  4. Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus
    6.3k
canbuscanbus adapterrotex hpsu
526 Beiträge 26 Kommentatoren 151.5k Aufrufe 21 Beobachtet
  • M MichaelK
    @crycode
    Ich habe nun nochmal auf 22.18.0 geupdatet, aber der Adapter lies sich wieder nicht starten.
    Erst nach einem "npm rebuild" von /opt/iobroker/node_modules/socketcan hat es dann funktioniert.
    Log:
    2025-08-21 17:36:01.315 - info: host.raspi instance system.adapter.canbus.0 in version "2.2.0" (non-npm: crycode-de/ioBroker.canbus) started with pid 6611
    2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: node:internal/modules/cjs/loader:1846
    2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: ^
    2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: Error: Module did not self-register: '/opt/iobroker/node_modules/socketcan/build/Release/can.node'.
    2025-08-21 17:36:01.892 - error: host.raspi Caught by controller[0]: at Object..node (node:internal/modules/cjs/loader:1846:18)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1423:32)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1246:12)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1445:12)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at require (node:internal/modules/helpers:135:16)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/socketcan/dist/socketcan.js:51:26)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1688:14)
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1820:10) {
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: }
    2025-08-21 17:36:01.893 - error: host.raspi Caught by controller[0]: Node.js v22.18.0
    2025-08-21 17:36:01.893 - error: host.raspi instance system.adapter.canbus.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-08-21 17:36:01.893 - info: host.raspi Restart adapter system.adapter.canbus.0 because enabled
    RaspiUserR Offline
    RaspiUserR Offline
    RaspiUser
    #516
    @crycode
    @michaelk sagte in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
    Erst nach einem "npm rebuild" von /opt/iobroker/node_modules/socketcan ....
    ... der "Trick" hat mir auch geholfen, Danke dafür
    • E Offline
      earl80
      #517
      Gibt es eigentlich auch die Möglichkeit, die Heizgrenze Tag/Nacht anzupassen? Abfragen ist canbus.0.680.fa0116/fa0117, aber setzen habe ich nicht gefunden...
      crycodeC 1 Antwort Letzte Antwort
      • E earl80
        crycodeC Offline
        crycodeC Offline
        crycode
        #518
        @earl80 Ich habe der latest Config soeben fa0116-set und fa0117-set hinzugefügt. Kannst du das bitte mal testen, ob es wie gedacht funktioniert?
        Meine Adapter: discord | canbus | ds18b20 | odl | radiohead
        E 1 Antwort Letzte Antwort
        • crycodeC crycode
          earl80
          schrieb am zuletzt editiert von earl80
          #519
          @crycode said in Rotex HPSU / Daikin Altherma Wärmepumpe über ioBroker.canbus:
          fa0116-set
          Zuerst habe ich probiert die Config mit der Adapterversion 2.2.0 zu laden, da kommt aber eine Fehlermeldung. Mit der Version 2.2.1 kann man die Config wieder laden. Jetzt habe ich die latest aber direkt von Github (https://github.com/crycode-de/ioBroker.canbus/blob/master/well-known-messages/configs/rotex-hpsu-latest.json) geladen und importiert. Die neuen fa0116-set und fa0117-set sehe ich bei den Objekten nicht.
          crycodeC 2 Antworten Letzte Antwort
          • E earl80
            fa0116-set
            crycodeC Offline
            crycodeC Offline
            crycode
            #520
            @earl80 Huch, da scheint was an der Import-Funktion kaputt zu sein. Schaue ich mir an...
            • E earl80
              fa0116-set
              crycodeC Offline
              crycodeC Offline
              crycode
              schrieb am zuletzt editiert von crycode
              #521
              @earl80 Mit der neuen Version 2.3.0 vom Adapter (aktuell per NPM installierbar) sollte der Import nun wieder funktionieren.
              Edit: Wenn wie fa0116-set und fa0117-set Punkte bei dir nicht direkt nach dem Import angezeigt werden, dann einmal mit "Speichern und Schließen" die Adapterkonfiguration beenden und dann neu öffnen. Danach sollten die beiden Parser auf jeden Fall da sein.
              Zudem wird ab v2.3.0 nun auch Node.js 24 unterstützt.
              • crycodeC crycode
                earl80
                #522
                @crycode Da sich meine Fritzbox einfach verabschiedet hat, melde ich mich erst jetzt. Es funktioniert alles - vielen Dank!!!
                  dv1407
                  #523
                  Hallo Zusammen, was machen ich den falsch wenn ich im candump nur die gesendeten Nachrichten sehe?
                  (1777823662.939294) can0 680 [7] 31 00 FA 06 70 00 00
                  (1777823662.939386) can0 680 [7] 31 00 FA 06 70 00 00
                  (1777823663.172858) can0 680 [7] 31 00 FA 06 71 00 00
                  (1777823663.172999) can0 680 [7] 31 00 FA 06 71 00 00
                  (1777823663.380897) can0 680 [7] 31 00 FA 06 72 00 00
                  (1777823663.381000) can0 680 [7] 31 00 FA 06 72 00 00
                  (1777823663.586324) can0 680 [7] 31 00 FA 06 73 00 00
                  (1777823663.586414) can0 680 [7] 31 00 FA 06 73 00 00
                  (1777823663.776907) can0 680 [7] 31 00 FA 06 79 00 00
                  (1777823663.777006) can0 680 [7] 31 00 FA 06 79 00 00
                  (1777823663.969841) can0 680 [7] 31 00 FA 06 7E 00 00
                  (1777823663.969938) can0 680 [7] 31 00 FA 06 7E 00 00
                  (1777823664.160110) can0 680 [7] 31 00 FA 06 93 00 00
                  (1777823664.160213) can0 680 [7] 31 00 FA 06 93 00 00
                  (1777823664.374354) can0 680 [7] 31 00 FA 06 94 00 00
                  (1777823664.374520) can0 680 [7] 31 00 FA 06 94 00 00
                  • D dv1407
                    crycodeC Offline
                    crycodeC Offline
                    crycode
                    #524
                    @dv1407 Hi, das sieht so aus, als würde etwas mit der Bus-Verbindung nicht stimmen. Wenn du nur das gesendete siehst, dann kommen von der Gegenstelle (der Wärmepumpe) gar keine Daten bei dir an.
                    • crycodeC crycode
                      dv1407
                      #525
                      @crycode Wie kann ich hier den Fehler finden. Ich habe H und L jeweils mit der Wärmepumpe und Canhat verbunden und alles konfiguriert?
                      • D dv1407
                        crycodeC Offline
                        crycodeC Offline
                        crycode
                        #526
                        @dv1407 Du solltest die Verkabelung nochmals prüfen und dabei darauf achten, dass H und L korrekt sind und auch GND (Masse) verbunden ist. Dazu auch mal die Konfiguration deines CAN- Interfaces prüfen, besonders die Baudrate.
