  4. Homeconect Adapter wird nicht mehr grün
    6.3k
16 Beiträge 7 Kommentatoren 555 Aufrufe 5 Beobachtet
    TimoWald
    Hallo seit 2 Tagen wird mein Homeconect Adapter nicht mehr grün.
    Die App habe ich neu angelegt aber keine veränderung.
    Benutzername und Passwort habe ich schonmal geändert und auch geprüft.
    Was ist da faul?
    2026-05-10 11:44:22.835 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:44:22.878 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:44:22.952 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:44:26.962 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4cc8]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:44:46.827 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c9f]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:44:47.013 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:44:47.053 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:44:47.996 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:45:01.069 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:45:06.830 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c9b]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:45:07.005 - warn: daswetter.0 (615987) Got terminate signal. Checking desired PID: 0 vs own PID 615987
    2026-05-10 11:45:07.005 - info: daswetter.0 (615987) terminating
    2026-05-10 11:45:07.006 - info: daswetter.0 (615987) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-05-10 11:45:07.044 - info: host.iobroker instance system.adapter.daswetter.0 in version "4.5.3" started with pid 616063
    2026-05-10 11:45:07.507 - info: daswetter.0 (615987) terminating
    2026-05-10 11:45:07.655 - info: host.iobroker instance system.adapter.daswetter.0 having pid 615987 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-05-10 11:45:08.038 - info: daswetter.0 (616063) starting. Version 4.5.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.7
    2026-05-10 11:45:08.256 - error: daswetter.0 (616063) DasWetter_0: no api key available, please check settings
    2026-05-10 11:45:08.257 - error: daswetter.0 (616063) DasWetter_0: no location hash available, please check postcode and city settings
    2026-05-10 11:45:10.870 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:45:10.871 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:45:10.871 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:45:10.871 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:45:10.871 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:45:20.020 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:45:20.055 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:45:20.999 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:45:23.482 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:45:23.526 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:45:23.609 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:45:27.114 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c99]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:45:46.833 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c8d]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:45:53.024 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:45:53.058 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:45:54.001 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:46:01.017 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:46:06.863 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4caa]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:46:11.435 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:46:11.436 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:46:11.436 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:46:11.436 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:46:11.436 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:46:19.530 - info: shelly.0 (447370) [MQTT] Device with client id "shellyplus1pm-08f9e0ffec60" connected from 192.168.9.33!
    2026-05-10 11:46:20.596 - info: shelly.0 (447370) [MQTT] Device with client id "shellyplus1pm-08f9e0ffec60" initialized.
    2026-05-10 11:46:21.524 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:46:21.524 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:46:21.524 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:46:21.525 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:46:21.525 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:46:24.153 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:46:24.197 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:46:24.281 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:46:26.028 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:46:26.060 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:46:26.892 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4ca0]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:46:27.995 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:46:31.618 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:46:31.618 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:46:31.618 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:46:31.619 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:46:31.619 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:46:46.814 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c8c]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:46:51.263 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.18 for GA 25/5/24 (not in ETS project). data=[051e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:46:51.786 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:46:51.786 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:46:51.786 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:46:51.787 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:46:51.787 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:46:59.031 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:46:59.063 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:47:00.998 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:47:06.842 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c8b]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:47:10.550 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:47:22.057 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:47:22.058 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:47:22.058 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:47:22.058 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:47:22.058 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:47:24.752 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:47:24.795 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:47:24.877 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:47:26.840 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c76]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:47:32.034 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:47:32.065 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:47:32.142 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:47:32.143 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:47:32.143 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:47:32.143 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:47:32.143 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:47:34.001 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:47:46.842 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c71]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:48:01.040 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:48:05.037 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:48:05.069 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:48:06.837 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c63]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:48:07.004 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:48:18.518 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.5 for GA 25/5/25 (not in ETS project). data=[0c1a]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:48:18.538 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.5 for GA 25/5/27 (not in ETS project). data=[02bc]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:48:25.330 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:48:25.373 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:48:25.457 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:48:26.806 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c54]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:48:38.040 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:48:38.072 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:48:40.007 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:48:42.737 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:48:42.737 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:48:42.737 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:48:42.737 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:48:42.738 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:48:46.819 - error: xsense.0 (447508) [XSense] No data received from bridge: another device is logged in !
    2026-05-10 11:48:46.842 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c68]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:48:52.906 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:48:52.906 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:48:52.906 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:48:52.906 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:48:52.907 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:49:01.025 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:49:06.837 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c8e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:49:11.042 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:49:11.077 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:49:13.011 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:49:13.071 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:49:13.072 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:49:13.072 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:49:13.072 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:49:13.072 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:49:18.497 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.5 for GA 25/5/28 (not in ETS project). data=[00]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:49:26.091 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:49:26.137 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:49:26.226 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:49:26.826 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c99]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:49:44.045 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:49:44.079 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:49:46.014 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:49:46.851 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c99]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:50:01.042 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:50:06.811 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c82]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:50:17.048 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:50:17.083 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:50:19.017 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:50:23.741 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:50:23.741 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:50:23.741 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:50:23.741 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:50:23.742 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:50:26.793 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:50:26.817 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c51]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:50:26.837 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:50:26.924 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:50:46.848 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c51]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:50:50.051 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:50:50.086 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:50:52.020 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:50:54.005 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:50:54.005 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:50:54.005 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:50:54.005 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:50:54.006 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:51:01.115 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:51:06.846 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c5e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:51:14.374 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:51:14.375 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:51:14.375 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:51:14.375 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:51:14.375 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:51:23.052 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:51:23.088 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:51:25.023 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:51:26.928 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c79]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:51:27.434 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:51:27.477 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:51:27.557 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:51:46.804 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c6e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:51:51.254 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.18 for GA 25/5/24 (not in ETS project). data=[051e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:51:56.055 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:51:56.090 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:51:58.025 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:52:01.025 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:52:06.877 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c70]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:52:15.129 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:52:15.130 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:52:15.130 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:52:15.130 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:52:15.130 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:52:26.825 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c55]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:52:28.086 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:52:28.130 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:52:28.218 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:52:29.059 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:52:29.095 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:52:31.034 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:52:45.509 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:52:45.509 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:52:45.509 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:52:45.510 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:52:45.510 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:52:46.821 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c6a]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:53:01.011 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:53:02.062 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:53:02.098 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:53:04.038 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:53:06.853 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c3b]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:53:18.476 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.5 for GA 25/5/25 (not in ETS project). data=[0c1a]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:53:26.563 - warn: javascript.0 (573510) You are assigning a boolean to the state "0_userdata.0.Mähroboter.Kantenschnitt" which expects a string. Please fix your code to use a string or change the state type to boolean. This warning might become an error in future versions.
