  4. HomeKit Controller last sich nicht installieren
    5.8k
9 Beiträge 5 Kommentatoren 411 Aufrufe 4 Beobachtet
  • Horst BöttcherH Offline
    Horst Böttcher
    DANKE
    Adaptername: homekit-controller
    Link zu Adapterrepository: https://github.com/Apollon77/ioBroker.homekit-controller
    Adapterversion: 0.5.11
    js-controller Version: 7.0.7
    Admin Version: 7.7.22
    Hardwaresystem: Proxmox LXC (unprivilegiert)
    Arbeitsspeicher: 4.88 GiB
    Festplattenart: SSD / NVMe
    Betriebssystem: Debian GNU/Linux 13 (trixie)
    Nodejs-Version: v20.20.2
    NPM-Version: 10.8.2
    Installationsart: Skript
    Image, Docker genutzt: Nein
    Ort, Name der Imagedatei: n/a
    Linux User bitte hier den Output von iob diag einfügen.
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iob
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.17.13-2-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     21:52:37 up  1:37,  0 users,  load average: 0.93, 0.54, 0.56
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2026-03-29 21:52:37 CEST
               Universal time: Sun 2026-03-29 19:52:37 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    iob
    HOME=/home/iob
    GROUPS=iob sudo users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/iob
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            5.2G        2.0G        2.9G         73K        302M        3.2G
    Swap:           5.2G        791M        4.5G
    Total:           10G        2.8G        7.4G
    Active iob-Instances:   31
             5000 M total memory
             1908 M used memory
              950 M active memory
             1122 M inactive memory
             2802 M free memory
                0 M buffer memory
              288 M swap cache
             5000 M total swap
              755 M used swap
             4244 M free swap
    top - 21:52:37 up  1:37,  0 users,  load average: 0.93, 0.54, 0.56
    Tasks:  61 total,   1 running,  60 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   5000.0 total,   2801.4 free,   1909.6 used,    288.9 buff/cache
    MiB Swap:   5000.0 total,   4244.9 free,    755.1 used.   3090.4 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--105--disk--0 ext4      9.8G  5.1G  4.3G  55% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
    tmpfs                            tmpfs     3.8G     0  3.8G   0% /dev/shm
    tmpfs                            tmpfs     1.6G  108K  1.6G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     3.8G     0  3.8G   0% /tmp
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--105--disk--0 ext4   rw,relatime,stripe=16
    /var:
    554M    /var/
    351M    /var/cache
    347M    /var/cache/apt
    257M    /var/cache/apt/archives
    162M    /var/lib
    Archived and active journals take up 16M in the file system.
    /opt/iobroker/backups:
    140M    /opt/iobroker/backups/
    20K     /opt/iobroker/backups/zigbee2mqtt_tmp
    /opt/iobroker/iobroker-data:
    1.2G    /opt/iobroker/iobroker-data/
    433M    /opt/iobroker/iobroker-data/files
    366M    /opt/iobroker/iobroker-data/history
    158M    /opt/iobroker/iobroker-data/backup-objects
    81M     /opt/iobroker/iobroker-data/files/vis
    164M    /opt/iobroker/iobroker-data/objects.jsonl
    89M     /opt/iobroker/iobroker-data/states.jsonl
    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.20.2
    /usr/bin/node           v20.20.2
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    ✓ Node.js installation is correct
    nodejs:
      Installed: 20.20.2-1nodesource1
      Candidate: 20.20.2-1nodesource1
      Version table:
     *** 20.20.2-1nodesource1 100
         20.20.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.6-1nodesource1 600
         20.19.5-1nodesource1 600
         20.19.4-1nodesource1 600
         20.19.3-1nodesource1 600
         20.19.2+dfsg-1+deb13u2 500
            500 http://security.debian.org trixie-security/main amd64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
         20.19.2-1nodesource1 600
         20.19.1-1nodesource1 600
         20.19.0-1nodesource1 600
         20.18.3-1nodesource1 600
         20.18.2-1nodesource1 600
         20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.20.8-1nodesource1 600
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.20.6-1nodesource1 600
         18.20.5-1nodesource1 600
         18.20.4-1nodesource1 600
         18.20.3-1nodesource1 600
         18.20.2-1nodesource1 600
         18.20.1-1nodesource1 600
         18.20.0-1nodesource1 600
         18.19.1-1nodesource1 600
         18.19.0-1nodesource1 600
         18.18.2-1nodesource1 600
         18.18.1-1nodesource1 600
         18.18.0-1nodesource1 600
         18.17.1-1nodesource1 600
         18.17.0-1nodesource1 600
         18.16.1-1nodesource1 600
         18.16.0-1nodesource1 600
         18.15.0-1nodesource1 600
         18.14.2-1nodesource1 600
         18.14.1-1nodesource1 600
         18.14.0-1nodesource1 600
         18.13.0-1nodesource1 600
         18.12.0-1nodesource1 600
         18.11.0-1nodesource1 600
         18.10.0-1nodesource1 600
         18.9.1-1nodesource1 600
         18.9.0-1nodesource1 600
         18.8.0-1nodesource1 600
         18.7.0-1nodesource1 600
         18.6.0-1nodesource1 600
         18.5.0-1nodesource1 600
         18.4.0-1nodesource1 600
         18.3.0-1nodesource1 600
         18.2.0-1nodesource1 600
         18.1.0-1nodesource1 600
         18.0.0-1nodesource1 600
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iob                 iob (version: 7.0.7, hostname: iob           , alive, uptime: 4641)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     4
    +-- iobroker.info@2.0.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#863fada0c02d8c0f718022943bb783f40514f059)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
    +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
    +-- iobroker.unifi-network@1.3.4 (git+ssh://git@github.com/Scrounger/ioBroker.unifi-network.git#3989edbb0f48ca1fe5666054de88eb495aaf7b43)
    Adapter State
      system.adapter.accuweather.0            : accuweather           : iob                                      - disabled
