  3. Einsteigerfragen
  4. Installation
  5. Re-Installation von ioBroker Migration Bookworm -> Trixie
    6.8k
52 Beiträge 5 Kommentatoren 3.5k Aufrufe 5 Beobachtet
    Sneak-L8
    Danke, die Info, wie ich hier das Debug-Log aktiviere, hatte mir gefehlt:
    iobroker upgrade rpi2@3.0.2 --debug
    This upgrade of "rpi2" will at least introduce the following changes:
    -> 3.0.2:
    Check for required libgpiod-dev package version
    -> 3.0.1:
    Updated logo, workflows and documentation
    admin 7.6.17 and js-controller 6.0.11 (or later) are required
    -> 3.0.0:
    NodeJS 20.x (or newer) is required
    Updated opengpio to v2 (works on Debian trixie)
    -> 2.4.0:
    read the current state of GPIO outputs during adapter startup.
    re-read GPIO input, if set by the user (with ack=false).
    add an option to invert true/false mapping to 1/0.
    Allow multiple instances of this adapter per host.
    tried to improve initialization of GPIO inputs.
    -> 2.3.2:
    added support for NVMe temperature (needs additional configuration, see README)
    fixed inital values for outputs.
    -> 2.3.1:
    fixed: GPIO library failed to load after recent dependency update.
    -> 2.3.0:
    correct interpretation of start value setting. Output with initial value 0/1 will set GPIO accordingly during startup. Output without an initial state will not set GPIO at all.
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade rpi2 from @1.3.2 to @3.0.2 now? [(y)es, (n)o]: y
    Update rpi2 from @1.3.2 to @3.0.2
    NPM version: 10.9.7
    Installing iobroker.rpi2@3.0.2... (System call)
    > iobroker.rpi2@3.0.2 preinstall
    > bash ./preinstall-check.sh
    Checking package: libgpiod-dev >= 2.2
    libgpiod-dev version OK: 2.2.1-2+deb13u1
    > node-dht-sensor@0.4.5 install
    > node-gyp configure
    gyp info it worked if it ends with ok
    gyp info using node-gyp@8.4.1
    gyp info using node@22.22.2 | linux | arm64
    (node:58457) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    (Use `node --trace-deprecation ...` to show where the warning was created)
    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
    gyp info spawn /usr/bin/python3
    gyp info spawn args [
    gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
    gyp info spawn args   'binding.gyp',
    gyp info spawn args   '-f',
    gyp info spawn args   'make',
    gyp info spawn args   '-I',
    gyp info spawn args   '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',
    gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
    gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.22.2/include/node/common.gypi',
    gyp info spawn args   '-Dlibrary=shared_library',
    gyp info spawn args   '-Dvisibility=default',
    gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.22.2',
    gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
    gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.22.2/<(target_arch)/node.lib',
    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',
    gyp info spawn args   '-Dnode_engine=v8',
    gyp info spawn args   '--depth=.',
    gyp info spawn args   '--no-parallel',
    gyp info spawn args   '--generator-output',
    gyp info spawn args   'build',
    gyp info spawn args   '-Goutput_dir=.'
    gyp info spawn args ]
    Traceback (most recent call last):
     File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>
       import gyp  # noqa: E402
     File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>
       import gyp.input
     File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>
       from distutils.version import StrictVersion
    ModuleNotFoundError: No module named 'distutils'
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
    gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
    gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
    gyp ERR! System Linux 6.12.75+rpt-rpi-v8
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
    gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
    gyp ERR! node -v v22.22.2
    gyp ERR! node-gyp -v v8.4.1
    gyp ERR! not ok
    > opengpio@2.0.2 install
    > node-gyp rebuild
    (node:58475) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
    gyp info spawn args   '/opt/iobroker/node_modules/opengpio/build/config.gypi',
    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',
       import gyp.input
    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/opengpio
    gyp ERR! not ok
    npm error code 1
    npm error path /opt/iobroker/node_modules/opengpio
    npm error command failed
    npm error command sh -c node-gyp rebuild
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-debug-0.log
    Updating objects from io-package.json for adapter "rpi2" with version "1.3.2"
    upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
    upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
    upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
    • S Sneak-L8
      -> 3.0.2:
      -> 3.0.1:
      -> 3.0.0:
      -> 2.4.0:
      -> 2.3.2:
      -> 2.3.1:
      -> 2.3.0:
      NPM version: 10.9.7
      > node-gyp configure
         import gyp.input
      gyp ERR! not ok
      > node-gyp rebuild
         import gyp.input
      gyp ERR! not ok
      npm error code 1
      @Sneak-L8 sagte:
      Bitte auch zeigen!
