  4. Update Rpi 5 und Rpi 4 Master und Slave [Solved]
    6.3k
27 Beiträge 2 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • MichaelFM Online
    MichaelFM Online
    MichaelF
    Sorry für die späte Rückmeldung....
    Hier die diag´s :
    Der Master:
    Script v.2026-01-31
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.12.75+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     09:41:08 up 20 days, 18:48,  2 users,  load average: 1.60, 1.24, 0.89
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    ~ Throttling has occurred
    ~ Soft temperature limit has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-04-27 09:41:08 CEST
               Universal time: Mon 2026-04-27 07:41:08 UTC
                     RTC time: Mon 2026-04-27 07:41:08
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.5G        7.3G        446M        966K        996M        1.2G
    Swap:           536M        535M        1.3M
    Total:          9.0G        7.8G        447M
    Active iob-Instances:   59
             8063 M total memory
             6943 M used memory
             3157 M active memory
             3832 M inactive memory
              425 M free memory
              127 M buffer memory
              823 M swap cache
              511 M total swap
              510 M used swap
                1 M free swap
    top - 09:41:08 up 20 days, 18:48,  2 users,  load average: 1.60, 1.24, 0.89
    Tasks: 264 total,   1 running, 263 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.1 total,    421.6 free,   6947.4 used,    950.5 buff/cache
    MiB Swap:    512.0 total,      1.3 free,    510.7 used.   1115.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    7 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M  5.2M  802M   1% /run
    /dev/nvme0n1p2 ext4      235G   17G  206G   8% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/nvme0n1p1 vfat      510M   57M  454M  12% /boot/firmware
    tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
    [Mon Apr  6 14:52:37 2026] EXT4-fs (nvme0n1p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Mon Apr  6 14:52:38 2026] EXT4-fs (nvme0n1p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.6G    /var/
    441M    /var/cache
    440M    /var/log
    439M    /var/log/journal/ff5660355b0e4138b8b00244b401160e
    Archived and active journals take up 438.8M in the file system.
    /opt/iobroker/backups:
    7.4G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    644M    /opt/iobroker/iobroker-data/sqlite
    379M    /opt/iobroker/iobroker-data/files
    138M    /opt/iobroker/iobroker-data/backup-objects
    74M     /opt/iobroker/iobroker-data/files/vis
    644M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    45M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    16M     /opt/iobroker/iobroker-data/states.jsonl
    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IoBroker64Bit       IoBroker64Bit (version: 7.0.7, hostname: IoBroker64Bit , alive, uptime: 2099702)
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 1795707)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     10
    +-- iobroker.fully-tablet-control@0.3.8 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#ae07136c27d18a8b6ffa23763324d6f417e2ee97)
    +-- iobroker.niu@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.niu.git#bb6cc29dc1cea582643854c7b0183f3efc1aa6f4)
    +-- iobroker.nspanel-lovelace-ui@0.17.5 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#f4d905285401b1980e3235c9adb7f7a386482d2a)
    +-- iobroker.parcel@0.3.1 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#c579b7c8e878e72c56ae1c30c2fed9292b469895)
    +-- iobroker.pioneer_sc_vsx@0.1.0 (git+ssh://git@github.com/okeck1982/ioBroker.pioneer_sc_vsx.git#b74d0f748835d2c1c4b860d43a8e6a24939039ce)
    +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#97c61972c09ae9e53b157f4abc64e7e39efe617c)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#056daf7c0911a454ee3f4a0f7f3b329cf70222c2)
    +-- iobroker.spritmonitor@0.0.3-beta.2 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#43ee460516dc02b2dab881f2b00b306cc6f54cf6)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.vis-materialdesign@0.5.94 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#8b7529d493f223dfc4f1d1f632553fcb35bbcc92)
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
    + system.adapter.brightsky.0              : brightsky             : IoBroker64Bit                            -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8428
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
      system.adapter.luftdaten.0              : luftdaten             : IoBroker64Bit                            -  enabled
    + system.adapter.midea.0                  : midea                 : IoBroker64Bit                            -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.niu.0                    : niu                   : iobroker                                 -  enabled
    + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobroker                                 -  enabled
    + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
    + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
    + system.adapter.nuki.2                   : nuki                  : IoBroker64Bit                            -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
      system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
      system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
      system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
    + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
    + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
    + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartloadmanager.0       : smartloadmanager      : iobroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : IoBroker64Bit                            -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.spritmonitor.0           : spritmonitor          : iobroker                                 -  enabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name     │ url                                                  │ auto upgrade │
    │ 0       │ 'stable' │ 'http://iobroker.live/repo/sources-dist.json'        │ false        │
    │ 1       │ 'beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
    Adapter    "device-watcher": 2.15.5  , installed 2.15.5
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "ical"         : 1.20.0   , installed 1.19.7 [Updatable]
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
    Adapter    "niu"          : 0.0.3    , installed 0.0.3
    Adapter    "nspanel-lovelace-ui": 0.16.2, installed 0.17.5
    Adapter    "nut"          : 1.7.0    , installed 1.7.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "pi-hole"      : 2.0.0    , installed 2.0.0
    Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
    Adapter    "pvforecast"   : 5.1.0    , installed 5.1.0
    Adapter    "roborock"     : 0.6.18   , installed 0.6.19
    Adapter    "rpi2"         : 3.0.2    , installed 2.4.0  [Updatable]
    Adapter    "s7"           : 1.5.0    , installed 1.5.0
    Adapter    "sainlogic"    : 1.2.0    , installed 1.2.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "smartloadmanager": 0.1.0 , installed 0.1.0
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.17.0   , installed 3.16.0 [Updatable]
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
    Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "worx"         : 3.3.0    , installed 3.3.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        48697
    States:         41150
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Get:6 https://repos.influxdata.com/debian stable InRelease [6922 B]
    Fetched 6922 B in 1s (10.4 kB/s)
    Reading package lists...
