  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
  • tiga3110T Offline
    tiga3110T Offline
    tiga3110
    #3243
    nochmals geprüft mit version aus git:
    fc7f7e4c-e3fe-4eda-9ebb-a7efc9dbff7f-image.png bzw.
    vw-connect.1
    2026-03-18 08:59:09.722	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:59:09.590	error	Reconnect count exceeded. Stop MQTT
    vw-connect.1
    2026-03-18 08:58:09.587	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:57:09.451	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:56:09.326	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:55:09.181	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:54:09.054	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    husqvarna-automower.0
    2026-03-18 08:53:45.967	info	Accepted. Command PARKUNTILFURTHERNOTICE Set.
    vw-connect.1
    2026-03-18 08:53:08.905	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:52:08.759	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:51:08.616	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:50:08.484	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:49:08.339	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    vw-connect.1
    2026-03-18 08:48:08.215	error	MQTT Offline
    vw-connect.1
    2026-03-18 08:48:08.212	error	MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
    • T tombox
      @MartinSteinNoki mal die GitHub version testen
      TT-Tom
      #3244
      @tombox
      aktuell kommt diese Fehlermeldung, keine MQTT Meldungen
      vw-connect.0
      2026-03-18 09:54:45.179	error	"Too many requests"
      vw-connect.0
      2026-03-18 09:54:45.179	error	AxiosError: Request failed with status code 429
      vw-connect.0
      2026-03-18 09:54:45.179	error	https://mysmob.api.connect.skoda-auto.cz/api/v1/vehicle-health-report/warning-lights/
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
        SabineT
        #3245
        Nach knapp 2 Stunden kommt die Meldung bei mir jetzt wieder:
        2026-03-18 08:13:12.770  - info: host.iobroker instance system.adapter.vw-connect.0 in version "0.7.15" (non-npm: ta2k/ioBroker.vw-connect) started with pid 170267
        2026-03-18 10:01:16.461  - error: vw-connect.0 (170267) MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
        2026-03-18 10:01:16.462  - error: vw-connect.0 (170267) MQTT Offline
        2026-03-18 10:02:22.061  - error: vw-connect.0 (170267) MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
        2026-03-18 10:03:27.680  - error: vw-connect.0 (170267) MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
        • I Offline
          I Offline
          Int17
          schrieb am zuletzt editiert von Int17
          #3246
          Muss mich revidieren. Fehler kommt wieder, auch wenn es was gedauert hat.
          2026-03-18 13:07:34.665 - info: host.iobroker "system.adapter.vw-connect.0" enabled
          2026-03-18 13:07:34.853 - info: host.iobroker instance system.adapter.vw-connect.0 in version "0.7.15" (non-npm: ta2k/ioBroker.vw-connect) started with pid 28294
          2026-03-18 13:07:35.230 - debug: vw-connect.0 (28294) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2026-03-18 13:07:35.242 - debug: vw-connect.0 (28294) Objects client ready ... initialize now
          2026-03-18 13:07:35.243 - debug: vw-connect.0 (28294) Objects create System PubSub Client
          2026-03-18 13:07:35.243 - debug: vw-connect.0 (28294) Objects create User PubSub Client
          2026-03-18 13:07:35.263 - debug: vw-connect.0 (28294) Objects client initialize lua scripts
