  4. Test Adapter shelly - ALPHA Versionen
    6.1k
mcm1957shelly
218 Beiträge 24 Kommentatoren 44.9k Aufrufe 28 Beobachtet
  • S Online
    S Online
    Schimi
    #194
    keine ahnung ob das wichtig ist:
    shelly.0
    2026-02-06 19:20:41.508	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.firmwareupdateProgress" has no existing object, this might lead to an error in future versions
    shelly.0
    2026-02-06 19:18:31.776	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.online" has no existing object, this might lead to an error in future versions
    shelly.0
    2026-02-06 19:18:30.795	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.protocol" has no existing object, this might lead to an error in future versions
    shelly.0
    2026-02-06 19:18:30.795	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.knowledgeBaseUrl" has no existing object, this might lead to an error in future versions
    shelly.0
    2026-02-06 19:18:30.794	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.type" has no existing object, this might lead to an error in future versions
    shelly.0
    2026-02-06 19:18:30.793	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.class" has no existing object, this might lead to an error in future versions
    shelly.0
    2026-02-06 19:18:30.793	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.id" has no existing object, this might lead to an error in future versions
    shelly.0
    2026-02-06 19:18:30.792	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.online" has no existing object, this might lead to an error in future versions
    shelly.0
    2026-02-06 19:18:30.750	warn	State "shelly.0.shellyplugsg3#d0cf13daf7f0#1.gen" has no existing object, this might lead to an error in future versions
    • mcm1957M Online
      mcm1957M Online
      mcm1957
      #195
      DANKE
      sollte natürlich nicht auftreten.
      Ich werd schaun warim das kommt.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M Online
        mcm1957M Online
        mcm1957
        #196
        Release 10.6.0 wurde ins LATEST Repository entlassen
        Aber keine Sorge. Die nächste alpha kommt bald. :-)
        • mcm1957M Online
          mcm1957M Online
          mcm1957
          #197
          Ich freu mich heute die neue 11.0.0-alpha.* Serie anzukündigen.
          Ein ganz grosses DANKE geht an @bluefox der mit viel Aufwand den Devicemanager Support implementiert hat. Es ist nunmehr möglich:
          • eine übersichtliche Devicemanager Ansicht (Kachelform) aufzurufen, und zwar vom Admin Interface oder vom Devicemanager Tab aus
          • nach neuen Shelly (G2+) zu scannen und diese per One-Click einzubinden. Für Shellies Gen 2+ ist KEINE EInrichtung am Shelly mehr notwendig, ioBroker kann das nun alles selbst erledigen
          • in der Kachelansicht die wichtigsten Funktionen / Werte zu sehen und auch zu ändern (ersetzt aber natürlich keine volle VIS)
          Weiters wurde die Limitierung dass die Device-Id nicht geändert werden darf teilweise aufgehoben. Der 'mac' Bereich der Device-Id kann nun im Zuge der Einrichtung weitestgehend frei umbenannt werden und erlaubt damit leichter erkennbare Ids.
          Durch die Umbauten und notwendige Anpassungen hat sich die EInbindung neuer Geräte nach hinten verschoben. Dies ist aber der nächste Task auf meiner Liste.
          ACHTUNG:
          Bitte insbesondere beim Test des Provisioning darn denken, dass ev. auf eurem Testsystem produktive Shellies gefunden werden die nicht mit dem testsystem verbunden sind. Ein unbedachtes Aktivierung der Einbindung routet diese Shellies ggF von eurem Produktivsystem auf das Testsystem um. Also bitte aufpassen - das Adapter kann nicht ahnen welche Shellies produktiv sind und welche zum Testen existzieren.
          Happy Testing
          • mcm1957M Online
            mcm1957M Online
            mcm1957
            #198
            Und es geht einen kleinen (1) Schritt weiter.
            ei Version 11.0.0-alpah.7 sollte nun den Shelly Presence Gen 4 erkennen. Allerdings sind seine Dateils noch nicht implementiert - er wird daher nur seeeeehr rudimentär in den Objekten erscheinen.