    Pending systemupdates: 2
    *** Listening Ports ***
    tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       8580       1142/io.hm-rpc.2
    tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       8525       1106/io.hm-rpc.1
    tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       6013       1205/io.hm-rpc.3
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       7852       837/iobroker.js-con
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       4785       837/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8091412    577208/sshd: /usr/s
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       9363       1298/io.mqtt.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       9362       1298/io.mqtt.1
    tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       9288       1094/io.hm-rpc.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        7823       791/influxd
    tcp6       0      0 :::8883                 :::*                    LISTEN      1001       13171404   941201/io.nspanel-l
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8091414    577208/sshd: /usr/s
    tcp6       0      0 :::45000                :::*                    LISTEN      1001       2875791    202561/io.sainlogic
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        6580       791/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10655      1723/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       4807       857/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10926      1887/io.web.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6374       588/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       13364      1819/io.upnp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       9731       1486/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       9732       1486/io.tuya.0
    udp        0      0 0.0.0.0:40389           0.0.0.0:*                           104        6376       588/avahi-daemon: r
    udp6       0      0 fe80::a154:eb9:60c4:546 :::*                                0          7831       630/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        6375       588/avahi-daemon: r
    udp6       0      0 :::53558                :::*                                104        6377       588/avahi-daemon: r
    2026-04-27 09:25:53.683  - info: dwd.0 (1465948) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-04-27 09:25:54.201  - info: host.iobroker instance system.adapter.dwd.0 having pid 1465948 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-04-27 09:27:52.492  - info: sourceanalytix.0 (1739) Device reset detected for 0_userdata.0.PV_Ersparnis, feature disabled processing normally)
    2026-04-27 09:30:00.031  - info: host.iobroker instance system.adapter.ical.0 in version "1.19.7" started with pid 1466152
    2026-04-27 09:30:01.772  - info: ical.0 (1466152) starting. Version 1.19.7 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
    2026-04-27 09:30:02.822  - info: ical.0 (1466152) processing URL: Google https://calendar.google.com/calendar/ical/mferber83%40gmail.com/private-54e18925919b923d77c7864d1eaab115/basic.ics
    2026-04-27 09:30:08.462  - info: ical.0 (1466152) Terminated (NO_ERROR): Without reason
    2026-04-27 09:30:08.971  - info: host.iobroker instance system.adapter.ical.0 having pid 1466152 terminated with code 0 (NO_ERROR)
    2026-04-27 09:30:30.462  - info: sourceanalytix.0 (1739) Device reset detected for 0_userdata.0.PV_Ersparnis, feature disabled processing normally)
    2026-04-27 09:30:51.019  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 1466212
    2026-04-27 09:30:52.833  - info: dwd.0 (1466212) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.2, js-controller: 7.0.7
    2026-04-27 09:30:53.658  - info: dwd.0 (1466212) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-04-27 09:30:54.169  - info: host.iobroker instance system.adapter.dwd.0 having pid 1466212 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-04-27 09:33:08.405  - info: sourceanalytix.0 (1739) Device reset detected for 0_userdata.0.PV_Ersparnis, feature disabled processing normally)
    2026-04-27 09:35:46.368  - info: sourceanalytix.0 (1739) Device reset detected for 0_userdata.0.PV_Ersparnis, feature disabled processing normally)
    2026-04-27 09:35:51.019  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 1466452
    2026-04-27 09:35:52.650  - info: dwd.0 (1466452) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.2, js-controller: 7.0.7
    2026-04-27 09:35:53.228  - info: dwd.0 (1466452) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-04-27 09:35:53.738  - info: host.iobroker instance system.adapter.dwd.0 having pid 1466452 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-04-27 09:38:24.359  - info: sourceanalytix.0 (1739) Device reset detected for 0_userdata.0.PV_Ersparnis, feature disabled processing normally)
    2026-04-27 09:40:51.020  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 1466740
    2026-04-27 09:40:53.477  - info: dwd.0 (1466740) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.2, js-controller: 7.0.7
    2026-04-27 09:40:54.336  - info: dwd.0 (1466740) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-04-27 09:40:55.585  - info: host.iobroker instance system.adapter.dwd.0 having pid 1466740 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-04-27 09:41:02.290  - info: sourceanalytix.0 (1739) Device reset detected for 0_userdata.0.PV_Ersparnis, feature disabled processing normally)
    • MichaelFM Online
      MichaelFM Online
      MichaelF
      Der Slave:
      Script v.2026-01-31
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 11 (bullseye)
         Static hostname: IoBroker64Bit
               Icon name: computer
                  Kernel: Linux 6.1.25-v8+
            Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
       09:43:37 up 24 days,  7:18,  1 user,  load average: 0.72, 0.34, 0.23
      CPU threads: 4
      Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
      Current issues:
                     Local time: Mon 2026-04-27 09:43:37 CEST
                 Universal time: Mon 2026-04-27 07:43:37 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      Display-Manager:        * lightdm.service - Light Display Manager
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            1.8G        811M         56M        0.0K        980M        968M
      Swap:            99M         99M        0.0K
      Total:          1.9G        910M         57M
               1848 M total memory
                811 M used memory
                713 M active memory
                964 M inactive memory
                 59 M free memory
                  1 M buffer memory
                976 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      top - 09:44:01 up 24 days,  7:18,  1 user,  load average: 0.95, 0.42, 0.26
      Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  1.4 us,  1.4 sy,  0.0 ni, 97.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   1848.2 total,     59.0 free,    812.2 used,    977.0 buff/cache
      MiB Swap:    100.0 total,      0.2 free,     99.8 used.    968.0 avail Mem
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4      117G  9.4G  102G   9% /
      devtmpfs       devtmpfs  667M     0  667M   0% /dev
      tmpfs          tmpfs     925M     0  925M   0% /dev/shm
      tmpfs          tmpfs     370M  1.2M  369M   1% /run
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     185M   16K  185M   1% /run/user/1000
      [Fri Apr  3 02:25:20 2026] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Apr  3 02:25:20 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Apr  3 02:25:22 2026] EXT4-fs (sda2): re-mounted. Quota mode: none.
      /       /dev/sda2 ext4   rw,noatime,stripe=8191
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.1G    /var/
      1.6G    /var/log/journal/122b3afb23014f43b9b08ad8562e656b
      1.6G    /var/log
      1.3G    /var/cache/apt
      Archived and active journals take up 1.5G in the file system.
      4.0K    /opt/iobroker/backups/
      17M     /opt/iobroker/iobroker-data/
      14M     /opt/iobroker/iobroker-data/files
      13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      2.9M    /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      USB-Devices by-id:
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      nodejs:
        Version table:
           12.22.12~dfsg-1~deb11u7 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      ioBroker Status
      At least one iobroker host is running.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      IoBroker64Bit       IoBroker64Bit (version: 7.0.7, hostname: IoBroker64Bit , alive, uptime: 2099897)
      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 1795902)
      admin:          "admin" not found
      javascript:     "javascript" not found
      nodejs modules from github:     3
      +-- iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#5e1839b1adece7fbc92213409f953417a1907475)
      +-- iobroker.mihome-vacuum@5.3.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.mihome-vacuum.git#6a4bbbd5642a972e70e715faaee7bad2b769d2ea)
      +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
      Adapter State
      + instance is alive
      Adapter    "brightsky"    : 1.0.1    , installed 1.0.1
      Adapter    "envertech-pv" : 1.5.1    , installed 1.5.1
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "midea"        : 0.0.7    , installed 0.1.0
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
      Objects and States
      Objects:        48697
      States:         41159
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Pending systemupdates: 44
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       14921      910/io.sonoff.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8510214    1935133/cupsd