          2026-03-18 13:07:35.264 - debug: vw-connect.0 (28294) Objects connected to redis: 127.0.0.1:9001
          2026-03-18 13:07:35.282 - debug: vw-connect.0 (28294) Redis States: Use Redis connection: 127.0.0.1:9000
          2026-03-18 13:07:35.288 - debug: vw-connect.0 (28294) States create System PubSub Client
          2026-03-18 13:07:35.288 - debug: vw-connect.0 (28294) States create User PubSub Client
          2026-03-18 13:07:35.338 - debug: vw-connect.0 (28294) States connected to redis: 127.0.0.1:9000
          2026-03-18 13:07:35.349 - debug: vw-connect.0 (28294) Plugin sentry Initialize Plugin (enabled=true)
          2026-03-18 13:07:35.665 - info: vw-connect.0 (28294) starting. Version 0.7.15 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v22.22.1, js-controller: 7.1.0
          2026-03-18 13:07:35.672 - info: vw-connect.0 (28294) Login in with skodae
          2026-03-18 13:07:35.672 - debug: vw-connect.0 (28294) Login URL: https://identity.vwgroup.io/oidc/v1/authorize?client_id=7f045eee-7003-4379-9968-9355ed2adb06@apps_vw-dilab_com&scope=address badge birthdate cars driversLicense dealers email mileage mbb nationalIdentifier openid phone profession profile vin&response_type=code&redirect_uri=myskoda%3A%2F%2Fredirect%2Flogin%2F&nonce=c9fDvdg5ulJakOgloDEeTL+Wdrt/9aYabdRq3LhppUc&state=5e7d56cb-3ea9-4823-b9a0-3523acd68b49&code_challenge=7oHZS69VtsDuLpvlIYcllLrTyImu57-4Posuk42rdDY&code_challenge_method=S256
          2026-03-18 13:07:35.917 - debug: vw-connect.0 (28294) parseEmailForm - Legacy authentication
          2026-03-18 13:07:36.098 - debug: vw-connect.0 (28294) emailPasswordForm2
          2026-03-18 13:07:36.357 - debug: vw-connect.0 (28294) ""
          2026-03-18 13:07:36.357 - debug: vw-connect.0 (28294) {"date":"Wed, 18 Mar 2026 12:07:36 GMT","content-length":"0","connection":"keep-alive","x-content-type-options":"nosniff","x-xss-protection":"0","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","strict-transport-security":"max-age=31536000; includeSubDomains; preload","x-frame-options":"DENY","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=7f045eee-7003-4379-9968-9355ed2adb06@apps_vw-dilab_com&relayState=b62a4c6752d716b3e80349e80691e82060b6f71a&userId=40f49f1c-a6bd-4635-9696-45b9e7bf9706&HMAC=8c2d786a2f34832ffeb048e150bf4a62240791e9e96efcaa51708561c6e6e18b","content-language":"en-US","apigw-requestid":"aaxNViRMliAEMug="}
          2026-03-18 13:07:36.816 - debug: vw-connect.0 (28294) Error: Invalid protocol: myskoda:
          2026-03-18 13:07:37.338 - info: vw-connect.0 (28294) History limit: 100, set to -1 to disable wallcharging login
          2026-03-18 13:07:37.500 - info: vw-connect.0 (28294) Wallbox is not paired
          2026-03-18 13:07:37.500 - info: vw-connect.0 (28294) Login successful
          2026-03-18 13:07:37.708 - debug: vw-connect.0 (28294) get user data {"id":"40f49f1c-a6bd-4615-9696-45b9e7bf9706","email":"<mail address","firstName":"<vorname>","lastName":"<nachname>","nickname":"<nickname>","country":"DE","countryOfResidence":"DE","preferredLanguage":"de","phone":"+4915120721258","billingAddress":{"country":"DE","city":"<city>","street":"<street>","houseNumber":"<no>","zipCode":"<zip>"},"capabilities":[{"id":"SPIN_MANAGEMENT"},{"id":"MARKETING_CONSENT_SAD"},{"id":"MARKETING_CONSENT_SAD_THIRDPARTY"},{"id":"MARKETING_CONSENT_SAD_DEALERS"},{"id":"TEST_DRIVE"},{"id":"LOYALTY_PROGRAM"}],"profilePictureUrl":"https://mysmob.api.connect.skoda-auto.cz/api/v1/users/40f49f1c-a6bd-4615-9696-45b9e7bf9706/profile-picture?etag=0x8DE3A4BC33C5A38"}
