<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Deprecation Warning - util._extend]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">in den logs von Adapter Updates wir mit immer wieder ein DepreciatonWarning angezeigt.<br />
Es geht dabei um 'util._extend API is depreciated.</p>
<p dir="auto">Hier ein Ausschnitt aus einem Log am Screen während eines Adapter Updates:<br />
</p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>2026-04-18 13:05:51.588  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker &gt; cpu-features@0.0.10 install&gt; node buildcheck.js &gt; buildcheck.gypi &amp;&amp; node-gyp rebuild
2026-04-18 13:05:51.700  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker gyp info it worked if it ends with ok
2026-04-18 13:05:51.701  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker gyp info using node-gyp@8.4.1
2026-04-18 13:05:51.701  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker gyp info using node@22.22.1 | linux | x64
2026-04-18 13:05:51.727  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker (node:621588) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use&gt;
2026-04-18 13:05:51.840  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn&gt;
2026-04-18 13:05:52.164  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker Traceback (most recent call last):  File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in &lt;module&gt;    i&gt;
2026-04-18 13:05:52.444  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker added 3 packages, removed 7 packages, and changed 19 packages in 4s353 packages are looking for funding  run `npm fund` f&gt;
2026-04-18 13:05:53.560  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker Updating objects from io-package.json for adapter "backitup" with version "3.3.17"
2026-04-18 13:05:53.597  - ^[[32minfo^[[39m: host.ioBroker-prox iobroker Update "system.adapter.backitup.0"
</code></pre>
<p dir="auto"></p></section></section><p></p>
<p dir="auto">Hoffe einer der Experten kann mir hier einen Tipp geben, ob das com ioB-System herrührt oder, das eher adapterspezifisch ist.</p>
<p dir="auto">Danke</p>
]]></description><link>https://forum.iobroker.net/topic/84337/deprecation-warning-util._extend</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 00:47:10 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84337.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 18 Apr 2026 11:21:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 18:51:30 GMT]]></title><description><![CDATA[<p dir="auto">Dem Reolink hab ich nun das Feld das bemängelt wird von Number auf Boolean umgestellt.<br />
Beim ZigBee2MQTT hab ich mal die Einstellung: Proxy Zigbee2MQTT Protokolle zu ioBroker Protokollen deaktiviert.<br />
Bei frigate auch eine Einstellung gemacht.</p>
<p dir="auto">Werde das log morgen Mittags checken.</p>
<p dir="auto">BTW, im log habe ich gerade festgestellt:</p>
<pre><code>admin.0 2026-04-18 20:43:43.814	warn	Docker is not installed. Please install Docker.
</code></pre>
<p dir="auto">Warum braucht admin denn Docker?</p>
<p dir="auto">Danke nochmals für die Tips</p>
]]></description><link>https://forum.iobroker.net/post/1335219</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335219</guid><dc:creator><![CDATA[tritor]]></dc:creator><pubDate>Sat, 18 Apr 2026 18:51:30 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 17:29:27 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tritor" aria-label="Profile: tritor">@<bdi>tritor</bdi></a> <a href="/post/1335214">sagte</a>:</p>
<p dir="auto">Keine Fehlermeldungen mehr!</p>
</blockquote>
<p dir="auto">Dann kannst du dich ja jetzt um dein reolink, zigbee2mqtt und frigate kümmern und schauen, warum die dein Log zuknallen.</p>
<p dir="auto">Zum Vergleich mal mein Log seit 0 Uhr in voller Länge:</p>
<pre><code>echad@chet:~ $ iob logs
2026-04-18 00:00:26.022  - info: followthesun.0 (64314) Cronjob 'Sun parameter calculation' starts
2026-04-18 00:04:45.353  - warn: awtrix-light.0 (64186) (custom?name=solcur) Unable to update custom app "solcur": AxiosError: timeout of 10000ms exceeded
2026-04-18 05:29:31.858  - error: mihome-cloud.0 (250751) Error polling custom properties for Ventilator: timeout of 15000ms exceeded
2026-04-18 07:45:56.626  - warn: awtrix-light.0 (64186) (custom?name=batlow) Unable to update custom app "batlow": AxiosError: timeout of 10000ms exceeded
2026-04-18 09:39:26.741  - error: mihome-cloud.0 (250751) Error polling custom properties for Fenster rechts: timeout of 15000ms exceeded
2026-04-18 14:27:09.209  - warn: awtrix-light.0 (64186) [refreshApp] Unable to remove hidden app "batlow": AxiosError: timeout of 10000ms exceeded
2026-04-18 18:55:15.804  - warn: awtrix-light.0 (64186) (custom?name=soltotal) Unable to update custom app "soltotal": AxiosError: timeout of 10000ms exceeded
echad@chet:~ $
</code></pre>
<p dir="auto">Das kann ich dann auch ohne LogParser oder sowas lesen.</p>
]]></description><link>https://forum.iobroker.net/post/1335215</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335215</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 18 Apr 2026 17:29:27 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 17:22:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
Nach dem Update, usrmod und ein erneuter Versionswechsels des Adapters ist alles ok:</p>
<p dir="auto"></p><section class="spoiler-wrapper"><button class="spoiler-control btn btn-default">Spoiler</button><section style="display:none" class="spoiler-content"><p></p>
<pre><code>$ iobroker upgrade vis-2-widgets-inventwo@0.6.5 --debug
Update vis-2-widgets-inventwo from @0.6.4 to @0.6.5
NPM version: 10.9.7
Installing iobroker.vis-2-widgets-inventwo@0.6.5... (System call)
changed 1 package in 2s352 packages are looking for funding run `npm fund` for details
Updating objects from io-package.json for adapter "vis-2-widgets-inventwo" with version "0.6.5"
Update "system.adapter.vis-2-widgets-inventwo.0"
upload [0] vis-2-widgets-inventwo.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-inventwo/admin/vis-2-widgets-inventwo.png vis-2-widgets-inventwo.png image/png
Process exited with code 0
</code></pre>
<p dir="auto">Auch das diag sieht für mich ok aus:</p>
<pre><code>```bash
Script v.2026-01-31
*** BASE SYSTEM ***
Operating System: Debian GNU/Linux 13 (trixie)
Static hostname: ioBroker-prox
      Icon name: computer-vm
        Chassis: vm 🖴
   AF_VSOCK CID: 1
 Virtualization: kvm
         Kernel: Linux 6.12.74+deb13+1-amd64
   Architecture: x86-64
Hardware Vendor: QEMU
 Hardware Model: Standard PC _Q35 + ICH9, 2009_
Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
  Firmware Date: Tue 2014-04-01
   Firmware Age: 12y 2w 3d
OS is similar to:
model name      : QEMU Virtual CPU version 2.5+
Docker          : false
Virtualization  : kvm
Kernel          : x86_64
Userland        : 64 bit
Systemuptime and Load:
19:19:14 up  1:22,  2 users,  load average: 0.28, 0.25, 0.17
CPU threads: 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'trixie'!
*** TIME AND TIMEZONES ***
              Local time: Sat 2026-04-18 19:19:14 CEST
          Universal time: Sat 2026-04-18 17:19:14 UTC
                RTC time: Sat 2026-04-18 17:19:14
               Time zone: Europe/Vienna (CEST, +0200)
             NTP service: active
         RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
gfaigel
HOME=/home/gfaigel
GROUPS=gfaigel adm cdrom floppy sudo audio dip video plugdev netdev iobroker
iobroker
HOME=/home/iobroker
SUDO_HOME=/home/gfaigel
GROUPS=iobroker tty dialout audio video plugdev redis
*** DISPLAY-SERVER SETUP ***
Display-Server:         false
Unit display-manager.service could not be found.
Display-Manager:
Desktop:
Session:                tty
*** MEMORY ***
Mem:             10G        5.6G        3.3G        3.4M        1.8G        4.9G
Swap:           8.6G          0B        8.6G
Total:           19G        5.6G         11G
Active iob-Instances:   52
        9951 M total memory
        5322 M used memory
        4932 M active memory
        1376 M inactive memory
        3183 M free memory
         146 M buffer memory
        1591 M swap cache
        8189 M total swap
           0 M used swap
        8189 M free swap
top - 19:19:14 up  1:22,  2 users,  load average: 0.28, 0.25, 0.17
Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
%Cpu(s):  9.3 us,  2.3 sy,  0.0 ni, 88.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   9951.2 total,   3182.9 free,   5324.0 used,   1738.6 buff/cache
MiB Swap:   8190.0 total,   8190.0 free,      0.0 used.   4627.2 avail Mem
*** FAILED SERVICES ***
0 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  4.9G     0  4.9G   0% /dev
tmpfs          tmpfs     996M  708K  995M   1% /run
/dev/sda1      ext4       55G   20G   33G  38% /
tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
tmpfs          tmpfs     4.9G  2.6M  4.9G   1% /tmp
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
tmpfs          tmpfs     996M  8.0K  996M   1% /run/user/1000
[Sat Apr 18 17:56:26 2026] EXT4-fs (sda1): mounted filesystem cc29babb-816d-4628-a5f0-de4d1d09f393 ro with ordered data mode. Quota mode: none.
[Sat Apr 18 17:56:26 2026] EXT4-fs (sda1): re-mounted cc29babb-816d-4628-a5f0-de4d1d09f393 r/w.
Show mounted filesystems:
TARGET SOURCE    FSTYPE OPTIONS
/      /dev/sda1 ext4   rw,relatime,errors=remount-ro
/var:
5.2G    /var/
4.0G    /var/log
3.8G    /var/log/journal/6985862c63364d5e93cffdc681984609
983M    /var/cache
Archived and active journals take up 3.7G in the file system.