    2026-05-10 11:53:26.564 - warn: javascript.0 (573510) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
    2026-05-10 11:53:26.564 - warn: javascript.0 (573510) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2739:29)
    2026-05-10 11:53:26.564 - warn: javascript.0 (573510) at listOnTimeout (node:internal/timers:590:11)
    2026-05-10 11:53:26.564 - warn: javascript.0 (573510) at processTimers (node:internal/timers:523:7)
    2026-05-10 11:53:26.566 - info: javascript.0 (573510) State value to set for "0_userdata.0.Mähroboter.Kantenschnitt" has to be type "string" but received type "boolean"
    2026-05-10 11:53:26.824 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c60]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:53:28.713 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
    2026-05-10 11:53:28.758 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
    2026-05-10 11:53:28.829 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
    2026-05-10 11:53:35.064 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
    2026-05-10 11:53:35.099 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
    2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:53:37.040 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
    2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
    2026-05-10 11:53:46.780 - error: xsense.0 (447508) [XSense] No data received from bridge: another device is logged in !
    2026-05-10 11:53:46.818 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c6f]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
    2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
    2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
    2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
    2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) "The request content was malformed:\nSubstream Source(EntitySource) cannot be materialized more than once"
    2026-05-10 11:54:01.012 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
    • teletapiT Online
      teletapiT Online
      teletapi
      https://forum.iobroker.net/topic/16446/test-adapter-homeconnect-bsh-home-connect-v0-0-x/1428?_=1778407220166
        TimoWald
        Danke das hat jetzt Funktioniert.
        • T TimoWald
          Hallo seit 2 Tagen wird mein Homeconect Adapter nicht mehr grün.
          Die App habe ich neu angelegt aber keine veränderung.
          Benutzername und Passwort habe ich schonmal geändert und auch geprüft.
          Was ist da faul?
          2026-05-10 11:44:22.835 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:44:22.878 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:44:22.952 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:44:26.962 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4cc8]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:44:30.538 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:44:46.827 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c9f]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:44:47.013 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:44:47.053 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:44:47.996 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:44:50.688 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:45:00.788 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:45:01.069 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:45:06.830 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c9b]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:45:07.005 - warn: daswetter.0 (615987) Got terminate signal. Checking desired PID: 0 vs own PID 615987
          2026-05-10 11:45:07.005 - info: daswetter.0 (615987) terminating
          2026-05-10 11:45:07.006 - info: daswetter.0 (615987) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2026-05-10 11:45:07.044 - info: host.iobroker instance system.adapter.daswetter.0 in version "4.5.3" started with pid 616063
          2026-05-10 11:45:07.507 - info: daswetter.0 (615987) terminating
          2026-05-10 11:45:07.655 - info: host.iobroker instance system.adapter.daswetter.0 having pid 615987 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2026-05-10 11:45:08.038 - info: daswetter.0 (616063) starting. Version 4.5.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v22.21.0, js-controller: 7.0.7
          2026-05-10 11:45:08.256 - error: daswetter.0 (616063) DasWetter_0: no api key available, please check settings
          2026-05-10 11:45:08.257 - error: daswetter.0 (616063) DasWetter_0: no location hash available, please check postcode and city settings
          2026-05-10 11:45:10.870 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:45:10.871 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:45:10.871 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:45:10.871 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:45:10.871 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:45:20.020 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:45:20.055 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:45:20.982 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:45:20.999 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:45:23.482 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:45:23.526 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:45:23.609 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:45:27.114 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c99]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:45:31.078 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:45:41.183 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:45:46.833 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c8d]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:45:51.286 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:45:53.024 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:45:53.058 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:45:54.001 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:46:01.017 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:46:01.361 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:46:06.863 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4caa]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:46:11.435 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:46:11.436 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:46:11.436 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:46:11.436 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:46:11.436 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:46:19.530 - info: shelly.0 (447370) [MQTT] Device with client id "shellyplus1pm-08f9e0ffec60" connected from 192.168.9.33!
          2026-05-10 11:46:20.596 - info: shelly.0 (447370) [MQTT] Device with client id "shellyplus1pm-08f9e0ffec60" initialized.
          2026-05-10 11:46:21.524 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:46:21.524 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:46:21.524 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:46:21.525 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:46:21.525 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:46:24.153 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:46:24.197 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:46:24.281 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:46:26.028 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:46:26.060 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:46:26.892 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4ca0]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:46:27.995 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:46:31.618 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:46:31.618 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:46:31.618 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:46:31.619 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:46:31.619 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:46:41.690 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:46:46.814 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c8c]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:46:51.263 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.18 for GA 25/5/24 (not in ETS project). data=[051e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:46:51.786 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:46:51.786 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:46:51.786 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:46:51.787 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:46:51.787 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:46:59.031 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:46:59.063 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:47:00.998 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:47:01.870 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:47:06.842 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c8b]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:47:10.550 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:47:11.951 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:47:22.057 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:47:22.058 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:47:22.058 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:47:22.058 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:47:22.058 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:47:24.752 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:47:24.795 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:47:24.877 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:47:26.840 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c76]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:47:32.034 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:47:32.065 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:47:32.142 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:47:32.143 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:47:32.143 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:47:32.143 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:47:32.143 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:47:34.001 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:47:42.216 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:47:46.842 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c71]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:47:52.319 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:48:01.040 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:48:02.395 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:48:05.037 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:48:05.069 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:48:06.837 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c63]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:48:07.004 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:48:12.478 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:48:18.518 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.5 for GA 25/5/25 (not in ETS project). data=[0c1a]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:48:18.538 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.5 for GA 25/5/27 (not in ETS project). data=[02bc]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:48:22.589 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:48:25.330 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:48:25.373 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:48:25.457 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:48:26.806 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c54]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:48:32.661 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:48:38.040 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:48:38.072 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:48:40.007 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:48:42.737 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:48:42.737 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:48:42.737 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:48:42.737 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:48:42.738 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:48:46.819 - error: xsense.0 (447508) [XSense] No data received from bridge: another device is logged in !
          2026-05-10 11:48:46.842 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c68]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:48:52.906 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:48:52.906 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:48:52.906 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:48:52.906 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:48:52.907 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:49:01.025 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:49:02.983 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:49:06.837 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c8e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:49:11.042 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:49:11.077 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:49:13.011 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:49:13.071 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:49:13.072 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:49:13.072 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:49:13.072 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:49:13.072 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:49:18.497 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.5 for GA 25/5/28 (not in ETS project). data=[00]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:49:23.179 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:49:26.091 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:49:26.137 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:49:26.226 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:49:26.826 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c99]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:49:33.285 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:49:43.358 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:49:44.045 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:49:44.079 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:49:46.014 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:49:46.851 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c99]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:49:53.461 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:50:01.042 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:50:03.568 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:50:06.811 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c82]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:50:13.666 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:50:17.048 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:50:17.083 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:50:19.017 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:50:23.741 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:50:23.741 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:50:23.741 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:50:23.741 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:50:23.742 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:50:26.793 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:50:26.817 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c51]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:50:26.837 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:50:26.924 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:50:33.842 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:50:43.913 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:50:46.848 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c51]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:50:50.051 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:50:50.086 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:50:52.020 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:50:54.005 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:50:54.005 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:50:54.005 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:50:54.005 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:50:54.006 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:51:01.115 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:51:04.190 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:51:06.846 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c5e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:51:14.374 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:51:14.375 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:51:14.375 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:51:14.375 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:51:14.375 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:51:23.052 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:51:23.088 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:51:24.467 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:51:25.023 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:51:26.928 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c79]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:51:27.434 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:51:27.477 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:51:27.557 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:51:34.670 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:51:44.768 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:51:46.804 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c6e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:51:51.254 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.18 for GA 25/5/24 (not in ETS project). data=[051e]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:51:54.902 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:51:56.055 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:51:56.090 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:51:58.025 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:52:01.025 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:52:05.021 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:52:06.877 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c70]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:52:15.129 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:52:15.130 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:52:15.130 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:52:15.130 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:52:15.130 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:52:25.206 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:52:26.825 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c55]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:52:28.086 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:52:28.130 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:52:28.218 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:52:29.059 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:52:29.095 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:52:31.034 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:52:35.337 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:52:45.509 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:52:45.509 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:52:45.509 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:52:45.510 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:52:45.510 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:52:46.821 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c6a]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:52:55.681 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:53:01.011 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:53:02.062 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:53:02.098 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:53:04.038 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:53:05.767 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:53:06.853 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c3b]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:53:15.863 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:53:18.476 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.3.5 for GA 25/5/25 (not in ETS project). data=[0c1a]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:53:25.932 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:53:26.563 - warn: javascript.0 (573510) You are assigning a boolean to the state "0_userdata.0.Mähroboter.Kantenschnitt" which expects a string. Please fix your code to use a string or change the state type to boolean. This warning might become an error in future versions.
