  4. Tester gesucht: Zigbee 3.4.10
    2.4k
    4.4k
134 Beiträge 18 Kommentatoren 9.8k Aufrufe 16 Beobachtet
  • S Shadowhunter23
    @asgothian
    Nur als Info für dich, welche warn Meldungen bei mir kamen:
    zigbee.4
    2026-05-04 10:11:00.939	warn	pushing state generation for feature running_state for device 0x0cae5ffffeac0998 (TRVZB)
    zigbee.4
    2026-05-04 10:11:00.939	warn	pushing state generation for feature system_mode for device 0x0cae5ffffeac0998 (TRVZB)
    zigbee.4
    2026-05-04 10:11:00.939	warn	pushing state generation for feature local_temperature_calibration for device 0x0cae5ffffeac0998 (TRVZB)
    zigbee.4
    2026-05-04 10:11:00.939	warn	pushing state generation for feature local_temperature for device 0x0cae5ffffeac0998 (TRVZB)
    zigbee.4
    2026-05-04 10:11:00.939	warn	pushing state generation for feature occupied_heating_setpoint for device 0x0cae5ffffeac0998 (TRVZB)
    zigbee.3
    2026-05-04 10:10:56.759	warn	pushing state generation for feature running_state for device 0x08ddebfffea96811 (TRVZB)
    zigbee.3
    2026-05-04 10:10:56.758	warn	pushing state generation for feature system_mode for device 0x08ddebfffea96811 (TRVZB)
    zigbee.3
    2026-05-04 10:10:56.758	warn	pushing state generation for feature local_temperature_calibration for device 0x08ddebfffea96811 (TRVZB)
    zigbee.3
    2026-05-04 10:10:56.758	warn	pushing state generation for feature local_temperature for device 0x08ddebfffea96811 (TRVZB)
    zigbee.3
    2026-05-04 10:10:56.758	warn	pushing state generation for feature occupied_heating_setpoint for device 0x08ddebfffea96811 (TRVZB)
    zigbee.2
    2026-05-04 10:10:52.032	warn	pushing state generation for feature running_state for device 0x08ddebfffea9a426 (TRVZB)
    zigbee.2
    2026-05-04 10:10:52.032	warn	pushing state generation for feature system_mode for device 0x08ddebfffea9a426 (TRVZB)
    zigbee.2
    2026-05-04 10:10:52.031	warn	pushing state generation for feature local_temperature_calibration for device 0x08ddebfffea9a426 (TRVZB)
    zigbee.2
    2026-05-04 10:10:52.031	warn	pushing state generation for feature local_temperature for device 0x08ddebfffea9a426 (TRVZB)
    zigbee.2
    2026-05-04 10:10:52.031	warn	pushing state generation for feature occupied_heating_setpoint for device 0x08ddebfffea9a426 (TRVZB)
    zigbee.1
    2026-05-04 10:10:47.166	warn	pushing state generation for feature running_state for device 0x44e2f8fffe10cfc4 (TRVZB)
    zigbee.1
    2026-05-04 10:10:47.166	warn	pushing state generation for feature system_mode for device 0x44e2f8fffe10cfc4 (TRVZB)
    zigbee.1
    2026-05-04 10:10:47.166	warn	pushing state generation for feature local_temperature_calibration for device 0x44e2f8fffe10cfc4 (TRVZB)
    zigbee.1
    2026-05-04 10:10:47.166	warn	pushing state generation for feature local_temperature for device 0x44e2f8fffe10cfc4 (TRVZB)
    zigbee.1
    2026-05-04 10:10:47.166	warn	pushing state generation for feature occupied_heating_setpoint for device 0x44e2f8fffe10cfc4 (TRVZB)
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @Shadowhunter23 sagte:
    Danke für die Info. Besagte Meldungen werden mit der 4.3.2 verschwinden.
    A.
    • AsgothianA Asgothian
      A.
      arteckA Offline
      arteckA Offline
      arteck
      @Asgothian sagte:
      4.3.2 verschwinden
      öhme sicher nicht die Zigbee 3.4.2 ?
      • arteckA arteck
        @Asgothian sagte:
        4.3.2 verschwinden
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @arteck sagte:
        @Asgothian sagte:
        4.3.2 verschwinden
        Wer weiss 😁
        • Peter V.P Offline
          Peter V.P Offline
          Peter V.
          schrieb am zuletzt editiert von Peter V.
          läuft nach Update ohne Auffälligkeiten,
          einzig folgende Meldung kommt einmalig bei Start (3x hintereinander)
          zigbee.0 	2026-05-04 16:28:15.464	warn	Error while processing converters DEVICE_ID: 'a4c13839d5132278' cluster 'lightingColorCtrl' type 'attributeReport,readResponse' message: Cannot read properties of undefined (reading 'x')
          Ist folgendes Gerät:
          0xa4c13839d5132278 (addr 37906): TS0505B_1 - Tuya Zigbee RGB+CCT light (Router)
          • Peter V.P Peter V.
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @Peter-V. sagte:
            Kommt die Meldung auch wenn du die Farbe am Gerät anpasst ?
            Was Passiert wenn du 'device_debug' für das Gerät aktivierst (https://github.com/ioBroker/ioBroker.zigbee/wiki/Device-messaging-debug) ?
            A.
            Peter V.P 1 Antwort Letzte Antwort
            • AsgothianA Offline
              AsgothianA Offline
              Asgothian
              Hat irgendwer den Adapter unter Windows laufen ? Ich muss wissen ob das Auflisten der seriellen Schnittstellen unter Windows funktioniert.
              A.
              • PischleuderP Online
                PischleuderP Online
                Pischleuder
                @asgothian
                ich habe bei einer Leuchte: https://www.zigbee2mqtt.io/devices/50064.html folgende error Meldung:
                2026-05-04 18:30:09.475	error	Send command to 0x00158d00013b22d3 failed with no error code (failed to send ZCL request (248)
                2026-05-04 18:34:12.958	warn    error reading brightness from 0x00158d00013b22d3 : ZCL command 0x00158d00013b22d3/1 genLevelCtrl.read(["currentLevel"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (failed to send ZCL request (1) Error: Failed APS-DATA.request with confirm status: ApsNoAck (0xa7))
                Vielleicht weil diese noch aus ist ?
                  @Peter-V. sagte:
                  A.
                  Peter V.P Offline
                  Peter V.P Offline
                  Peter V.
                  @Asgothian
                  Ich glaube, ich habe diese Logmeldung selber provoziert.
                  Hatte wohl aus unachsamkeit beim schauen im Admin-Instanzsettings "use channel for complex exposes" aktiviert.
                  Seit dem entfernen des Häckchens ist die Meldung auch nicht mehr gekommen.
                  Falls du doch noch Debug_log brauchst, kann ich es gerne erstellen.
                    AsgothianA Offline
                    Asgothian
                    bitte ja. die nutzung der channels soll ab 3.5 verplichtend werden
                    A.
                    • PischleuderP Pischleuder
                      @asgothian
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      @Pischleuder sagte:
                      @asgothian
                      Was meinst du mit 'noch aus' ?
                      Generell wird mindestens die Warnmeldung in Zukunft unterdrückt, aber das schalten von Leuchten die keinen Strom haben ist immer ein Problem.
                      A.
                      PischleuderP 1 Antwort Letzte Antwort
                        A.
                        Peter V.P Offline
                        Peter V.P Offline
                        Peter V.
                        @Asgothian sagte:
                        bitte ja. ....
                        A.
                        Aber gerne doch, mach ich dir fertig.
                        Jetzt Log + debug anbei.zigbee.log - zigbee-debug.txt
                        AsgothianA 2 Antworten Letzte Antwort
                          @Pischleuder sagte:
                          @asgothian
                          A.
                          PischleuderP Online
                          PischleuderP Online
                          Pischleuder
                          schrieb am zuletzt editiert von Pischleuder
                          Ich meinte, wenn der Leuchtkörper ansich augeschaltet ist, Strom hat sie ja.
                            @Asgothian sagte:
                            bitte ja. ....
                            A.
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @Pischleuder sagte:
                            Da kann man (leider) nie sicher sein. Die Meldung deutet eigentlich darauf hin das besagte Leuchte eine schlechte Funkverbindung hat - deswegen die Frage ob sie Strom hat 😁
                            Wenn sie Strom hat dann passt etwas anderes nicht - ich würde empfehlen (wenn möglich)
                            • Leuchte vom Strom nehmen
                            • 60 s warten
                            • Zigbee Netz öffnen
                            • Leuchte an den Strom hängen
                            • Schauen ob es eine meldung Device 0x00158d00013b22d3 announced itself im Log gibt.
                            A.
                            Edit: Klarstellung und Vorschlag wie weiter zu machen.
                              @Asgothian sagte:
                              bitte ja. ....
                              A.
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              @Peter-V. sagte:
                              @Asgothian sagte:
                              bitte ja. ....
                              A.
                              Leider helfen die beiden nicht:
                              • Die Meldungen kommen nur beim Start - da war aber das 'device_debug' nicht drin
                              • Anstatt aus dem Debug-Interface via diesem Button: Screenshot 2026-05-04 at 21.18.01.png die Log einträge der relevanten Meldungen (von denen ohne SUCCESS) zu posten hast du auf der einen Seite den Text aus dem Interface kopiert (was den sehr unleserlich macht), und parallel das ganze Log mitgeschickt (bei dem ggf. verschiedene Meldungen ineinander laufen).
                              Kannst du bitte folgendes tun:
                              • device_debug für das Gerät wieder aktivieren
                              • besagte Option wieder aktivieren
                              • den Adapter neu starten
                              • dann ins Debug interface schauen (ggf. musst du auf refresh clicken), da sollten 3 Zeilen mit der Meldung EPROC auftauchen. Zu denen jeweils die über den oben verlinkten Button bereitgestellten Log-Ausschnitte posten.