/opt/iobroker/backups:
253M    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
1.5G    /opt/iobroker/iobroker-data/
1.1G    /opt/iobroker/iobroker-data/files
379M    /opt/iobroker/iobroker-data/files/vis
371M    /opt/iobroker/iobroker-data/files/vis/widgets
283M    /opt/iobroker/iobroker-data/files/vis-2
49M     /opt/iobroker/iobroker-data/objects.jsonl
41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-DqJdyjgH.js.map
34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-CrLrNq4s.js.map
26M     /opt/iobroker/iobroker-data/states.jsonl
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
No Devices found 'by-id'
*** ZigBee Settings ***
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
*** NodeJS-Installation ***
/usr/bin/nodejs         v22.22.2
/usr/bin/node           v22.22.2
/usr/bin/npm            10.9.7
/usr/bin/npx            10.9.7
✓ Node.js installation is correct
nodejs:
 Installed: 22.22.2-1nodesource1
 Candidate: 22.22.2-1nodesource1
 Version table:
*** 22.22.2-1nodesource1 1001
       500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
       100 /var/lib/dpkg/status
    22.22.1-1nodesource1 1001
    22.22.0-1nodesource1 1001
    22.21.0-1nodesource1 1001
    22.20.0-1nodesource1 1001
    22.19.0-1nodesource1 1001
    22.18.0-1nodesource1 1001
    22.17.1-1nodesource1 1001
    22.17.0-1nodesource1 1001
    22.16.0-1nodesource1 1001
    22.15.1-1nodesource1 1001
    22.15.0-1nodesource1 1001
    22.14.0-1nodesource1 1001
    22.13.1-1nodesource1 1001
    22.13.0-1nodesource1 1001
    22.12.0-1nodesource1 1001
    22.11.0-1nodesource1 1001
    22.10.0-1nodesource1 1001
    22.9.0-1nodesource1 1001
    22.8.0-1nodesource1 1001
    22.7.0-1nodesource1 1001
    22.6.0-1nodesource1 1001
    22.5.1-1nodesource1 1001
    22.5.0-1nodesource1 1001
    22.4.1-1nodesource1 1001
    22.4.0-1nodesource1 1001
    22.3.0-1nodesource1 1001
    22.2.0-1nodesource1 1001
    22.1.0-1nodesource1 1001
    22.0.0-1nodesource1 1001
    20.19.2+dfsg-1+deb13u2 500
       500 https://security.debian.org/debian-security trixie-security/main amd64 Packages
    20.19.2+dfsg-1 500
       500 https://deb.debian.org/debian trixie/main amd64 Packages
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: redis
Hosts:
ioBroker-prox       ioBroker-prox (version: 7.1.1, hostname: ioBroker-prox , alive, uptime: 4968)
Core adapters versions
js-controller:  7.1.1
admin:          7.8.20
javascript:     9.2.0
nodejs modules from github:     2
+-- iobroker.electrolux-aeg@0.0.5 (git+ssh://git@github.com/TA2k/ioBroker.electrolux-aeg.git#cdd3bdd3f76e96e5940fff159dcc82c19a531d95)
| +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
Adapter State
+ system.adapter.accuweather.0            : accuweather           : ioBroker-prox                            -  enabled
+ system.adapter.admin.0                  : admin                 : ioBroker-prox                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
+ system.adapter.alexa2.0                 : alexa2                : ioBroker-prox                            -  enabled
 system.adapter.alias-manager.0          : alias-manager         : ioBroker-prox                            -  enabled
 system.adapter.apg-info.0               : apg-info              : ioBroker-prox                            -  enabled
 system.adapter.awattar.0                : awattar               : ioBroker-prox                            -  enabled
+ system.adapter.awtrix-light.0           : awtrix-light          : ioBroker-prox                            -  enabled
+ system.adapter.backitup.0               : backitup              : ioBroker-prox                            -  enabled
+ system.adapter.bosesoundtouch.0         : bosesoundtouch        : ioBroker-prox                            -  enabled
+ system.adapter.bring.0                  : bring                 : ioBroker-prox                            -  enabled
+ system.adapter.bwt.0                    : bwt                   : ioBroker-prox                            -  enabled
+ system.adapter.bydhvs.0                 : bydhvs                : ioBroker-prox                            -  enabled
+ system.adapter.cloud.0                  : cloud                 : ioBroker-prox                            -  enabled
+ system.adapter.daswetter.0              : daswetter             : ioBroker-prox                            -  enabled
+ system.adapter.denon.0                  : denon                 : ioBroker-prox                            -  enabled
 system.adapter.devices.0                : devices               : ioBroker-prox                            -  enabled
+ system.adapter.discovery.0              : discovery             : ioBroker-prox                            -  enabled
+ system.adapter.electrolux-aeg.0         : electrolux-aeg        : ioBroker-prox                            -  enabled
+ system.adapter.email.0                  : email                 : ioBroker-prox                            -  enabled
+ system.adapter.energiefluss.0           : energiefluss          : ioBroker-prox                            -  enabled
+ system.adapter.enigma2.0                : enigma2               : ioBroker-prox                            -  enabled
+ system.adapter.epson_ecotank_et_2750.0  : epson_ecotank_et_2750 : ioBroker-prox                            -  enabled
+ system.adapter.frigate.0                : frigate               : ioBroker-prox                            -  enabled
+ system.adapter.fronius-solarweb.0       : fronius-solarweb      : ioBroker-prox                            -  enabled
+ system.adapter.fronius.0                : fronius               : ioBroker-prox                            -  enabled
 system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker-prox                            -  enabled
 system.adapter.fuelpricemonitor.1       : fuelpricemonitor      : ioBroker-prox                            -  enabled
+ system.adapter.fullcalendar.0           : fullcalendar          : ioBroker-prox                            -  enabled
+ system.adapter.harmony.0                : harmony               : ioBroker-prox                            -  enabled
 system.adapter.hue.0                    : hue                   : ioBroker-prox                            - disabled, port: 80
 system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-prox                            -  enabled
 system.adapter.icons-material-png.0     : icons-material-png    : ioBroker-prox                            -  enabled
 system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker-prox                            -  enabled
 system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-prox                            -  enabled
 system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-prox                            -  enabled
 system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker-prox                            -  enabled
+ system.adapter.influxdb.0               : influxdb              : ioBroker-prox                            -  enabled, port: 8086
+ system.adapter.iot.0                    : iot                   : ioBroker-prox                            -  enabled
+ system.adapter.jablotron.0              : jablotron             : ioBroker-prox                            -  enabled
+ system.adapter.javascript.0             : javascript            : ioBroker-prox                            -  enabled
+ system.adapter.lgtv.0                   : lgtv                  : ioBroker-prox                            -  enabled
 system.adapter.material.0               : material              : ioBroker-prox                            -  enabled
+ system.adapter.mercedesme.0             : mercedesme            : ioBroker-prox                            -  enabled
+ system.adapter.mielecloudservice.0      : mielecloudservice     : ioBroker-prox                            -  enabled
 system.adapter.modbus.0                 : modbus                : ioBroker-prox                            - disabled
+ system.adapter.mqtt.0                   : mqtt                  : ioBroker-prox                            -  enabled, port: 1883, bind: 0.0.0.0
+ system.adapter.nut.0                    : nut                   : ioBroker-prox                            -  enabled
 system.adapter.nut.1                    : nut                   : ioBroker-prox                            - disabled
+ system.adapter.onkyo.0                  : onkyo                 : ioBroker-prox                            -  enabled
 system.adapter.openweathermap.0         : openweathermap        : ioBroker-prox                            -  enabled
+ system.adapter.ping.0                   : ping                  : ioBroker-prox                            -  enabled
+ system.adapter.proxmox.0                : proxmox               : ioBroker-prox                            -  enabled, port: 8006
+ system.adapter.pushover.0               : pushover              : ioBroker-prox                            -  enabled
+ system.adapter.reolink.0                : reolink               : ioBroker-prox                            -  enabled
+ system.adapter.rest-api.0               : rest-api              : ioBroker-prox                            -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
+ system.adapter.scenes.0                 : scenes                : ioBroker-prox                            -  enabled
+ system.adapter.shelly.0                 : shelly                : ioBroker-prox                            -  enabled, port: 1888, bind: 0.0.0.0
+ system.adapter.simple-api.0             : simple-api            : ioBroker-prox                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
+ system.adapter.sql.0                    : sql                   : ioBroker-prox                            -  enabled, port: 5432
 system.adapter.synology.0               : synology              : ioBroker-prox                            - disabled, port: 5001
+ system.adapter.vaillant.0               : vaillant              : ioBroker-prox                            -  enabled
 system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker-prox                            -  enabled
 system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker-prox                            -  enabled
 system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker-prox                            -  enabled
 system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker-prox                            -  enabled
 system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: ioBroker-prox                            -  enabled
+ system.adapter.vis-2.0                  : vis-2                 : ioBroker-prox                            -  enabled
 system.adapter.vis-bars.0               : vis-bars              : ioBroker-prox                            -  enabled
 system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker-prox                            -  enabled
 system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker-prox                            -  enabled
 system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-prox                            -  enabled
 system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker-prox                            -  enabled
 system.adapter.vis-history.0            : vis-history           : ioBroker-prox                            -  enabled
 system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-prox                            -  enabled
 system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker-prox                            -  enabled
+ system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-prox                            -  enabled
 system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker-prox                            -  enabled
 system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-prox                            -  enabled
 system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker-prox                            -  enabled
 system.adapter.vis-map.0                : vis-map               : ioBroker-prox                            -  enabled
 system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker-prox                            -  enabled
 system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker-prox                            -  enabled
 system.adapter.vis-material.0           : vis-material          : ioBroker-prox                            -  enabled
 system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker-prox                            -  enabled
 system.adapter.vis-players.0            : vis-players           : ioBroker-prox                            -  enabled
 system.adapter.vis-plumb.0              : vis-plumb             : ioBroker-prox                            -  enabled
 system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker-prox                            -  enabled
 system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-prox                            -  enabled
 system.adapter.vis-weather.0            : vis-weather           : ioBroker-prox                            -  enabled
 system.adapter.vis.0                    : vis                   : ioBroker-prox                            -  enabled
+ system.adapter.web.0                    : web                   : ioBroker-prox                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker-prox                            -  enabled
+ system.adapter.wifilight.0              : wifilight             : ioBroker-prox                            -  enabled
 system.adapter.wlanthermo-nano.0        : wlanthermo-nano       : ioBroker-prox                            - disabled
 system.adapter.wlanthermo-nano.1        : wlanthermo-nano       : ioBroker-prox                            - disabled
 system.adapter.wled.0                   : wled                  : ioBroker-prox                            - disabled
+ system.adapter.yahka.0                  : yahka                 : ioBroker-prox                            -  enabled
+ system.adapter.yahka.1                  : yahka                 : ioBroker-prox                            -  enabled
+ system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : ioBroker-prox                            -  enabled
+ instance is alive
ioBroker-Repositories
│ 0       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
│ 1       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
Active repo(s): beta
Upgrade policy: none
Installed ioBroker-Adapters
Used repository: beta
Adapter    "accuweather"  : 2.2.0    , installed 2.2.0
Adapter    "admin"        : 7.8.20   , installed 7.8.20
Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
Adapter    "alias-manager": 2.1.0    , installed 2.1.0
Adapter    "apg-info"     : 0.1.30   , installed 0.1.30
Adapter    "awattar"      : 1.0.6    , installed 1.0.6
Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
Adapter    "backitup"     : 3.3.17   , installed 3.3.17
Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
Adapter    "bring"        : 1.9.1    , installed 1.9.1
Adapter    "bwt"          : 0.1.2    , installed 0.1.2
Adapter    "bydhvs"       : 1.5.5    , installed 1.5.5
Adapter    "cloud"        : 6.0.1    , installed 6.0.1
Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
Adapter    "denon"        : 1.15.12  , installed 1.15.12
Adapter    "devices"      : 2.0.5    , installed 2.0.5
Adapter    "email"        : 2.0.4    , installed 2.0.4
Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
Adapter    "enigma2"      : 2.3.0    , installed 2.3.0
Adapter    "epson_ecotank_et_2750": 1.1.0, installed 1.1.0
Adapter    "frigate"      : 2.3.1    , installed 2.3.1
Adapter    "fronius"      : 2.2.0    , installed 2.2.0
Adapter    "fronius-solarweb": 0.1.1 , installed 0.1.1
Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
Adapter    "harmony"      : 2.1.0    , installed 2.1.0
Adapter    "hue"          : 3.16.2   , installed 3.16.2
Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
Adapter    "icons-material-png": 0.1.0, installed 0.1.0
Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
Adapter    "iot"          : 6.0.1    , installed 6.0.1
Adapter    "jablotron"    : 0.1.8    , installed 0.1.8
Adapter    "javascript"   : 9.2.0    , installed 9.2.0
Controller "js-controller": 7.1.1    , installed 7.1.1
Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
Adapter    "material"     : 1.3.1    , installed 1.3.1
Adapter    "mercedesme"   : 0.7.1    , installed 0.7.1
Adapter    "mielecloudservice": 6.5.12, installed 6.5.12
Adapter    "modbus"       : 8.1.3    , installed 8.1.3
Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
Adapter    "nut"          : 1.7.0    , installed 1.7.0
Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
Adapter    "openweathermap": 1.4.0   , installed 1.4.0
Adapter    "ping"         : 2.1.0    , installed 2.1.0
Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
Adapter    "pushover"     : 5.0.0    , installed 5.0.0
Adapter    "reolink"      : 1.4.2    , installed 1.4.2
Adapter    "rest-api"     : 4.0.1    , installed 4.0.1
Adapter    "scenes"       : 4.0.4    , installed 4.0.4
Adapter    "shelly"       : 10.6.1   , installed 10.6.1
Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
Adapter    "snmp"         : 3.4.0    , installed 3.4.0
Adapter    "socketio"     : 7.1.3    , installed 7.1.3
Adapter    "sql"          : 3.0.1    , installed 3.0.1
Adapter    "synology"     : 3.1.0    , installed 3.1.0
Adapter    "vaillant"     : 0.7.5    , installed 0.7.5
Adapter    "vis-2"        : 2.13.17  , installed 2.13.17
Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
Adapter    "vis-2-widgets-inventwo": 0.6.5, installed 0.6.5
Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
Adapter    "vis-2-widgets-radar-trap": 2.3.3, installed 2.3.3
Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.4
Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
Adapter    "vis-keyboard" : 0.0.3    , installed 0.0.3
Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
Adapter    "vis-material" : 0.2.0    , installed 0.2.0
Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
Adapter    "web"          : 8.1.0    , installed 8.1.0
Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
Adapter    "wlanthermo-nano": 0.2.1  , installed 0.2.1
Adapter    "wled"         : 0.9.2    , installed 0.9.2
Adapter    "ws"           : 4.1.0    , installed 4.1.0
Adapter    "yahka"        : 1.1.6    , installed 1.1.6
Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
Objects and States
Objects:        38036
States:         32120
Hit:1 https://security.debian.org/debian-security trixie-security InRelease
Hit:2 https://deb.debian.org/debian trixie InRelease
Hit:3 https://deb.debian.org/debian trixie-updates InRelease
Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
Reading package lists...
