  4. Test Tesla-Motors v2.0.x
    6.3k
1.0k Beiträge 112 Kommentatoren 404.2k Aufrufe 101 Beobachtet
  • Marcus KlöstersM Marcus Klösters
    @tombox
    tesla-motors.0
    2026-04-16 17:48:32.745 debug updateDevices start (forceUpdate=true, location=false, devices=3)
    tesla-motors.0
    2026-04-16 17:48:27.745 error Command charge_stop failed for XX<VINREPLACED>XX: Request failed with status code 400
    tesla-motors.0
    2026-04-16 17:48:27.745 error signed_command HTTP 400: {"response":null,"error":"unsupported routable_message signature type","error_description":"","txid":"b90db6f5702ae02530e324871197d96a"}
    tesla-motors.0
    2026-04-16 17:48:27.685 debug [SignedCmd] URL: https://fleet-api.prd.eu.vn.cloud.tesla.com/api/1/vehicles/XX<VINREPLACED>XX/signed_command
    tesla-motors.0
    2026-04-16 17:48:27.685 debug [SignedCmd] routable_message: MgIIAzoSEhBqd6eUxWULswjytjTYQjYlUgYSBDICKgBqRQpDCkEE2sR8dbpwM0PXCdp5pXgEm3LO+ZuUEdOei1m3R4nbpnNbm+wLRb65wtYLJ/ZuwXQKrTrImR9z0ezqrSJlrmcZJpoDEK6Mj4hZ5aVn5L/qeX99/PmgAwA=
    tesla-motors.0
    2026-04-16 17:48:27.685 debug [SignedCmd] POST /signed_command for XX<VINREPLACED>XX, payload size=125B, base64 length=168
    tesla-motors.0
    2026-04-16 17:48:27.684 debug [TeslaSigning] Sending 125B to domain 3 for XX<VINREPLACED>XX
    tesla-motors.0
    2026-04-16 17:48:27.684 debug [TeslaSigning] CarServer action: chargingStartStopAction, counter=6, retried=false
    tesla-motors.0
    2026-04-16 17:48:27.684 info Sending signed command: charge_stop to XX<VINREPLACED>XX
    host.iobroker
    2026-04-16 17:47:20.973 info iobroker exit 0
    host.iobroker
    2026-04-16 17:47:19.924 info iobroker Updating objects from io-package.json for adapter "tesla-motors" with version "2.0.1"
    tombox
    #974
    @Marcus-Klösters sicher das du über GitHub installiert hast und adapter neugestartet hast.. v2.0.2-beta1
    • FrankSchorbF Offline
      FrankSchorb
      #975
      v2.0.2-beta1 läuft bei mir. per github installiert. nach wie vor zählen die tesla-api-zugriffe hoch. im log kommen einige meldungen wie zb: "XP7YGCEK...... vehicle_data received, keys: id, user_id, vehicle_id, vin, color, access_type, granular_access, tokens, state, in_service, id_s, calendar_enabled, api_version, backseat_token, backseat_token_updated_at, ble_autopair_enrolled, supercharger_payment_needed, supercharging_enabled".
      Aber: die Objekte werden nicht aktualisiert. zb zeigt tesla-motors.0.XP7YG..........charge_state.battery_level immer noch den stand von gestern. Fahrzeug ist "wach".
      • FrankSchorbF FrankSchorb
        tombox
        #976
        @FrankSchorb
        2.0.2-beta2 testen
        bräuchte kompletten debug log
        tombox2020@gmail.com
          FrankSchorb
          #977
          @tombox
          funktioniert nun. Nach Update auf 2.0.2-beta2 hat der Adapter neu gestartet, den Tesla aufgeweckt, ein force-update gezogen und nun sind auch die Objekte aktuell (zumindest die, die ich überblicken kann). Nach einiger Zeit geht der Tesla dann auch wieder in den Schlafmodus. Passt also. Ich schicke Dir noch eine pm wenn Du mich zum Testen brauchst.