      tcp        0      0 192.168.178.76:9091     0.0.0.0:*               LISTEN      1001       15649      840/io.nuki.0
      tcp        0      0 192.168.178.76:9092     0.0.0.0:*               LISTEN      1001       16429      852/io.nuki.1
      tcp        0      0 192.168.178.76:9093     0.0.0.0:*               LISTEN      1001       15697      864/io.nuki.2
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14125      562/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14127      562/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8510213    1935133/cupsd
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15506      458/dhcpcd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15595      828/io.mihome-vacuu
      udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       15889      926/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1684       389/avahi-daemon: r
      udp        0      0 0.0.0.0:54077           0.0.0.0:*                           108        1686       389/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        1685       389/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14656      458/dhcpcd
      udp6       0      0 :::42713                :::*                                108        1687       389/avahi-daemon: r
      2026-04-27 09:36:35.015  - info: nuki.0 (840) Lock list requested: http://192.168.178.8:8080/list?ts=2026-04-27T07:36:34Z&rnr=34199&hash=fce3fd3483fa26fb70527d08a93286e224120d4d77943411fc0e7319bbfc6807
      2026-04-27 09:36:44.038  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 1967094
      2026-04-27 09:36:46.949  - info: luftdaten.0 (1967094) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
      2026-04-27 09:36:47.375  - info: luftdaten.0 (1967094) Terminated (NO_ERROR): Without reason
      2026-04-27 09:36:47.913  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 1967094 terminated with code 0 (NO_ERROR)
      2026-04-27 09:38:44.018  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 1967194
      2026-04-27 09:38:47.021  - info: luftdaten.0 (1967194) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
      2026-04-27 09:38:47.282  - info: luftdaten.0 (1967194) Terminated (NO_ERROR): Without reason
      2026-04-27 09:38:47.820  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 1967194 terminated with code 0 (NO_ERROR)
      2026-04-27 09:38:53.608  - info: nuki.2 (864) Bridge Info requested: http://192.168.178.42:8080/info?ts=2026-04-27T07:38:52Z&rnr=43464&hash=6bcca6cf98871bb30ef81676be7901e52b8815b1f4a372ce7ed3026b7509f4d3
      2026-04-27 09:38:56.048  - info: nuki.2 (864) Lock list requested: http://192.168.178.42:8080/list?ts=2026-04-27T07:38:55Z&rnr=29868&hash=704715cbf5da8e92682444c8bc9c360fd24f0bcab1f94c29ae9328f68e064ff3
      2026-04-27 09:40:44.038  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 1967292
      2026-04-27 09:40:46.979  - info: luftdaten.0 (1967292) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
      2026-04-27 09:40:47.231  - info: luftdaten.0 (1967292) Terminated (NO_ERROR): Without reason
      2026-04-27 09:40:47.772  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 1967292 terminated with code 0 (NO_ERROR)
      2026-04-27 09:41:41.700  - info: nuki.1 (852) Bridge Info requested: http://192.168.178.9:8080/info?ts=2026-04-27T07:41:41Z&rnr=19071&hash=1c057601bc06302b73e3e148d1c02f9d8fab5b718e26789080d237789895e437
      2026-04-27 09:41:44.670  - info: nuki.1 (852) Lock list requested: http://192.168.178.9:8080/list?ts=2026-04-27T07:41:44Z&rnr=6175&hash=d8f8305e380e81d39886266c6768ada5354ece367137d311fe63e60bcedaf74c
      2026-04-27 09:42:44.034  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 1967403
      2026-04-27 09:42:47.014  - info: luftdaten.0 (1967403) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
      2026-04-27 09:42:47.289  - info: luftdaten.0 (1967403) Terminated (NO_ERROR): Without reason
      2026-04-27 09:42:47.822  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 1967403 terminated with code 0 (NO_ERROR)
      2026-04-27 09:44:44.190  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 1967933
      2026-04-27 09:44:47.387  - info: luftdaten.0 (1967933) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
      2026-04-27 09:44:47.766  - info: luftdaten.0 (1967933) Terminated (NO_ERROR): Without reason
      2026-04-27 09:44:48.325  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 1967933 terminated with code 0 (NO_ERROR)
      • MichaelFM MichaelF
        Der Slave:
        Script v.2026-01-31
        *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:            99M         99M        0.0K
                 1848 M total memory
                  811 M used memory
                  713 M active memory
                   59 M free memory
                    1 M buffer memory
                  976 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        3.1G    /var/
        1.6G    /var/log
        1.3G    /var/cache/apt
        USB-Devices by-id:
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        Adapter State
        + instance is alive
        Objects and States
        Objects:        48697
        States:         41159
        @MichaelF
        Zum Master:
        Betreibst du den mit einem gescheiten NETZTEIL?
        Sieht nämlich nicht so aus. Auch die
        anschauen!
        Arbeitsspeicher ist ziemlich ausgelastet.
        Du setzt viel zu viele Adapter aus GitHub ein. Bring die mal auf die Versionen aus den Repos.
        Wenn die Spannungsversorgung stabilisiert ist und die critical errors behoben sind sollte das System aber mit dem üblichen Verfahren auf Debian 13 'Trixie' zu hieven sein.
        Zum Slave:
        Sprung von RaspberryOS 11 auf 13 zu groß, ein Upgrade ist auch über einen Zwischenschritt über Raspberry12 nicht sauber möglich: Neuinstallation.
        • MichaelFM Online
          MichaelFM Online
          MichaelF
          Danke für die schnelle Antwort!
          [Do Apr 16 17:17:17 2026] hwmon hwmon3: Undervoltage detected!
          [So Apr 19 15:33:49 2026] hwmon hwmon3: Undervoltage detected!
          [So Apr 19 18:35:16 2026] hwmon hwmon3: Undervoltage detected!
          [So Apr 19 21:04:25 2026] hwmon hwmon3: Undervoltage detected!
          [Mo Apr 20 19:56:20 2026] hwmon hwmon3: Undervoltage detected!
          [Mo Apr 20 23:12:35 2026] hwmon hwmon3: Undervoltage detected!
          [Mi Apr 22 14:11:38 2026] hwmon hwmon3: Undervoltage detected!
          muss ich echt mal nach dem Netzteil schauen, eigentlich sollte das groß genug sein.
          Der Pi läuft seit Ewigkeiten Fehlerfrei daher hatte ich so nie danach geschaut.
          Also kann ich dann quasi deine Anleitung für das update auf Trixie nutzen.
          Zum slave, neues Betriebssystem installieren, iobroker installieren, wenn die Ip Adressen gleich bleiben erkennt der Master diesen alleine?
          • MichaelFM Online
            MichaelFM Online
            MichaelF
            Hi, habe heute den Master auf trixie gebracht.
            Script v.2026-01-31
            *** BASE SYSTEM ***
            Operating System: Debian GNU/Linux 13 (trixie)
                   Icon name: computer
                      Kernel: Linux 6.18.29+rpt-rpi-2712
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
             21:49:00 up 12 min,  1 user,  load average: 0.95, 1.84, 1.47
            CPU threads: 4
            Operating System is the current Debian stable version codenamed 'trixie'!
            Current issues:
                           Local time: Sat 2026-05-16 21:49:00 CEST
                       Universal time: Sat 2026-05-16 19:49:00 UTC
                             RTC time: Sat 2026-05-16 19:49:00
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            SUDO_HOME=/home/pi
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:            8.5G        4.9G        2.0G         24M        1.6G        3.5G
            Swap:           536M          0B        536M
            Total:          9.0G        4.9G        2.6G
                     8062 M total memory
                     4697 M used memory
                     4392 M active memory
                     1151 M inactive memory
                     1927 M free memory
                      202 M buffer memory
                     1345 M swap cache
                      511 M total swap
                        0 M used swap
                      511 M free swap
            top - 21:49:00 up 12 min,  1 user,  load average: 0.95, 1.84, 1.47
            Tasks: 223 total,   3 running, 220 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 28.6 us,  0.0 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8062.4 total,   1925.5 free,   4699.2 used,   1547.9 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3363.2 avail Mem
            *** FILESYSTEM ***
            tmpfs          tmpfs     807M   15M  793M   2% /run
            /dev/nvme0n1p2 ext4      235G   18G  205G   8% /
            tmpfs          tmpfs     4.0G  9.2M  4.0G   1% /tmp
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
            /dev/nvme0n1p1 vfat      510M   66M  445M  13% /boot/firmware
            tmpfs          tmpfs     807M   32K  807M   1% /run/user/1000
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
            tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
            [Sat May 16 21:36:11 2026] EXT4-fs (nvme0n1p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
            [Sat May 16 21:36:12 2026] EXT4-fs (nvme0n1p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
            /var:
            1.4G    /var/
            499M    /var/log
            497M    /var/log/journal/ff5660355b0e4138b8b00244b401160e
            208M    /var/lib
            Archived and active journals take up 505.5M in the file system.