    + system.adapter.admin.0                  : admin                 : iob                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : iob                                      - disabled
      system.adapter.alias-manager.0          : alias-manager         : iob                                      -  enabled
    + system.adapter.backitup.0               : backitup              : iob                                      -  enabled
    + system.adapter.chromecast.0             : chromecast            : iob                                      -  enabled
      system.adapter.device-reminder.0        : device-reminder       : iob                                      - disabled
      system.adapter.devices.0                : devices               : iob                                      - disabled
    + system.adapter.discovergy.0             : discovergy            : iob                                      -  enabled
    + system.adapter.discovery.0              : discovery             : iob                                      -  enabled
    + system.adapter.echarts.0                : echarts               : iob                                      -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iob                                      - disabled
      system.adapter.feiertage.0              : feiertage             : iob                                      -  enabled
      system.adapter.flexcharts.0             : flexcharts            : iob                                      -  enabled
    + system.adapter.history.0                : history               : iob                                      -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iob                                      -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iob                                      -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iob                                      - disabled
      system.adapter.ical.1                   : ical                  : iob                                      - disabled
      system.adapter.ical.2                   : ical                  : iob                                      - disabled
      system.adapter.ical.3                   : ical                  : iob                                      - disabled
      system.adapter.ical.4                   : ical                  : iob                                      - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iob                                      - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob                                      - disabled
    + system.adapter.influxdb.0               : influxdb              : iob                                      -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iob                                      -  enabled
    + system.adapter.iot.0                    : iot                   : iob                                      -  enabled
    + system.adapter.javascript.0             : javascript            : iob                                      -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iob                                      -  enabled, port: 1890, bind: 0.0.0.0
      system.adapter.net-tools.0              : net-tools             : iob                                      - disabled
    + system.adapter.nuki-extended.0          : nuki-extended         : iob                                      -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iob                                      -  enabled
    + system.adapter.pushover.0               : pushover              : iob                                      -  enabled
      system.adapter.radar2.0                 : radar2                : iob                                      -  enabled
    + system.adapter.rssfeed.0                : rssfeed               : iob                                      -  enabled
    + system.adapter.sayit.0                  : sayit                 : iob                                      -  enabled
    + system.adapter.shelly.0                 : shelly                : iob                                      -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iob                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iob                                      -  enabled
    + system.adapter.systeminfo.0             : systeminfo            : iob                                      -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iob                                      -  enabled
      system.adapter.tapo.0                   : tapo                  : iob                                      - disabled
    + system.adapter.telegram.0               : telegram              : iob                                      -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : iob                                      -  enabled
      system.adapter.twinkly.0                : twinkly               : iob                                      - disabled
      system.adapter.unifi-network.0          : unifi-network         : iob                                      - disabled, port: 11443
      system.adapter.unifi.0                  : unifi                 : iob                                      - disabled
    + system.adapter.upnp.0                   : upnp                  : iob                                      -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iob                                      - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob                                      - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iob                                      -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob                                      - disabled
      system.adapter.vis.0                    : vis                   : iob                                      -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : iob                                      -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iob                                      - disabled