      Ich denke nicht dass der Error
      @Sneak-L8 sagte:
      noqa: E402
      Der HTML 402 (payment required)sein sollte 😉
        Sneak-L8
        Gerne.
        cat /home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-debug-0.log
        0 verbose cli /usr/bin/node /usr/bin/npm
        1 info using npm@10.9.7
        2 info using node@v22.22.2
        3 silly config load:file:/usr/lib/node_modules/npm/npmrc
        4 silly config load:file:/opt/iobroker/.npmrc
        5 silly config load:file:/home/iobroker/.npmrc
        6 silly config load:file:/usr/etc/npmrc
        7 verbose title npm install iobroker.rpi2@3.0.2
        8 verbose argv "install" "--save-exact" "iobroker.rpi2@3.0.2" "--foreground-scripts"
        9 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-
        10 verbose logfile /home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-debug-0.log
        11 silly logfile start cleaning logs, removing 1 files
        12 silly packumentCache heap:2041053184 maxSize:510263296 maxEntrySize:255131648
        13 silly logfile done cleaning log files
        14 silly idealTree buildDeps
        15 silly fetch manifest iobroker.rpi2@3.0.2
        16 silly packumentCache full:https://registry.npmjs.org/iobroker.rpi2 cache-miss
        17 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
        18 http fetch GET 200 https://registry.npmjs.org/iobroker.rpi2 2238ms (cache revalidated)
        19 silly packumentCache full:https://registry.npmjs.org/iobroker.rpi2 set size:169789 disposed:false
        20 silly placeDep ROOT iobroker.rpi2@3.0.2 REPLACE for: iobroker.inst@3.0.0 want: 3.0.2
        21 silly fetch manifest ci@^2.3.0
        22 silly packumentCache full:https://registry.npmjs.org/ci cache-miss
        23 silly fetch manifest opengpio@^2.0.2
        24 silly packumentCache full:https://registry.npmjs.org/opengpio cache-miss
        25 http fetch GET 200 https://registry.npmjs.org/ci 570ms (cache revalidated)
        26 silly packumentCache full:https://registry.npmjs.org/ci set size:22895 disposed:false
        27 http fetch GET 200 https://registry.npmjs.org/opengpio 679ms (cache revalidated)
        28 silly packumentCache full:https://registry.npmjs.org/opengpio set size:46175 disposed:false
        29 silly placeDep ROOT ci@2.3.0 OK for: iobroker.rpi2@3.0.2 want: ^2.3.0
        30 silly placeDep ROOT opengpio@2.0.2 OK for: iobroker.rpi2@3.0.2 want: ^2.0.2
        31 silly reify mark retired [ '/opt/iobroker/node_modules/iobroker.rpi2' ]
        32 silly reify mark retired [ '/opt/iobroker/node_modules/sync-exec' ]
        33 silly reify moves {
        33 silly reify   '/opt/iobroker/node_modules/iobroker.rpi2': '/opt/iobroker/node_modules/.iobroker.rpi2-2YWXQatr',
        33 silly reify   '/opt/iobroker/node_modules/sync-exec': '/opt/iobroker/node_modules/.sync-exec-ypF59BB9'
        33 silly reify }
        34 verbose reify failed optional dependency /opt/iobroker/node_modules/fsevents
        35 silly reify mark deleted [ '/opt/iobroker/node_modules/fsevents' ]
        36 http cache opengpio@https://registry.npmjs.org/opengpio/-/opengpio-2.0.2.tgz 0ms (cache hit)
        37 http cache node-dht-sensor@https://registry.npmjs.org/node-dht-sensor/-/node-dht-sensor-0.4.5.tgz 0ms (cache hit)
        38 http cache iobroker.rpi2@https://registry.npmjs.org/iobroker.rpi2/-/iobroker.rpi2-3.0.2.tgz 0ms (cache hit)
        39 http cache ci@https://registry.npmjs.org/ci/-/ci-2.3.0.tgz 0ms (cache hit)
        40 http cache node-addon-api@https://registry.npmjs.org/node-addon-api/-/node-addon-api-1.7.2.tgz 0ms (cache hit)
        41 info run iobroker.rpi2@3.0.2 preinstall node_modules/iobroker.rpi2 bash ./preinstall-check.sh
        42 info run iobroker.rpi2@3.0.2 preinstall { code: 0, signal: null }
        43 info run node-dht-sensor@0.4.5 install node_modules/node-dht-sensor node-gyp configure
        44 info run node-dht-sensor@0.4.5 install { code: 1, signal: null }
        45 verbose reify failed optional dependency /opt/iobroker/node_modules/node-dht-sensor
        46 silly reify mark deleted [ '/opt/iobroker/node_modules/node-dht-sensor' ]
        47 verbose reify failed optional dependency /opt/iobroker/node_modules/node-dht-sensor/node_modules/node-addon-api
        48 silly reify mark deleted [
        48 silly reify   '/opt/iobroker/node_modules/node-dht-sensor/node_modules/node-addon-api'
        48 silly reify ]
        49 info run opengpio@2.0.2 install node_modules/opengpio node-gyp rebuild
        50 info run opengpio@2.0.2 install { code: 1, signal: null }
        51 verbose stack Error: command failed
        51 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:22:22)
        51 verbose stack     at spawnWithShell (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:124:10)
        51 verbose stack     at promiseSpawn (/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib/index.js:12:12)
        51 verbose stack     at runScriptPkg (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script-pkg.js:79:13)
        51 verbose stack     at runScript (/usr/lib/node_modules/npm/node_modules/@npmcli/run-script/lib/run-script.js:9:12)
        51 verbose stack     at /usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:329:17
        51 verbose stack     at run (/usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:67:22)
        51 verbose stack     at /usr/lib/node_modules/npm/node_modules/promise-call-limit/dist/commonjs/index.js:79:13
        51 verbose stack     at process.processTicksAndRejections (node:internal/process/task_queues:103:5)
        52 verbose pkgid opengpio@2.0.2
        53 error code 1
        54 error path /opt/iobroker/node_modules/opengpio
        55 error command failed
        56 error command sh -c node-gyp rebuild
        57 silly unfinished npm timer reify 1777445850399
        58 silly unfinished npm timer reify:build 1777445856727
        59 silly unfinished npm timer build 1777445856729
        60 silly unfinished npm timer build:deps 1777445856729
        61 silly unfinished npm timer build:run:install 1777445856791
        62 silly unfinished npm timer build:run:install:node_modules/opengpio 1777445857732
        63 verbose cwd /opt/iobroker
        64 verbose os Linux 6.12.75+rpt-rpi-v8
        65 verbose node v22.22.2
        66 verbose npm  v10.9.7
        67 verbose exit 1
        68 verbose code 1
        69 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-29T06_57_29_211Z-debug-0.log
        • S Sneak-L8
          Gerne.
          33 silly reify }
          48 silly reify ]
          53 error code 1
          67 verbose exit 1
          68 verbose code 1
          @Sneak-L8
          sudo apt update
          sudo apt install python3-setuptools
          iob nodejs-update 22
          Rückfragen von nodejs-update bejahen. Danach nochmal den rpi2-Adapter installieren.
            Sneak-L8
            Danke, jetzt hat es geklappt.
            ioBroker nodejs fixer 2026-01-31
            You requested to install latest version from nodejs v22 tree.
            Your current setup is:
            /usr/bin/nodejs         v22.22.2
            /usr/bin/node           v22.22.2
            /usr/bin/npm            10.9.7
            /usr/bin/npx            10.9.7
            We found these nodejs versions available for installation:
            nodejs:
             Installed: 22.22.2-1nodesource1
             Candidate: 22.22.2-1nodesource1
             Version table:
            *** 22.22.2-1nodesource1 1001
                   500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                22.22.1-1nodesource1 1001
                22.22.0-1nodesource1 1001
                22.21.0-1nodesource1 1001
                22.20.0-1nodesource1 1001
                22.19.0-1nodesource1 1001
                22.18.0-1nodesource1 1001
                22.17.1-1nodesource1 1001
                22.17.0-1nodesource1 1001
                22.16.0-1nodesource1 1001
                22.15.1-1nodesource1 1001
                22.15.0-1nodesource1 1001
                22.14.0-1nodesource1 1001
                22.13.1-1nodesource1 1001
                22.13.0-1nodesource1 1001
                22.12.0-1nodesource1 1001
                22.11.0-1nodesource1 1001
                22.10.0-1nodesource1 1001
                22.9.0-1nodesource1 1001
                22.8.0-1nodesource1 1001
                22.7.0-1nodesource1 1001
                22.6.0-1nodesource1 1001
                22.5.1-1nodesource1 1001
                22.5.0-1nodesource1 1001
                22.4.1-1nodesource1 1001
                22.4.0-1nodesource1 1001
                22.3.0-1nodesource1 1001
                22.2.0-1nodesource1 1001
                22.1.0-1nodesource1 1001
                22.0.0-1nodesource1 1001
                20.19.2+dfsg-1+deb13u2 500
                   500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                20.19.2+dfsg-1 500
                   500 http://deb.debian.org/debian trixie/main arm64 Packages
            Nothing to do - Your installation is using the correct paths.
            You are missing the nodesource.list or
            you want to change your current nodejs version: v22.22.2 ?
            Press <y> to continue or any other key to quit
            Trying to fix your installation now. Please be patient.
            You are running nodejs v22.22.2. Do you want to install latest version from nodejs v.22 tree?
            rm: cannot remove '': No such file or directory
            Stopping ioBroker now
            ioBroker has been stopped
            Removing dfsg-nodejs
            *** These repos are active on your system:
            Hit:1 http://deb.debian.org/debian trixie InRelease
            Hit:2 http://deb.debian.org/debian trixie-updates InRelease
            Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
            Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
            Reading package lists... Done
            *** Installing ca-certificates, curl and gnupg, just in case they are missing.
            *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
            Package: nodejs
            Pin: origin deb.nodesource.com
            Pin-Priority: 1001
            *** These repos are active after the adjustments:
            Get:5 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
            Get:6 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages [9768 B]
            Fetched 21.9 kB in 0s (79.7 kB/s)
            Installing nodejs now!
            Installing latest nodejs v22 release
            SUCCESS!
            v22.22.2 has been installed! You are using the latest nodejs@22 release now!
            COMPATIBILITY CHECK IN PROGRESS (Only a --dry-run! No modules are really changed or added!)
            add rpi-gpio-buttons 2.0.1
            add rpi-gpio 2.1.7
            add debug 3.2.7
            add node-dht-sensor 0.4.5
            add node-addon-api 1.7.2
            add fsevents 2.3.3
            add epoll 2.0.10
            add button-events 1.1.0
            add async-retry 1.3.3
            add retry 0.13.1
            added 10 packages in 6s
            294 packages are looking for funding
             run `npm fund` for details
            We tried our best to fix your nodejs. Please run iob diag again to verify.
            *** RESTARTING ioBroker NOW! ***
            Please refresh or restart your browser in a few moments.