            8.3G    /opt/iobroker/backups/
            1.4G    /opt/iobroker/iobroker-data/
            650M    /opt/iobroker/iobroker-data/sqlite
            142M    /opt/iobroker/iobroker-data/backup-objects
            73M     /opt/iobroker/iobroker-data/files/vis
            650M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
            114M    /opt/iobroker/iobroker-data/states.jsonl
            64M     /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            /usr/bin/npm            10.9.7
            /usr/bin/npx            10.9.7
            nodejs:
              Version table:
                 20.19.2+dfsg-1+deb13u2 500
                    500 http://deb.debian.org/debian trixie/main arm64 Packages
                    500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            IoBroker64Bit       IoBroker64Bit (version: 7.0.7, hostname: IoBroker64Bit , alive, uptime: 700)
            iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 762)
            admin:          7.8.23
            javascript:     9.0.18
            nodejs modules from github:     8
            +-- iobroker.nspanel-lovelace-ui@0.17.8 (git+ssh://git@github.com/ticaki/ioBroker.nspanel-lovelace-ui.git#58bb65c680944e140dec6f22e98780b3fe3e35c1)
            Adapter State
            + instance is alive
            Adapter    "admin"        : 7.8.23   , installed 7.8.23
            Adapter    "ical"         : 1.20.0   , installed 1.20.0
            Adapter    "nspanel-lovelace-ui": 0.16.2, installed 0.17.8
            Adapter    "pvforecast"   : 6.1.0    , installed 6.1.0
            Adapter    "roborock"     : 0.6.18   , installed 0.6.18
            Adapter    "socketio"     : 7.1.3    , installed 7.1.3
            Adapter    "tuya"         : 3.17.0   , installed 3.17.0
            Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
            Objects and States
            Objects:        50419
            States:         42673
            [3~
            W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
            W: Failed to fetch https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
            W: Some index files failed to download. They have been ignored, or old ones used instead.
            Hit:1 http://deb.debian.org/debian trixie InRelease
            Hit:2 http://deb.debian.org/debian-security trixie-security InRelease
            Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
            Hit:4 http://deb.debian.org/debian trixie-updates InRelease
            Err:5 https://deb.nodesource.com/node_22.x nodistro InRelease
            Fetched 6922 B in 1s (12.7 kB/s)
            Pending systemupdates: 0
            tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       10659      1508/io.hm-rpc.3
            tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       10090      1409/io.hm-rpc.1
            tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       10096      1435/io.hm-rpc.2
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       10820      1545/io.mqtt.1
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       10819      1545/io.mqtt.1
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7398       779/sshd: /usr/sbin
            tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       12739      1397/io.hm-rpc.0
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       8496       1163/iobroker.js-co
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       6121       1163/iobroker.js-co
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7573       1047/exim4
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        9558       1099/influxd
            tcp6       0      0 :::22                   :::*                    LISTEN      0          7400       779/sshd: /usr/sbin
            tcp6       0      0 :::8883                 :::*                    LISTEN      1001       26650      3147/io.nspanel-lov
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7574       1047/exim4
            tcp6       0      0 :::45000                :::*                    LISTEN      1001       16196      2465/io.sainlogic.0
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       17195      2542/io.simple-api.
            tcp6       0      0 :::8086                 :::*                    LISTEN      999        9594       1099/influxd
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19349      2774/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10266      1183/io.admin.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1993       593/avahi-daemon: r
            udp        0      0 0.0.0.0:59155           0.0.0.0:*                           104        1995       593/avahi-daemon: r
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       23221      2683/io.upnp.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       16573      1865/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       16574      1865/io.tuya.0
            udp6       0      0 fe80::a154:eb9:60c4:546 :::*                                0          9617       617/NetworkManager
            udp6       0      0 :::5353                 :::*                                104        1994       593/avahi-daemon: r
            udp6       0      0 :::56564                :::*                                104        1996       593/avahi-daemon: r
            2026-05-16 21:47:22.766  - info: host.iobroker iobroker gyp info spawn args   '-Dnode_engine=v8',gyp info spawn args   '--depth=.',gyp info spawn args   '--no-parallel',gyp info spawn args   '--generator-output',gyp info spawn args   'build',gyp info spawn args   '-Goutput_dir=.'gyp info spawn args ]
            2026-05-16 21:47:22.815  - info: host.iobroker iobroker Traceback (most recent call last):  File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>    import gyp  # noqa: E402    ^^^^^^^^^^  File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>    import gyp.input  File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>    from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'
            2026-05-16 21:47:22.834  - info: host.iobroker iobroker gyp ERR! configure error
            2026-05-16 21:47:22.834  - info: host.iobroker iobroker gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack     at ChildProcess.emit (node:events:519:28)gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)gyp ERR! System Linux 6.18.29+rpt-rpi-2712
            2026-05-16 21:47:22.835  - info: host.iobroker iobroker gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.22.2gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
            2026-05-16 21:47:22.863  - info: host.iobroker iobroker npm error code 1
            2026-05-16 21:47:22.864  - info: host.iobroker iobroker npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuild
            2026-05-16 21:47:22.866  - info: host.iobroker iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-16T19_47_19_128Z-debug-0.log
            2026-05-16 21:47:25.467  - info: host.iobroker iobroker Updating objects from io-package.json for adapter "rpi2" with version "2.4.0"
            2026-05-16 21:47:26.850  - info: host.iobroker iobroker upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
            2026-05-16 21:47:26.854  - info: host.iobroker iobroker upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
            2026-05-16 21:47:26.857  - info: host.iobroker iobroker upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
            2026-05-16 21:47:26.860  - info: host.iobroker iobroker upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            2026-05-16 21:47:26.863  - info: host.iobroker iobroker upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
            2026-05-16 21:47:26.866  - info: host.iobroker iobroker upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            2026-05-16 21:47:26.868  - info: host.iobroker iobroker upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            2026-05-16 21:47:26.871  - info: host.iobroker iobroker upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            2026-05-16 21:47:26.876  - info: host.iobroker iobroker upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            2026-05-16 21:47:26.882  - info: host.iobroker iobroker upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
            2026-05-16 21:47:26.887  - info: host.iobroker iobroker upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            2026-05-16 21:47:26.889  - info: host.iobroker iobroker upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
            2026-05-16 21:47:26.893  - info: host.iobroker iobroker upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
            2026-05-16 21:47:26.896  - info: host.iobroker iobroker upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
            2026-05-16 21:47:27.908  - info: host.iobroker iobroker exit 0
            2026-05-16 21:47:36.511  - info: javascript.0 (3856) script.js.Licht_Flur: true
            Bei :
            sudo apt update
            Hab ich noch fogendes:
            pi@iobroker:~ $ sudo apt update
            OK:1 http://deb.debian.org/debian trixie InRelease
            OK:2 http://deb.debian.org/debian-security trixie-security InRelease
            OK:3 http://deb.debian.org/debian trixie-updates InRelease
            OK:4 http://archive.raspberrypi.com/debian trixie InRelease
            OK:5 https://deb.nodesource.com/node_22.x nodistro InRelease
            Fehl:5 https://deb.nodesource.com/node_22.x nodistro InRelease
            Holen:6 https://repos.influxdata.com/debian stable InRelease [6.922 B]
            Es wurden 6.922 B in 1 s geholt (11,7 kB/s).