    + system.adapter.web.0                    : web                   : iob                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob                                      - disabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iob                                      -  enabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ true         │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "accuweather"  : 2.2.0    , installed 2.2.0
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.1.0    , installed 2.1.0
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "chromecast"   : 4.1.1    , installed 4.1.1
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "discovergy"   : 0.6.0    , installed 0.6.0
    Adapter    "echarts"      : 3.1.0    , installed 3.1.0
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
    Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
    Adapter    "ical"         : 1.19.7   , installed 1.19.7
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "rssfeed"      : 4.0.2    , installed 4.0.2
    Adapter    "sayit"        : 5.1.0    , installed 5.1.0
    Adapter    "shelly"       : 10.6.1   , installed 10.6.1
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "tuya"         : 3.16.0   , installed 3.17.0
    Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "unifi-network": 1.3.1    , installed 1.3.4
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "weather-warnings": 0.10.0, installed 0.10.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Adapter    "zigbee2mqtt"  : 3.0.21   , installed 3.0.21
    Objects and States
    Objects:        84712
    States:         64082
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          24217899   1/init
    tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1001       24310628   3283/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       24311165   3216/io.shelly.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          24218538   274/master
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       24304767   2607/iobroker.js-co
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       24304781   2607/iobroker.js-co
    tcp        0      0 127.0.0.1:9292          0.0.0.0:*               LISTEN      1001       24306611   3003/io.hm-rpc.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          24218982   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          24217901   1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          24218539   274/master
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       24321192   3810/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24305026   2625/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       24311598   3428/io.web.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24320972   3899/io.upnp.0
    udp        0      0 0.0.0.0:38931           0.0.0.0:*                           1001       24320626   3899/io.upnp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       24454232   4306/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       24454233   4306/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          24219294   202/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          24217900   1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24305556   2836/io.chromecast.
    udp6       0      0 :::111                  :::*                                0          24217902   1/init
    udp6       0      0 fe80::be24:11ff:fee:546 :::*                                0          24219862   297/dhclient
    2026-03-29 21:25:03.837  - info: admin.0 (2625) <== Disconnect system.user.admin from ::ffff:192.168.20.19 admin
    2026-03-29 21:25:04.197  - info: admin.0 (2625) ==> Connected system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:25:07.768  - info: admin.0 (2625) ==> Connected system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:25:09.580  - info: host.iob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2026-03-29 21:36:22.628  - info: admin.0 (2625) <== Disconnect system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:36:22.632  - info: admin.0 (2625) <== Disconnect system.user.admin from ::ffff:192.168.20.19 admin
    2026-03-29 21:36:23.032  - info: host.iob instance system.adapter.openweathermap.0 in version "1.4.0" started with pid 4612
    2026-03-29 21:36:23.035  - info: admin.0 (2625) ==> Connected system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:36:27.904  - info: admin.0 (2625) ==> Connected system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:36:27.977  - info: openweathermap.0 (4612) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.20.2, js-controller: 7.0.7
    2026-03-29 21:36:29.626  - info: host.iob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2026-03-29 21:36:49.029  - info: openweathermap.0 (4612) Terminated (NO_ERROR): Without reason
    2026-03-29 21:36:49.543  - info: host.iob instance system.adapter.openweathermap.0 having pid 4612 terminated with code 0 (NO_ERROR)
    2026-03-29 21:37:01.800  - info: admin.0 (2625) <== Disconnect system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:37:10.767  - info: admin.0 (2625) ==> Connected system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:37:12.628  - info: host.iob Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2026-03-29 21:38:06.577  - info: admin.0 (2625) ==> Connected system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:38:08.483  - info: admin.0 (2625) <== Disconnect system.user.admin from ::ffff:192.168.20.19 javascript
    2026-03-29 21:41:24.420  - info: admin.0 (2625) <== Disconnect system.user.admin from ::ffff:192.168.20.19
    2026-03-29 21:44:26.233  - info: host.iob iobroker add homekit-controller --host iob
    2026-03-29 21:44:28.527  - info: host.iob iobroker NPM version: 10.8.2
    2026-03-29 21:44:28.527  - info: host.iob iobroker Installing iobroker.homekit-controller@0.5.11... (System call)
    2026-03-29 21:44:36.167  - error: host.iob iobroker npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.17.13-2-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v20.20.2npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-03-29T19_44_28_612Z-debug-0.log
    2026-03-29 21:44:36.168  - error: host.iob iobroker host.iob Cannot install iobroker.homekit-controller@0.5.11: 7
    2026-03-29 21:44:37.183  - info: host.iob iobroker exit 25
    iob diag has finished.
