  4. Ikea Tradfri Adapter läuft nicht.
    5.5k
28 Beiträge 3 Kommentatoren 4.1k Aufrufe
  • AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    Wir kommen der Sache näher - bitte nochmal probieren.
    • F Offline
      fossil
      hier das ergebniss nach dem ich es nun das zweite mal ausgeführt habe:
      pi@raspberrypi:~ $ sudo npm install https://github.com/AlCalzone/node-aead-crypto/tarball/fix-3 --production
      ! > node-aead-crypto@1.0.4 install /home/pi/node_modules/node-aead-crypto
      node lib/install.js
      ! running rpi1 installation script
      gyp ERR! build error
      gyp ERR! stack Error: You must run node-gyp configure first!
      gyp ERR! stack at ReadFileContext. <anonymous>(/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:51:20)
      gyp ERR! stack at ReadFileContext.callback (/usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16)
      gyp ERR! stack at FSReqWrap.readFileAfterOpen [as oncomplete] (fs.js:367:13)
      gyp ERR! System Linux 4.9.59+
      gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--module=/home/pi/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm/node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=/home/pi/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm"
      gyp ERR! cwd /home/pi/node_modules/node-aead-crypto
      gyp ERR! node -v v6.12.3
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --module=/home/pi/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm/node_aead_crypto.node --module_name=node_aead_crypto --module_path=/home/pi/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm' (1)
      node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack at emitTwo (events.js:106:13)
      node-pre-gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:920:16)
      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
      node-pre-gyp ERR! System Linux 4.9.59+
      node-pre-gyp ERR! command "/usr/local/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "build"
      node-pre-gyp ERR! cwd /home/pi/node_modules/node-aead-crypto
      node-pre-gyp ERR! node -v v6.12.3
      node-pre-gyp ERR! node-pre-gyp -v v0.6.39
      node-pre-gyp ERR! not ok
      ! npm ERR! Linux 4.9.59+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "run" "install:rpi1"
      npm ERR! node v6.12.3
      npm ERR! npm v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! node-aead-crypto@1.0.4 install:rpi1: node-gyp configure & node-pre-gyp build
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the node-aead-crypto@1.0.4 install:rpi1 script 'node-gyp configure & node-pre-gyp build'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the node-aead-crypto package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node-gyp configure & node-pre-gyp build
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs node-aead-crypto
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR! npm owner ls node-aead-crypto
      npm ERR! There is likely additional logging output above.
      npm WARN Local package.json exists, but node_modules missing, did you mean to install?
      ! npm ERR! Please include the following file with any support request:
      npm ERR! /home/pi/node_modules/node-aead-crypto/npm-debug.log
      gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.12.3"
      gyp WARN EACCES attempting to reinstall using temporary dev dir "/home/pi/node_modules/node-aead-crypto/.node-gyp"
      gyp: Undefined variable module_name in binding.gyp while trying to load binding.gyp
      gyp ERR! configure error
      gyp ERR! stack Error: gyp failed with exit code: 1
      gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
      gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure"
      gyp ERR! not ok
      child_process.js:516
      throw err;
      ! Error: Command failed: npm run install:rpi1
      gyp ERR! not ok
      npm ERR!
      gyp ERR! not ok
      ! at checkExecSyncError (child_process.js:473:13)
      at execSync (child_process.js:513:13)
      at Object. <anonymous>(/home/pi/node_modules/node-aead-crypto/lib/install.js:22:1)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions..js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.runMain (module.js:604:10)
      at run (bootstrap_node.js:383:7)
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm WARN pi No description
      npm WARN pi No repository field.
      npm WARN pi No README data
      npm WARN pi No license field.
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/AlCalzone/node-aead-crypto/tarball/fix-3" "--production"
      ! npm ERR! node-aead-crypto@1.0.4 install: node lib/install.js
      npm ERR!
      npm ERR! Failed at the node-aead-crypto@1.0.4 install script 'node lib/install.js'.
      npm ERR! node lib/install.js
      npm ERR! /home/pi/npm-debug.log
      pi@raspberrypi:~ $</anonymous></anonymous></anonymous></anonymous></anonymous>
        AlCalzoneA Offline
        AlCalzone
        Neuer Versuch ;) Nochmal bitte!