Pending systemupdates: 0
*** Listening Ports ***
tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          6742       1030/exim4
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7683       1026/iobroker.js-co
tcp        0      0 0.0.0.0:40803           0.0.0.0:*               LISTEN      1001       10832      1725/io.yahka.0
tcp        0      0 127.0.0.1:35603         0.0.0.0:*               LISTEN      1001       158383     1725/io.yahka.0
tcp        0      0 0.0.0.0:34681           0.0.0.0:*               LISTEN      1001       11018      1850/io.yahka.1
tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1001       9663       1686/io.shelly.0
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1127       1/init
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6610       751/sshd: /usr/sbin
tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          6532       715/vsftpd
tcp        0      0 0.0.0.0:9080            0.0.0.0:*               LISTEN      1001       223042     93118/nc
tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        5800       690/redis-server 12
tcp        0      0 127.0.0.1:39469         0.0.0.0:*               LISTEN      1001       14360      1725/io.yahka.0
tcp6       0      0 ::1:6379                :::*                    LISTEN      109        5801       690/redis-server 12
tcp6       0      0 :::61991                :::*                    LISTEN      1001       10654      1596/io.harmony.0
tcp6       0      0 :::8093                 :::*                    LISTEN      1001       14542      2122/io.rest-api.0
tcp6       0      0 :::8087                 :::*                    LISTEN      1001       13803      2139/io.simple-api.
tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14863      2681/io.web.0
tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6777       1059/io.admin.0
tcp6       0      0 :::1889                 :::*                    LISTEN      1001       17554      3205/io.frigate.0
tcp6       0      0 :::111                  :::*                    LISTEN      0          1128       1/init
tcp6       0      0 :::22                   :::*                    LISTEN      0          6620       751/sshd: /usr/sbin
tcp6       0      0 ::1:25                  :::*                    LISTEN      0          6743       1030/exim4
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11023      1850/io.yahka.1
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11022      1850/io.yahka.1
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       9024       1725/io.yahka.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       9023       1725/io.yahka.0
udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          486        1/init
udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       10655      1596/io.harmony.0
udp6       0      0 :::111                  :::*                                0          1129       1/init
2026-04-18 19:17:57.579  - info: host.ioBroker-prox instance system.adapter.openweathermap.0 having pid 90573 terminated with code 0 (NO_ERROR)
2026-04-18 19:18:00.002  - info: mqtt.0 (1633) send2Server mqtt.0.Smarthome.nspanel_9BC8E8.cmnd.CustomSend[Smarthome/nspanel_9BC8E8/cmnd/CustomSend]
2026-04-18 19:18:03.351  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:18:13.731  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:18:24.332  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:18:29.186  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-OG', payload '{"last_seen":"2026-04-18T17:18:29.176Z","linkquality":58,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:18:29.671  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-OG', payload '{"last_seen":"2026-04-18T17:18:29.661Z","linkquality":58,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:18:34.746  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:18:36.885  - info: web.0 (2681) &lt;== Disconnect system.user.admin from ::ffff:192.168.10.32 vis.0
2026-04-18 19:18:37.593  - info: shelly.0 (1686) [MQTT] Client Disconnect: 192.168.10.170 (shellyht / shellyht-95645D / SHHT-1#95645D#1)
2026-04-18 19:18:39.878  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-KG', payload '{"last_seen":"2026-04-18T17:18:39.868Z","linkquality":47,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:18:41.063  - info: frigate.0 (3205) Notification sending active but no image available for type person state Event After
2026-04-18 19:18:41.161  - info: frigate.0 (3205) Notification sending active but no image available for type person state Event After
2026-04-18 19:18:42.159  - info: web.0 (2681) ==&gt; Connected system.user.admin from ::ffff:192.168.10.32
2026-04-18 19:18:42.471  - info: frigate.0 (3205) Clip sending active but no clip available
2026-04-18 19:18:45.122  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:18:55.499  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:19:00.001  - info: mqtt.0 (1633) send2Server mqtt.0.Smarthome.nspanel_9BC8E8.cmnd.CustomSend[Smarthome/nspanel_9BC8E8/cmnd/CustomSend]
2026-04-18 19:19:05.005  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/EsszimmerVitrine', payload '{"brightness":254,"last_seen":"2026-04-18T17:19:04.995Z","linkquality":218,"state":"OFF","update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-transformer_release_prod_v587753009_17d32c23-151f-44cb-a947-4c13a78f36e6.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:19:05.934  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:19:13.163  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/EsszimmerVitrine', payload '{"brightness":254,"last_seen":"2026-04-18T17:19:13.153Z","linkquality":218,"state":"OFF","update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-transformer_release_prod_v587753009_17d32c23-151f-44cb-a947-4c13a78f36e6.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:19:13.164  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/EsszimmerVitrine', payload '{"brightness":254,"last_seen":"2026-04-18T17:19:13.153Z","linkquality":218,"state":"ON","update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-transformer_release_prod_v587753009_17d32c23-151f-44cb-a947-4c13a78f36e6.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:19:16.351  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:19:26.747  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:19:37.135  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
</code></pre>
<pre><code>[/s]
Vielen  Dank!!!</code></pre>
</section></section>]]></description><link>https://forum.iobroker.net/post/1335214</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335214</guid><dc:creator><![CDATA[tritor]]></dc:creator><pubDate>Sat, 18 Apr 2026 17:22:24 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 17:17:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tritor" aria-label="Profile: tritor">@<bdi>tritor</bdi></a> <a href="/post/1335209">sagte</a>:</p>
<p dir="auto">Hint: You are currently not seeing messages from other users and the system.<br />
Users in groups 'adm', 'systemd-journal' can see all messages.</p>
</blockquote>
<p dir="auto">Setz den user 'gfaigel' in die Gruppe 'adm' rein:</p>
<pre><code>sudo usermod -aG adm gfaigel
</code></pre>
<p dir="auto">gfaigel muss sich danach einmal aus- und wieder einloggen.</p>
]]></description><link>https://forum.iobroker.net/post/1335213</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335213</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 18 Apr 2026 17:17:43 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 17:13:17 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">No module named 'distutils'</p>
</blockquote>
<p dir="auto">Beheben per</p>
<pre><code>sudo apt update
sudo apt install python3-setuptools
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1335211</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335211</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 18 Apr 2026 17:13:17 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 17:08:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tritor" aria-label="Profile: tritor">@<bdi>tritor</bdi></a></p>
<p dir="auto">Verwende bitte das Log wie oben angegeben aus deinem Terminal...</p>
]]></description><link>https://forum.iobroker.net/post/1335210</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335210</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 18 Apr 2026 17:08:35 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 17:13:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a><br />
habe mal den Adapter Vis 2 invento Widgets zum Testen auf eine andere Version  (0.6.5 -&gt; 0.6.4) gestellt.</p>
<p dir="auto">Hier das log dazu.</p>
<pre><code>$ iobroker upgrade vis-2-widgets-inventwo@0.6.4 --debug
Update vis-2-widgets-inventwo from @0.6.5 to @0.6.4
NPM version: 10.9.7
Installing iobroker.vis-2-widgets-inventwo@0.6.4... (System call)
gyp info using node-gyp@8.4.1gyp info using node@22.22.2 | linux | x64
(node:955370) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
gyp http GET https://nodejs.org/download/release/v22.22.2/node-v22.22.2-headers.tar.gz
gyp http 200 https://nodejs.org/download/release/v22.22.2/node-v22.22.2-headers.tar.gz
gyp http GET https://nodejs.org/download/release/v22.22.2/SHASUMS256.txt
gyp http 200 https://nodejs.org/download/release/v22.22.2/SHASUMS256.txt
gyp info spawn args '/home/iobroker/.cache/node-gyp/22.22.2/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.22.2',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.22.2/&lt;(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/cpu-features',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',
gyp info spawn args ]
File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in &lt;module&gt; import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in &lt;module&gt; import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in &lt;module&gt; from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'
gyp ERR! configure error
gyp ERR! cwd /opt/iobroker/node_modules/cpu-featuresgyp ERR! node -v v22.22.2gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
changed 1 package in 3s
Adapter "system.adapter.vis-2.0" restarted.Updating objects from io-package.json for adapter "vis-2-widgets-inventwo" with version "0.6.4"
</code></pre>
<p dir="auto">Hier auch die diag:</p>
<pre><code class="language-bash">Script v.2026-01-31
*** BASE SYSTEM ***
         Chassis: vm 🖴
    AF_VSOCK CID: 1
  Virtualization: kvm
OS is similar to:
Docker          : false
Kernel          : x86_64
Userland        : 64 bit
 19:09:49 up  1:13,  2 users,  load average: 0.16, 0.18, 0.13
CPU threads: 4
               Local time: Sat 2026-04-18 19:09:49 CEST
           Universal time: Sat 2026-04-18 17:09:49 UTC
                 RTC time: Sat 2026-04-18 17:09:49
              NTP service: active
          RTC in local TZ: no
gfaigel
HOME=/home/gfaigel
GROUPS=gfaigel cdrom floppy sudo audio dip video plugdev netdev iobroker
iobroker
HOME=/home/iobroker
Display-Manager:
Desktop:
Session:                tty
*** MEMORY ***
Mem:             10G        5.5G        3.5G        3.4M        1.7G        5.0G
Swap:           8.6G          0B        8.6G
Total:           19G        5.5G         12G
         9951 M total memory
         5208 M used memory
         4791 M active memory
         1333 M inactive memory
         3385 M free memory
          140 M buffer memory
         1507 M swap cache
         8189 M total swap
            0 M used swap
         8189 M free swap
top - 19:09:50 up  1:13,  2 users,  load average: 0.16, 0.18, 0.13
Tasks: 207 total,   1 running, 206 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.0 us,  2.4 sy,  0.0 ni, 97.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   9951.2 total,   3384.8 free,   5209.2 used,   1648.9 buff/cache
MiB Swap:   8190.0 total,   8190.0 free,      0.0 used.   4742.0 avail Mem
*** FILESYSTEM ***
tmpfs          tmpfs     996M  720K  995M   1% /run
tmpfs          tmpfs     996M  8.0K  996M   1% /run/user/0
/var:
5.2G    /var/
4.0G    /var/log
983M    /var/cache
Archived and active journals take up 45.4M in the file system.
USB-Devices by-id:
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
/usr/bin/npm            10.9.7
/usr/bin/npx            10.9.7
nodejs:
  Version table:
     20.19.2+dfsg-1 500
ioBroker Status
Objects type: jsonl
States  type: redis
Hosts:
ioBroker-prox       ioBroker-prox (version: 7.1.1, hostname: ioBroker-prox , alive, uptime: 4398)
admin:          7.8.20
javascript:     9.2.0
Adapter State
+ instance is alive
Objects and States
Objects:        38036
States:         32120
tcp        0      0 0.0.0.0:9080            0.0.0.0:*               LISTEN      1001       195398     81691/nc
2026-04-18 19:08:23.538  - info: shelly.0 (1686) [MQTT] Device with client id "shellyht-B89BA4" connected from 192.168.10.130!
2026-04-18 19:08:23.993  - info: shelly.0 (1686) [MQTT] Device with client id "shellyht-B89BA4" initialized.