          Danke und Grüße, Frank
          • Marcus KlöstersM Offline
            Marcus Klösters
            #978
            @tombox
            Super, vielen Dank!
            Mit v2.0.2 kann mein gutes, altes Überschussladen-Skript nun offenbar seine Befehle wieder erfolgreich absetzen.
            Keine HTTP 400 Fehlermeldungen mehr im Protokoll zu sehen.
              branka
              #979
              seit 20.4. habe ich das Problem mit dem Tesla Adapter (2.0.2), dass er meine Wallbox nicht mehr findet. Der Adapter startet und wird "Grün". Im Log erhalte ich untenstehende Fehlermeldung. Adapter neustart und Token rücksetzen hat nichts gebracht.., Kann mir jemand bitte helfen?
              tesla-motors.0
              2026-04-24 09:53:17.643 info Location interval is less than 10s. Skip location update
              tesla-motors.0
              2026-04-24 09:53:17.643 info Update interval set to 30s
              tesla-motors.0
              2026-04-24 09:53:17.641 info Device list received, 0 devices found. Starting first update (forceUpdate=true)
              tesla-motors.0
              2026-04-24 09:53:17.641 error {"error":"Account XXX must be registered in the current region https://fleet-api.prd.eu.vn.cloud.tesla.com, please see https://developer.tesla.com/docs/fleet-api/endpoints/partner-endpoints#register"}
              tesla-motors.0
              2026-04-24 09:53:17.640 error AxiosError: Request failed with status code 412
              tesla-motors.0
              2026-04-24 09:53:17.639 warn Partner registration failed for na: Request failed with status code 400
              tesla-motors.0
              2026-04-24 09:53:16.347 warn Partner registration failed for eu: Request failed with status code 400
              tesla-motors.0
              2026-04-24 09:53:15.477 info Partner account not registered. Registering automatically...
              tesla-motors.0
              2026-04-24 09:53:15.279 info Receive device list
              tesla-motors.0
              2026-04-24 09:53:15.278 info Region from JWT: eu
              tesla-motors.0
              2026-04-24 09:53:14.903 info Region from JWT: eu
              tesla-motors.0
              2026-04-24 09:53:13.785 info Refresh session
              tesla-motors.0
              2026-04-24 09:53:13.784 info Fleet session loaded
              tesla-motors.0
              2026-04-24 09:53:13.206 info starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.tesla-motors, node: v22.22.0, js-controller: 7.0.7
              • B branka
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tesla-motors.0
                tombox
                #980
                @branka teste die GitHub version die sollte mehr infos anzeigen
                • T tombox
                  branka
                  #981
                  @tombox sagte:
                  Danke Tombox. Das hat geholfen :-) nun konnte ich den Fehler sehen - hatte noch https:// vor xxx.fleetkey stehen
                  • mcBirneM Offline
                    mcBirneM Offline
                    mcBirne
                    #982
                    Hallo zusammen, ich wollte auch den neuen Tela Adapter 2.02 einrichten. Ich seitere am letzten Punkt. Wenn ich den QRCode Scanner erhalte ich diese Meldung.
                    Hat jemand eine Idee, woran das liegt?
                    d34df4c3D 1 Antwort Letzte Antwort
                      Kasi-m3
                      #983
                      Ich hatte den Error ebenfalls. Nach wiederholen von "AUTH-LINK GENERIEREN" und den "Page not found" - Link eintragen, speichern, wurde der Adapter grün. Danach klappte denn auch der Schritt mit dem QRCode. Dann hatte der Tesla einen zusätzlichen Schlüssel und ich konnte ihn steuern.
                      Viel Erfolg
                      • mcBirneM Offline
                        mcBirneM Offline
                        mcBirne
                        #984
                        Danke für den Tipp! Hat bei mir auch funktioniert. Habe den Auth link erneut erzeugt und eingefügt. Nun läuft es
                        • mcBirneM Offline
                          mcBirneM Offline
                          mcBirne
                          #985
                          Der Adapter ist grün und Stati werden korrekt synchronisiert. Aber ich kann z.B. die Türen nicht öffnen oder schließen. Klappt das bei euch?
