  4. npm error code EACCES
    6.3k
53 Beiträge 5 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • jvfleJ Offline
    jvfleJ Offline
    jvfle
    Geht leider nicht mehr.
    • jvfleJ Offline
      jvfleJ Offline
      jvfle
      schrieb am zuletzt editiert von jvfle
      Sorry, ich habe eben diesen Befehl ausprobiert (steht unten) und siehe da:
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.75+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model		: Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       17:05:26 up  1:47,  1 user,  load average: 0.05, 0.51, 0.66
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2026-04-25 17:05:27 CEST
                 Universal time: Sat 2026-04-25 15:05:27 UTC
                       RTC time: Sat 2026-04-25 15:05:27
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      jvfle
      HOME=/home/jvfle
      GROUPS=jvfle adm dialout cdrom sudo audio video plugdev games users netdev lpadmin gpio i2c spi render input iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/jvfle
      *** DISPLAY-SERVER SETUP ***
      Display-Server: 	true
      Display-Manager: 	* lightdm.service - Light Display Manager
      Desktop: 		rpd-labwc
      Session: 		wayland
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.5G        3.6G        2.9G        224M        2.3G        4.9G
      Swap:           2.1G          0B        2.1G
      Total:           10G        3.6G        5.1G
      Active iob-Instances: 	22
               8058 M total memory
               3408 M used memory
               3518 M active memory
               1013 M inactive memory
               2783 M free memory
                185 M buffer memory
               1982 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      top - 17:05:27 up  1:47,  1 user,  load average: 0.05, 0.51, 0.66
      Tasks: 270 total,   1 running, 269 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.3 us,  2.3 sy,  0.0 ni, 95.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8058.9 total,   2779.5 free,   3411.9 used,   2168.8 buff/cache
      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4647.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     1.6G   16M  1.6G   1% /run
      /dev/nvme0n1p2 ext4      469G   21G  430G   5% /
      tmpfs          tmpfs     4.0G   40M  3.9G   1% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      /dev/nvme0n1p1 vfat      510M   78M  433M  16% /boot/firmware
      tmpfs          tmpfs     4.0G   27M  4.0G   1% /tmp
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
      tmpfs          tmpfs     806M  304K  806M   1% /run/user/1000
      [Sat Apr 25 15:17:54 2026] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
      [Sat Apr 25 15:17:54 2026] EXT4-fs (nvme0n1p2): mounted filesystem d6944274-f2f7-4644-96a4-213c3b367f5c ro with ordered data mode. Quota mode: none.
      [Sat Apr 25 15:17:57 2026] EXT4-fs (nvme0n1p2): re-mounted d6944274-f2f7-4644-96a4-213c3b367f5c r/w.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/nvme0n1p2 ext4   rw,noatime
      `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      4.7G	/var/
      2.5G	/var/cache
      2.4G	/var/cache/apt
      2.3G	/var/cache/apt/archives
      265M	/var/lib
      Archived and active journals take up 8M in the file system.
      /opt/iobroker/backups:
      933M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      455M	/opt/iobroker/iobroker-data/
      360M	/opt/iobroker/iobroker-data/files
      78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      64M	/opt/iobroker/iobroker-data/backup-objects
      47M	/opt/iobroker/iobroker-data/files/admin.admin
      26M	/opt/iobroker/iobroker-data/objects.jsonl
      8.2M	/opt/iobroker/iobroker-data/files/modbus.admin/assets/index-6vd4TbNS.js
      8.2M	/opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
      6.6M	/opt/iobroker/iobroker-data/states.jsonl
      6.5M	/opt/iobroker/iobroker-data/files/vis.0/Dashboard/vis-views.json
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      No nvbackup.json found.
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v22.22.2
      /usr/bin/node 		v22.22.2
      /usr/bin/npm 		10.9.7
      /usr/bin/npx 		10.9.7
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.22.2-1nodesource1
        Candidate: 22.22.2-1nodesource1
        Version table:
       *** 22.22.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      npm error syscall mkdir
      npm error path /home/iobroker/.npm/_cacache/tmp
      npm error errno EACCES
      npm error
      npm error Your cache folder contains root-owned files, due to a bug in
      npm error previous versions of npm which has since been addressed.