2026-04-18 19:08:27.436  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:08:36.742  - info: web.0 (2681) &lt;== Disconnect system.user.admin from ::ffff:192.168.10.32 vis.0
2026-04-18 19:08:37.809  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:08:37.874  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-KG', payload '{"last_seen":"2026-04-18T17:08:37.858Z","linkquality":51,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:08:41.369  - info: web.0 (2681) ==&gt; Connected system.user.admin from ::ffff:192.168.10.32
2026-04-18 19:08:46.836  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/EsszimmerVitrine', payload '{"brightness":254,"last_seen":"2026-04-18T17:08:46.819Z","linkquality":218,"state":"OFF","update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-transformer_release_prod_v587753009_17d32c23-151f-44cb-a947-4c13a78f36e6.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:08:48.427  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:08:51.383  - info: shelly.0 (1686) [MQTT] Client Disconnect: 192.168.10.130 (shellyht / shellyht-B89BA4 / SHHT-1#B89BA4#1)
2026-04-18 19:08:58.840  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:09:00.001  - info: mqtt.0 (1633) send2Server mqtt.0.Smarthome.nspanel_9BC8E8.cmnd.CustomSend[Smarthome/nspanel_9BC8E8/cmnd/CustomSend]
2026-04-18 19:09:09.238  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:09:19.655  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:09:30.074  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:09:31.500  - info: zigbee2mqtt.0 (1781) z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Repeater-EG', payload '{"last_seen":"2026-04-18T17:09:31.484Z","linkquality":58,"update":{"installed_version":587753009,"latest_release_notes":"https://ww8.ikea.com/ikeahomesmart/releasenotes/releasenotes.html","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/IKEA/tradfri-signal-repeater_release_prod_v587753009_3ce8f096-bd12-4b2c-b66e-51dc9f2637dc.ota","latest_version":587753009,"state":"idle"}}'
2026-04-18 19:09:40.502  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:09:44.086  - info: frigate.0 (3205) Notification sending active but no image available for type person state Event After
2026-04-18 19:09:44.296  - info: frigate.0 (3205) Notification sending active but no image available for type person state Event After
2026-04-18 19:09:44.715  - info: frigate.0 (3205) Clip sending active but no clip available
2026-04-18 19:09:46.189  - info: shelly.0 (1686) [MQTT] Device with client id "shellyht-95645D" connected from 192.168.10.170!
2026-04-18 19:09:46.668  - info: shelly.0 (1686) [MQTT] Device with client id "shellyht-95645D" initialized.
2026-04-18 19:09:50.936  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
2026-04-18 19:10:00.001  - info: mqtt.0 (1633) send2Server mqtt.0.Smarthome.nspanel_9BC8E8.cmnd.CustomSend[Smarthome/nspanel_9BC8E8/cmnd/CustomSend]
2026-04-18 19:10:01.364  - info: reolink.0 (2723) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "boolean"
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1335209</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335209</guid><dc:creator><![CDATA[tritor]]></dc:creator><pubDate>Sat, 18 Apr 2026 17:13:02 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 15:39:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tritor" aria-label="Profile: tritor">@<bdi>tritor</bdi></a></p>
<p dir="auto">Nix 'ausschneiden',  das Log wird in Gänze gebraucht.</p>
]]></description><link>https://forum.iobroker.net/post/1335204</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335204</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 18 Apr 2026 15:39:18 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 15:33:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tritor" aria-label="Profile: tritor">@<bdi>tritor</bdi></a></p>
<p dir="auto">Und im Log schlägt sich das wie nieder?</p>
]]></description><link>https://forum.iobroker.net/post/1335203</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335203</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 18 Apr 2026 15:33:49 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 15:29:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliverio" aria-label="Profile: OliverIO">@<bdi>OliverIO</bdi></a></p>
<p dir="auto">Ja da gibt es jede Menge Auflistung.<br />
<pre><code>node_modules/prompt/node_modules/winston/lib/winston/container.js
node_modules/iobroker.admin/adminWww/static/js/worker-html.js
node_modules/iobroker.admin/adminWww/static/js/worker-javascript.js
node_modules/iobroker.admin/adminWww/assets/ace-B1WbEy8J.js
node_modules/iobroker.admin/adminWww/assets/Objects-CQ1Cgg6L.js
node_modules/iobroker.admin/adminWww/assets/leaflet-src-B651YTWC.js
node_modules/iobroker.admin/adminWww/assets/index-Cy4zkLZ7.js
node_modules/iobroker.admin/adminWww/assets/bootstrap-D0re3WSJ.js
node_modules/iobroker.admin/adminWww/assets/index-DA90dn-y.js
node_modules/iobroker.admin/admin/custom/assets/index-JHWyZnE9.js
node_modules/iobroker.admin/admin/custom/assets/index-BqaC8TTV.js
node_modules/iobroker.admin/admin/custom/assets/index-lwTE6AOa.js
node_modules/iobroker.admin/admin/custom/assets/index-fHKF7cIy.js
node_modules/iobroker.admin/admin/custom/assets/AdminComponentEasyAccessSet__mf_v__runtimeInit__mf_v__-JbSPU0nV.js
node_modules/iobroker.admin/admin/custom/assets/index-C2cQRe9d.js
node_modules/iobroker.admin/admin/custom/assets/index-DI-4AL4q.js
node_modules/iobroker.admin/admin/custom/assets/AdminComponentEasyAccessSet__mf_v__runtimeInit__mf_v__-CbzMf-XP.js
node_modules/iobroker.admin/admin/custom/assets/index-Cgl0l3l6.js
node_modules/iobroker.admin/admin/custom/assets/index-CcWdaO-A.js
node_modules/iobroker.admin/admin/custom/assets/index-BTEHfIqN.js
node_modules/iobroker.admin/admin/custom/assets/index-WGNhBVhU.js
node_modules/iobroker.admin/admin/custom/assets/index-DsmGf2-7.js
node_modules/iobroker.admin/admin/custom/assets/index-DIVai5gZ.js
node_modules/esprima/dist/esprima.js
node_modules/rxjs/_esm5/internal/SubjectSubscription.js
node_modules/rxjs/_esm5/internal/scheduler/AsyncAction.js
node_modules/rxjs/_esm5/internal/scheduler/AsapAction.js
node_modules/rxjs/_esm5/internal/scheduler/AsyncScheduler.js
node_modules/rxjs/_esm5/internal/scheduler/AsapScheduler.js
node_modules/rxjs/_esm5/internal/scheduler/QueueAction.js
node_modules/rxjs/_esm5/internal/scheduler/QueueScheduler.js
node_modules/rxjs/_esm5/internal/scheduler/AnimationFrameScheduler.js
node_modules/rxjs/_esm5/internal/scheduler/VirtualTimeScheduler.js
node_modules/rxjs/_esm5/internal/scheduler/AnimationFrameAction.js
node_modules/rxjs/_esm5/internal/scheduler/Action.js
node_modules/rxjs/_esm5/internal/observable/zip.js
node_modules/rxjs/_esm5/internal/observable/race.js
node_modules/rxjs/_esm5/internal/observable/SubscribeOnObservable.js
node_modules/rxjs/_esm5/internal/observable/dom/WebSocketSubject.js
node_modules/rxjs/_esm5/internal/observable/dom/AjaxObservable.js
node_modules/rxjs/_esm5/internal/observable/ConnectableObservable.js
node_modules/rxjs/_esm5/internal/observable/combineLatest.js
node_modules/rxjs/_esm5/internal/operators/refCount.js
node_modules/rxjs/_esm5/internal/operators/expand.js
node_modules/rxjs/_esm5/internal/operators/skipUntil.js
node_modules/rxjs/_esm5/internal/operators/debounce.js
node_modules/rxjs/_esm5/internal/operators/single.js
node_modules/rxjs/_esm5/internal/operators/pairwise.js
node_modules/rxjs/_esm5/internal/operators/exhaust.js
node_modules/rxjs/_esm5/internal/operators/take.js
node_modules/rxjs/_esm5/internal/operators/repeat.js
node_modules/rxjs/_esm5/internal/operators/sequenceEqual.js
node_modules/rxjs/_esm5/internal/operators/skipLast.js
node_modules/rxjs/_esm5/internal/operators/audit.js
node_modules/rxjs/_esm5/internal/operators/map.js
node_modules/rxjs/_esm5/internal/operators/every.js
node_modules/rxjs/_esm5/internal/operators/throttleTime.js
node_modules/rxjs/_esm5/internal/operators/takeWhile.js
node_modules/rxjs/_esm5/internal/operators/ignoreElements.js
node_modules/rxjs/_esm5/internal/operators/delay.js
node_modules/rxjs/_esm5/internal/operators/takeLast.js
node_modules/rxjs/_esm5/internal/operators/bufferWhen.js
node_modules/rxjs/_esm5/internal/operators/skip.js
node_modules/rxjs/_esm5/internal/operators/windowToggle.js
node_modules/rxjs/_esm5/internal/operators/mergeScan.js
node_modules/rxjs/_esm5/internal/operators/count.js
node_modules/rxjs/_esm5/internal/operators/windowCount.js
node_modules/rxjs/_esm5/internal/operators/buffer.js
node_modules/rxjs/_esm5/internal/operators/throttle.js
node_modules/rxjs/_esm5/internal/operators/sampleTime.js
node_modules/rxjs/_esm5/internal/operators/skipWhile.js
node_modules/rxjs/_esm5/internal/operators/takeUntil.js
node_modules/rxjs/_esm5/internal/operators/isEmpty.js
node_modules/rxjs/_esm5/internal/operators/bufferToggle.js
node_modules/rxjs/_esm5/internal/operators/defaultIfEmpty.js
node_modules/rxjs/_esm5/internal/operators/tap.js
node_modules/rxjs/_esm5/internal/operators/distinct.js
node_modules/rxjs/_esm5/internal/operators/groupBy.js
node_modules/rxjs/_esm5/internal/operators/catchError.js
node_modules/rxjs/_esm5/internal/operators/find.js
node_modules/rxjs/_esm5/internal/operators/bufferCount.js
node_modules/rxjs/_esm5/internal/operators/timeoutWith.js
node_modules/rxjs/_esm5/internal/operators/throwIfEmpty.js
node_modules/rxjs/_esm5/internal/operators/repeatWhen.js
node_modules/rxjs/_esm5/internal/operators/withLatestFrom.js
node_modules/rxjs/_esm5/internal/operators/filter.js
node_modules/rxjs/_esm5/internal/operators/exhaustMap.js
node_modules/rxjs/_esm5/internal/operators/delayWhen.js
node_modules/rxjs/_esm5/internal/operators/dematerialize.js
node_modules/rxjs/_esm5/internal/operators/retry.js
node_modules/rxjs/_esm5/internal/operators/materialize.js
node_modules/rxjs/_esm5/internal/operators/retryWhen.js
node_modules/rxjs/_esm5/internal/operators/onErrorResumeNext.js
node_modules/rxjs/_esm5/internal/operators/mapTo.js
node_modules/rxjs/_esm5/internal/operators/bufferTime.js
node_modules/rxjs/_esm5/internal/operators/sample.js
node_modules/rxjs/_esm5/internal/operators/scan.js
node_modules/rxjs/_esm5/internal/operators/mergeMap.js
node_modules/rxjs/_esm5/internal/operators/switchMap.js
node_modules/rxjs/_esm5/internal/operators/window.js
node_modules/rxjs/_esm5/internal/operators/debounceTime.js
node_modules/rxjs/_esm5/internal/operators/windowTime.js
node_modules/rxjs/_esm5/internal/operators/windowWhen.js
node_modules/rxjs/_esm5/internal/operators/finalize.js
node_modules/rxjs/_esm5/internal/operators/distinctUntilChanged.js
node_modules/rxjs/_esm5/internal/operators/observeOn.js
node_modules/rxjs/_esm5/internal/BehaviorSubject.js
node_modules/rxjs/_esm5/internal/OuterSubscriber.js
node_modules/rxjs/_esm5/internal/Subscriber.js
node_modules/rxjs/_esm5/internal/innerSubscribe.js
node_modules/rxjs/_esm5/internal/AsyncSubject.js
node_modules/rxjs/_esm5/internal/ReplaySubject.js
node_modules/rxjs/_esm5/internal/testing/HotObservable.js
node_modules/rxjs/_esm5/internal/testing/TestScheduler.js
node_modules/rxjs/_esm5/internal/testing/ColdObservable.js
node_modules/rxjs/_esm5/internal/InnerSubscriber.js
node_modules/rxjs/_esm5/internal/Subject.js
node_modules/rxjs/internal/SubjectSubscription.js
node_modules/rxjs/internal/scheduler/AsyncAction.js
node_modules/rxjs/internal/scheduler/AsapAction.js
node_modules/rxjs/internal/scheduler/AsyncScheduler.js
node_modules/rxjs/internal/scheduler/AsapScheduler.js
node_modules/rxjs/internal/scheduler/QueueAction.js
node_modules/rxjs/internal/scheduler/QueueScheduler.js
node_modules/rxjs/internal/scheduler/AnimationFrameScheduler.js
node_modules/rxjs/internal/scheduler/VirtualTimeScheduler.js
node_modules/rxjs/internal/scheduler/AnimationFrameAction.js
node_modules/rxjs/internal/scheduler/Action.js
node_modules/rxjs/internal/observable/zip.js
node_modules/rxjs/internal/observable/race.js
node_modules/rxjs/internal/observable/SubscribeOnObservable.js
node_modules/rxjs/internal/observable/dom/WebSocketSubject.js
node_modules/rxjs/internal/observable/dom/AjaxObservable.js
node_modules/rxjs/internal/observable/ConnectableObservable.js
node_modules/rxjs/internal/observable/combineLatest.js
node_modules/rxjs/internal/operators/refCount.js
node_modules/rxjs/internal/operators/expand.js
node_modules/rxjs/internal/operators/skipUntil.js
node_modules/rxjs/internal/operators/debounce.js
node_modules/rxjs/internal/operators/single.js
node_modules/rxjs/internal/operators/pairwise.js
node_modules/rxjs/internal/operators/exhaust.js
node_modules/rxjs/internal/operators/take.js
node_modules/rxjs/internal/operators/repeat.js
node_modules/rxjs/internal/operators/sequenceEqual.js
node_modules/rxjs/internal/operators/skipLast.js
