026-05-16 21:47:26.896  - info: host.iobroker iobroker upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
    2026-05-16 21:47:27.908  - info: host.iobroker iobroker exit 0
    2026-05-16 21:47:36.511  - info: javascript.0 (3856) script.js.Licht_Flur: true
    Bei :
    sudo apt update
    Hab ich noch fogendes:
    pi@iobroker:~ $ sudo apt update
    OK:1 http://deb.debian.org/debian trixie InRelease
    OK:2 http://deb.debian.org/debian-security trixie-security InRelease
    OK:3 http://deb.debian.org/debian trixie-updates InRelease
    OK:4 http://archive.raspberrypi.com/debian trixie InRelease
    OK:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Fehl:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Holen:6 https://repos.influxdata.com/debian stable InRelease [6.922 B]
    Es wurden 6.922 B in 1 s geholt (11,7 kB/s).
    Alle Pakete sind aktuell.
    Warnung: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. OpenPGP-Signaturüberprüfung fehlgeschlagen: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    Warnung: Fehlschlag beim Holen von https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    Warnung: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
    Hinweis: Fehlendes Signed-By im Eintrag sources.list(5) für »http://archive.raspberrypi.com/debian«
    @MichaelF
    iob nodejs-update 22
    Künftig dann regelmäßiger updaten, die Meldung muss dir schon Monate um die Ohren fliegen.
    Und von einem mit Meldungen verzierten apt macht man auch kein Dist-Upgrade.
    Die zweite Meldung ist auch keine Unbekannte. Benutz mal die Suchfunktion.
    €dit:
    sudo apt install python3-setuptools
    • MichaelFM Online
      MichaelFM Online
      MichaelF
      Riesen danke für die schnelle Antwort:
      pi@iobroker:~ $ iob nodejs-update 22
      Valid major version. CUSTOM installation of nodejs v22
      ioBroker nodejs-update v2026-01-31 is starting. Please be patient!
      ioBroker nodejs fixer 2026-01-31
      You requested to install latest version from nodejs v22 tree.
      Your current setup is:
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      We found these nodejs versions available for installation:
      nodejs:
        Version table:
      Nothing to do - Your installation is using the correct paths.
      You are missing the nodesource.list or
      you want to change your current nodejs version: v22.22.2 ?
      Press <y> to continue or any other key to quit
      We are not fixing your installation. Exiting.
      Ist leider immer noch da
      pi@iobroker:~ $
      Nach der zweiten Meldung bin ich noch am suchen
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Version table:
        pi@iobroker:~ $
        @MichaelF sagte:
        Das solltest du bejahen...
          /usr/bin/npm            10.9.7
          /usr/bin/npx            10.9.7
          nodejs:
            Version table:
          pi@iobroker:~ $
          @MichaelF sagte:
          MichaelFM 1 Antwort Letzte Antwort
          • MichaelFM Online
            MichaelFM Online
            MichaelF
            Sorry............
            Hat geklappt, ich hätte schwören können das ich
            y
            gedrückt hatte.....
            Danke nochmal
              @MichaelF sagte:
              MichaelFM Online
              MichaelFM Online
              MichaelF
              @Thomas-Braun sagte:
              @MichaelF sagte:
              Auch gefunden, geht jetzt auch.
              • MichaelFM Online
                MichaelFM Online
                MichaelF
                Nochmal ein glaube ich doofe frage zum slave.
                Trixie direkt auf die ssd, iobroker installieren, muss ich dann ein Backup einspielen das der Master wieder weiß das der Slave neu ist ?
                Also wie kommen die Adapter wieder auf den Slave.
                Das wäre das das Projekt für morgen
                • MichaelFM Online
                  MichaelFM Online
                  MichaelF
                  schrieb am zuletzt editiert von MichaelF
                  Hi, habe gestern versucht den Slave von bullsseye auf bookworm über die Konsole zu bekommen.
                  Hat anscheinend auch soweit geklappt, einen Fehler hatte ich beim update des Kernels aber mit Hilfe von chatgpt behoben bekommen.
                  Kann man jetzt von hier aus auf Trixie ?
                  Ich hatte mich gescheut weil das voll die Katastrophe war den Pi4 von SD booten zu lassen, daher über die Konsole.