          2026-03-18 13:07:38.136 - debug: vw-connect.0 (28294) {"vehicles":[{"vin":"<vin>","name":"Elroq","licensePlate":"<kennz>","state":"ACTIVATED","devicePlatform":"WCAR","systemModelId":"PYLJK2","title":"Škoda Elroq","renders":[],"compositeRenders":[{"layers":[{"url":"https://iprenders.blob.core.windows.net/basepylv25100027/1Z1Zvr8nahSydHgm4D306k-AvLGoPZ4eqYJyhjz9NVlIcDU3.-mhK.sRacDYUfiG6B3-FAPTINDK-19201080dayvext_side1080.png","viewPoint":"exterior_side","type":"REAL","order":0}],"viewType":"UNMODIFIED_EXTERIOR_SIDE"}],"priority":0}]}
          2026-03-18 13:07:38.136 - info: vw-connect.0 (28294) Found 1 vehicles
          2026-03-18 13:07:38.185 - debug: vw-connect.0 (28294) Connecting to MQTT
          2026-03-18 13:07:38.284 - error: vw-connect.0 (28294) MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
          2026-03-18 13:07:38.285 - error: vw-connect.0 (28294) MQTT Offline
          2026-03-18 13:07:38.285 - info: vw-connect.0 (28294) MQTT Connection closed
          2026-03-18 13:07:38.363 - debug: vw-connect.0 (28294) {"overall":{"doorsLocked":"YES","locked":"YES","doors":"CLOSED","windows":"CLOSED","lights":"OFF","reliableLockStatus":"LOCKED"},"detail":{"sunroof":"UNSUPPORTED","trunk":"CLOSED","bonnet":"CLOSED"},"renders":{"lightMode":{"oneX":"https://mysmob.api.connect.skoda-auto.cz/api/v2/vehicle-status/render?carType=SUV&vehicleState=1-1-1-1-0-0-0-0-0&lastModifiedAt=1771857953&dimension=1x&theme=LIGHT","oneAndHalfX":"https://mysmob.api.connect.skoda-auto.cz/api/v2/vehicle-status/render?carType=SUV&vehicleState=1-1-1-1-0-0-0-0-0&lastModifiedAt=1771857953&dimension=1-5x&theme=LIGHT","twoX":"https://mysmob.api.connect.skoda-auto.cz/api/v2/vehicle-status/render?carType=SUV&vehicleState=1-1-1-1-0-0-0-0-0&lastModifiedAt=1771857953&dimension=2x&theme=LIGHT","threeX":"https://mysmob.api.connect.skoda-auto.cz/api/v2/vehicle-status/render?carType=SUV&vehicleState=1-1-1-1-0-0-0-0-0&lastModifiedAt=1771857953&dimension=3x&theme=LIGHT"},"darkMode":{"oneX":"https://mysmob.api.connect.skoda-auto.cz/api/v2/vehicle-status/render?carType=SUV&vehicleState=1-1-1-1-0-0-0-0-0&lastModifiedAt=1771857953&dimension=1x&theme=DARK","oneAndHalfX":"https://mysmob.api.connect.skoda-auto.cz/api/v2/vehicle-status/render?carType=SUV&vehicleState=1-1-1-1-0-0-0-0-0&lastModifiedAt=1771857953&dimension=1-5x&theme=DARK","twoX":"https://mysmob.api.connect.skoda-auto.cz/api/v2/vehicle-status/render?carType=SUV&vehicleState=1-1-1-1-0-0-0-0-0&lastModifiedAt=1771857953&dimension=2x&theme=DARK","threeX":"https://mysmob.api.connect.skoda-auto.cz/api/v2/vehicle-status/render?carType=SUV&vehicleState=1-1-1-1-0-0-0-0-0&lastModifiedAt=1771857953&dimension=3x&theme=DARK"}},"carCapturedTimestamp":"2026-03-18T11:00:18.844Z"}
          2026-03-18 13:07:38.363 - debug: vw-connect.0 (28294) <vin>.status.vehicle-status
          2026-03-18 13:07:38.363 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:38.591 - debug: vw-connect.0 (28294) {"carType":"electric","totalRangeInKm":347,"primaryEngineRange":{"engineType":"electric","currentSoCInPercent":80,"remainingRangeInKm":347},"carCapturedTimestamp":"2026-03-18T12:00:16.094Z"}
          2026-03-18 13:07:38.591 - debug: vw-connect.0 (28294) <vin>.status.vehicle-status.driving-range