node_modules/rxjs/internal/operators/audit.js
node_modules/rxjs/internal/operators/map.js
node_modules/rxjs/internal/operators/every.js
node_modules/rxjs/internal/operators/throttleTime.js
node_modules/rxjs/internal/operators/takeWhile.js
node_modules/rxjs/internal/operators/ignoreElements.js
node_modules/rxjs/internal/operators/delay.js
node_modules/rxjs/internal/operators/takeLast.js
node_modules/rxjs/internal/operators/bufferWhen.js
node_modules/rxjs/internal/operators/skip.js
node_modules/rxjs/internal/operators/windowToggle.js
node_modules/rxjs/internal/operators/mergeScan.js
node_modules/rxjs/internal/operators/count.js
node_modules/rxjs/internal/operators/windowCount.js
node_modules/rxjs/internal/operators/buffer.js
node_modules/rxjs/internal/operators/throttle.js
node_modules/rxjs/internal/operators/sampleTime.js
node_modules/rxjs/internal/operators/skipWhile.js
node_modules/rxjs/internal/operators/takeUntil.js
node_modules/rxjs/internal/operators/isEmpty.js
node_modules/rxjs/internal/operators/bufferToggle.js
node_modules/rxjs/internal/operators/defaultIfEmpty.js
node_modules/rxjs/internal/operators/tap.js
node_modules/rxjs/internal/operators/distinct.js
node_modules/rxjs/internal/operators/groupBy.js
node_modules/rxjs/internal/operators/catchError.js
node_modules/rxjs/internal/operators/find.js
node_modules/rxjs/internal/operators/bufferCount.js
node_modules/rxjs/internal/operators/timeoutWith.js
node_modules/rxjs/internal/operators/throwIfEmpty.js
node_modules/rxjs/internal/operators/repeatWhen.js
node_modules/rxjs/internal/operators/withLatestFrom.js
node_modules/rxjs/internal/operators/filter.js
node_modules/rxjs/internal/operators/exhaustMap.js
node_modules/rxjs/internal/operators/delayWhen.js
node_modules/rxjs/internal/operators/dematerialize.js
node_modules/rxjs/internal/operators/retry.js
node_modules/rxjs/internal/operators/materialize.js
node_modules/rxjs/internal/operators/retryWhen.js
node_modules/rxjs/internal/operators/onErrorResumeNext.js
node_modules/rxjs/internal/operators/mapTo.js
node_modules/rxjs/internal/operators/bufferTime.js
node_modules/rxjs/internal/operators/sample.js
node_modules/rxjs/internal/operators/scan.js
node_modules/rxjs/internal/operators/mergeMap.js
node_modules/rxjs/internal/operators/switchMap.js
node_modules/rxjs/internal/operators/window.js
node_modules/rxjs/internal/operators/debounceTime.js
node_modules/rxjs/internal/operators/windowTime.js
node_modules/rxjs/internal/operators/windowWhen.js
node_modules/rxjs/internal/operators/finalize.js
node_modules/rxjs/internal/operators/distinctUntilChanged.js
node_modules/rxjs/internal/operators/observeOn.js
node_modules/rxjs/internal/BehaviorSubject.js
node_modules/rxjs/internal/OuterSubscriber.js
node_modules/rxjs/internal/Subscriber.js
node_modules/rxjs/internal/innerSubscribe.js
node_modules/rxjs/internal/AsyncSubject.js
node_modules/rxjs/internal/ReplaySubject.js
node_modules/rxjs/internal/testing/HotObservable.js
node_modules/rxjs/internal/testing/TestScheduler.js
node_modules/rxjs/internal/testing/ColdObservable.js
node_modules/rxjs/internal/InnerSubscriber.js
node_modules/rxjs/internal/Subject.js
node_modules/rxjs/bundles/rxjs.umd.js.map
node_modules/rxjs/bundles/rxjs.umd.min.js.map
node_modules/iobroker.scenes/admin/assets/index-B_g9fImg.js
node_modules/broker-factory/node_modules/tslib/README.md
node_modules/broker-factory/node_modules/tslib/modules/index.js
node_modules/broker-factory/node_modules/tslib/modules/index.d.ts
node_modules/broker-factory/node_modules/tslib/tslib.es6.js
node_modules/broker-factory/node_modules/tslib/tslib.js
node_modules/broker-factory/node_modules/tslib/tslib.d.ts
node_modules/broker-factory/node_modules/tslib/tslib.es6.mjs
node_modules/express/History.md
node_modules/iobroker.devices/www/assets/index-C8dcoZB8.js
node_modules/iobroker.devices/admin/assets/index-SJof8gXx.js
node_modules/acorn-globals/node_modules/acorn/dist/acorn.js
node_modules/acorn-globals/node_modules/acorn/dist/acorn_loose.js
node_modules/acorn-globals/node_modules/acorn/src/statement.js
node_modules/acorn-globals/node_modules/acorn/src/loose/statement.js
node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
node_modules/iobroker.fullcalendar/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
node_modules/iobroker.fullcalendar/admin/static/js/main.c13d3761.js
node_modules/iobroker.fullcalendar/admin/static/js/main.c13d3761.js.map
node_modules/dot-prop/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/dropbox-v2-api/dist/api.json
node_modules/dropbox-v2-api/src/api.json
node_modules/boxen/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/web-streams-polyfill/dist/ponyfill.mjs.map
node_modules/web-streams-polyfill/dist/ponyfill.js.map
node_modules/web-streams-polyfill/dist/ponyfill.es6.mjs.map
node_modules/web-streams-polyfill/dist/polyfill.min.js.map
node_modules/web-streams-polyfill/dist/polyfill.js.map
node_modules/web-streams-polyfill/dist/polyfill.mjs.map
node_modules/web-streams-polyfill/dist/polyfill.es6.mjs.map
node_modules/web-streams-polyfill/dist/ponyfill.es6.js.map
node_modules/web-streams-polyfill/dist/polyfill.es6.min.js.map
node_modules/web-streams-polyfill/dist/polyfill.es6.js.map
node_modules/worker-timers-broker/node_modules/tslib/README.md
node_modules/worker-timers-broker/node_modules/tslib/modules/index.js
node_modules/worker-timers-broker/node_modules/tslib/modules/index.d.ts
node_modules/worker-timers-broker/node_modules/tslib/tslib.es6.js
node_modules/worker-timers-broker/node_modules/tslib/tslib.js
node_modules/worker-timers-broker/node_modules/tslib/tslib.d.ts
node_modules/worker-timers-broker/node_modules/tslib/tslib.es6.mjs
node_modules/iobroker.vis/www/index.html
node_modules/iobroker.vis/www/widgets/basic.html
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/src_Components_VacuumIcon_js-src_Components_WindowClosed_js-node_modules_react-circular-slide-54a955.34b175bb.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_leaflet_dist_leaflet_css-node_modules_leaflet_dist_images_marker-icon-2x-281382.49131c79.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.9a6346f3.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.ef43cd96.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react_jsx-runtime_js-node_modules_leaflet_dist_leaflet_css-node_modules_-5c5561.c33b1195.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.199f0b4e.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.3c144320.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.837c9082.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react_jsx-runtime_js-node_modules_leaflet_dist_leaflet_css-node_modules_-5c5561.c33b1195.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.3ebf8200.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b24a2b7b.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_legend_install_js.432b0c40.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_react-circular-slider-svg_dist_index_js-node_modules_react_cjs_react-jsx-6278e5.433d1581.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/src_Generic_jsx-node_modules_react-circular-slider-svg_dist_index_js.f186cf20.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.ef43cd96.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.0cbfea69.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b80a2194.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.5884108b.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_grid_install_js-node_modules_echarts_lib_component-ad25e5.08cf7e1a.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.5884108b.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_uiw_react-color-shade-slider_esm_index_js-node_modules_uiw_react-color-s-589d31.5d75fa27.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts-for-react_lib_core_js-node_modules_react_jsx-runtime_js-node_mod-ecec97.b80a2194.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/static/js/vendors-node_modules_echarts_lib_component_legend_install_js.a18746ef.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__mf_v__runtimeInit__mf_v__-mPD03Tof.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-bcz2UOY-.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/index-DBeNUnty.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/Map-DvvTKot1.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
node_modules/iobroker.vis/www/widgets/materialdesign/lib.min.js
node_modules/iobroker.vis/www/widgets/materialdesign/lib/vuetify.js
node_modules/iobroker.vis/www/widgets/materialdesign/lib/material-components-web.js
node_modules/iobroker.vis/www/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
node_modules/iobroker.vis/www/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.ff34318e.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.f78ceb8d.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-liquid-gauge_lib_index_js.b2dda7e4.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-battery-gauge_dist_react-battery-gauge_esm_js.438236c2.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/static/js/vendors-node_modules_react-battery-gauge_dist_react-battery-gauge_esm_js.81e383f5.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-1RJxOR8B.js
node_modules/iobroker.vis/www/widgets/openweathermap/assets/index-DnuTl29g.js
node_modules/iobroker.vis/www/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_esm_index_js.49c59391.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_styled_js.25c617b0.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-8c1e82.52c5b0a7.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_isMuiElement_isMuiElement-90f327.68e2ebbd.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_index_js.6f996889.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.b58e6a51.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-8c1e82.52c5b0a7.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.a10fb2cd.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_index_js.6f996889.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js-n-287313.6a72939a.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.0fdc2efe.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.54021824.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.22192a38.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_styleFunctionSx_e-646437.480ef8e8.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_ZoomOutMap_js-node_modules_mui_material_Fab_Fab_js-no-238edc.c17f49ad.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_esm_index_js.4a02bfba.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_ZoomOutMap_js-node_modules_mui_material_Fab_Fab_js-no-de51fd.47eda6f0.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.7fc5de73.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_esm_isMuiElement_isMuiEle-37774c.5027f981.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.e83bdd95.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.7fc5de73.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.97b3e2d1.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.1749f755.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js-node_modules_mui_utils_esm_isMuiElement_isMuiEle-37774c.5027f981.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js-node_modules_mui_system_esm_u-30631c.5a5082ed.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.3ed26143.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Checkbox_Checkbox_js-node_modules_mui_material_FormControl_-ab667d.80eee493.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_createTheme_creat-8e35a0.19e0cbc7.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-09395c.bf487e67.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_colors_index_js-node_modules_mui_material_styles_index_js-n-287313.6a72939a.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_index_js-node_modules_mui_material_styles_Them-0bf85c.de23cbfb.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.97b3e2d1.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_styled_js.dae67faa.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_x-date-pickers_TimePicker_TimePicker_js-node_modules_babel_runtime_h-8a0c27.799842e9.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_x-date-pickers_AdapterDayjs_Adapte-b79734.de09a47b.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-5ae56a.fbe8964c.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-66a30d.53923d06.chunk.js
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-66a30d.53923d06.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_createTheme_creat-c54a24.aedd89eb.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-f5912f.292616a4.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_x-date-pickers_AdapterDayjs_Adapte-c0e24c.44cc9956.chunk.js.map