                  Script v.2026-01-31
                  *** BASE SYSTEM ***
                   Static hostname: IoBroker64Bit
                         Icon name: computer
                            Kernel: Linux 6.12.87+rpt-rpi-v8
                      Architecture: arm64
                  OS is similar to:
                  Model           : Raspberry Pi 4 Model B Rev 1.4
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   01:36:10 up 4 days, 19 min,  2 users,  load average: 0.75, 0.49, 0.34
                  CPU threads: 4
                  Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                  Current issues:
                                 Local time: Thu 2026-05-21 01:36:10 CEST
                             Universal time: Wed 2026-05-20 23:36:10 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:        * lightdm.service - Light Display Manager
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:            1.9G        789M         94M         32K        1.1G        1.1G
                  Swap:           209M        207M        2.3M
                  Total:          2.1G        996M         96M
                           1844 M total memory
                            751 M used memory
                            813 M active memory
                            814 M inactive memory
                             89 M free memory
                              2 M buffer memory
                           1068 M swap cache
                            199 M total swap
                            197 M used swap
                              2 M free swap
                  top - 01:36:30 up 4 days, 20 min,  2 users,  load average: 1.20, 0.60, 0.38
                  Tasks: 200 total,   3 running, 197 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  7.7 us, 38.5 sy,  0.0 ni, 38.5 id,  7.7 wa,  0.0 hi,  7.7 si,  0.0 st
                  MiB Mem :   1844.7 total,    113.7 free,    758.8 used,   1056.7 buff/cache
                  MiB Swap:    200.0 total,      0.0 free,    200.0 used.   1085.9 avail Mem
                  *** FILESYSTEM ***
                  /dev/root      ext4      117G  9.7G  101G   9% /
                  devtmpfs       devtmpfs  664M     0  664M   0% /dev
                  tmpfs          tmpfs     923M     0  923M   0% /dev/shm
                  tmpfs          tmpfs     369M  1.2M  368M   1% /run
                  tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                  /dev/sda1      vfat      253M  102M  152M  41% /boot/firmware
                  tmpfs          tmpfs     185M   40K  185M   1% /run/user/1000
                  [Sun May 17 01:16:23 2026] EXT4-fs (sda2): mounted filesystem 1b73c456-a078-49d1-a94b-759928005fb9 ro with ordered data mode. Quota mode: none.
                  [Sun May 17 01:16:23 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                  [Sun May 17 01:16:24 2026] EXT4-fs (sda2): re-mounted 1b73c456-a078-49d1-a94b-759928005fb9 r/w.
                  /                /dev/sda2 ext4   rw,noatime,stripe=8191
                  `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  2.1G    /var/
                  1.5G    /var/log/journal/122b3afb23014f43b9b08ad8562e656b
                  1.5G    /var/log
                  264M    /var/lib
                  Archived and active journals take up 1.4G in the file system.
                  4.0K    /opt/iobroker/backups/
                  17M     /opt/iobroker/iobroker-data/
                  14M     /opt/iobroker/iobroker-data/files
                  13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                  6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                  2.9M    /opt/iobroker/iobroker-data/objects.jsonl
                  2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                  1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                  652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                  USB-Devices by-id:
                  /usr/bin/npm            10.9.7
                  /usr/bin/npx            10.9.7
                  nodejs:
                    Version table:
                       18.20.4+dfsg-1~deb12u2 500
                          500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                       18.20.4+dfsg-1~deb12u1 500
                          500 http://deb.debian.org/debian bookworm/main arm64 Packages
                  ioBroker Status
                  At least one iobroker host is running.