            Wer diesen besitzt bitte die Insatnz auf DEBUG setzen und loggen was der Presence so schickt. Im Log sollten solche Mledungen auftreten:
            [MQTT] Publish: 10.17.3.120 (shellypro3em63 / shellypro3em63-ac15186d3658 / shellypro3em63#ac15186d3658#1) - topic: shellypro3em63-ac15186d3658/status/em:0, qos: 1, payload: {"id":0,"a_current":0.882,"a_voltage":238.1,"a_act_power":181.6,"a_aprt_power":210.0,"a_pf":0.87,"a_freq":49.9,"b_current":1.395,"b_voltage":238.6,"b_act_power":-290.2,"b_aprt_power":332.8,"b_pf":0.87,"b_freq":49.9,"c_current":0.868,"c_voltage":239.9,"c_act_power":174.2,"c_aprt_power":208.3,"c_pf":0.84,"c_freq":49.9,"n_current":null,"total_current":3.145,"total_act_power":65.542,"total_aprt_power":751.002, "user_calibrated_phase":[],"errors": ["phase_sequence"]}
            (natürlich vom shellypresence, dieser log ist nur ein Beispiel).
            Bitte auch unbedingt schaun ob ALLE drei MQTT Hakerln gesetzt sind (https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/en/protocol-mqtt.md#generation-2-devices-plus-and-pro)
            Log bitte hier oder im Issue posten (https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/1228)
            Danke für eure Hilfe.
            • mcm1957M Online
              mcm1957M Online
              mcm1957
              #199
              Es gibt ein Update: 11.0.0-alpha.8
              Diese Release beinhaltet eine erste Implementierung für den Shelly Presence Gen 4. Weiters wurden fehlende States bei der Komponente Illuminance ergänzt.
              Feedback (sowohl OK Meldungen als auch Fehler) ist gerne gesehen / benötigt da ich keinen Presence besitze und daher der Code absolut ungetestet ist.
              DANKE an @MeisterQ frü die umfangreichen Logs auf Github.
              P.S. alpha.9 mit Shelly Cury plane ich für morgen ...
              • mcm1957M Online
                mcm1957M Online
                mcm1957
                #200
                Es gibt ein Update: 11.0.0-alpha.11
                Das Update beinhaltet einige Korrekturen für den Shelly Presence Gen 4. Leider leifert der Shelly bei drei Datenpunkten andere Attribute als ind er API Doku stehen. Ich habe den Adaüpter jetzt mal an die mitgloggten Daten angepasst. ich vermute dass die Dokumentation fehlerhaft ist - aber wir werden sehen...
                In jedem Fall hab ich mal ein Issue bei Shelly geöffnet. Datails siehe auch im Adapter Issue: https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/1228#issuecomment-4335324613
                • mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  #201
                  Und schon gehts weiter :-)
                  Da die Rückmeldung zum Shelly Presence nun keine gröberen Probleme mehr aufzeigt gibt es nun eine neue Version 11.0.0-alpha.12
                  Mit dieser Version sollte der Adapter den Cury by Shelly (https://www.shelly.com/de/products/cury-by-shelly) erkennen und ansprechen können.
                  Da ich dieses Gerät nicht besitze ist auch hier die Implemntierung blind nach Spi Spec erfolgt. Bitte um Rückmeldung was funktioniert oder nicht funktioniert. Bei Problemen bitte einen DEBUG Log anhängen. Das zugrhörige Issue im Adapterrepo ist hier: https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/1399
                  DANKE für eure Mithilfe
                  • mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #202
                    Update:
                    In Kürze steht 11.0.0-alpha.13 zur Verfügung.
                    Die Release unterstützt den neuen Shelly EM G4.
                    • mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #203
                      Ab 11.0.0-alpha.14 steht ist nun auch die HiluX DS8 konfiguriert.
                      Da ich kein cct Device beitze ist das Ganze eine weitere Implementierung nur nach API Doku. Feedback was geht und was nicht geht ist daher sehr gerne gesehen.
                      Hinweis:
                      Nightmode ist zur Zeit disabled da auch bei cct in der Firmware < 2.0.0 ein Totalschaden bei Verwendung des nightmodes via rpc droht.
                      • mcm1957M mcm1957
                        Hinweis:
                        TH16
                        #204
                        @mcm1957
                        Ich kann die HiluX-Alpha leider nicht weiter testen.
                        Nach Installation von iobroker.shelly@11.0.0-alpha.14 auf meinem produktiven ioBroker-System wurden alle bestehenden Shelly-Instanzen rot. Ein gezielter Test nur mit einer separaten Instanz ist nicht möglich, da die Adapter-Version hostweit gilt und nicht pro Instanz.