          2026-03-18 13:07:38.591 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:39.813 - debug: vw-connect.0 (28294) {"isVehicleInSavedLocation":true,"status":{"chargePowerInKw":0,"remainingTimeToFullyChargedInMinutes":0,"fullyChargedAt":"2026-03-18T06:50:32Z","state":"CONNECT_CABLE","battery":{"remainingCruisingRangeInMeters":347000,"stateOfChargeInPercent":80}},"settings":{"targetStateOfChargeInPercent":100,"batteryCareModeTargetValueInPercent":80,"preferredChargeMode":"MANUAL","availableChargeModes":["MANUAL"],"chargingCareMode":"ACTIVATED","autoUnlockPlugWhenCharged":"OFF","maxChargeCurrentAc":"MAXIMUM"},"carCapturedTimestamp":"2026-03-18T11:00:27Z","errors":[]}
          2026-03-18 13:07:39.813 - debug: vw-connect.0 (28294) <vin>.status.charging
          2026-03-18 13:07:39.813 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:40.300 - debug: vw-connect.0 (28294) {"state":"OFF","runningRequests":[],"targetTemperature":{"temperatureValue":21,"unitInCar":"CELSIUS"},"airConditioningAtUnlock":false,"windowHeatingEnabled":false,"steeringWheelPosition":"LEFT","seatHeatingActivated":{"frontLeft":true,"frontRight":false},"chargerConnectionState":"DISCONNECTED","chargerLockState":"UNLOCKED","windowHeatingState":{"front":"OFF","rear":"OFF","unspecified":"INVALID"},"timers":[{"id":1,"enabled":false,"time":"00:00","type":"ONE_OFF","selectedDays":["SATURDAY"]},{"id":2,"enabled":false,"time":"00:00","type":"ONE_OFF","selectedDays":["SATURDAY"]}],"carCapturedTimestamp":"2026-03-18T11:00:26Z","outsideTemperature":{"temperatureValue":14.5,"temperatureUnit":"CELSIUS","carCapturedTimestamp":"2026-03-18T11:22:07.717Z"},"errors":[]}
          2026-03-18 13:07:40.300 - debug: vw-connect.0 (28294) <vin>.status.air-conditioning
          2026-03-18 13:07:40.300 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:40.534 - debug: vw-connect.0 (28294) {"state":"INVALID","durationInSeconds":600,"timers":[{"id":1,"enabled":false,"time":"00:00","type":"ONE_OFF","selectedDays":["SATURDAY"]},{"id":2,"enabled":false,"time":"00:00","type":"ONE_OFF","selectedDays":["SATURDAY"]}],"carCapturedTimestamp":"2026-03-18T11:00:25Z","errors":[]}
          2026-03-18 13:07:40.535 - debug: vw-connect.0 (28294) <vin>.status.ventilation
          2026-03-18 13:07:40.535 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:40.771 - debug: vw-connect.0 (28294) {"targetTemperature":{"temperatureValue":21,"unitInCar":"CELSIUS"},"state":"INVALID","durationInSeconds":600,"timers":[{"id":1,"enabled":false,"time":"00:00","type":"ONE_OFF","selectedDays":["SATURDAY"]},{"id":2,"enabled":false,"time":"00:00","type":"ONE_OFF","selectedDays":["SATURDAY"]}],"carCapturedTimestamp":"2026-03-18T11:00:25Z","errors":[]}
          2026-03-18 13:07:40.772 - debug: vw-connect.0 (28294) <vin>.status.auxiliary-heating
          2026-03-18 13:07:40.772 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:41.064 - debug: vw-connect.0 (28294) {"maintenanceReport":{"capturedAt":"2026-03-18T12:00:14.896Z","inspectionDueInDays":422,"mileageInKm":9743},"preferredServicePartner":{"name":"Autohaus Minrath GmbH & Co.KG","brand":"C","partnerNumber":"47937","id":"DEUC47937","contact":{"phone":"+49 2841 1450","url":"http://x.skoda-auto.de","email":"x.kd@partner.skoda-auto.de"},"address":{"street":"x  6","zipCode":"x","city":"x","countryCode":"DEU"},"location":{"latitude":52.55889,"longitude":6.7902857},"openingHours":[{"periodStart":"MONDAY","periodEnd":"FRIDAY","openingTimes":[{"from":"07:00:00","to":"18:00:00"}]},{"periodStart":"SATURDAY","periodEnd":"SATURDAY","openingTimes":[{"from":"08:00:00","to":"12:30:00"}]},{"periodStart":"SUNDAY","periodEnd":"SUNDAY","openingTimes":[]}]},"predictiveMaintenance":{"setting":{"serviceActivated":true,"email":"<emal>","phone":"<mobil>"}}}
          2026-03-18 13:07:41.065 - debug: vw-connect.0 (28294) <vin>.status.vehicle-maintenancevehicles