    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
    • Horst BöttcherH Horst Böttcher
      DANKE
      NPM-Version: 10.8.2
      ```bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      iob
      HOME=/home/iob
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/iob
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
               5000 M total memory
               1908 M used memory
                950 M active memory
               2802 M free memory
                  0 M buffer memory
                288 M swap cache
               5000 M total swap
                755 M used swap
               4244 M free swap
      *** FILESYSTEM ***
      /var:
      554M    /var/
      351M    /var/cache
      347M    /var/cache/apt
      162M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.22
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        84712
      States:         64082
      @Horst-Böttcher sagte in HomeKit Controller last sich nicht installieren:
      Das Thema hatten wird doch gerade schon...
      UPDATEN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
      Ist dein buildenvironment okay?
      sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
      Edit:
      Grundsätzlich baut der Adapter auf einem aktuellen System:
      echad@chet:~ $ iob add homekit-controller --host chet --debug
      NPM version: 11.11.1
      added 11 packages in 14s
      260 packages are looking for funding
        run `npm fund` for details
      host.chet install adapter homekit-controller
      upload [127] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/asset-manifest.json asset-manifest.json application/json
      upload [100] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Cold Water.937aad5fa21b0c20a856.svg static/media/Cold Water.937aad5fa21b0c20a856.svg image/svg+xml
      upload [90] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Doorstep.10630b759b4867a10776.svg static/media/Doorstep.10630b759b4867a10776.svg image/svg+xml
      upload [80] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg static/media/Garage Doors.0c2a1cfca7ad1ea59625.svg image/svg+xml
      upload [70] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Handle.3de1d1320fc3ce2f9712.svg static/media/Handle.3de1d1320fc3ce2f9712.svg image/svg+xml
      upload [60] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Laundry Room.58da550dff0173676e02.svg static/media/Laundry Room.58da550dff0173676e02.svg image/svg+xml
      upload [50] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Music.67bc6063cb601642fd74.svg static/media/Music.67bc6063cb601642fd74.svg image/svg+xml
      upload [40] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Pump.a6035507cddbe7db5f6a.svg static/media/Pump.a6035507cddbe7db5f6a.svg image/svg+xml
      upload [30] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/SmokeDetector.8222f77cb07030a409ee.svg static/media/SmokeDetector.8222f77cb07030a409ee.svg image/svg+xml
      upload [20] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Temperature Sensors.75d805988a6b77b231d8.svg static/media/Temperature Sensors.75d805988a6b77b231d8.svg image/svg+xml
      upload [19] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
      upload [18] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
      upload [17] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
      upload [16] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
      upload [15] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
      upload [14] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
      upload [13] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
      upload [12] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
      upload [11] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
      upload [10] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
      upload [9] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Water Heater.7e4bb4d99a5213f24d08.svg static/media/Water Heater.7e4bb4d99a5213f24d08.svg image/svg+xml
      upload [8] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
      upload [7] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Wc.83604dd2daafb67067dd.svg static/media/Wc.83604dd2daafb67067dd.svg image/svg+xml
      upload [6] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Weather.e91dae647698d48365e3.svg static/media/Weather.e91dae647698d48365e3.svg image/svg+xml
      upload [5] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Window.421664f57c35e5109aa2.svg static/media/Window.421664f57c35e5109aa2.svg image/svg+xml