        • F Offline
          fossil
          hier der nächste versuch :D
          node lib/install.js
          make: *** Keine Regel vorhanden, um das Ziel „../.node-gyp/6.12.3/include/node/common.gypi“,
          benötigt von „Makefile“, zu erstellen. Schluss.
          gyp ERR! stack Error: make failed with exit code: 2
          gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
          gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--build-from-source" "--module=/home/pi/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm/node_aead_crypto.node" "--module_name=node_aead_crypto" "--module_path=/home/pi/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm"
          gyp ERR! not ok
          node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --build-from-source --module=/home/pi/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm/node_aead_crypto.node --module_name=node_aead_crypto --module_path=/home/pi/node_modules/node-aead-crypto/build/Release/node-v48-linux-arm' (1)
          node-pre-gyp ERR! command "/usr/local/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--build-from-source"
          npm ERR! node-aead-crypto@1.0.4 install:rpi1: node-pre-gyp install --build-from-source
          npm ERR!
          npm ERR! Failed at the node-aead-crypto@1.0.4 install:rpi1 script 'node-pre-gyp install --build-from-source'.
          npm ERR! node-pre-gyp install --build-from-source
          throw err;
          gyp ERR! not ok
          npm ERR!
          npm ERR!
            AlCalzoneA Offline
            AlCalzone
            Abgesehen davon, dass du wieder im falschen Ordner unterwegs bist (das sollte wie vorhin /opt/iobroker) sein, dürfte jetzt nur eine Kleinigkeit am Kommando fehlen:
            sudo npm install https://github.com/AlCalzone/node-aead-crypto/tarball/fix-3 --production --unsafe-perm
            • F Offline
              fossil
              So probiere das nun gerade mit der Installation noch mal aus :D
              und da ich das in dem Ordner /opt/iobroker/ machen soll habe ich gekonnt überlesen :shock:
              werde dann gleich berichten ob es geklappt hat. :)
              Woran liegt das überhaupt?
              Ist das ein Problem mit dem Raspberry Pi1 oder habe ich bei der installation am Anfang schon etwas falsch gemacht!
              • F Offline
                fossil
                hier das ergebniss in dem Richtigem Ordner :lol:
                pi@raspberrypi:~ $ cd /opt/iobroker/
                pi@raspberrypi:/opt/iobroker $ sudo npm install https://github.com/AlCalzone/node-aead-crypto/tarball/fix-3 --production --unsafe-perm
                ! > node-aead-crypto@1.0.4 install /opt/iobroker/node_modules/node-aead-crypto
                node lib/install.js
                abbrev@1.1.1 node_modules/node-aead-crypto/node_modules/abbrev -> node_modules/abbrev
                aproba@1.2.0 node_modules/node-aead-crypto/node_modules/aproba -> node_modules/aproba
                block-stream@0.0.9 node_modules/node-aead-crypto/node_modules/block-stream -> node_modules/block-stream
                console-control-strings@1.1.0 node_modules/node-aead-crypto/node_modules/console-control-strings -> node_modules/console-control-strings
                delegates@1.0.0 node_modules/node-aead-crypto/node_modules/delegates -> node_modules/delegates
                are-we-there-yet@1.1.4 node_modules/node-aead-crypto/node_modules/are-we-there-yet -> node_modules/are-we-there-yet
                detect-libc@1.0.3 node_modules/node-aead-crypto/node_modules/detect-libc -> node_modules/detect-libc
                fstream@1.0.11 node_modules/node-aead-crypto/node_modules/fstream -> node_modules/fstream
                fstream-ignore@1.0.5 node_modules/node-aead-crypto/node_modules/fstream-ignore -> node_modules/fstream-ignore
                has-unicode@2.0.1 node_modules/node-aead-crypto/node_modules/has-unicode -> node_modules/has-unicode
                ini@1.3.5 node_modules/node-aead-crypto/node_modules/ini -> node_modules/ini
                jsonify@0.0.0 node_modules/node-aead-crypto/node_modules/jsonify -> node_modules/jsonify