      npm error
      npm error To permanently fix this problem, please run:
      npm error   sudo chown -R 1001:1001 "/home/iobroker/.npm"
      npm notice
      npm notice New major version of npm available! 10.9.7 -> 11.13.0
      npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.13.0
      npm notice To update run: npm install -g npm@11.13.0
      npm notice
      npm error Log files were not written due to an error writing to the directory: /home/iobroker/.npm/_logs
      npm error You can rerun the command with `--loglevel=verbose` to see the logs in your terminal
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 5972)
      Core adapters versions
      js-controller: 	7.0.7
      admin: 		7.7.22
      javascript: 	9.0.18
      nodejs modules from github: 	1
      +-- iobroker.slideshow@0.2.1 (git+ssh://git@github.com/gaudes/ioBroker.slideshow.git#8106f8a17407036e34f9ee63f4da866d0f03115b)
      Adapter State
        system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
        system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              - disabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : raspberrypi                              - disabled
      + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
      + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.slideshow.0              : slideshow             : raspberrypi                              -  enabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      + system.adapter.weather-warnings.0       : weather-warnings      : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
        system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.webcal.0                 : webcal                : raspberrypi                              -  enabled
        system.adapter.webcal.1                 : webcal                : raspberrypi                              -  enabled
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.22   , installed 7.7.22
      Adapter    "alarm"        : 3.7.6    , installed 3.7.6
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "backitup"     : 3.3.14   , installed 3.3.14
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "history"      : 4.0.0    , installed 3.0.1  [Updatable]
      Adapter    "ical"         : 1.20.0   , installed 1.19.7 [Updatable]
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 9.0.18   , installed 9.0.18
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "modbus"       : 8.0.3    , installed 8.0.3
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 6.0.7    , installed 5.2.1  [Updatable]
      Adapter    "openweathermap": 1.4.0   , installed 1.4.0
      Adapter    "parser"       : 3.0.0    , installed 3.0.0
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "shelly"       : 10.6.1   , installed 10.6.1
      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.17.0   , installed 3.16.0 [Updatable]
      Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
      Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.1 [Updatable]
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
      Adapter    "weather-warnings": 0.10.0, installed 0.10.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Objects and States
      Objects: 	7752
      States: 	6796
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:3 http://deb.debian.org/debian trixie-updates InRelease
      Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists... Done
      Pending systemupdates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8813       1018/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       24961      4377/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       24230      4377/iobroker.js-co
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       27267      5282/io.sonoff.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       25767      4594/node-red
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       26830      4912/io.mqtt.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4407       1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7766       1032/sshd: /usr/sbi
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24284      4403/io.admin.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8812       1018/cupsd
      tcp6       0      0 :::9090                 :::*                    LISTEN      0          3842       1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          3198       1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          7768       1032/sshd: /usr/sbi
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        8454       750/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       26512      5336/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       26513      5336/io.tuya.0
      udp        0      0 0.0.0.0:35863           0.0.0.0:*                           101        8456       750/avahi-daemon: r
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5815       1/init
      udp6       0      0 :::5353                 :::*                                101        8455       750/avahi-daemon: r
      udp6       0      0 :::44438                :::*                                101        8457       750/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          4408       1/init
      2026-04-25 17:00:00.014  - info: host.raspberrypi instance system.adapter.ical.0 in version "1.19.7" started with pid 7896
      2026-04-25 17:00:00.904  - info: ical.0 (7896) starting. Version 1.19.7 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
      2026-04-25 17:00:01.986  - info: ical.0 (7896) processing URL: Inbox https://jvfle@garemer.synology.me/caldav.php/jvfle/home_todo/
      2026-04-25 17:00:02.332  - info: ical.0 (7896) processing URL: My Calendar https://jvfle@garemer.synology.me/caldav.php/jvfle/home/
      2026-04-25 17:00:12.553  - info: ical.0 (7896) processing URL: Timetable https://jvfle@garemer.synology.me/caldav.php/jvfle/uqtya/
      2026-04-25 17:00:18.421  - info: ical.0 (7896) Terminated (NO_ERROR): Without reason
      2026-04-25 17:00:18.935  - info: host.raspberrypi instance system.adapter.ical.0 having pid 7896 terminated with code 0 (NO_ERROR)
      2026-04-25 17:00:50.006  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 7929
      2026-04-25 17:00:50.777  - info: dwd.0 (7929) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.2, js-controller: 7.0.7
      2026-04-25 17:00:51.284  - info: dwd.0 (7929) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2026-04-25 17:00:51.795  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 7929 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2026-04-25 17:01:00.733  - debug: admin.0 (4403) cmdExec on system.host.raspberrypi(202622500): add iot auto --host raspberrypi --debug
      2026-04-25 17:01:00.735  - info: host.raspberrypi iobroker add iot auto --host raspberrypi --debug
      2026-04-25 17:01:02.172  - info: host.raspberrypi iobroker NPM version: 10.9.7
      2026-04-25 17:01:02.173  - info: host.raspberrypi iobroker Installing iobroker.iot@5.0.12... (System call)
      2026-04-25 17:01:06.302  - info: host.raspberrypi iobroker npm error code EACCES
      2026-04-25 17:01:06.303  - info: host.raspberrypi iobroker npm error syscall mkdirnpm error path /home/iobroker/.npm/_cacache/tmpnpm error errno EACCESnpm errornpm error Your cache folder contains root-owned files, due to a bug innpm error previous versions of npm which has since been addressed.npm errornpm error To permanently fix this problem, please run:npm error   sudo chown -R 1001:1001 "/home/iobroker/.npm"
      2026-04-25 17:01:06.305  - info: host.raspberrypi iobroker npm error Log files were not written due to an error writing to the directory: /home/iobroker/.npm/_logsnpm error You can rerun the command with `--loglevel=verbose` to see the logs in your terminal
      2026-04-25 17:01:06.321  - error: host.raspberrypi iobroker npm error code EACCESnpm error syscall mkdirnpm error path /home/iobroker/.npm/_cacache/tmpnpm error errno EACCESnpm errornpm error Your cache folder contains root-owned files, due to a bug innpm error previous versions of npm which has since been addressed.npm errornpm error To permanently fix this problem, please run:npm error   sudo chown -R 1001:1001 "/home/iobroker/.npm"npm error Log files were not written due to an error writing to the directory: /home/iobroker/.npm/_logsnpm error You can rerun the command with `--loglevel=verbose` to see the logs in your terminal
      2026-04-25 17:01:06.322  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.iot@5.0.12: 1
      2026-04-25 17:01:07.339  - info: host.raspberrypi iobroker exit 25
      2026-04-25 17:05:50.014  - info: host.raspberrypi instance system.adapter.dwd.0 in version "2.8.5" started with pid 8497
      2026-04-25 17:05:50.947  - info: dwd.0 (8497) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.22.2, js-controller: 7.0.7
      2026-04-25 17:05:51.475  - info: dwd.0 (8497) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2026-04-25 17:05:51.983  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 8497 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      iob diag has finished.
      curl -sLf -o diag.sh https://.net/diag.sh && bash diag.sh
      hat funktioniert : iob diag nicht (falls die Info hilft).
      Thomas BraunT Ro75R 3 Antworten Letzte Antwort
      • jvfleJ jvfle
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        jvfle
        HOME=/home/jvfle
        iobroker
        HOME=/home/iobroker
        Desktop: 		rpd-labwc
        Session: 		wayland
        *** MEMORY ***
        Swap:           2.1G          0B        2.1G
                 8058 M total memory
                 3408 M used memory
                 2783 M free memory
                  185 M buffer memory
                 1982 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        *** FILESYSTEM ***
        /var:
        4.7G	/var/
        2.5G	/var/cache
        2.4G	/var/cache/apt
        265M	/var/lib
        USB-Devices by-id:
        /usr/bin/npm 		10.9.7
        /usr/bin/npx 		10.9.7
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        npm error
        npm error
        npm notice
        npm notice
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin: 		7.7.22
        javascript: 	9.0.18
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	7752
        States: 	6796
        @jvfle
        Probiert?
        Und dann ein
        iob stop
        iob fix
        iob start
        hinterher.
        jvfleJ 1 Antwort Letzte Antwort
        • jvfleJ jvfle
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                        NTP service: active
                    RTC in local TZ: no
          jvfle
          HOME=/home/jvfle
          iobroker
          HOME=/home/iobroker
          Desktop: 		rpd-labwc
          Session: 		wayland
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   8058 M total memory
                   3408 M used memory
                   2783 M free memory
                    185 M buffer memory
                   1982 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          4.7G	/var/
          2.5G	/var/cache
          2.4G	/var/cache/apt
          265M	/var/lib
          USB-Devices by-id:
          /usr/bin/npm 		10.9.7
          /usr/bin/npx 		10.9.7
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          npm error
          npm error
          npm notice
          npm notice
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin: 		7.7.22
          javascript: 	9.0.18
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	7752
          States: 	6796
          @jvfle
          Und schalt den Desktop-Klimmbimm aus.