            Alle Pakete sind aktuell.
            Warnung: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. OpenPGP-Signaturüberprüfung fehlgeschlagen: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
            Warnung: Fehlschlag beim Holen von https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
            Warnung: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.
            Hinweis: Fehlendes Signed-By im Eintrag sources.list(5) für »http://archive.raspberrypi.com/debian«
            • MichaelFM Online
              MichaelFM Online
              MichaelF
              Und ein Update macht er leider nicht vom Rpi Adapter, mit :
              $ iobroker upgrade rpi2@3.0.2 --debug
              Update rpi2 from @2.4.0 to @3.0.2
              NPM version: 10.9.7
              Installing iobroker.rpi2@3.0.2... (System call)
              > iobroker.rpi2@3.0.2 preinstall> bash ./preinstall-check.sh
              Checking package: libgpiod-dev >= 2.2
              libgpiod-dev version OK: 2.2.1-2+deb13u1
              > opengpio@2.0.2 install> node-gyp rebuild
              gyp info it worked if it ends with okgyp info using node-gyp@8.4.1gyp info using node@22.22.2 | linux | arm64
              (node:5451) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
              gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
              gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/opengpio/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/22.22.2/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.22.2',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.22.2/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
              gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack at ChildProcess.emit (node:events:519:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:293:12)gyp ERR! System Linux 6.18.29+rpt-rpi-2712gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/opengpiogyp ERR! node -v v22.22.2gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-16T19_52_10_075Z-debug-0.log
              Process exited with code 0
                Script v.2026-01-31
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                SUDO_HOME=/home/pi
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Swap:           536M          0B        536M
                         8062 M total memory
                         4697 M used memory
                         1927 M free memory
                          202 M buffer memory
                         1345 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                *** FILESYSTEM ***
                /var:
                1.4G    /var/
                499M    /var/log
                208M    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.9.7
                /usr/bin/npx            10.9.7
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.8.23
                javascript:     9.0.18
                Adapter State
                + instance is alive
                Objects and States
                Objects:        50419
                States:         42673
                [3~
                Bei :
                sudo apt update
                @MichaelF
                iob nodejs-update 22
                Künftig dann regelmäßiger updaten, die Meldung muss dir schon Monate um die Ohren fliegen.
                Und von einem mit Meldungen verzierten apt macht man auch kein Dist-Upgrade.
                Die zweite Meldung ist auch keine Unbekannte. Benutz mal die Suchfunktion.
                €dit:
                sudo apt install python3-setuptools
                • MichaelFM Online
                  MichaelFM Online
                  MichaelF
                  Riesen danke für die schnelle Antwort:
                  pi@iobroker:~ $ iob nodejs-update 22
                  Valid major version. CUSTOM installation of nodejs v22
                  ioBroker nodejs-update v2026-01-31 is starting. Please be patient!
                  ioBroker nodejs fixer 2026-01-31
                  You requested to install latest version from nodejs v22 tree.
                  Your current setup is:
                  /usr/bin/npm            10.9.7
                  /usr/bin/npx            10.9.7
                  We found these nodejs versions available for installation:
                  nodejs:
                    Version table:
                  Nothing to do - Your installation is using the correct paths.
                  You are missing the nodesource.list or
                  you want to change your current nodejs version: v22.22.2 ?
                  Press <y> to continue or any other key to quit
                  We are not fixing your installation. Exiting.
                  Ist leider immer noch da
                  pi@iobroker:~ $
                  Nach der zweiten Meldung bin ich noch am suchen
                    /usr/bin/npm            10.9.7
                    /usr/bin/npx            10.9.7
                    nodejs:
                      Version table:
                    pi@iobroker:~ $
                    @MichaelF sagte:
                    Das solltest du bejahen...
                      /usr/bin/npm            10.9.7
                      /usr/bin/npx            10.9.7
                      nodejs:
                        Version table:
                      pi@iobroker:~ $
                      @MichaelF sagte:
                      MichaelFM 1 Antwort Letzte Antwort
                      • MichaelFM Online
                        MichaelFM Online
                        MichaelF
                        Sorry............
                        Hat geklappt, ich hätte schwören können das ich
                        y
                        gedrückt hatte.....
                        Danke nochmal
                          @MichaelF sagte:
                          MichaelFM Online
                          MichaelFM Online
                          MichaelF
                          @Thomas-Braun sagte:
                          @MichaelF sagte:
                          Auch gefunden, geht jetzt auch.
                          • MichaelFM Online
                            MichaelFM Online
                            MichaelF
                            Nochmal ein glaube ich doofe frage zum slave.
                            Trixie direkt auf die ssd, iobroker installieren, muss ich dann ein Backup einspielen das der Master wieder weiß das der Slave neu ist ?
                            Also wie kommen die Adapter wieder auf den Slave.
                            Das wäre das das Projekt für morgen
                            • MichaelFM Online
                              MichaelFM Online
                              MichaelF
                              schrieb am zuletzt editiert von MichaelF
                              Hi, habe gestern versucht den Slave von bullsseye auf bookworm über die Konsole zu bekommen.
                              Hat anscheinend auch soweit geklappt, einen Fehler hatte ich beim update des Kernels aber mit Hilfe von chatgpt behoben bekommen.
                              Kann man jetzt von hier aus auf Trixie ?
                              Ich hatte mich gescheut weil das voll die Katastrophe war den Pi4 von SD booten zu lassen, daher über die Konsole.
                              Script v.2026-01-31
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                        Kernel: Linux 6.12.87+rpt-rpi-v8
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                               01:36:10 up 4 days, 19 min,  2 users,  load average: 0.75, 0.49, 0.34
                              CPU threads: 4
                              Current issues:
                                             Local time: Thu 2026-05-21 01:36:10 CEST
                                         Universal time: Wed 2026-05-20 23:36:10 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Mem:            1.9G        789M         94M         32K        1.1G        1.1G
                              Swap:           209M        207M        2.3M
                              Total:          2.1G        996M         96M
                                       1844 M total memory
                                        751 M used memory
                                        813 M active memory
                                        814 M inactive memory
                                         89 M free memory
                                          2 M buffer memory
                                       1068 M swap cache
                                        199 M total swap
                                        197 M used swap
                                          2 M free swap
                              top - 01:36:30 up 4 days, 20 min,  2 users,  load average: 1.20, 0.60, 0.38
                              Tasks: 200 total,   3 running, 197 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  7.7 us, 38.5 sy,  0.0 ni, 38.5 id,  7.7 wa,  0.0 hi,  7.7 si,  0.0 st
                              MiB Mem :   1844.7 total,    113.7 free,    758.8 used,   1056.7 buff/cache
                              MiB Swap:    200.0 total,      0.0 free,    200.0 used.   1085.9 avail Mem
                              *** FILESYSTEM ***
                              /dev/root      ext4      117G  9.7G  101G   9% /
                              devtmpfs       devtmpfs  664M     0  664M   0% /dev
                              tmpfs          tmpfs     923M     0  923M   0% /dev/shm
                              tmpfs          tmpfs     369M  1.2M  368M   1% /run
                              tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                              /dev/sda1      vfat      253M  102M  152M  41% /boot/firmware
                              tmpfs          tmpfs     185M   40K  185M   1% /run/user/1000
                              [Sun May 17 01:16:23 2026] EXT4-fs (sda2): mounted filesystem 1b73c456-a078-49d1-a94b-759928005fb9 ro with ordered data mode. Quota mode: none.