            • S Sneak-L8
              /usr/bin/npm            10.9.7
              /usr/bin/npx            10.9.7
              nodejs:
               Version table:
                  20.19.2+dfsg-1 500
              Package: nodejs
              Pin-Priority: 1001
              SUCCESS!
              add rpi-gpio 2.1.7
              add debug 3.2.7
              add fsevents 2.3.3
              add epoll 2.0.10
              add retry 0.13.1
              @Sneak-L8
              Und die Installation von rpi2 sieht/sah wie aus?
              • S Sneak-L8
                /usr/bin/npm            10.9.7
                /usr/bin/npx            10.9.7
                nodejs:
                 Version table:
                    20.19.2+dfsg-1 500
                Package: nodejs
                Pin-Priority: 1001
                SUCCESS!
                add rpi-gpio 2.1.7
                add debug 3.2.7
                add fsevents 2.3.3
                add epoll 2.0.10
                add retry 0.13.1
                @Sneak-L8 sagte:
                Aah, soweit runter hatte ich nie gescrollt 🙈
                  Sneak-L8
                  Install hatte ich jetzt wieder in der GUI gemacht. Daher der Output aus dem Log.
                  2026-04-29 10:15:08.189 - info: host.RaspberryPi4B iobroker Update "system.adapter.rpi2.0"
                  2026-04-29 10:15:08.210 - info: host.RaspberryPi4B stopInstance system.adapter.rpi2.0 (force=false, process=true)
                  2026-04-29 10:15:08.215 - info: rpi2.0 (62170) Got terminate signal TERMINATE_YOURSELF
                  2026-04-29 10:15:08.218 - info: rpi2.0 (62170) terminating
                  2026-04-29 10:15:08.220 - info: rpi2.0 (62170) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2026-04-29 10:15:08.295 - info: host.RaspberryPi4B stopInstance system.adapter.rpi2.0 send kill signal
                  2026-04-29 10:15:08.354 - info: host.RaspberryPi4B iobroker upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  2026-04-29 10:15:08.370 - info: host.RaspberryPi4B iobroker upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  2026-04-29 10:15:08.380 - info: host.RaspberryPi4B iobroker upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  2026-04-29 10:15:08.388 - info: host.RaspberryPi4B iobroker upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  2026-04-29 10:15:08.403 - info: host.RaspberryPi4B iobroker upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  2026-04-29 10:15:08.411 - info: host.RaspberryPi4B iobroker upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  2026-04-29 10:15:08.419 - info: host.RaspberryPi4B iobroker upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  2026-04-29 10:15:08.426 - info: host.RaspberryPi4B iobroker upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  2026-04-29 10:15:08.448 - info: host.RaspberryPi4B iobroker upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  2026-04-29 10:15:08.458 - info: host.RaspberryPi4B iobroker upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  2026-04-29 10:15:08.466 - info: host.RaspberryPi4B iobroker upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  2026-04-29 10:15:08.474 - info: host.RaspberryPi4B iobroker upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
                  2026-04-29 10:15:08.480 - info: host.RaspberryPi4B iobroker upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
                  2026-04-29 10:15:08.488 - info: host.RaspberryPi4B iobroker upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                  2026-04-29 10:15:08.723 - info: rpi2.0 (62170) terminating
                  2026-04-29 10:15:08.825 - info: host.RaspberryPi4B instance system.adapter.rpi2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2026-04-29 10:15:09.526 - info: host.RaspberryPi4B iobroker exit 0
                  2026-04-29 10:15:12.643 - info: host.RaspberryPi4B instance system.adapter.rpi2.0 in version "3.0.2" started with pid 63055
                    @Sneak-L8 sagte:
                    @Homoran sagte:
                    Das wird immer angezeigt. Heißt nicht, dass die dfsg-Version auch installiert war.
                    In der neusten Version von nodejs-update ist der Text an der Stelle auch geändert.
                    Die Version ist aber noch nicht verfügbar.
                    • S Sneak-L8
                      @Sneak-L8 sagte:
                      Sowas macht man natürlich im Terminal, weil GUI stinkt. Und dich dumm hält.