          2026-05-10 11:53:26.564 - warn: javascript.0 (573510) at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
          2026-05-10 11:53:26.564 - warn: javascript.0 (573510) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2739:29)
          2026-05-10 11:53:26.564 - warn: javascript.0 (573510) at listOnTimeout (node:internal/timers:590:11)
          2026-05-10 11:53:26.564 - warn: javascript.0 (573510) at processTimers (node:internal/timers:523:7)
          2026-05-10 11:53:26.566 - info: javascript.0 (573510) State value to set for "0_userdata.0.Mähroboter.Kantenschnitt" has to be type "string" but received type "boolean"
          2026-05-10 11:53:26.824 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c60]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:53:28.713 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
          2026-05-10 11:53:28.758 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
          2026-05-10 11:53:28.829 - info: myuplink.0 (447280) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
          2026-05-10 11:53:35.064 - warn: wled.0 (447486) Unable to initialise 192.168.9.93 will retry in scheduled interval !
          2026-05-10 11:53:35.099 - warn: wled.0 (447486) Unable to initialise 192.168.9.94 will retry in scheduled interval !
          2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:53:36.054 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:53:37.040 - warn: wled.0 (447486) Unable to initialise 192.168.9.95 will retry in scheduled interval !
          2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:53:46.143 - error: homeconnect.0 (616029) {"error":"authorization_pending","error_description":"The authorization request is still pending as the end-user hasn't yet completed the user interaction steps"}
          2026-05-10 11:53:46.780 - error: xsense.0 (447508) [XSense] No data received from bridge: another device is logged in !
          2026-05-10 11:53:46.818 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/2 (not in ETS project). data=[4c6f]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) AxiosError: Request failed with status code 400
          2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) Please check username and password or visit this site for manually login:
          2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) Bitte überprüfe Benutzername und Passwort oder besuche diese Seite für manuelle Anmeldung:
          2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          2026-05-10 11:53:56.221 - error: homeconnect.0 (616029) "The request content was malformed:\nSubstream Source(EntitySource) cannot be materialized more than once"
          2026-05-10 11:54:01.012 - warn: openknx.0 (567923) Ignoring GroupValue_Write from 1.1.0 for GA 9/4/1 (not in ETS project). data=[ff]. Reimport ETS project to add this GA, or enable 'suppress unknown GA warnings'.
          @TimoWald sagte:
          2026-05-10 11:44:40.615 - error: homeconnect.0 (616029) https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23
          • T TimoWald
            Danke das hat jetzt Funktioniert.
            haselchenH Offline
            haselchenH Offline
            haselchen
            @TimoWald
            Schreib bitte ein GELÖST vor den Threadtitel.
            • holly200289H Offline
              holly200289
              Moin moin,
              leider erkennt der Adapter zwei von meinen 4 Geräten nicht mehr.
              Der Backofen und die Spühlmaschine sind verbunden,
              der Trockner und die Wschmaschine leider nicht ?
              vieleicht könnt ihr ja helfen ?
              Thomas BraunT T 2 Antworten Letzte Antwort
              • holly200289H holly200289
                Moin moin,
                @holly200289 sagte:
                Ohne 'was zu beißen' wird es schwer...
                Logs?
                Ausgabe von
                iob diag
                  holly200289
                  Script v.2026-01-31
                  *** BASE SYSTEM ***
                  Operating System: Debian GNU/Linux 13 (trixie)
                   Static hostname: iobroker
                         Icon name: computer-container
                           Chassis: container ☐
                    Virtualization: lxc
                            Kernel: Linux 6.8.12-23-pve
                      Architecture: x86-64
                  OS is similar to:
                  model name      : Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
                  Docker          : false
                  Virtualization  : lxc
                  Kernel          : x86_64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   21:47:36 up 1 day, 23:57,  1 user,  load average: 0.93, 1.24, 1.61
                  CPU threads: 8
                  *** LIFE CYCLE STATUS ***
                  Operating System is the current Debian stable version codenamed 'trixie'!
                  *** TIME AND TIMEZONES ***
                                 Local time: Tue 2026-05-12 21:47:36 CEST
                             Universal time: Tue 2026-05-12 19:47:36 UTC
                                   RTC time: n/a
                                NTP service: inactive
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  admin
                  HOME=/home/admin
                  GROUPS=admin adm dialout sudo audio video plugdev users iobroker
                  iobroker
                  HOME=/home/iobroker
                  SUDO_HOME=/home/admin
                  GROUPS=iobroker tty dialout audio video plugdev bluetooth docker
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server:         false
                  Unit display-manager.service could not be found.
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:             27G         10G         16G        3.3M        255M         16G
                  Swap:           1.0G         16K        1.0G
                  Total:           28G         10G         17G
                  Active iob-Instances:   85
                          26000 M total memory
                           9804 M used memory
                           9692 M active memory
                              8 M inactive memory
                          15955 M free memory
                              0 M buffer memory
                            243 M swap cache
                           1000 M total swap
                              0 M used swap
                            999 M free swap
                  top - 21:47:36 up 1 day, 23:57,  1 user,  load average: 0.93, 1.24, 1.61
                  Tasks: 122 total,   1 running, 121 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  1.2 us,  1.2 sy,  0.0 ni, 96.5 id,  0.0 wa,  0.0 hi,  1.2 si,  0.0 st
                  MiB Mem :  26000.0 total,  15953.0 free,   9806.2 used,    243.8 buff/cache
                  MiB Swap:   1000.0 total,   1000.0 free,      0.0 used.  16193.8 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  Filesystem                Type   Size  Used Avail Use% Mounted on
                  daten/subvol-100-disk-0   zfs    230G   24G  207G  11% /
                  none                      tmpfs  492K  4.0K  488K   1% /dev
                  tmpfs                     tmpfs   16G     0   16G   0% /dev/shm
                  tmpfs                     tmpfs  6.3G  176K  6.3G   1% /run
                  tmpfs                     tmpfs   16G  3.0M   16G   1% /tmp
                  tmpfs                     tmpfs  5.0M     0  5.0M   0% /run/lock
                  tmpfs                     tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                  tmpfs                     tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
                  tmpfs                     tmpfs  1.0M     0  1.0M   0% /run/credentials/console-getty.service
                  tmpfs                     tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@2.service
                  tmpfs                     tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@1.service
                  //192.168.178.91/Iobroker cifs   1.8T  481G  1.3T  27% /opt/iobroker/backups
                  tmpfs                     tmpfs  3.2G  8.0K  3.2G   1% /run/user/1001
                  [Sun May 10 18:27:38 2026] EXT4-fs (dm-1): mounted filesystem ab1ad7c3-0cdf-4b46-8d50-76e8a5569dcc ro with ordered data mode. Quota mode: none.
