  4. Test Adapter - Fox ESS Cloud
    6.8k
photovoltaikanlagewechselrichterbalkonkraftwerkspeicher
12 Beiträge 2 Kommentatoren 967 Aufrufe 2 Beobachtet
  • skvarelS Online
    skvarelS Online
    skvarel
    schrieb am zuletzt editiert von skvarel
    Changelog
    (Dieser Beitrag wird laufend erweitert/editiert)
    0.6.3 (2026-06-05)
    (skvarel) Fixed repository checker error E0036
    0.6.2 (2026-06-02)
    (skvarel) Documented Open API rate limit (per API key, multiple instances) in README and admin General tab
    (skvarel) Migrated project rules from GitHub Copilot to Cursor rules
    0.6.1 (2026-05-29)
    (skvarel) Revised config and i18n
    0.6.0 (2026-05-27)
    (StephanBeutel) Added support for up to 24 PV strings with dynamic state creation on first occurrence
    (StephanBeutel) Added report states for daily, weekly, monthly, and yearly energy totals derived from lifetime API values
    (StephanBeutel) Fixed null value handling for inverter and battery temperature states
    (StephanBeutel) Extracted reusable makeApiRequest() method for cleaner API communication
    (StephanBeutel) Centralized all state name translations into a single STATE_NAMES constant
    (skvarel) Fixed report states not updating during current period (values were only written at period rollover)
    (skvarel) Made energy reporting configurable via a new Reporting tab in the admin UI
    0.5.1 (2026-05-25)
    (skvarel) Replaced process.env and process.exit usage in tools/api-test.js to fix compatibility issues reported by ioBroker repository checker (E5049, E5050)
    (skvarel) Downgraded @types/node from ^25 to ^22 to match supported Node.js version (W0066)
    Older changes:
    0.5.0 (2026-05-23)
    (skvarel) Added PV Power JSON statistics (daily, weekly, monthly) for VIS widget integration with optional cost calculation per kWh
    0.4.0 (2026-05-19)
    (skvarel) Added PV string 1 and string 2 power datapoints (pv1Power, pv2Power)
    (skvarel) Added battery temperature datapoint (batTemperature)
    (skvarel) Added inverter running state datapoint (runningState)
    0.3.0 (2026-05-19)
    (skvarel) Added inverter internal temperature datapoint in °C
    0.2.3 (2026-05-14)
    (skvarel) Fixed issue from adapter checker
    0.2.2 (2026-05-14)
    (skvarel) Fixed some lint errors/warnings
    0.2.1 (2026-04-13)
    (skvarel) Removed: React and mui
    0.2.0 (2026-04-06)
    (skvarel) Updated: Minimum Node.js version requirement to >=22
    0.1.9 (2026-03-13)
    (skvarel) Improved: Enabled Node.js 24 support in GitHub Actions workflows.
    (skvarel) Fixed: Issue detected by repository checker.
    0.1.8 (2026-03-12)
    0.1.7 (2026-02-28)
    0.1.6 (2026-02-01)
    (skvarel) Improved: Use node: prefix for core modules and adapter timer wrappers for better compatibility
    (skvarel) Fixed: Added .env.example to .gitignore
    0.1.5 (2026-01-31)
    (skvarel) Improved: Removed unnecessary devDependencies (eslint, should, dotenv) to follow ioBroker best practices.
    (skvarel) Improved: Updated test scripts to use standard mocha command instead of hardcoded paths.
    (skvarel) Improved: Switched Node.js core module imports to node:xxx format where applicable.
    (skvarel) Improved: Enforced minimum and maximum interval limits for data polling to comply with Node.js timer restrictions.
    (skvarel) Improved: Code formatting and configuration files updated for consistency with ioBroker standards.
    (skvarel) Fixed: Addressed review feedback for ioBroker latest repository inclusion.
    (skvarel) Added: Full multi-language support for all state names (EN, DE, RU, PT, NL, FR, IT, ES, PL, UK, ZH-CN).