          2026-03-18 13:07:41.065 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:41.313 - debug: vw-connect.0 (28294) {"capturedAt":"2026-03-18T12:00:14.896Z","inspectionDueInDays":422,"mileageInKm":9743}
          2026-03-18 13:07:41.313 - debug: vw-connect.0 (28294) <vin>.status.vehicle-maintenancevehicles.report
          2026-03-18 13:07:41.313 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:41.473 - debug: vw-connect.0 (28294) {"parkingPosition":{"gpsCoordinates":{"latitude":51.449547,"longitude":6.613958},"formattedAddress":"Möwenweg 13, 47441 Moers, Germany"}}
          2026-03-18 13:07:41.473 - debug: vw-connect.0 (28294) <vin>.status.position
          2026-03-18 13:07:41.473 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:41.473 - debug: vw-connect.0 (28294) Set is car moving to false
          2026-03-18 13:07:41.520 - debug: vw-connect.0 (28294) {"devicePlatform":"WCAR","vehicleSpecification":{"title":"Škoda Elroq","manufacturingDate":"2025-03-10","model":"Elroq","modelYear":"2025","body":"SUV","trimLevel":"85","systemCode":"UNKNOWN","systemModelId":"PYLJK2","maxChargingPowerInKW":125,"battery":{"capacityInKWh":77},"engine":{"type":"iV","powerInKW":210},"gearbox":{"type":"E1H"}},"renders":[],"compositeRenders":[{"layers":[{"url":"https://iprenders.blob.core.windows.net/basepylv25100027/1Z1Zvr8nahSydHgm4D306k-AvLGoPZ4eqYJyhjz9NVlIcDU3.-mhK.sRacDYUfiG6B3-FAPTINDK-19201080dayvext_side1080.png","viewPoint":"EXTERIOR_SIDE","type":"REAL","order":0}],"viewType":"UNMODIFIED_EXTERIOR_SIDE"}]}
          2026-03-18 13:07:41.520 - debug: vw-connect.0 (28294) <vin>.status.vehicle-information
          2026-03-18 13:07:41.520 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:41.594 - debug: vw-connect.0 (28294) air-conditioning /settings
          2026-03-18 13:07:41.594 - debug: vw-connect.0 (28294) AxiosError: Request failed with status code 403
          2026-03-18 13:07:41.594 - debug: vw-connect.0 (28294) ""
          2026-03-18 13:07:41.652 - debug: vw-connect.0 (28294) charging /settings
          2026-03-18 13:07:41.652 - debug: vw-connect.0 (28294) AxiosError: Request failed with status code 404
          2026-03-18 13:07:41.652 - debug: vw-connect.0 (28294) {"timestamp":"2026-03-18T12:07:41.641+00:00","path":"/api/v1/charging/<vin>/settings","status":404,"error":"Not Found","requestId":"96fdccce-103426740"}
          2026-03-18 13:07:41.652 - debug: vw-connect.0 (28294) Vehicle is not supporting charging /settings
          2026-03-18 13:07:41.809 - debug: vw-connect.0 (28294) {"capturedAt":"2026-03-17T14:29:41.896Z","mileageInKm":9743,"warningLights":[{"category":"ASSISTANCE","defects":[]},{"category":"COMFORT","defects":[]},{"category":"BRAKE","defects":[]},{"category":"ELECTRIC_ENGINE","defects":[]},{"category":"LIGHTING","defects":[]},{"category":"TIRE","defects":[]},{"category":"OTHER","defects":[]}]}
          2026-03-18 13:07:41.809 - debug: vw-connect.0 (28294) <vin>.status.health
          2026-03-18 13:07:41.809 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:42.083 - debug: vw-connect.0 (28294) {"unreachable":false,"inMotion":false,"ignitionOn":false,"batteryProtectionLimitOn":false}
          2026-03-18 13:07:42.084 - debug: vw-connect.0 (28294) <vin>.status.connectionStatus
          2026-03-18 13:07:42.084 - debug: vw-connect.0 (28294) 200
          2026-03-18 13:07:42.131 - debug: vw-connect.0 (28294) fueling/sessions
          2026-03-18 13:07:42.131 - debug: vw-connect.0 (28294) AxiosError: Request failed with status code 500
