  3. Einsteigerfragen
  4. Installation
  5. Node js installationsprobleme
    6.8k
42 Beiträge 5 Kommentatoren 3.7k Aufrufe 5 Beobachtet
  • D dodi666
    @thomas-braun alles tiptop ;-) Danke Dir
    @dodi666
    Und wie sieht der Rest nun aus?
      dodi666
      schrieb am zuletzt editiert von dodi666
      Alles in Ordnung.
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: ioBroker
             Icon name: computer-vm
               Chassis: vm 🖴
          AF_VSOCK CID: 1
        Virtualization: kvm
                Kernel: Linux 6.12.74+deb13+1-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
         Firmware Date: Tue 2014-04-01
          Firmware Age: 12y 2w 4d
      OS is similar to:
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       15:07:19 up 14 min,  2 users,  load average: 0.17, 0.32, 0.31
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2026-04-19 15:07:19 CEST
                 Universal time: Sun 2026-04-19 13:07:19 UTC
                       RTC time: Sun 2026-04-19 13:07:19
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      sascha
      HOME=/home/sascha
      GROUPS=sascha sudo users iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/sascha
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:             10G        3.7G        6.1G        7.5M        1.0G        6.8G
      Swap:           4.3G          0B        4.3G
      Total:           14G        3.7G         10G
      Active iob-Instances:   43
               9951 M total memory
               3483 M used memory
               3118 M active memory
                649 M inactive memory
               5778 M free memory
                120 M buffer memory
                873 M swap cache
               4093 M total swap
                  0 M used swap
               4093 M free swap
      top - 15:07:19 up 14 min,  2 users,  load average: 0.17, 0.32, 0.31
      Tasks: 181 total,   3 running, 178 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  4.8 us,  2.4 sy,  0.0 ni, 92.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   9951.3 total,   5778.7 free,   3484.1 used,    994.4 buff/cache
      MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   6467.2 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  4.9G     0  4.9G   0% /dev
      tmpfs          tmpfs     996M  508K  995M   1% /run
      /dev/sda1      ext4       28G   15G   12G  54% /
      tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     4.9G  6.7M  4.9G   1% /tmp
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     996M   12K  996M   1% /run/user/1002
      [Sun Apr 19 14:52:55 2026] EXT4-fs (sda1): mounted filesystem 4ea8b218-a1e2-4ff7-934f-3e4f8b3810f1 ro with ordered data mode. Quota mode: none.
      [Sun Apr 19 14:52:56 2026] EXT4-fs (sda1): re-mounted 4ea8b218-a1e2-4ff7-934f-3e4f8b3810f1 r/w.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      1.7G    /var/
      773M    /var/log
      756M    /var/log/journal/d9618fe7fcdc4f2bb46496e1ef04e703
      710M    /var/cache
      Archived and active journals take up 72M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.9G    /opt/iobroker/iobroker-data/
      673M    /opt/iobroker/iobroker-data/history
      462M    /opt/iobroker/iobroker-data/files
      340M    /opt/iobroker/iobroker-data/sonosCache
      269M    /opt/iobroker/iobroker-data/backup-objects
      48M     /opt/iobroker/iobroker-data/objects.jsonl
      42M     /opt/iobroker/iobroker-data/states.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      17M     /opt/iobroker/iobroker-data/objects.json.migrated
      17M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      *** ZigBee Settings ***
      ⚠ HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'.
      Please check your setting:
      tcp
      ⚠ HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'.
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.22.2
      /usr/bin/node           v22.22.2
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.22.2-1nodesource1
        Candidate: 22.22.2-1nodesource1
        Version table:
       *** 22.22.2-1nodesource1 1001
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 859)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.22
      javascript:     9.0.18
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alarm.0                  : alarm                 : ioBroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        system.adapter.drops-weather.0          : drops-weather         : ioBroker                                 - disabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      + system.adapter.espresense.0             : espresense            : ioBroker                                 -  enabled
      + system.adapter.eusec.0                  : eusec                 : ioBroker                                 -  enabled
      + system.adapter.eventlist.0              : eventlist             : ioBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
        system.adapter.harmony.0                : harmony               : ioBroker                                 - disabled
      + system.adapter.hass.0                   : hass                  : ioBroker                                 -  enabled, port: 8123
      + system.adapter.heizoel.0                : heizoel               : ioBroker                                 -  enabled
      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
        system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 - disabled, port: 54321
      + system.adapter.mihome-vacuum.2          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
      + system.adapter.opendtu.0                : opendtu               : ioBroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.1               : pushover              : ioBroker                                 -  enabled
        system.adapter.pushover.2               : pushover              : ioBroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 - disabled
      + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.1.36
      + system.adapter.sony-bravia.0            : sony-bravia           : ioBroker                                 -  enabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.1.24:6638
      + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.1.25:6638
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url        │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
      │ 2       │ 'sources'          │ 'conf/sources-dist.json'        │ false        │
      │ 3       │ 'online'           │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Adapters
      Adapter    "admin"        : 7.7.22   , installed 7.7.22
      Adapter    "alarm"        : 3.7.6    , installed 3.7.6
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
      Adapter    "backitup"     : 3.3.14   , installed 3.3.14
      Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "drops-weather": 1.3.0    , installed 1.3.0
      Adapter    "echarts"      : 3.1.0    , installed 3.1.0
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "espresense"   : 0.6.3    , installed 0.6.3
      Adapter    "eusec"        : 2.0.3    , installed 2.0.3
      Adapter    "eventlist"    : 2.1.0    , installed 2.1.0
      Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
      Adapter    "harmony"      : 2.0.5    , installed 2.0.5
      Adapter    "hass"         : 1.4.0    , installed 1.4.0
      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
      Adapter    "history"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
      Adapter    "ical"         : 1.19.7   , installed 1.19.7
      Adapter    "javascript"   : 9.0.18   , installed 9.0.18
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "logparser"    : 2.4.0    , installed 2.4.0
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "shelly"       : 10.6.1   , installed 10.6.1
      Adapter    "shuttercontrol": 2.0.12  , installed 2.0.12
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
      Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2"        : 2.13.8   , installed 2.13.8
      Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
      Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
      Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
      Adapter    "web"          : 8.0.0    , installed 8.0.0
      Adapter    "ws"           : 4.0.0    , installed 4.0.0
      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
      Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
      Objects and States
      Objects:        19370
      States:         16564
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://security.debian.org/debian-security trixie-security InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending systemupdates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.1.36:1883       0.0.0.0:*               LISTEN      1001       8892       1539/io.sonoff.0
      tcp        0      0 192.168.1.36:2001       0.0.0.0:*               LISTEN      1001       8476       1179/io.hm-rpc.0
      tcp        0      0 192.168.1.36:2010       0.0.0.0:*               LISTEN      1001       8487       1198/io.hm-rpc.1
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7353       906/exim4
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8295       637/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6709       637/iobroker.js-con
      tcp        0      0 192.168.1.36:8701       0.0.0.0:*               LISTEN      1001       8040       1476/io.hm-rpc.2
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       9287       1416/io.shelly.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          3309       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7308       662/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:41003           0.0.0.0:*               LISTEN      1001       8023       1455/io.yahka.0
      tcp        0      0 127.0.0.1:38443         0.0.0.0:*               LISTEN      1001       9379       1455/io.yahka.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8336       923/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10820      1818/io.web.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7354       906/exim4
      tcp6       0      0 :::1884                 :::*                    LISTEN      1001       7647       991/io.javascript.0
      tcp6       0      0 :::1885                 :::*                    LISTEN      1001       9556       1678/io.espresense.
      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       10612      1726/go2rtc
      tcp6       0      0 :::111                  :::*                    LISTEN      0          352        1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          7310       662/sshd: /usr/sbin
      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       11382      1726/go2rtc
      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       10616      1726/go2rtc
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          3310       1/init
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10882      1780/io.upnp.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       9226       1354/io.mihome-vacu
      udp        0      0 0.0.0.0:53423           0.0.0.0:*                           1001       8951       1627/io.mihome-vacu
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10296      1455/io.yahka.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10295      1455/io.yahka.0
      udp        0      0 0.0.0.0:39975           0.0.0.0:*                           1001       10603      1695/io.eusec.0
      udp6       0      0 :::111                  :::*                                0          4233       1/init
      udp6       0      0 :::8555                 :::*                                1001       10617      1726/go2rtc
      2026-04-19 15:05:07.127  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2026-04-19 15:05:13.003  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/playlists
      2026-04-19 15:05:17.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/preset
      2026-04-19 15:05:28.256  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2026-04-19 15:05:49.437  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2026-04-19 15:06:00.003  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/favorites
      2026-04-19 15:06:10.557  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2026-04-19 15:06:13.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/playlists
      2026-04-19 15:06:17.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/preset
      2026-04-19 15:06:31.048  - warn: javascript.0 (991) getState "daswetter.0.NextHours.Location_1.Day_1.current.temp_value" not found (3)
      2026-04-19 15:06:31.049  - warn: javascript.0 (991)     at Object.<anonymous> (script.js.Eigene_Skripte.PRG_001_SYS.FensterUeberwachung_Meldung:200:229)
      2026-04-19 15:06:31.049  - warn: javascript.0 (991)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
      2026-04-19 15:06:31.049  - warn: javascript.0 (991)     at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
      2026-04-19 15:06:31.049  - warn: javascript.0 (991)     at JavaScript.emit (node:events:519:28)
      2026-04-19 15:06:31.049  - warn: javascript.0 (991)     at JavaScript.emit (node:domain:489:12)
      2026-04-19 15:06:31.050  - warn: javascript.0 (991)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11138:53)
      2026-04-19 15:06:31.050  - warn: javascript.0 (991)     at processImmediate (node:internal/timers:484:21)
      2026-04-19 15:06:31.690  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2026-04-19 15:06:52.863  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2026-04-19 15:07:00.012  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/favorites
      2026-04-19 15:07:09.697  - info: web.0 (1818) <== Disconnect system.user.admin from ::ffff:192.168.1.90 vis.0
      2026-04-19 15:07:09.698  - info: web.0 (1818) <== Disconnect system.user.admin from ::ffff:192.168.1.90
      2026-04-19 15:07:13.002  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/playlists
      2026-04-19 15:07:14.073  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
      2026-04-19 15:07:17.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/preset
      • D dodi666
        Alles in Ordnung.
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
            AF_VSOCK CID: 1
          Virtualization: kvm
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        sascha
        HOME=/home/sascha
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           4.3G          0B        4.3G
        Total:           14G        3.7G         10G
                 9951 M total memory
                 3483 M used memory
                 5778 M free memory
                  120 M buffer memory
                  873 M swap cache
                 4093 M total swap
                    0 M used swap
                 4093 M free swap
        *** FILESYSTEM ***
        /var:
        1.7G    /var/
        773M    /var/log
        710M    /var/cache
        USB-Devices by-id:
        ⚠ HINT:
        tcp
        ⚠ HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.22
        javascript:     9.0.18
        Adapter State
        + instance is alive
        Objects and States
        Objects:        19370
        States:         16564
        @dodi666 sagte:
        Setz den user 'sascha' in die Gruppe 'adm'
        Lösch die iob-Repos 'sources' und 'online'.
          dodi666
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
              AF_VSOCK CID: 1
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
           15:46:08 up 53 min,  2 users,  load average: 0.39, 0.38, 0.37
          CPU threads: 8
                         Local time: Sun 2026-04-19 15:46:08 CEST
                     Universal time: Sun 2026-04-19 13:46:08 UTC
                           RTC time: Sun 2026-04-19 13:46:08
                        NTP service: active
                    RTC in local TZ: no
          sascha
          HOME=/home/sascha
          GROUPS=sascha adm sudo users iobroker
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:             10G        4.2G        4.7G        7.5M        2.0G        6.3G
          Swap:           4.3G          0B        4.3G
          Total:           14G        4.2G        8.9G
          Active iob-Instances:   44
                   9951 M total memory
                   3958 M used memory
                   3555 M active memory
                   1472 M inactive memory
                   4436 M free memory
                    148 M buffer memory
                   1721 M swap cache
                   4093 M total swap
                      0 M used swap
                   4093 M free swap
          top - 15:46:09 up 53 min,  2 users,  load average: 0.39, 0.38, 0.37
          Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  7.0 us,  0.0 sy,  0.0 ni, 90.7 id,  0.0 wa,  0.0 hi,  2.3 si,  0.0 st
          MiB Mem :   9951.3 total,   4436.0 free,   3958.4 used,   1869.9 buff/cache
          MiB Swap:   4094.0 total,   4094.0 free,      0.0 used.   5992.9 avail Mem
          *** FILESYSTEM ***
          /dev/sda1      ext4       28G   15G   12G  57% /
          [Sun Apr 19 14:52:58 2026] EXT4-fs (sda1): mounted filesystem 4ea8b218-a1e2-4ff7-934f-3e4f8b3810f1 ro with ordered data mode. Quota mode: none.
          [Sun Apr 19 14:52:59 2026] EXT4-fs (sda1): re-mounted 4ea8b218-a1e2-4ff7-934f-3e4f8b3810f1 r/w.
          /var:
          1.7G    /var/
          773M    /var/log
          710M    /var/cache
          Archived and active journals take up 755M in the file system.
          132M    /opt/iobroker/iobroker-data/objects.jsonl
          20M     /opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          ⚠ HINT:
          tcp
          ⚠ HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.7
          /usr/bin/npx            10.9.7
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 3185)
          admin:          7.7.22
          javascript:     9.0.18
          Adapter State
          + system.adapter.parcel.0                 : parcel                : ioBroker                                 -  enabled
          + instance is alive
          │ 2       │ 'live-beta'        │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
          │ 3       │ 'live-stable'      │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
          Objects and States
          Objects:        20157
          States:         17086
          Hit:2 http://deb.debian.org/debian trixie-updates InRelease
          Hit:3 http://security.debian.org/debian-security trixie-security InRelease
          2026-04-19 15:42:17.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/preset
          2026-04-19 15:42:31.527  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:42:52.666  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:43:00.014  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/favorites
          2026-04-19 15:43:13.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/playlists
          2026-04-19 15:43:13.797  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:43:17.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/preset
          2026-04-19 15:43:34.943  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:43:56.078  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:44:00.002  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/favorites
          2026-04-19 15:44:13.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/playlists
          2026-04-19 15:44:17.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/preset
          2026-04-19 15:44:17.211  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:44:38.325  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:44:59.455  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:45:00.013  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/favorites
          2026-04-19 15:45:13.001  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/playlists
          2026-04-19 15:45:17.002  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/preset
          2026-04-19 15:45:20.555  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:45:41.659  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:46:00.003  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/favorites
          2026-04-19 15:46:02.755  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          2026-04-19 15:46:13.002  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/playlists
          2026-04-19 15:46:17.010  - info: javascript.0 (991) script.js.Eigene_Skripte.PRG_011_SONOS.Z_SonosAPI_Data: requestSonosAPI URL: http://192.168.1.37:5005/preset
          2026-04-19 15:46:23.877  - info: mihome-vacuum.0 (1354) State value to set for "mihome-vacuum.0.info.water_box" has to be type "text" but received type "boolean"
          Gute Hinweise, vielen Dank. Sollte jetzt okay sein, oder?
          • I Offline
            I Offline
            io2345
            schrieb am zuletzt editiert von io2345
            Habe mich an einem Update von 22.22.0 auf 22.22.2 versucht (einfach auf den Kreispfeil in der Übersicht geklickt). Es kommt aber:
            node.js v22.22.2 iobroker Node.js-Aktualisierung fehlgeschlagen: Command failed: sudo apt upgrade -y nodejs WARNING: apt does not have a stable CLI interface. Use with caution in scripts. E: Failed to fetch http://security.debian.org/pool/updates/main/o/openssl/libssl3_3.0.18-1~deb12u2_amd64.deb 404 Not Found [IP: 2a04:4e42::644 80]
            Was ist das Problem?
            • I io2345
              @io2345 sagte:
              Deine Paketquellen.
              sudo apt update
              sagt?
              Und bring das System auf Debian 13.
              • I Offline
                I Offline
                io2345
                Ah, ok. Vorher "sudo apt update && sudo apt full-upgrade" für alle, die ähnlich ahnungslos sind wie ich ;-)
                Muss man Debian 13 nehmen, oder geht 12 noch eine Zeit lang? Ich scheue das Risiko. Beim ersten Versuch vor ca. einem Jahr hat einiges anschließend nicht mehr funktioniert, hab dann 12 wieder in Betrieb genommen...
                • I io2345
                  @io2345 sagte:
                  Nein, am 10.Juni 2026 wird Debian 12 sein Lebensende erreichen.
                  Du musst also upgraden.
                  Und je länger du damit zögerst umso komplexer wird dann der ohnhein unvermeidliche Sprung auf eine aktuelle Version.
                  Also mach es jetzt, bevor die Releases noch weiter auseinander driften.
                  • I Offline
                    I Offline
                    io2345
                    Dann sag ich mal lieber nicht laut, dass mein Jdownloader noch auf Debian 11 läuft. Sind aber alles Proxmox-CTs. Proxmox selber ist bereits auf 13.
                    Na gut, wat mutt datt mutt. Werde mich nochmal versuchen. War glaub ich von der Grundidee her einfach, irgendwie ging der ioBroker zu sichern, dann OS updaten und IOB wieder einspielen, richtig?
                    • I io2345
                      @io2345 sagte:
                      Dann roll da halt aktuelle Container raus.
                      Wird mir doch immer erzählt, das wäre so einfach und schnell. Mach es halt.
                      Auch für den jdownloader.
                      • I Offline
                        I Offline
                        io2345
                        Ich bin ja nur ein ganz kleines Licht in dieser Hinsicht (drum schieb ich's auch immer so lang wie möglich vor mir her).
                        Muss erst mal suchen und viel lesen um herauszufinden, wie das Ganze funktioniert. Wenn es "einfach & schnell" geht: umso besser ;-)
                        • I io2345
                          @io2345 sagte:
                          Klassiker...
                          Das 'running süstäm' wird so lange 'näwah getatscht', bis es dann komplett versumpft ist.
                          • I Offline
                            I Offline
                            io2345
                            Ich kenne auch noch einen anderen Klassiker: "Ist ja nur ne Kleinigkeit, das mach ich jetzt schnell" - und sitz dann drei Tage am PC, weil der Mist doch nicht so funktioniert hat, wie gedacht. Dann lieber das running system am running lassen, und alle paar Jahre mal eine richtige Wartung+Runderneuerung. Aber das ist natürlich eine Frage der persönlichen Mentalität, Fähigkeiten, Leidensdruck und verfügbarer Freizeit
                            • I io2345
                              @io2345 sagte:
                              Aber auch der Rundumschlag muss rechtzeitig erfolgen. Und der Rundumschlag fällt überschaubarer aus, wenn man sein Zeug bis dahin laufend aktuell hält.
                              Das Debian-Release-Modell ist ja auch mit seinem Veröffentlichungstakt von 2 Jahren genau auf diese Strategie ausgerichtet.
                              • I Offline
                                I Offline
                                io2345
                                Na, hab's jetzt versucht, den ioBroker-Container auf Debian 13 zu heben. Gab aber ein paar Fehler:
                                ...Processing triggers for systemd (257.9-1~deb13u1) ...
                                Job for systemd-sysctl.service failed because the control process exited with error code.
                                See "systemctl status systemd-sysctl.service" and "journalctl -xeu systemd-sysctl.service" for details.
                                Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                                Warning: Failed to fetch https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-04-30T12:36:57Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
                                Warning: Some index files failed to download. They have been ignored, or old ones used instead.
                                Jetzt läuft das System zwar offenbar (kann z.B. die Admin-Oberfläche öffnen), die Instanzen sind gestartet. In Proxmox hat der Container aber keine funktionierende Konsole, man kann sich nicht einloggen. Ist also eine Einbahnstraße, da weitere Updates somit ja nicht möglich sind.
                                • I io2345
                                  @io2345 sagte:
                                  Macht man eh per SSH. Und da wirst du wohl eine Konsole haben.
                                  • I Offline
                                    I Offline
                                    io2345
                                    Lassen wir das hier, das Thema des Threads ist ja "node-js-installationsprobleme"
                                    • I io2345
                                      @io2345
                                      Das ist ja auch ein Thema von nodejs/nodesource. Du musst das Repo bzw. dessen Schlüssel aktuell halten. Ist das Thema mit dem 'so lange wie möglich vor mir herschieben'. Da haste jetzt halt wie nicht anders erwartet zu lange geschoben.
                                      iob nodejs-update 22
                                      würde das aber korrigieren.
                                      • I Offline
                                        I Offline
                                        io2345
                                        Gemacht, funktioniert!
                                        Habe den Container mittlerweile aus dem Backup wiederhergestellt und (weil ich wohl sturköpfig bin) nochmal das Inplace-Upgrade auf Debian 13 gestartet - vorher aber Nesting für den Container eingeschalten. Und was soll ich sagen: Jetzt ist es durchgelaufen und ich habe wieder meine Konsole. Danke an alle für die Hilfe!