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  IoBroker64Bit       IoBroker64Bit (version: 7.0.7, hostname: IoBroker64Bit , alive, uptime: 346780)
                  iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 360017)
                  admin:          "admin" not found
                  javascript:     "javascript" not found
                  nodejs modules from github:     2
                  +-- iobroker.midea@1.7.1 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#649a929d1d81a2fc5f30d362b4080729065c0c89)
                  +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
                  Adapter State
                  + instance is alive
                  Adapter    "brightsky"    : 1.0.1    , installed 1.0.1
                  Adapter    "envertech-pv" : 1.5.1    , installed 1.5.1
                  Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                  Adapter    "midea"        : 0.0.7    , installed 1.7.1
                  Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                  Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                  Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                  Objects and States
                  Objects:        51262
                  States:         43342
                  Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                  Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
                  Pending systemupdates: 2
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1317231    342939/cupsd
                  tcp        0      0 192.168.178.76:9091     0.0.0.0:*               LISTEN      1001       7350       1020/io.nuki.0
                  tcp        0      0 192.168.178.76:9093     0.0.0.0:*               LISTEN      1001       6955       1060/io.nuki.2
                  tcp        0      0 192.168.178.76:9092     0.0.0.0:*               LISTEN      1001       9250       1044/io.nuki.1
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6669       653/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6949       1129/io.sonoff.0
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1317230    342939/cupsd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          6671       653/sshd: /usr/sbin
                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6700       490/dhcpcd: [master
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15808      3750/io.mihome-vacu
                  udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       8387       1145/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        5704       403/avahi-daemon: r
                  udp        0      0 0.0.0.0:49490           0.0.0.0:*                           108        5706       403/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          6713       490/dhcpcd: [master
                  udp6       0      0 :::50293                :::*                                108        5707       403/avahi-daemon: r
                  udp6       0      0 :::5353                 :::*                                108        5705       403/avahi-daemon: r
                  2026-05-21 01:28:51.546  - info: luftdaten.0 (348020) Terminated (NO_ERROR): Without reason
                  2026-05-21 01:28:52.079  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348020 terminated with code 0 (NO_ERROR)
                  2026-05-21 01:30:48.032  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 348121
                  2026-05-21 01:30:51.071  - info: luftdaten.0 (348121) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                  2026-05-21 01:30:52.258  - info: luftdaten.0 (348121) Terminated (NO_ERROR): Without reason
                  2026-05-21 01:30:52.789  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348121 terminated with code 0 (NO_ERROR)
                  2026-05-21 01:32:25.460  - info: nuki.1 (1044) Bridge Info requested: http://192.168.178.9:8080/info?ts=2026-05-20T23:32:22Z&rnr=27316&hash=533df9fcd0503733085c12c4251add735065649b46d28aebfa0c51923c13b1cf
                  2026-05-21 01:32:25.594  - info: nuki.1 (1044) Lock list requested: http://192.168.178.9:8080/list?ts=2026-05-20T23:32:25Z&rnr=43402&hash=8b439ad061d56055ac8b22f95ecc91bc291ed35d236032c6e98f591125951e65
                  2026-05-21 01:32:48.084  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 348254
                  2026-05-21 01:32:51.046  - info: luftdaten.0 (348254) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                  2026-05-21 01:32:51.316  - info: luftdaten.0 (348254) Terminated (NO_ERROR): Without reason
                  2026-05-21 01:32:51.850  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348254 terminated with code 0 (NO_ERROR)
                  2026-05-21 01:33:26.474  - info: nuki.2 (1060) Bridge Info requested: http://192.168.178.42:8080/info?ts=2026-05-20T23:33:26Z&rnr=36514&hash=428ed57d26051b73fb1a184504c7ca0dd57e99904ba2b6a17fa43bee5d1cbf20
                  2026-05-21 01:33:29.454  - info: nuki.2 (1060) Lock list requested: http://192.168.178.42:8080/list?ts=2026-05-20T23:33:29Z&rnr=44900&hash=ad66503f52be3482d9b2ced152e2dadf83fb3b5496944249e3b70cc7fcb94b79
                  2026-05-21 01:34:33.386  - info: midea.0 (303716) LanClient[152832116580279]: LAN authentication succeeded (tcpKey 32 bytes)
                  2026-05-21 01:34:48.048  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 348410