node_modules/iobroker.vis/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.48ced1a3.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b33a19f6.chunk.js.map
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/static/js/vendors-node_modules_mui_system_esm_index_js.2f5bd81f.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/static/js/vendors-node_modules_mui_material_index_js.108fbfef.chunk.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-CsZQ1K9c.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-BJeC_1Nc.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-4dZ_faDJ.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-CJ-kxqUy.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-B5RqNgEg.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-COK1nOKA.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BZKNvirX.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-DpCJnELL.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-Bp2scStG.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-Bk5B5ET5.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-B6mUFPf4.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-C-Jo2qj7.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-2uL955SU.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__mf_v__runtimeInit__mf_v__-CBbfFHA5.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-C5a4dcu-.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/index-BlUXZP4n.js
node_modules/iobroker.vis/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
node_modules/iobroker.vis/www/edit.html
node_modules/iobroker.vis/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js
node_modules/iobroker.vis/www/lib/ace/worker-html.js
node_modules/eventsource/example/eventsource-polyfill.js
node_modules/@js-sdsl/ordered-map/dist/esm/index.js
node_modules/@js-sdsl/ordered-map/dist/esm/index.js.map
node_modules/@js-sdsl/ordered-map/dist/umd/ordered-map.js
node_modules/@js-sdsl/ordered-map/dist/umd/ordered-map.min.js.map
node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.js
node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.min.js.map
node_modules/browser-sync-ui/node_modules/engine.io-client/dist/engine.io.js.map
node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.msgpack.min.js.map
node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.min.js.map
node_modules/browser-sync-ui/node_modules/socket.io-client/dist/socket.io.js.map
node_modules/nise/nise.js
node_modules/@iobroker/types/build/types.d.ts
node_modules/@iobroker/dev-server/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/@iobroker/js-controller-adapter/build/esm/lib/adapter/adapter.d.ts
node_modules/@iobroker/js-controller-adapter/build/esm/lib/adapter/adapter.js
node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.d.ts
node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js.map
node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.d.ts
node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js
node_modules/@iobroker/db-objects-redis/build/cjs/lib/objects/objectsInRedisClient.d.ts
node_modules/@iobroker/db-objects-redis/build/cjs/lib/objects/objectsInRedisClient.js.map
node_modules/iobroker.zigbee2mqtt/node_modules/tslib/README.md
node_modules/iobroker.zigbee2mqtt/node_modules/tslib/modules/index.js
node_modules/iobroker.zigbee2mqtt/node_modules/tslib/modules/index.d.ts
node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.es6.js
node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.js
node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.d.ts
node_modules/iobroker.zigbee2mqtt/node_modules/tslib/tslib.es6.mjs
node_modules/iobroker.reolink/node_modules/tslib/README.md
node_modules/iobroker.reolink/node_modules/tslib/modules/index.js
node_modules/iobroker.reolink/node_modules/tslib/modules/index.d.ts
node_modules/iobroker.reolink/node_modules/tslib/tslib.es6.js
node_modules/iobroker.reolink/node_modules/tslib/tslib.js
node_modules/iobroker.reolink/node_modules/tslib/tslib.d.ts
node_modules/iobroker.reolink/node_modules/tslib/tslib.es6.mjs
node_modules/xml2js/lib/xml2js.bc.js
node_modules/iobroker.wlanthermo-nano/admin/build/index.js
node_modules/iobroker.wlanthermo-nano/admin/build/index.js.map
node_modules/nedb/browser-version/out/nedb.min.js
node_modules/nedb/browser-version/out/nedb.js
node_modules/nedb/browser-version/test/localforage.js
node_modules/iobroker.vis-2-widgets-energy/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
node_modules/@babel/runtime/helpers/extends.js
node_modules/@babel/runtime/helpers/esm/extends.js
node_modules/eslint-plugin-node/lib/rules/no-deprecated-api.js
node_modules/terminal-link/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/p-memoize/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/iobroker.backitup/node_modules/tslib/README.md
node_modules/iobroker.backitup/node_modules/tslib/modules/index.js
node_modules/iobroker.backitup/node_modules/tslib/modules/index.d.ts
node_modules/iobroker.backitup/node_modules/tslib/tslib.es6.js
node_modules/iobroker.backitup/node_modules/tslib/tslib.js
node_modules/iobroker.backitup/node_modules/tslib/tslib.d.ts
node_modules/iobroker.backitup/node_modules/tslib/tslib.es6.mjs
node_modules/iobroker.backitup/admin/assets/index-BeQV_TGa.js
node_modules/iobroker.backitup/admin/custom/assets/index-CHFaRedm.js
node_modules/iobroker.backitup/admin/custom/assets/index-Ba6zELes.js
node_modules/iobroker.backitup/admin/custom/assets/ConfigCustomBackItUpSet__loadShare___mf_0_mui_mf_1_material__loadShare__.js-DqH6EEuz.js
node_modules/iobroker.discovery/node_modules/@serialport/bindings-cpp/prebuilds/android-arm64/node.napi.armv8.node
node_modules/iobroker.discovery/node_modules/node-addon-api/napi-inl.h
node_modules/sqlite3/node_modules/node-addon-api/napi-inl.h
node_modules/sqlite3/build/Release/node_sqlite3.node
node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.msgpack.min.js.map
node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.min.js.map
node_modules/browser-sync/node_modules/socket.io/client-dist/socket.io.js.map
node_modules/node-rest-client/lib/node-rest-client.js
node_modules/@img/sharp-linux-x64/lib/sharp-linux-x64.node
node_modules/@img/sharp-linuxmusl-x64/lib/sharp-linuxmusl-x64.node
node_modules/@img/sharp-libvips-linuxmusl-x64/lib/libvips-cpp.so.42
node_modules/@img/sharp-libvips-linux-x64/lib/libvips-cpp.so.42
node_modules/js-sdsl/dist/esm/container/TreeContainer/OrderedSet.js.map
node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/index.js
node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/index.js.map
node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeIterator.js.map
node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeNode.js
node_modules/js-sdsl/dist/esm/container/TreeContainer/Base/TreeNode.js.map
node_modules/js-sdsl/dist/esm/container/TreeContainer/OrderedMap.js.map
node_modules/js-sdsl/dist/esm/container/OtherContainer/Queue.js
node_modules/js-sdsl/dist/esm/container/OtherContainer/PriorityQueue.js.map
node_modules/js-sdsl/dist/esm/container/OtherContainer/Queue.js.map
node_modules/js-sdsl/dist/esm/container/OtherContainer/Stack.js.map
node_modules/js-sdsl/dist/esm/container/ContainerBase/index.js
node_modules/js-sdsl/dist/esm/container/ContainerBase/index.js.map
node_modules/js-sdsl/dist/esm/container/HashContainer/Base/index.js
node_modules/js-sdsl/dist/esm/container/HashContainer/Base/index.js.map
node_modules/js-sdsl/dist/esm/container/HashContainer/HashSet.js
node_modules/js-sdsl/dist/esm/container/HashContainer/HashMap.js.map
node_modules/js-sdsl/dist/esm/container/HashContainer/HashSet.js.map
node_modules/js-sdsl/dist/esm/container/SequentialContainer/Deque.js
node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/RandomIterator.js.map
node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/index.js
node_modules/js-sdsl/dist/esm/container/SequentialContainer/Base/index.js.map
node_modules/js-sdsl/dist/esm/container/SequentialContainer/Deque.js.map
node_modules/js-sdsl/dist/esm/container/SequentialContainer/Vector.js
node_modules/js-sdsl/dist/esm/container/SequentialContainer/LinkList.js.map
node_modules/js-sdsl/dist/esm/container/SequentialContainer/Vector.js.map
node_modules/js-sdsl/dist/umd/js-sdsl.js
node_modules/js-sdsl/dist/umd/js-sdsl.min.js.map
node_modules/iobroker.frigate/node_modules/tslib/README.md
node_modules/iobroker.frigate/node_modules/tslib/modules/index.js
node_modules/iobroker.frigate/node_modules/tslib/modules/index.d.ts
node_modules/iobroker.frigate/node_modules/tslib/tslib.es6.js
node_modules/iobroker.frigate/node_modules/tslib/tslib.js
node_modules/iobroker.frigate/node_modules/tslib/tslib.d.ts
node_modules/iobroker.frigate/node_modules/tslib/tslib.es6.mjs
node_modules/jsdom/node_modules/acorn/dist/acorn.js
node_modules/jsdom/node_modules/acorn/dist/acorn_loose.js
node_modules/jsdom/node_modules/acorn/src/statement.js
node_modules/jsdom/node_modules/acorn/src/loose/statement.js
node_modules/@opentelemetry/instrumentation/build/esm/platform/browser/instrumentation.js
node_modules/@opentelemetry/instrumentation/build/esm/platform/node/instrumentation.js
node_modules/@opentelemetry/api/build/esm/metrics/NoopMeter.js
node_modules/@opentelemetry/sdk-trace-base/build/esm/platform/browser/export/BatchSpanProcessor.js
node_modules/@opentelemetry/sdk-trace-base/build/esm/platform/node/export/BatchSpanProcessor.js
node_modules/@opentelemetry/core/build/esm/utils/timeout.js
node_modules/mocha/mocha.js
node_modules/ajv/README.md
node_modules/fast-glob/README.md
node_modules/globals/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/date-fns/package.json
node_modules/jsx-ast-utils/lib/values/index.js
node_modules/jsx-ast-utils/lib/values/expressions/index.js
node_modules/jsx-ast-utils/lib/values/expressions/ObjectExpression.js
node_modules/jsx-ast-utils/lib/getProp.js
node_modules/bs-recipes/recipes/webpack.typescript.react/app/dist/bundle.js
node_modules/browser-sync-client/dist/index.js
node_modules/http-proxy/lib/http-proxy/index.js
node_modules/http-proxy/lib/http-proxy/common.js
node_modules/standard/node_modules/acorn/dist/acorn.mjs.map
node_modules/standard/node_modules/acorn/dist/acorn.d.ts
node_modules/standard/node_modules/acorn/dist/acorn.js.map
node_modules/iobroker.vis-2/www/widgets.html
node_modules/iobroker.vis-2/www/widgets/basic.html
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
node_modules/iobroker.vis-2/www/widgets/materialdesign/lib.min.js
node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/vuetify.js
node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/material-components-web.js
node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
node_modules/iobroker.vis-2/www/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
node_modules/iobroker.vis-2/www/widgets/openweathermap/assets/index-DnuTl29g.js
node_modules/iobroker.vis-2/www/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_suncalc2_suncalc2_js-node_modules_mui_system_DefaultPropsProvider_Defaul-ffa10d.8398b4c4.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_styles_useTheme_js-node_modules_mui_material_styles_useThem-e5c7b0.54818e0b.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_system_colorManipulator_colorManipulator_js-node_modules_mui_system_-2200b2.f031f43b.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/fullcalendar/static/js/vendors-node_modules_mui_material_Button_Button_js-node_modules_mui_material_Chip_Chip_js-nod-a19771.16aa452d.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-energy/static/js/vendors-node_modules_echarts-for-react_esm_index_js-node_modules_react_jsx-runtime_js.b995bce7.chunk.js.map
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
node_modules/iobroker.vis-2/www/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
node_modules/iobroker.vis-2/www/assets/createStyled-CtLRJdF1.js
node_modules/iobroker.vis-2/www/assets/index-D_qqioAY.js.map
node_modules/iobroker.vis-2/www/assets/index-BRd7FNtl.js
node_modules/iobroker.vis-2/www/assets/index-CrLrNq4s.js
node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-B8Z0SsW4.js.map
node_modules/iobroker.vis-2/www/assets/Dialog-DElqR5zv.js.map
node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Dt1au33l.js
node_modules/iobroker.vis-2/www/assets/Dialog-Dgkz1L-r.js
node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Dt1au33l.js.map
node_modules/iobroker.vis-2/www/assets/createStyled-BvULSPVR.js.map
node_modules/iobroker.vis-2/www/assets/index-BGo51MQZ.js
node_modules/iobroker.vis-2/www/assets/index-DqJdyjgH.js.map
node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-y8HJH6Vp.js
node_modules/iobroker.vis-2/www/assets/Box-Bl3kq-x-.js.map
node_modules/iobroker.vis-2/www/assets/index-BGhFZJYV.js.map
node_modules/iobroker.vis-2/www/assets/assertThisInitialized-DtkDSj7h.js.map
node_modules/iobroker.vis-2/www/assets/Dialog-Dgkz1L-r.js.map