            @jvfle
            Probiert?
            Und dann ein
            iob stop
            iob fix
            iob start
            hinterher.
            jvfleJ Offline
            jvfleJ Offline
            jvfle
            @Thomas-Braun Ja, habe ich natürlich.
            • jvfleJ jvfle
              @jvfle sagte:
              Mit welchen Rückmeldungen?
                @jvfle
                jvfleJ Offline
                jvfleJ Offline
                jvfle
                @Thomas-Braun Warum? Über den Touchscreen werden alle Sensoren, etc angezeigt, sowie ein Schaltpanel bedient. Was hat das mit der Fehlermeldung zu tun? Hat ja vorher auch wunderbar funktioniert. BG
                • jvfleJ jvfle
                  @jvfle sagte:
                  Warum
                  Weil man ohne Rückmeldungen nichts analysieren kann.
                  @jvfle sagte:
                  Ist Keine brauchbare "Rückmeldung"
                    @jvfle sagte:
                    jvfleJ Offline
                    jvfleJ Offline
                    jvfle
                    @Thomas-Braun Alle Fehlermeldungen habe ich oben gepostet. Ich habe dann versucht die Adapter zu aktualisieren, wurde jedesmal abgelehnt. Keine Berechtigung.
                      @jvfle sagte:
                      Warum
                      @jvfle sagte:
                      jvfleJ Offline
                      jvfleJ Offline
                      jvfle
                      @Homoran Das "warum" bezog sich auf den Bildschirm. Welche Meldungen werden noch benötigt? Stelle ich gerne hier ein.
                      • jvfleJ jvfle
                        @jvfle sagte:
                        Aber das war doch vor dem
                        @Thomas-Braun sagte:
                        @jvfle
                        Probiert?
                          @jvfle sagte:
                          @jvfle
                          Probiert?
                          jvfleJ Offline
                          jvfleJ Offline
                          jvfle
                          @Homoran ja, hat leider nichts gebracht
                          • jvfleJ jvfle
                            @jvfle sagte:
                            Ist auch keine Rückmeldung der Befehle
                            Bitte IMMER ALLES zeigen!
                              @jvfle sagte:
                              jvfleJ Offline
                              jvfleJ Offline
                              jvfle
                              @Homoran Ok, mache ich gleich noch einmal. Muss den Rechner hochfahren.
                              • jvfleJ jvfle
                                @jvfle
                                iob fix
                                VOLLSTÄNDIGE Ein- wie Ausgaben posten. Nix löschen, nix verändern, 1:1 ALLES hier reinkopieren.
                                Dann die Kiste komplett NEUSTARTEN.
                                Und dann noch mal ein
                                iob diag
                                • jvfleJ jvfle
                                  @jvfle bitte u bedingt mal lesen:
                                  Und befolgen 😉
                                  Dann müssen wir nicht dauernd raten und nachfragen
                                  • jvfleJ Offline
                                    jvfleJ Offline
                                    jvfle
                                    Das sind die Meldungen:
                                    jvfle@raspberrypi:~ $ sudo chown -R 1001:1001 "/home/iobroker/.npm"
                                    jvfle@raspberrypi:~ $ iob stop
                                    jvfle@raspberrypi:~ $ iob fix
                                    jvfle@raspberrypi:~ $ iob start
                                    mehr kam nicht.
                                    nichts
                                    • jvfleJ jvfle
                                      mehr kam nicht.
                                      nichts
                                      @jvfle sagte:
                                      Dem user 'jvfle' fehlen die Rechte das Verzeichnis /home/iobroker zu betreten.
                                      Oder der iob fix kann nicht vom Server geladen werden.
                                      Starte die Kiste mal komplett durch.
                                        @jvfle sagte:
                                        jvfleJ Offline
                                        jvfleJ Offline
                                        jvfle
                                        @jvfle sagte:
                                        Habe ich eben gemacht.
                                        jvfle@raspberrypi:~ $ iob diag
                                        das kam dabei raus, leider
                                        • jvfleJ jvfle
                                          @jvfle sagte:
                                          jvfleJ Offline
                                          jvfleJ Offline
                                          jvfle
                                          jvfle sagte:
                                          @jvfle sagte:
                                          also erst neu gestartet und dann iob diag, das kam dabei raus, leider