                  2026-05-21 01:34:51.286  - info: luftdaten.0 (348410) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                  2026-05-21 01:34:51.557  - info: luftdaten.0 (348410) Terminated (NO_ERROR): Without reason
                  2026-05-21 01:34:52.088  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348410 terminated with code 0 (NO_ERROR)
                  2026-05-21 01:36:48.149  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 348926
                  2026-05-21 01:36:51.870  - info: luftdaten.0 (348926) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                  2026-05-21 01:36:52.299  - info: luftdaten.0 (348926) Terminated (NO_ERROR): Without reason
                  2026-05-21 01:36:52.837  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348926 terminated with code 0 (NO_ERROR)
                  2026-05-21 01:37:19.268  - info: nuki.0 (1020) Bridge Info requested: http://192.168.178.8:8080/info?ts=2026-05-20T23:37:19Z&rnr=24839&hash=eaea45e2c6d912f6f9d33796ed76e7ea1829014191e7054ec06272458ce5739f
                  2026-05-21 01:37:22.221  - info: nuki.0 (1020) Lock list requested: http://192.168.178.8:8080/list?ts=2026-05-20T23:37:22Z&rnr=24706&hash=2e856b3bcbbd307d93255806c355bf53402cfcb1ec053eab174231d2b3864135
                  pi@IoBroker64Bit:~ $ cat /etc/debian_version
                  12.14
                  pi@IoBroker64Bit:~ $ uname -a
                  Linux IoBroker64Bit 6.12.87+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.87-1+rpt1~bookworm (2026-05-12) aarch64 GNU/Linux
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                             1844 M total memory
                              751 M used memory
                              813 M active memory
                               89 M free memory
                                2 M buffer memory
                             1068 M swap cache
                              199 M total swap
                              197 M used swap
                                2 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.1G    /var/
                    1.5G    /var/log
                    264M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            10.9.7
                    /usr/bin/npx            10.9.7
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        51262
                    States:         43342
                    12.14
                    @MichaelF sagte:
                    Probier es aus.
                    • MichaelFM Online
                      MichaelFM Online
                      MichaelF
                      Hat geklappt, der Slave hat jetzt auch Trixie
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                             Icon name: computer
                                Kernel: Linux 6.18.29+rpt-rpi-v8
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       18:44:46 up 11 min,  1 user,  load average: 1.17, 1.03, 0.63
                      CPU threads: 4
                      Current issues:
                                     Local time: Thu 2026-05-21 18:44:46 CEST
                                 Universal time: Thu 2026-05-21 16:44:46 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      iobroker
                      HOME=/home/iobroker
                      SUDO_HOME=/home/pi
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Mem:            1.9G        722M         97M        3.7M        1.2G        1.2G
                      Swap:           209M        204M        5.6M
                      Total:          2.1G        926M        103M
                               1843 M total memory
                                690 M used memory
                               1561 M active memory
                                 49 M inactive memory
                                 92 M free memory
                                  2 M buffer memory
                               1130 M swap cache
                                199 M total swap
                                194 M used swap
                                  5 M free swap
                      top - 18:45:06 up 11 min,  1 user,  load average: 1.44, 1.10, 0.66
                      Tasks: 193 total,   1 running, 192 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  6.0 us,  6.0 sy,  0.0 ni, 84.0 id,  4.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   1843.7 total,     91.6 free,    689.5 used,   1134.2 buff/cache
                      MiB Swap:    200.0 total,      5.9 free,    194.0 used.   1154.3 avail Mem
                      *** FILESYSTEM ***
                      /dev/root      ext4      117G   11G  101G  10% /
                      devtmpfs       devtmpfs  665M     0  665M   0% /dev
                      tmpfs          tmpfs     922M     0  922M   0% /dev/shm
                      tmpfs          tmpfs     369M  5.9M  363M   2% /run
                      tmpfs          tmpfs     922M  2.6M  920M   1% /tmp
                      /dev/sda1      vfat      253M  101M  152M  40% /boot/firmware
                      tmpfs          tmpfs     185M   72K  185M   1% /run/user/1000
                      [Thu May 21 18:33:38 2026] EXT4-fs (sda2): mounted filesystem 1b73c456-a078-49d1-a94b-759928005fb9 ro with ordered data mode. Quota mode: none.
                      [Thu May 21 18:33:38 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                      [Thu May 21 18:33:40 2026] EXT4-fs (sda2): re-mounted 1b73c456-a078-49d1-a94b-759928005fb9 r/w.