                        Nach Downgrade auf iobroker.shelly@10.6.1 liefen alle Instanzen sofort wieder grün und die Shelly-Geräte funktionierten wieder.
                        Damit ist die Alpha in meinem Setup aktuell nicht testbar, weil sie bereits die bestehenden Shelly-Instanzen blockiert.
                        • mcm1957M Online
                          mcm1957M Online
                          mcm1957
                          #205
                          Wär interessant warum die alpha auf deinem System so gar nicht funtkioniert.
                          Hast du noch ein log? Irgendwas müßte da ja drinnen stehen warum es nicht geht
                          Kann es sein, dass du
                          • noch nicht admin 7.8.23 installiert hast ?
                          • noch nicht auf node.js 22 ist ?
                          In jedem Fall solte die alpha allerdings nur auf einem testsystem installiert werden.
                          In jedem Fall mal DANKE dass du es versucht hast und hier bescheid gegeben hast-
                          Peter V.P 1 Antwort Letzte Antwort
                          • mcm1957M mcm1957
                            Peter V.P Offline
                            Peter V.P Offline
                            Peter V.
                            #206
                            @mcm1957
                            Kurze Info für dich,
                            Alpha 14 läuft bei mir ohne Probleme.
                            Hab momentan leider kein neues Gerät zum testen.
                            Danke für deine ganze Arbeit.
                            js-controller 7.1.1
                            Admin 7.8.24
                            Node.js 22.22.2
                            • mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #207
                              DANKE für mich ist auch die Info sehr wichtig dass bestehende Geräte witer funktionieren. Insbesondere die massisven Einbauten (von Buefox gemacht ! - DANKE) für den Devicemanager müssen ja auch getestet werden damit keine unerwünschten negativen Effekte da sind.
                              • Peter V.P Offline
                                Peter V.P Offline
                                Peter V.
                                schrieb am zuletzt editiert von Peter V.
                                #208
                                Sorry, war hier falsch....
                                • mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #209
                                  Ab 11.0.0-alpha.15 steht nun zur Verfügung.
                                  Der brandneue Shelly Dimmer 0/1-10V PM Gen4 (shelly0110dimG4) ist dort konfiguriert.
                                  • mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #210
                                    Release 11.0.0 wurde ins LATEST entlassen.
                                    • mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      #211
                                      Ich freu mich heute die neue 12.0.0-alpha.* Serie anzukündigen.
                                      Diese Major Release basiert auf einer komplett auf TypeScript migrierten Codebasis. Die Migration auf Typescript ermöglich nun eine vielfach bessere Typprüfung und hilft Programmierfehler schon zum Bauzeitpunkt rascher zu erkennen. Ein ganz grosses DANKE an @bluefox der diese Migration im Alleingang umgesetzt hat. (Für nicht Programmierer - die Umstellung erfasst lt. PR 180 Dateien).
                                      Funktional sollte alles wie bisher funktionieren. Auf Grund der Anzahl der geändrten Dateien liegt die Betonung auf 'sollte'. Natürlich läuft die codebasis der 12.0.0-alpha.0 Version schion seit einier Zeit bei Bluefox im produktiven Einsatz. Trotzdem kann es noch unentdeckte Fehler geben.
                                      Bitte daher - wer Zeit und Lust hat - die neue Version testen und Feedback geben. Für offensichtliche Fehler bitte gleich ein Issue anlegen. Aber auch Feedback im Sinne "alles läuft wie immer" sind gerne gesehen.
                                      Happy Testing
                                      mcm1957 und @bluefox
                                      • skvarelS Offline
                                        skvarelS Offline
                                        skvarel
                                        #212
                                        Ich habe zwar nur einen Shelly (PM Mini Gen3), wollte das Update aber trotzdem ausprobieren.
                                        Installation verlief fehlerfrei, die Instanz startet ordentlich und die Daten kommen sauber ein
                                        #TeamInventwo
                                        Unsere Adapter:
                                        • Peter V.P Offline
                                          Peter V.P Offline
                                          Peter V.
                                          #213
                                          Bekomme leider folgende Fehlermeldung:
                                          startInstance shelly.0: cannot find start file!