          2026-03-18 13:07:42.131 - debug: vw-connect.0 (28294) "Internal server error"
          2026-03-18 13:07:42.131 - info: vw-connect.0 (28294) Server not available. For endpoint fueling/sessions Please try again later:"Internal server error"
          2026-03-18 13:07:42.192 - debug: vw-connect.0 (28294) fueling/sessions /state
          2026-03-18 13:07:42.193 - debug: vw-connect.0 (28294) AxiosError: Request failed with status code 500
          2026-03-18 13:07:42.193 - debug: vw-connect.0 (28294) "Internal server error"
          2026-03-18 13:07:42.193 - info: vw-connect.0 (28294) Server not available. For endpoint fueling/sessions/state Please try again later:"Internal server error"
          2026-03-18 13:07:42.250 - debug: vw-connect.0 (28294) fueling/locations
          2026-03-18 13:07:42.250 - debug: vw-connect.0 (28294) AxiosError: Request failed with status code 500
          2026-03-18 13:07:42.250 - debug: vw-connect.0 (28294) "Internal server error"
          2026-03-18 13:07:42.251 - info: vw-connect.0 (28294) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
          2026-03-18 13:07:42.284 - debug: vw-connect.0 (28294) fueling/sessions /latest
          2026-03-18 13:07:42.284 - debug: vw-connect.0 (28294) AxiosError: Request failed with status code 404
          2026-03-18 13:07:42.284 - debug: vw-connect.0 (28294) {"timestamp":"2026-03-18T12:07:42.275+00:00","path":"/api/v2/fueling/sessions/<vin>/latest","status":404,"error":"Not Found","requestId":"66063cd7-105591692"}
          2026-03-18 13:07:42.284 - debug: vw-connect.0 (28294) Vehicle is not supporting fueling/sessions /latest
          2026-03-18 13:07:42.427 - debug: vw-connect.0 (28294) trip-statistics
          2026-03-18 13:07:42.427 - debug: vw-connect.0 (28294) AxiosError: Request failed with status code 403
          2026-03-18 13:07:42.427 - debug: vw-connect.0 (28294) "Not authorized"
          2026-03-18 13:07:42.712 - debug: vw-connect.0 (28294) trip-statistics
          2026-03-18 13:07:42.712 - debug: vw-connect.0 (28294) AxiosError: Request failed with status code 403
          2026-03-18 13:07:42.712 - debug: vw-connect.0 (28294) "Not authorized"
          2026-03-18 13:07:51.908 - info: host.iobroker "system.adapter.vw-connect.0" disabled
          • I Int17
            tombox
            #3247
            @Int17 Eigenartig man könnte fast denken skoda macht das mit Absicht
              Sven77PV
              #3248
              "Könnte"?
              Es ist sogar SEHR sicher, dass die das mit Absicht machen. Es ist noch gar nicht lange her, als ganz spezifisch "ioBroker" als client-id gesperrt wurde (kann mich nicht mehr genau erinnern, aber es wurde damals dann einfach die Groß-/Kleinschreibung geändert und später glaube ich die gleiche wie in der App benutzt).
              Letztlich wollen die ja auch nicht, dass "irgendjemand" ihre undokumentierten APIs nutzt.
              Nicht, dass am Ende keiner mehr die aufgeblähten Apps installiert oder gar Funktionen findet, die in der App noch gar nicht extistieren.
              • S Sven77PV
                "Könnte"?
                tombox
                #3249
                @Sven77PV nochmal den adapter neustarten ob es jetzt geht.. myskoda hat nochmal was geändert
                  Sven77PV
                  #3250
                  Vielen Dank für den Hinweis!
                  Das betrifft aber nur den user-agent, den setzen die von mir verwendeten Tools gar nicht bzw. anders.
                  Hauptsache es funktioniert (mal) wieder.
                  Dir vielen Dank für's Reverse Engineering!!