                  [Sun May 10 18:27:39 2026] EXT4-fs (dm-1): re-mounted ab1ad7c3-0cdf-4b46-8d50-76e8a5569dcc r/w.
                  Show mounted filesystems:
                  TARGET                  SOURCE                    FSTYPE OPTIONS
                  /                       daten/subvol-100-disk-0   zfs    rw,relatime,xattr,posixacl,casesensitive
                  `-/opt/iobroker/backups //192.168.178.91/Iobroker cifs   rw,relatime,vers=3.1.1,cache=strict,upcall_target=app,username=datei,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.91,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
                  /var:
                  3.0G    /var/
                  1.9G    /var/lib
                  1.8G    /var/lib/containerd
                  1.1G    /var/lib/containerd/io.containerd.snapshotter.v1.overlayfs/snapshots
                  Archived and active journals take up 957.8M in the file system.
                  /opt/iobroker/backups:
                  133G    /opt/iobroker/backups/
                  132G    /opt/iobroker/backups/dump
                  0       /opt/iobroker/backups/influxDB_2026_05_12-02_48_34_Iobroker2024_backupiobroker
                  0       /opt/iobroker/backups/influxDB_2026_05_11-02_48_32_Iobroker2024_backupiobroker
                  0       /opt/iobroker/backups/influxDB_2026_05_10-02_48_30_Iobroker2024_backupiobroker
                  /opt/iobroker/iobroker-data:
                  1.8G    /opt/iobroker/iobroker-data/
                  793M    /opt/iobroker/iobroker-data/files
                  565M    /opt/iobroker/iobroker-data/history
                  390M    /opt/iobroker/iobroker-data/backup-objects
                  84M     /opt/iobroker/iobroker-data/files/vis
                  18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                  17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
                  17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
                  17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
                  17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
                  USB-Devices by-id:
                  USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                  please always prefer the links 'by-id':
                  No Devices found 'by-id'
                  *** ZigBee Settings ***
                  ⚠ HINT:
                  Your zigbee.1 COM-Port is NOT matching 'by-id'.
                  Please check your setting:
                  tcp
                  ⚠ HINT:
                  Your zigbee.2 COM-Port is NOT matching 'by-id'.
                  tcp
                  ⚠ HINT:
                  Your zigbee.3 COM-Port is NOT matching 'by-id'.
                  tcp
                  ⚠ HINT:
                  Your zigbee.4 COM-Port is NOT matching 'by-id'.
                  tcp
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v22.22.2
                  /usr/bin/node           v22.22.2
                  /usr/bin/npm            11.13.0
                  /usr/bin/npx            11.13.0
                  ✓ Node.js installation is correct
                  nodejs:
                    Installed: 22.22.2-1nodesource1
                    Candidate: 22.22.2-1nodesource1
                    Version table:
                   *** 22.22.2-1nodesource1 600
                       22.22.1-1nodesource1 600
                       22.22.0-1nodesource1 600
                       22.21.0-1nodesource1 600
                       22.20.0-1nodesource1 600
                       22.19.0-1nodesource1 600
                       22.18.0-1nodesource1 600
                       22.17.1-1nodesource1 600
                       22.17.0-1nodesource1 600
                       22.16.0-1nodesource1 600
                       22.15.1-1nodesource1 600
                       22.15.0-1nodesource1 600
                       22.14.0-1nodesource1 600
                       22.13.1-1nodesource1 600
                       22.13.0-1nodesource1 600
                       22.12.0-1nodesource1 600
                       22.11.0-1nodesource1 600
                       22.10.0-1nodesource1 600
                       22.9.0-1nodesource1 600
                       22.8.0-1nodesource1 600
                       22.7.0-1nodesource1 600
                       22.6.0-1nodesource1 600
                       22.5.1-1nodesource1 600
                       22.5.0-1nodesource1 600
                       22.4.1-1nodesource1 600
                       22.4.0-1nodesource1 600
                       22.3.0-1nodesource1 600
                       22.2.0-1nodesource1 600
                       22.1.0-1nodesource1 600
                       22.0.0-1nodesource1 600
                       20.19.2+dfsg-1+deb13u2 500
                          500 http://security.debian.org trixie-security/main amd64 Packages
                       20.19.2+dfsg-1 500
                          500 http://deb.debian.org/debian trixie/main amd64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  iobroker            iobroker (version: 7.1.2, hostname: iobroker      , alive, uptime: 172688)
                  Core adapters versions
                  js-controller:  7.1.2
                  admin:          7.8.24
                  javascript:     9.0.18
                  nodejs modules from github:     17
                  +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#31c593552c25cd0f10e2946589fbc88ad30cc480)
                  +-- bosch-xmpp@1.4.2 (git+ssh://git@github.com/robertklep/bosch-xmpp.git#9f16a4279a14dbc7074734c512a16c3fd3b437cb)
                  +-- homebridge-hikconnect@1.3.3 (git+ssh://git@github.com/judge/homebridge-hikconnect.git#45c72711caac7dcc019874ffc3221b55e74f21e9)
                  +-- iobroker.espresense@0.6.3 (git+ssh://git@github.com/ticaki/ioBroker.espresense.git#a76c524be7eadc1bc0a185fb0dd231780069f73f)
                  +-- iobroker.klipper-moonraker@0.1.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#81680f7d4f8353ddd78f1f10414b27f217b9a7c8)
                  +-- iobroker.omada@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#ee691229a04c5618eed617d4a9e2f079d0e32911)
                  +-- iobroker.philips-tv@0.5.4 (git+ssh://git@github.com/AlCalzone/ioBroker.philips-tv.git#dcbbc814338e68ccb1d3041998fa284db907bc57)
                  +-- iobroker.rssfeed@4.0.3 (git+ssh://git@github.com/oweitman/ioBroker.rssfeed.git#fe163d0f821e88f492030117847f470c11e5b5dc)
                  +-- iobroker.rtspStream@0.0.2 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#3891a8545b5566946b89b6f4dbfeac1e2a6527a5)
                  | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                  +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
                  | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                  +-- iobroker.vis-jsontemplate@4.4.3 (git+ssh://git@github.com/oweitman/ioBroker.vis-jsontemplate.git#4050936319aff4e975e3f872bdcd952c4ea13fa3)
                  +-- iobroker.wiobrowser@2.0.2 (git+ssh://git@github.com/Bettman66/ioBroker.wiobrowser.git#dfa854682a78debebc0be50e3fa7ac6be9dae917)
                  +-- JQuery-Snowfall@1.7.1 (git+ssh://git@github.com/loktar00/JQuery-Snowfall.git#d22ba78f76804e21404bc000142c019d6c10973d)
                  +-- magic-snowflakes@7.0.1 (git+ssh://git@github.com/hcodes/snowflakes.git#718a2b06c3d590ea89081700d96cfa014074dd4a)
                  `-- zigbee-herdsman-converters@25.96.0 (git+ssh://git@github.com/Koenkk/zigbee-herdsman-converters.git#e9132fc65cc0bcbef60a5793976ba192fcc845ac)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.250 (SSL), run as: admin
                  + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8088, bind: 127.0.0.1, run as: admin
                  + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
                  + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
                  + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                  + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
                  + system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                  + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                    system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                  + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                  + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                  + system.adapter.espresense.0             : espresense            : iobroker                                 -  enabled
                    system.adapter.flexcharts.0             : flexcharts            : iobroker                                 -  enabled
                  + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                  + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
                    system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                  + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
                  + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                  + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                    system.adapter.hoymiles.0               : hoymiles              : iobroker                                 - disabled
                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                    system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
                    system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                    system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                    system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                    system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                  + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                  + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                  + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  + system.adapter.klipper-moonraker.0      : klipper-moonraker     : iobroker                                 -  enabled
                  + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
                  + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                    system.adapter.material.0               : material              : iobroker                                 - disabled
                    system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
                    system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
                  + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                  + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                  + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                  + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
                    system.adapter.openweathermap.1         : openweathermap        : iobroker                                 -  enabled
                  + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
                  + system.adapter.philips-air.0            : philips-air           : iobroker                                 -  enabled
                  + system.adapter.philips-air.1            : philips-air           : iobroker                                 -  enabled
                  + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
                  + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                  + system.adapter.places.0                 : places                : iobroker                                 -  enabled
                    system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                  + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                  + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
                  + system.adapter.rtspStream.0             : rtspStream            : iobroker                                 -  enabled, port: 8083
                  + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
                  + system.adapter.samsung.1                : samsung               : iobroker                                 -  enabled
                  + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
                  + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.slideshow.0              : slideshow             : iobroker                                 -  enabled