                json-stable-stringify@1.0.1 node_modules/node-aead-crypto/node_modules/json-stable-stringify -> node_modules/json-stable-stringify
                • ansi-regex@2.1.1 node_modules/node-aead-crypto/node_modules/ansi-regex
                • asn1@0.2.3 node_modules/node-aead-crypto/node_modules/asn1
                • asynckit@0.4.0 node_modules/node-aead-crypto/node_modules/asynckit
                • aws4@1.6.0 node_modules/node-aead-crypto/node_modules/aws4
                • balanced-match@1.0.0 node_modules/node-aead-crypto/node_modules/balanced-match
                • browser-stdout@1.3.0 node_modules/node-aead-crypto/node_modules/browser-stdout
                • caseless@0.12.0 node_modules/node-aead-crypto/node_modules/caseless
                • co@4.6.0 node_modules/node-aead-crypto/node_modules/co
                • code-point-at@1.1.0 node_modules/node-aead-crypto/node_modules/code-point-at
                • commander@2.14.1 node_modules/node-aead-crypto/node_modules/commander
                • concat-map@0.0.1 node_modules/node-aead-crypto/node_modules/concat-map
                • brace-expansion@1.1.8 node_modules/node-aead-crypto/node_modules/brace-expansion
                • core-util-is@1.0.2 node_modules/node-aead-crypto/node_modules/core-util-is
                • assert-plus@1.0.0 node_modules/node-aead-crypto/node_modules/dashdash/node_modules/assert-plus
                • dashdash@1.14.1 node_modules/node-aead-crypto/node_modules/dashdash
                • delayed-stream@1.0.0 node_modules/node-aead-crypto/node_modules/delayed-stream
                • combined-stream@1.0.6 node_modules/node-aead-crypto/node_modules/combined-stream
                • diff@3.2.0 node_modules/node-aead-crypto/node_modules/diff
                • escape-string-regexp@1.0.5 node_modules/node-aead-crypto/node_modules/escape-string-regexp
                • extend@3.0.1 node_modules/node-aead-crypto/node_modules/extend
                • extsprintf@1.3.0 node_modules/node-aead-crypto/node_modules/extsprintf
                • forever-agent@0.6.1 node_modules/node-aead-crypto/node_modules/forever-agent
                • fs.realpath@1.0.0 node_modules/node-aead-crypto/node_modules/fs.realpath
                • assert-plus@1.0.0 node_modules/node-aead-crypto/node_modules/getpass/node_modules/assert-plus
                • getpass@0.1.7 node_modules/node-aead-crypto/node_modules/getpass
                • graceful-fs@4.1.11 node_modules/node-aead-crypto/node_modules/graceful-fs
                • graceful-readlink@1.0.1 node_modules/node-aead-crypto/node_modules/graceful-readlink
                • growl@1.9.2 node_modules/node-aead-crypto/node_modules/growl
                • has-flag@1.0.0 node_modules/node-aead-crypto/node_modules/has-flag
                • he@1.1.1 node_modules/node-aead-crypto/node_modules/he
                • inherits@2.0.3 node_modules/node-aead-crypto/node_modules/inherits
                • is-typedarray@1.0.0 node_modules/node-aead-crypto/node_modules/is-typedarray
                • isstream@0.1.2 node_modules/node-aead-crypto/node_modules/isstream
                • jsbn@0.1.1 node_modules/node-aead-crypto/node_modules/jsbn
                • ecc-jsbn@0.1.1 node_modules/node-aead-crypto/node_modules/ecc-jsbn
                • json-schema@0.2.3 node_modules/node-aead-crypto/node_modules/json-schema
                • json-stringify-safe@5.0.1 node_modules/node-aead-crypto/node_modules/json-stringify-safe
                • json3@3.3.2 node_modules/node-aead-crypto/node_modules/json3
                • assert-plus@1.0.0 node_modules/node-aead-crypto/node_modules/jsprim/node_modules/assert-plus
                • lodash._basecopy@3.0.1 node_modules/node-aead-crypto/node_modules/lodash._basecopy
                • lodash._basecreate@3.0.3 node_modules/node-aead-crypto/node_modules/lodash._basecreate
                • lodash._getnative@3.9.1 node_modules/node-aead-crypto/node_modules/lodash._getnative
                • lodash._isiterateecall@3.0.9 node_modules/node-aead-crypto/node_modules/lodash._isiterateecall
                • lodash.isarguments@3.1.0 node_modules/node-aead-crypto/node_modules/lodash.isarguments