                  • I Offline
                    I Offline
                    Int17
                    #3251
                    @tombox
                    Habe die neue Version 0.7.16 installiert, beim Start kommt wieder
                    2026-03-19 10:16:46.549 - debug: vw-connect.0 (147241) <vin>.status.health
                    2026-03-19 10:16:46.549 - debug: vw-connect.0 (147241) 200
                    2026-03-19 10:16:47.987 - debug: vw-connect.0 (147241) {"unreachable":false,"inMotion":false,"ignitionOn":false,"batteryProtectionLimitOn":false}
                    2026-03-19 10:16:47.987 - debug: vw-connect.0 (147241) TMBNH9NY4SF082588.status.connectionStatus
                    2026-03-19 10:16:47.987 - debug: vw-connect.0 (147241) 200
                    2026-03-19 10:16:48.040 - debug: vw-connect.0 (147241) fueling/sessions
                    2026-03-19 10:16:48.040 - debug: vw-connect.0 (147241) AxiosError: Request failed with status code 404
                    2026-03-19 10:16:48.040 - debug: vw-connect.0 (147241) "Resource not found"
                    2026-03-19 10:16:48.040 - debug: vw-connect.0 (147241) Vehicle is not supporting fueling/sessions
                    2026-03-19 10:16:48.090 - debug: vw-connect.0 (147241) fueling/sessions /state
                    2026-03-19 10:16:48.090 - debug: vw-connect.0 (147241) AxiosError: Request failed with status code 404
                    2026-03-19 10:16:48.090 - debug: vw-connect.0 (147241) "Resource not found"
                    2026-03-19 10:16:48.091 - debug: vw-connect.0 (147241) Vehicle is not supporting fueling/sessions /state
                    2026-03-19 10:16:48.163 - debug: vw-connect.0 (147241) fueling/locations
                    2026-03-19 10:16:48.163 - debug: vw-connect.0 (147241) AxiosError: Request failed with status code 500
                    2026-03-19 10:16:48.163 - debug: vw-connect.0 (147241) "Internal server error"
                    2026-03-19 10:16:48.163 - info: vw-connect.0 (147241) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
                    2026-03-19 10:16:48.205 - debug: vw-connect.0 (147241) fueling/sessions /latest
                    2026-03-19 10:16:48.205 - debug: vw-connect.0 (147241) AxiosError: Request failed with status code 404
                    2026-03-19 10:16:48.205 - debug: vw-connect.0 (147241) {"timestamp":"2026-03-19T09:16:48.196+00:00","path":"/api/v2/fueling/sessions/<vin>/latest","status":404,"error":"Not Found","requestId":"df287dcf-118990451"}
                    2026-03-19 10:16:48.205 - debug: vw-connect.0 (147241) Vehicle is not supporting fueling/sessions /latest
                    2026-03-19 10:16:48.366 - debug: vw-connect.0 (147241) trip-statistics
                    2026-03-19 10:16:48.366 - debug: vw-connect.0 (147241) AxiosError: Request failed with status code 403
                    2026-03-19 10:16:48.366 - debug: vw-connect.0 (147241) "Not authorized"
                    2026-03-19 10:16:48.755 - debug: vw-connect.0 (147241) trip-statistics
                    2026-03-19 10:16:48.755 - debug: vw-connect.0 (147241) AxiosError: Request failed with status code 403
                    2026-03-19 10:16:48.755 - debug: vw-connect.0 (147241) "Not authorized"
                    2026-03-19 10:17:00.177 - info: host.iobroker "system.adapter.vw-connect.0" disabled
                    • I Int17
                      @tombox
                      tombox
                      #3252
                      @Int17 nur error sind relevant nicht debug
                      • T tombox
                        MartinSteinNoki
                        #3253
                        @tombox Das Auto steht noch bis Samstag in einer Tiefgerage und ist offline.
                        Wenn ich es aus Github installiere, muss ich das als eigene Istanz installieren, oder kann ich die bestehende überbügeln?
                        Martin
                        • M MartinSteinNoki
                          Martin
                          TT-Tom
                          #3254
                          @MartinSteinNoki
                          Wenn du schon eine Instanz hast brauchst du nur das Update durchführen, die Instanz nutzt automatisch den neuen Code.
                          Gruß Tom
                          Public Transport
                          • U Offline
                            U Offline
                            ULBE01
                            #3255
                            Iobroker: Modell: Cortex-A72
                            RAM: 3.7 GB
                            Node.js: v20.17.0
                            NPM: 10.8.2
                            Mein neuer Passat will nicht mit IOBroker reden :-) Fehlermeldungen (von unten nach oben:
                            Caught by controller[0]: Instead change the require of index.js in /opt/iobroker/node_modules/iobroker.vw-connect/main.js to a dynamic import() which is available in all CommonJS modules.