                  + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                  + system.adapter.smoothed.0               : smoothed              : iobroker                                 -  enabled
                    system.adapter.snmp.0                   : snmp                  : iobroker                                 - disabled
                  + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.250
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                  + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
                  + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
                  + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                  + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
                  + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                  + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                    system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                    system.adapter.vis-jsontemplate.0       : vis-jsontemplate      : iobroker                                 -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                    system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
                    system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                    system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                    system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
                    system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                    system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                    system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                    system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                    system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                  + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                  + system.adapter.webcal.0                 : webcal                : iobroker                                 -  enabled
                  + system.adapter.webui.0                  : webui                 : iobroker                                 -  enabled
                  + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, port: 8080, bind: 192.168.178.250 (SSL), run as: admin
                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                  + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
                  + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
                  + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
                  + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                    system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                  + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.187:1020
                  + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.38:2030
                  + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.230:4060
                  + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.240:6080
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): beta
                  Upgrade policy: patch
                  Installed ioBroker-Adapters
                  Used repository: beta
                  Adapter    "admin"        : 7.8.24   , installed 7.8.24
                  Adapter    "alexa-timer-vis": 2.2.2  , installed 2.2.2
                  Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                  Adapter    "alias-manager": 2.1.0    , installed 2.1.0
                  Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
                  Adapter    "backitup"     : 3.3.17   , installed 3.3.17
                  Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                  Adapter    "bshb"         : 0.6.2    , installed 0.6.2
                  Adapter    "chromecast"   : 4.2.0    , installed 4.2.0
                  Adapter    "cloud"        : 6.0.1    , installed 6.0.1
                  Adapter    "daikin"       : 1.5.1    , installed 1.5.1
                  Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
                  Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
                  Adapter    "device-watcher": 2.15.12 , installed 2.15.12
                  Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                  Adapter    "email"        : 2.0.4    , installed 2.0.4
                  Adapter    "espresense"   : 0.6.3    , installed 0.6.3
                  Adapter    "firetv"       : 2.2.0    , installed 2.2.0
                  Adapter    "flexcharts"   : 0.7.2    , installed 0.7.2
                  Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
                  Adapter    "fullybrowser" : 3.1.5    , installed 3.1.5
                  Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                  Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                  Adapter    "ham"          : 5.3.1    , installed 5.3.1
                  Adapter    "harmony"      : 2.1.0    , installed 2.1.0
                  Adapter    "history"      : 4.0.0    , installed 4.0.0
                  Adapter    "homeconnect"  : 1.6.0    , installed 1.6.0
                  Adapter    "hoymiles"     : 0.3.4    , installed 0.3.4
                  Adapter    "ical"         : 1.20.1   , installed 1.20.1
                  Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
                  Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                  Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
                  Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                  Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                  Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
                  Adapter    "iot"          : 6.0.3    , installed 6.0.3
                  Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                  Adapter    "javascript"   : 9.2.2    , installed 9.0.18 [Updatable]
                  Controller "js-controller": 7.1.2    , installed 7.1.2
                  Adapter    "lightcontrol" : 2.0.0    , installed 2.0.0
                  Adapter    "lovelace"     : 5.0.5    , installed 5.0.5
                  Adapter    "material"     : 1.3.1    , installed 1.3.1
                  Adapter    "matter"       : 1.0.0    , installed 1.0.0
                  Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                  Adapter    "mihome-cloud" : 1.0.6    , installed 1.0.6
                  Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
                  Adapter    "minuvis"      : 2.7.1    , installed 2.7.1
                  Adapter    "moma"         : 1.2.9    , installed 1.2.9
                  Adapter    "node-red"     : 6.0.7    , installed 6.0.7
                  Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                  Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                  Adapter    "nut"          : 1.7.0    , installed 1.7.0
                  Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                  Adapter    "parser"       : 3.1.0    , installed 3.1.0
                  Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
                  Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
                  Adapter    "ping"         : 2.2.2    , installed 2.2.2
                  Adapter    "places"       : 1.4.0    , installed 1.4.0
                  Adapter    "proxmox"      : 2.5.5    , installed 2.5.5
                  Adapter    "ring"         : 6.4.0    , installed 6.4.0
                  Adapter    "roborock"     : 0.7.0    , installed 0.7.0
                  Adapter    "rssfeed"      : 4.0.3    , installed 4.0.3
                  Adapter    "samsung"      : 0.7.0    , installed 0.7.0
                  Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                  Adapter    "scenes"       : 4.0.4    , installed 4.0.4
                  Adapter    "script-restore": 0.0.12  , installed 0.0.12
                  Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                  Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
                  Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                  Adapter    "slideshow"    : 0.2.1    , installed 0.2.1
                  Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                  Adapter    "smartthings"  : 0.3.0    , installed 0.3.0
                  Adapter    "smoothed"     : 1.7.0    , installed 1.7.0
                  Adapter    "snmp"         : 3.4.0    , installed 3.4.0
                  Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                  Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                  Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                  Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
                  Adapter    "synology"     : 3.1.0    , installed 3.1.0
                  Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
                  Adapter    "text2command" : 4.0.0    , installed 4.0.0
                  Adapter    "tinymqttbroker": 0.1.6   , installed 0.1.6
                  Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                  Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                  Adapter    "upnp"         : 1.1.10   , installed 1.1.10
                  Adapter    "vis-2"        : 2.13.19  , installed 2.13.19
                  Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
                  Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
                  Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                  Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                  Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                  Adapter    "vis-jsontemplate": 4.4.3 , installed 4.4.3
                  Adapter    "vis-keyboard" : 0.0.3    , installed 0.0.3
                  Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                  Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                  Adapter    "vis-material" : 0.2.0    , installed 0.2.0
                  Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                  Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                  Adapter    "vw-connect"   : 0.8.3    , installed 0.8.3
                  Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                  Adapter    "weather-warnings": 0.10.1, installed 0.10.1
                  Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                  Adapter    "web"          : 8.1.0    , installed 8.1.0
                  Adapter    "webcal"       : 1.4.0    , installed 1.4.0
                  Adapter    "webui"        : 1.46.1   , installed 1.46.1
                  Adapter    "welcome"      : 1.1.1    , installed 1.1.1
                  Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                  Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
                  Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                  Adapter    "wireguard"    : 1.8.0    , installed 1.8.0
                  Adapter    "wled"         : 0.9.2    , installed 0.9.2
                  Adapter    "ws"           : 4.1.0    , installed 4.1.0
                  Adapter    "yahka"        : 1.1.6    , installed 1.1.6
                  Adapter    "youtube"      : 7.0.0    , installed 7.0.0
                  Adapter    "yr"           : 5.3.0    , installed 5.3.0
                  Adapter    "zigbee"       : 3.4.3    , installed 3.4.3
                  Objects and States
                  Objects:        51877
                  States:         40613
                  Hit:1 http://deb.debian.org/debian trixie InRelease
                  Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                  Hit:3 http://security.debian.org trixie-security InRelease
                  Hit:4 https://download.docker.com/linux/debian trixie InRelease
                  Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                  Reading package lists...