node_modules/iobroker.vis-2/www/assets/index-CrLrNq4s.js.map
node_modules/iobroker.vis-2/www/assets/index-CzkXf0rM.js.map
node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Zvkdie3d.js
node_modules/iobroker.vis-2/www/assets/assertThisInitialized-DFQXnDE3.js.map
node_modules/iobroker.vis-2/www/assets/index-BRd7FNtl.js.map
node_modules/iobroker.vis-2/www/assets/index-BGo51MQZ.js.map
node_modules/iobroker.vis-2/www/assets/index-BTDdCqea.js
node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_system__loadShare__.js-Zvkdie3d.js.map
node_modules/iobroker.vis-2/www/assets/createStyled-CtLRJdF1.js.map
node_modules/iobroker.vis-2/www/assets/iobroker_vis__loadShare___mf_0_mui_mf_1_material__loadShare__.js-y8HJH6Vp.js.map
node_modules/iobroker.vis-2/www/assets/visWidgetsCatalog-D4OT0wlf.js.map
node_modules/iobroker.vis-2/www/assets/index-B2JJPlmn.js.map
node_modules/iobroker.vis-2/www/lib/js/jquery-ui-timepicker-addon-1.6.3.js
node_modules/worker-timers/node_modules/tslib/README.md
node_modules/worker-timers/node_modules/tslib/modules/index.js
node_modules/worker-timers/node_modules/tslib/modules/index.d.ts
node_modules/worker-timers/node_modules/tslib/tslib.es6.js
node_modules/worker-timers/node_modules/tslib/tslib.js
node_modules/worker-timers/node_modules/tslib/tslib.d.ts
node_modules/worker-timers/node_modules/tslib/tslib.es6.mjs
node_modules/acorn/dist/acorn.d.mts
node_modules/iobroker.openweathermap/widgets/openweathermap/assets/index-DnuTl29g.js
node_modules/iobroker.openweathermap/widgets/openweathermap/assets/openweathermap__mf_v__runtimeInit__mf_v__-B1N0h572.js
node_modules/prettier/plugins/babel.mjs
node_modules/prettier/plugins/flow.mjs
node_modules/prettier/plugins/acorn.js
node_modules/prettier/plugins/typescript.mjs
node_modules/prettier/plugins/typescript.js
node_modules/prettier/plugins/acorn.mjs
node_modules/prettier/plugins/flow.js
node_modules/prettier/plugins/babel.js
node_modules/prettier/internal/experimental-cli.mjs
node_modules/core-util-is/float.patch
node_modules/new-github-release-url/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/iobroker.ping/admin/custom/assets/index-D8RJ5veu.js
node_modules/iobroker.ping/admin/custom/assets/index-CbxD1KHt.js
node_modules/typescript/lib/pl/diagnosticMessages.generated.json
node_modules/typescript/lib/ja/diagnosticMessages.generated.json
node_modules/typescript/lib/it/diagnosticMessages.generated.json
node_modules/typescript/lib/ko/diagnosticMessages.generated.json
node_modules/typescript/lib/ru/diagnosticMessages.generated.json
node_modules/typescript/lib/zh-cn/diagnosticMessages.generated.json
node_modules/typescript/lib/cs/diagnosticMessages.generated.json
node_modules/typescript/lib/de/diagnosticMessages.generated.json
node_modules/typescript/lib/fr/diagnosticMessages.generated.json
node_modules/typescript/lib/_tsc.js
node_modules/typescript/lib/typescript.js
node_modules/typescript/lib/zh-tw/diagnosticMessages.generated.json
node_modules/typescript/lib/tr/diagnosticMessages.generated.json
node_modules/typescript/lib/es/diagnosticMessages.generated.json
node_modules/typescript/lib/pt-br/diagnosticMessages.generated.json
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_icons-material_AutorenewOutlined_js-node_modules_mui_icons-material_-180f28.3c3e33dc.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_react-is_index_js-node_modules_react-transition-group_esm_Transition_js--bf91e9.2cb3ad54.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Avatar_Avatar_js-node_modules_mui_material_ListItemAvatar_L-051c91.36feecca.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_build_index_js.3ac07b4b.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_index_js.a16faec2.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_index_js.96f4463a.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_material_index_js.b3f5c784.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_system_esm_index_js.2e4e3670.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_styled-engine_index_js-node_modules_mui_system_esm_DefaultPropsProvi-b76827.6111dfe7.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_CircularProgress_CircularProgress_js-node_modules_mui_mater-73e472.5d3fa838.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mapbox-gl_dist_mapbox-gl_js.f9312d28.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_emotion_styled_dist_emotion-styled_browser_esm_js-node_modules_react_jsx-947537.79f26eb7.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_vis-2-widgets-react-dev_node_modules_mui_system_esm_index_js.df9db284.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_system_esm_Unstable_Grid_createGrid_js.eac9a8be.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_material_index_js.4769ce25.chunk.js.map
node_modules/iobroker.vis-2-widgets-radar-trap/widgets/vis-2-widgets-radar-trap/static/js/vendors-node_modules_mui_material_Box_Box_js-node_modules_mui_material_Checkbox_Checkbox_js-n-668e62.47ad2310.chunk.js.map
node_modules/canvas/build/Release/libpango-1.0.so.0
node_modules/canvas/build/Release/canvas.node
node_modules/canvas/build/Release/libharfbuzz.so.0
node_modules/canvas/build/Release/libcairo.so.2
node_modules/canvas/build/Release/libcairo-gobject.so.2
node_modules/canvas/build/Release/librsvg-2.so.2
node_modules/canvas/build/Release/libglib-2.0.so.0
node_modules/canvas/build/Release/obj.target/canvas.node
node_modules/canvas/build/Release/obj.target/canvas/src/CanvasRenderingContext2d.o
node_modules/canvas/build/Release/libgio-2.0.so.0
node_modules/canvas/src/CanvasRenderingContext2d.cc
node_modules/canvas/src/CanvasRenderingContext2d.cc.orig
node_modules/request/CHANGELOG.md
node_modules/swagger-ui-dist/swagger-ui-standalone-preset.js
node_modules/swagger-ui-dist/swagger-ui.js.map
node_modules/swagger-ui-dist/swagger-ui-es-bundle-core.js
node_modules/swagger-ui-dist/swagger-ui-bundle.js.map
node_modules/swagger-ui-dist/swagger-ui-es-bundle.js
node_modules/swagger-ui-dist/swagger-ui-es-bundle-core.js.map
node_modules/swagger-ui-dist/swagger-ui-es-bundle.js.map
node_modules/swagger-ui-dist/swagger-ui-standalone-preset.js.map
node_modules/@azure/keyvault-keys/node_modules/tslib/README.md
node_modules/@azure/keyvault-keys/node_modules/tslib/modules/index.js
node_modules/@azure/keyvault-keys/node_modules/tslib/modules/index.d.ts
node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.es6.js
node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.js
node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.d.ts
node_modules/@azure/keyvault-keys/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/core-tracing/node_modules/tslib/README.md
node_modules/@azure/core-tracing/node_modules/tslib/modules/index.js
node_modules/@azure/core-tracing/node_modules/tslib/modules/index.d.ts
node_modules/@azure/core-tracing/node_modules/tslib/tslib.es6.js
node_modules/@azure/core-tracing/node_modules/tslib/tslib.js
node_modules/@azure/core-tracing/node_modules/tslib/tslib.d.ts
node_modules/@azure/core-tracing/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/abort-controller/node_modules/tslib/README.md
node_modules/@azure/abort-controller/node_modules/tslib/modules/index.js
node_modules/@azure/abort-controller/node_modules/tslib/modules/index.d.ts
node_modules/@azure/abort-controller/node_modules/tslib/tslib.es6.js
node_modules/@azure/abort-controller/node_modules/tslib/tslib.js
node_modules/@azure/abort-controller/node_modules/tslib/tslib.d.ts
node_modules/@azure/abort-controller/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/core-auth/node_modules/tslib/README.md
node_modules/@azure/core-auth/node_modules/tslib/modules/index.js
node_modules/@azure/core-auth/node_modules/tslib/modules/index.d.ts
node_modules/@azure/core-auth/node_modules/tslib/tslib.es6.js
node_modules/@azure/core-auth/node_modules/tslib/tslib.js
node_modules/@azure/core-auth/node_modules/tslib/tslib.d.ts
node_modules/@azure/core-auth/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/core-util/node_modules/tslib/README.md
node_modules/@azure/core-util/node_modules/tslib/modules/index.js
node_modules/@azure/core-util/node_modules/tslib/modules/index.d.ts
node_modules/@azure/core-util/node_modules/tslib/tslib.es6.js
node_modules/@azure/core-util/node_modules/tslib/tslib.js
node_modules/@azure/core-util/node_modules/tslib/tslib.d.ts
node_modules/@azure/core-util/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/logger/node_modules/tslib/README.md
node_modules/@azure/logger/node_modules/tslib/modules/index.js
node_modules/@azure/logger/node_modules/tslib/modules/index.d.ts
node_modules/@azure/logger/node_modules/tslib/tslib.es6.js
node_modules/@azure/logger/node_modules/tslib/tslib.js
node_modules/@azure/logger/node_modules/tslib/tslib.d.ts
node_modules/@azure/logger/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/identity/node_modules/tslib/README.md
node_modules/@azure/identity/node_modules/tslib/modules/index.js
node_modules/@azure/identity/node_modules/tslib/modules/index.d.ts
node_modules/@azure/identity/node_modules/tslib/tslib.es6.js
node_modules/@azure/identity/node_modules/tslib/tslib.js
node_modules/@azure/identity/node_modules/tslib/tslib.d.ts
node_modules/@azure/identity/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/core-lro/node_modules/tslib/README.md
node_modules/@azure/core-lro/node_modules/tslib/modules/index.js
node_modules/@azure/core-lro/node_modules/tslib/modules/index.d.ts
node_modules/@azure/core-lro/node_modules/tslib/tslib.es6.js
node_modules/@azure/core-lro/node_modules/tslib/tslib.js
node_modules/@azure/core-lro/node_modules/tslib/tslib.d.ts
node_modules/@azure/core-lro/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/core-client/node_modules/tslib/README.md
node_modules/@azure/core-client/node_modules/tslib/modules/index.js
node_modules/@azure/core-client/node_modules/tslib/modules/index.d.ts
node_modules/@azure/core-client/node_modules/tslib/tslib.es6.js
node_modules/@azure/core-client/node_modules/tslib/tslib.js
node_modules/@azure/core-client/node_modules/tslib/tslib.d.ts
node_modules/@azure/core-client/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/core-http-compat/node_modules/tslib/README.md
node_modules/@azure/core-http-compat/node_modules/tslib/modules/index.js
node_modules/@azure/core-http-compat/node_modules/tslib/modules/index.d.ts
node_modules/@azure/core-http-compat/node_modules/tslib/tslib.es6.js
node_modules/@azure/core-http-compat/node_modules/tslib/tslib.js
node_modules/@azure/core-http-compat/node_modules/tslib/tslib.d.ts
node_modules/@azure/core-http-compat/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/core-rest-pipeline/node_modules/tslib/README.md
node_modules/@azure/core-rest-pipeline/node_modules/tslib/modules/index.js
node_modules/@azure/core-rest-pipeline/node_modules/tslib/modules/index.d.ts
node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.es6.js
node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.js
node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.d.ts
node_modules/@azure/core-rest-pipeline/node_modules/tslib/tslib.es6.mjs
node_modules/@azure/core-paging/node_modules/tslib/README.md
node_modules/@azure/core-paging/node_modules/tslib/modules/index.js
node_modules/@azure/core-paging/node_modules/tslib/modules/index.d.ts
node_modules/@azure/core-paging/node_modules/tslib/tslib.es6.js
node_modules/@azure/core-paging/node_modules/tslib/tslib.js
node_modules/@azure/core-paging/node_modules/tslib/tslib.d.ts
node_modules/@azure/core-paging/node_modules/tslib/tslib.es6.mjs
node_modules/external-editor/main/errors/CreateFileError.js
node_modules/external-editor/main/errors/LaunchEditorError.js
node_modules/external-editor/main/errors/ReadFileError.js
node_modules/external-editor/main/errors/RemoveFileError.js
node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/tslib.es6-BuLyYyFn.js
node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/vis2materialWidgets__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-DPGKvGE_.js
node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/installSVGRenderer-HmkSWafm.js
node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/index-BpRTpc1m.js
node_modules/iobroker.vis-2-widgets-material/widgets/vis-2-widgets-material/assets/Map-2arjYX2u.js
node_modules/xmldom/dom.js
node_modules/@serialport/bindings-cpp/prebuilds/android-arm64/@serialport+bindings-cpp.armv8.node
node_modules/read-package-up/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/@homebridge/hap-nodejs/node_modules/tslib/README.md
node_modules/@homebridge/hap-nodejs/node_modules/tslib/modules/index.js
node_modules/@homebridge/hap-nodejs/node_modules/tslib/modules/index.d.ts
node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.es6.js