                              [Sun May 17 01:16:23 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                              [Sun May 17 01:16:24 2026] EXT4-fs (sda2): re-mounted 1b73c456-a078-49d1-a94b-759928005fb9 r/w.
                              `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              2.1G    /var/
                              1.5G    /var/log/journal/122b3afb23014f43b9b08ad8562e656b
                              1.5G    /var/log
                              264M    /var/lib
                              Archived and active journals take up 1.4G in the file system.
                              USB-Devices by-id:
                              /usr/bin/npm            10.9.7
                              /usr/bin/npx            10.9.7
                              nodejs:
                                Version table:
                                   18.20.4+dfsg-1~deb12u2 500
                                      500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              IoBroker64Bit       IoBroker64Bit (version: 7.0.7, hostname: IoBroker64Bit , alive, uptime: 346780)
                              iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 360017)
                              nodejs modules from github:     2
                              +-- iobroker.midea@1.7.1 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#649a929d1d81a2fc5f30d362b4080729065c0c89)
                              Adapter State
                              + instance is alive
                              Adapter    "midea"        : 0.0.7    , installed 1.7.1
                              Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                              Objects and States
                              Objects:        51262
                              States:         43342
                              Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                              Hit:2 http://deb.debian.org/debian bookworm InRelease
                              Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1317231    342939/cupsd
                              tcp        0      0 192.168.178.76:9091     0.0.0.0:*               LISTEN      1001       7350       1020/io.nuki.0
                              tcp        0      0 192.168.178.76:9093     0.0.0.0:*               LISTEN      1001       6955       1060/io.nuki.2
                              tcp        0      0 192.168.178.76:9092     0.0.0.0:*               LISTEN      1001       9250       1044/io.nuki.1
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6669       653/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       6949       1129/io.sonoff.0
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1317230    342939/cupsd
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          6671       653/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6700       490/dhcpcd: [master
                              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       15808      3750/io.mihome-vacu
                              udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       8387       1145/io.tr-064.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        5704       403/avahi-daemon: r
                              udp        0      0 0.0.0.0:49490           0.0.0.0:*                           108        5706       403/avahi-daemon: r
                              udp6       0      0 :::546                  :::*                                0          6713       490/dhcpcd: [master
                              udp6       0      0 :::50293                :::*                                108        5707       403/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                108        5705       403/avahi-daemon: r
                              2026-05-21 01:28:51.546  - info: luftdaten.0 (348020) Terminated (NO_ERROR): Without reason
                              2026-05-21 01:28:52.079  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348020 terminated with code 0 (NO_ERROR)
                              2026-05-21 01:30:48.032  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 348121
                              2026-05-21 01:30:51.071  - info: luftdaten.0 (348121) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                              2026-05-21 01:30:52.258  - info: luftdaten.0 (348121) Terminated (NO_ERROR): Without reason
                              2026-05-21 01:30:52.789  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348121 terminated with code 0 (NO_ERROR)
                              2026-05-21 01:32:25.460  - info: nuki.1 (1044) Bridge Info requested: http://192.168.178.9:8080/info?ts=2026-05-20T23:32:22Z&rnr=27316&hash=533df9fcd0503733085c12c4251add735065649b46d28aebfa0c51923c13b1cf
                              2026-05-21 01:32:25.594  - info: nuki.1 (1044) Lock list requested: http://192.168.178.9:8080/list?ts=2026-05-20T23:32:25Z&rnr=43402&hash=8b439ad061d56055ac8b22f95ecc91bc291ed35d236032c6e98f591125951e65
                              2026-05-21 01:32:48.084  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 348254
                              2026-05-21 01:32:51.046  - info: luftdaten.0 (348254) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                              2026-05-21 01:32:51.316  - info: luftdaten.0 (348254) Terminated (NO_ERROR): Without reason
                              2026-05-21 01:32:51.850  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348254 terminated with code 0 (NO_ERROR)
                              2026-05-21 01:33:26.474  - info: nuki.2 (1060) Bridge Info requested: http://192.168.178.42:8080/info?ts=2026-05-20T23:33:26Z&rnr=36514&hash=428ed57d26051b73fb1a184504c7ca0dd57e99904ba2b6a17fa43bee5d1cbf20
                              2026-05-21 01:33:29.454  - info: nuki.2 (1060) Lock list requested: http://192.168.178.42:8080/list?ts=2026-05-20T23:33:29Z&rnr=44900&hash=ad66503f52be3482d9b2ced152e2dadf83fb3b5496944249e3b70cc7fcb94b79
                              2026-05-21 01:34:33.386  - info: midea.0 (303716) LanClient[152832116580279]: LAN authentication succeeded (tcpKey 32 bytes)
                              2026-05-21 01:34:48.048  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 348410
                              2026-05-21 01:34:51.286  - info: luftdaten.0 (348410) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                              2026-05-21 01:34:51.557  - info: luftdaten.0 (348410) Terminated (NO_ERROR): Without reason
                              2026-05-21 01:34:52.088  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348410 terminated with code 0 (NO_ERROR)
                              2026-05-21 01:36:48.149  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 348926
                              2026-05-21 01:36:51.870  - info: luftdaten.0 (348926) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                              2026-05-21 01:36:52.299  - info: luftdaten.0 (348926) Terminated (NO_ERROR): Without reason
                              2026-05-21 01:36:52.837  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 348926 terminated with code 0 (NO_ERROR)
                              2026-05-21 01:37:19.268  - info: nuki.0 (1020) Bridge Info requested: http://192.168.178.8:8080/info?ts=2026-05-20T23:37:19Z&rnr=24839&hash=eaea45e2c6d912f6f9d33796ed76e7ea1829014191e7054ec06272458ce5739f
                              2026-05-21 01:37:22.221  - info: nuki.0 (1020) Lock list requested: http://192.168.178.8:8080/list?ts=2026-05-20T23:37:22Z&rnr=24706&hash=2e856b3bcbbd307d93255806c355bf53402cfcb1ec053eab174231d2b3864135
                              pi@IoBroker64Bit:~ $ cat /etc/debian_version
                              12.14
                              pi@IoBroker64Bit:~ $ uname -a
                              Linux IoBroker64Bit 6.12.87+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.87-1+rpt1~bookworm (2026-05-12) aarch64 GNU/Linux
                                Script v.2026-01-31
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                CPU threads: 4
                                Current issues:
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                pi
                                HOME=/home/pi
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Session:                tty
                                *** MEMORY ***
                                         1844 M total memory
                                          751 M used memory
                                          813 M active memory
                                           89 M free memory
                                            2 M buffer memory
                                         1068 M swap cache
                                          199 M total swap
                                          197 M used swap
                                            2 M free swap
                                *** FILESYSTEM ***
                                /var:
                                2.1G    /var/
                                1.5G    /var/log
                                264M    /var/lib
                                USB-Devices by-id:
                                /usr/bin/npm            10.9.7
                                /usr/bin/npx            10.9.7
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        51262
                                States:         43342
                                12.14
                                @MichaelF sagte:
                                Probier es aus.