                  Pending systemupdates: 8
                  *** Listening Ports ***
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1708125    316/master
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      1000       1708881    756/io.admin.1
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1705619    162/iobroker.js-con
                  tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1705626    162/iobroker.js-con
                  tcp        0      0 192.168.178.250:9092    0.0.0.0:*               LISTEN      1000       1765633    3691/io.nuki.0
                  tcp        0      0 192.168.178.250:8081    0.0.0.0:*               LISTEN      1000       1708588    706/io.admin.0
                  tcp        0      0 192.168.178.250:8080    0.0.0.0:*               LISTEN      1000       1786308    4659/io.welcome.0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1749445    3511/io.mqtt.0
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1766479    3599/io.shelly.0
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1718496    2254/node-red
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1705447    1/init
                  tcp        0      0 192.168.178.250:1886    0.0.0.0:*               LISTEN      1000       1742469    3079/io.sonoff.0
                  tcp6       0      0 :::61991                :::*                    LISTEN      1000       1729952    2586/io.harmony.0
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1708126    316/master
                  tcp6       0      0 :::8555                 :::*                    LISTEN      1000       21974869   264156/go2rtc
                  tcp6       0      0 :::8554                 :::*                    LISTEN      1000       21974868   264156/go2rtc
                  tcp6       0      0 :::7999                 :::*                    LISTEN      1000       1718909    2545/io.geofency.0
                  tcp6       0      0 :::8091                 :::*                    LISTEN      1000       1778526    4354/io.lovelace.0
                  tcp6       0      0 :::8083                 :::*                    LISTEN      1000       1789049    4391/io.rtspStream.
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       21969094   263470/io.web.0
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1779896    4104/io.simple-api.
                  tcp6       0      0 :::8084                 :::*                    LISTEN      1000       1783867    4108/io.socketio.0
                  tcp6       0      0 :::1890                 :::*                    LISTEN      1000       1742666    3395/io.espresense.
                  tcp6       0      0 :::1984                 :::*                    LISTEN      1000       21970618   264156/go2rtc
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          1689396    1/init
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          1682170    1/init
                  udp        0      0 0.0.0.0:47959           0.0.0.0:*                           1000       21243235   214902/io.daikin-cl
                  udp        0      0 0.0.0.0:48113           0.0.0.0:*                           1000       1686874    162/iobroker.js-con
                  udp        0      0 0.0.0.0:48147           0.0.0.0:*                           1000       1801710    4928/io.smoothed.0
                  udp        0      0 0.0.0.0:48687           0.0.0.0:*                           1000       1722931    2692/io.places.0
                  udp        0      0 0.0.0.0:49062           0.0.0.0:*                           1000       1789190    4659/io.welcome.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1705448    1/init
                  udp        0      0 0.0.0.0:49367           0.0.0.0:*                           1000       1764851    3691/io.nuki.0
                  udp        0      0 0.0.0.0:49396           0.0.0.0:*                           1000       1800201    4873/io.smartthings
                  udp        0      0 0.0.0.0:33059           0.0.0.0:*                           1000       1789029    4414/io.upnp.0
                  udp        0      0 0.0.0.0:49478           0.0.0.0:*                           1000       1722515    2345/io.whatsapp-cm
                  udp        0      0 0.0.0.0:49546           0.0.0.0:*                           1000       1718907    2545/io.geofency.0
                  udp        0      0 0.0.0.0:33369           0.0.0.0:*                           1000       34569057   403759/io.spotify-p
                  udp        0      0 0.0.0.0:49872           0.0.0.0:*                           1000       1778586    4400/io.text2comman
                  udp        0      0 0.0.0.0:50084           0.0.0.0:*                           1000       1784624    4909/io.echarts.0
                  udp        0      0 0.0.0.0:33706           0.0.0.0:*                           1000       1772035    4183/io.iqontrol.0
                  udp        0      0 0.0.0.0:50261           0.0.0.0:*                           1000       1767837    3617/io.webcal.0
                  udp        0      0 0.0.0.0:33983           0.0.0.0:*                           1000       36240411   441579/io.broadlink
                  udp        0      0 0.0.0.0:34013           0.0.0.0:*                           1000       1772484    4736/io.philips-tv.