    0.1.2 (2026-01-23)
    (skvarel) Fix .vscode/settings.json
    0.1.1 (2026-01-23)
    (skvarel) Remove mocha from devDependencies (included in @iobroker/testing)
    (skvarel) Add .vscode/settings.json with JSON schema definitions
    0.1.0 (2026-01-22)
    (skvarel) Initial release
    #TeamInventwo
    Unsere Adapter:
    • skvarelS Online
      skvarelS Online
      skvarel
      Keine Wünsche auf weitere Datenpunkte? Bei Adapter-Request waren ein paar Stimmen für diesen Adapter und hier ist es komplett ruhig ?!
      #TeamInventwo
      Unsere Adapter:
      • skvarelS Online
        skvarelS Online
        skvarel
        v0.1.6 ist nun im Latest Repo
        #TeamInventwo
        Unsere Adapter:
        • skvarelS Online
          skvarelS Online
          skvarel
          LATEST Update
          Ich habe gerade die 0.4.0 hochgeladen.
          Ein paar weitere Datenpunkte hinzugefügt:
          #TeamInventwo
          Unsere Adapter:
          • MartinPM Online
            MartinPM Online
            MartinP
            Bevor es den Adapter gab, habe ich mir ein Script geschrieben um den Fox ESS WR meines Balkonkraftwerks über die Cloud auszulesen bzw den Code in großen Teilen aus dem Internet besorgt und an die Nutzung mit iobroker angepasst.
            Läuft derzeit annehmbar, werde aber einen Blick auf den Adapter werfen.
            skvarelS 1 Antwort Letzte Antwort
            • MartinPM MartinP
              skvarelS Online
              skvarelS Online
              skvarel
              @MartinP .. bei meinem Microwechselrichter bleiben ein paar Datenpunkte leer, weil ich das Balkonkraftwerk ohne Speicher betreibe.
              Ich hatte den Adapter eigentlich für meine große Anlage erstellt und jetzt über eine zweite Instanz das BKW in den ioBroker geholt.
              So sieht es bei meinem M1-800-E aus:
              Was hast du für Datenpunkte über dein Script erstellen lassen? Ich könnte den Adapter dann gern erweitern.
              #TeamInventwo
              Unsere Adapter:
              • MartinPM Online
                MartinPM Online
                MartinP
                Das ist eher schlicht.
                • Aktuelle Leistung
                • Kumulierte Energie aktueller Tag
                • Energie Vortag
                • MartinPM MartinP
                  • Aktuelle Leistung
                  • Energie Vortag
                  skvarelS Online
                  skvarelS Online
                  skvarel
                  @MartinP sagte:
                  • Energie Vortag
                  Das könnte ich noch einbauen
                  EDIT:
                  Ich mache es allerdings über SourceAnalytix
                  (Die Euros sind die Ersparnisse und nicht die Einspeisevergütungen)
                  #TeamInventwo
                  Unsere Adapter:
                  • skvarelS Online
                    skvarelS Online
                    skvarel
                    Ich überlege gerade, ein (bzw. mehrere) json in die Objekte schreiben zu lassen ?!
                    In der Config definierbar, ob man Tage, Wochen und/oder Monate als json haben möchte. Zusätzlich könnte man optional einen Preis je kWh angeben.
                    Wenn kein Preis angegeben wird, dann nur zwei Spalten .... mit Preis dann drei Spalten
                    #TeamInventwo
                    Unsere Adapter:
                    • MartinPM Online
                      MartinPM Online
                      MartinP
                      Ich nutze Influx/Grafana für meine Auswertungen...
                      Das Script habe ich zwischen Tür und Angel hingebastelt ...
                      Ausgewertet wird die aktuelle Leistung und Ertrag des Vortages - bei dem gibt es manchmal eine "0", die nicht korrekt ist... Ist wahrscheinlich nicht Script-Neustart sicher.
                      Außerdem vom Zweiwege-Zähler die Einspeisung..
                      • skvarelS Online
                        skvarelS Online
                        skvarel
                        ALPHA Update
                        Ich habe drei json hinzugefügt
                        Ich beobachte die Werte ein/zwei Tage, dann schicke ich die Version ins Latest
                        #TeamInventwo
                        Unsere Adapter:
