  4. Deprecation Warning - util._extend
    2.0k
    2.5k
17 Beiträge 5 Kommentatoren 586 Aufrufe 4 Beobachtet
    tritor
    schrieb am zuletzt editiert von tritor
    in den logs von Adapter Updates wir mit immer wieder ein DepreciatonWarning angezeigt.
    Es geht dabei um 'util._extend API is depreciated.
    Hier ein Ausschnitt aus einem Log am Screen während eines Adapter Updates:
    2026-04-18 13:05:51.588  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker > cpu-features@0.0.10 install> node buildcheck.js > buildcheck.gypi && node-gyp rebuild
    2026-04-18 13:05:51.700  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker gyp info it worked if it ends with ok
    2026-04-18 13:05:51.701  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker gyp info using node-gyp@8.4.1
    2026-04-18 13:05:51.701  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker gyp info using node@22.22.1 | linux | x64
    2026-04-18 13:05:51.727  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker (node:621588) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use>
    2026-04-18 13:05:51.840  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn>
    2026-04-18 13:05:52.164  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker Traceback (most recent call last):  File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>    i>
    2026-04-18 13:05:52.444  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker added 3 packages, removed 7 packages, and changed 19 packages in 4s353 packages are looking for funding  run `npm fund` f>
    2026-04-18 13:05:53.560  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker Updating objects from io-package.json for adapter "backitup" with version "3.3.17"
    2026-04-18 13:05:53.597  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker Update "system.adapter.backitup.0"
    Hoffe einer der Experten kann mir hier einen Tipp geben, ob das com ioB-System herrührt oder, das eher adapterspezifisch ist.
    Gernot
    Host: i9 server Proxmox , Debian 13.4 for ioBroker
    ioBroker: 7.8.24, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.1.2
    Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
    Grafana 13.0.1 / InfluxDB 2.8.0
    Samson71S OliverIOO 2 Antworten Letzte Antwort
    • T tritor
      Samson71S Offline
      Samson71S Offline
      Samson71
      Global Moderator
      Sofern Du anständige Logs in Code-Tags </> postest und nicht kryptisch ausgeschnittene Bildchen einbaust - vielleicht.
      Auch die Überschrift bedarf wohl einer kleinen Korrektur.
      Markus
      Bitte beachten:
      • T tritor
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @tritor
        hier ein issue dazu, wobei die angewendete suchmethode nicht so ganz perfekt ist, da sie nur util._extend findet. sobald aber paket und funktion separiert notiert sind, funktioniert das nicht mehr
        https://github.com/ioBroker/ioBroker.js-controller/issues/3073
        ich würde im /opt/iobroker Verzeichnis mal nach
        grep -Rnl "_extend" node_modules/
        suchen.
        Meine Adapter und Widgets
        Links im Profil
        • Samson71S Samson71
          tritor
          @Samson71
          den Tipp-Fehler hab ich korrigiert, das Bild leider nicht, das war auf die Schnelle ein Screenshot, da konnte ich das log nicht kopieren, das Fenster schloss automatisch. Werde das das nächste mal berücksichtigen.
          Gernot
          • T tritor
            @Samson71
            @tritor sagte:
            Das log liegt z. B. unter
            iob logs
            Da kann man das auch wunderschön als reinen Text herauskopieren.
            Am Rande: System inkl. nodejs updaten auf Stand bringen.
            • OliverIOO OliverIO
              @tritor
              suchen.
              tritor
              @OliverIO
              Ja da gibt es jede Menge Auflistung.
              node_modules/prompt/node_modules/winston/lib/winston/container.js
              node_modules/iobroker.admin/adminWww/static/js/worker-html.js
              node_modules/iobroker.admin/adminWww/static/js/worker-javascript.js
              node_modules/iobroker.admin/adminWww/assets/ace-B1WbEy8J.js
              node_modules/iobroker.admin/adminWww/assets/Objects-CQ1Cgg6L.js
              node_modules/iobroker.admin/adminWww/assets/leaflet-src-B651YTWC.js
              node_modules/iobroker.admin/adminWww/assets/index-Cy4zkLZ7.js
              node_modules/iobroker.admin/adminWww/assets/bootstrap-D0re3WSJ.js
              node_modules/iobroker.admin/adminWww/assets/index-DA90dn-y.js
              node_modules/iobroker.admin/admin/custom/assets/index-JHWyZnE9.js
              node_modules/iobroker.admin/admin/custom/assets/index-BqaC8TTV.js
              node_modules/iobroker.admin/admin/custom/assets/index-lwTE6AOa.js
              node_modules/iobroker.admin/admin/custom/assets/index-fHKF7cIy.js
              node_modules/iobroker.admin/admin/custom/assets/AdminComponentEasyAccessSet__mf_v__runtimeInit__mf_v__-JbSPU0nV.js
              node_modules/iobroker.admin/admin/custom/assets/index-C2cQRe9d.js
              node_modules/iobroker.admin/admin/custom/assets/index-DI-4AL4q.js
              node_modules/iobroker.admin/admin/custom/assets/AdminComponentEasyAccessSet__mf_v__runtimeInit__mf_v__-CbzMf-XP.js
              node_modules/iobroker.admin/admin/custom/assets/index-Cgl0l3l6.js
              node_modules/iobroker.admin/admin/custom/assets/index-CcWdaO-A.js
              node_modules/iobroker.admin/admin/custom/assets/index-BTEHfIqN.js
              node_modules/iobroker.admin/admin/custom/assets/index-WGNhBVhU.js
              node_modules/iobroker.admin/admin/custom/assets/index-DsmGf2-7.js
              node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js
              node_modules/esprima/dist/esprima.js
              node_modules/rxjs/_esm5/internal/SubjectSubscription.js
              node_modules/rxjs/_esm5/internal/scheduler/AsyncAction.js
              node_modules/rxjs/_esm5/internal/scheduler/AsapAction.js
              node_modules/rxjs/_esm5/internal/scheduler/AsyncScheduler.js
              node_modules/rxjs/_esm5/internal/scheduler/AsapScheduler.js
              node_modules/rxjs/_esm5/internal/scheduler/QueueAction.js
              node_modules/rxjs/_esm5/internal/scheduler/QueueScheduler.js
              node_modules/rxjs/_esm5/internal/scheduler/AnimationFrameScheduler.js
              node_modules/rxjs/_esm5/internal/scheduler/VirtualTimeScheduler.js
              node_modules/rxjs/_esm5/internal/scheduler/AnimationFrameAction.js
              node_modules/rxjs/_esm5/internal/scheduler/Action.js
              node_modules/rxjs/_esm5/internal/observable/zip.js
              node_modules/rxjs/_esm5/internal/observable/race.js
              node_modules/rxjs/_esm5/internal/observable/SubscribeOnObservable.js
              node_modules/rxjs/_esm5/internal/observable/dom/WebSocketSubject.js
              node_modules/rxjs/_esm5/internal/observable/dom/AjaxObservable.js
              node_modules/rxjs/_esm5/internal/observable/ConnectableObservable.js
              node_modules/rxjs/_esm5/internal/observable/combineLatest.js
              node_modules/rxjs/_esm5/internal/operators/refCount.js
              node_modules/rxjs/_esm5/internal/operators/expand.js
              node_modules/rxjs/_esm5/internal/operators/skipUntil.js
              node_modules/rxjs/_esm5/internal/operators/debounce.js
              node_modules/rxjs/_esm5/internal/operators/single.js
              node_modules/rxjs/_esm5/internal/operators/pairwise.js
              node_modules/rxjs/_esm5/internal/operators/exhaust.js
              node_modules/rxjs/_esm5/internal/operators/take.js
              node_modules/rxjs/_esm5/internal/operators/repeat.js
              node_modules/rxjs/_esm5/internal/operators/sequenceEqual.js
              node_modules/rxjs/_esm5/internal/operators/skipLast.js
              node_modules/rxjs/_esm5/internal/operators/audit.js
              node_modules/rxjs/_esm5/internal/operators/map.js
              node_modules/rxjs/_esm5/internal/operators/every.js
              node_modules/rxjs/_esm5/internal/operators/throttleTime.js
              node_modules/rxjs/_esm5/internal/operators/takeWhile.js
              node_modules/rxjs/_esm5/internal/operators/ignoreElements.js
              node_modules/rxjs/_esm5/internal/operators/delay.js
              node_modules/rxjs/_esm5/internal/operators/takeLast.js
              node_modules/rxjs/_esm5/internal/operators/bufferWhen.js
              node_modules/rxjs/_esm5/internal/operators/skip.js
              node_modules/rxjs/_esm5/internal/operators/windowToggle.js
              node_modules/rxjs/_esm5/internal/operators/mergeScan.js
              node_modules/rxjs/_esm5/internal/operators/count.js
              node_modules/rxjs/_esm5/internal/operators/windowCount.js
              node_modules/rxjs/_esm5/internal/operators/buffer.js
              node_modules/rxjs/_esm5/internal/operators/throttle.js
              node_modules/rxjs/_esm5/internal/operators/sampleTime.js
              node_modules/rxjs/_esm5/internal/operators/skipWhile.js
              node_modules/rxjs/_esm5/internal/operators/takeUntil.js
              node_modules/rxjs/_esm5/internal/operators/isEmpty.js
              node_modules/rxjs/_esm5/internal/operators/bufferToggle.js
              node_modules/rxjs/_esm5/internal/operators/defaultIfEmpty.js
              node_modules/rxjs/_esm5/internal/operators/tap.js
              node_modules/rxjs/_esm5/internal/operators/distinct.js
              node_modules/rxjs/_esm5/internal/operators/groupBy.js
              node_modules/rxjs/_esm5/internal/operators/catchError.js
              node_modules/rxjs/_esm5/internal/operators/find.js
              node_modules/rxjs/_esm5/internal/operators/bufferCount.js
              node_modules/rxjs/_esm5/internal/operators/timeoutWith.js
              node_modules/rxjs/_esm5/internal/operators/throwIfEmpty.js
              node_modules/rxjs/_esm5/internal/operators/repeatWhen.js
              node_modules/rxjs/_esm5/internal/operators/withLatestFrom.js
              node_modules/rxjs/_esm5/internal/operators/filter.js
              node_modules/rxjs/_esm5/internal/operators/exhaustMap.js
              node_modules/rxjs/_esm5/internal/operators/delayWhen.js
              node_modules/rxjs/_esm5/internal/operators/dematerialize.js
              node_modules/rxjs/_esm5/internal/operators/retry.js
              node_modules/rxjs/_esm5/internal/operators/materialize.js
              node_modules/rxjs/_esm5/internal/operators/retryWhen.js
              node_modules/rxjs/_esm5/internal/operators/onErrorResumeNext.js
              node_modules/rxjs/_esm5/internal/operators/mapTo.js
              node_modules/rxjs/_esm5/internal/operators/bufferTime.js
              node_modules/rxjs/_esm5/internal/operators/sample.js
              node_modules/rxjs/_esm5/internal/operators/scan.js
              node_modules/rxjs/_esm5/internal/operators/mergeMap.js
              node_modules/rxjs/_esm5/internal/operators/switchMap.js
              node_modules/rxjs/_esm5/internal/operators/window.js
              node_modules/rxjs/_esm5/internal/operators/debounceTime.js
              node_modules/rxjs/_esm5/internal/operators/windowTime.js
              node_modules/rxjs/_esm5/internal/operators/windowWhen.js
              node_modules/rxjs/_esm5/internal/operators/finalize.js
              node_modules/rxjs/_esm5/internal/operators/distinctUntilChanged.js
              node_modules/rxjs/_esm5/internal/operators/observeOn.js
              node_modules/rxjs/_esm5/internal/BehaviorSubject.js
              node_modules/rxjs/_esm5/internal/OuterSubscriber.js
              node_modules/rxjs/_esm5/internal/Subscriber.js
              node_modules/rxjs/_esm5/internal/innerSubscribe.js
              node_modules/rxjs/_esm5/internal/AsyncSubject.js
              node_modules/rxjs/_esm5/internal/ReplaySubject.js
              node_modules/rxjs/_esm5/internal/testing/HotObservable.js
              node_modules/rxjs/_esm5/internal/testing/TestScheduler.js
              node_modules/rxjs/_esm5/internal/testing/ColdObservable.js
              node_modules/rxjs/_esm5/internal/InnerSubscriber.js
              node_modules/rxjs/_esm5/internal/Subject.js
              node_modules/rxjs/internal/SubjectSubscription.js
              node_modules/rxjs/internal/scheduler/AsyncAction.js
              node_modules/rxjs/internal/scheduler/AsapAction.js
              node_modules/rxjs/internal/scheduler/AsyncScheduler.js
              node_modules/rxjs/internal/scheduler/AsapScheduler.js
              node_modules/rxjs/internal/scheduler/QueueAction.js
              node_modules/rxjs/internal/scheduler/QueueScheduler.js
              node_modules/rxjs/internal/scheduler/AnimationFrameScheduler.js
              node_modules/rxjs/internal/scheduler/VirtualTimeScheduler.js
              node_modules/rxjs/internal/scheduler/AnimationFrameAction.js
              node_modules/rxjs/internal/scheduler/Action.js
              node_modules/rxjs/internal/observable/zip.js
              node_modules/rxjs/internal/observable/race.js
              node_modules/rxjs/internal/observable/SubscribeOnObservable.js
              node_modules/rxjs/internal/observable/dom/WebSocketSubject.js
              node_modules/rxjs/internal/observable/dom/AjaxObservable.js
              node_modules/rxjs/internal/observable/ConnectableObservable.js
              node_modules/rxjs/internal/observable/combineLatest.js
              node_modules/rxjs/internal/operators/refCount.js
              node_modules/rxjs/internal/operators/expand.js
              node_modules/rxjs/internal/operators/skipUntil.js
              node_modules/rxjs/internal/operators/debounce.js
              node_modules/rxjs/internal/operators/single.js
              node_modules/rxjs/internal/operators/pairwise.js
              node_modules/rxjs/internal/operators/exhaust.js
              node_modules/rxjs/internal/operators/take.js
              node_modules/rxjs/internal/operators/repeat.js
              node_modules/rxjs/internal/operators/sequenceEqual.js
              node_modules/rxjs/internal/operators/skipLast.js
              node_modules/rxjs/internal/operators/audit.js
              node_modules/rxjs/internal/operators/map.js
              node_modules/rxjs/internal/operators/every.js
              node_modules/rxjs/internal/operators/throttleTime.js
              node_modules/rxjs/internal/operators/takeWhile.js
              node_modules/rxjs/internal/operators/ignoreElements.js
              node_modules/rxjs/internal/operators/delay.js
              node_modules/rxjs/internal/operators/takeLast.js
              node_modules/rxjs/internal/operators/bufferWhen.js
              node_modules/rxjs/internal/operators/skip.js
              node_modules/rxjs/internal/operators/windowToggle.js
              node_modules/rxjs/internal/operators/mergeScan.js
              node_modules/rxjs/internal/operators/count.js
              node_modules/rxjs/internal/operators/windowCount.js
              node_modules/rxjs/internal/operators/buffer.js
              node_modules/rxjs/internal/operators/throttle.js
              node_modules/rxjs/internal/operators/sampleTime.js
              node_modules/rxjs/internal/operators/skipWhile.js
              node_modules/rxjs/internal/operators/takeUntil.js
              node_modules/rxjs/internal/operators/isEmpty.js
              node_modules/rxjs/internal/operators/bufferToggle.js
              node_modules/rxjs/internal/operators/defaultIfEmpty.js
              node_modules/rxjs/internal/operators/tap.js
              node_modules/rxjs/internal/operators/distinct.js
              node_modules/rxjs/internal/operators/groupBy.js
              node_modules/rxjs/internal/operators/catchError.js
              node_modules/rxjs/internal/operators/find.js
              node_modules/rxjs/internal/operators/bufferCount.js
              node_modules/rxjs/internal/operators/timeoutWith.js
              node_modules/rxjs/internal/operators/throwIfEmpty.js
              node_modules/rxjs/internal/operators/repeatWhen.js
              node_modules/rxjs/internal/operators/withLatestFrom.js
              node_modules/rxjs/internal/operators/filter.js
              node_modules/rxjs/internal/operators/exhaustMap.js
              node_modules/rxjs/internal/operators/delayWhen.js
              node_modules/rxjs/internal/operators/dematerialize.js
              node_modules/rxjs/internal/operators/retry.js
              node_modules/rxjs/internal/operators/materialize.js
              node_modules/rxjs/internal/operators/retryWhen.js
              node_modules/rxjs/internal/operators/onErrorResumeNext.js
              node_modules/rxjs/internal/operators/mapTo.js
              node_modules/rxjs/internal/operators/bufferTime.js
              node_modules/rxjs/internal/operators/sample.js
              node_modules/rxjs/internal/operators/scan.js
              node_modules/rxjs/internal/operators/mergeMap.js
              node_modules/rxjs/internal/operators/switchMap.js
              node_modules/rxjs/internal/operators/window.js
              node_modules/rxjs/internal/operators/debounceTime.js
              node_modules/rxjs/internal/operators/windowTime.js
              node_modules/rxjs/internal/operators/windowWhen.js
              node_modules/rxjs/internal/operators/finalize.js
              node_modules/rxjs/internal/operators/distinctUntilChanged.js
              node_modules/rxjs/internal/operators/observeOn.js
              node_modules/rxjs/internal/BehaviorSubject.js
              node_modules/rxjs/internal/OuterSubscriber.js
              node_modules/rxjs/internal/Subscriber.js
              node_modules/rxjs/internal/innerSubscribe.js
              node_modules/rxjs/internal/AsyncSubject.js
              node_modules/rxjs/internal/ReplaySubject.js
              node_modules/rxjs/internal/testing/HotObservable.js
              node_modules/rxjs/internal/testing/TestScheduler.js
              node_modules/rxjs/internal/testing/ColdObservable.js
              node_modules/rxjs/internal/InnerSubscriber.js
              node_modules/rxjs/internal/Subject.js
              node_modules/rxjs/bundles/rxjs.umd.js.map
              node_modules/rxjs/bundles/rxjs.umd.min.js.map
              node_modules/iobroker.scenes/admin/assets/index-B_g9fImg.js
              node_modules/broker-factory/node_modules/tslib/README.md
              node_modules/broker-factory/node_modules/tslib/modules/index.js
              node_modules/broker-factory/node_modules/tslib/modules/index.d.ts
              node_modules/broker-factory/node_modules/tslib/tslib.es6.js
              node_modules/broker-factory/node_modules/tslib/tslib.js
              node_modules/broker-factory/node_modules/tslib/tslib.d.ts
              node_modules/broker-factory/node_modules/tslib/tslib.es6.mjs
              node_modules/express/History.md
              node_modules/iobroker.devices/www/assets/index-C8dcoZB8.js
              node_modules/iobroker.devices/admin/assets/index-SJof8gXx.js
              node_modules/acorn-globals/node_modules/acorn/dist/acorn.js
              node_modules/acorn-globals/node_modules/acorn/dist/acorn_loose.js
              node_modules/acorn-globals/node_modules/acorn/src/statement.js
              node_modules/acorn-globals/node_modules/acorn/src/loose/statement.js
              node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
              node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
              node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
              node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
              node_modules/iobroker.fullcalendar/admin/static/js/main.c13d3761.js
              node_modules/iobroker.fullcalendar/admin/static/js/main.c13d3761.js.map
              node_modules/dot-prop/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/dropbox-v2-api/dist/api.json
              node_modules/dropbox-v2-api/src/api.json
              node_modules/boxen/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/web-streams-polyfill/dist/ponyfill.mjs.map
              node_modules/web-streams-polyfill/dist/ponyfill.js.map
              node_modules/web-streams-polyfill/dist/ponyfill.es6.mjs.map
              node_modules/web-streams-polyfill/dist/polyfill.min.js.map
              node_modules/web-streams-polyfill/dist/polyfill.js.map
              node_modules/web-streams-polyfill/dist/polyfill.mjs.map
              node_modules/web-streams-polyfill/dist/polyfill.es6.mjs.map
              node_modules/web-streams-polyfill/dist/ponyfill.es6.js.map
              node_modules/web-streams-polyfill/dist/polyfill.es6.min.js.map
              node_modules/web-streams-polyfill/dist/polyfill.es6.js.map
              node_modules/worker-timers-broker/node_modules/tslib/README.md
              node_modules/worker-timers-broker/node_modules/tslib/modules/index.js
              node_modules/worker-timers-broker/node_modules/tslib/modules/index.d.ts
              node_modules/worker-timers-broker/node_modules/tslib/tslib.es6.js
              node_modules/worker-timers-broker/node_modules/tslib/tslib.js
              node_modules/worker-timers-broker/node_modules/tslib/tslib.d.ts
              node_modules/worker-timers-broker/node_modules/tslib/tslib.es6.mjs
              node_modules/iobroker.vis/www/index.html
              node_modules/iobroker.vis/www/widgets/basic.html
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/src_Components_VacuumIcon_js-src_Components_WindowClosed_js-node_modules_react-circular-slide-54a955.34b175bb.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_leaflet_dist_leaflet_css-node_modules_leaflet_dist_images_marker-icon-2x-281382.49131c79.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.9a6346f3.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.ef43cd96.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react_jsx-runtime_js-node_modules_leaflet_dist_leaflet_css-node_modules_-5c5561.c33b1195.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.199f0b4e.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.3c144320.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.837c9082.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react_jsx-runtime_js-node_modules_leaflet_dist_leaflet_css-node_modules_-5c5561.c33b1195.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.3ebf8200.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b24a2b7b.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_legend_install_js.432b0c40.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react-circular-slider-svg_dist_index_js-node_modules_react_cjs_react-jsx-6278e5.433d1581.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/src_Generic_jsx-node_modules_react-circular-slider-svg_dist_index_js.f186cf20.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.ef43cd96.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.0cbfea69.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b80a2194.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.5884108b.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.08cf7e1a.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.5884108b.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.5d75fa27.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b80a2194.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_legend_install_js.a18746ef.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__mf_v__runtimeInit__mf_v__-mPD03Tof.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-bcz2UOY-.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/index-DBeNUnty.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/Map-DvvTKot1.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
              node_modules/iobroker.vis/www/widgets/materialdesign/lib.min.js
              node_modules/iobroker.vis/www/widgets/materialdesign/lib/vuetify.js
              node_modules/iobroker.vis/www/widgets/materialdesign/lib/material-components-web.js
              node_modules/iobroker.vis/www/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
              node_modules/iobroker.vis/www/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.ff34318e.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.f78ceb8d.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.b2dda7e4.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-battery-gauge_dist_react-battery-gauge_esm_js.438236c2.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-battery-gauge_dist_react-battery-gauge_esm_js.81e383f5.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-1RJxOR8B.js
              node_modules/iobroker.vis/www/widgets/openweathermap/assets/index-DnuTl29g.js
              node_modules/iobroker.vis/www/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_esm_index_js.49c59391.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_styled_js.25c617b0.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-8c1e82.52c5b0a7.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_isMuiElement_isMuiElement-90f327.68e2ebbd.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_index_js.6f996889.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.b58e6a51.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-8c1e82.52c5b0a7.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.a10fb2cd.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_index_js.6f996889.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js-n-287313.6a72939a.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.0fdc2efe.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.54021824.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.22192a38.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_styleFunctionSx_e-646437.480ef8e8.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_ZoomOutMap_js-node_modules_mui_material_Fab_Fab_js-no-238edc.c17f49ad.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_esm_index_js.4a02bfba.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_ZoomOutMap_js-node_modules_mui_material_Fab_Fab_js-no-de51fd.47eda6f0.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.7fc5de73.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_esm_isMuiElement_isMuiEle-37774c.5027f981.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.e83bdd95.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.7fc5de73.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.97b3e2d1.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.1749f755.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_esm_isMuiElement_isMuiEle-37774c.5027f981.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js-node_modules_mui_system_esm_u-30631c.5a5082ed.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.3ed26143.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Checkbox_Checkbox_js-node_modules_mui_material_FormControl_-ab667d.80eee493.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_createTheme_creat-8e35a0.19e0cbc7.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-09395c.bf487e67.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js-n-287313.6a72939a.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_material_styles_Them-0bf85c.de23cbfb.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.97b3e2d1.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_styled_js.dae67faa.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_x-date-pickers_TimePicker_TimePicker_js-node_modules_babel_runtime_h-8a0c27.799842e9.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_x-date-pickers_AdapterDayjs_Adapte-b79734.de09a47b.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-5ae56a.fbe8964c.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-66a30d.53923d06.chunk.js
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-66a30d.53923d06.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_createTheme_creat-c54a24.aedd89eb.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-f5912f.292616a4.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_x-date-pickers_AdapterDayjs_Adapte-c0e24c.44cc9956.chunk.js.map
              node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.48ced1a3.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b33a19f6.chunk.js.map
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/static/js/vendors-node_modules_mui_system_esm_index_js.2f5bd81f.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/static/js/vendors-node_modules_mui_material_index_js.108fbfef.chunk.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-CsZQ1K9c.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-BJeC_1Nc.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-4dZ_faDJ.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-CJ-kxqUy.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-B5RqNgEg.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-COK1nOKA.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BZKNvirX.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-DpCJnELL.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-Bp2scStG.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-Bk5B5ET5.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-B6mUFPf4.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-C-Jo2qj7.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-2uL955SU.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-CBbfFHA5.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-C5a4dcu-.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BlUXZP4n.js
              node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
              node_modules/iobroker.vis/www/edit.html
              node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js
              node_modules/iobroker.vis/www/lib/ace/worker-html.js
              node_modules/eventsource/example/eventsource-polyfill.js
              node_modules/@js-sdsl/ordered-map/dist/esm/index.js
              node_modules/@js-sdsl/ordered-map/dist/esm/index.js.map
              node_modules/@js-sdsl/ordered-map/dist/umd/ordered-map.js
              node_modules/@js-sdsl/ordered-map/dist/umd/ordered-map.min.js.map
              node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.js
              node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.min.js.map
              node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.js.map
              node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.msgpack.min.js.map
              node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.min.js.map
              node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.js.map
              node_modules/nise/nise.js
              node_modules/@iobroker/types/build/types.d.ts
              node_modules/@iobroker/dev-server/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/@iobroker/js-controller-adapter/build/esm/lib/adapter/adapter.d.ts
              node_modules/@iobroker/js-controller-adapter/build/esm/lib/adapter/adapter.js
              node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.d.ts
              node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js.map
              node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.d.ts
              node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js
              node_modules/@iobroker/db-objects-redis/build/cjs/lib/objects/objectsInRedisClient.d.ts
              node_modules/@iobroker/db-objects-redis/build/cjs/lib/objects/objectsInRedisClient.js.map
              node_modules/iobroker.zigbee2mqtt/node_modules/tslib/README.md
              node_modules/iobroker.zigbee2mqtt/node_modules/tslib/modules/index.js
              node_modules/iobroker.zigbee2mqtt/node_modules/tslib/modules/index.d.ts
              node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.es6.js
              node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.js
              node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.d.ts
              node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.es6.mjs
              node_modules/iobroker.reolink/node_modules/tslib/README.md
              node_modules/iobroker.reolink/node_modules/tslib/modules/index.js
              node_modules/iobroker.reolink/node_modules/tslib/modules/index.d.ts
              node_modules/iobroker.reolink/node_modules/tslib/tslib.es6.js
              node_modules/iobroker.reolink/node_modules/tslib/tslib.js
              node_modules/iobroker.reolink/node_modules/tslib/tslib.d.ts
              node_modules/iobroker.reolink/node_modules/tslib/tslib.es6.mjs
              node_modules/xml2js/lib/xml2js.bc.js
              node_modules/iobroker.wlanthermo-nano/admin/build/index.js
              node_modules/iobroker.wlanthermo-nano/admin/build/index.js.map
              node_modules/nedb/browser-version/out/nedb.min.js
              node_modules/nedb/browser-version/out/nedb.js
              node_modules/nedb/browser-version/test/localforage.js
              node_modules/iobroker.vis-2-widgets-energy/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
              node_modules/@babel/runtime/helpers/extends.js
              node_modules/@babel/runtime/helpers/esm/extends.js
              node_modules/eslint-plugin-node/lib/rules/no-deprecated-api.js
              node_modules/terminal-link/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/p-memoize/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/iobroker.backitup/node_modules/tslib/README.md
              node_modules/iobroker.backitup/node_modules/tslib/modules/index.js
              node_modules/iobroker.backitup/node_modules/tslib/modules/index.d.ts
              node_modules/iobroker.backitup/node_modules/tslib/tslib.es6.js
              node_modules/iobroker.backitup/node_modules/tslib/tslib.js
              node_modules/iobroker.backitup/node_modules/tslib/tslib.d.ts
              node_modules/iobroker.backitup/node_modules/tslib/tslib.es6.mjs
              node_modules/iobroker.backitup/admin/assets/index-BeQV_TGa.js
              node_modules/iobroker.backitup/admin/custom/assets/index-CHFaRedm.js
              node_modules/iobroker.backitup/admin/custom/assets/index-Ba6zELes.js
              node_modules/iobroker.backitup/admin/custom/assets/ConfigCustomBackItUpSet__loadShare___mf_0_mui_mf_1_material__loadShare__.js-DqH6EEuz.js
              node_modules/iobroker.discovery/node_modules/@serialport/bindings-cpp/prebuilds/android-arm64/node.napi.armv8.node
              node_modules/iobroker.discovery/node_modules/node-addon-api/napi-inl.h
              node_modules/sqlite3/node_modules/node-addon-api/napi-inl.h
              node_modules/sqlite3/build/Release/node_sqlite3.node
              node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.msgpack.min.js.map
              node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.min.js.map
              node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.js.map
              node_modules/node-rest-client/lib/node-rest-client.js
              node_modules/@img/sharp-linux-x64/lib/sharp-linux-x64.node
              node_modules/@img/sharp-linuxmusl-x64/lib/sharp-linuxmusl-x64.node
              node_modules/@img/sharp-libvips-linuxmusl-x64/lib/libvips-cpp.so.42
              node_modules/@img/sharp-libvips-linux-x64/lib/libvips-cpp.so.42
              node_modules/js-sdsl/dist/esm/container/TreeContainer/OrderedSet.js.map
              node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/index.js
              node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/index.js.map
              node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeIterator.js.map
              node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeNode.js
              node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeNode.js.map
              node_modules/js-sdsl/dist/esm/container/TreeContainer/OrderedMap.js.map
              node_modules/js-sdsl/dist/esm/container/OtherContainer/Queue.js
              node_modules/js-sdsl/dist/esm/container/OtherContainer/PriorityQueue.js.map
              node_modules/js-sdsl/dist/esm/container/OtherContainer/Queue.js.map
              node_modules/js-sdsl/dist/esm/container/OtherContainer/Stack.js.map
              node_modules/js-sdsl/dist/esm/container/ContainerBase/index.js
              node_modules/js-sdsl/dist/esm/container/ContainerBase/index.js.map
              node_modules/js-sdsl/dist/esm/container/HashContainer/Base/index.js
              node_modules/js-sdsl/dist/esm/container/HashContainer/Base/index.js.map
              node_modules/js-sdsl/dist/esm/container/HashContainer/HashSet.js
              node_modules/js-sdsl/dist/esm/container/HashContainer/HashMap.js.map
              node_modules/js-sdsl/dist/esm/container/HashContainer/HashSet.js.map
              node_modules/js-sdsl/dist/esm/container/SequentialContainer/Deque.js
              node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/RandomIterator.js.map
              node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/index.js
              node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/index.js.map
              node_modules/js-sdsl/dist/esm/container/SequentialContainer/Deque.js.map
              node_modules/js-sdsl/dist/esm/container/SequentialContainer/Vector.js
              node_modules/js-sdsl/dist/esm/container/SequentialContainer/LinkList.js.map
              node_modules/js-sdsl/dist/esm/container/SequentialContainer/Vector.js.map
              node_modules/js-sdsl/dist/umd/js-sdsl.js
              node_modules/js-sdsl/dist/umd/js-sdsl.min.js.map
              node_modules/iobroker.frigate/node_modules/tslib/README.md
              node_modules/iobroker.frigate/node_modules/tslib/modules/index.js
              node_modules/iobroker.frigate/node_modules/tslib/modules/index.d.ts
              node_modules/iobroker.frigate/node_modules/tslib/tslib.es6.js
              node_modules/iobroker.frigate/node_modules/tslib/tslib.js
              node_modules/iobroker.frigate/node_modules/tslib/tslib.d.ts
              node_modules/iobroker.frigate/node_modules/tslib/tslib.es6.mjs
              node_modules/jsdom/node_modules/acorn/dist/acorn.js
              node_modules/jsdom/node_modules/acorn/dist/acorn_loose.js
              node_modules/jsdom/node_modules/acorn/src/statement.js
              node_modules/jsdom/node_modules/acorn/src/loose/statement.js
              node_modules/@opentelemetry/instrumentation/build/esm/platform/browser/instrumentation.js
              node_modules/@opentelemetry/instrumentation/build/esm/platform/node/instrumentation.js
              node_modules/@opentelemetry/api/build/esm/metrics/NoopMeter.js
              node_modules/@opentelemetry/sdk-trace-base/build/esm/platform/browser/export/BatchSpanProcessor.js
              node_modules/@opentelemetry/sdk-trace-base/build/esm/platform/node/export/BatchSpanProcessor.js
              node_modules/@opentelemetry/core/build/esm/utils/timeout.js
              node_modules/mocha/mocha.js
              node_modules/ajv/README.md
              node_modules/fast-glob/README.md
              node_modules/globals/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/date-fns/package.json
              node_modules/jsx-ast-utils/lib/values/index.js
              node_modules/jsx-ast-utils/lib/values/expressions/index.js
              node_modules/jsx-ast-utils/lib/values/expressions/ObjectExpression.js
              node_modules/jsx-ast-utils/lib/getProp.js
              node_modules/bs-recipes/recipes/webpack.typescript.react/app/dist/bundle.js
              node_modules/browser-sync-client/dist/index.js
              node_modules/http-proxy/lib/http-proxy/index.js
              node_modules/http-proxy/lib/http-proxy/common.js
              node_modules/standard/node_modules/acorn/dist/acorn.mjs.map
              node_modules/standard/node_modules/acorn/dist/acorn.d.ts
              node_modules/standard/node_modules/acorn/dist/acorn.js.map
              node_modules/iobroker.vis-2/www/widgets.html
              node_modules/iobroker.vis-2/www/widgets/basic.html
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
              node_modules/iobroker.vis-2/www/widgets/materialdesign/lib.min.js
              node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/vuetify.js
              node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/material-components-web.js
              node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
              node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
              node_modules/iobroker.vis-2/www/widgets/openweathermap/assets/index-DnuTl29g.js
              node_modules/iobroker.vis-2/www/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
              node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
              node_modules/iobroker.vis-2/www/assets/createStyled-CtLRJdF1.js
              node_modules/iobroker.vis-2/www/assets/index-D_qqioAY.js.map
              node_modules/iobroker.vis-2/www/assets/index-BRd7FNtl.js
              node_modules/iobroker.vis-2/www/assets/index-CrLrNq4s.js
              node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-B8Z0SsW4.js.map
              node_modules/iobroker.vis-2/www/assets/Dialog-DElqR5zv.js.map
              node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Dt1au33l.js
              node_modules/iobroker.vis-2/www/assets/Dialog-Dgkz1L-r.js
              node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Dt1au33l.js.map
              node_modules/iobroker.vis-2/www/assets/createStyled-BvULSPVR.js.map
              node_modules/iobroker.vis-2/www/assets/index-BGo51MQZ.js
              node_modules/iobroker.vis-2/www/assets/index-DqJdyjgH.js.map
              node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-y8HJH6Vp.js
              node_modules/iobroker.vis-2/www/assets/Box-Bl3kq-x-.js.map
              node_modules/iobroker.vis-2/www/assets/index-BGhFZJYV.js.map
              node_modules/iobroker.vis-2/www/assets/assertThisInitialized-DtkDSj7h.js.map
              node_modules/iobroker.vis-2/www/assets/Dialog-Dgkz1L-r.js.map
              node_modules/iobroker.vis-2/www/assets/index-CrLrNq4s.js.map
              node_modules/iobroker.vis-2/www/assets/index-CzkXf0rM.js.map
              node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Zvkdie3d.js
              node_modules/iobroker.vis-2/www/assets/assertThisInitialized-DFQXnDE3.js.map
              node_modules/iobroker.vis-2/www/assets/index-BRd7FNtl.js.map
              node_modules/iobroker.vis-2/www/assets/index-BGo51MQZ.js.map
              node_modules/iobroker.vis-2/www/assets/index-BTDdCqea.js
              node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Zvkdie3d.js.map
              node_modules/iobroker.vis-2/www/assets/createStyled-CtLRJdF1.js.map
              node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-y8HJH6Vp.js.map
              node_modules/iobroker.vis-2/www/assets/visWidgetsCatalog-D4OT0wlf.js.map
              node_modules/iobroker.vis-2/www/assets/index-B2JJPlmn.js.map
              node_modules/iobroker.vis-2/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js
              node_modules/worker-timers/node_modules/tslib/README.md
              node_modules/worker-timers/node_modules/tslib/modules/index.js
              node_modules/worker-timers/node_modules/tslib/modules/index.d.ts
              node_modules/worker-timers/node_modules/tslib/tslib.es6.js
              node_modules/worker-timers/node_modules/tslib/tslib.js
              node_modules/worker-timers/node_modules/tslib/tslib.d.ts
              node_modules/worker-timers/node_modules/tslib/tslib.es6.mjs
              node_modules/acorn/dist/acorn.d.mts
              node_modules/iobroker.openweathermap/widgets/openweathermap/assets/index-DnuTl29g.js
              node_modules/iobroker.openweathermap/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
              node_modules/prettier/plugins/babel.mjs
              node_modules/prettier/plugins/flow.mjs
              node_modules/prettier/plugins/acorn.js
              node_modules/prettier/plugins/typescript.mjs
              node_modules/prettier/plugins/typescript.js
              node_modules/prettier/plugins/acorn.mjs
              node_modules/prettier/plugins/flow.js
              node_modules/prettier/plugins/babel.js
              node_modules/prettier/internal/experimental-cli.mjs
              node_modules/core-util-is/float.patch
              node_modules/new-github-release-url/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/iobroker.ping/admin/custom/assets/index-D8RJ5veu.js
              node_modules/iobroker.ping/admin/custom/assets/index-CbxD1KHt.js
              node_modules/typescript/lib/pl/diagnosticMessages.generated.json
              node_modules/typescript/lib/ja/diagnosticMessages.generated.json
              node_modules/typescript/lib/it/diagnosticMessages.generated.json
              node_modules/typescript/lib/ko/diagnosticMessages.generated.json
              node_modules/typescript/lib/ru/diagnosticMessages.generated.json
              node_modules/typescript/lib/zh-cn/diagnosticMessages.generated.json
              node_modules/typescript/lib/cs/diagnosticMessages.generated.json
              node_modules/typescript/lib/de/diagnosticMessages.generated.json
              node_modules/typescript/lib/fr/diagnosticMessages.generated.json
              node_modules/typescript/lib/_tsc.js
              node_modules/typescript/lib/typescript.js
              node_modules/typescript/lib/zh-tw/diagnosticMessages.generated.json
              node_modules/typescript/lib/tr/diagnosticMessages.generated.json
              node_modules/typescript/lib/es/diagnosticMessages.generated.json
              node_modules/typescript/lib/pt-br/diagnosticMessages.generated.json
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
              node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
              node_modules/canvas/build/Release/libpango-1.0.so.0
              node_modules/canvas/build/Release/canvas.node
              node_modules/canvas/build/Release/libharfbuzz.so.0
              node_modules/canvas/build/Release/libcairo.so.2
              node_modules/canvas/build/Release/libcairo-gobject.so.2
              node_modules/canvas/build/Release/librsvg-2.so.2
              node_modules/canvas/build/Release/libglib-2.0.so.0
              node_modules/canvas/build/Release/obj.target/canvas.node
              node_modules/canvas/build/Release/obj.target/canvas/src/CanvasRenderingContext2d.o
              node_modules/canvas/build/Release/libgio-2.0.so.0
              node_modules/canvas/src/CanvasRenderingContext2d.cc
              node_modules/canvas/src/CanvasRenderingContext2d.cc.orig
              node_modules/request/CHANGELOG.md
              node_modules/swagger-ui-dist/swagger-ui-standalone-preset.js
              node_modules/swagger-ui-dist/swagger-ui.js.map
              node_modules/swagger-ui-dist/swagger-ui-es-bundle-core.js
              node_modules/swagger-ui-dist/swagger-ui-bundle.js.map
              node_modules/swagger-ui-dist/swagger-ui-es-bundle.js
              node_modules/swagger-ui-dist/swagger-ui-es-bundle-core.js.map
              node_modules/swagger-ui-dist/swagger-ui-es-bundle.js.map
              node_modules/swagger-ui-dist/swagger-ui-standalone-preset.js.map
              node_modules/@azure/keyvault-keys/node_modules/tslib/README.md
              node_modules/@azure/keyvault-keys/node_modules/tslib/modules/index.js
              node_modules/@azure/keyvault-keys/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.es6.js
              node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.js
              node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.d.ts
              node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/core-tracing/node_modules/tslib/README.md
              node_modules/@azure/core-tracing/node_modules/tslib/modules/index.js
              node_modules/@azure/core-tracing/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/core-tracing/node_modules/tslib/tslib.es6.js
              node_modules/@azure/core-tracing/node_modules/tslib/tslib.js
              node_modules/@azure/core-tracing/node_modules/tslib/tslib.d.ts
              node_modules/@azure/core-tracing/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/abort-controller/node_modules/tslib/README.md
              node_modules/@azure/abort-controller/node_modules/tslib/modules/index.js
              node_modules/@azure/abort-controller/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/abort-controller/node_modules/tslib/tslib.es6.js
              node_modules/@azure/abort-controller/node_modules/tslib/tslib.js
              node_modules/@azure/abort-controller/node_modules/tslib/tslib.d.ts
              node_modules/@azure/abort-controller/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/core-auth/node_modules/tslib/README.md
              node_modules/@azure/core-auth/node_modules/tslib/modules/index.js
              node_modules/@azure/core-auth/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/core-auth/node_modules/tslib/tslib.es6.js
              node_modules/@azure/core-auth/node_modules/tslib/tslib.js
              node_modules/@azure/core-auth/node_modules/tslib/tslib.d.ts
              node_modules/@azure/core-auth/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/core-util/node_modules/tslib/README.md
              node_modules/@azure/core-util/node_modules/tslib/modules/index.js
              node_modules/@azure/core-util/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/core-util/node_modules/tslib/tslib.es6.js
              node_modules/@azure/core-util/node_modules/tslib/tslib.js
              node_modules/@azure/core-util/node_modules/tslib/tslib.d.ts
              node_modules/@azure/core-util/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/logger/node_modules/tslib/README.md
              node_modules/@azure/logger/node_modules/tslib/modules/index.js
              node_modules/@azure/logger/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/logger/node_modules/tslib/tslib.es6.js
              node_modules/@azure/logger/node_modules/tslib/tslib.js
              node_modules/@azure/logger/node_modules/tslib/tslib.d.ts
              node_modules/@azure/logger/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/identity/node_modules/tslib/README.md
              node_modules/@azure/identity/node_modules/tslib/modules/index.js
              node_modules/@azure/identity/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/identity/node_modules/tslib/tslib.es6.js
              node_modules/@azure/identity/node_modules/tslib/tslib.js
              node_modules/@azure/identity/node_modules/tslib/tslib.d.ts
              node_modules/@azure/identity/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/core-lro/node_modules/tslib/README.md
              node_modules/@azure/core-lro/node_modules/tslib/modules/index.js
              node_modules/@azure/core-lro/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/core-lro/node_modules/tslib/tslib.es6.js
              node_modules/@azure/core-lro/node_modules/tslib/tslib.js
              node_modules/@azure/core-lro/node_modules/tslib/tslib.d.ts
              node_modules/@azure/core-lro/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/core-client/node_modules/tslib/README.md
              node_modules/@azure/core-client/node_modules/tslib/modules/index.js
              node_modules/@azure/core-client/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/core-client/node_modules/tslib/tslib.es6.js
              node_modules/@azure/core-client/node_modules/tslib/tslib.js
              node_modules/@azure/core-client/node_modules/tslib/tslib.d.ts
              node_modules/@azure/core-client/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/core-http-compat/node_modules/tslib/README.md
              node_modules/@azure/core-http-compat/node_modules/tslib/modules/index.js
              node_modules/@azure/core-http-compat/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/core-http-compat/node_modules/tslib/tslib.es6.js
              node_modules/@azure/core-http-compat/node_modules/tslib/tslib.js
              node_modules/@azure/core-http-compat/node_modules/tslib/tslib.d.ts
              node_modules/@azure/core-http-compat/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/core-rest-pipeline/node_modules/tslib/README.md
              node_modules/@azure/core-rest-pipeline/node_modules/tslib/modules/index.js
              node_modules/@azure/core-rest-pipeline/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.es6.js
              node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.js
              node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.d.ts
              node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.es6.mjs
              node_modules/@azure/core-paging/node_modules/tslib/README.md
              node_modules/@azure/core-paging/node_modules/tslib/modules/index.js
              node_modules/@azure/core-paging/node_modules/tslib/modules/index.d.ts
              node_modules/@azure/core-paging/node_modules/tslib/tslib.es6.js
              node_modules/@azure/core-paging/node_modules/tslib/tslib.js
              node_modules/@azure/core-paging/node_modules/tslib/tslib.d.ts
              node_modules/@azure/core-paging/node_modules/tslib/tslib.es6.mjs
              node_modules/external-editor/main/errors/CreateFileError.js
              node_modules/external-editor/main/errors/LaunchEditorError.js
              node_modules/external-editor/main/errors/ReadFileError.js
              node_modules/external-editor/main/errors/RemoveFileError.js
              node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
              node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
              node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
              node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
              node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
              node_modules/xmldom/dom.js
              node_modules/@serialport/bindings-cpp/prebuilds/android-arm64/@serialport+bindings-cpp.armv8.node
              node_modules/read-package-up/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/@homebridge/hap-nodejs/node_modules/tslib/README.md
              node_modules/@homebridge/hap-nodejs/node_modules/tslib/modules/index.js
              node_modules/@homebridge/hap-nodejs/node_modules/tslib/modules/index.d.ts
              node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.es6.js
              node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.js
              node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.d.ts
              node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.es6.mjs
              node_modules/@homebridge/ciao/node_modules/tslib/README.md
              node_modules/@homebridge/ciao/node_modules/tslib/modules/index.js
              node_modules/@homebridge/ciao/node_modules/tslib/modules/index.d.ts
              node_modules/@homebridge/ciao/node_modules/tslib/tslib.es6.js
              node_modules/@homebridge/ciao/node_modules/tslib/tslib.js
              node_modules/@homebridge/ciao/node_modules/tslib/tslib.d.ts
              node_modules/@homebridge/ciao/node_modules/tslib/tslib.es6.mjs
              node_modules/syno/definitions/6.x/_full.json
              node_modules/syno/test/browser/js/syno-6.x.min.js
              node_modules/syno/dist/syno-6.x.min.js
              node_modules/syno/dist/syno-5.x.min.js
              node_modules/iobroker.yahka/admin/yahka.admin.js
              node_modules/iobroker.yahka/admin/yahka.admin.js.map
              node_modules/hosted-git-info/git-host.js
              node_modules/winston-seq-updated/lib/index.js
              node_modules/iobroker.vis-2-widgets-gauges/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
              node_modules/worker-timers-worker/node_modules/tslib/README.md
              node_modules/worker-timers-worker/node_modules/tslib/modules/index.js
              node_modules/worker-timers-worker/node_modules/tslib/modules/index.d.ts
              node_modules/worker-timers-worker/node_modules/tslib/tslib.es6.js
              node_modules/worker-timers-worker/node_modules/tslib/tslib.js
              node_modules/worker-timers-worker/node_modules/tslib/tslib.d.ts
              node_modules/worker-timers-worker/node_modules/tslib/tslib.es6.mjs
              node_modules/json2iob/tsconfig.json
              node_modules/worker-factory/node_modules/tslib/README.md
              node_modules/worker-factory/node_modules/tslib/modules/index.js
              node_modules/worker-factory/node_modules/tslib/modules/index.d.ts
              node_modules/worker-factory/node_modules/tslib/tslib.es6.js
              node_modules/worker-factory/node_modules/tslib/tslib.js
              node_modules/worker-factory/node_modules/tslib/tslib.d.ts
              node_modules/worker-factory/node_modules/tslib/tslib.es6.mjs
              node_modules/fast-unique-numbers/node_modules/tslib/README.md
              node_modules/fast-unique-numbers/node_modules/tslib/modules/index.js
              node_modules/fast-unique-numbers/node_modules/tslib/modules/index.d.ts
              node_modules/fast-unique-numbers/node_modules/tslib/tslib.es6.js
              node_modules/fast-unique-numbers/node_modules/tslib/tslib.js
              node_modules/fast-unique-numbers/node_modules/tslib/tslib.d.ts
              node_modules/fast-unique-numbers/node_modules/tslib/tslib.es6.mjs
              node_modules/rrule/node_modules/tslib/README.md
              node_modules/rrule/node_modules/tslib/modules/index.js
              node_modules/rrule/node_modules/tslib/modules/index.d.ts
              node_modules/rrule/node_modules/tslib/tslib.es6.js
              node_modules/rrule/node_modules/tslib/tslib.js
              node_modules/rrule/node_modules/tslib/tslib.d.ts
              node_modules/rrule/node_modules/tslib/tslib.es6.mjs
              node_modules/rrule/dist/es5/rrule.js
              node_modules/rrule/dist/es5/rrule.min.js.map
              node_modules/rrule/dist/esm/callbackiterresult.js
              node_modules/rrule/dist/esm/datetime.js
              node_modules/rrule/dist/esm/rruleset.js
              node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib.min.js
              node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/vuetify.js
              node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/material-components-web.js
              node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
              node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
              node_modules/iobroker.modbus/admin/assets/index-Blv_5nFZ.js
              node_modules/iobroker.material/www/static/js/main.c5478f66.js.map
              node_modules/jszip/tsconfig.json
              node_modules/iobroker.daswetter/admin/assets/index-84bRrRlB.js
              node_modules/node-gyp/lib/find-python.js
              node_modules/iobroker.javascript/admin/plugins/bundle.js
              node_modules/iobroker.javascript/admin/assets/index-dN73sbyQ.js
              node_modules/iobroker.javascript/admin/assets/iobroker_javascript__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-CV1_X-Lf.js
              node_modules/iobroker.javascript/admin/vs/editor/editor.main.js
              node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js
              node_modules/iobroker.javascript/admin/custom/assets/index-BptSiKBK.js
              node_modules/iobroker.javascript/admin/custom/assets/index-BVwMgafs.js
              node_modules/iobroker.javascript/admin/custom/assets/ConfigCustomJavascriptSet__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-KsT5vKjV.js
              node_modules/iobroker.javascript/admin/custom/assets/leaflet-src-k2rCV-Ix.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsyncAction.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsapAction.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsyncScheduler.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsapScheduler.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/QueueAction.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/QueueScheduler.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AnimationFrameScheduler.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/VirtualTimeScheduler.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AnimationFrameAction.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/Action.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/observable/dom/WebSocketSubject.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/observable/ConnectableObservable.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/operators/OperatorSubscriber.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/BehaviorSubject.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/Subscriber.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/AsyncSubject.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/ReplaySubject.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/HotObservable.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/TestScheduler.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/ColdObservable.js
              node_modules/np/node_modules/rxjs/dist/esm5/internal/Subject.js
              node_modules/np/node_modules/rxjs/dist/bundles/rxjs.umd.js.map
              node_modules/np/node_modules/rxjs/dist/bundles/rxjs.umd.min.js.map
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsyncAction.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsapAction.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsyncScheduler.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsapScheduler.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/QueueAction.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/QueueScheduler.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AnimationFrameScheduler.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/VirtualTimeScheduler.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AnimationFrameAction.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/Action.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/observable/dom/WebSocketSubject.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/observable/ConnectableObservable.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/operators/OperatorSubscriber.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/BehaviorSubject.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/Subscriber.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/AsyncSubject.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/ReplaySubject.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/HotObservable.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/TestScheduler.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/ColdObservable.js
              node_modules/np/node_modules/rxjs/dist/cjs/internal/Subject.js
              node_modules/np/node_modules/tslib/README.md
              node_modules/np/node_modules/tslib/modules/index.js
              node_modules/np/node_modules/tslib/modules/index.d.ts
              node_modules/np/node_modules/tslib/tslib.es6.js
              node_modules/np/node_modules/tslib/tslib.js
              node_modules/np/node_modules/tslib/tslib.d.ts
              node_modules/np/node_modules/tslib/tslib.es6.mjs
              node_modules/np/node_modules/type-fest/source/tsconfig-json.d.ts
              node_modules/iobroker.vis-2-widgets-inventwo/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
              node_modules/iobroker.vis-2-widgets-inventwo/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
              node_modules/sinon/pkg/sinon-esm.js
              node_modules/sinon/pkg/sinon-no-sourcemaps.cjs
              node_modules/sinon/pkg/sinon.js
              node_modules/luxon/build/cjs-browser/luxon.js
              node_modules/luxon/build/cjs-browser/luxon.js.map
              node_modules/luxon/build/amd/luxon.js
              node_modules/luxon/build/amd/luxon.js.map
              node_modules/luxon/build/global/luxon.min.js.map
              node_modules/luxon/build/global/luxon.js
              node_modules/luxon/build/global/luxon.js.map
              node_modules/localforage/bower_components/mocha/mocha.js
              node_modules/localforage/dist/localforage.js
              node_modules/localforage/dist/localforage.nopromises.min.js
              node_modules/localforage/dist/localforage.nopromises.js
              node_modules/localforage/dist/localforage.min.js
              node_modules/localforage/build/es5src/localforage.js
              node_modules/localforage/src/localforage.js
              node_modules/iobroker.email/admin/custom/assets/index-ByILBjTr.js
              node_modules/iobroker.email/admin/custom/assets/index-D-vy1JIC.js
              node_modules/iobroker.email/admin/custom/assets/ConfigCustomEmailSet__mf_v__runtimeInit__mf_v__-Bd5Kc7oi.js
              node_modules/iobroker.email/admin/rules/assets/ActionSendEmail__mf_v__runtimeInit__mf_v__-eLULivoH.js
              Gernot
              Host: i9 server Proxmox , Debian 13.4 for ioBroker
              ioBroker: 7.8.24, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.1.2
              Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
              Grafana 13.0.1 / InfluxDB 2.8.0
              • T tritor
                @OliverIO
                Ja da gibt es jede Menge Auflistung.
                node_modules/prompt/node_modules/winston/lib/winston/container.js
                node_modules/iobroker.admin/adminWww/static/js/worker-html.js
                node_modules/iobroker.admin/adminWww/static/js/worker-javascript.js
                node_modules/iobroker.admin/adminWww/assets/ace-B1WbEy8J.js
                node_modules/iobroker.admin/adminWww/assets/Objects-CQ1Cgg6L.js
                node_modules/iobroker.admin/adminWww/assets/leaflet-src-B651YTWC.js
                node_modules/iobroker.admin/adminWww/assets/index-Cy4zkLZ7.js
                node_modules/iobroker.admin/adminWww/assets/bootstrap-D0re3WSJ.js
                node_modules/iobroker.admin/adminWww/assets/index-DA90dn-y.js
                node_modules/iobroker.admin/admin/custom/assets/index-JHWyZnE9.js
                node_modules/iobroker.admin/admin/custom/assets/index-BqaC8TTV.js
                node_modules/iobroker.admin/admin/custom/assets/index-lwTE6AOa.js
                node_modules/iobroker.admin/admin/custom/assets/index-fHKF7cIy.js
                node_modules/iobroker.admin/admin/custom/assets/AdminComponentEasyAccessSet__mf_v__runtimeInit__mf_v__-JbSPU0nV.js
                node_modules/iobroker.admin/admin/custom/assets/index-C2cQRe9d.js
                node_modules/iobroker.admin/admin/custom/assets/index-DI-4AL4q.js
                node_modules/iobroker.admin/admin/custom/assets/AdminComponentEasyAccessSet__mf_v__runtimeInit__mf_v__-CbzMf-XP.js
                node_modules/iobroker.admin/admin/custom/assets/index-Cgl0l3l6.js
                node_modules/iobroker.admin/admin/custom/assets/index-CcWdaO-A.js
                node_modules/iobroker.admin/admin/custom/assets/index-BTEHfIqN.js
                node_modules/iobroker.admin/admin/custom/assets/index-WGNhBVhU.js
                node_modules/iobroker.admin/admin/custom/assets/index-DsmGf2-7.js
                node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js
                node_modules/esprima/dist/esprima.js
                node_modules/rxjs/_esm5/internal/SubjectSubscription.js
                node_modules/rxjs/_esm5/internal/scheduler/AsyncAction.js
                node_modules/rxjs/_esm5/internal/scheduler/AsapAction.js
                node_modules/rxjs/_esm5/internal/scheduler/AsyncScheduler.js
                node_modules/rxjs/_esm5/internal/scheduler/AsapScheduler.js
                node_modules/rxjs/_esm5/internal/scheduler/QueueAction.js
                node_modules/rxjs/_esm5/internal/scheduler/QueueScheduler.js
                node_modules/rxjs/_esm5/internal/scheduler/AnimationFrameScheduler.js
                node_modules/rxjs/_esm5/internal/scheduler/VirtualTimeScheduler.js
                node_modules/rxjs/_esm5/internal/scheduler/AnimationFrameAction.js
                node_modules/rxjs/_esm5/internal/scheduler/Action.js
                node_modules/rxjs/_esm5/internal/observable/zip.js
                node_modules/rxjs/_esm5/internal/observable/race.js
                node_modules/rxjs/_esm5/internal/observable/SubscribeOnObservable.js
                node_modules/rxjs/_esm5/internal/observable/dom/WebSocketSubject.js
                node_modules/rxjs/_esm5/internal/observable/dom/AjaxObservable.js
                node_modules/rxjs/_esm5/internal/observable/ConnectableObservable.js
                node_modules/rxjs/_esm5/internal/observable/combineLatest.js
                node_modules/rxjs/_esm5/internal/operators/refCount.js
                node_modules/rxjs/_esm5/internal/operators/expand.js
                node_modules/rxjs/_esm5/internal/operators/skipUntil.js
                node_modules/rxjs/_esm5/internal/operators/debounce.js
                node_modules/rxjs/_esm5/internal/operators/single.js
                node_modules/rxjs/_esm5/internal/operators/pairwise.js
                node_modules/rxjs/_esm5/internal/operators/exhaust.js
                node_modules/rxjs/_esm5/internal/operators/take.js
                node_modules/rxjs/_esm5/internal/operators/repeat.js
                node_modules/rxjs/_esm5/internal/operators/sequenceEqual.js
                node_modules/rxjs/_esm5/internal/operators/skipLast.js
                node_modules/rxjs/_esm5/internal/operators/audit.js
                node_modules/rxjs/_esm5/internal/operators/map.js
                node_modules/rxjs/_esm5/internal/operators/every.js
                node_modules/rxjs/_esm5/internal/operators/throttleTime.js
                node_modules/rxjs/_esm5/internal/operators/takeWhile.js
                node_modules/rxjs/_esm5/internal/operators/ignoreElements.js
                node_modules/rxjs/_esm5/internal/operators/delay.js
                node_modules/rxjs/_esm5/internal/operators/takeLast.js
                node_modules/rxjs/_esm5/internal/operators/bufferWhen.js
                node_modules/rxjs/_esm5/internal/operators/skip.js
                node_modules/rxjs/_esm5/internal/operators/windowToggle.js
                node_modules/rxjs/_esm5/internal/operators/mergeScan.js
                node_modules/rxjs/_esm5/internal/operators/count.js
                node_modules/rxjs/_esm5/internal/operators/windowCount.js
                node_modules/rxjs/_esm5/internal/operators/buffer.js
                node_modules/rxjs/_esm5/internal/operators/throttle.js
                node_modules/rxjs/_esm5/internal/operators/sampleTime.js
                node_modules/rxjs/_esm5/internal/operators/skipWhile.js
                node_modules/rxjs/_esm5/internal/operators/takeUntil.js
                node_modules/rxjs/_esm5/internal/operators/isEmpty.js
                node_modules/rxjs/_esm5/internal/operators/bufferToggle.js
                node_modules/rxjs/_esm5/internal/operators/defaultIfEmpty.js
                node_modules/rxjs/_esm5/internal/operators/tap.js
                node_modules/rxjs/_esm5/internal/operators/distinct.js
                node_modules/rxjs/_esm5/internal/operators/groupBy.js
                node_modules/rxjs/_esm5/internal/operators/catchError.js
                node_modules/rxjs/_esm5/internal/operators/find.js
                node_modules/rxjs/_esm5/internal/operators/bufferCount.js
                node_modules/rxjs/_esm5/internal/operators/timeoutWith.js
                node_modules/rxjs/_esm5/internal/operators/throwIfEmpty.js
                node_modules/rxjs/_esm5/internal/operators/repeatWhen.js
                node_modules/rxjs/_esm5/internal/operators/withLatestFrom.js
                node_modules/rxjs/_esm5/internal/operators/filter.js
                node_modules/rxjs/_esm5/internal/operators/exhaustMap.js
                node_modules/rxjs/_esm5/internal/operators/delayWhen.js
                node_modules/rxjs/_esm5/internal/operators/dematerialize.js
                node_modules/rxjs/_esm5/internal/operators/retry.js
                node_modules/rxjs/_esm5/internal/operators/materialize.js
                node_modules/rxjs/_esm5/internal/operators/retryWhen.js
                node_modules/rxjs/_esm5/internal/operators/onErrorResumeNext.js
                node_modules/rxjs/_esm5/internal/operators/mapTo.js
                node_modules/rxjs/_esm5/internal/operators/bufferTime.js
                node_modules/rxjs/_esm5/internal/operators/sample.js
                node_modules/rxjs/_esm5/internal/operators/scan.js
                node_modules/rxjs/_esm5/internal/operators/mergeMap.js
                node_modules/rxjs/_esm5/internal/operators/switchMap.js
                node_modules/rxjs/_esm5/internal/operators/window.js
                node_modules/rxjs/_esm5/internal/operators/debounceTime.js
                node_modules/rxjs/_esm5/internal/operators/windowTime.js
                node_modules/rxjs/_esm5/internal/operators/windowWhen.js
                node_modules/rxjs/_esm5/internal/operators/finalize.js
                node_modules/rxjs/_esm5/internal/operators/distinctUntilChanged.js
                node_modules/rxjs/_esm5/internal/operators/observeOn.js
                node_modules/rxjs/_esm5/internal/BehaviorSubject.js
                node_modules/rxjs/_esm5/internal/OuterSubscriber.js
                node_modules/rxjs/_esm5/internal/Subscriber.js
                node_modules/rxjs/_esm5/internal/innerSubscribe.js
                node_modules/rxjs/_esm5/internal/AsyncSubject.js
                node_modules/rxjs/_esm5/internal/ReplaySubject.js
                node_modules/rxjs/_esm5/internal/testing/HotObservable.js
                node_modules/rxjs/_esm5/internal/testing/TestScheduler.js
                node_modules/rxjs/_esm5/internal/testing/ColdObservable.js
                node_modules/rxjs/_esm5/internal/InnerSubscriber.js
                node_modules/rxjs/_esm5/internal/Subject.js
                node_modules/rxjs/internal/SubjectSubscription.js
                node_modules/rxjs/internal/scheduler/AsyncAction.js
                node_modules/rxjs/internal/scheduler/AsapAction.js
                node_modules/rxjs/internal/scheduler/AsyncScheduler.js
                node_modules/rxjs/internal/scheduler/AsapScheduler.js
                node_modules/rxjs/internal/scheduler/QueueAction.js
                node_modules/rxjs/internal/scheduler/QueueScheduler.js
                node_modules/rxjs/internal/scheduler/AnimationFrameScheduler.js
                node_modules/rxjs/internal/scheduler/VirtualTimeScheduler.js
                node_modules/rxjs/internal/scheduler/AnimationFrameAction.js
                node_modules/rxjs/internal/scheduler/Action.js
                node_modules/rxjs/internal/observable/zip.js
                node_modules/rxjs/internal/observable/race.js
                node_modules/rxjs/internal/observable/SubscribeOnObservable.js
                node_modules/rxjs/internal/observable/dom/WebSocketSubject.js
                node_modules/rxjs/internal/observable/dom/AjaxObservable.js
                node_modules/rxjs/internal/observable/ConnectableObservable.js
                node_modules/rxjs/internal/observable/combineLatest.js
                node_modules/rxjs/internal/operators/refCount.js
                node_modules/rxjs/internal/operators/expand.js
                node_modules/rxjs/internal/operators/skipUntil.js
                node_modules/rxjs/internal/operators/debounce.js
                node_modules/rxjs/internal/operators/single.js
                node_modules/rxjs/internal/operators/pairwise.js
                node_modules/rxjs/internal/operators/exhaust.js
                node_modules/rxjs/internal/operators/take.js
                node_modules/rxjs/internal/operators/repeat.js
                node_modules/rxjs/internal/operators/sequenceEqual.js
                node_modules/rxjs/internal/operators/skipLast.js
                node_modules/rxjs/internal/operators/audit.js
                node_modules/rxjs/internal/operators/map.js
                node_modules/rxjs/internal/operators/every.js
                node_modules/rxjs/internal/operators/throttleTime.js
                node_modules/rxjs/internal/operators/takeWhile.js
                node_modules/rxjs/internal/operators/ignoreElements.js
                node_modules/rxjs/internal/operators/delay.js
                node_modules/rxjs/internal/operators/takeLast.js
                node_modules/rxjs/internal/operators/bufferWhen.js
                node_modules/rxjs/internal/operators/skip.js
                node_modules/rxjs/internal/operators/windowToggle.js
                node_modules/rxjs/internal/operators/mergeScan.js
                node_modules/rxjs/internal/operators/count.js
                node_modules/rxjs/internal/operators/windowCount.js
                node_modules/rxjs/internal/operators/buffer.js
                node_modules/rxjs/internal/operators/throttle.js
                node_modules/rxjs/internal/operators/sampleTime.js
                node_modules/rxjs/internal/operators/skipWhile.js
                node_modules/rxjs/internal/operators/takeUntil.js
                node_modules/rxjs/internal/operators/isEmpty.js
                node_modules/rxjs/internal/operators/bufferToggle.js
                node_modules/rxjs/internal/operators/defaultIfEmpty.js
                node_modules/rxjs/internal/operators/tap.js
                node_modules/rxjs/internal/operators/distinct.js
                node_modules/rxjs/internal/operators/groupBy.js
                node_modules/rxjs/internal/operators/catchError.js
                node_modules/rxjs/internal/operators/find.js
                node_modules/rxjs/internal/operators/bufferCount.js
                node_modules/rxjs/internal/operators/timeoutWith.js
                node_modules/rxjs/internal/operators/throwIfEmpty.js
                node_modules/rxjs/internal/operators/repeatWhen.js
                node_modules/rxjs/internal/operators/withLatestFrom.js
                node_modules/rxjs/internal/operators/filter.js
                node_modules/rxjs/internal/operators/exhaustMap.js
                node_modules/rxjs/internal/operators/delayWhen.js
                node_modules/rxjs/internal/operators/dematerialize.js
                node_modules/rxjs/internal/operators/retry.js
                node_modules/rxjs/internal/operators/materialize.js
                node_modules/rxjs/internal/operators/retryWhen.js
                node_modules/rxjs/internal/operators/onErrorResumeNext.js
                node_modules/rxjs/internal/operators/mapTo.js
                node_modules/rxjs/internal/operators/bufferTime.js
                node_modules/rxjs/internal/operators/sample.js
                node_modules/rxjs/internal/operators/scan.js
                node_modules/rxjs/internal/operators/mergeMap.js
                node_modules/rxjs/internal/operators/switchMap.js
                node_modules/rxjs/internal/operators/window.js
                node_modules/rxjs/internal/operators/debounceTime.js
                node_modules/rxjs/internal/operators/windowTime.js
                node_modules/rxjs/internal/operators/windowWhen.js
                node_modules/rxjs/internal/operators/finalize.js
                node_modules/rxjs/internal/operators/distinctUntilChanged.js
                node_modules/rxjs/internal/operators/observeOn.js
                node_modules/rxjs/internal/BehaviorSubject.js
                node_modules/rxjs/internal/OuterSubscriber.js
                node_modules/rxjs/internal/Subscriber.js
                node_modules/rxjs/internal/innerSubscribe.js
                node_modules/rxjs/internal/AsyncSubject.js
                node_modules/rxjs/internal/ReplaySubject.js
                node_modules/rxjs/internal/testing/HotObservable.js
                node_modules/rxjs/internal/testing/TestScheduler.js
                node_modules/rxjs/internal/testing/ColdObservable.js
                node_modules/rxjs/internal/InnerSubscriber.js
                node_modules/rxjs/internal/Subject.js
                node_modules/rxjs/bundles/rxjs.umd.js.map
                node_modules/rxjs/bundles/rxjs.umd.min.js.map
                node_modules/iobroker.scenes/admin/assets/index-B_g9fImg.js
                node_modules/broker-factory/node_modules/tslib/README.md
                node_modules/broker-factory/node_modules/tslib/modules/index.js
                node_modules/broker-factory/node_modules/tslib/modules/index.d.ts
                node_modules/broker-factory/node_modules/tslib/tslib.es6.js
                node_modules/broker-factory/node_modules/tslib/tslib.js
                node_modules/broker-factory/node_modules/tslib/tslib.d.ts
                node_modules/broker-factory/node_modules/tslib/tslib.es6.mjs
                node_modules/express/History.md
                node_modules/iobroker.devices/www/assets/index-C8dcoZB8.js
                node_modules/iobroker.devices/admin/assets/index-SJof8gXx.js
                node_modules/acorn-globals/node_modules/acorn/dist/acorn.js
                node_modules/acorn-globals/node_modules/acorn/dist/acorn_loose.js
                node_modules/acorn-globals/node_modules/acorn/src/statement.js
                node_modules/acorn-globals/node_modules/acorn/src/loose/statement.js
                node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
                node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
                node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
                node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
                node_modules/iobroker.fullcalendar/admin/static/js/main.c13d3761.js
                node_modules/iobroker.fullcalendar/admin/static/js/main.c13d3761.js.map
                node_modules/dot-prop/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/dropbox-v2-api/dist/api.json
                node_modules/dropbox-v2-api/src/api.json
                node_modules/boxen/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/web-streams-polyfill/dist/ponyfill.mjs.map
                node_modules/web-streams-polyfill/dist/ponyfill.js.map
                node_modules/web-streams-polyfill/dist/ponyfill.es6.mjs.map
                node_modules/web-streams-polyfill/dist/polyfill.min.js.map
                node_modules/web-streams-polyfill/dist/polyfill.js.map
                node_modules/web-streams-polyfill/dist/polyfill.mjs.map
                node_modules/web-streams-polyfill/dist/polyfill.es6.mjs.map
                node_modules/web-streams-polyfill/dist/ponyfill.es6.js.map
                node_modules/web-streams-polyfill/dist/polyfill.es6.min.js.map
                node_modules/web-streams-polyfill/dist/polyfill.es6.js.map
                node_modules/worker-timers-broker/node_modules/tslib/README.md
                node_modules/worker-timers-broker/node_modules/tslib/modules/index.js
                node_modules/worker-timers-broker/node_modules/tslib/modules/index.d.ts
                node_modules/worker-timers-broker/node_modules/tslib/tslib.es6.js
                node_modules/worker-timers-broker/node_modules/tslib/tslib.js
                node_modules/worker-timers-broker/node_modules/tslib/tslib.d.ts
                node_modules/worker-timers-broker/node_modules/tslib/tslib.es6.mjs
                node_modules/iobroker.vis/www/index.html
                node_modules/iobroker.vis/www/widgets/basic.html
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/src_Components_VacuumIcon_js-src_Components_WindowClosed_js-node_modules_react-circular-slide-54a955.34b175bb.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_leaflet_dist_leaflet_css-node_modules_leaflet_dist_images_marker-icon-2x-281382.49131c79.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.9a6346f3.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.ef43cd96.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react_jsx-runtime_js-node_modules_leaflet_dist_leaflet_css-node_modules_-5c5561.c33b1195.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.199f0b4e.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.3c144320.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.837c9082.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react_jsx-runtime_js-node_modules_leaflet_dist_leaflet_css-node_modules_-5c5561.c33b1195.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.3ebf8200.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b24a2b7b.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_legend_install_js.432b0c40.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react-circular-slider-svg_dist_index_js-node_modules_react_cjs_react-jsx-6278e5.433d1581.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/src_Generic_jsx-node_modules_react-circular-slider-svg_dist_index_js.f186cf20.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.ef43cd96.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.0cbfea69.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b80a2194.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.5884108b.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.08cf7e1a.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.5884108b.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.5d75fa27.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b80a2194.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_legend_install_js.a18746ef.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__mf_v__runtimeInit__mf_v__-mPD03Tof.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-bcz2UOY-.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/index-DBeNUnty.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/Map-DvvTKot1.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
                node_modules/iobroker.vis/www/widgets/materialdesign/lib.min.js
                node_modules/iobroker.vis/www/widgets/materialdesign/lib/vuetify.js
                node_modules/iobroker.vis/www/widgets/materialdesign/lib/material-components-web.js
                node_modules/iobroker.vis/www/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
                node_modules/iobroker.vis/www/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.ff34318e.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.f78ceb8d.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.b2dda7e4.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-battery-gauge_dist_react-battery-gauge_esm_js.438236c2.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-battery-gauge_dist_react-battery-gauge_esm_js.81e383f5.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-1RJxOR8B.js
                node_modules/iobroker.vis/www/widgets/openweathermap/assets/index-DnuTl29g.js
                node_modules/iobroker.vis/www/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_esm_index_js.49c59391.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_styled_js.25c617b0.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-8c1e82.52c5b0a7.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_isMuiElement_isMuiElement-90f327.68e2ebbd.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_index_js.6f996889.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.b58e6a51.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-8c1e82.52c5b0a7.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.a10fb2cd.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_index_js.6f996889.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js-n-287313.6a72939a.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.0fdc2efe.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.54021824.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.22192a38.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_styleFunctionSx_e-646437.480ef8e8.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_ZoomOutMap_js-node_modules_mui_material_Fab_Fab_js-no-238edc.c17f49ad.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_esm_index_js.4a02bfba.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_ZoomOutMap_js-node_modules_mui_material_Fab_Fab_js-no-de51fd.47eda6f0.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.7fc5de73.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_esm_isMuiElement_isMuiEle-37774c.5027f981.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.e83bdd95.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.7fc5de73.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.97b3e2d1.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.1749f755.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_esm_isMuiElement_isMuiEle-37774c.5027f981.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js-node_modules_mui_system_esm_u-30631c.5a5082ed.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.3ed26143.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Checkbox_Checkbox_js-node_modules_mui_material_FormControl_-ab667d.80eee493.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_createTheme_creat-8e35a0.19e0cbc7.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-09395c.bf487e67.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js-n-287313.6a72939a.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_material_styles_Them-0bf85c.de23cbfb.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.97b3e2d1.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_styled_js.dae67faa.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_x-date-pickers_TimePicker_TimePicker_js-node_modules_babel_runtime_h-8a0c27.799842e9.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_x-date-pickers_AdapterDayjs_Adapte-b79734.de09a47b.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-5ae56a.fbe8964c.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-66a30d.53923d06.chunk.js
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-66a30d.53923d06.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_createTheme_creat-c54a24.aedd89eb.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-f5912f.292616a4.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_x-date-pickers_AdapterDayjs_Adapte-c0e24c.44cc9956.chunk.js.map
                node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.48ced1a3.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b33a19f6.chunk.js.map
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/static/js/vendors-node_modules_mui_system_esm_index_js.2f5bd81f.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/static/js/vendors-node_modules_mui_material_index_js.108fbfef.chunk.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-CsZQ1K9c.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-BJeC_1Nc.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-4dZ_faDJ.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-CJ-kxqUy.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-B5RqNgEg.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-COK1nOKA.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BZKNvirX.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-DpCJnELL.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-Bp2scStG.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-Bk5B5ET5.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-B6mUFPf4.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-C-Jo2qj7.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-2uL955SU.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-CBbfFHA5.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-C5a4dcu-.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BlUXZP4n.js
                node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
                node_modules/iobroker.vis/www/edit.html
                node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js
                node_modules/iobroker.vis/www/lib/ace/worker-html.js
                node_modules/eventsource/example/eventsource-polyfill.js
                node_modules/@js-sdsl/ordered-map/dist/esm/index.js
                node_modules/@js-sdsl/ordered-map/dist/esm/index.js.map
                node_modules/@js-sdsl/ordered-map/dist/umd/ordered-map.js
                node_modules/@js-sdsl/ordered-map/dist/umd/ordered-map.min.js.map
                node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.js
                node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.min.js.map
                node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.js.map
                node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.msgpack.min.js.map
                node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.min.js.map
                node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.js.map
                node_modules/nise/nise.js
                node_modules/@iobroker/types/build/types.d.ts
                node_modules/@iobroker/dev-server/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/@iobroker/js-controller-adapter/build/esm/lib/adapter/adapter.d.ts
                node_modules/@iobroker/js-controller-adapter/build/esm/lib/adapter/adapter.js
                node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.d.ts
                node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js.map
                node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.d.ts
                node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js
                node_modules/@iobroker/db-objects-redis/build/cjs/lib/objects/objectsInRedisClient.d.ts
                node_modules/@iobroker/db-objects-redis/build/cjs/lib/objects/objectsInRedisClient.js.map
                node_modules/iobroker.zigbee2mqtt/node_modules/tslib/README.md
                node_modules/iobroker.zigbee2mqtt/node_modules/tslib/modules/index.js
                node_modules/iobroker.zigbee2mqtt/node_modules/tslib/modules/index.d.ts
                node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.es6.js
                node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.js
                node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.d.ts
                node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.es6.mjs
                node_modules/iobroker.reolink/node_modules/tslib/README.md
                node_modules/iobroker.reolink/node_modules/tslib/modules/index.js
                node_modules/iobroker.reolink/node_modules/tslib/modules/index.d.ts
                node_modules/iobroker.reolink/node_modules/tslib/tslib.es6.js
                node_modules/iobroker.reolink/node_modules/tslib/tslib.js
                node_modules/iobroker.reolink/node_modules/tslib/tslib.d.ts
                node_modules/iobroker.reolink/node_modules/tslib/tslib.es6.mjs
                node_modules/xml2js/lib/xml2js.bc.js
                node_modules/iobroker.wlanthermo-nano/admin/build/index.js
                node_modules/iobroker.wlanthermo-nano/admin/build/index.js.map
                node_modules/nedb/browser-version/out/nedb.min.js
                node_modules/nedb/browser-version/out/nedb.js
                node_modules/nedb/browser-version/test/localforage.js
                node_modules/iobroker.vis-2-widgets-energy/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
                node_modules/@babel/runtime/helpers/extends.js
                node_modules/@babel/runtime/helpers/esm/extends.js
                node_modules/eslint-plugin-node/lib/rules/no-deprecated-api.js
                node_modules/terminal-link/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/p-memoize/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/iobroker.backitup/node_modules/tslib/README.md
                node_modules/iobroker.backitup/node_modules/tslib/modules/index.js
                node_modules/iobroker.backitup/node_modules/tslib/modules/index.d.ts
                node_modules/iobroker.backitup/node_modules/tslib/tslib.es6.js
                node_modules/iobroker.backitup/node_modules/tslib/tslib.js
                node_modules/iobroker.backitup/node_modules/tslib/tslib.d.ts
                node_modules/iobroker.backitup/node_modules/tslib/tslib.es6.mjs
                node_modules/iobroker.backitup/admin/assets/index-BeQV_TGa.js
                node_modules/iobroker.backitup/admin/custom/assets/index-CHFaRedm.js
                node_modules/iobroker.backitup/admin/custom/assets/index-Ba6zELes.js
                node_modules/iobroker.backitup/admin/custom/assets/ConfigCustomBackItUpSet__loadShare___mf_0_mui_mf_1_material__loadShare__.js-DqH6EEuz.js
                node_modules/iobroker.discovery/node_modules/@serialport/bindings-cpp/prebuilds/android-arm64/node.napi.armv8.node
                node_modules/iobroker.discovery/node_modules/node-addon-api/napi-inl.h
                node_modules/sqlite3/node_modules/node-addon-api/napi-inl.h
                node_modules/sqlite3/build/Release/node_sqlite3.node
                node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.msgpack.min.js.map
                node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.min.js.map
                node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.js.map
                node_modules/node-rest-client/lib/node-rest-client.js
                node_modules/@img/sharp-linux-x64/lib/sharp-linux-x64.node
                node_modules/@img/sharp-linuxmusl-x64/lib/sharp-linuxmusl-x64.node
                node_modules/@img/sharp-libvips-linuxmusl-x64/lib/libvips-cpp.so.42
                node_modules/@img/sharp-libvips-linux-x64/lib/libvips-cpp.so.42
                node_modules/js-sdsl/dist/esm/container/TreeContainer/OrderedSet.js.map
                node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/index.js
                node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/index.js.map
                node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeIterator.js.map
                node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeNode.js
                node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeNode.js.map
                node_modules/js-sdsl/dist/esm/container/TreeContainer/OrderedMap.js.map
                node_modules/js-sdsl/dist/esm/container/OtherContainer/Queue.js
                node_modules/js-sdsl/dist/esm/container/OtherContainer/PriorityQueue.js.map
                node_modules/js-sdsl/dist/esm/container/OtherContainer/Queue.js.map
                node_modules/js-sdsl/dist/esm/container/OtherContainer/Stack.js.map
                node_modules/js-sdsl/dist/esm/container/ContainerBase/index.js
                node_modules/js-sdsl/dist/esm/container/ContainerBase/index.js.map
                node_modules/js-sdsl/dist/esm/container/HashContainer/Base/index.js
                node_modules/js-sdsl/dist/esm/container/HashContainer/Base/index.js.map
                node_modules/js-sdsl/dist/esm/container/HashContainer/HashSet.js
                node_modules/js-sdsl/dist/esm/container/HashContainer/HashMap.js.map
                node_modules/js-sdsl/dist/esm/container/HashContainer/HashSet.js.map
                node_modules/js-sdsl/dist/esm/container/SequentialContainer/Deque.js
                node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/RandomIterator.js.map
                node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/index.js
                node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/index.js.map
                node_modules/js-sdsl/dist/esm/container/SequentialContainer/Deque.js.map
                node_modules/js-sdsl/dist/esm/container/SequentialContainer/Vector.js
                node_modules/js-sdsl/dist/esm/container/SequentialContainer/LinkList.js.map
                node_modules/js-sdsl/dist/esm/container/SequentialContainer/Vector.js.map
                node_modules/js-sdsl/dist/umd/js-sdsl.js
                node_modules/js-sdsl/dist/umd/js-sdsl.min.js.map
                node_modules/iobroker.frigate/node_modules/tslib/README.md
                node_modules/iobroker.frigate/node_modules/tslib/modules/index.js
                node_modules/iobroker.frigate/node_modules/tslib/modules/index.d.ts
                node_modules/iobroker.frigate/node_modules/tslib/tslib.es6.js
                node_modules/iobroker.frigate/node_modules/tslib/tslib.js
                node_modules/iobroker.frigate/node_modules/tslib/tslib.d.ts
                node_modules/iobroker.frigate/node_modules/tslib/tslib.es6.mjs
                node_modules/jsdom/node_modules/acorn/dist/acorn.js
                node_modules/jsdom/node_modules/acorn/dist/acorn_loose.js
                node_modules/jsdom/node_modules/acorn/src/statement.js
                node_modules/jsdom/node_modules/acorn/src/loose/statement.js
                node_modules/@opentelemetry/instrumentation/build/esm/platform/browser/instrumentation.js
                node_modules/@opentelemetry/instrumentation/build/esm/platform/node/instrumentation.js
                node_modules/@opentelemetry/api/build/esm/metrics/NoopMeter.js
                node_modules/@opentelemetry/sdk-trace-base/build/esm/platform/browser/export/BatchSpanProcessor.js
                node_modules/@opentelemetry/sdk-trace-base/build/esm/platform/node/export/BatchSpanProcessor.js
                node_modules/@opentelemetry/core/build/esm/utils/timeout.js
                node_modules/mocha/mocha.js
                node_modules/ajv/README.md
                node_modules/fast-glob/README.md
                node_modules/globals/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/date-fns/package.json
                node_modules/jsx-ast-utils/lib/values/index.js
                node_modules/jsx-ast-utils/lib/values/expressions/index.js
                node_modules/jsx-ast-utils/lib/values/expressions/ObjectExpression.js
                node_modules/jsx-ast-utils/lib/getProp.js
                node_modules/bs-recipes/recipes/webpack.typescript.react/app/dist/bundle.js
                node_modules/browser-sync-client/dist/index.js
                node_modules/http-proxy/lib/http-proxy/index.js
                node_modules/http-proxy/lib/http-proxy/common.js
                node_modules/standard/node_modules/acorn/dist/acorn.mjs.map
                node_modules/standard/node_modules/acorn/dist/acorn.d.ts
                node_modules/standard/node_modules/acorn/dist/acorn.js.map
                node_modules/iobroker.vis-2/www/widgets.html
                node_modules/iobroker.vis-2/www/widgets/basic.html
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
                node_modules/iobroker.vis-2/www/widgets/materialdesign/lib.min.js
                node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/vuetify.js
                node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/material-components-web.js
                node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
                node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
                node_modules/iobroker.vis-2/www/widgets/openweathermap/assets/index-DnuTl29g.js
                node_modules/iobroker.vis-2/www/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
                node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
                node_modules/iobroker.vis-2/www/assets/createStyled-CtLRJdF1.js
                node_modules/iobroker.vis-2/www/assets/index-D_qqioAY.js.map
                node_modules/iobroker.vis-2/www/assets/index-BRd7FNtl.js
                node_modules/iobroker.vis-2/www/assets/index-CrLrNq4s.js
                node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-B8Z0SsW4.js.map
                node_modules/iobroker.vis-2/www/assets/Dialog-DElqR5zv.js.map
                node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Dt1au33l.js
                node_modules/iobroker.vis-2/www/assets/Dialog-Dgkz1L-r.js
                node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Dt1au33l.js.map
                node_modules/iobroker.vis-2/www/assets/createStyled-BvULSPVR.js.map
                node_modules/iobroker.vis-2/www/assets/index-BGo51MQZ.js
                node_modules/iobroker.vis-2/www/assets/index-DqJdyjgH.js.map
                node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-y8HJH6Vp.js
                node_modules/iobroker.vis-2/www/assets/Box-Bl3kq-x-.js.map
                node_modules/iobroker.vis-2/www/assets/index-BGhFZJYV.js.map
                node_modules/iobroker.vis-2/www/assets/assertThisInitialized-DtkDSj7h.js.map
                node_modules/iobroker.vis-2/www/assets/Dialog-Dgkz1L-r.js.map
                node_modules/iobroker.vis-2/www/assets/index-CrLrNq4s.js.map
                node_modules/iobroker.vis-2/www/assets/index-CzkXf0rM.js.map
                node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Zvkdie3d.js
                node_modules/iobroker.vis-2/www/assets/assertThisInitialized-DFQXnDE3.js.map
                node_modules/iobroker.vis-2/www/assets/index-BRd7FNtl.js.map
                node_modules/iobroker.vis-2/www/assets/index-BGo51MQZ.js.map
                node_modules/iobroker.vis-2/www/assets/index-BTDdCqea.js
                node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Zvkdie3d.js.map
                node_modules/iobroker.vis-2/www/assets/createStyled-CtLRJdF1.js.map
                node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-y8HJH6Vp.js.map
                node_modules/iobroker.vis-2/www/assets/visWidgetsCatalog-D4OT0wlf.js.map
                node_modules/iobroker.vis-2/www/assets/index-B2JJPlmn.js.map
                node_modules/iobroker.vis-2/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js
                node_modules/worker-timers/node_modules/tslib/README.md
                node_modules/worker-timers/node_modules/tslib/modules/index.js
                node_modules/worker-timers/node_modules/tslib/modules/index.d.ts
                node_modules/worker-timers/node_modules/tslib/tslib.es6.js
                node_modules/worker-timers/node_modules/tslib/tslib.js
                node_modules/worker-timers/node_modules/tslib/tslib.d.ts
                node_modules/worker-timers/node_modules/tslib/tslib.es6.mjs
                node_modules/acorn/dist/acorn.d.mts
                node_modules/iobroker.openweathermap/widgets/openweathermap/assets/index-DnuTl29g.js
                node_modules/iobroker.openweathermap/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
                node_modules/prettier/plugins/babel.mjs
                node_modules/prettier/plugins/flow.mjs
                node_modules/prettier/plugins/acorn.js
                node_modules/prettier/plugins/typescript.mjs
                node_modules/prettier/plugins/typescript.js
                node_modules/prettier/plugins/acorn.mjs
                node_modules/prettier/plugins/flow.js
                node_modules/prettier/plugins/babel.js
                node_modules/prettier/internal/experimental-cli.mjs
                node_modules/core-util-is/float.patch
                node_modules/new-github-release-url/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/iobroker.ping/admin/custom/assets/index-D8RJ5veu.js
                node_modules/iobroker.ping/admin/custom/assets/index-CbxD1KHt.js
                node_modules/typescript/lib/pl/diagnosticMessages.generated.json
                node_modules/typescript/lib/ja/diagnosticMessages.generated.json
                node_modules/typescript/lib/it/diagnosticMessages.generated.json
                node_modules/typescript/lib/ko/diagnosticMessages.generated.json
                node_modules/typescript/lib/ru/diagnosticMessages.generated.json
                node_modules/typescript/lib/zh-cn/diagnosticMessages.generated.json
                node_modules/typescript/lib/cs/diagnosticMessages.generated.json
                node_modules/typescript/lib/de/diagnosticMessages.generated.json
                node_modules/typescript/lib/fr/diagnosticMessages.generated.json
                node_modules/typescript/lib/_tsc.js
                node_modules/typescript/lib/typescript.js
                node_modules/typescript/lib/zh-tw/diagnosticMessages.generated.json
                node_modules/typescript/lib/tr/diagnosticMessages.generated.json
                node_modules/typescript/lib/es/diagnosticMessages.generated.json
                node_modules/typescript/lib/pt-br/diagnosticMessages.generated.json
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
                node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
                node_modules/canvas/build/Release/libpango-1.0.so.0
                node_modules/canvas/build/Release/canvas.node
                node_modules/canvas/build/Release/libharfbuzz.so.0
                node_modules/canvas/build/Release/libcairo.so.2
                node_modules/canvas/build/Release/libcairo-gobject.so.2
                node_modules/canvas/build/Release/librsvg-2.so.2
                node_modules/canvas/build/Release/libglib-2.0.so.0
                node_modules/canvas/build/Release/obj.target/canvas.node
                node_modules/canvas/build/Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                node_modules/canvas/build/Release/libgio-2.0.so.0
                node_modules/canvas/src/CanvasRenderingContext2d.cc
                node_modules/canvas/src/CanvasRenderingContext2d.cc.orig
                node_modules/request/CHANGELOG.md
                node_modules/swagger-ui-dist/swagger-ui-standalone-preset.js
                node_modules/swagger-ui-dist/swagger-ui.js.map
                node_modules/swagger-ui-dist/swagger-ui-es-bundle-core.js
                node_modules/swagger-ui-dist/swagger-ui-bundle.js.map
                node_modules/swagger-ui-dist/swagger-ui-es-bundle.js
                node_modules/swagger-ui-dist/swagger-ui-es-bundle-core.js.map
                node_modules/swagger-ui-dist/swagger-ui-es-bundle.js.map
                node_modules/swagger-ui-dist/swagger-ui-standalone-preset.js.map
                node_modules/@azure/keyvault-keys/node_modules/tslib/README.md
                node_modules/@azure/keyvault-keys/node_modules/tslib/modules/index.js
                node_modules/@azure/keyvault-keys/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.es6.js
                node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.js
                node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.d.ts
                node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/core-tracing/node_modules/tslib/README.md
                node_modules/@azure/core-tracing/node_modules/tslib/modules/index.js
                node_modules/@azure/core-tracing/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/core-tracing/node_modules/tslib/tslib.es6.js
                node_modules/@azure/core-tracing/node_modules/tslib/tslib.js
                node_modules/@azure/core-tracing/node_modules/tslib/tslib.d.ts
                node_modules/@azure/core-tracing/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/abort-controller/node_modules/tslib/README.md
                node_modules/@azure/abort-controller/node_modules/tslib/modules/index.js
                node_modules/@azure/abort-controller/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/abort-controller/node_modules/tslib/tslib.es6.js
                node_modules/@azure/abort-controller/node_modules/tslib/tslib.js
                node_modules/@azure/abort-controller/node_modules/tslib/tslib.d.ts
                node_modules/@azure/abort-controller/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/core-auth/node_modules/tslib/README.md
                node_modules/@azure/core-auth/node_modules/tslib/modules/index.js
                node_modules/@azure/core-auth/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/core-auth/node_modules/tslib/tslib.es6.js
                node_modules/@azure/core-auth/node_modules/tslib/tslib.js
                node_modules/@azure/core-auth/node_modules/tslib/tslib.d.ts
                node_modules/@azure/core-auth/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/core-util/node_modules/tslib/README.md
                node_modules/@azure/core-util/node_modules/tslib/modules/index.js
                node_modules/@azure/core-util/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/core-util/node_modules/tslib/tslib.es6.js
                node_modules/@azure/core-util/node_modules/tslib/tslib.js
                node_modules/@azure/core-util/node_modules/tslib/tslib.d.ts
                node_modules/@azure/core-util/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/logger/node_modules/tslib/README.md
                node_modules/@azure/logger/node_modules/tslib/modules/index.js
                node_modules/@azure/logger/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/logger/node_modules/tslib/tslib.es6.js
                node_modules/@azure/logger/node_modules/tslib/tslib.js
                node_modules/@azure/logger/node_modules/tslib/tslib.d.ts
                node_modules/@azure/logger/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/identity/node_modules/tslib/README.md
                node_modules/@azure/identity/node_modules/tslib/modules/index.js
                node_modules/@azure/identity/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/identity/node_modules/tslib/tslib.es6.js
                node_modules/@azure/identity/node_modules/tslib/tslib.js
                node_modules/@azure/identity/node_modules/tslib/tslib.d.ts
                node_modules/@azure/identity/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/core-lro/node_modules/tslib/README.md
                node_modules/@azure/core-lro/node_modules/tslib/modules/index.js
                node_modules/@azure/core-lro/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/core-lro/node_modules/tslib/tslib.es6.js
                node_modules/@azure/core-lro/node_modules/tslib/tslib.js
                node_modules/@azure/core-lro/node_modules/tslib/tslib.d.ts
                node_modules/@azure/core-lro/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/core-client/node_modules/tslib/README.md
                node_modules/@azure/core-client/node_modules/tslib/modules/index.js
                node_modules/@azure/core-client/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/core-client/node_modules/tslib/tslib.es6.js
                node_modules/@azure/core-client/node_modules/tslib/tslib.js
                node_modules/@azure/core-client/node_modules/tslib/tslib.d.ts
                node_modules/@azure/core-client/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/core-http-compat/node_modules/tslib/README.md
                node_modules/@azure/core-http-compat/node_modules/tslib/modules/index.js
                node_modules/@azure/core-http-compat/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/core-http-compat/node_modules/tslib/tslib.es6.js
                node_modules/@azure/core-http-compat/node_modules/tslib/tslib.js
                node_modules/@azure/core-http-compat/node_modules/tslib/tslib.d.ts
                node_modules/@azure/core-http-compat/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/core-rest-pipeline/node_modules/tslib/README.md
                node_modules/@azure/core-rest-pipeline/node_modules/tslib/modules/index.js
                node_modules/@azure/core-rest-pipeline/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.es6.js
                node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.js
                node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.d.ts
                node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.es6.mjs
                node_modules/@azure/core-paging/node_modules/tslib/README.md
                node_modules/@azure/core-paging/node_modules/tslib/modules/index.js
                node_modules/@azure/core-paging/node_modules/tslib/modules/index.d.ts
                node_modules/@azure/core-paging/node_modules/tslib/tslib.es6.js
                node_modules/@azure/core-paging/node_modules/tslib/tslib.js
                node_modules/@azure/core-paging/node_modules/tslib/tslib.d.ts
                node_modules/@azure/core-paging/node_modules/tslib/tslib.es6.mjs
                node_modules/external-editor/main/errors/CreateFileError.js
                node_modules/external-editor/main/errors/LaunchEditorError.js
                node_modules/external-editor/main/errors/ReadFileError.js
                node_modules/external-editor/main/errors/RemoveFileError.js
                node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
                node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
                node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
                node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
                node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
                node_modules/xmldom/dom.js
                node_modules/@serialport/bindings-cpp/prebuilds/android-arm64/@serialport+bindings-cpp.armv8.node
                node_modules/read-package-up/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/@homebridge/hap-nodejs/node_modules/tslib/README.md
                node_modules/@homebridge/hap-nodejs/node_modules/tslib/modules/index.js
                node_modules/@homebridge/hap-nodejs/node_modules/tslib/modules/index.d.ts
                node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.es6.js
                node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.js
                node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.d.ts
                node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.es6.mjs
                node_modules/@homebridge/ciao/node_modules/tslib/README.md
                node_modules/@homebridge/ciao/node_modules/tslib/modules/index.js
                node_modules/@homebridge/ciao/node_modules/tslib/modules/index.d.ts
                node_modules/@homebridge/ciao/node_modules/tslib/tslib.es6.js
                node_modules/@homebridge/ciao/node_modules/tslib/tslib.js
                node_modules/@homebridge/ciao/node_modules/tslib/tslib.d.ts
                node_modules/@homebridge/ciao/node_modules/tslib/tslib.es6.mjs
                node_modules/syno/definitions/6.x/_full.json
                node_modules/syno/test/browser/js/syno-6.x.min.js
                node_modules/syno/dist/syno-6.x.min.js
                node_modules/syno/dist/syno-5.x.min.js
                node_modules/iobroker.yahka/admin/yahka.admin.js
                node_modules/iobroker.yahka/admin/yahka.admin.js.map
                node_modules/hosted-git-info/git-host.js
                node_modules/winston-seq-updated/lib/index.js
                node_modules/iobroker.vis-2-widgets-gauges/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
                node_modules/worker-timers-worker/node_modules/tslib/README.md
                node_modules/worker-timers-worker/node_modules/tslib/modules/index.js
                node_modules/worker-timers-worker/node_modules/tslib/modules/index.d.ts
                node_modules/worker-timers-worker/node_modules/tslib/tslib.es6.js
                node_modules/worker-timers-worker/node_modules/tslib/tslib.js
                node_modules/worker-timers-worker/node_modules/tslib/tslib.d.ts
                node_modules/worker-timers-worker/node_modules/tslib/tslib.es6.mjs
                node_modules/json2iob/tsconfig.json
                node_modules/worker-factory/node_modules/tslib/README.md
                node_modules/worker-factory/node_modules/tslib/modules/index.js
                node_modules/worker-factory/node_modules/tslib/modules/index.d.ts
                node_modules/worker-factory/node_modules/tslib/tslib.es6.js
                node_modules/worker-factory/node_modules/tslib/tslib.js
                node_modules/worker-factory/node_modules/tslib/tslib.d.ts
                node_modules/worker-factory/node_modules/tslib/tslib.es6.mjs
                node_modules/fast-unique-numbers/node_modules/tslib/README.md
                node_modules/fast-unique-numbers/node_modules/tslib/modules/index.js
                node_modules/fast-unique-numbers/node_modules/tslib/modules/index.d.ts
                node_modules/fast-unique-numbers/node_modules/tslib/tslib.es6.js
                node_modules/fast-unique-numbers/node_modules/tslib/tslib.js
                node_modules/fast-unique-numbers/node_modules/tslib/tslib.d.ts
                node_modules/fast-unique-numbers/node_modules/tslib/tslib.es6.mjs
                node_modules/rrule/node_modules/tslib/README.md
                node_modules/rrule/node_modules/tslib/modules/index.js
                node_modules/rrule/node_modules/tslib/modules/index.d.ts
                node_modules/rrule/node_modules/tslib/tslib.es6.js
                node_modules/rrule/node_modules/tslib/tslib.js
                node_modules/rrule/node_modules/tslib/tslib.d.ts
                node_modules/rrule/node_modules/tslib/tslib.es6.mjs
                node_modules/rrule/dist/es5/rrule.js
                node_modules/rrule/dist/es5/rrule.min.js.map
                node_modules/rrule/dist/esm/callbackiterresult.js
                node_modules/rrule/dist/esm/datetime.js
                node_modules/rrule/dist/esm/rruleset.js
                node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib.min.js
                node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/vuetify.js
                node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/material-components-web.js
                node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
                node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
                node_modules/iobroker.modbus/admin/assets/index-Blv_5nFZ.js
                node_modules/iobroker.material/www/static/js/main.c5478f66.js.map
                node_modules/jszip/tsconfig.json
                node_modules/iobroker.daswetter/admin/assets/index-84bRrRlB.js
                node_modules/node-gyp/lib/find-python.js
                node_modules/iobroker.javascript/admin/plugins/bundle.js
                node_modules/iobroker.javascript/admin/assets/index-dN73sbyQ.js
                node_modules/iobroker.javascript/admin/assets/iobroker_javascript__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-CV1_X-Lf.js
                node_modules/iobroker.javascript/admin/vs/editor/editor.main.js
                node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js
                node_modules/iobroker.javascript/admin/custom/assets/index-BptSiKBK.js
                node_modules/iobroker.javascript/admin/custom/assets/index-BVwMgafs.js
                node_modules/iobroker.javascript/admin/custom/assets/ConfigCustomJavascriptSet__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-KsT5vKjV.js
                node_modules/iobroker.javascript/admin/custom/assets/leaflet-src-k2rCV-Ix.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsyncAction.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsapAction.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsyncScheduler.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsapScheduler.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/QueueAction.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/QueueScheduler.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AnimationFrameScheduler.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/VirtualTimeScheduler.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AnimationFrameAction.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/Action.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/observable/dom/WebSocketSubject.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/observable/ConnectableObservable.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/operators/OperatorSubscriber.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/BehaviorSubject.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/Subscriber.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/AsyncSubject.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/ReplaySubject.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/HotObservable.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/TestScheduler.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/ColdObservable.js
                node_modules/np/node_modules/rxjs/dist/esm5/internal/Subject.js
                node_modules/np/node_modules/rxjs/dist/bundles/rxjs.umd.js.map
                node_modules/np/node_modules/rxjs/dist/bundles/rxjs.umd.min.js.map
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsyncAction.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsapAction.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsyncScheduler.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsapScheduler.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/QueueAction.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/QueueScheduler.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AnimationFrameScheduler.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/VirtualTimeScheduler.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AnimationFrameAction.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/Action.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/observable/dom/WebSocketSubject.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/observable/ConnectableObservable.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/operators/OperatorSubscriber.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/BehaviorSubject.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/Subscriber.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/AsyncSubject.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/ReplaySubject.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/HotObservable.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/TestScheduler.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/ColdObservable.js
                node_modules/np/node_modules/rxjs/dist/cjs/internal/Subject.js
                node_modules/np/node_modules/tslib/README.md
                node_modules/np/node_modules/tslib/modules/index.js
                node_modules/np/node_modules/tslib/modules/index.d.ts
                node_modules/np/node_modules/tslib/tslib.es6.js
                node_modules/np/node_modules/tslib/tslib.js
                node_modules/np/node_modules/tslib/tslib.d.ts
                node_modules/np/node_modules/tslib/tslib.es6.mjs
                node_modules/np/node_modules/type-fest/source/tsconfig-json.d.ts
                node_modules/iobroker.vis-2-widgets-inventwo/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
                node_modules/iobroker.vis-2-widgets-inventwo/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
                node_modules/sinon/pkg/sinon-esm.js
                node_modules/sinon/pkg/sinon-no-sourcemaps.cjs
                node_modules/sinon/pkg/sinon.js
                node_modules/luxon/build/cjs-browser/luxon.js
                node_modules/luxon/build/cjs-browser/luxon.js.map
                node_modules/luxon/build/amd/luxon.js
                node_modules/luxon/build/amd/luxon.js.map
                node_modules/luxon/build/global/luxon.min.js.map
                node_modules/luxon/build/global/luxon.js
                node_modules/luxon/build/global/luxon.js.map
                node_modules/localforage/bower_components/mocha/mocha.js
                node_modules/localforage/dist/localforage.js
                node_modules/localforage/dist/localforage.nopromises.min.js
                node_modules/localforage/dist/localforage.nopromises.js
                node_modules/localforage/dist/localforage.min.js
                node_modules/localforage/build/es5src/localforage.js
                node_modules/localforage/src/localforage.js
                node_modules/iobroker.email/admin/custom/assets/index-ByILBjTr.js
                node_modules/iobroker.email/admin/custom/assets/index-D-vy1JIC.js
                node_modules/iobroker.email/admin/custom/assets/ConfigCustomEmailSet__mf_v__runtimeInit__mf_v__-Bd5Kc7oi.js
                node_modules/iobroker.email/admin/rules/assets/ActionSendEmail__mf_v__runtimeInit__mf_v__-eLULivoH.js
                @tritor
                Und im Log schlägt sich das wie nieder?
                • T tritor
                  @OliverIO
                  Ja da gibt es jede Menge Auflistung.
                  node_modules/prompt/node_modules/winston/lib/winston/container.js
                  node_modules/iobroker.admin/adminWww/static/js/worker-html.js
                  node_modules/iobroker.admin/adminWww/static/js/worker-javascript.js
                  node_modules/iobroker.admin/adminWww/assets/ace-B1WbEy8J.js
                  node_modules/iobroker.admin/adminWww/assets/Objects-CQ1Cgg6L.js
                  node_modules/iobroker.admin/adminWww/assets/leaflet-src-B651YTWC.js
                  node_modules/iobroker.admin/adminWww/assets/index-Cy4zkLZ7.js
                  node_modules/iobroker.admin/adminWww/assets/bootstrap-D0re3WSJ.js
                  node_modules/iobroker.admin/adminWww/assets/index-DA90dn-y.js
                  node_modules/iobroker.admin/admin/custom/assets/index-JHWyZnE9.js
                  node_modules/iobroker.admin/admin/custom/assets/index-BqaC8TTV.js
                  node_modules/iobroker.admin/admin/custom/assets/index-lwTE6AOa.js
                  node_modules/iobroker.admin/admin/custom/assets/index-fHKF7cIy.js
                  node_modules/iobroker.admin/admin/custom/assets/AdminComponentEasyAccessSet__mf_v__runtimeInit__mf_v__-JbSPU0nV.js
                  node_modules/iobroker.admin/admin/custom/assets/index-C2cQRe9d.js
                  node_modules/iobroker.admin/admin/custom/assets/index-DI-4AL4q.js
                  node_modules/iobroker.admin/admin/custom/assets/AdminComponentEasyAccessSet__mf_v__runtimeInit__mf_v__-CbzMf-XP.js
                  node_modules/iobroker.admin/admin/custom/assets/index-Cgl0l3l6.js
                  node_modules/iobroker.admin/admin/custom/assets/index-CcWdaO-A.js
                  node_modules/iobroker.admin/admin/custom/assets/index-BTEHfIqN.js
                  node_modules/iobroker.admin/admin/custom/assets/index-WGNhBVhU.js
                  node_modules/iobroker.admin/admin/custom/assets/index-DsmGf2-7.js
                  node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js
                  node_modules/esprima/dist/esprima.js
                  node_modules/rxjs/_esm5/internal/SubjectSubscription.js
                  node_modules/rxjs/_esm5/internal/scheduler/AsyncAction.js
                  node_modules/rxjs/_esm5/internal/scheduler/AsapAction.js
                  node_modules/rxjs/_esm5/internal/scheduler/AsyncScheduler.js
                  node_modules/rxjs/_esm5/internal/scheduler/AsapScheduler.js
                  node_modules/rxjs/_esm5/internal/scheduler/QueueAction.js
                  node_modules/rxjs/_esm5/internal/scheduler/QueueScheduler.js
                  node_modules/rxjs/_esm5/internal/scheduler/AnimationFrameScheduler.js
                  node_modules/rxjs/_esm5/internal/scheduler/VirtualTimeScheduler.js
                  node_modules/rxjs/_esm5/internal/scheduler/AnimationFrameAction.js
                  node_modules/rxjs/_esm5/internal/scheduler/Action.js
                  node_modules/rxjs/_esm5/internal/observable/zip.js
                  node_modules/rxjs/_esm5/internal/observable/race.js
                  node_modules/rxjs/_esm5/internal/observable/SubscribeOnObservable.js
                  node_modules/rxjs/_esm5/internal/observable/dom/WebSocketSubject.js
                  node_modules/rxjs/_esm5/internal/observable/dom/AjaxObservable.js
                  node_modules/rxjs/_esm5/internal/observable/ConnectableObservable.js
                  node_modules/rxjs/_esm5/internal/observable/combineLatest.js
                  node_modules/rxjs/_esm5/internal/operators/refCount.js
                  node_modules/rxjs/_esm5/internal/operators/expand.js
                  node_modules/rxjs/_esm5/internal/operators/skipUntil.js
                  node_modules/rxjs/_esm5/internal/operators/debounce.js
                  node_modules/rxjs/_esm5/internal/operators/single.js
                  node_modules/rxjs/_esm5/internal/operators/pairwise.js
                  node_modules/rxjs/_esm5/internal/operators/exhaust.js
                  node_modules/rxjs/_esm5/internal/operators/take.js
                  node_modules/rxjs/_esm5/internal/operators/repeat.js
                  node_modules/rxjs/_esm5/internal/operators/sequenceEqual.js
                  node_modules/rxjs/_esm5/internal/operators/skipLast.js
                  node_modules/rxjs/_esm5/internal/operators/audit.js
                  node_modules/rxjs/_esm5/internal/operators/map.js
                  node_modules/rxjs/_esm5/internal/operators/every.js
                  node_modules/rxjs/_esm5/internal/operators/throttleTime.js
                  node_modules/rxjs/_esm5/internal/operators/takeWhile.js
                  node_modules/rxjs/_esm5/internal/operators/ignoreElements.js
                  node_modules/rxjs/_esm5/internal/operators/delay.js
                  node_modules/rxjs/_esm5/internal/operators/takeLast.js
                  node_modules/rxjs/_esm5/internal/operators/bufferWhen.js
                  node_modules/rxjs/_esm5/internal/operators/skip.js
                  node_modules/rxjs/_esm5/internal/operators/windowToggle.js
                  node_modules/rxjs/_esm5/internal/operators/mergeScan.js
                  node_modules/rxjs/_esm5/internal/operators/count.js
                  node_modules/rxjs/_esm5/internal/operators/windowCount.js
                  node_modules/rxjs/_esm5/internal/operators/buffer.js
                  node_modules/rxjs/_esm5/internal/operators/throttle.js
                  node_modules/rxjs/_esm5/internal/operators/sampleTime.js
                  node_modules/rxjs/_esm5/internal/operators/skipWhile.js
                  node_modules/rxjs/_esm5/internal/operators/takeUntil.js
                  node_modules/rxjs/_esm5/internal/operators/isEmpty.js
                  node_modules/rxjs/_esm5/internal/operators/bufferToggle.js
                  node_modules/rxjs/_esm5/internal/operators/defaultIfEmpty.js
                  node_modules/rxjs/_esm5/internal/operators/tap.js
                  node_modules/rxjs/_esm5/internal/operators/distinct.js
                  node_modules/rxjs/_esm5/internal/operators/groupBy.js
                  node_modules/rxjs/_esm5/internal/operators/catchError.js
                  node_modules/rxjs/_esm5/internal/operators/find.js
                  node_modules/rxjs/_esm5/internal/operators/bufferCount.js
                  node_modules/rxjs/_esm5/internal/operators/timeoutWith.js
                  node_modules/rxjs/_esm5/internal/operators/throwIfEmpty.js
                  node_modules/rxjs/_esm5/internal/operators/repeatWhen.js
                  node_modules/rxjs/_esm5/internal/operators/withLatestFrom.js
                  node_modules/rxjs/_esm5/internal/operators/filter.js
                  node_modules/rxjs/_esm5/internal/operators/exhaustMap.js
                  node_modules/rxjs/_esm5/internal/operators/delayWhen.js
                  node_modules/rxjs/_esm5/internal/operators/dematerialize.js
                  node_modules/rxjs/_esm5/internal/operators/retry.js
                  node_modules/rxjs/_esm5/internal/operators/materialize.js
                  node_modules/rxjs/_esm5/internal/operators/retryWhen.js
                  node_modules/rxjs/_esm5/internal/operators/onErrorResumeNext.js
                  node_modules/rxjs/_esm5/internal/operators/mapTo.js
                  node_modules/rxjs/_esm5/internal/operators/bufferTime.js
                  node_modules/rxjs/_esm5/internal/operators/sample.js
                  node_modules/rxjs/_esm5/internal/operators/scan.js
                  node_modules/rxjs/_esm5/internal/operators/mergeMap.js
                  node_modules/rxjs/_esm5/internal/operators/switchMap.js
                  node_modules/rxjs/_esm5/internal/operators/window.js
                  node_modules/rxjs/_esm5/internal/operators/debounceTime.js
                  node_modules/rxjs/_esm5/internal/operators/windowTime.js
                  node_modules/rxjs/_esm5/internal/operators/windowWhen.js
                  node_modules/rxjs/_esm5/internal/operators/finalize.js
                  node_modules/rxjs/_esm5/internal/operators/distinctUntilChanged.js
                  node_modules/rxjs/_esm5/internal/operators/observeOn.js
                  node_modules/rxjs/_esm5/internal/BehaviorSubject.js
                  node_modules/rxjs/_esm5/internal/OuterSubscriber.js
                  node_modules/rxjs/_esm5/internal/Subscriber.js
                  node_modules/rxjs/_esm5/internal/innerSubscribe.js
                  node_modules/rxjs/_esm5/internal/AsyncSubject.js
                  node_modules/rxjs/_esm5/internal/ReplaySubject.js
                  node_modules/rxjs/_esm5/internal/testing/HotObservable.js
                  node_modules/rxjs/_esm5/internal/testing/TestScheduler.js
                  node_modules/rxjs/_esm5/internal/testing/ColdObservable.js
                  node_modules/rxjs/_esm5/internal/InnerSubscriber.js
                  node_modules/rxjs/_esm5/internal/Subject.js
                  node_modules/rxjs/internal/SubjectSubscription.js
                  node_modules/rxjs/internal/scheduler/AsyncAction.js
                  node_modules/rxjs/internal/scheduler/AsapAction.js
                  node_modules/rxjs/internal/scheduler/AsyncScheduler.js
                  node_modules/rxjs/internal/scheduler/AsapScheduler.js
                  node_modules/rxjs/internal/scheduler/QueueAction.js
                  node_modules/rxjs/internal/scheduler/QueueScheduler.js
                  node_modules/rxjs/internal/scheduler/AnimationFrameScheduler.js
                  node_modules/rxjs/internal/scheduler/VirtualTimeScheduler.js
                  node_modules/rxjs/internal/scheduler/AnimationFrameAction.js
                  node_modules/rxjs/internal/scheduler/Action.js
                  node_modules/rxjs/internal/observable/zip.js
                  node_modules/rxjs/internal/observable/race.js
                  node_modules/rxjs/internal/observable/SubscribeOnObservable.js
                  node_modules/rxjs/internal/observable/dom/WebSocketSubject.js
                  node_modules/rxjs/internal/observable/dom/AjaxObservable.js
                  node_modules/rxjs/internal/observable/ConnectableObservable.js
                  node_modules/rxjs/internal/observable/combineLatest.js
                  node_modules/rxjs/internal/operators/refCount.js
                  node_modules/rxjs/internal/operators/expand.js
                  node_modules/rxjs/internal/operators/skipUntil.js
                  node_modules/rxjs/internal/operators/debounce.js
                  node_modules/rxjs/internal/operators/single.js
                  node_modules/rxjs/internal/operators/pairwise.js
                  node_modules/rxjs/internal/operators/exhaust.js
                  node_modules/rxjs/internal/operators/take.js
                  node_modules/rxjs/internal/operators/repeat.js
                  node_modules/rxjs/internal/operators/sequenceEqual.js
                  node_modules/rxjs/internal/operators/skipLast.js
                  node_modules/rxjs/internal/operators/audit.js
                  node_modules/rxjs/internal/operators/map.js
                  node_modules/rxjs/internal/operators/every.js
                  node_modules/rxjs/internal/operators/throttleTime.js
                  node_modules/rxjs/internal/operators/takeWhile.js
                  node_modules/rxjs/internal/operators/ignoreElements.js
                  node_modules/rxjs/internal/operators/delay.js
                  node_modules/rxjs/internal/operators/takeLast.js
                  node_modules/rxjs/internal/operators/bufferWhen.js
                  node_modules/rxjs/internal/operators/skip.js
                  node_modules/rxjs/internal/operators/windowToggle.js
                  node_modules/rxjs/internal/operators/mergeScan.js
                  node_modules/rxjs/internal/operators/count.js
                  node_modules/rxjs/internal/operators/windowCount.js
                  node_modules/rxjs/internal/operators/buffer.js
                  node_modules/rxjs/internal/operators/throttle.js
                  node_modules/rxjs/internal/operators/sampleTime.js
                  node_modules/rxjs/internal/operators/skipWhile.js
                  node_modules/rxjs/internal/operators/takeUntil.js
                  node_modules/rxjs/internal/operators/isEmpty.js
                  node_modules/rxjs/internal/operators/bufferToggle.js
                  node_modules/rxjs/internal/operators/defaultIfEmpty.js
                  node_modules/rxjs/internal/operators/tap.js
                  node_modules/rxjs/internal/operators/distinct.js
                  node_modules/rxjs/internal/operators/groupBy.js
                  node_modules/rxjs/internal/operators/catchError.js
                  node_modules/rxjs/internal/operators/find.js
                  node_modules/rxjs/internal/operators/bufferCount.js
                  node_modules/rxjs/internal/operators/timeoutWith.js
                  node_modules/rxjs/internal/operators/throwIfEmpty.js
                  node_modules/rxjs/internal/operators/repeatWhen.js
                  node_modules/rxjs/internal/operators/withLatestFrom.js
                  node_modules/rxjs/internal/operators/filter.js
                  node_modules/rxjs/internal/operators/exhaustMap.js
                  node_modules/rxjs/internal/operators/delayWhen.js
                  node_modules/rxjs/internal/operators/dematerialize.js
                  node_modules/rxjs/internal/operators/retry.js
                  node_modules/rxjs/internal/operators/materialize.js
                  node_modules/rxjs/internal/operators/retryWhen.js
                  node_modules/rxjs/internal/operators/onErrorResumeNext.js
                  node_modules/rxjs/internal/operators/mapTo.js
                  node_modules/rxjs/internal/operators/bufferTime.js
                  node_modules/rxjs/internal/operators/sample.js
                  node_modules/rxjs/internal/operators/scan.js
                  node_modules/rxjs/internal/operators/mergeMap.js
                  node_modules/rxjs/internal/operators/switchMap.js
                  node_modules/rxjs/internal/operators/window.js
                  node_modules/rxjs/internal/operators/debounceTime.js
                  node_modules/rxjs/internal/operators/windowTime.js
                  node_modules/rxjs/internal/operators/windowWhen.js
                  node_modules/rxjs/internal/operators/finalize.js
                  node_modules/rxjs/internal/operators/distinctUntilChanged.js
                  node_modules/rxjs/internal/operators/observeOn.js
                  node_modules/rxjs/internal/BehaviorSubject.js
                  node_modules/rxjs/internal/OuterSubscriber.js
                  node_modules/rxjs/internal/Subscriber.js
                  node_modules/rxjs/internal/innerSubscribe.js
                  node_modules/rxjs/internal/AsyncSubject.js
                  node_modules/rxjs/internal/ReplaySubject.js
                  node_modules/rxjs/internal/testing/HotObservable.js
                  node_modules/rxjs/internal/testing/TestScheduler.js
                  node_modules/rxjs/internal/testing/ColdObservable.js
                  node_modules/rxjs/internal/InnerSubscriber.js
                  node_modules/rxjs/internal/Subject.js
                  node_modules/rxjs/bundles/rxjs.umd.js.map
                  node_modules/rxjs/bundles/rxjs.umd.min.js.map
                  node_modules/iobroker.scenes/admin/assets/index-B_g9fImg.js
                  node_modules/broker-factory/node_modules/tslib/README.md
                  node_modules/broker-factory/node_modules/tslib/modules/index.js
                  node_modules/broker-factory/node_modules/tslib/modules/index.d.ts
                  node_modules/broker-factory/node_modules/tslib/tslib.es6.js
                  node_modules/broker-factory/node_modules/tslib/tslib.js
                  node_modules/broker-factory/node_modules/tslib/tslib.d.ts
                  node_modules/broker-factory/node_modules/tslib/tslib.es6.mjs
                  node_modules/express/History.md
                  node_modules/iobroker.devices/www/assets/index-C8dcoZB8.js
                  node_modules/iobroker.devices/admin/assets/index-SJof8gXx.js
                  node_modules/acorn-globals/node_modules/acorn/dist/acorn.js
                  node_modules/acorn-globals/node_modules/acorn/dist/acorn_loose.js
                  node_modules/acorn-globals/node_modules/acorn/src/statement.js
                  node_modules/acorn-globals/node_modules/acorn/src/loose/statement.js
                  node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
                  node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
                  node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
                  node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
                  node_modules/iobroker.fullcalendar/admin/static/js/main.c13d3761.js
                  node_modules/iobroker.fullcalendar/admin/static/js/main.c13d3761.js.map
                  node_modules/dot-prop/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/dropbox-v2-api/dist/api.json
                  node_modules/dropbox-v2-api/src/api.json
                  node_modules/boxen/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/web-streams-polyfill/dist/ponyfill.mjs.map
                  node_modules/web-streams-polyfill/dist/ponyfill.js.map
                  node_modules/web-streams-polyfill/dist/ponyfill.es6.mjs.map
                  node_modules/web-streams-polyfill/dist/polyfill.min.js.map
                  node_modules/web-streams-polyfill/dist/polyfill.js.map
                  node_modules/web-streams-polyfill/dist/polyfill.mjs.map
                  node_modules/web-streams-polyfill/dist/polyfill.es6.mjs.map
                  node_modules/web-streams-polyfill/dist/ponyfill.es6.js.map
                  node_modules/web-streams-polyfill/dist/polyfill.es6.min.js.map
                  node_modules/web-streams-polyfill/dist/polyfill.es6.js.map
                  node_modules/worker-timers-broker/node_modules/tslib/README.md
                  node_modules/worker-timers-broker/node_modules/tslib/modules/index.js
                  node_modules/worker-timers-broker/node_modules/tslib/modules/index.d.ts
                  node_modules/worker-timers-broker/node_modules/tslib/tslib.es6.js
                  node_modules/worker-timers-broker/node_modules/tslib/tslib.js
                  node_modules/worker-timers-broker/node_modules/tslib/tslib.d.ts
                  node_modules/worker-timers-broker/node_modules/tslib/tslib.es6.mjs
                  node_modules/iobroker.vis/www/index.html
                  node_modules/iobroker.vis/www/widgets/basic.html
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/src_Components_VacuumIcon_js-src_Components_WindowClosed_js-node_modules_react-circular-slide-54a955.34b175bb.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_leaflet_dist_leaflet_css-node_modules_leaflet_dist_images_marker-icon-2x-281382.49131c79.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.9a6346f3.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.ef43cd96.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react_jsx-runtime_js-node_modules_leaflet_dist_leaflet_css-node_modules_-5c5561.c33b1195.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.199f0b4e.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.3c144320.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.837c9082.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react_jsx-runtime_js-node_modules_leaflet_dist_leaflet_css-node_modules_-5c5561.c33b1195.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.3ebf8200.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b24a2b7b.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_legend_install_js.432b0c40.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react-circular-slider-svg_dist_index_js-node_modules_react_cjs_react-jsx-6278e5.433d1581.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/src_Generic_jsx-node_modules_react-circular-slider-svg_dist_index_js.f186cf20.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.ef43cd96.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.0cbfea69.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b80a2194.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.5884108b.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.08cf7e1a.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.5884108b.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.5d75fa27.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b80a2194.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_legend_install_js.a18746ef.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__mf_v__runtimeInit__mf_v__-mPD03Tof.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-bcz2UOY-.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/index-DBeNUnty.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/Map-DvvTKot1.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
                  node_modules/iobroker.vis/www/widgets/materialdesign/lib.min.js
                  node_modules/iobroker.vis/www/widgets/materialdesign/lib/vuetify.js
                  node_modules/iobroker.vis/www/widgets/materialdesign/lib/material-components-web.js
                  node_modules/iobroker.vis/www/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
                  node_modules/iobroker.vis/www/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.ff34318e.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.f78ceb8d.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.b2dda7e4.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-battery-gauge_dist_react-battery-gauge_esm_js.438236c2.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-battery-gauge_dist_react-battery-gauge_esm_js.81e383f5.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-1RJxOR8B.js
                  node_modules/iobroker.vis/www/widgets/openweathermap/assets/index-DnuTl29g.js
                  node_modules/iobroker.vis/www/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_esm_index_js.49c59391.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_styled_js.25c617b0.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-8c1e82.52c5b0a7.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_isMuiElement_isMuiElement-90f327.68e2ebbd.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_index_js.6f996889.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.b58e6a51.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-8c1e82.52c5b0a7.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.a10fb2cd.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_index_js.6f996889.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js-n-287313.6a72939a.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.0fdc2efe.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.54021824.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.22192a38.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_styleFunctionSx_e-646437.480ef8e8.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_ZoomOutMap_js-node_modules_mui_material_Fab_Fab_js-no-238edc.c17f49ad.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_esm_index_js.4a02bfba.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_ZoomOutMap_js-node_modules_mui_material_Fab_Fab_js-no-de51fd.47eda6f0.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.7fc5de73.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_esm_isMuiElement_isMuiEle-37774c.5027f981.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.e83bdd95.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.7fc5de73.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.97b3e2d1.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.1749f755.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_esm_isMuiElement_isMuiEle-37774c.5027f981.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js-node_modules_mui_system_esm_u-30631c.5a5082ed.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.3ed26143.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Checkbox_Checkbox_js-node_modules_mui_material_FormControl_-ab667d.80eee493.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_createTheme_creat-8e35a0.19e0cbc7.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-09395c.bf487e67.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js-n-287313.6a72939a.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_material_styles_Them-0bf85c.de23cbfb.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.97b3e2d1.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_styled_js.dae67faa.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_x-date-pickers_TimePicker_TimePicker_js-node_modules_babel_runtime_h-8a0c27.799842e9.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_x-date-pickers_AdapterDayjs_Adapte-b79734.de09a47b.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-5ae56a.fbe8964c.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-66a30d.53923d06.chunk.js
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-66a30d.53923d06.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_createTheme_creat-c54a24.aedd89eb.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-f5912f.292616a4.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_x-date-pickers_AdapterDayjs_Adapte-c0e24c.44cc9956.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.48ced1a3.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b33a19f6.chunk.js.map
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/static/js/vendors-node_modules_mui_system_esm_index_js.2f5bd81f.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/static/js/vendors-node_modules_mui_material_index_js.108fbfef.chunk.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-CsZQ1K9c.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-BJeC_1Nc.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-4dZ_faDJ.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-CJ-kxqUy.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-B5RqNgEg.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-COK1nOKA.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BZKNvirX.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-DpCJnELL.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-Bp2scStG.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-Bk5B5ET5.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-B6mUFPf4.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-C-Jo2qj7.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-2uL955SU.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-CBbfFHA5.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-C5a4dcu-.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BlUXZP4n.js
                  node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
                  node_modules/iobroker.vis/www/edit.html
                  node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js
                  node_modules/iobroker.vis/www/lib/ace/worker-html.js
                  node_modules/eventsource/example/eventsource-polyfill.js
                  node_modules/@js-sdsl/ordered-map/dist/esm/index.js
                  node_modules/@js-sdsl/ordered-map/dist/esm/index.js.map
                  node_modules/@js-sdsl/ordered-map/dist/umd/ordered-map.js
                  node_modules/@js-sdsl/ordered-map/dist/umd/ordered-map.min.js.map
                  node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.js
                  node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.min.js.map
                  node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.js.map
                  node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.msgpack.min.js.map
                  node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.min.js.map
                  node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.js.map
                  node_modules/nise/nise.js
                  node_modules/@iobroker/types/build/types.d.ts
                  node_modules/@iobroker/dev-server/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/@iobroker/js-controller-adapter/build/esm/lib/adapter/adapter.d.ts
                  node_modules/@iobroker/js-controller-adapter/build/esm/lib/adapter/adapter.js
                  node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.d.ts
                  node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js.map
                  node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.d.ts
                  node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js
                  node_modules/@iobroker/db-objects-redis/build/cjs/lib/objects/objectsInRedisClient.d.ts
                  node_modules/@iobroker/db-objects-redis/build/cjs/lib/objects/objectsInRedisClient.js.map
                  node_modules/iobroker.zigbee2mqtt/node_modules/tslib/README.md
                  node_modules/iobroker.zigbee2mqtt/node_modules/tslib/modules/index.js
                  node_modules/iobroker.zigbee2mqtt/node_modules/tslib/modules/index.d.ts
                  node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.es6.js
                  node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.js
                  node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.d.ts
                  node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.es6.mjs
                  node_modules/iobroker.reolink/node_modules/tslib/README.md
                  node_modules/iobroker.reolink/node_modules/tslib/modules/index.js
                  node_modules/iobroker.reolink/node_modules/tslib/modules/index.d.ts
                  node_modules/iobroker.reolink/node_modules/tslib/tslib.es6.js
                  node_modules/iobroker.reolink/node_modules/tslib/tslib.js
                  node_modules/iobroker.reolink/node_modules/tslib/tslib.d.ts
                  node_modules/iobroker.reolink/node_modules/tslib/tslib.es6.mjs
                  node_modules/xml2js/lib/xml2js.bc.js
                  node_modules/iobroker.wlanthermo-nano/admin/build/index.js
                  node_modules/iobroker.wlanthermo-nano/admin/build/index.js.map
                  node_modules/nedb/browser-version/out/nedb.min.js
                  node_modules/nedb/browser-version/out/nedb.js
                  node_modules/nedb/browser-version/test/localforage.js
                  node_modules/iobroker.vis-2-widgets-energy/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
                  node_modules/@babel/runtime/helpers/extends.js
                  node_modules/@babel/runtime/helpers/esm/extends.js
                  node_modules/eslint-plugin-node/lib/rules/no-deprecated-api.js
                  node_modules/terminal-link/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/p-memoize/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/iobroker.backitup/node_modules/tslib/README.md
                  node_modules/iobroker.backitup/node_modules/tslib/modules/index.js
                  node_modules/iobroker.backitup/node_modules/tslib/modules/index.d.ts
                  node_modules/iobroker.backitup/node_modules/tslib/tslib.es6.js
                  node_modules/iobroker.backitup/node_modules/tslib/tslib.js
                  node_modules/iobroker.backitup/node_modules/tslib/tslib.d.ts
                  node_modules/iobroker.backitup/node_modules/tslib/tslib.es6.mjs
                  node_modules/iobroker.backitup/admin/assets/index-BeQV_TGa.js
                  node_modules/iobroker.backitup/admin/custom/assets/index-CHFaRedm.js
                  node_modules/iobroker.backitup/admin/custom/assets/index-Ba6zELes.js
                  node_modules/iobroker.backitup/admin/custom/assets/ConfigCustomBackItUpSet__loadShare___mf_0_mui_mf_1_material__loadShare__.js-DqH6EEuz.js
                  node_modules/iobroker.discovery/node_modules/@serialport/bindings-cpp/prebuilds/android-arm64/node.napi.armv8.node
                  node_modules/iobroker.discovery/node_modules/node-addon-api/napi-inl.h
                  node_modules/sqlite3/node_modules/node-addon-api/napi-inl.h
                  node_modules/sqlite3/build/Release/node_sqlite3.node
                  node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.msgpack.min.js.map
                  node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.min.js.map
                  node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.js.map
                  node_modules/node-rest-client/lib/node-rest-client.js
                  node_modules/@img/sharp-linux-x64/lib/sharp-linux-x64.node
                  node_modules/@img/sharp-linuxmusl-x64/lib/sharp-linuxmusl-x64.node
                  node_modules/@img/sharp-libvips-linuxmusl-x64/lib/libvips-cpp.so.42
                  node_modules/@img/sharp-libvips-linux-x64/lib/libvips-cpp.so.42
                  node_modules/js-sdsl/dist/esm/container/TreeContainer/OrderedSet.js.map
                  node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/index.js
                  node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/index.js.map
                  node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeIterator.js.map
                  node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeNode.js
                  node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeNode.js.map
                  node_modules/js-sdsl/dist/esm/container/TreeContainer/OrderedMap.js.map
                  node_modules/js-sdsl/dist/esm/container/OtherContainer/Queue.js
                  node_modules/js-sdsl/dist/esm/container/OtherContainer/PriorityQueue.js.map
                  node_modules/js-sdsl/dist/esm/container/OtherContainer/Queue.js.map
                  node_modules/js-sdsl/dist/esm/container/OtherContainer/Stack.js.map
                  node_modules/js-sdsl/dist/esm/container/ContainerBase/index.js
                  node_modules/js-sdsl/dist/esm/container/ContainerBase/index.js.map
                  node_modules/js-sdsl/dist/esm/container/HashContainer/Base/index.js
                  node_modules/js-sdsl/dist/esm/container/HashContainer/Base/index.js.map
                  node_modules/js-sdsl/dist/esm/container/HashContainer/HashSet.js
                  node_modules/js-sdsl/dist/esm/container/HashContainer/HashMap.js.map
                  node_modules/js-sdsl/dist/esm/container/HashContainer/HashSet.js.map
                  node_modules/js-sdsl/dist/esm/container/SequentialContainer/Deque.js
                  node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/RandomIterator.js.map
                  node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/index.js
                  node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/index.js.map
                  node_modules/js-sdsl/dist/esm/container/SequentialContainer/Deque.js.map
                  node_modules/js-sdsl/dist/esm/container/SequentialContainer/Vector.js
                  node_modules/js-sdsl/dist/esm/container/SequentialContainer/LinkList.js.map
                  node_modules/js-sdsl/dist/esm/container/SequentialContainer/Vector.js.map
                  node_modules/js-sdsl/dist/umd/js-sdsl.js
                  node_modules/js-sdsl/dist/umd/js-sdsl.min.js.map
                  node_modules/iobroker.frigate/node_modules/tslib/README.md
                  node_modules/iobroker.frigate/node_modules/tslib/modules/index.js
                  node_modules/iobroker.frigate/node_modules/tslib/modules/index.d.ts
                  node_modules/iobroker.frigate/node_modules/tslib/tslib.es6.js
                  node_modules/iobroker.frigate/node_modules/tslib/tslib.js
                  node_modules/iobroker.frigate/node_modules/tslib/tslib.d.ts
                  node_modules/iobroker.frigate/node_modules/tslib/tslib.es6.mjs
                  node_modules/jsdom/node_modules/acorn/dist/acorn.js
                  node_modules/jsdom/node_modules/acorn/dist/acorn_loose.js
                  node_modules/jsdom/node_modules/acorn/src/statement.js
                  node_modules/jsdom/node_modules/acorn/src/loose/statement.js
                  node_modules/@opentelemetry/instrumentation/build/esm/platform/browser/instrumentation.js
                  node_modules/@opentelemetry/instrumentation/build/esm/platform/node/instrumentation.js
                  node_modules/@opentelemetry/api/build/esm/metrics/NoopMeter.js
                  node_modules/@opentelemetry/sdk-trace-base/build/esm/platform/browser/export/BatchSpanProcessor.js
                  node_modules/@opentelemetry/sdk-trace-base/build/esm/platform/node/export/BatchSpanProcessor.js
                  node_modules/@opentelemetry/core/build/esm/utils/timeout.js
                  node_modules/mocha/mocha.js
                  node_modules/ajv/README.md
                  node_modules/fast-glob/README.md
                  node_modules/globals/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/date-fns/package.json
                  node_modules/jsx-ast-utils/lib/values/index.js
                  node_modules/jsx-ast-utils/lib/values/expressions/index.js
                  node_modules/jsx-ast-utils/lib/values/expressions/ObjectExpression.js
                  node_modules/jsx-ast-utils/lib/getProp.js
                  node_modules/bs-recipes/recipes/webpack.typescript.react/app/dist/bundle.js
                  node_modules/browser-sync-client/dist/index.js
                  node_modules/http-proxy/lib/http-proxy/index.js
                  node_modules/http-proxy/lib/http-proxy/common.js
                  node_modules/standard/node_modules/acorn/dist/acorn.mjs.map
                  node_modules/standard/node_modules/acorn/dist/acorn.d.ts
                  node_modules/standard/node_modules/acorn/dist/acorn.js.map
                  node_modules/iobroker.vis-2/www/widgets.html
                  node_modules/iobroker.vis-2/www/widgets/basic.html
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
                  node_modules/iobroker.vis-2/www/widgets/materialdesign/lib.min.js
                  node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/vuetify.js
                  node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/material-components-web.js
                  node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
                  node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
                  node_modules/iobroker.vis-2/www/widgets/openweathermap/assets/index-DnuTl29g.js
                  node_modules/iobroker.vis-2/www/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
                  node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
                  node_modules/iobroker.vis-2/www/assets/createStyled-CtLRJdF1.js
                  node_modules/iobroker.vis-2/www/assets/index-D_qqioAY.js.map
                  node_modules/iobroker.vis-2/www/assets/index-BRd7FNtl.js
                  node_modules/iobroker.vis-2/www/assets/index-CrLrNq4s.js
                  node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-B8Z0SsW4.js.map
                  node_modules/iobroker.vis-2/www/assets/Dialog-DElqR5zv.js.map
                  node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Dt1au33l.js
                  node_modules/iobroker.vis-2/www/assets/Dialog-Dgkz1L-r.js
                  node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Dt1au33l.js.map
                  node_modules/iobroker.vis-2/www/assets/createStyled-BvULSPVR.js.map
                  node_modules/iobroker.vis-2/www/assets/index-BGo51MQZ.js
                  node_modules/iobroker.vis-2/www/assets/index-DqJdyjgH.js.map
                  node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-y8HJH6Vp.js
                  node_modules/iobroker.vis-2/www/assets/Box-Bl3kq-x-.js.map
                  node_modules/iobroker.vis-2/www/assets/index-BGhFZJYV.js.map
                  node_modules/iobroker.vis-2/www/assets/assertThisInitialized-DtkDSj7h.js.map
                  node_modules/iobroker.vis-2/www/assets/Dialog-Dgkz1L-r.js.map
                  node_modules/iobroker.vis-2/www/assets/index-CrLrNq4s.js.map
                  node_modules/iobroker.vis-2/www/assets/index-CzkXf0rM.js.map
                  node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Zvkdie3d.js
                  node_modules/iobroker.vis-2/www/assets/assertThisInitialized-DFQXnDE3.js.map
                  node_modules/iobroker.vis-2/www/assets/index-BRd7FNtl.js.map
                  node_modules/iobroker.vis-2/www/assets/index-BGo51MQZ.js.map
                  node_modules/iobroker.vis-2/www/assets/index-BTDdCqea.js
                  node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Zvkdie3d.js.map
                  node_modules/iobroker.vis-2/www/assets/createStyled-CtLRJdF1.js.map
                  node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-y8HJH6Vp.js.map
                  node_modules/iobroker.vis-2/www/assets/visWidgetsCatalog-D4OT0wlf.js.map
                  node_modules/iobroker.vis-2/www/assets/index-B2JJPlmn.js.map
                  node_modules/iobroker.vis-2/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js
                  node_modules/worker-timers/node_modules/tslib/README.md
                  node_modules/worker-timers/node_modules/tslib/modules/index.js
                  node_modules/worker-timers/node_modules/tslib/modules/index.d.ts
                  node_modules/worker-timers/node_modules/tslib/tslib.es6.js
                  node_modules/worker-timers/node_modules/tslib/tslib.js
                  node_modules/worker-timers/node_modules/tslib/tslib.d.ts
                  node_modules/worker-timers/node_modules/tslib/tslib.es6.mjs
                  node_modules/acorn/dist/acorn.d.mts
                  node_modules/iobroker.openweathermap/widgets/openweathermap/assets/index-DnuTl29g.js
                  node_modules/iobroker.openweathermap/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
                  node_modules/prettier/plugins/babel.mjs
                  node_modules/prettier/plugins/flow.mjs
                  node_modules/prettier/plugins/acorn.js
                  node_modules/prettier/plugins/typescript.mjs
                  node_modules/prettier/plugins/typescript.js
                  node_modules/prettier/plugins/acorn.mjs
                  node_modules/prettier/plugins/flow.js
                  node_modules/prettier/plugins/babel.js
                  node_modules/prettier/internal/experimental-cli.mjs
                  node_modules/core-util-is/float.patch
                  node_modules/new-github-release-url/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/iobroker.ping/admin/custom/assets/index-D8RJ5veu.js
                  node_modules/iobroker.ping/admin/custom/assets/index-CbxD1KHt.js
                  node_modules/typescript/lib/pl/diagnosticMessages.generated.json
                  node_modules/typescript/lib/ja/diagnosticMessages.generated.json
                  node_modules/typescript/lib/it/diagnosticMessages.generated.json
                  node_modules/typescript/lib/ko/diagnosticMessages.generated.json
                  node_modules/typescript/lib/ru/diagnosticMessages.generated.json
                  node_modules/typescript/lib/zh-cn/diagnosticMessages.generated.json
                  node_modules/typescript/lib/cs/diagnosticMessages.generated.json
                  node_modules/typescript/lib/de/diagnosticMessages.generated.json
                  node_modules/typescript/lib/fr/diagnosticMessages.generated.json
                  node_modules/typescript/lib/_tsc.js
                  node_modules/typescript/lib/typescript.js
                  node_modules/typescript/lib/zh-tw/diagnosticMessages.generated.json
                  node_modules/typescript/lib/tr/diagnosticMessages.generated.json
                  node_modules/typescript/lib/es/diagnosticMessages.generated.json
                  node_modules/typescript/lib/pt-br/diagnosticMessages.generated.json
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
                  node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
                  node_modules/canvas/build/Release/libpango-1.0.so.0
                  node_modules/canvas/build/Release/canvas.node
                  node_modules/canvas/build/Release/libharfbuzz.so.0
                  node_modules/canvas/build/Release/libcairo.so.2
                  node_modules/canvas/build/Release/libcairo-gobject.so.2
                  node_modules/canvas/build/Release/librsvg-2.so.2
                  node_modules/canvas/build/Release/libglib-2.0.so.0
                  node_modules/canvas/build/Release/obj.target/canvas.node
                  node_modules/canvas/build/Release/obj.target/canvas/src/CanvasRenderingContext2d.o
                  node_modules/canvas/build/Release/libgio-2.0.so.0
                  node_modules/canvas/src/CanvasRenderingContext2d.cc
                  node_modules/canvas/src/CanvasRenderingContext2d.cc.orig
                  node_modules/request/CHANGELOG.md
                  node_modules/swagger-ui-dist/swagger-ui-standalone-preset.js
                  node_modules/swagger-ui-dist/swagger-ui.js.map
                  node_modules/swagger-ui-dist/swagger-ui-es-bundle-core.js
                  node_modules/swagger-ui-dist/swagger-ui-bundle.js.map
                  node_modules/swagger-ui-dist/swagger-ui-es-bundle.js
                  node_modules/swagger-ui-dist/swagger-ui-es-bundle-core.js.map
                  node_modules/swagger-ui-dist/swagger-ui-es-bundle.js.map
                  node_modules/swagger-ui-dist/swagger-ui-standalone-preset.js.map
                  node_modules/@azure/keyvault-keys/node_modules/tslib/README.md
                  node_modules/@azure/keyvault-keys/node_modules/tslib/modules/index.js
                  node_modules/@azure/keyvault-keys/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.js
                  node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/core-tracing/node_modules/tslib/README.md
                  node_modules/@azure/core-tracing/node_modules/tslib/modules/index.js
                  node_modules/@azure/core-tracing/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/core-tracing/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/core-tracing/node_modules/tslib/tslib.js
                  node_modules/@azure/core-tracing/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/core-tracing/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/abort-controller/node_modules/tslib/README.md
                  node_modules/@azure/abort-controller/node_modules/tslib/modules/index.js
                  node_modules/@azure/abort-controller/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/abort-controller/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/abort-controller/node_modules/tslib/tslib.js
                  node_modules/@azure/abort-controller/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/abort-controller/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/core-auth/node_modules/tslib/README.md
                  node_modules/@azure/core-auth/node_modules/tslib/modules/index.js
                  node_modules/@azure/core-auth/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/core-auth/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/core-auth/node_modules/tslib/tslib.js
                  node_modules/@azure/core-auth/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/core-auth/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/core-util/node_modules/tslib/README.md
                  node_modules/@azure/core-util/node_modules/tslib/modules/index.js
                  node_modules/@azure/core-util/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/core-util/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/core-util/node_modules/tslib/tslib.js
                  node_modules/@azure/core-util/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/core-util/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/logger/node_modules/tslib/README.md
                  node_modules/@azure/logger/node_modules/tslib/modules/index.js
                  node_modules/@azure/logger/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/logger/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/logger/node_modules/tslib/tslib.js
                  node_modules/@azure/logger/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/logger/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/identity/node_modules/tslib/README.md
                  node_modules/@azure/identity/node_modules/tslib/modules/index.js
                  node_modules/@azure/identity/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/identity/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/identity/node_modules/tslib/tslib.js
                  node_modules/@azure/identity/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/identity/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/core-lro/node_modules/tslib/README.md
                  node_modules/@azure/core-lro/node_modules/tslib/modules/index.js
                  node_modules/@azure/core-lro/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/core-lro/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/core-lro/node_modules/tslib/tslib.js
                  node_modules/@azure/core-lro/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/core-lro/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/core-client/node_modules/tslib/README.md
                  node_modules/@azure/core-client/node_modules/tslib/modules/index.js
                  node_modules/@azure/core-client/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/core-client/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/core-client/node_modules/tslib/tslib.js
                  node_modules/@azure/core-client/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/core-client/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/core-http-compat/node_modules/tslib/README.md
                  node_modules/@azure/core-http-compat/node_modules/tslib/modules/index.js
                  node_modules/@azure/core-http-compat/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/core-http-compat/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/core-http-compat/node_modules/tslib/tslib.js
                  node_modules/@azure/core-http-compat/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/core-http-compat/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/core-rest-pipeline/node_modules/tslib/README.md
                  node_modules/@azure/core-rest-pipeline/node_modules/tslib/modules/index.js
                  node_modules/@azure/core-rest-pipeline/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.js
                  node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.es6.mjs
                  node_modules/@azure/core-paging/node_modules/tslib/README.md
                  node_modules/@azure/core-paging/node_modules/tslib/modules/index.js
                  node_modules/@azure/core-paging/node_modules/tslib/modules/index.d.ts
                  node_modules/@azure/core-paging/node_modules/tslib/tslib.es6.js
                  node_modules/@azure/core-paging/node_modules/tslib/tslib.js
                  node_modules/@azure/core-paging/node_modules/tslib/tslib.d.ts
                  node_modules/@azure/core-paging/node_modules/tslib/tslib.es6.mjs
                  node_modules/external-editor/main/errors/CreateFileError.js
                  node_modules/external-editor/main/errors/LaunchEditorError.js
                  node_modules/external-editor/main/errors/ReadFileError.js
                  node_modules/external-editor/main/errors/RemoveFileError.js
                  node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
                  node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
                  node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
                  node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
                  node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
                  node_modules/xmldom/dom.js
                  node_modules/@serialport/bindings-cpp/prebuilds/android-arm64/@serialport+bindings-cpp.armv8.node
                  node_modules/read-package-up/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/@homebridge/hap-nodejs/node_modules/tslib/README.md
                  node_modules/@homebridge/hap-nodejs/node_modules/tslib/modules/index.js
                  node_modules/@homebridge/hap-nodejs/node_modules/tslib/modules/index.d.ts
                  node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.es6.js
                  node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.js
                  node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.d.ts
                  node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.es6.mjs
                  node_modules/@homebridge/ciao/node_modules/tslib/README.md
                  node_modules/@homebridge/ciao/node_modules/tslib/modules/index.js
                  node_modules/@homebridge/ciao/node_modules/tslib/modules/index.d.ts
                  node_modules/@homebridge/ciao/node_modules/tslib/tslib.es6.js
                  node_modules/@homebridge/ciao/node_modules/tslib/tslib.js
                  node_modules/@homebridge/ciao/node_modules/tslib/tslib.d.ts
                  node_modules/@homebridge/ciao/node_modules/tslib/tslib.es6.mjs
                  node_modules/syno/definitions/6.x/_full.json
                  node_modules/syno/test/browser/js/syno-6.x.min.js
                  node_modules/syno/dist/syno-6.x.min.js
                  node_modules/syno/dist/syno-5.x.min.js
                  node_modules/iobroker.yahka/admin/yahka.admin.js
                  node_modules/iobroker.yahka/admin/yahka.admin.js.map
                  node_modules/hosted-git-info/git-host.js
                  node_modules/winston-seq-updated/lib/index.js
                  node_modules/iobroker.vis-2-widgets-gauges/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
                  node_modules/worker-timers-worker/node_modules/tslib/README.md
                  node_modules/worker-timers-worker/node_modules/tslib/modules/index.js
                  node_modules/worker-timers-worker/node_modules/tslib/modules/index.d.ts
                  node_modules/worker-timers-worker/node_modules/tslib/tslib.es6.js
                  node_modules/worker-timers-worker/node_modules/tslib/tslib.js
                  node_modules/worker-timers-worker/node_modules/tslib/tslib.d.ts
                  node_modules/worker-timers-worker/node_modules/tslib/tslib.es6.mjs
                  node_modules/json2iob/tsconfig.json
                  node_modules/worker-factory/node_modules/tslib/README.md
                  node_modules/worker-factory/node_modules/tslib/modules/index.js
                  node_modules/worker-factory/node_modules/tslib/modules/index.d.ts
                  node_modules/worker-factory/node_modules/tslib/tslib.es6.js
                  node_modules/worker-factory/node_modules/tslib/tslib.js
                  node_modules/worker-factory/node_modules/tslib/tslib.d.ts
                  node_modules/worker-factory/node_modules/tslib/tslib.es6.mjs
                  node_modules/fast-unique-numbers/node_modules/tslib/README.md
                  node_modules/fast-unique-numbers/node_modules/tslib/modules/index.js
                  node_modules/fast-unique-numbers/node_modules/tslib/modules/index.d.ts
                  node_modules/fast-unique-numbers/node_modules/tslib/tslib.es6.js
                  node_modules/fast-unique-numbers/node_modules/tslib/tslib.js
                  node_modules/fast-unique-numbers/node_modules/tslib/tslib.d.ts
                  node_modules/fast-unique-numbers/node_modules/tslib/tslib.es6.mjs
                  node_modules/rrule/node_modules/tslib/README.md
                  node_modules/rrule/node_modules/tslib/modules/index.js
                  node_modules/rrule/node_modules/tslib/modules/index.d.ts
                  node_modules/rrule/node_modules/tslib/tslib.es6.js
                  node_modules/rrule/node_modules/tslib/tslib.js
                  node_modules/rrule/node_modules/tslib/tslib.d.ts
                  node_modules/rrule/node_modules/tslib/tslib.es6.mjs
                  node_modules/rrule/dist/es5/rrule.js
                  node_modules/rrule/dist/es5/rrule.min.js.map
                  node_modules/rrule/dist/esm/callbackiterresult.js
                  node_modules/rrule/dist/esm/datetime.js
                  node_modules/rrule/dist/esm/rruleset.js
                  node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib.min.js
                  node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/vuetify.js
                  node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/material-components-web.js
                  node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
                  node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
                  node_modules/iobroker.modbus/admin/assets/index-Blv_5nFZ.js
                  node_modules/iobroker.material/www/static/js/main.c5478f66.js.map
                  node_modules/jszip/tsconfig.json
                  node_modules/iobroker.daswetter/admin/assets/index-84bRrRlB.js
                  node_modules/node-gyp/lib/find-python.js
                  node_modules/iobroker.javascript/admin/plugins/bundle.js
                  node_modules/iobroker.javascript/admin/assets/index-dN73sbyQ.js
                  node_modules/iobroker.javascript/admin/assets/iobroker_javascript__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-CV1_X-Lf.js
                  node_modules/iobroker.javascript/admin/vs/editor/editor.main.js
                  node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js
                  node_modules/iobroker.javascript/admin/custom/assets/index-BptSiKBK.js
                  node_modules/iobroker.javascript/admin/custom/assets/index-BVwMgafs.js
                  node_modules/iobroker.javascript/admin/custom/assets/ConfigCustomJavascriptSet__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-KsT5vKjV.js
                  node_modules/iobroker.javascript/admin/custom/assets/leaflet-src-k2rCV-Ix.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsyncAction.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsapAction.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsyncScheduler.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsapScheduler.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/QueueAction.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/QueueScheduler.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AnimationFrameScheduler.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/VirtualTimeScheduler.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AnimationFrameAction.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/Action.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/observable/dom/WebSocketSubject.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/observable/ConnectableObservable.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/operators/OperatorSubscriber.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/BehaviorSubject.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/Subscriber.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/AsyncSubject.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/ReplaySubject.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/HotObservable.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/TestScheduler.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/ColdObservable.js
                  node_modules/np/node_modules/rxjs/dist/esm5/internal/Subject.js
                  node_modules/np/node_modules/rxjs/dist/bundles/rxjs.umd.js.map
                  node_modules/np/node_modules/rxjs/dist/bundles/rxjs.umd.min.js.map
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsyncAction.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsapAction.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsyncScheduler.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsapScheduler.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/QueueAction.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/QueueScheduler.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AnimationFrameScheduler.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/VirtualTimeScheduler.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AnimationFrameAction.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/Action.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/observable/dom/WebSocketSubject.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/observable/ConnectableObservable.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/operators/OperatorSubscriber.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/BehaviorSubject.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/Subscriber.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/AsyncSubject.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/ReplaySubject.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/HotObservable.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/TestScheduler.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/ColdObservable.js
                  node_modules/np/node_modules/rxjs/dist/cjs/internal/Subject.js
                  node_modules/np/node_modules/tslib/README.md
                  node_modules/np/node_modules/tslib/modules/index.js
                  node_modules/np/node_modules/tslib/modules/index.d.ts
                  node_modules/np/node_modules/tslib/tslib.es6.js
                  node_modules/np/node_modules/tslib/tslib.js
                  node_modules/np/node_modules/tslib/tslib.d.ts
                  node_modules/np/node_modules/tslib/tslib.es6.mjs
                  node_modules/np/node_modules/type-fest/source/tsconfig-json.d.ts
                  node_modules/iobroker.vis-2-widgets-inventwo/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
                  node_modules/iobroker.vis-2-widgets-inventwo/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
                  node_modules/sinon/pkg/sinon-esm.js
                  node_modules/sinon/pkg/sinon-no-sourcemaps.cjs
                  node_modules/sinon/pkg/sinon.js
                  node_modules/luxon/build/cjs-browser/luxon.js
                  node_modules/luxon/build/cjs-browser/luxon.js.map
                  node_modules/luxon/build/amd/luxon.js
                  node_modules/luxon/build/amd/luxon.js.map
                  node_modules/luxon/build/global/luxon.min.js.map
                  node_modules/luxon/build/global/luxon.js
                  node_modules/luxon/build/global/luxon.js.map
                  node_modules/localforage/bower_components/mocha/mocha.js
                  node_modules/localforage/dist/localforage.js
                  node_modules/localforage/dist/localforage.nopromises.min.js
                  node_modules/localforage/dist/localforage.nopromises.js
                  node_modules/localforage/dist/localforage.min.js
                  node_modules/localforage/build/es5src/localforage.js
                  node_modules/localforage/src/localforage.js
                  node_modules/iobroker.email/admin/custom/assets/index-ByILBjTr.js
                  node_modules/iobroker.email/admin/custom/assets/index-D-vy1JIC.js
                  node_modules/iobroker.email/admin/custom/assets/ConfigCustomEmailSet__mf_v__runtimeInit__mf_v__-Bd5Kc7oi.js
                  node_modules/iobroker.email/admin/rules/assets/ActionSendEmail__mf_v__runtimeInit__mf_v__-eLULivoH.js
                  @tritor
                  Nix 'ausschneiden', das Log wird in Gänze gebraucht.
                    @tritor
                    tritor
                    schrieb am zuletzt editiert von tritor
                    @Thomas-Braun
                    habe mal den Adapter Vis 2 invento Widgets zum Testen auf eine andere Version (0.6.5 -> 0.6.4) gestellt.
                    Hier das log dazu.
                    $ iobroker upgrade vis-2-widgets-inventwo@0.6.4 --debug
                    Update vis-2-widgets-inventwo from @0.6.5 to @0.6.4
                    NPM version: 10.9.7
                    Installing iobroker.vis-2-widgets-inventwo@0.6.4... (System call)
                    > cpu-features@0.0.10 install> node buildcheck.js > buildcheck.gypi && node-gyp rebuild
                    gyp info it worked if it ends with ok
                    gyp info using node-gyp@8.4.1gyp info using node@22.22.2 | linux | x64
                    (node:955370) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
                    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                    gyp http GET https://nodejs.org/download/release/v22.22.2/node-v22.22.2-headers.tar.gz
                    gyp http 200 https://nodejs.org/download/release/v22.22.2/node-v22.22.2-headers.tar.gz
                    gyp http GET https://nodejs.org/download/release/v22.22.2/SHASUMS256.txt
                    gyp http 200 https://nodejs.org/download/release/v22.22.2/SHASUMS256.txt
                    gyp info spawn /usr/bin/python3
                    gyp info spawn args '/home/iobroker/.cache/node-gyp/22.22.2/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.22.2',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.22.2/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/cpu-features',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',
                    gyp info spawn args ]
                    Traceback (most recent call last):
                    File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'
                    gyp ERR! configure error
                    gyp ERR! cwd /opt/iobroker/node_modules/cpu-featuresgyp ERR! node -v v22.22.2gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
                    changed 1 package in 3s
                    352 packages are looking for funding run `npm fund` for details
                    Adapter "system.adapter.vis-2.0" restarted.Updating objects from io-package.json for adapter "vis-2-widgets-inventwo" with version "0.6.4"
                    upload [0] vis-2-widgets-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-inventwo/admin/vis-2-widgets-inventwo.png vis-2-widgets-inventwo.png image/png
                    Process exited with code 0
                    Hier auch die diag:
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                    Operating System: Debian GNU/Linux 13 (trixie)
                     Static hostname: ioBroker-prox
                           Icon name: computer-vm
                             Chassis: vm 🖴
                        AF_VSOCK CID: 1
                      Virtualization: kvm
                              Kernel: Linux 6.12.74+deb13+1-amd64
                        Architecture: x86-64
                     Hardware Vendor: QEMU
                      Hardware Model: Standard PC _Q35 + ICH9, 2009_
                    Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
                       Firmware Date: Tue 2014-04-01
                        Firmware Age: 12y 2w 3d
                    OS is similar to:
                    model name      : QEMU Virtual CPU version 2.5+
                    Docker          : false
                    Virtualization  : kvm
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     19:09:49 up  1:13,  2 users,  load average: 0.16, 0.18, 0.13
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'trixie'!
                    *** TIME AND TIMEZONES ***
                                   Local time: Sat 2026-04-18 19:09:49 CEST
                               Universal time: Sat 2026-04-18 17:09:49 UTC
                                     RTC time: Sat 2026-04-18 17:09:49
                                    Time zone: Europe/Vienna (CEST, +0200)
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    gfaigel
                    HOME=/home/gfaigel
                    GROUPS=gfaigel cdrom floppy sudo audio dip video plugdev netdev iobroker
                    iobroker
                    HOME=/home/iobroker
                    SUDO_HOME=/home/gfaigel
                    GROUPS=iobroker tty dialout audio video plugdev redis
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         false
                    Unit display-manager.service could not be found.
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:             10G        5.5G        3.5G        3.4M        1.7G        5.0G
                    Swap:           8.6G          0B        8.6G
                    Total:           19G        5.5G         12G
                    Active iob-Instances:   52
                             9951 M total memory
                             5208 M used memory
                             4791 M active memory
                             1333 M inactive memory
                             3385 M free memory
                              140 M buffer memory
                             1507 M swap cache
                             8189 M total swap
                                0 M used swap
                             8189 M free swap
                    top - 19:09:50 up  1:13,  2 users,  load average: 0.16, 0.18, 0.13
                    Tasks: 207 total,   1 running, 206 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us,  2.4 sy,  0.0 ni, 97.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   9951.2 total,   3384.8 free,   5209.2 used,   1648.9 buff/cache
                    MiB Swap:   8190.0 total,   8190.0 free,      0.0 used.   4742.0 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    udev           devtmpfs  4.9G     0  4.9G   0% /dev
                    tmpfs          tmpfs     996M  720K  995M   1% /run
                    /dev/sda1      ext4       55G   20G   33G  38% /
                    tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
                    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                    tmpfs          tmpfs     4.9G  2.6M  4.9G   1% /tmp
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                    tmpfs          tmpfs     996M  8.0K  996M   1% /run/user/0
                    tmpfs          tmpfs     996M  8.0K  996M   1% /run/user/1000
                    [Sat Apr 18 17:56:26 2026] EXT4-fs (sda1): mounted filesystem cc29babb-816d-4628-a5f0-de4d1d09f393 ro with ordered data mode. Quota mode: none.
                    [Sat Apr 18 17:56:26 2026] EXT4-fs (sda1): re-mounted cc29babb-816d-4628-a5f0-de4d1d09f393 r/w.
                    Show mounted filesystems:
                    TARGET SOURCE    FSTYPE OPTIONS
                    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                    /var:
                    5.2G    /var/
                    4.0G    /var/log
                    3.8G    /var/log/journal/6985862c63364d5e93cffdc681984609
                    983M    /var/cache
                    Archived and active journals take up 45.4M in the file system.
                    /opt/iobroker/backups:
                    253M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    1.5G    /opt/iobroker/iobroker-data/
                    1.1G    /opt/iobroker/iobroker-data/files
                    379M    /opt/iobroker/iobroker-data/files/vis
                    371M    /opt/iobroker/iobroker-data/files/vis/widgets
                    283M    /opt/iobroker/iobroker-data/files/vis-2
                    49M     /opt/iobroker/iobroker-data/objects.jsonl
                    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                    34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-DqJdyjgH.js.map
                    34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-CrLrNq4s.js.map
                    26M     /opt/iobroker/iobroker-data/states.jsonl
                    USB-Devices by-id:
                    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                    please always prefer the links 'by-id':
                    No Devices found 'by-id'
                    *** ZigBee Settings ***
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v22.22.2
                    /usr/bin/node           v22.22.2
                    /usr/bin/npm            10.9.7
                    /usr/bin/npx            10.9.7
                    ✓ Node.js installation is correct
                    nodejs:
                      Installed: 22.22.2-1nodesource1
                      Candidate: 22.22.2-1nodesource1
                      Version table:
                     *** 22.22.2-1nodesource1 1001
                         22.22.1-1nodesource1 1001
                         22.22.0-1nodesource1 1001
                         22.21.0-1nodesource1 1001
                         22.20.0-1nodesource1 1001
                         22.19.0-1nodesource1 1001
                         22.18.0-1nodesource1 1001
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                         20.19.2+dfsg-1+deb13u2 500
                            500 https://security.debian.org/debian-security trixie-security/main amd64 Packages
                         20.19.2+dfsg-1 500
                            500 https://deb.debian.org/debian trixie/main amd64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: redis
                    Hosts:
                    ioBroker-prox       ioBroker-prox (version: 7.1.1, hostname: ioBroker-prox , alive, uptime: 4398)
                    Core adapters versions
                    js-controller:  7.1.1
                    admin:          7.8.20
                    javascript:     9.2.0
                    nodejs modules from github:     2
                    +-- iobroker.electrolux-aeg@0.0.5 (git+ssh://git@github.com/TA2k/ioBroker.electrolux-aeg.git#cdd3bdd3f76e96e5940fff159dcc82c19a531d95)
                    | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                    Adapter State
                    + system.adapter.accuweather.0            : accuweather           : ioBroker-prox                            -  enabled
                    + system.adapter.admin.0                  : admin                 : ioBroker-prox                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : ioBroker-prox                            -  enabled
                      system.adapter.alias-manager.0          : alias-manager         : ioBroker-prox                            -  enabled
                      system.adapter.apg-info.0               : apg-info              : ioBroker-prox                            -  enabled
                      system.adapter.awattar.0                : awattar               : ioBroker-prox                            -  enabled
                    + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker-prox                            -  enabled
                    + system.adapter.backitup.0               : backitup              : ioBroker-prox                            -  enabled
                    + system.adapter.bosesoundtouch.0         : bosesoundtouch        : ioBroker-prox                            -  enabled
                    + system.adapter.bring.0                  : bring                 : ioBroker-prox                            -  enabled
                    + system.adapter.bwt.0                    : bwt                   : ioBroker-prox                            -  enabled
                    + system.adapter.bydhvs.0                 : bydhvs                : ioBroker-prox                            -  enabled
                    + system.adapter.cloud.0                  : cloud                 : ioBroker-prox                            -  enabled
                    + system.adapter.daswetter.0              : daswetter             : ioBroker-prox                            -  enabled
                    + system.adapter.denon.0                  : denon                 : ioBroker-prox                            -  enabled
                      system.adapter.devices.0                : devices               : ioBroker-prox                            -  enabled
                    + system.adapter.discovery.0              : discovery             : ioBroker-prox                            -  enabled
                    + system.adapter.electrolux-aeg.0         : electrolux-aeg        : ioBroker-prox                            -  enabled
                    + system.adapter.email.0                  : email                 : ioBroker-prox                            -  enabled
                    + system.adapter.energiefluss.0           : energiefluss          : ioBroker-prox                            -  enabled
                    + system.adapter.enigma2.0                : enigma2               : ioBroker-prox                            -  enabled
                    + system.adapter.epson_ecotank_et_2750.0  : epson_ecotank_et_2750 : ioBroker-prox                            -  enabled
                    + system.adapter.frigate.0                : frigate               : ioBroker-prox                            -  enabled
                    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-prox                            -  enabled
                    + system.adapter.fronius.0                : fronius               : ioBroker-prox                            -  enabled
                      system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker-prox                            -  enabled
                      system.adapter.fuelpricemonitor.1       : fuelpricemonitor      : ioBroker-prox                            -  enabled
                    + system.adapter.fullcalendar.0           : fullcalendar          : ioBroker-prox                            -  enabled
                    + system.adapter.harmony.0                : harmony               : ioBroker-prox                            -  enabled
                      system.adapter.hue.0                    : hue                   : ioBroker-prox                            - disabled, port: 80
                      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-prox                            -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-prox                            -  enabled
                      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-prox                            -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-prox                            -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-prox                            -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-prox                            -  enabled
                    + system.adapter.influxdb.0               : influxdb              : ioBroker-prox                            -  enabled, port: 8086
                    + system.adapter.iot.0                    : iot                   : ioBroker-prox                            -  enabled
                    + system.adapter.jablotron.0              : jablotron             : ioBroker-prox                            -  enabled
                    + system.adapter.javascript.0             : javascript            : ioBroker-prox                            -  enabled
                    + system.adapter.lgtv.0                   : lgtv                  : ioBroker-prox                            -  enabled
                      system.adapter.material.0               : material              : ioBroker-prox                            -  enabled
                    + system.adapter.mercedesme.0             : mercedesme            : ioBroker-prox                            -  enabled
                    + system.adapter.mielecloudservice.0      : mielecloudservice     : ioBroker-prox                            -  enabled
                      system.adapter.modbus.0                 : modbus                : ioBroker-prox                            - disabled
                    + system.adapter.mqtt.0                   : mqtt                  : ioBroker-prox                            -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.nut.0                    : nut                   : ioBroker-prox                            -  enabled
                      system.adapter.nut.1                    : nut                   : ioBroker-prox                            - disabled
                    + system.adapter.onkyo.0                  : onkyo                 : ioBroker-prox                            -  enabled
                      system.adapter.openweathermap.0         : openweathermap        : ioBroker-prox                            -  enabled
                    + system.adapter.ping.0                   : ping                  : ioBroker-prox                            -  enabled
                    + system.adapter.proxmox.0                : proxmox               : ioBroker-prox                            -  enabled, port: 8006
                    + system.adapter.pushover.0               : pushover              : ioBroker-prox                            -  enabled
                    + system.adapter.reolink.0                : reolink               : ioBroker-prox                            -  enabled
                    + system.adapter.rest-api.0               : rest-api              : ioBroker-prox                            -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                    + system.adapter.scenes.0                 : scenes                : ioBroker-prox                            -  enabled
                    + system.adapter.shelly.0                 : shelly                : ioBroker-prox                            -  enabled, port: 1888, bind: 0.0.0.0
                    + system.adapter.simple-api.0             : simple-api            : ioBroker-prox                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.sql.0                    : sql                   : ioBroker-prox                            -  enabled, port: 5432
                      system.adapter.synology.0               : synology              : ioBroker-prox                            - disabled, port: 5001
                    + system.adapter.vaillant.0               : vaillant              : ioBroker-prox                            -  enabled
                      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker-prox                            -  enabled
                      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker-prox                            -  enabled
                      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-prox                            -  enabled
                      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-prox                            -  enabled
                      system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: ioBroker-prox                            -  enabled
                    + system.adapter.vis-2.0                  : vis-2                 : ioBroker-prox                            -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : ioBroker-prox                            -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-prox                            -  enabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-prox                            -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-prox                            -  enabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-prox                            -  enabled
                      system.adapter.vis-history.0            : vis-history           : ioBroker-prox                            -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-prox                            -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-prox                            -  enabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-prox                            -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-prox                            -  enabled
                      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-prox                            -  enabled
                      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-prox                            -  enabled
                      system.adapter.vis-map.0                : vis-map               : ioBroker-prox                            -  enabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker-prox                            -  enabled
                      system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker-prox                            -  enabled
                      system.adapter.vis-material.0           : vis-material          : ioBroker-prox                            -  enabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-prox                            -  enabled
                      system.adapter.vis-players.0            : vis-players           : ioBroker-prox                            -  enabled
                      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-prox                            -  enabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-prox                            -  enabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-prox                            -  enabled
                      system.adapter.vis-weather.0            : vis-weather           : ioBroker-prox                            -  enabled
                      system.adapter.vis.0                    : vis                   : ioBroker-prox                            -  enabled
                    + system.adapter.web.0                    : web                   : ioBroker-prox                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker-prox                            -  enabled
                    + system.adapter.wifilight.0              : wifilight             : ioBroker-prox                            -  enabled
                      system.adapter.wlanthermo-nano.0        : wlanthermo-nano       : ioBroker-prox                            - disabled
                      system.adapter.wlanthermo-nano.1        : wlanthermo-nano       : ioBroker-prox                            - disabled
                      system.adapter.wled.0                   : wled                  : ioBroker-prox                            - disabled
                    + system.adapter.yahka.0                  : yahka                 : ioBroker-prox                            -  enabled
                    + system.adapter.yahka.1                  : yahka                 : ioBroker-prox                            -  enabled
                    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker-prox                            -  enabled
                    + instance is alive
                    ioBroker-Repositories
                    │ 0       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                    │ 1       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                    Active repo(s): beta
                    Upgrade policy: none
                    Installed ioBroker-Adapters
                    Used repository: beta
                    Adapter    "accuweather"  : 2.2.0    , installed 2.2.0
                    Adapter    "admin"        : 7.8.20   , installed 7.8.20
                    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
                    Adapter    "apg-info"     : 0.1.30   , installed 0.1.30
                    Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
                    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
                    Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
                    Adapter    "bring"        : 1.9.1    , installed 1.9.1
                    Adapter    "bwt"          : 0.1.2    , installed 0.1.2
                    Adapter    "bydhvs"       : 1.5.5    , installed 1.5.5
                    Adapter    "cloud"        : 6.0.1    , installed 6.0.1
                    Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
                    Adapter    "denon"        : 1.15.12  , installed 1.15.12
                    Adapter    "devices"      : 2.0.5    , installed 2.0.5
                    Adapter    "email"        : 2.0.4    , installed 2.0.4
                    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                    Adapter    "enigma2"      : 2.3.0    , installed 2.3.0
                    Adapter    "epson_ecotank_et_2750": 1.1.0, installed 1.1.0
                    Adapter    "frigate"      : 2.3.1    , installed 2.3.1
                    Adapter    "fronius"      : 2.2.0    , installed 2.2.0
                    Adapter    "fronius-solarweb": 0.1.1 , installed 0.1.1
                    Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
                    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
                    Adapter    "harmony"      : 2.1.0    , installed 2.1.0
                    Adapter    "hue"          : 3.16.2   , installed 3.16.2
                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                    Adapter    "iot"          : 6.0.1    , installed 6.0.1
                    Adapter    "jablotron"    : 0.1.8    , installed 0.1.8
                    Adapter    "javascript"   : 9.2.0    , installed 9.2.0
                    Controller "js-controller": 7.1.1    , installed 7.1.1
                    Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
                    Adapter    "material"     : 1.3.1    , installed 1.3.1
                    Adapter    "mercedesme"   : 0.7.1    , installed 0.7.1
                    Adapter    "mielecloudservice": 6.5.12, installed 6.5.12
                    Adapter    "modbus"       : 8.1.3    , installed 8.1.3
                    Adapter    "nut"          : 1.7.0    , installed 1.7.0
                    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                    Adapter    "ping"         : 2.1.0    , installed 2.1.0
                    Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
                    Adapter    "pushover"     : 5.0.0    , installed 5.0.0
                    Adapter    "reolink"      : 1.4.2    , installed 1.4.2
                    Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
                    Adapter    "scenes"       : 4.0.4    , installed 4.0.4
                    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                    Adapter    "snmp"         : 3.4.0    , installed 3.4.0
                    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                    Adapter    "sql"          : 3.0.1    , installed 3.0.1
                    Adapter    "synology"     : 3.1.0    , installed 3.1.0
                    Adapter    "vaillant"     : 0.7.5    , installed 0.7.5
                    Adapter    "vis-2"        : 2.13.17  , installed 2.13.17
                    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                    Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
                    Adapter    "vis-2-widgets-inventwo": 0.6.5, installed 0.6.5
                    Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
                    Adapter    "vis-2-widgets-radar-trap": 2.3.3, installed 2.3.3
                    Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
                    Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
                    Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                    Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                    Adapter    "vis-keyboard" : 0.0.3    , installed 0.0.3
                    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
                    Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                    Adapter    "web"          : 8.1.0    , installed 8.1.0
                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
                    Adapter    "wlanthermo-nano": 0.2.1  , installed 0.2.1
                    Adapter    "wled"         : 0.9.2    , installed 0.9.2
                    Adapter    "ws"           : 4.1.0    , installed 4.1.0
                    Adapter    "yahka"        : 1.1.6    , installed 1.1.6
                    Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
                    Objects and States
                    Objects:        38036
                    States:         32120
                    Hit:1 https://security.debian.org/debian-security trixie-security InRelease
                    Hit:2 https://deb.debian.org/debian trixie InRelease
                    Hit:3 https://deb.debian.org/debian trixie-updates InRelease
                    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Reading package lists...
                    Pending systemupdates: 0
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6742       1030/exim4
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7683       1026/iobroker.js-co
                    tcp        0      0 0.0.0.0:40803           0.0.0.0:*               LISTEN      1001       10832      1725/io.yahka.0
                    tcp        0      0 127.0.0.1:35603         0.0.0.0:*               LISTEN      1001       158383     1725/io.yahka.0
                    tcp        0      0 0.0.0.0:34681           0.0.0.0:*               LISTEN      1001       11018      1850/io.yahka.1
                    tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       9663       1686/io.shelly.0
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1127       1/init
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6610       751/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          6532       715/vsftpd
                    tcp        0      0 0.0.0.0:9080            0.0.0.0:*               LISTEN      1001       195398     81691/nc
                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        5800       690/redis-server 12
                    tcp        0      0 127.0.0.1:39469         0.0.0.0:*               LISTEN      1001       14360      1725/io.yahka.0
                    tcp6       0      0 ::1:6379                :::*                    LISTEN      109        5801       690/redis-server 12
                    tcp6       0      0 :::61991                :::*                    LISTEN      1001       10654      1596/io.harmony.0
                    tcp6       0      0 :::8093                 :::*                    LISTEN      1001       14542      2122/io.rest-api.0
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       13803      2139/io.simple-api.
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14863      2681/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6777       1059/io.admin.0
                    tcp6       0      0 :::1889                 :::*                    LISTEN      1001       17554      3205/io.frigate.0
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          1128       1/init
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          6620       751/sshd: /usr/sbin
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6743       1030/exim4
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11023      1850/io.yahka.1
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11022      1850/io.yahka.1
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       9024       1725/io.yahka.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       9023       1725/io.yahka.0
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          486        1/init
                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       10655      1596/io.harmony.0
                    udp6       0      0 :::111                  :::*                                0          1129       1/init
                    2026-04-18 19:08:23.538  - info: shelly.0 (1686) [MQTT] Device with client id "shellyht-B89BA4" connected from 192.168.10.130!
                    2026-04-18 19:08:23.993  - info: shelly.0 (1686) [MQTT] Device with client id "shellyht-B89BA4" initialized.
                    2026-04-18 19:08:27.436  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:08:36.742  - info: web.0 (2681) <== Disconnect system.user.admin from ::ffff:192.168.10.32 vis.0
                    2026-04-18 19:08:37.809  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:08:37.874  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-KG', payload '{"last_seen":"2026-04-18T17:08:37.858Z","linkquality":51,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
                    2026-04-18 19:08:41.369  - info: web.0 (2681) ==> Connected system.user.admin from ::ffff:192.168.10.32
                    2026-04-18 19:08:46.836  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/EsszimmerVitrine', payload '{"brightness":254,"last_seen":"2026-04-18T17:08:46.819Z","linkquality":218,"state":"OFF","update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-transformer_release_prod_v587753009_17d32c23-151f-44cb-a947-4c13a78f36e6.ota","latest_version":587753009,"state":"idle"}}'
                    2026-04-18 19:08:48.427  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:08:51.383  - info: shelly.0 (1686) [MQTT] Client Disconnect: 192.168.10.130 (shellyht / shellyht-B89BA4 / SHHT-1#B89BA4#1)
                    2026-04-18 19:08:58.840  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:09:00.001  - info: mqtt.0 (1633) send2Server mqtt.0.Smarthome.nspanel_9BC8E8.cmnd.CustomSend[Smarthome/nspanel_9BC8E8/cmnd/CustomSend]
                    2026-04-18 19:09:09.238  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:09:19.655  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:09:30.074  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:09:31.500  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-EG', payload '{"last_seen":"2026-04-18T17:09:31.484Z","linkquality":58,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
                    2026-04-18 19:09:40.502  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:09:44.086  - info: frigate.0 (3205) Notification sending active but no image available for type person state Event After
                    2026-04-18 19:09:44.296  - info: frigate.0 (3205) Notification sending active but no image available for type person state Event After
                    2026-04-18 19:09:44.715  - info: frigate.0 (3205) Clip sending active but no clip available
                    2026-04-18 19:09:46.189  - info: shelly.0 (1686) [MQTT] Device with client id "shellyht-95645D" connected from 192.168.10.170!
                    2026-04-18 19:09:46.668  - info: shelly.0 (1686) [MQTT] Device with client id "shellyht-95645D" initialized.
                    2026-04-18 19:09:50.936  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    2026-04-18 19:10:00.001  - info: mqtt.0 (1633) send2Server mqtt.0.Smarthome.nspanel_9BC8E8.cmnd.CustomSend[Smarthome/nspanel_9BC8E8/cmnd/CustomSend]
                    2026-04-18 19:10:01.364  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                    Gernot
                    Host: i9 server Proxmox , Debian 13.4 for ioBroker
                    ioBroker: 7.8.24, Node.js: 22.22.2, NPM: 10.9.4, JS-controller: 7.1.2
                    Wetterstation: HP1000SEPro V1.9.7 Easeweather V1.7.5
                    Grafana 13.0.1 / InfluxDB 2.8.0
                    Thomas BraunT 3 Antworten Letzte Antwort
                    • T tritor
                      @Thomas-Braun
                      Hier das log dazu.
                      NPM version: 10.9.7
                      Hier auch die diag:
                      Script v.2026-01-31
                      *** BASE SYSTEM ***
                               Chassis: vm 🖴
                          AF_VSOCK CID: 1
                        Virtualization: kvm
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      CPU threads: 4
                                    NTP service: active
                                RTC in local TZ: no
                      gfaigel
                      HOME=/home/gfaigel
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Swap:           8.6G          0B        8.6G
                      Total:           19G        5.5G         12G
                               9951 M total memory
                               5208 M used memory
                               3385 M free memory
                                140 M buffer memory
                               1507 M swap cache
                               8189 M total swap
                                  0 M used swap
                               8189 M free swap
                      *** FILESYSTEM ***
                      /var:
                      5.2G    /var/
                      4.0G    /var/log
                      983M    /var/cache
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.7
                      /usr/bin/npx            10.9.7
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: redis
                      Hosts:
                      admin:          7.8.20
                      javascript:     9.2.0
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        38036
                      States:         32120
                      @tritor
                      Verwende bitte das Log wie oben angegeben aus deinem Terminal...
                      • T tritor
                        @Thomas-Braun
                        Hier das log dazu.
                        NPM version: 10.9.7
                        Hier auch die diag:
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                                 Chassis: vm 🖴
                            AF_VSOCK CID: 1
                          Virtualization: kvm
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 4
                                      NTP service: active
                                  RTC in local TZ: no
                        gfaigel
                        HOME=/home/gfaigel
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Swap:           8.6G          0B        8.6G
                        Total:           19G        5.5G         12G
                                 9951 M total memory
                                 5208 M used memory
                                 3385 M free memory
                                  140 M buffer memory
                                 1507 M swap cache
                                 8189 M total swap
                                    0 M used swap
                                 8189 M free swap
                        *** FILESYSTEM ***
                        /var:
                        5.2G    /var/
                        4.0G    /var/log
                        983M    /var/cache
                        USB-Devices by-id:
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.7
                        /usr/bin/npx            10.9.7
                        nodejs:
                          Version table:
                             20.19.2+dfsg-1 500
                        ioBroker Status
                        Objects type: jsonl
                        States  type: redis
                        Hosts:
                        admin:          7.8.20
                        javascript:     9.2.0
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        38036
                        States:         32120
                        @tritor sagte:
                        Beheben per
                        sudo apt update
                        sudo apt install python3-setuptools
                        • T tritor
                          @Thomas-Braun
                          Hier das log dazu.
                          NPM version: 10.9.7
                          Hier auch die diag:
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                                   Chassis: vm 🖴
                              AF_VSOCK CID: 1
                            Virtualization: kvm
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 4
                                        NTP service: active
                                    RTC in local TZ: no
                          gfaigel
                          HOME=/home/gfaigel
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:           8.6G          0B        8.6G
                          Total:           19G        5.5G         12G
                                   9951 M total memory
                                   5208 M used memory
                                   3385 M free memory
                                    140 M buffer memory
                                   1507 M swap cache
                                   8189 M total swap
                                      0 M used swap
                                   8189 M free swap
                          *** FILESYSTEM ***
                          /var:
                          5.2G    /var/
                          4.0G    /var/log
                          983M    /var/cache
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.7
                          /usr/bin/npx            10.9.7
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: redis
                          Hosts:
                          admin:          7.8.20
                          javascript:     9.2.0
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        38036
                          States:         32120
                          @tritor sagte:
                          Setz den user 'gfaigel' in die Gruppe 'adm' rein:
                          sudo usermod -aG adm gfaigel
                          gfaigel muss sich danach einmal aus- und wieder einloggen.
                            @tritor sagte:
                            Beheben per
                            sudo apt update
                            tritor
                            @Thomas-Braun
                            Nach dem Update, usrmod und ein erneuter Versionswechsels des Adapters ist alles ok:
                            $ iobroker upgrade vis-2-widgets-inventwo@0.6.5 --debug
                            Update vis-2-widgets-inventwo from @0.6.4 to @0.6.5
                            NPM version: 10.9.7
                            Installing iobroker.vis-2-widgets-inventwo@0.6.5... (System call)
                            changed 1 package in 2s352 packages are looking for funding run `npm fund` for details
                            Updating objects from io-package.json for adapter "vis-2-widgets-inventwo" with version "0.6.5"
                            Update "system.adapter.vis-2-widgets-inventwo.0"
                            Keine Fehlermeldungen mehr!
                            Auch das diag sieht für mich ok aus:
                            ```bash
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                                    Chassis: vm 🖴
                               AF_VSOCK CID: 1
                             Virtualization: kvm
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            19:19:14 up  1:22,  2 users,  load average: 0.28, 0.25, 0.17
                            CPU threads: 4
                                          Local time: Sat 2026-04-18 19:19:14 CEST
                                      Universal time: Sat 2026-04-18 17:19:14 UTC
                                            RTC time: Sat 2026-04-18 17:19:14
                                         NTP service: active
                                     RTC in local TZ: no
                            gfaigel
                            HOME=/home/gfaigel
                            GROUPS=gfaigel adm cdrom floppy sudo audio dip video plugdev netdev iobroker
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:             10G        5.6G        3.3G        3.4M        1.8G        4.9G
                            Swap:           8.6G          0B        8.6G
                            Total:           19G        5.6G         11G
                                    9951 M total memory
                                    5322 M used memory
                                    4932 M active memory
                                    1376 M inactive memory
                                    3183 M free memory
                                     146 M buffer memory
                                    1591 M swap cache
                                    8189 M total swap
                                       0 M used swap
                                    8189 M free swap
                            top - 19:19:14 up  1:22,  2 users,  load average: 0.28, 0.25, 0.17
                            Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  9.3 us,  2.3 sy,  0.0 ni, 88.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   9951.2 total,   3182.9 free,   5324.0 used,   1738.6 buff/cache
                            MiB Swap:   8190.0 total,   8190.0 free,      0.0 used.   4627.2 avail Mem
                            *** FILESYSTEM ***
                            tmpfs          tmpfs     996M  708K  995M   1% /run
                            /var:
                            5.2G    /var/
                            4.0G    /var/log
                            983M    /var/cache
                            Archived and active journals take up 3.7G in the file system.
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            nodejs:
                             Version table:
                                20.19.2+dfsg-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            Hosts:
                            ioBroker-prox       ioBroker-prox (version: 7.1.1, hostname: ioBroker-prox , alive, uptime: 4968)
                            admin:          7.8.20
                            javascript:     9.2.0
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        38036
                            States:         32120
                            tcp        0      0 0.0.0.0:9080            0.0.0.0:*               LISTEN      1001       223042     93118/nc
                            2026-04-18 19:17:57.579  - info: host.ioBroker-prox instance system.adapter.openweathermap.0 having pid 90573 terminated with code 0 (NO_ERROR)
                            2026-04-18 19:18:00.002  - info: mqtt.0 (1633) send2Server mqtt.0.Smarthome.nspanel_9BC8E8.cmnd.CustomSend[Smarthome/nspanel_9BC8E8/cmnd/CustomSend]
                            2026-04-18 19:18:03.351  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:18:13.731  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:18:24.332  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:18:29.186  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-OG', payload '{"last_seen":"2026-04-18T17:18:29.176Z","linkquality":58,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
                            2026-04-18 19:18:29.671  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-OG', payload '{"last_seen":"2026-04-18T17:18:29.661Z","linkquality":58,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
                            2026-04-18 19:18:34.746  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:18:36.885  - info: web.0 (2681) <== Disconnect system.user.admin from ::ffff:192.168.10.32 vis.0
                            2026-04-18 19:18:37.593  - info: shelly.0 (1686) [MQTT] Client Disconnect: 192.168.10.170 (shellyht / shellyht-95645D / SHHT-1#95645D#1)
                            2026-04-18 19:18:39.878  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-KG', payload '{"last_seen":"2026-04-18T17:18:39.868Z","linkquality":47,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
                            2026-04-18 19:18:41.063  - info: frigate.0 (3205) Notification sending active but no image available for type person state Event After
                            2026-04-18 19:18:41.161  - info: frigate.0 (3205) Notification sending active but no image available for type person state Event After
                            2026-04-18 19:18:42.159  - info: web.0 (2681) ==> Connected system.user.admin from ::ffff:192.168.10.32
                            2026-04-18 19:18:42.471  - info: frigate.0 (3205) Clip sending active but no clip available
                            2026-04-18 19:18:45.122  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:18:55.499  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:19:00.001  - info: mqtt.0 (1633) send2Server mqtt.0.Smarthome.nspanel_9BC8E8.cmnd.CustomSend[Smarthome/nspanel_9BC8E8/cmnd/CustomSend]
                            2026-04-18 19:19:05.005  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/EsszimmerVitrine', payload '{"brightness":254,"last_seen":"2026-04-18T17:19:04.995Z","linkquality":218,"state":"OFF","update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-transformer_release_prod_v587753009_17d32c23-151f-44cb-a947-4c13a78f36e6.ota","latest_version":587753009,"state":"idle"}}'
                            2026-04-18 19:19:05.934  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:19:13.163  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/EsszimmerVitrine', payload '{"brightness":254,"last_seen":"2026-04-18T17:19:13.153Z","linkquality":218,"state":"OFF","update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-transformer_release_prod_v587753009_17d32c23-151f-44cb-a947-4c13a78f36e6.ota","latest_version":587753009,"state":"idle"}}'
                            2026-04-18 19:19:13.164  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/EsszimmerVitrine', payload '{"brightness":254,"last_seen":"2026-04-18T17:19:13.153Z","linkquality":218,"state":"ON","update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-transformer_release_prod_v587753009_17d32c23-151f-44cb-a947-4c13a78f36e6.ota","latest_version":587753009,"state":"idle"}}'
                            2026-04-18 19:19:16.351  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:19:26.747  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            2026-04-18 19:19:37.135  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
                            [/s]
                            Vielen  Dank!!!
                            Gernot
                            • T tritor
                              @Thomas-Braun
                              NPM version: 10.9.7
                              ```bash
                              Script v.2026-01-31
                              *** BASE SYSTEM ***
                                      Chassis: vm 🖴
                                 AF_VSOCK CID: 1
                               Virtualization: kvm
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                           NTP service: active
                                       RTC in local TZ: no
                              gfaigel
                              HOME=/home/gfaigel
                              iobroker
                              HOME=/home/iobroker
                              Display-Manager:
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           8.6G          0B        8.6G
                              Total:           19G        5.6G         11G
                                      9951 M total memory
                                      5322 M used memory
                                      3183 M free memory
                                       146 M buffer memory
                                      1591 M swap cache
                                      8189 M total swap
                                         0 M used swap
                                      8189 M free swap
                              *** FILESYSTEM ***
                              /var:
                              5.2G    /var/
                              4.0G    /var/log
                              983M    /var/cache
                              USB-Devices by-id:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.9.7
                              /usr/bin/npx            10.9.7
                              nodejs:
                               Version table:
                                  20.19.2+dfsg-1 500
                              ioBroker Status
                              Objects type: jsonl
                              States  type: redis
                              Hosts:
                              admin:          7.8.20
                              javascript:     9.2.0
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        38036
                              States:         32120
                              [/s]
                              Vielen  Dank!!!
                              @tritor sagte:
                              Dann kannst du dich ja jetzt um dein reolink, zigbee2mqtt und frigate kümmern und schauen, warum die dein Log zuknallen.
                              Zum Vergleich mal mein Log seit 0 Uhr in voller Länge:
                              echad@chet:~ $ iob logs
                              2026-04-18 00:00:26.022  - info: followthesun.0 (64314) Cronjob 'Sun parameter calculation' starts
                              2026-04-18 00:04:45.353  - warn: awtrix-light.0 (64186) (custom?name=solcur) Unable to update custom app "solcur": AxiosError: timeout of 10000ms exceeded
                              2026-04-18 05:29:31.858  - error: mihome-cloud.0 (250751) Error polling custom properties for Ventilator: timeout of 15000ms exceeded
                              2026-04-18 07:45:56.626  - warn: awtrix-light.0 (64186) (custom?name=batlow) Unable to update custom app "batlow": AxiosError: timeout of 10000ms exceeded
                              2026-04-18 09:39:26.741  - error: mihome-cloud.0 (250751) Error polling custom properties for Fenster rechts: timeout of 15000ms exceeded
                              2026-04-18 14:27:09.209  - warn: awtrix-light.0 (64186) [refreshApp] Unable to remove hidden app "batlow": AxiosError: timeout of 10000ms exceeded
                              2026-04-18 18:55:15.804  - warn: awtrix-light.0 (64186) (custom?name=soltotal) Unable to update custom app "soltotal": AxiosError: timeout of 10000ms exceeded
                              echad@chet:~ $
                              Das kann ich dann auch ohne LogParser oder sowas lesen.
                                tritor
                                Dem Reolink hab ich nun das Feld das bemängelt wird von Number auf Boolean umgestellt.
                                Beim ZigBee2MQTT hab ich mal die Einstellung: Proxy Zigbee2MQTT Protokolle zu ioBroker Protokollen deaktiviert.
                                Bei frigate auch eine Einstellung gemacht.
                                Werde das log morgen Mittags checken.
                                BTW, im log habe ich gerade festgestellt:
                                admin.0 2026-04-18 20:43:43.814	warn	Docker is not installed. Please install Docker.
                                Warum braucht admin denn Docker?
                                Danke nochmals für die Tips
                                Gernot
                                  tritor
                                  schrieb zuletzt editiert von tritor
                                  Sorry, das ich hier nochmals nachfrage betreffend der Docker Meldung, die hab ich immer noch im Log.
                                  admin.0 2026-06-15 11:46:41.845	warn	Docker is not installed. Please install Docker.
                                  Gernot
                                  • T tritor
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    @tritor sagte:
                                    Versteh zwar nicht ganz was das mit dem Titel dieses Topics zu tun hat - aber ...
                                    Welche Admin Version hast du installiert?
                                    Support Repositoryverwaltung.
                                    LESEN - gute Forenbeitrage
                                    83.2k