                • lodash.isarray@3.0.4 node_modules/node-aead-crypto/node_modules/lodash.isarray
                • lodash.keys@3.1.2 node_modules/node-aead-crypto/node_modules/lodash.keys
                • lodash._baseassign@3.2.0 node_modules/node-aead-crypto/node_modules/lodash._baseassign
                • lodash.create@3.1.1 node_modules/node-aead-crypto/node_modules/lodash.create
                • mime@1.6.0 node_modules/node-aead-crypto/node_modules/mime
                • github@0.2.4 node_modules/node-aead-crypto/node_modules/github
                • mime-db@1.33.0 node_modules/node-aead-crypto/node_modules/mime-db
                • mime-types@2.1.18 node_modules/node-aead-crypto/node_modules/mime-types
                • minimatch@3.0.4 node_modules/node-aead-crypto/node_modules/minimatch
                • minimist@0.0.8 node_modules/node-aead-crypto/node_modules/minimist
                • mkdirp@0.5.1 node_modules/node-aead-crypto/node_modules/mkdirp
                • commander@2.9.0 node_modules/node-aead-crypto/node_modules/mocha/node_modules/commander
                • ms@2.0.0 node_modules/node-aead-crypto/node_modules/ms
                • debug@2.6.8 node_modules/node-aead-crypto/node_modules/debug
                • node-pre-gyp-github@1.3.1 node_modules/node-aead-crypto/node_modules/node-pre-gyp-github
                • number-is-nan@1.0.1 node_modules/node-aead-crypto/node_modules/number-is-nan
                • is-fullwidth-code-point@1.0.0 node_modules/node-aead-crypto/node_modules/is-fullwidth-code-point
                • oauth-sign@0.8.2 node_modules/node-aead-crypto/node_modules/oauth-sign
                • object-assign@4.1.1 node_modules/node-aead-crypto/node_modules/object-assign
                • path-is-absolute@1.0.1 node_modules/node-aead-crypto/node_modules/path-is-absolute
                • punycode@1.4.1 node_modules/node-aead-crypto/node_modules/punycode
                • safe-buffer@5.1.1 node_modules/node-aead-crypto/node_modules/safe-buffer
                • semver@5.5.0 node_modules/node-aead-crypto/node_modules/semver
                • set-blocking@2.0.0 node_modules/node-aead-crypto/node_modules/set-blocking
                • should-type@1.4.0 node_modules/node-aead-crypto/node_modules/should-type
                • should-equal@1.0.1 node_modules/node-aead-crypto/node_modules/should-equal
                • should-util@1.0.0 node_modules/node-aead-crypto/node_modules/should-util
                • should-type-adaptors@1.1.0 node_modules/node-aead-crypto/node_modules/should-type-adaptors
                • should-format@3.0.3 node_modules/node-aead-crypto/node_modules/should-format
                • assert-plus@1.0.0 node_modules/node-aead-crypto/node_modules/sshpk/node_modules/assert-plus
                • stringstream@0.0.5 node_modules/node-aead-crypto/node_modules/stringstream
                • strip-ansi@3.0.1 node_modules/node-aead-crypto/node_modules/strip-ansi
                • string-width@1.0.2 node_modules/node-aead-crypto/node_modules/string-width
                • supports-color@3.1.2 node_modules/node-aead-crypto/node_modules/supports-color
                • tough-cookie@2.3.3 node_modules/node-aead-crypto/node_modules/tough-cookie
                • tunnel-agent@0.6.0 node_modules/node-aead-crypto/node_modules/tunnel-agent
                • tweetnacl@0.14.5 node_modules/node-aead-crypto/node_modules/tweetnacl
                • bcrypt-pbkdf@1.0.1 node_modules/node-aead-crypto/node_modules/bcrypt-pbkdf
                • sshpk@1.13.1 node_modules/node-aead-crypto/node_modules/sshpk
                • uid-number@0.0.6 node_modules/node-aead-crypto/node_modules/uid-number
                • util-deprecate@1.0.2 node_modules/node-aead-crypto/node_modules/util-deprecate
                • uuid@3.2.1 node_modules/node-aead-crypto/node_modules/uuid
                • assert-plus@1.0.0 node_modules/node-aead-crypto/node_modules/verror/node_modules/assert-plus
                • verror@1.10.0 node_modules/node-aead-crypto/node_modules/verror
                • jsprim@1.4.1 node_modules/node-aead-crypto/node_modules/jsprim