      upload [4] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Windscreen.6058448bf63f72dd5036.svg static/media/Windscreen.6058448bf63f72dd5036.svg image/svg+xml
      upload [3] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Workshop.7856e59fe4f164c90609.svg static/media/Workshop.7856e59fe4f164c90609.svg image/svg+xml
      upload [2] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/Workspace.97d73e419d966bfb6428.svg static/media/Workspace.97d73e419d966bfb6428.svg image/svg+xml
      upload [1] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/names.3a7dae0bd6b8b03b280f.txt static/media/names.3a7dae0bd6b8b03b280f.txt text/plain
      upload [0] homekit-controller.admin /opt/iobroker/node_modules/iobroker.homekit-controller/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
      host.chet object system.adapter.homekit-controller created/updated
      Updating objects from io-package.json for adapter "homekit-controller" with version "0.5.11"
      host.chet create instance homekit-controller
      host.chet object system.adapter.homekit-controller.0.alive created
      host.chet object system.adapter.homekit-controller.0.connected created
      host.chet object system.adapter.homekit-controller.0.compactMode created
      host.chet object system.adapter.homekit-controller.0.cpu created
      host.chet object system.adapter.homekit-controller.0.cputime created
      host.chet object system.adapter.homekit-controller.0.memHeapUsed created
      host.chet object system.adapter.homekit-controller.0.memHeapTotal created
      host.chet object system.adapter.homekit-controller.0.memRss created
      host.chet object system.adapter.homekit-controller.0.uptime created
      host.chet object system.adapter.homekit-controller.0.inputCount created
      host.chet object system.adapter.homekit-controller.0.outputCount created
      host.chet object system.adapter.homekit-controller.0.eventLoopLag created
      host.chet object system.adapter.homekit-controller.0.sigKill created
      host.chet object system.adapter.homekit-controller.0.logLevel created
      host.chet object system.adapter.homekit-controller.0.objectsWarnLimit created
      host.chet object homekit-controller.0.info created
      host.chet object homekit-controller.0.info.connection created
      host.chet Set default value of homekit-controller.0.info.connection: false
      host.chet object system.adapter.homekit-controller.0 created
      echad@chet:~ $
      • ilovegymI Offline
        ilovegymI Offline
        ilovegym
        und warum noch das Repo von Node 18 drin? :) Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        nimm das mal raus.. du wurschtelst da rum und mixed versionen..
        • ilovegymI ilovegym
          crunchipC Offline
          crunchipC Offline
          @ilovegym sagte in HomeKit Controller last sich nicht installieren:
          das ist eher das generelle Problem, erst sollte man eines lösen, bevor man schon wieder an anderer Stelle bastelt
            Horst Böttcher
            schrieb am zuletzt editiert von Horst Böttcher
            „Ich hab jetzt einmal komplett aufgeräumt, alle Repositories rausgeworfen und ein sauberes System-Update gemacht – jetzt läuft es endlich wieder. Man sollte echt vorsichtig sein, wenn man blind Tipps aus irgendwelchen Foren übernimmt, die man über Google findet. Lektion gelernt!“
            das einziege problem ich kann sie nicht verbinden
              Dazu sollte es etwasim LogFile geben.
                Horst Böttcher
                Kann jetzt gerne geschlossen werden 🙂
                Fehler ist gefunden – und ja… es war mal wieder ein klassischer Fall von: Erst Logs lesen, dann denken… und nicht andersrum 😄
                Nachdem ich mir das Ganze nochmal in Ruhe angeschaut habe, war das Problem dann doch offensichtlicher als gedacht. Manchmal steht die Lösung halt schon direkt vor einem – man muss nur richtig hinschauen.
                Danke euch trotzdem fürs Mitdenken! 🙌 @thomas-braun
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @Horst-Böttcher
                  Und die Lösung gibs nur gegen Cash oder wie ist der Hilfe-Lösung Gedanke von einem Forum?
                  • ilovegymI Offline
                    ilovegymI Offline
                    ilovegym
                    @horst-böttcher wichtig ist, der Reihe nach vorgehen, bei jeder Änderung den Stand und Status checken, dann erst weiter machen..