                          C 1 Antwort Letzte Antwort
                            tbi
                            #986
                            laut Anleitung (https://github.com/iobroker-community-adapters/ioBroker.tesla-motors) muss man sich ja bei https://fleetkey.net/ seine Subdomain mit seinem Public Key erstellen.
                            Mein Problem ist, dass ich gar nicht soweit komme, da der Button "Create xyz.fleetkey.net" nicht klickbar ist.
                            Ich mutmaße(!) dass der auf der Landingpage vorher ersichtliche Punkt "Setup integration in Home Assistant" für den Schritt der Subdomain-Generierung erforderlich ist, oder?
                            Aber ich hab ja keine Home Assistant Integration, ich hab ja ioBroker ✌
                            Kann mich jemand aufklären, wie das geht? Lieben Dank
                              micklafisch
                              #987
                              Ich hab das gestern auch erst gemacht (iobroker und nicht HA). Hast du aus dem Adapter den Public Key auch auf die Webseite kopiert? Der Button wird danach scharf bei mir.
                                tbi
                                #988
                                Danke @micklafisch ! Die Lösung war die letzte Leerzeile beim Public Key zu löschen nachdem man diese eingefügt hat
                                • mcBirneM mcBirne
                                  d34df4c3D Offline
                                  d34df4c3D Offline
                                  d34df4c3
                                  #989
                                  @mcBirne
                                  Ensure you successfully did the "Step 3":
                                  • Copy/paste your AUTH LINK
                                  • Click SAVE AND CLOSE (important !)
                                  I initially skipped the "Save and close" and got the same error than you.
                                  Once I did step again, the Step 4 worked.
                                  • L Offline
                                    LaplaceII
                                    schrieb am zuletzt editiert von LaplaceII
                                    #990
                                    ich habe mir einen Public Key über die IOBroker Instanz des Tesla Adapters erzeugt und diesen auf der fleekey.net Seite kopiert. Die Anlage der Subdomain wurde bestätigt. Wenn ich diese Subdomain mit https://xxxxx.fleetkey.net aufrufe wird ein Host Error angezeigt. Egal wie oft ich den Vorgang durchführe, es kommt immer zu diesem Fehler. Ist das dennoch richtig bzw. was mache ich falsch?
                                    In der Anleitung steht, dass man ein Konto erstellen soll. Das kann man aber über den Link nicht tun, oder habe ich was übersehen? Auf der Seite kann ich doch nur die Subdomain erzeugen, oder?7dc7538a-d1f2-451d-b094-05bb2e5e0508-image.jpeg
                                      micklafisch
                                      schrieb am zuletzt editiert von micklafisch
                                      #991
                                      Den Public Key hier reinkopieren und dann den Button auslösen. Denke das ist im Bereich Übersetzungsfehler, ggf. wurde auch zwischenzeitlich die Webseite erneuert.
                                      Damit ist das Konto erstellt.
                                      • L Offline
                                        LaplaceII
                                        #992
                                        Das habe ich getan (scheinbar habe ich es oben nicht gut genug beschrieben). Die damit erzeugte Adresse ist nicht erreichbar (s. Bild oben -> Host Error). Des Weiteren bin ich anscheinend nicht der Einzige, der auch nicht in der Lage ist ein Konto zu erstellen (s. roter Kringel im Bild oben): https://forum.iobroker.net/topic/84504/tesla-adapter-bin-zu-doof-für-die-konfiguration
                                          Sandmanyz
                                          schrieb am zuletzt editiert von Sandmanyz
                                          #993
                                          @LaplaceII
                                          Die Meldung erscheint bei mri auch. Du sollst deine Individuelle URL auch nicht im Browser öffnen.
                                          Ich habe es mal in deinem genannten Beitrag versucht zu beschreiben.
                                          Frage:
                                          Über den neuen Adapter ist das ganze dann aber kostenpflichtig oder? Ich habe irgendwann mal was von einem Guthaben von monatlich 10 EUR geklesen aber finde dazu nichts.