                • wrappy@1.0.2 node_modules/node-aead-crypto/node_modules/wrappy
                • once@1.4.0 node_modules/node-aead-crypto/node_modules/once
                • inflight@1.0.6 node_modules/node-aead-crypto/node_modules/inflight
                • glob@7.1.2 node_modules/node-aead-crypto/node_modules/glob
                • rimraf@2.6.2 node_modules/node-aead-crypto/node_modules/rimraf
                • glob@7.1.1 node_modules/node-aead-crypto/node_modules/mocha/node_modules/glob
                  ajv@4.11.8 node_modules/node-aead-crypto/node_modules/ajv -> node_modules/node-pre-gyp/node_modules/ajv
                  assert-plus@0.2.0 node_modules/node-aead-crypto/node_modules/assert-plus -> node_modules/node-pre-gyp/node_modules/assert-plus
                  aws-sign2@0.6.0 node_modules/node-aead-crypto/node_modules/aws-sign2 -> node_modules/node-pre-gyp/node_modules/aws-sign2
                  form-data@2.1.4 node_modules/node-aead-crypto/node_modules/form-data -> node_modules/node-pre-gyp/node_modules/form-data
                  har-schema@1.0.5 node_modules/node-aead-crypto/node_modules/har-schema -> node_modules/node-pre-gyp/node_modules/har-schema
                  har-validator@4.2.1 node_modules/node-aead-crypto/node_modules/har-validator -> node_modules/node-pre-gyp/node_modules/har-validator
                  hoek@2.16.3 node_modules/node-aead-crypto/node_modules/hoek -> node_modules/node-pre-gyp/node_modules/hoek
                  boom@2.10.1 node_modules/node-aead-crypto/node_modules/boom -> node_modules/node-pre-gyp/node_modules/boom
                  cryptiles@2.0.5 node_modules/node-aead-crypto/node_modules/cryptiles -> node_modules/node-pre-gyp/node_modules/cryptiles
                  http-signature@1.1.1 node_modules/node-aead-crypto/node_modules/http-signature -> node_modules/node-pre-gyp/node_modules/http-signature
                  performance-now@0.2.0 node_modules/node-aead-crypto/node_modules/performance-now -> node_modules/node-pre-gyp/node_modules/performance-now
                  qs@6.4.0 node_modules/node-aead-crypto/node_modules/qs -> node_modules/node-pre-gyp/node_modules/qs
                  sntp@1.0.9 node_modules/node-aead-crypto/node_modules/sntp -> node_modules/node-pre-gyp/node_modules/sntp
                  hawk@3.1.3 node_modules/node-aead-crypto/node_modules/hawk -> node_modules/node-pre-gyp/node_modules/hawk
                  request@2.81.0 node_modules/node-aead-crypto/node_modules/request -> node_modules/node-pre-gyp/node_modules/request
                  tar@2.2.1 node_modules/node-aead-crypto/node_modules/tar -> node_modules/node-pre-gyp/node_modules/tar
                  os-homedir@1.0.2 node_modules/node-aead-crypto/node_modules/os-homedir -> node_modules/os-homedir
                  os-tmpdir@1.0.2 node_modules/node-aead-crypto/node_modules/os-tmpdir -> node_modules/os-tmpdir
                  osenv@0.1.5 node_modules/node-aead-crypto/node_modules/osenv -> node_modules/osenv
                  nopt@4.0.1 node_modules/node-aead-crypto/node_modules/nopt -> node_modules/nopt
                  deep-extend@0.4.2 node_modules/node-aead-crypto/node_modules/deep-extend -> node_modules/rc/node_modules/deep-extend
                  minimist@1.2.0 node_modules/node-aead-crypto/node_modules/rc/node_modules/minimist -> node_modules/rc/node_modules/minimist
                  signal-exit@3.0.2 node_modules/node-aead-crypto/node_modules/signal-exit -> node_modules/signal-exit
                  strip-json-comments@2.0.1 node_modules/node-aead-crypto/node_modules/strip-json-comments -> node_modules/strip-json-comments
                  rc@1.2.5 node_modules/node-aead-crypto/node_modules/rc -> node_modules/rc
                  isarray@1.0.0 node_modules/node-aead-crypto/node_modules/isarray -> node_modules/tar-pack/node_modules/isarray
                  process-nextick-args@2.0.0 node_modules/node-aead-crypto/node_modules/process-nextick-args -> node_modules/tar-pack/node_modules/process-nextick-args
                  string_decoder@1.0.3 node_modules/node-aead-crypto/node_modules/string_decoder -> node_modules/tar-pack/node_modules/string_decoder