                  udp        0      0 0.0.0.0:50402           0.0.0.0:*                           1000       1742766    3469/io.samsung_tiz
                  udp        0      0 0.0.0.0:34035           0.0.0.0:*                           1000       1783898    4171/io.iot.0
                  udp        0      0 0.0.0.0:50420           0.0.0.0:*                           1000       21982803   264309/io.tuya.0
                  udp        0      0 0.0.0.0:50549           0.0.0.0:*                           1000       1730039    2655/io.ping.0
                  udp        0      0 0.0.0.0:50703           0.0.0.0:*                           1000       1791104    4406/io.sourceanaly
                  udp        0      0 0.0.0.0:34605           0.0.0.0:*                           1000       1722975    2735/io.samsung.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1795244    4414/io.upnp.0
                  udp        0      0 0.0.0.0:35103           0.0.0.0:*                           1000       1718136    617/io.javascript.0
                  udp        0      0 0.0.0.0:51497           0.0.0.0:*                           1000       19047909   2850/io.tr-064.1
                  udp        0      0 0.0.0.0:35228           0.0.0.0:*                           1000       32116829   358456/io.philips-a
                  udp        0      0 0.0.0.0:51625           0.0.0.0:*                           1000       34596178   404410/io.vis-2.0
                  udp        0      0 0.0.0.0:51754           0.0.0.0:*                           1000       1789043    4414/io.upnp.0
                  udp        0      0 0.0.0.0:35425           0.0.0.0:*                           1000       1783836    4140/io.fullcalenda
                  udp        0      0 0.0.0.0:51828           0.0.0.0:*                           1000       1749007    2764/io.samsung.1
                  udp        0      0 0.0.0.0:52152           0.0.0.0:*                           1000       32116832   358456/io.philips-a
                  udp        0      0 0.0.0.0:52742           0.0.0.0:*                           1000       1720337    1479/io.history.0
                  udp        0      0 0.0.0.0:36479           0.0.0.0:*                           1000       11973155   129508/io.vw-connec
                  udp        0      0 0.0.0.0:52896           0.0.0.0:*                           1000       36240407   441579/io.broadlink
                  udp        0      0 0.0.0.0:53077           0.0.0.0:*                           1000       1771805    3937/io.discovery.0
                  udp        0      0 0.0.0.0:53151           0.0.0.0:*                           1000       1789008    4427/io.vis-inventw
                  udp        0      0 0.0.0.0:37345           0.0.0.0:*                           1000       33518481   378992/io.nut.0
                  udp        0      0 0.0.0.0:53930           0.0.0.0:*                           1000       1784164    4532/io.webui.0
                  udp        0      0 0.0.0.0:37662           0.0.0.0:*                           1000       1784081    4366/io.moma.0
                  udp        0      0 0.0.0.0:37903           0.0.0.0:*                           1000       1760530    3366/io.wifilight.0
                  udp        0      0 0.0.0.0:54335           0.0.0.0:*                           1000       1768863    3761/io.zigbee.3
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       36212682   441294/io.ham.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1789206    4706/io.wled.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1774748    3899/io.chromecast.
                  udp        0      0 192.168.178.250:5353    0.0.0.0:*                           1000       1727099    2850/io.tr-064.1
                  udp        0      0 0.0.0.0:54643           0.0.0.0:*                           1000       1713509    2213/io.node-red.0
                  udp        0      0 0.0.0.0:38942           0.0.0.0:*                           1000       36240419   441579/io.broadlink
                  udp        0      0 0.0.0.0:38944           0.0.0.0:*                           1000       36240412   441579/io.broadlink
                  udp        0      0 0.0.0.0:38965           0.0.0.0:*                           1000       36240425   441579/io.broadlink
                  udp        0      0 0.0.0.0:39064           0.0.0.0:*                           1000       1765210    3899/io.chromecast.
                  udp        0      0 0.0.0.0:39124           0.0.0.0:*                           1000       1796271    4852/io.wallpanel.0
                  udp        0      0 0.0.0.0:39280           0.0.0.0:*                           1000       1771787    3859/io.zigbee.1
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       21969454   264309/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       21969455   264309/io.tuya.0
                  udp        0      0 0.0.0.0:39615           0.0.0.0:*                           1000       1788148    4354/io.lovelace.0
                  udp        0      0 0.0.0.0:56140           0.0.0.0:*                           1000       36240401   441579/io.broadlink
                  udp        0      0 0.0.0.0:56574           0.0.0.0:*                           1000       36237353   441579/io.broadlink
                  udp        0      0 0.0.0.0:56688           0.0.0.0:*                           1000       1794564    4815/io.alexa-timer
                  udp        0      0 0.0.0.0:40308           0.0.0.0:*                           1000       35250311   420440/io.device-wa
                  udp        0      0 0.0.0.0:57204           0.0.0.0:*                           1000       28316895   314798/io.homeconne
                  udp        0      0 0.0.0.0:57721           0.0.0.0:*                           1000       1772386    4595/io.slideshow.0
                  udp        0      0 0.0.0.0:57804           0.0.0.0:*                           1000       1717073    809/io.email.0
                  udp        0      0 0.0.0.0:58310           0.0.0.0:*                           1000       1709699    756/io.admin.1
                  udp        0      0 0.0.0.0:42128           0.0.0.0:*                           1000       1749364    3395/io.espresense.
                  udp        0      0 0.0.0.0:42498           0.0.0.0:*                           1000       1758962    3252/io.fullybrowse
                  udp        0      0 0.0.0.0:42654           0.0.0.0:*                           1000       34599017   404425/io.rssfeed.0
                  udp        0      0 0.0.0.0:59284           0.0.0.0:*                           1000       1742175    2808/io.shuttercont
                  udp        0      0 0.0.0.0:43067           0.0.0.0:*                           1000       1791707    4964/io.omada.0
                  udp        0      0 0.0.0.0:59540           0.0.0.0:*                           1000       1729830    2470/io.backitup.0
                  udp        0      0 0.0.0.0:59879           0.0.0.0:*                           1000       1729950    2586/io.harmony.0
                  udp        0      0 0.0.0.0:59905           0.0.0.0:*                           1000       32122900   358449/io.philips-a
                  udp        0      0 0.0.0.0:59954           0.0.0.0:*                           1000       1713694    2272/io.scenes.0
                  udp        0      0 0.0.0.0:43572           0.0.0.0:*                           1000       1729497    2539/io.alexa2.0
                  udp        0      0 0.0.0.0:43675           0.0.0.0:*                           1000       1766875    3833/io.zigbee.2
                  udp        0      0 0.0.0.0:43782           0.0.0.0:*                           1000       1745137    2890/io.tr-064.2
                  udp        0      0 0.0.0.0:43862           0.0.0.0:*                           1000       1742467    3079/io.sonoff.0
                  udp        0      0 0.0.0.0:60524           0.0.0.0:*                           1000       1718606    2383/io.influxdb.0
                  udp        0      0 0.0.0.0:44309           0.0.0.0:*                           1000       1745262    3117/io.systeminfo.
                  udp        0      0 0.0.0.0:60746           0.0.0.0:*                           1000       13431821   140710/io.cloud.0
                  udp        0      0 0.0.0.0:44386           0.0.0.0:*                           1000       1774169    3800/io.zigbee.4
                  udp        0      0 0.0.0.0:44542           0.0.0.0:*                           1000       1772303    4475/io.windows-con
                  udp        0      0 0.0.0.0:44630           0.0.0.0:*                           1000       1794497    4768/io.lightcontro
                  udp        0      0 0.0.0.0:44651           0.0.0.0:*                           1000       25797069   291101/io.telegram.
                  udp        0      0 0.0.0.0:44676           0.0.0.0:*                           1000       36580050   441579/io.broadlink
                  udp        0      0 0.0.0.0:44893           0.0.0.0:*                           1000       1722470    2290/io.whatsapp-cm
                  udp        0      0 0.0.0.0:45067           0.0.0.0:*                           1000       21973183   263470/io.web.0
                  udp        0      0 0.0.0.0:45470           0.0.0.0:*                           1000       32121182   358449/io.philips-a
                  udp        0      0 0.0.0.0:45557           0.0.0.0:*                           1000       1801746    4944/io.daswetter.0
                  udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       1729953    2586/io.harmony.0
                  udp        0      0 0.0.0.0:45634           0.0.0.0:*                           1000       36240410   441579/io.broadlink
                  udp        0      0 0.0.0.0:45817           0.0.0.0:*                           1000       36240402   441579/io.broadlink
                  udp        0      0 0.0.0.0:45825           0.0.0.0:*                           1000       1786173    4391/io.rtspStream.