                            error	Caught by controller[0]: Error [ERR_REQUIRE_ESM]: require() of ES Module /opt/iobroker/node_modules/iobroker.vw-connect/node_modules/uuid/dist-node/index.js from /opt/iobroker/node_modules/iobroker.vw-connect/main.js not supported.
                            error	Caught by controller[0]error	Caught by controller[0]: const { v4: uuidv4 } = require("uuid");
                            error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.vw-connect/main.js:16
                            info	instance system.adapter.vw-connect.0 in version "0.7.15" (non-npm: TA2k/ioBroker.vw-connect#48331ce4ea3112204b4cdea0b78243de9732bfb8) started with pid 443447
                            Was passt da nicht?
                            MOD-EDIT
                            Bitte zukünftig Code-Tags </> benutzen
                            Thomas BraunT T 2 Antworten Letzte Antwort
                            • U ULBE01
                              RAM: 3.7 GB
                              Node.js: v20.17.0
                              NPM: 10.8.2
                              Was passt da nicht?
                              MOD-EDIT
                              #3256
                              @ULBE01 sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                              Node.js: v20.17.0
                              Auf nodejs@22 bringen...
                              iob nodejs-update
                              fertig...
                              Rest vom Fest auch auf Stand bringen.
                              Keine Versionen aus dem GitHub fischen. vw-connect gibt es als ordentliches Release über das Beta-Repo.
                              Verwende das gescheite Log:
                              iobroker logs --watch
                              Das ist auch nicht 'von unten nach oben'...
                              • U Offline
                                U Offline
                                ULBE01
                                #3257
                                Und wo? Google suche findet immer nur git...
                                • U ULBE01
                                  #3258
                                  @ULBE01
                                  Du aktivierst temporär die Beta-Quelle.
                                  • U Offline
                                    U Offline
                                    ULBE01
                                    #3259
                                    Updates sind gelaufen, aber:
                                    Jetzt gibts nur noch ein gelbes Warndreieck und diese Meldung. Und die Connection ist immer noch falsch....
                                    2026-03-21 17:52:31.979 - error: vw-connect.0 (472745) No Token received. Please try to logout and login in the latest MySkoda or MySeat App
                                    • U ULBE01
                                      RAM: 3.7 GB
                                      Node.js: v20.17.0
                                      NPM: 10.8.2
                                      Was passt da nicht?
                                      MOD-EDIT
                                      tombox
                                      #3260
                                      @ULBE01 Ja ist minimum 22.12
                                      steht da noch mehr im log.. das du irgendwelche urls besuchen sollst bzw hast es probier dich in der app auszuloggen und einzuloggen
                                      • U Offline
                                        U Offline
                                        ULBE01
                                        #3261
                                        So sieht die letzte Anmeldung aus:
                                        2026-03-21 18:16:21.690 - info: host.iobroker "system.adapter.vw-connect.0" enabled
                                        2026-03-21 18:16:22.944 - info: host.iobroker instance system.adapter.vw-connect.0 in version "0.7.16" started with pid 473216
                                        2026-03-21 18:16:27.174 - info: vw-connect.0 (473216) starting. Version 0.7.16 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v22.22.1, js-controller: 7.0.7
                                        2026-03-21 18:16:27.221 - info: vw-connect.0 (473216) Login in with go
                                        2026-03-21 18:16:28.432 - warn: vw-connect.0 (473216) No Token received visiting url and accept the permissions or login in the App and accept manually
                                        2026-03-21 18:16:28.432 - info: vw-connect.0 (473216) ...private Daten entfernt...@apps_vw-dilab_com?scopes=openid%20profile%20address%20email%20phone&relayState=....&callback=https://identity.vwgroup.io/oidc/v1/oauth/client/callback&hmac=...private Daten entfetnt...
                                        2026-03-21 18:16:28.554 - error: vw-connect.0 (473216) No Token received. Please try to logout and login in the latest MySkoda or MySeat App
                                        MOD-EDIT: private Daten entfernt!
                                          ShadoVV
                                          #3262
                                          Hi, nach Umstieg vom id.4 auf id.7 wurden der id.7 nicht hinzugefügt, daher habe ich die Instanz auf v0.0.51 geupdated, nun habe ich allerdings dauerhaft das gelbe Warndreieck.