                  readable-stream@2.3.4 node_modules/node-aead-crypto/node_modules/readable-stream -> node_modules/tar-pack/node_modules/readable-stream
                  tar-pack@3.4.1 node_modules/node-aead-crypto/node_modules/tar-pack -> node_modules/tar-pack
                  wide-align@1.1.2 node_modules/node-aead-crypto/node_modules/wide-align -> node_modules/wide-align
                  gauge@2.7.4 node_modules/node-aead-crypto/node_modules/gauge -> node_modules/gauge
                  npmlog@4.1.2 node_modules/node-aead-crypto/node_modules/npmlog -> node_modules/npmlog
                • buffertools@2.1.6 node_modules/node-aead-crypto/node_modules/buffertools
                • mocha@3.5.3 node_modules/node-aead-crypto/node_modules/mocha
                • should@11.2.1 node_modules/node-aead-crypto/node_modules/should
                  node-pre-gyp@0.6.39 node_modules/node-aead-crypto/node_modules/node-pre-gyp -> node_modules/node-pre-gyp
                  iobroker.inst@1.0.8 /opt/iobroker
                  └── (empty)
                ! npm ERR! code 1
                EDIT:
                Der Adapter läuft nun einwand frei :o
                aber dann noch mal zu meiner Frage:
                Ist das ein Problem mit dem Raspberry Pi1 oder habe ich bei der installation am Anfang schon etwas falsch gemacht?
                P.s. Danke für den großartigen Support :D :)
                  AlCalzoneA Offline
                  AlCalzone
                  @fossil:
                  Ist das ein Problem mit dem Raspberry Pi1 oder habe ich bei der installation am Anfang schon etwas falsch gemacht? `
                  Das Paket in Frage rüstet benötigte Verschlüsselungsmethoden für die Kommunikation nach und muss je nach NodeJS-Version und Plattform kompiliert werden. Da das nicht unbedingt trivial ist, insbesondere auf Windows, setze ich ein Paket (node-pre-gyp) ein, das diese vorkompiliert. Bei der Installation muss dann nur noch die passende Version heruntergeladen werden.
                  Allerdings existiert für node-pre-gyp nur linux/darwin(osx)/windows/arm - hier wird keine Unterscheidung zwischen armv6 und armv7 getroffen. Die Compiler, die zum Vorkompilieren eingesetzt werden, kennen auch nur armv7. Daher wurde bisher einfach die armv7 Version auf Raspberry installiert, was auf Pi1 oder Pi Zero allerdings die falsche ist.
                  Die Lösung ist jetzt, dass das Paket bei der Installation erkennt, ob es auf einem armv6 installiert werden soll. In diesem Fall wird es auf dem Gerät kompiliert, ohne zu versuchen, die vorkompilierte Variante herunterzuladen.
                  • F Offline
                    fossil
                    Also nur noch mal für mein Verständnis:
                    Jeder der ein Pi 1 oder Zero mit armv6 besitzt und Iobroker installiert hat, muss nach dem er den Tradfri Adapter über den Iobroker.Admin installiert hat noch einemal über ssh in den Ordner:
                    cd /opt/iobroker/
                    und mit dem Befehl:
                    die richtige Verschlüsselungsmethode installieren?
                      AlCalzoneA Offline
                      AlCalzone
                      @fossil:
                      Jeder der ein Pi 1 oder Zero mit armv6 besitzt und Iobroker installiert hat, muss … die richtige Verschlüsselungsmethode installieren? `
                      Nein, du warst nur mein Testkaninchen. Der fix-3 branch ist mittlerweile in master gemerged, d.h. jede zukünftige Installation macht das automatisch. Es könnte lediglich notwendig sein, den Adapter auf Pi1/Zero manuell zu installieren statt über Admin-GUI:
                      cd /opt/iobroker
                      sudo npm install iobroker.tradfri --production --unsafe-perm
                      • F Offline
                        fossil
                        Okay dann probiere ich das gleich an meinem zweiten Pi1 den ich einmal neu aufsetzte aus und gebe Rückmeldung :D
                        • F Offline
                          fossil
                          So habe den anderen RPi nun fertig und es hat ohne Probleme über den iobroker.admin geklappt. :D
                          Dank dir AlCalzone für dem super Support.