                                • MichaelFM Online
                                  MichaelFM Online
                                  MichaelF
                                  Hat geklappt, der Slave hat jetzt auch Trixie
                                  Script v.2026-01-31
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                            Kernel: Linux 6.18.29+rpt-rpi-v8
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  Systemuptime and Load:
                                   18:44:46 up 11 min,  1 user,  load average: 1.17, 1.03, 0.63
                                  CPU threads: 4
                                  *** LIFE CYCLE STATUS ***
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  *** TIME AND TIMEZONES ***
                                                 Local time: Thu 2026-05-21 18:44:46 CEST
                                             Universal time: Thu 2026-05-21 16:44:46 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** Users and Groups ***
                                  User that called 'iob diag':
                                  pi
                                  HOME=/home/pi
                                  iobroker
                                  HOME=/home/iobroker
                                  SUDO_HOME=/home/pi
                                  *** DISPLAY-SERVER SETUP ***
                                  Display-Server:         false
                                  Desktop:
                                  Session:                tty
                                  *** MEMORY ***
                                  Mem:            1.9G        722M         97M        3.7M        1.2G        1.2G
                                  Swap:           209M        204M        5.6M
                                  Total:          2.1G        926M        103M
                                  Active iob-Instances:   59
                                           1843 M total memory
                                            690 M used memory
                                           1561 M active memory
                                             49 M inactive memory
                                             92 M free memory
                                              2 M buffer memory
                                           1130 M swap cache
                                            199 M total swap
                                            194 M used swap
                                              5 M free swap
                                  top - 18:45:06 up 11 min,  1 user,  load average: 1.44, 1.10, 0.66
                                  Tasks: 193 total,   1 running, 192 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  6.0 us,  6.0 sy,  0.0 ni, 84.0 id,  4.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   1843.7 total,     91.6 free,    689.5 used,   1134.2 buff/cache
                                  MiB Swap:    200.0 total,      5.9 free,    194.0 used.   1154.3 avail Mem
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** DMESG CRITICAL ERRORS ***
                                  *** FILESYSTEM ***
                                  /dev/root      ext4      117G   11G  101G  10% /
                                  devtmpfs       devtmpfs  665M     0  665M   0% /dev
                                  tmpfs          tmpfs     922M     0  922M   0% /dev/shm
                                  tmpfs          tmpfs     369M  5.9M  363M   2% /run
                                  tmpfs          tmpfs     922M  2.6M  920M   1% /tmp
                                  /dev/sda1      vfat      253M  101M  152M  40% /boot/firmware
                                  tmpfs          tmpfs     185M   72K  185M   1% /run/user/1000
                                  [Thu May 21 18:33:38 2026] EXT4-fs (sda2): mounted filesystem 1b73c456-a078-49d1-a94b-759928005fb9 ro with ordered data mode. Quota mode: none.
                                  [Thu May 21 18:33:38 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                  [Thu May 21 18:33:40 2026] EXT4-fs (sda2): re-mounted 1b73c456-a078-49d1-a94b-759928005fb9 r/w.
                                  Show mounted filesystems:
                                  TARGET           SOURCE    FSTYPE OPTIONS
                                  /var:
                                  2.6G    /var/
                                  1.5G    /var/log
                                  605M    /var/cache
                                  /opt/iobroker/backups:
                                  /opt/iobroker/iobroker-data:
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.9.7
                                  /usr/bin/npx            10.9.7
                                  nodejs:
                                    Version table:
                                          500 http://security.debian.org/debian-security trixie-security/main arm64 Packages
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  IoBroker64Bit       IoBroker64Bit (version: 7.0.7, hostname: IoBroker64Bit , alive, uptime: 273)
                                  iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 421744)
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        51219
                                  States:         43321
                                  Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                                  Hit:3 http://security.debian.org/debian-security trixie-security InRelease
                                  Hit:4 http://archive.raspberrypi.org/debian trixie InRelease
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7346       1013/exim4
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18928      2885/io.sonoff.0
                                  tcp        0      0 192.168.178.76:9091     0.0.0.0:*               LISTEN      1001       19718      2752/io.nuki.0
                                  tcp        0      0 192.168.178.76:9093     0.0.0.0:*               LISTEN      1001       19742      2817/io.nuki.2
                                  tcp        0      0 192.168.178.76:9092     0.0.0.0:*               LISTEN      1001       19727      2768/io.nuki.1
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6035       682/cupsd
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5995       757/sshd: /usr/sbin
                                  tcp6       0      0 :::5900                 :::*                    LISTEN      994        9403       725/wayvnc
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6034       682/cupsd
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7347       1013/exim4
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          5997       757/sshd: /usr/sbin
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2811       527/dhcpcd: [networ
                                  udp        0      0 0.0.0.0:47203           0.0.0.0:*                           108        6181       454/avahi-daemon: r
                                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       20500      2963/io.mihome-vacu
                                  udp        0      0 192.168.178.76:5353     0.0.0.0:*                           1001       18390      2907/io.tr-064.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        6179       454/avahi-daemon: r
                                  udp6       0      0 :::546                  :::*                                0          2813       527/dhcpcd: [networ
                                  udp6       0      0 :::5353                 :::*                                108        6180       454/avahi-daemon: r
                                  udp6       0      0 :::35109                :::*                                108        6182       454/avahi-daemon: r
                                  2026-05-21 18:41:42.857  - warn: mihome-vacuum.0 (2963) State "mihome-vacuum.0.control.clean_home" has no existing object, this might lead to an error in future versions
                                  2026-05-21 18:41:42.926  - info: mihome-vacuum.0 (2963) create state for carpet_mode
                                  2026-05-21 18:41:42.961  - info: luftdaten.0 (2995) Terminated (NO_ERROR): Without reason
                                  2026-05-21 18:41:44.239  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                  2026-05-21 18:41:44.426  - info: switchbot-hub.0 (3027) starting. Version 0.1.2 (non-npm: DrozmotiX/ioBroker.switchbot-hub#7a05fa59dfc5e3ce8d73018badc4e420996452f8) in /opt/iobroker/node_modules/iobroker.switchbot-hub, node: v22.22.2, js-controller: 7.0.7
                                  2026-05-21 18:41:44.587  - info: switchbot-hub.0 (3027) Connected to SwitchBot API found 3 devices
                                  2026-05-21 18:41:44.787  - info: midea.0 (3079) starting. Version 1.7.1 (non-npm: TA2k/ioBroker.midea#649a929d1d81a2fc5f30d362b4080729065c0c89) in /opt/iobroker/node_modules/iobroker.midea, node: v22.22.2, js-controller: 7.0.7
                                  2026-05-21 18:41:45.753  - info: midea.0 (3079) Cloud listing: 1 appliance(s)
                                  2026-05-21 18:41:45.758  - info: midea.0 (3079) LAN discovery: also unicast-probing configured device IPs [192.168.178.51]
                                  2026-05-21 18:41:46.144  - info: switchbot-hub.0 (3027) All devices and values loaded, adapter ready
                                  2026-05-21 18:41:50.767  - info: midea.0 (3079) LAN discovery found 1 appliance(s)
                                  2026-05-21 18:41:51.001  - info: midea.0 (3079) Device 152832116580279: using token/key from device list (admin override, token=97F67491…)
                                  2026-05-21 18:41:51.080  - info: midea.0 (3079) LanClient[152832116580279]: LAN authentication succeeded (tcpKey 32 bytes)
                                  2026-05-21 18:41:51.656  - info: midea.0 (3079) Discovery summary: cloud=1, lan=1, both=1, registered=1
                                  2026-05-21 18:42:21.475  - info: brightsky.0 (2924) Adapter started with configuration: Position: 50.58836475,8.461956549999996, WMO Station ID: 10532, DWD Station ID: , Currently data enabled. Poll interval: 60 minutes - Hourly data enabled. Poll interval: 1 hours - Daily data enabled - Radar data enabled. Poll interval: 10 minutes. Max distance: 50000 meters.