                  udp        0      0 0.0.0.0:46002           0.0.0.0:*                           1000       25788859   291109/io.telegram.
                  udp        0      0 0.0.0.0:46004           0.0.0.0:*                           1000       1788205    4373/io.parser.0
                  udp        0      0 0.0.0.0:46049           0.0.0.0:*                           1000       1749443    3511/io.mqtt.0
                  udp        0      0 0.0.0.0:46309           0.0.0.0:*                           1000       36240485   441589/io.klipper-m
                  udp        0      0 0.0.0.0:46310           0.0.0.0:*                           1000       1772060    4104/io.simple-api.
                  udp        0      0 0.0.0.0:46404           0.0.0.0:*                           1000       1786336    4706/io.wled.0
                  udp        0      0 0.0.0.0:46558           0.0.0.0:*                           1000       1713244    706/io.admin.0
                  udp        0      0 0.0.0.0:46946           0.0.0.0:*                           1000       1783865    4108/io.socketio.0
                  udp        0      0 0.0.0.0:47489           0.0.0.0:*                           1000       36240398   441579/io.broadlink
                  udp        0      0 0.0.0.0:47545           0.0.0.0:*                           1000       21973202   263463/io.roborock.
                  udp        0      0 0.0.0.0:47624           0.0.0.0:*                           1000       36240422   441579/io.broadlink
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       36236548   441579/io.broadlink
                  udp6       0      0 :::111                  :::*                                0          1706801    1/init
                  2026-05-12 21:48:13.577  - warn: javascript.0 (617)     at processImmediate (node:internal/timers:484:21)
                  2026-05-12 21:48:13.577  - warn: javascript.0 (617)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
                  2026-05-12 21:48:13.577  - warn: javascript.0 (617) You are assigning a string to the state "0_userdata.0.Luftreiniger_Schlafzimmer_Betriebszeit" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
                  2026-05-12 21:48:13.578  - warn: javascript.0 (617)     at setState (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:2661:20)
                  2026-05-12 21:48:13.578  - warn: javascript.0 (617)     at Object.<anonymous> (script.js.common.Bosch_Systeme_Sekunden_umrechnen.Waschmaschine_Zeitumrechnung:30:3)
                  2026-05-12 21:48:13.578  - warn: javascript.0 (617)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
                  2026-05-12 21:48:13.578  - warn: javascript.0 (617)     at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
                  2026-05-12 21:48:13.578  - warn: javascript.0 (617)     at JavaScript.emit (node:events:519:28)
                  2026-05-12 21:48:13.578  - warn: javascript.0 (617)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11163:53)
                  2026-05-12 21:48:13.578  - warn: javascript.0 (617)     at processImmediate (node:internal/timers:484:21)
                  2026-05-12 21:48:13.578  - warn: javascript.0 (617)     at process.callbackTrampoline (node:internal/async_hooks:130:17)
                  2026-05-12 21:48:13.607  - info: philips-air.0 (358449) State value to set for "philips-air.0.status.pm25" has to be type "number" but received type "string"
                  2026-05-12 21:48:13.652  - info: philips-air.0 (358449) State value to set for "philips-air.0.status.totalVolatileOrganicCompounds" has to be type "number" but received type "string"
                  2026-05-12 21:48:13.701  - info: philips-air.0 (358449) State value to set for "philips-air.0.filter.preFilterCleanInHours" has to be type "number" but received type "string"
                  2026-05-12 21:48:13.744  - info: philips-air.0 (358449) State value to set for "philips-air.0.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
                  2026-05-12 21:48:13.786  - info: philips-air.0 (358449) State value to set for "philips-air.0.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
                  2026-05-12 21:48:15.890  - warn: wifilight.0 (3366) [192.168.178.231] onError: EHOSTUNREACH connect EHOSTUNREACH 192.168.178.231:5577 - reconnecting in 5 sec...
                  iob diag has finished.
                  admin@iobroker:~$
                  • Halbeisen FabianH Offline
                    Halbeisen Fabian
                    @TimoWald sagte:
                    den Link der in der error Liste auftaucht (https://api.home-connect.com/security/oauth/device_verify?user_code=G6KD-XW23) im Browser öffnen und die Zugangsdaten eingeben und bestätigen.
                      Moin moin,
                      TimoWald
                      @holly200289 bei mir fehlt auch der Kaffeevollautomat. In der Homeconnect App auf dem Handy ist sie drin.
                      • T TimoWald
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @TimoWald
                        Den Hinweis von @halbeisen-fabian haste aber schon über Dir gelesen?
                        Und ansonsten wird im Log genauestens beschrieben , was zu tun ist.
                          holly200289
                          Es ist egal was man macht, dass System erkennt nur zwei Geräte
                            holly200289
                            homeconnect.0
                            2026-05-14 19:53:32.754	info	384020390180002730/programs/active/options: There is no program active.
                            homeconnect.0
                            2026-05-14 19:53:31.830	info	384020390180002730/programs/selected/options: There is no program selected.
                            homeconnect.0
                            2026-05-14 19:53:31.516	info	Wait 1 minute!
                            homeconnect.0
                            2026-05-14 19:53:31.508	info	No array: selected
                            homeconnect.0
                            2026-05-14 19:53:31.339	info	402040424779000175/programs/active/options: There is no program active.
                            homeconnect.0
                            2026-05-14 19:53:31.294	info	No array: active
                            homeconnect.0
                            2026-05-14 19:53:31.146	info	384020390180002730/programs/selected: There is no program selected.
                            homeconnect.0
                            2026-05-14 19:53:31.078	info	384020390180002730/programs/active: There is no program active.
                            homeconnect.0
                            2026-05-14 19:53:30.023	info	No array: selected
                            homeconnect.0
                            2026-05-14 19:53:29.911	info	No array: active
                            homeconnect.0
                            2026-05-14 19:53:29.734	info	402040424779000175/programs/active: There is no program active.
                            homeconnect.0
                            2026-05-14 19:53:29.333	info	Found 4 devices. Start slow update!
                            homeconnect.0
                            2026-05-14 19:53:29.086	info	starting. Version 1.6.0 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v22.22.2, js-controller: 7.1.2
                            homeconnect.0
                            2026-05-14 19:53:23.741	info	terminating
                            homeconnect.0
                            homeconnect.0
                            2026-05-14 19:53:23.740	info	terminating
                            homeconnect.0
                            homeconnect.0
                            2026-05-14 19:53:23.241	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            homeconnect.0
                            homeconnect.0
                            2026-05-14 19:53:23.240	info	terminating
                            homeconnect.0
                            homeconnect.0
                            2026-05-14 19:53:23.183	info	Got terminate signal TERMINATE_YOURSELF
                            homeconnect.0
                              holly200289
                              Bzw. werden als Offline angzeigt
                                holly200289
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @holly200289
                                  Ich bin noch bei Version 1.4.3
                                  Eventuell kannste dortin noch downgraden und die ganze Sache nochmal probieren.