node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.js
node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.d.ts
node_modules/@homebridge/hap-nodejs/node_modules/tslib/tslib.es6.mjs
node_modules/@homebridge/ciao/node_modules/tslib/README.md
node_modules/@homebridge/ciao/node_modules/tslib/modules/index.js
node_modules/@homebridge/ciao/node_modules/tslib/modules/index.d.ts
node_modules/@homebridge/ciao/node_modules/tslib/tslib.es6.js
node_modules/@homebridge/ciao/node_modules/tslib/tslib.js
node_modules/@homebridge/ciao/node_modules/tslib/tslib.d.ts
node_modules/@homebridge/ciao/node_modules/tslib/tslib.es6.mjs
node_modules/syno/definitions/6.x/_full.json
node_modules/syno/test/browser/js/syno-6.x.min.js
node_modules/syno/dist/syno-6.x.min.js
node_modules/syno/dist/syno-5.x.min.js
node_modules/iobroker.yahka/admin/yahka.admin.js
node_modules/iobroker.yahka/admin/yahka.admin.js.map
node_modules/hosted-git-info/git-host.js
node_modules/winston-seq-updated/lib/index.js
node_modules/iobroker.vis-2-widgets-gauges/widgets/vis-2-widgets-gauges/assets/vis2gaugeWidgets__mf_v__runtimeInit__mf_v__-C2HUVKfi.js
node_modules/worker-timers-worker/node_modules/tslib/README.md
node_modules/worker-timers-worker/node_modules/tslib/modules/index.js
node_modules/worker-timers-worker/node_modules/tslib/modules/index.d.ts
node_modules/worker-timers-worker/node_modules/tslib/tslib.es6.js
node_modules/worker-timers-worker/node_modules/tslib/tslib.js
node_modules/worker-timers-worker/node_modules/tslib/tslib.d.ts
node_modules/worker-timers-worker/node_modules/tslib/tslib.es6.mjs
node_modules/json2iob/tsconfig.json
node_modules/worker-factory/node_modules/tslib/README.md
node_modules/worker-factory/node_modules/tslib/modules/index.js
node_modules/worker-factory/node_modules/tslib/modules/index.d.ts
node_modules/worker-factory/node_modules/tslib/tslib.es6.js
node_modules/worker-factory/node_modules/tslib/tslib.js
node_modules/worker-factory/node_modules/tslib/tslib.d.ts
node_modules/worker-factory/node_modules/tslib/tslib.es6.mjs
node_modules/fast-unique-numbers/node_modules/tslib/README.md
node_modules/fast-unique-numbers/node_modules/tslib/modules/index.js
node_modules/fast-unique-numbers/node_modules/tslib/modules/index.d.ts
node_modules/fast-unique-numbers/node_modules/tslib/tslib.es6.js
node_modules/fast-unique-numbers/node_modules/tslib/tslib.js
node_modules/fast-unique-numbers/node_modules/tslib/tslib.d.ts
node_modules/fast-unique-numbers/node_modules/tslib/tslib.es6.mjs
node_modules/rrule/node_modules/tslib/README.md
node_modules/rrule/node_modules/tslib/modules/index.js
node_modules/rrule/node_modules/tslib/modules/index.d.ts
node_modules/rrule/node_modules/tslib/tslib.es6.js
node_modules/rrule/node_modules/tslib/tslib.js
node_modules/rrule/node_modules/tslib/tslib.d.ts
node_modules/rrule/node_modules/tslib/tslib.es6.mjs
node_modules/rrule/dist/es5/rrule.js
node_modules/rrule/dist/es5/rrule.min.js.map
node_modules/rrule/dist/esm/callbackiterresult.js
node_modules/rrule/dist/esm/datetime.js
node_modules/rrule/dist/esm/rruleset.js
node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib.min.js
node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/vuetify.js
node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/material-components-web.js
node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/raw/sentry/captureconsole.min.js.map
node_modules/iobroker.vis-materialdesign/widgets/materialdesign/lib/raw/sentry/bundle.min.js.map
node_modules/iobroker.modbus/admin/assets/index-Blv_5nFZ.js
node_modules/iobroker.material/www/static/js/main.c5478f66.js.map
node_modules/jszip/tsconfig.json
node_modules/iobroker.daswetter/admin/assets/index-84bRrRlB.js
node_modules/node-gyp/lib/find-python.js
node_modules/iobroker.javascript/admin/plugins/bundle.js
node_modules/iobroker.javascript/admin/assets/index-dN73sbyQ.js
node_modules/iobroker.javascript/admin/assets/iobroker_javascript__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-CV1_X-Lf.js
node_modules/iobroker.javascript/admin/vs/editor/editor.main.js
node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js
node_modules/iobroker.javascript/admin/custom/assets/index-BptSiKBK.js
node_modules/iobroker.javascript/admin/custom/assets/index-BVwMgafs.js
node_modules/iobroker.javascript/admin/custom/assets/ConfigCustomJavascriptSet__loadShare___mf_0_mui_mf_1_material__loadShare__.mjs-KsT5vKjV.js
node_modules/iobroker.javascript/admin/custom/assets/leaflet-src-k2rCV-Ix.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsyncAction.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsapAction.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsyncScheduler.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AsapScheduler.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/QueueAction.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/QueueScheduler.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AnimationFrameScheduler.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/VirtualTimeScheduler.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/AnimationFrameAction.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/scheduler/Action.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/observable/dom/WebSocketSubject.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/observable/ConnectableObservable.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/operators/OperatorSubscriber.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/BehaviorSubject.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/Subscriber.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/AsyncSubject.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/ReplaySubject.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/HotObservable.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/TestScheduler.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/testing/ColdObservable.js
node_modules/np/node_modules/rxjs/dist/esm5/internal/Subject.js
node_modules/np/node_modules/rxjs/dist/bundles/rxjs.umd.js.map
node_modules/np/node_modules/rxjs/dist/bundles/rxjs.umd.min.js.map
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsyncAction.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsapAction.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsyncScheduler.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AsapScheduler.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/QueueAction.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/QueueScheduler.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AnimationFrameScheduler.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/VirtualTimeScheduler.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/AnimationFrameAction.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/scheduler/Action.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/observable/dom/WebSocketSubject.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/observable/ConnectableObservable.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/operators/OperatorSubscriber.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/BehaviorSubject.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/Subscriber.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/AsyncSubject.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/ReplaySubject.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/HotObservable.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/TestScheduler.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/testing/ColdObservable.js
node_modules/np/node_modules/rxjs/dist/cjs/internal/Subject.js
node_modules/np/node_modules/tslib/README.md
node_modules/np/node_modules/tslib/modules/index.js
node_modules/np/node_modules/tslib/modules/index.d.ts
node_modules/np/node_modules/tslib/tslib.es6.js
node_modules/np/node_modules/tslib/tslib.js
node_modules/np/node_modules/tslib/tslib.d.ts
node_modules/np/node_modules/tslib/tslib.es6.mjs
node_modules/np/node_modules/type-fest/source/tsconfig-json.d.ts
node_modules/iobroker.vis-2-widgets-inventwo/widgets/vis-2-widgets-inventwo/assets/index-BEKHDyH5.js
node_modules/iobroker.vis-2-widgets-inventwo/widgets/vis-2-widgets-inventwo/assets/vis2Inventwo__loadShare___mf_0_mui_mf_1_material__loadShare__.js-D3TZWrVQ.js
node_modules/sinon/pkg/sinon-esm.js
node_modules/sinon/pkg/sinon-no-sourcemaps.cjs
node_modules/sinon/pkg/sinon.js
node_modules/luxon/build/cjs-browser/luxon.js
node_modules/luxon/build/cjs-browser/luxon.js.map
node_modules/luxon/build/amd/luxon.js
node_modules/luxon/build/amd/luxon.js.map
node_modules/luxon/build/global/luxon.min.js.map
node_modules/luxon/build/global/luxon.js
node_modules/luxon/build/global/luxon.js.map
node_modules/localforage/bower_components/mocha/mocha.js
node_modules/localforage/dist/localforage.js
node_modules/localforage/dist/localforage.nopromises.min.js
node_modules/localforage/dist/localforage.nopromises.js
node_modules/localforage/dist/localforage.min.js
node_modules/localforage/build/es5src/localforage.js
node_modules/localforage/src/localforage.js
node_modules/iobroker.email/admin/custom/assets/index-ByILBjTr.js
node_modules/iobroker.email/admin/custom/assets/index-D-vy1JIC.js
node_modules/iobroker.email/admin/custom/assets/ConfigCustomEmailSet__mf_v__runtimeInit__mf_v__-Bd5Kc7oi.js
node_modules/iobroker.email/admin/rules/assets/ActionSendEmail__mf_v__runtimeInit__mf_v__-eLULivoH.js
</code></pre>
<p dir="auto"></p></section></section><p></p>
]]></description><link>https://forum.iobroker.net/post/1335202</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335202</guid><dc:creator><![CDATA[tritor]]></dc:creator><pubDate>Sat, 18 Apr 2026 15:29:28 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 12:28:43 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tritor" aria-label="Profile: tritor">@<bdi>tritor</bdi></a> <a href="/post/1335170">sagte</a>:</p>
<p dir="auto">da konnte ich das log nicht kopieren</p>
</blockquote>
<p dir="auto">Das log liegt z. B. unter</p>
<pre><code>iob logs
</code></pre>
<p dir="auto">Da kann man das auch wunderschön als reinen Text herauskopieren.</p>
<p dir="auto">Am Rande: System inkl. nodejs updaten auf Stand bringen.</p>
]]></description><link>https://forum.iobroker.net/post/1335175</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335175</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sat, 18 Apr 2026 12:28:43 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 11:57:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/samson71" aria-label="Profile: Samson71">@<bdi>Samson71</bdi></a><br />
den Tipp-Fehler hab ich korrigiert, das Bild leider nicht, das war auf die Schnelle ein Screenshot, da konnte ich das log nicht kopieren, das Fenster schloss automatisch. Werde das das nächste mal berücksichtigen.</p>
]]></description><link>https://forum.iobroker.net/post/1335170</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335170</guid><dc:creator><![CDATA[tritor]]></dc:creator><pubDate>Sat, 18 Apr 2026 11:57:31 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 11:50:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tritor" aria-label="Profile: tritor">@<bdi>tritor</bdi></a></p>
<p dir="auto">hier ein issue dazu, wobei die angewendete suchmethode nicht so ganz perfekt ist, da sie nur util._extend findet. sobald aber paket und funktion separiert notiert sind, funktioniert das nicht mehr</p>
<p dir="auto"><a href="https://github.com/ioBroker/ioBroker.js-controller/issues/3073" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.js-controller/issues/3073</a></p>
<p dir="auto">ich würde im /opt/iobroker Verzeichnis mal nach</p>
<pre><code>grep -Rnl "_extend" node_modules/
</code></pre>
<p dir="auto">suchen.</p>
]]></description><link>https://forum.iobroker.net/post/1335168</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335168</guid><dc:creator><![CDATA[OliverIO]]></dc:creator><pubDate>Sat, 18 Apr 2026 11:50:35 GMT</pubDate></item><item><title><![CDATA[Reply to Deprecation Warning - util._extend on Sat, 18 Apr 2026 11:41:12 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Hoffe einer der Experten kann mir hier einen Tipp geben</p>
</blockquote>
<p dir="auto">Sofern Du anständige Logs in Code-Tags <code>&lt;/&gt;</code> postest und nicht kryptisch ausgeschnittene Bildchen einbaust - vielleicht.<br />
Auch die Überschrift bedarf wohl einer kleinen Korrektur.</p>
<p dir="auto"><img src="/assets/uploads/files/1776512468626-e6c5eae6-307e-4867-b790-ddaa7cf9ba9b-image.jpeg" alt="e6c5eae6-307e-4867-b790-ddaa7cf9ba9b-image.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/1335167</link><guid isPermaLink="true">https://forum.iobroker.net/post/1335167</guid><dc:creator><![CDATA[Samson71]]></dc:creator><pubDate>Sat, 18 Apr 2026 11:41:12 GMT</pubDate></item></channel></rss>