                                  2026-05-21 18:42:21.476  - info: brightsky.0 (2924) Using WMO Station ID: 10532
                                  2026-05-21 18:42:25.030  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 3149
                                  2026-05-21 18:42:27.942  - info: luftdaten.0 (3149) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                                  2026-05-21 18:42:28.353  - info: luftdaten.0 (3149) Terminated (NO_ERROR): Without reason
                                  2026-05-21 18:42:28.930  - warn: luftdaten.0 (3149) get state error: Connection is closed.
                                  2026-05-21 18:42:28.959  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 3149 terminated with code 0 (NO_ERROR)
                                  2026-05-21 18:44:25.030  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 in version "4.0.0" started with pid 4385
                                  2026-05-21 18:44:28.174  - info: luftdaten.0 (4385) starting. Version 4.0.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v22.22.2, js-controller: 7.0.7
                                  2026-05-21 18:44:28.911  - info: luftdaten.0 (4385) Terminated (NO_ERROR): Without reason
                                  2026-05-21 18:44:29.479  - info: host.IoBroker64Bit instance system.adapter.luftdaten.0 having pid 4385 terminated with code 0 (NO_ERROR)
                                    Script v.2026-01-31
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                    Current issues:
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    pi
                                    HOME=/home/pi
                                    iobroker
                                    HOME=/home/iobroker
                                    SUDO_HOME=/home/pi
                                    Desktop:
                                    Session:                tty
                                    *** MEMORY ***
                                             1843 M total memory
                                              690 M used memory
                                               92 M free memory
                                                2 M buffer memory
                                             1130 M swap cache
                                              199 M total swap
                                              194 M used swap
                                                5 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    2.6G    /var/
                                    1.5G    /var/log
                                    605M    /var/cache
                                    USB-Devices by-id:
                                    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                                    please always prefer the links 'by-id':
                                    No Devices found 'by-id'
                                    No nvbackup.json found.
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v22.22.2
                                    /usr/bin/node           v22.22.2
                                    /usr/bin/npm            10.9.7
                                    /usr/bin/npx            10.9.7
                                    ✓ Node.js installation is correct
                                    nodejs:
                                      Installed: 22.22.2-1nodesource1
                                      Candidate: 22.22.2-1nodesource1
                                      Version table:
                                     *** 22.22.2-1nodesource1 1001
                                            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                         22.22.1-1nodesource1 1001
                                         22.22.0-1nodesource1 1001
                                         22.21.0-1nodesource1 1001
                                         22.20.0-1nodesource1 1001
                                         22.19.0-1nodesource1 1001
                                         22.18.0-1nodesource1 1001
                                         22.17.1-1nodesource1 1001
                                         22.17.0-1nodesource1 1001
                                         22.16.0-1nodesource1 1001
                                         22.15.1-1nodesource1 1001
                                         22.15.0-1nodesource1 1001
                                         22.14.0-1nodesource1 1001
                                         22.13.1-1nodesource1 1001
                                         22.13.0-1nodesource1 1001
                                         22.12.0-1nodesource1 1001
                                         22.11.0-1nodesource1 1001
                                         22.10.0-1nodesource1 1001
                                         22.9.0-1nodesource1 1001
                                         22.8.0-1nodesource1 1001
                                         22.7.0-1nodesource1 1001
                                         22.6.0-1nodesource1 1001
                                         22.5.1-1nodesource1 1001
                                         22.5.0-1nodesource1 1001
                                         22.4.1-1nodesource1 1001
                                         22.4.0-1nodesource1 1001
                                         22.3.0-1nodesource1 1001
                                         22.2.0-1nodesource1 1001
                                         22.1.0-1nodesource1 1001
                                         22.0.0-1nodesource1 1001
                                    No problems detected
                                    Errors in npm tree: 0
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    Core adapters versions
                                    Adapter State
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
                                    + system.adapter.brightsky.0              : brightsky             : IoBroker64Bit                            -  enabled
                                    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                      system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
                                    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8428
                                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                      system.adapter.luftdaten.0              : luftdaten             : IoBroker64Bit                            -  enabled
                                    + system.adapter.midea.0                  : midea                 : IoBroker64Bit                            -  enabled
                                    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
                                    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.niu.0                    : niu                   : iobroker                                 -  enabled
                                    + system.adapter.nspanel-lovelace-ui.0    : nspanel-lovelace-ui   : iobroker                                 -  enabled
                                    + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
                                    + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
                                    + system.adapter.nuki.2                   : nuki                  : IoBroker64Bit                            -  enabled
                                    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                      system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
                                      system.adapter.octoprint.1              : octoprint             : iobroker                                 - disabled
                                    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                                      system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
                                    + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
                                    + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
                                    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                    + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
                                      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                    + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
                                    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                                    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
                                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.smartloadmanager.0       : smartloadmanager      : iobroker                                 -  enabled
                                    + system.adapter.sonoff.0                 : sonoff                : IoBroker64Bit                            -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                    + system.adapter.spritmonitor.0           : spritmonitor          : iobroker                                 -  enabled
                                    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
                                    + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
                                    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                                    + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                                      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                      system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                                      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                                    + instance is alive
                                    ioBroker-Repositories
                                    │ (index) │ name     │ url                                                  │ auto upgrade │
                                    │ 0       │ 'stable' │ 'http://iobroker.live/repo/sources-dist.json'        │ false        │
                                    │ 1       │ 'beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json' │ false        │
                                    Active repo(s): stable
                                    Upgrade policy: none
                                    Installed ioBroker-Adapters
                                    Used repository: stable
                                    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                                    Adapter    "device-watcher": 2.15.5  , installed 2.15.5
                                    Controller "js-controller": 7.0.7    , installed 7.0.7
                                    Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
                                    Adapter    "pi-hole"      : 2.0.0    , installed 2.0.0
                                    Adapter    "rpi2"         : 3.0.2    , installed 2.4.0  [Updatable]
                                    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                                    Objects and States
                                    Objects:        51219
                                    States:         43321
                                    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                    Reading package lists...
                                    *** Listening Ports ***
                                    @MichaelF sagte:
                                    • MichaelFM Online
                                      MichaelFM Online
                                      MichaelF
                                      Ja grade gesehen und auf den neusten Stand gebracht.
                                      Ganz ohne Problem ging es nicht, ich hatte ein Paketkonflikt zwischen lxpanel und lxplug-batt
                                      Hier hat aber ChatGBT recht schnell geholfen, der Update Prozess ist quasi mittendrin stehen geblieben.
                                      War das zweite mal das ich das genutzt habe, hätte ich nicht gedacht das sich so Fehler so gut beheben lassen, ohne das wäre mir wahrscheinlich nur die neu Installation geblieben.
                                      Danke nochmal und grüße.
                                        @MichaelF sagte:
                                        Das kann nicht sein, diese Pakete sind nur vorhanden, wenn da Desktop-Gerümpel installiert ist.
                                        Auf einem Server hat man sowas aber nicht...
                                          @MichaelF sagte:
                                          MichaelFM Online
                                          MichaelFM Online
                                          MichaelF
                                          @Thomas-Braun
                                          Wo die Pakete her kamen kann ich leider auch nicht sagen hier die Fehlermeldung, wären diese vorhanden wenn dort mal ein Desktop gelaufen wäre?