                      /var:
                      2.6G    /var/
                      1.5G    /var/log
                      605M    /var/cache
                      USB-Devices by-id:
                      /usr/bin/npm            10.9.7
                      /usr/bin/npx            10.9.7
                      nodejs:
                        Version table:
                              500 http://security.debian.org/debian-security trixie-security/main arm64 Packages
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      IoBroker64Bit       IoBroker64Bit (version: 7.0.7, hostname: IoBroker64Bit , alive, uptime: 273)
                      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 421744)
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        51219
                      States:         43321
                      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                      Hit:3 http://security.debian.org/debian-security trixie-security InRelease
                      Hit:4 http://archive.raspberrypi.org/debian trixie InRelease
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7346       1013/exim4
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18928      2885/io.sonoff.0
                      tcp        0      0 192.168.178.76:9091     0.0.0.0:*               LISTEN      1001       19718      2752/io.nuki.0
                      tcp        0      0 192.168.178.76:9093     0.0.0.0:*               LISTEN      1001       19742      2817/io.nuki.2
                      tcp        0      0 192.168.178.76:9092     0.0.0.0:*               LISTEN      1001       19727      2768/io.nuki.1
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6035       682/cupsd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5995       757/sshd: /usr/sbin
                      tcp6       0      0 :::5900                 :::*                    LISTEN      994        9403       725/wayvnc
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6034       682/cupsd
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7347       1013/exim4
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          5997       757/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2811       527/dhcpcd: [networ
                      udp        0      0 0.0.0.0:47203           0.0.0.0:*                           108        6181       454/avahi-daemon: r
                      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       20500      2963/io.mihome-vacu
                      udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       18390      2907/io.tr-064.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        6179       454/avahi-daemon: r
                      udp6       0      0 :::546                  :::*                                0          2813       527/dhcpcd: [networ
                      udp6       0      0 :::5353                 :::*                                108        6180       454/avahi-daemon: r
                      udp6       0      0 :::35109                :::*                                108        6182       454/avahi-daemon: r
                      2026-05-21 18:41:42.857  - warn: mihome-vacuum.0 (2963) State "mihome-vacuum.0.control.clean_home" has no existing object, this might lead to an error in future versions
                      2026-05-21 18:41:42.926  - info: mihome-vacuum.0 (2963) create state for carpet_mode
                      2026-05-21 18:41:42.961  - info: luftdaten.0 (2995) Terminated (NO_ERROR): Without reason
                      2026-05-21 18:41:44.239  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                      2026-05-21 18:41:44.426  - info: switchbot-hub.0 (3027) starting. Version 0.1.2 (non-npm: DrozmotiX/ioBroker.switchbot-hub#7a05fa59dfc5e3ce8d73018badc4e420996452f8) in /opt/iobroker/node_modules/iobroker.switchbot-hub, node: v22.22.2, js-controller: 7.0.7
                      2026-05-21 18:41:44.587  - info: switchbot-hub.0 (3027) Connected to SwitchBot API found 3 devices
                      2026-05-21 18:41:44.787  - info: midea.0 (3079) starting. Version 1.7.1 (non-npm: TA2k/ioBroker.midea#649a929d1d81a2fc5f30d362b4080729065c0c89) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
                      2026-05-21 18:41:45.753  - info: midea.0 (3079) Cloud listing: 1 appliance(s)
                      2026-05-21 18:41:45.758  - info: midea.0 (3079) LAN discovery: also unicast-probing configured device IPs [192.168.178.51]
                      2026-05-21 18:41:46.144  - info: switchbot-hub.0 (3027) All devices and values loaded, adapter ready
                      2026-05-21 18:41:50.767  - info: midea.0 (3079) LAN discovery found 1 appliance(s)
                      2026-05-21 18:41:51.001  - info: midea.0 (3079) Device 152832116580279: using token/key from device list (admin override, token=97F67491…)
                      2026-05-21 18:41:51.080  - info: midea.0 (3079) LanClient[152832116580279]: LAN authentication succeeded (tcpKey 32 bytes)
                      2026-05-21 18:41:51.656  - info: midea.0 (3079) Discovery summary: cloud=1, lan=1, both=1, registered=1
                      2026-05-21 18:42:21.475  - info: brightsky.0 (2924) Adapter started with configuration: Position: 50.58836475,8.461956549999996, WMO Station ID: 10532, DWD Station ID: , Currently data enabled. Poll interval: 60 minutes - Hourly data enabled. Poll interval: 1 hours - Daily data enabled - Radar data enabled. Poll interval: 10 minutes. Max distance: 50000 meters.