                              Danke.
                              A.
                                @Peter-V. sagte:
                                @Asgothian sagte:
                                bitte ja. ....
                                A.
                                Danke.
                                A.
                                Peter V.P Offline
                                Peter V.P Offline
                                Peter V.
                                @Asgothian
                                Es ist verhext, jetzt keine Meldungen mehr zu finden....🤷
                                Im debug hat er nur einen Ping Fehler, welcher auch nur direkt nach dem Adapterneustart kam.
                                Aber das Teil läuft ansonsten.
                                OPI: Pinging '0xa4c13839d5132278' (TS0505B) via ZH Ping
                                PIFAIL: Failed to ping 0xa4c13839d5132278 (TS0505B) after 4797 ms - ZCL command 0xa4c13839d5132278/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false,"sendPolicy":"immediate"}) failed (Delivery failed for '37906'.)
                                  @Asgothian
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  @Peter-V. Das deutet darauf hin das das Gerät nicht sauber im Netz ist oder Firmware probleme hat. Du kannst versuchen die Einstellung
                                  auf den im Bild sichtbaren Wert umzustellen. ggf. ändert das etwas.
                                    AsgothianA Offline
                                    Asgothian
                                    Es scheint einen Bug im Adapter zu geben der auftritt wenn Hex-werte in den State color eingetragen werden. (https://github.com/ioBroker/ioBroker.zigbee/issues/2842). Bisher konnte ich das nicht verifizieren. Im Issue ist eine Test-Prozedur beschrieben - über weitere Tests damit würde ich mich freuen
                                    A.
                                      Peter V.P Offline
                                      Peter V.P Offline
                                      Peter V.
                                      @Asgothian
                                      Nach Umstellung "genBasic/zclVersion:
                                      OPI: Pinging '0xa4c13839d5132278' (TS0505B) via ZCL Read with genBasic:zclVersion
                                      PIFAIL: Failed to ping 0xa4c13839d5132278 (TS0505B) after 4866 ms - ZCL command 0xa4c13839d5132278/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for '37906'.)
                                      und, die "alte" Meldung ist wieder aufgetreten:
                                      I01: Zigbee Event of Type readResponse from device 0xa4c13839d5132278, incoming event: {"type":"readResponse","data":{"colorMode":2,"colorTemperature":0},"linkquality":168,"groupID":0,"cluster":"lightingColorCtrl","meta":{"rawData":{"type":"Buffer","data":[24,18,1,8,0,0,48,2,7,0,0,33,0,0]},"zclTransactionSequenceNumber":18,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                      I04: value generated '168' from device a4c13839d5132278 for 'Link quality'
                                      I02: 1 converter available for 'TS0505B_1' 'a4c13839d5132278' with cluster 'lightingColorCtrl' and type 'readResponse'
                                      I02.1a: converter 1 : Cluster lightingColorCtrl
                                      EPROC: Error while processing converters DEVICE_ID: 'a4c13839d5132278' cluster 'lightingColorCtrl' type 'attributeReport,readResponse' message: Cannot read properties of undefined (reading 'x')
                                      I02.1c: candidates: [{}] => payload {}
                                      I03: message received '{}' from device a4c13839d5132278 type 'TS0505B_1'
                                      I04-1: No value published for device a4c13839d5132278
                                      I01: Zigbee Event of Type readResponse from device 0xa4c13839d5132278, incoming event: {"type":"readResponse","data":{"colorMode":2,"colorTemperature":0},"linkquality":164,"groupID":0,"cluster":"lightingColorCtrl","meta":{"rawData":{"type":"Buffer","data":[24,19,1,8,0,0,48,2,7,0,0,33,0,0]},"zclTransactionSequenceNumber":19,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                      I04: value generated '164' from device a4c13839d5132278 for 'Link quality'
                                      I01: Zigbee Event of Type readResponse from device 0xa4c13839d5132278, incoming event: {"type":"readResponse","data":{"colorMode":2,"colorTemperature":0},"linkquality":100,"groupID":0,"cluster":"lightingColorCtrl","meta":{"rawData":{"type":"Buffer","data":[24,20,1,8,0,0,48,2,7,0,0,33,0,0]},"zclTransactionSequenceNumber":20,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                      I04: value generated '100' from device a4c13839d5132278 for 'Link quality'
                                      Es ist dieses Gerät: FCOB LM052 Zigbee3.0 LED Controller für Monochrome CCT RGB RGBW RGBCCT
                                        @Asgothian
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        @Peter-V. Interessant. Kannst du bitte mal ein device_query auslösen ? (dieser Button auf der Kachel oder über den Objektbaum) ? Die Frage ist ob die Meldung dann auch kommt.
                                        A.
                                          A.
                                          Peter V.P Offline
                                          Peter V.P Offline
                                          Peter V.
                                          @Asgothian Ja, kommt dann sogar 4x