                      2026-05-21 18:42:21.476  - info: brightsky.0 (2924) Using WMO Station ID: 10532
                      2026-05-21 18:42:25.030  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 3149
                      2026-05-21 18:42:27.942  - info: luftdaten.0 (3149) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                      2026-05-21 18:42:28.353  - info: luftdaten.0 (3149) Terminated (NO_ERROR): Without reason
                      2026-05-21 18:42:28.930  - warn: luftdaten.0 (3149) get state error: Connection is closed.
                      2026-05-21 18:42:28.959  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 3149 terminated with code 0 (NO_ERROR)
                      2026-05-21 18:44:25.030  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 4385
                      2026-05-21 18:44:28.174  - info: luftdaten.0 (4385) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                      2026-05-21 18:44:28.911  - info: luftdaten.0 (4385) Terminated (NO_ERROR): Without reason
                      2026-05-21 18:44:29.479  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 4385 terminated with code 0 (NO_ERROR)
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                        CPU threads: 4
                        Current issues:
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        HOME=/home/pi
                        iobroker
                        HOME=/home/iobroker
                        SUDO_HOME=/home/pi
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                                 1843 M total memory
                                  690 M used memory
                                   92 M free memory
                                    2 M buffer memory
                                 1130 M swap cache
                                  199 M total swap
                                  194 M used swap
                                    5 M free swap
                        *** FILESYSTEM ***
                        /var:
                        2.6G    /var/
                        1.5G    /var/log
                        605M    /var/cache
                        USB-Devices by-id:
                        /usr/bin/npm            10.9.7
                        /usr/bin/npx            10.9.7
                        nodejs:
                          Version table:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        51219
                        States:         43321
                        @MichaelF sagte:
                        • MichaelFM Online
                          MichaelFM Online
                          MichaelF
                          Ja grade gesehen und auf den neusten Stand gebracht.
                          Ganz ohne Problem ging es nicht, ich hatte ein Paketkonflikt zwischen lxpanel und lxplug-batt
                          Hier hat aber ChatGBT recht schnell geholfen, der Update Prozess ist quasi mittendrin stehen geblieben.
                          War das zweite mal das ich das genutzt habe, hätte ich nicht gedacht das sich so Fehler so gut beheben lassen, ohne das wäre mir wahrscheinlich nur die neu Installation geblieben.
                          Danke nochmal und grüße.
                            @MichaelF sagte:
                            Das kann nicht sein, diese Pakete sind nur vorhanden, wenn da Desktop-Gerümpel installiert ist.
                            Auf einem Server hat man sowas aber nicht...
                              @MichaelF sagte:
                              MichaelFM Online
                              MichaelFM Online
                              MichaelF
                              @Thomas-Braun
                              Wo die Pakete her kamen kann ich leider auch nicht sagen hier die Fehlermeldung, wären diese vorhanden wenn dort mal ein Desktop gelaufen wäre?
                                @Thomas-Braun
                                @MichaelF sagte:
                                Und zwar nur dann.
                                Was hat die KI dir denn eingeflüstert? lxplug-batt zu entfernen?
                                • MichaelFM Online
                                  MichaelFM Online
                                  MichaelF
                                  Ausschließen das auf dem Slave mal ein Desktop war kann ich nicht , möglich das ich damals eine Version mit Desktop installiert habe wenn auch nicht nötig.
                                  Aber je das hat die Ki gesagt,
                                  • MichaelFM Online
                                    MichaelFM Online
                                    MichaelF
                                    Also wie schon geschrieben, ich war schon erstaunt dass das so geklappt hat. Erst das zweite mal benutzt, ohne wäre mir nur die neu Installation geblieben, weil da wäre ich nie drauf gekommen...
                                      @MichaelF
                                      KI-typisch etwas 'drüber'.
                                      Ein
                                      sudo apt remove lxplug-batt
                                      hätte vermutlich schon ausgereicht.
                                      • MichaelFM Online
                                        MichaelFM Online
                                        MichaelF
                                        Kann ich leider nicht sagen.....
                                        Hier noch die Erklärung die die Ki ausgespuckt hat, eben vergessen sorry:
