Test Adapter NSPanel-lovelace-ui v1.x.x
@TT-Tom
Moin,alles klar, hier der entsprechende Auszug:
2026-03-14 13:59:38.195 - [35msilly[39m: nspanel-lovelace-ui.0 (17162) States system redis pmessage io.messagebox.system.adapter.nspanel-lovelace-ui.0/io.messagebox.system.adapter.nspanel-lovelace-ui.0:{"command":"nsPanelInit","message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"RZwmuFYrCeRKKtr","mqttPassword":"1ZS-aFU0[Z1vM9>m]4ZOv0>(tYbQlk:U*MWeoTUgAJeAQ+H-Z:","internalServerIp":"192.168.178.116","useBetaTFT":false,"model":"eu"},"from":"system.adapter.admin.0","callback":{"message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"RZwmuFYrCeRKKtr","mqttPassword":"1ZS-aFU0[Z1vM9>m]4ZOv0>(tYbQlk:U*MWeoTUgAJeAQ+H-Z:","internalServerIp":"192.168.178.116","useBetaTFT":false,"model":"eu"},"id":643,"ack":false,"time":1773493178194},"_id":60922512} false2026-03-14 13:59:38.196 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) {"command":"nsPanelInit","message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"RZwmuFYrCeRKKtr","mqttPassword":"1ZS-aFU0[Z1vM9>m]4ZOv0>(tYbQlk:U*MWeoTUgAJeAQ+H-Z:","internalServerIp":"192.168.178.116","useBetaTFT":false,"model":"eu"},"from":"system.adapter.admin.0","callback":{"message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"RZwmuFYrCeRKKtr","mqttPassword":"1ZS-aFU0[Z1vM9>m]4ZOv0>(tYbQlk:U*MWeoTUgAJeAQ+H-Z:","internalServerIp":"192.168.178.116","useBetaTFT":false,"model":"eu"},"id":643,"ack":false,"time":1773493178194},"_id":60922512} false2026-03-14 13:59:38.196 - [32minfo[39m: nspanel-lovelace-ui.0 (17162) Sending mqtt config & base config to tasmota: 192.168.178.57 with user RZwmuFYrCeRKKtr && *** false2026-03-14 13:59:38.196 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) Requesting tasmota status 5 with url: http://192.168.178.57/cm?&cmnd=status%205 false2026-03-14 13:59:38.391 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) Response from tasmota status 5: {"StatusNET":{"Hostname":"tasmota-0BF3E8-5096","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"E0:E2:E6:0B:F3:E8","IP6Global":"fd9a:b998:ff69:481f:e2e2:e6ff:fe0b:f3e8","IP6Local":"fe80::e2e2:e6ff:fe0b:f3e8%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16}} false2026-03-14 13:59:38.391 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) Sending mqtt config & base config to tasmota with IP 192.168.178.57 and name PanelAnbau. false2026-03-14 13:59:38.476 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) [mqttClient] Wait for panel connect on: PanelAnbau/tele/INFO1 false2026-03-14 13:59:38.476 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) [mqttClient] subscribe to: PanelAnbau/tele/INFO12026-03-14 13:59:51.068 - [35msilly[39m: nspanel-lovelace-ui.0 (17162) Objects system redis pmessage system.config/cfg.o.system.config:{"_id":"system.config","type":"config","common":{"name":{"en":"System configuration","de":"Systemkonfiguration","ru":"Конфигурация системы","pt":"Configuração do sistema","nl":"Systeem configuratie","fr":"Configuration du système","it":"Configurazione di sistema","es":"Configuración del sistema","pl":"Konfiguracja systemu","zh-cn":"系统配置"},"city":"","country":"Germany","longitude":7.484436035156251,"latitude":53.462708023859555,"language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":true,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":["Stable (default)"],"diag":"none","tabs":["tab-intro","tab-adapters","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-logs","tab-devices","tab-iqontrol","tab-instances","tab-hosts","tab-enums","tab-terminal-0","tab-iqontrol-0"],"wizard":true,"infoAdapterInstall":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"intro":["admin.0_8081","alexa2.0_alexa.amazon.com","deconz.0_80","energiefluss-erweitert.0 pro_8082/energiefluss-erweitert/","simple-api.0_8087/get/system.adapter.simple-api.0.uptime?prettyPrint"],"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":false},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-devices","visible":true},{"name":"tab-backitup-0","visible":false},{"name":"tab-javascript","visible":true},{"name":"tab-iqontrol-0","visible":true},{"name":"tab-echarts","visible":true},{"name":"tab-alias-manager","visible":true}],"expertMode":false,"firstDayOfWeek":"monday","adapterAutoUpgrade":{"repositories":{},"defaultPolicy":"minor"}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"d56a14684e44fe5ae44ca75eb8a91008f7009b7b1a61eae4","introLinks":[]},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1773493190553} 2026-03-14 13:59:51.122 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) [mqttServer] Client "PanelAnbau-0BF3E8" login successful (user="RZwmuFYrCeRKKtr"). 2026-03-14 13:59:51.367 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) [mqttClient] Panel connect detected: PanelAnbau/tele/INFO1 2026-03-14 13:59:51.425 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) [mqttClient] Wait for panel connect on: PanelAnbau/tele/INFO1 2026-03-14 13:59:51.425 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) [mqttClient] subscribe to: PanelAnbau/tele/INFO1 2026-03-14 14:00:04.432 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) [mqttServer] Client "PanelAnbau-0BF3E8" login successful (user="RZwmuFYrCeRKKtr"). 2026-03-14 14:00:04.488 - [34mdebug[39m: nspanel-lovelace-ui.0 (17162) [mqttClient] Panel connect detected: PanelAnbau/tele/INFO1 2026-03-14 14:00:06.593 - [31merror[39m: nspanel-lovelace-ui.0 (17162) Error: while installing berry - TypeError: fetch failed 2026-03-14 14:00:08.094 - [31merror[39m: nspanel-lovelace-ui.0 (17162) No version entry for key "tft". 2026-03-14 14:00:08.095 - [31merror[39m: nspanel-lovelace-ui.0 (17162) No version found! -
@muuulle
Kann es sein das dein iobroker keinen zugriff aufhttps://raw.githubusercontent.comhat? Von dort werden die Versionsdaten bzw. das Berryscript geladen? -
Moin,
das ist richtig. Der Adapter lag auf dem Master, der keinen Internetzugang hat. Jetzt ist er auf den Slave mit Internetzugang umgezogen.Leider auch nicht erfolgreich.
2026-03-14 19:54:59.844 - debug: nspanel-lovelace-ui.0 (19669) Redis Objects: Use Redis connection: 192.168.178.116:9001 2026-03-14 19:54:59.919 - debug: nspanel-lovelace-ui.0 (19669) Objects client ready ... initialize now 2026-03-14 19:54:59.922 - debug: nspanel-lovelace-ui.0 (19669) Objects create System PubSub Client 2026-03-14 19:54:59.924 - debug: nspanel-lovelace-ui.0 (19669) Objects create User PubSub Client 2026-03-14 19:55:00.163 - debug: nspanel-lovelace-ui.0 (19669) Objects client initialize lua scripts 2026-03-14 19:55:00.581 - debug: nspanel-lovelace-ui.0 (19669) Objects connected to redis: 192.168.178.116:9001 2026-03-14 19:55:00.585 - silly: nspanel-lovelace-ui.0 (19669) redis psubscribe cfg.o.system.user.* 2026-03-14 19:55:01.114 - silly: nspanel-lovelace-ui.0 (19669) redis psubscribe cfg.o.enum.* 2026-03-14 19:55:01.218 - silly: nspanel-lovelace-ui.0 (19669) objectDB connected 2026-03-14 19:55:01.223 - debug: nspanel-lovelace-ui.0 (19669) Redis States: Use Redis connection: 192.168.178.116:9000 2026-03-14 19:55:01.342 - debug: nspanel-lovelace-ui.0 (19669) States create System PubSub Client 2026-03-14 19:55:01.343 - debug: nspanel-lovelace-ui.0 (19669) States create User PubSub Client 2026-03-14 19:55:01.483 - debug: nspanel-lovelace-ui.0 (19669) States connected to redis: 192.168.178.116:9000 2026-03-14 19:55:01.484 - silly: nspanel-lovelace-ui.0 (19669) statesDB connected 2026-03-14 19:55:01.664 - info: nspanel-lovelace-ui.0 (19669) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.1, js-controller: 7.0.7 2026-03-14 19:55:01.704 - silly: nspanel-lovelace-ui.0 (19669) States system redis pmessage system.adapter.nspanel-lovelace-ui.0.logLevel/system.adapter.nspanel-lovelace-ui.0.logLevel:{"val":"silly","ack":true,"ts":1773514501691,"q":0,"from":"system.adapter.nspanel-lovelace-ui.0","lc":1773469148463} 2026-03-14 19:55:01.722 - error: nspanel-lovelace-ui.0 (19669) No compatible config found for topics: . Adapter paused! 2026-03-14 19:55:01.724 - error: nspanel-lovelace-ui.0 (19669) Error in configuration: No compatible config found for topics: . Adapter paused! 2026-03-14 19:55:01.840 - info: nspanel-lovelace-ui.0 (19669) Create new keys for MQTT server. 2026-03-14 19:55:05.854 - debug: nspanel-lovelace-ui.0 (19669) [library] Load language de 2026-03-14 19:55:05.864 - debug: nspanel-lovelace-ui.0 (19669) [library] Load language de from custom 2026-03-14 19:55:05.870 - info: nspanel-lovelace-ui.0 (19669) [mqttServer] MQTT server started and listening on port 8883 2026-03-14 19:55:07.136 - debug: nspanel-lovelace-ui.0 (19669) [mqttServer] Client "iobroker_508270f3-0342-410c-ab8e-857dcc394e58" login successful (user="RZwmuFYrCeRKKtr"). 2026-03-14 19:55:07.184 - debug: nspanel-lovelace-ui.0 (19669) [mqttClient] MQTT connected. 2026-03-14 19:55:48.050 - info: host.pi-slave instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 19686 2026-03-14 19:55:53.257 - silly: nspanel-lovelace-ui.0 (19669) Objects system redis pmessage system.config/cfg.o.system.config:{"_id":"system.config","type":"config","common":{"name":{"en":"System configuration","de":"Systemkonfiguration","ru":"Конфигурация системы","pt":"Configuração do sistema","nl":"Systeem configuratie","fr":"Configuration du système","it":"Configurazione di sistema","es":"Configuración del sistema","pl":"Konfiguracja systemu","zh-cn":"系统配置"},"city":"","country":"Germany","longitude":7.484436035156251,"latitude":53.462708023859555,"language":"de","tempUnit":"°C","currency":"€","dontDelete":true,"dateFormat":"DD.MM.YYYY","isFloatComma":true,"licenseConfirmed":true,"defaultHistory":"history.0","activeRepo":["Stable (default)"],"diag":"none","tabs":["tab-intro","tab-adapters","tab-objects","tab-logs","tab-scenes","tab-javascript","tab-text2command-0","tab-node-red-0","tab-logs","tab-devices","tab-iqontrol","tab-instances","tab-hosts","tab-enums","tab-terminal-0","tab-iqontrol-0"],"wizard":true,"infoAdapterInstall":true,"defaultNewAcl":{"object":1636,"state":1636,"file":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"intro":["admin.0_8081","alexa2.0_alexa.amazon.com","deconz.0_80","energiefluss-erweitert.0 pro_8082/energiefluss-erweitert/","simple-api.0_8087/get/system.adapter.simple-api.0.uptime?prettyPrint"],"tabsVisible":[{"name":"tab-intro","visible":true},{"name":"tab-adapters","visible":true},{"name":"tab-instances","visible":true},{"name":"tab-objects","visible":true},{"name":"tab-enums","visible":true},{"name":"tab-logs","visible":true},{"name":"tab-users","visible":false},{"name":"tab-hosts","visible":true},{"name":"tab-files","visible":true},{"name":"tab-devices","visible":true},{"name":"tab-backitup-0","visible":false},{"name":"tab-javascript","visible":true},{"name":"tab-iqontrol-0","visible":true},{"name":"tab-echarts","visible":true},{"name":"tab-alias-manager","visible":true}],"expertMode":false,"firstDayOfWeek":"monday","adapterAutoUpgrade":{"repositories":{},"defaultPolicy":"minor"}},"acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1604},"native":{"secret":"d56a14684e44fe5ae44ca75eb8a91008f7009b7b1a61eae4","introLinks":[]},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1773514553255} 2026-03-14 19:56:18.003 - info: host.pi-slave instance system.adapter.weatherunderground.0 having pid 19686 terminated with code 0 (NO_ERROR) 2026-03-14 19:56:33.821 - silly: nspanel-lovelace-ui.0 (19669) States system redis pmessage io.messagebox.system.adapter.nspanel-lovelace-ui.0/io.messagebox.system.adapter.nspanel-lovelace-ui.0:{"command":"nsPanelInit","message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"RZwmuFYrCeRKKtr","mqttPassword":"1ZS-aFU0[Z1vM9>m]4ZOv0>(tYbQlk:U*MWeoTUgAJeAQ+H-Z:","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"from":"system.adapter.admin.0","callback":{"message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"RZwmuFYrCeRKKtr","mqttPassword":"1ZS-aFU0[Z1vM9>m]4ZOv0>(tYbQlk:U*MWeoTUgAJeAQ+H-Z:","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"id":743,"ack":false,"time":1773514593829},"_id":60922613} 2026-03-14 19:56:33.840 - debug: nspanel-lovelace-ui.0 (19669) {"command":"nsPanelInit","message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"RZwmuFYrCeRKKtr","mqttPassword":"1ZS-aFU0[Z1vM9>m]4ZOv0>(tYbQlk:U*MWeoTUgAJeAQ+H-Z:","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"from":"system.adapter.admin.0","callback":{"message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"RZwmuFYrCeRKKtr","mqttPassword":"1ZS-aFU0[Z1vM9>m]4ZOv0>(tYbQlk:U*MWeoTUgAJeAQ+H-Z:","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"id":743,"ack":false,"time":1773514593829},"_id":60922613} 2026-03-14 19:56:33.842 - info: nspanel-lovelace-ui.0 (19669) Sending mqtt config & base config to tasmota: 192.168.178.57 with user RZwmuFYrCeRKKtr && *** 2026-03-14 19:56:33.844 - debug: nspanel-lovelace-ui.0 (19669) Requesting tasmota status 5 with url: http://192.168.178.57/cm?&cmnd=status%205 2026-03-14 19:56:34.072 - debug: nspanel-lovelace-ui.0 (19669) Response from tasmota status 5: {"StatusNET":{"Hostname":"PanelAnbau","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"E0:E2:E6:0B:F3:E8","IP6Global":"fd9a:b998:ff69:481f:e2e2:e6ff:fe0b:f3e8","IP6Local":"fe80::e2e2:e6ff:fe0b:f3e8%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16}} 2026-03-14 19:56:34.074 - debug: nspanel-lovelace-ui.0 (19669) Sending mqtt config & base config to tasmota with IP 192.168.178.57 and name PanelAnbau. 2026-03-14 19:56:34.144 - debug: nspanel-lovelace-ui.0 (19669) [mqttClient] Wait for panel connect on: PanelAnbau/tele/INFO1 2026-03-14 19:56:34.146 - debug: nspanel-lovelace-ui.0 (19669) [mqttClient] subscribe to: PanelAnbau/tele/INFO1 2026-03-14 19:57:34.390 - error: nspanel-lovelace-ui.0 (19669) Error in nsPanelInit while sending config to tasmota (192.168.178.57): Error: Timeout for main mqttclient after 60000ms at /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui/src/lib/classes/mqtt.ts:158:28 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2712:17) at listOnTimeout (node:internal/timers:585:17) at processTimers (node:internal/timers:521:7) 2026-03-14 19:57:34.392 - silly: nspanel-lovelace-ui.0 (19669) sendTo "nsPanelInit" to system.adapter.admin.0 from system.adapter.nspanel-lovelace-ui.0 2026-03-14 19:58:12.691 - silly: nspanel-lovelace-ui.0 (19669) States system redis pmessage io.messagebox.system.adapter.nspanel-lovelace-ui.0/io.messagebox.system.adapter.nspanel-lovelace-ui.0:{"command":"getRandomMqttCredentials","message":{"mqttServer":true},"from":"system.adapter.admin.0","callback":{"message":{"mqttServer":true},"id":751,"ack":false,"time":1773514692698},"_id":60922621} 2026-03-14 19:58:12.692 - debug: nspanel-lovelace-ui.0 (19669) {"command":"getRandomMqttCredentials","message":{"mqttServer":true},"from":"system.adapter.admin.0","callback":{"message":{"mqttServer":true},"id":751,"ack":false,"time":1773514692698},"_id":60922621} 2026-03-14 19:58:12.798 - silly: nspanel-lovelace-ui.0 (19669) sendTo "getRandomMqttCredentials" to system.adapter.admin.0 from system.adapter.nspanel-lovelace-ui.0 2026-03-14 19:58:13.959 - silly: nspanel-lovelace-ui.0 (19669) States system redis pmessage io.messagebox.system.adapter.nspanel-lovelace-ui.0/io.messagebox.system.adapter.nspanel-lovelace-ui.0:{"command":"getRandomMqttCredentials","message":{"mqttServer":true},"from":"system.adapter.admin.0","callback":{"message":{"mqttServer":true},"id":752,"ack":false,"time":1773514693966},"_id":60922622} 2026-03-14 19:58:13.960 - debug: nspanel-lovelace-ui.0 (19669) {"command":"getRandomMqttCredentials","message":{"mqttServer":true},"from":"system.adapter.admin.0","callback":{"message":{"mqttServer":true},"id":752,"ack":false,"time":1773514693966},"_id":60922622} 2026-03-14 19:58:14.063 - silly: nspanel-lovelace-ui.0 (19669) sendTo "getRandomMqttCredentials" to system.adapter.admin.0 from system.adapter.nspanel-lovelace-ui.0 2026-03-14 19:58:15.219 - info: host.pi-slave stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=true) 2026-03-14 19:58:15.224 - silly: nspanel-lovelace-ui.0 (19669) States system redis pmessage system.adapter.nspanel-lovelace-ui.0.sigKill/system.adapter.nspanel-lovelace-ui.0.sigKill:{"val":-1,"ack":false,"ts":1773514695221,"q":0,"from":"system.host.pi-slave","lc":1773514695221} 2026-03-14 19:58:15.225 - info: nspanel-lovelace-ui.0 (19669) Got terminate signal TERMINATE_YOURSELF 2026-03-14 19:58:15.252 - info: nspanel-lovelace-ui.0 (19669) [mqttClient] MQTT connection closed. 2026-03-14 19:58:15.256 - info: nspanel-lovelace-ui.0 (19669) terminating 2026-03-14 19:58:15.258 - info: nspanel-lovelace-ui.0 (19669) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-03-14 19:58:15.388 - info: host.pi-slave stopInstance system.adapter.nspanel-lovelace-ui.0 send kill signal 2026-03-14 19:58:15.729 - info: nspanel-lovelace-ui.0 (19669) terminating 2026-03-14 19:58:16.196 - info: host.pi-slave instance system.adapter.nspanel-lovelace-ui.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-03-14 19:58:19.957 - info: host.pi-slave instance system.adapter.nspanel-lovelace-ui.0 in version "0.14.0" started with pid 19723 2026-03-14 19:58:22.426 - debug: nspanel-lovelace-ui.0 (19723) Redis Objects: Use Redis connection: 192.168.178.116:9001 2026-03-14 19:58:22.500 - debug: nspanel-lovelace-ui.0 (19723) Objects client ready ... initialize now 2026-03-14 19:58:22.503 - debug: nspanel-lovelace-ui.0 (19723) Objects create System PubSub Client 2026-03-14 19:58:22.505 - debug: nspanel-lovelace-ui.0 (19723) Objects create User PubSub Client 2026-03-14 19:58:22.614 - debug: nspanel-lovelace-ui.0 (19723) Objects client initialize lua scripts 2026-03-14 19:58:22.632 - debug: nspanel-lovelace-ui.0 (19723) Objects connected to redis: 192.168.178.116:9001 2026-03-14 19:58:22.637 - silly: nspanel-lovelace-ui.0 (19723) redis psubscribe cfg.o.system.user.* 2026-03-14 19:58:22.694 - silly: nspanel-lovelace-ui.0 (19723) redis psubscribe cfg.o.enum.* 2026-03-14 19:58:22.701 - silly: nspanel-lovelace-ui.0 (19723) objectDB connected 2026-03-14 19:58:22.705 - debug: nspanel-lovelace-ui.0 (19723) Redis States: Use Redis connection: 192.168.178.116:9000 2026-03-14 19:58:22.747 - debug: nspanel-lovelace-ui.0 (19723) States create System PubSub Client 2026-03-14 19:58:22.749 - debug: nspanel-lovelace-ui.0 (19723) States create User PubSub Client 2026-03-14 19:58:22.875 - debug: nspanel-lovelace-ui.0 (19723) States connected to redis: 192.168.178.116:9000 2026-03-14 19:58:22.876 - silly: nspanel-lovelace-ui.0 (19723) statesDB connected 2026-03-14 19:58:23.029 - info: nspanel-lovelace-ui.0 (19723) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.1, js-controller: 7.0.7 2026-03-14 19:58:23.072 - silly: nspanel-lovelace-ui.0 (19723) States system redis pmessage system.adapter.nspanel-lovelace-ui.0.logLevel/system.adapter.nspanel-lovelace-ui.0.logLevel:{"val":"silly","ack":true,"ts":1773514703058,"q":0,"from":"system.adapter.nspanel-lovelace-ui.0","lc":1773469148463} 2026-03-14 19:58:23.088 - error: nspanel-lovelace-ui.0 (19723) No compatible config found for topics: . Adapter paused! 2026-03-14 19:58:23.089 - error: nspanel-lovelace-ui.0 (19723) Error in configuration: No compatible config found for topics: . Adapter paused! 2026-03-14 19:58:23.218 - debug: nspanel-lovelace-ui.0 (19723) [library] Load language de 2026-03-14 19:58:23.226 - debug: nspanel-lovelace-ui.0 (19723) [library] Load language de from custom 2026-03-14 19:58:23.231 - info: nspanel-lovelace-ui.0 (19723) [mqttServer] MQTT server started and listening on port 8884 2026-03-14 19:58:24.485 - debug: nspanel-lovelace-ui.0 (19723) [mqttServer] Client "iobroker_307d8bc5-bc96-4775-a765-912ae52f89ea" login successful (user="SJvyHNXzXjiqRWE"). 2026-03-14 19:58:24.532 - debug: nspanel-lovelace-ui.0 (19723) [mqttClient] MQTT connected. 2026-03-14 19:58:50.837 - silly: nspanel-lovelace-ui.0 (19723) States system redis pmessage io.messagebox.system.adapter.nspanel-lovelace-ui.0/io.messagebox.system.adapter.nspanel-lovelace-ui.0:{"command":"nsPanelInit","message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8884,"mqttUsername":"SJvyHNXzXjiqRWE","mqttPassword":"[pVox.nSvRMS5yLI89UGk[+jLx=EKJqUEp>de)(BwEPrQ+Y9JN","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"from":"system.adapter.admin.0","callback":{"message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8884,"mqttUsername":"SJvyHNXzXjiqRWE","mqttPassword":"[pVox.nSvRMS5yLI89UGk[+jLx=EKJqUEp>de)(BwEPrQ+Y9JN","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"id":753,"ack":false,"time":1773514730715},"_id":60922623} 2026-03-14 19:58:50.856 - debug: nspanel-lovelace-ui.0 (19723) {"command":"nsPanelInit","message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8884,"mqttUsername":"SJvyHNXzXjiqRWE","mqttPassword":"[pVox.nSvRMS5yLI89UGk[+jLx=EKJqUEp>de)(BwEPrQ+Y9JN","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"from":"system.adapter.admin.0","callback":{"message":{"tasmotaName":"PanelAnbau","tasmotaIP":"192.168.178.57","tasmotaTopic":"PanelAnbau","mqttServer":true,"mqttIp":"","mqttPort":8884,"mqttUsername":"SJvyHNXzXjiqRWE","mqttPassword":"[pVox.nSvRMS5yLI89UGk[+jLx=EKJqUEp>de)(BwEPrQ+Y9JN","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"id":753,"ack":false,"time":1773514730715},"_id":60922623} 2026-03-14 19:58:50.859 - info: nspanel-lovelace-ui.0 (19723) Sending mqtt config & base config to tasmota: 192.168.178.57 with user SJvyHNXzXjiqRWE && *** 2026-03-14 19:58:50.861 - debug: nspanel-lovelace-ui.0 (19723) Requesting tasmota status 5 with url: http://192.168.178.57/cm?&cmnd=status%205 2026-03-14 19:58:51.072 - debug: nspanel-lovelace-ui.0 (19723) Response from tasmota status 5: {"StatusNET":{"Hostname":"PanelAnbau","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"E0:E2:E6:0B:F3:E8","IP6Global":"fd9a:b998:ff69:481f:e2e2:e6ff:fe0b:f3e8","IP6Local":"fe80::e2e2:e6ff:fe0b:f3e8%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16}} 2026-03-14 19:58:51.073 - debug: nspanel-lovelace-ui.0 (19723) Sending mqtt config & base config to tasmota with IP 192.168.178.57 and name PanelAnbau. 2026-03-14 19:58:51.150 - debug: nspanel-lovelace-ui.0 (19723) [mqttClient] Wait for panel connect on: PanelAnbau/tele/INFO1 2026-03-14 19:58:51.152 - debug: nspanel-lovelace-ui.0 (19723) [mqttClient] subscribe to: PanelAnbau/tele/INFO1 2026-03-14 19:59:51.391 - error: nspanel-lovelace-ui.0 (19723) Error in nsPanelInit while sending config to tasmota (192.168.178.57): Error: Timeout for main mqttclient after 60000ms at /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui/src/lib/classes/mqtt.ts:158:28 at Timeout._onTimeout (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:2712:17) at listOnTimeout (node:internal/timers:585:17) at processTimers (node:internal/timers:521:7) -
Moin,
@ticaki
Moin,ich habe eure Hinweise beherzigt - das Panel konnte hinzugefügt werden. Allerdings erscheint dauerhaft "waiting for content".
Hier ist das Log vom Tasmota:
00:00:00.002 HDW: ESP32-D0WD-V3 v3.0 00:00:00.015 UFS: FlashFS mounted with 288 kB free 00:00:00.022 CFG: Loaded from File, Anzahl 15 00:00:00.030 QPC: Count 1 00:00:00.066 BRY: Berry initialized, RAM used 3493 bytes 00:00:00.076 Projekt tasmota - Tasmota Version 15.0.1(release-tasmota32)-3_1_3(2025.06.14 10:39:16) 00:00:00.919 WIF: verbinden mit AP1 FRITZ!Box 5590 UZ Channel 6 BSSId 48:5D:35:BB:BE:6C in Modus HT40 als Panel-1... 00:00:03.523 WIF: verbunden 00:00:03.729 HTP: Web server active on Panel-1 with IP address 192.168.178.57 00:00:07.056 MQT: Verbindungsversuch… 00:00:07.846 MQT: TLS connected in 789 ms, stack low mark 2252 00:00:07.847 MQT: verbunden 00:00:07.851 MQT: Panel_1/tele/LWT = Online (beibehalten) 00:00:07.853 MQT: Panel_1/cmnd/POWER = 00:00:07.859 MQT: Panel_1/tele/INFO1 = {"Info1":{"Module":"Panel_1","Version":"15.0.1(release-tasmota32)","FallbackTopic":"cmnd/Panel_1-0BF3E8_fb/","GroupTopic":"Panel_1/cmnd/"}} 00:00:07.874 MQT: Panel_1/tele/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"Panel-1","IPAddress":"192.168.178.57","IP6Global":"fd9a:b998:ff69:481f:e2e2:e6ff:fe0b:f3e8","IP6Local":"fe80::e2e2:e6ff:fe0b:f3e8%st1"}} 00:00:07.900 MQT: Panel_1/tele/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":4}} 00:00:07.904 MQT: Panel_1/stat/RESULT = {"POWER1":"ON"} 00:00:07.906 MQT: Panel_1/stat/POWER1 = ON 00:00:07.918 MQT: Panel_1/stat/RESULT = {"POWER2":"ON"} 00:00:07.920 MQT: Panel_1/stat/POWER2 = ON 00:00:07.931 QPC: Reset 19:10:32.065 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:10:32.215 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:10:33.164 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:10:35.272 MQT: Panel_1/tele/STATE = {"Time":"2026-03-15T19:10:35","Uptime":"0T00:00:11","UptimeSec":11,"Heap":152,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":196,"MqttCount":1,"Berry":{"HeapUsed":3,"Objects":38},"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 5590 UZ","BSSId":"48:5D:35:BB:BE:6C","Channel":6,"Mode":"HT40","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:04"}} 19:10:35.315 MQT: Panel_1/tele/SENSOR = {"Time":"2026-03-15T19:10:35","ANALOG":{"Temperature1":21.2},"TempUnit":"C"} 19:10:36.136 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:10:41.187 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:10:48.148 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:10:57.149 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:11:00.033 MQT: Panel_1/stat/STATUS0 = {"Status":{"Module":0,"DeviceName":"Tasmota","FriendlyName":["Panel_1","Tasmota2"],"Topic":"tasmota_0BF3E8","ButtonTopic":"0","Power":"11","PowerLock":"00","PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":0,"InfoRetain":0,"StateRetain":0,"StatusRetain":0},"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://ota.tasmota.com/tasmota32/release/tasmota32-DE.bin","RestartReason":"Software reset CPU","Uptime":"0T00:00:35","StartupUTC":"2026-03-15T18:10:24","Sleep":50,"CfgHolder":4617,"BootCount":4,"BCResetTime":"2026-03-15T19:02:32","SaveCount":16},"StatusFWR":{"Version":"15.0.1(release-tasmota32)","BuildDateTime":"2025.06.14 10:39:16","Core":"3_1_3","SDK":"5.3.3.250501","CpuFrequency":160,"Hardware":"ESP32-D0WD-V3 v3.0","CR":"517/699"},"StatusLOG":{"SerialLog":2,"WebLog":2,"MqttLog":0,"FileLog":0,"SysLog":0,"LogHost":"","LogPort":514,"SSId":["FRITZ!Box 5590 UZ",""],"TelePeriod":300,"Resolution":"558180C0","SetOption":["00008009","2805C80001000600003C5A0A192800000000","00000080","20206000","00044000","00000000"]},"StatusMEM":{"ProgramSize":2045,"Free":834,"Heap":147,"StackLowMark":2,"PsrMax":0,"PsrFree":0,"ProgramFlashSize":4096,"FlashSize":4096,"FlashChipId":"16405E","FlashFrequency":40,"FlashMode":"DIO","Features":["0407","9F9AD7DF","0015A001","B7F7BFCF","05DA9BC4","E0360DC7","480840D2","20200000","D4BC482D","810A80F1","00000814"],"Drivers":"1,2,!3,!4,!5,7,!8,9,10,11,12,!14,!16,!17,!20,!21,24,26,!27,29,!34,!35,38,50,52,!59,!60,62,!63,!66,!67,!68,!73,!75,82,!86,!87,!88,!91,!121","Sensors":"1,2,3,5,6,7,8,9,10,11,12,13,14,15,17,18,19,20,21,22,26,31,34,37,39,40,42,43,45,51,52,55,56,58,59,64,66,67,74,85,92,95,98,103,105,109,127","I2CDriver":"7,8,9,10,11,12,13,14,15,17,18,20,24,29,31,36,41,42,44,46,48,58,62,65,69,76,77,82,89"},"StatusNET":{"Hostname":"Panel-1","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"E0:E2:E6:0B:F3:E8","IP6Global":"fd9a:b998:ff69:481f:e2e2:e6ff:fe0b:f3e8","IP6Local":"fe80::e2e2:e6ff:fe0b:f3e8%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16.0},"StatusMQT":{"MqttHost":"192.168.178.2","MqttPort":8883,"MqttClientMask":"Panel_1-0BF3E8","MqttClient":"Panel_1-0BF3E8","MqttUser":"WNsOXNbpSLDZjgX","MqttCount":1,"MqttTLS":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30,"SOCKET_TIMEOUT":4},"StatusTIM":{"UTC":"2026-03-15T18:11:00Z","Local":"2026-03-15T19:11:00","StartDST":"2026-03-29T02:00:00","EndDST":"2026-10-25T03:00:00","Timezone":"+01:00","Sunrise":"07:03","Sunset":"18:54"},"StatusSNS":{"Time":"2026-03-15T19:11:00","ANALOG":{"Temperature1":21.3},"TempUnit":"C"},"StatusSTS":{"Time":"2026-03-15T19:11:00","Uptime":"0T00:00:36","UptimeSec":36,"Heap":146,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"Berry":{"HeapUsed":3,"Objects":38},"POWER1":"ON","POWER2":"ON","Wifi":{"AP":1,"SSId":"FRITZ!Box 5590 UZ","BSSId":"48:5D:35:BB:BE:6C","Channel":6,"Mode":"HT40","RSSI":64,"Signal":-68,"LinkCount":1,"Downtime":"0T00:00:04"}}} 19:11:08.110 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:11:14.759 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:11:18.959 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:11:21.910 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:11:26.960 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:11:33.909 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:11:42.911 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:11:53.962 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:12:06.963 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:12:21.914 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:12:39.024 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"} 19:12:57.977 MQT: Panel_1/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND pageType~pageStartup"}Und hier der entsprechende Auszug vom Adapter:
2026-03-15 19:10:13.499 - info: host.pi-slave stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=true) 2026-03-15 19:10:13.503 - info: nspanel-lovelace-ui.0 (34302) Got terminate signal TERMINATE_YOURSELF 2026-03-15 19:10:13.674 - info: host.pi-slave stopInstance system.adapter.nspanel-lovelace-ui.0 send kill signal 2026-03-15 19:10:13.682 - info: nspanel-lovelace-ui.0 (34302) [Panel_1] Goint offline because delete panel! 2026-03-15 19:10:13.791 - info: nspanel-lovelace-ui.0 (34302) [mqttClient] MQTT connection closed. 2026-03-15 19:10:13.794 - info: nspanel-lovelace-ui.0 (34302) terminating 2026-03-15 19:10:13.796 - info: nspanel-lovelace-ui.0 (34302) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-03-15 19:10:14.005 - info: nspanel-lovelace-ui.0 (34302) terminating 2026-03-15 19:10:14.572 - info: host.pi-slave instance system.adapter.nspanel-lovelace-ui.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-03-15 19:10:18.135 - info: host.pi-slave instance system.adapter.nspanel-lovelace-ui.0 in version "0.14.0" started with pid 34321 2026-03-15 19:10:21.480 - info: nspanel-lovelace-ui.0 (34321) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.1, js-controller: 7.0.7 2026-03-15 19:10:21.548 - info: nspanel-lovelace-ui.0 (34321) Configured panels: name#topic -> [Panel_1#Panel_1] 2026-03-15 19:10:21.549 - info: nspanel-lovelace-ui.0 (34321) Found 1 script configs for topics: Panel_1 2026-03-15 19:10:21.550 - info: nspanel-lovelace-ui.0 (34321) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter. 2026-03-15 19:10:21.790 - info: nspanel-lovelace-ui.0 (34321) [mqttServer] MQTT server started and listening on port 8883 2026-03-15 19:10:23.662 - info: nspanel-lovelace-ui.0 (34321) [Panel_1] Setting panel to offline until first message! 2026-03-15 19:10:29.217 - info: nspanel-lovelace-ui.0 (34321) [controller] 1 Panels initialized 2026-03-15 19:10:48.051 - info: host.pi-slave instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 34337 2026-03-15 19:11:11.016 - info: host.pi-slave instance system.adapter.weatherunderground.0 having pid 34337 terminated with code 0 (NO_ERROR) 2026-03-15 19:11:14.855 - info: nspanel-lovelace-ui.0 (34321) [Panel_1] Goint offline because delete panel! 2026-03-15 19:11:14.957 - info: nspanel-lovelace-ui.0 (34321) [controller] Panel Panel_1 deleted 2026-03-15 19:11:16.026 - info: nspanel-lovelace-ui.0 (34321) [Panel_1] Setting panel to offline until first message! 2026-03-15 19:11:18.797 - info: nspanel-lovelace-ui.0 (34321) ✅ Panel "E0_E2_E6_0B_F3_E8" reloaded with updated configuration.Und hier mein Skript (nur der zu editierende Bereich; geändert habe ich lediglich die Tasten und Screensaver Einstellungen):
async function configuration (): Promise<void> { const overrideConfig: Partial<ScriptConfig.Config> = { // hier kann man die Werte von unten überschreiben bzw nicht ewig im Skript suchen wo nochmal die Farbe steht :) // pages und subpages geht hier nicht, weil die Seiten ja erst später angelegt werden. Bei const gehts nach Reihenfolge. // panelTopic: 'nspanel/ns_panel4', weatherEntity: 'pirate-weather.0.', defaultOffColor: Off, defaultOnColor: On, // weatherAddDefaultItems: // - true => alle Standard-Wetterelemente hinzufügen // - false => keine hinzufügen // - { ... } => selektiv per Schlüssel aktivieren: // sunriseSet, forecastDay1, forecastDay2, forecastDay3, forecastDay4, forecastDay5, forecastDay6, // windSpeed, windGust, windDirection, uvIndex, solar // Hinweis: Die einzelnen Schlüssel funktionieren nur, wenn der gewählte Wetteranbieter // die entsprechenden Daten liefert und diese im Adapter vorbereitet wurden "weatherAddDefaultItems": false } /************************************************************************************** ** ** ** https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/wiki/Adapter-Installation ** ** ** *************************************************************************************/ /*********************************************************************** ** ** ** Page Configuration ** ** ** ***********************************************************************/ // Beispiel Hauptseite / Mainpage // Diese Seite ist die Hauptseite, sie wird immer als erstes angezeigt und hat den uniqueName 'main'. // uniqueName 'main' muß mindestens einmal vorkommen, damit die Navigation funktioniert. const Hauptseite: ScriptConfig.PageGrid = { type: 'cardGrid', uniqueName: 'main', heading: 'Die Leere', items: [] }; // Diese Konfiguration für den Fahrplan ist ein Beispiel was die interne Adapterkonfiguration benutzt, diese // ist recht komplex und wird nicht weiter erläutert. Da gibts später fertige Templates die man hier verwenden kann. // wie am Fahrplan Beispiel zu sehen ist. /* const fahrplan: any = { heading: 'Fahrplan Script', native: { card: 'cardEntities', dpInit: 'fahrplan.0.0', uniqueID: 'fahrplanrouten', template: 'entities.fahrplan.routes', } }; */ // Konfiguration findet im Admin statt, uniqueName muß gleich dem namen in der Adminkonfiguration sein. /* const qrCode: ScriptConfig.PageQR = { type: 'cardQR', uniqueName: 'qrCode' }; */ // Konfiguration findet im Admin statt, uniqueName muß gleich dem namen in der Adminkonfiguration sein. /* const chartHeizung: ScriptConfig.PageChart = { type: 'cardChart', uniqueName: 'temperatur' }; */ // Ein Beispiel für eine Gridseite mit verschiedenen Farbskalen /* const irgendeinName: ScriptConfig.PageGrid = { type: 'cardGrid', uniqueName: 'main', heading: 'Wohnzimmer', items: [ {id: 'alias.0.Temperatur', name: 'standard', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40}}, {id: 'alias.0.Temperatur', name: 'hue', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'hue'}}, {id: 'alias.0.Temperatur', name: 'cie', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'cie'}}, {id: 'alias.0.Temperatur', name: 'standard log min', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, log10: 'min'}}, {id: 'alias.0.Temperatur', name: 'hue log min', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'hue', log10: 'min'}}, {id: 'alias.0.Temperatur', name: 'cie log min', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'cie', log10: 'min'}}, {id: 'alias.0.Temperatur', name: 'standard', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40}}, {id: 'alias.0.Temperatur', name: 'hue', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'hue'}}, {id: 'alias.0.Temperatur', name: 'cie', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'cie'}}, {id: 'alias.0.Temperatur', name: 'standard log max', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, log10: 'max'}}, {id: 'alias.0.Temperatur', name: 'hue log max', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'hue', log10: 'max'}}, {id: 'alias.0.Temperatur', name: 'cie log max', onColor: Red, offColor: Blue, colorScale: {'val_min': 0, 'val_max': 40, mode: 'cie', log10: 'max'}}, ] }; */ /* const grid1: ScriptConfig.PageGrid = { uniqueName: 'grid1', // keine Navigation, am besten uniqueName von config.ts übernehmen heading: 'Grid 1', items: [ {id: 'alias.0.Licht.lights.Gerät_1'}, {id: 'alias.0.Licht.lights.Gerät_2'}, {id: '0_userdata.0.Einzelne_Geräte.dimmer'}, {id: 'alias.0.NSPanel.allgemein.hue', }, {navigate: true, targetPage: 'fahrplanrouten'}, {id: 'alias.0.NSPanel.allgemein.shutter'} ], type: 'cardGrid', } */ const config: ScriptConfig.Config = { panelTopic: 'Panel_1', weatherEntity: 'pirate-weather.0.', defaultOffColor: Off, defaultOnColor: On, defaultBackgroundColor: HMIDark, weatherAddDefaultItems: false, // Als Gedankenstütze, die Hauptseite muß main heißen! //panelName: 'NSPanel', //unique name for the panel // Seiteneinteilung / Page division // Hauptseiten / Mainpages pages: [ Hauptseite //irgendeinName, //grid1, //qrCode, //chartHeizung, ], // Unterseiten / Subpages subPages: [ //fahrplan ], /*********************************************************************** ** ** ** Screensaver Configuration ** ** ** ***********************************************************************/ favoritScreensaverEntity: [ { type: 'script', ScreensaverEntity: '0_userdata.0.Solar.Energiefluss.NSPanel.Verbrauch_kW', ScreensaverEntityFactor: -1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'power-plug-outline', ScreensaverEntityText: 'Verbrauch', ScreensaverEntityUnitText: ' kW', ScreensaverEntityOffColor: White, ScreensaverEntityOnColor: White, }, ], alternateScreensaverEntity: [ // only used with alternate Screensaver ], indicatorScreensaverEntity: [ // indicatorScreensaverEntity 1 (only Advanced Screensaver) { type: 'script', ScreensaverEntityText: '', ScreensaverEntity: null, ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '', /*ON*/ ScreensaverEntityIconOn: null, ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: null, ScreensaverEntityOffColor: White }, // indicatorScreensaverEntity 2 (only Advanced Screensaver) { type: 'script', ScreensaverEntityText: '', ScreensaverEntity: null, ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '', /*ON*/ ScreensaverEntityIconOn: null, ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: null, ScreensaverEntityOffColor: White }, // indicatorScreensaverEntity 3 (only Advanced Screensaver) { type: 'script', ScreensaverEntityText: '', ScreensaverEntity: '', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '', /*ON*/ ScreensaverEntityIconOn: null, ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: null, ScreensaverEntityOffColor: White }, // indicatorScreensaverEntity 4 (only Advanced Screensaver) { type: 'script', ScreensaverEntityText: 'Fenster', ScreensaverEntity: '0_userdata.0.Alarm.Elemente.Alarm-Element-Anzahl-boolean', /*ON*/ ScreensaverEntityIconOn: 'door-open', ScreensaverEntityOnColor: MSRed, /*OFF*/ ScreensaverEntityIconOff: 'door-closed', ScreensaverEntityOffColor: White }, // indicatorScreensaverEntity 5 (only Advanced Screensaver) { type: 'script', ScreensaverEntityText: 'Alarmanlage', ScreensaverEntity: '0_userdata.0.Elemente.Status-Alarmanlage', /*ON*/ ScreensaverEntityIconOn: 'shield-lock', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'shield-lock-open-outline', ScreensaverEntityOffColor: White }, ], bottomScreensaverEntity: [ // bottomScreensaverEntity 1 { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="0false"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-10', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-10', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="0true"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-charging-10', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-charging-10', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="25false"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-30', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-30', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="25true"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-charging-30', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-charging-30', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="50false"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-50', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-50', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="50true"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-charging-50', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-charging-50', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="75false"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-70', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-70', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="75true"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-charging-70', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-charging-70', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="100false"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery', ScreensaverEntityOffColor: White }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Bild-Batterie'; ScreensaverEntityVisibleCondition: 'val==="100true"'; ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Solar.Solplanet.soc-Batteriekapazitaet_Prozent', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: '%', /*ON*/ ScreensaverEntityIconOn: 'battery-charging-100', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'battery-charging-100', ScreensaverEntityOffColor: White }, // bottomScreensaverEntity 2 { type: 'script', ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Wasser.Werte.Tagesverbrauch-in-Litern', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityUnitText: ' L', /*ON*/ ScreensaverEntityIconOn: 'water', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'water', ScreensaverEntityOffColor: White }, // bottomScreensaverEntity 3 { type: 'script', ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Abfuhrkalender.NSPanel.1.Datum', ScreensaverEntityUnitText: '', /*ON*/ ScreensaverEntityIconOn: 'delete', //@ts-ignore ScreensaverEntityOnColor: '0_userdata.0.Abfuhrkalender.NSPanel.1.Farbe', /*OFF*/ ScreensaverEntityIconOff: 'delete', //@ts-ignore ScreensaverEntityOffColor: '0_userdata.0.Abfuhrkalender.NSPanel.1.Farbe' }, // bottomScreensaverEntity 4 { type: 'script', ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Abfuhrkalender.NSPanel.2.Datum', ScreensaverEntityUnitText: '', /*ON*/ ScreensaverEntityIconOn: 'delete', //@ts-ignore ScreensaverEntityOnColor: '0_userdata.0.Abfuhrkalender.NSPanel.2.Farbe', /*OFF*/ ScreensaverEntityIconOff: 'delete', //@ts-ignore ScreensaverEntityOffColor: '0_userdata.0.Abfuhrkalender.NSPanel.2.Farbe' }, // bottomScreensaverEntity 5 (Advanced Screensaver) { type: 'script', ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Abfuhrkalender.NSPanel.3.Datum', ScreensaverEntityUnitText: '', /*ON*/ ScreensaverEntityIconOn: 'delete', //@ts-ignore ScreensaverEntityOnColor: '0_userdata.0.Abfuhrkalender.NSPanel.3.Farbe', /*OFF*/ ScreensaverEntityIconOff: 'delete', //@ts-ignore ScreensaverEntityOffColor: '0_userdata.0.Abfuhrkalender.NSPanel.3.Farbe' }, // bottomScreensaverEntity 6 (for Advanced Screensaver) { type: 'script', ScreensaverEntityText: '', ScreensaverEntity: '0_userdata.0.Abfuhrkalender.NSPanel.4.Datum', ScreensaverEntityUnitText: '', /*ON*/ ScreensaverEntityIconOn: 'delete', //@ts-ignore ScreensaverEntityOnColor: '0_userdata.0.Abfuhrkalender.NSPanel.4.Farbe', /*OFF*/ ScreensaverEntityIconOff: 'delete', //@ts-ignore ScreensaverEntityOffColor: '0_userdata.0.Abfuhrkalender.NSPanel.4.Farbe' }, ], leftScreensaverEntity: [ // leftScreensaverEntity 1 (only Advanced Screensaver) { type: 'script', // ScreensaverEntityEnabled: '0_userdata.0.Solar.Leistung'; // ScreensaverEntityVisibleCondition: 'val!==0'; ScreensaverEntity: '0_userdata.0.Solar.Leistung', ScreensaverEntityText: 'Solarproduktion', ScreensaverEntityUnitText: ' kW', ScreensaverEntityFactor: 0.001, ScreensaverEntityDecimalPlaces: 1, /*ON*/ ScreensaverEntityIconOn: 'white-balance-sunny', ScreensaverEntityOnColor: White, /*OFF*/ ScreensaverEntityIconOff: 'white-balance-sunny', ScreensaverEntityOffColor: White }, // leftScreensaverEntity 2 (only Advanced Screensaver) { type: 'script', // ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Zaehlerveraenderung_kW'; // ScreensaverEntityVisibleCondition: 'val!==0'; ScreensaverEntity: '0_userdata.0.Solar.Energiefluss.NSPanel.Zaehlerveraenderung_kW', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'transmission-tower', ScreensaverEntityText: 'Netz', ScreensaverEntityUnitText: ' kW', ScreensaverEntityOffColor: White, ScreensaverEntityOnColor: White, }, // leftScreensaverEntity 3 (only Advanced Screensaver) { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Batterieveraenderung_kW'; ScreensaverEntityVisibleCondition: 'val>0'; ScreensaverEntity: '0_userdata.0.Solar.Energiefluss.NSPanel.Batterieveraenderung_kW', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'battery-minus-outline', ScreensaverEntityText: 'Netz', ScreensaverEntityUnitText: ' kW', ScreensaverEntityOffColor: White, ScreensaverEntityOnColor: White, }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Batterieveraenderung_kW'; ScreensaverEntityVisibleCondition: 'val<0'; ScreensaverEntity: '0_userdata.0.Solar.Energiefluss.NSPanel.Batterieveraenderung_kW', ScreensaverEntityFactor: -1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'battery-plus-outline', ScreensaverEntityText: 'Netz', ScreensaverEntityUnitText: ' kW', ScreensaverEntityOffColor: White, ScreensaverEntityOnColor: White, }, { type: 'script', ScreensaverEntityEnabled: '0_userdata.0.Solar.Energiefluss.NSPanel.Batterieveraenderung_kW'; ScreensaverEntityVisibleCondition: 'val==0'; ScreensaverEntity: '0_userdata.0.Solar.Energiefluss.NSPanel.Batterieveraenderung_kW', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'battery-outline', ScreensaverEntityText: 'Netz', ScreensaverEntityUnitText: ' kW', ScreensaverEntityOffColor: White, ScreensaverEntityOnColor: White, }, ], // Status Icon mrIcon1ScreensaverEntity: { type: 'script', ScreensaverEntity: 'Relay.1', ScreensaverEntityIconOn: 'lightbulb', ScreensaverEntityIconOff: null, ScreensaverEntityValue: null, ScreensaverEntityValueDecimalPlace: 0, ScreensaverEntityValueUnit: null, ScreensaverEntityOnColor: HMIDark, ScreensaverEntityOffColor: HMIDark }, mrIcon2ScreensaverEntity: { type: 'script', ScreensaverEntity: 'Relay.2', ScreensaverEntityIconOn: null, ScreensaverEntityIconOff: null, ScreensaverEntityValue: null, ScreensaverEntityValueDecimalPlace: 0, ScreensaverEntityValueUnit: null, ScreensaverEntityOnColor: HMIDark, ScreensaverEntityOffColor: HMIDark }, // ------ DE: Ende der Screensaver Einstellungen -------------------- // ------ EN: End of screensaver settings --------------------------- // DE: Konfiguration des linken Schalters des NSPanels // EN: Configuration of the left switch of the NSPanel buttonLeft: { mode: 'page', page: 'main', }, // DE: Konfiguration des rechten Schalters des NSPanels // EN: Configuration of the right switch of the NSPanel buttonRight: { mode: 'button', state: '0_userdata.0.Alarm.Alarm-Zeitschaltung-vorzeitig' // Datenpunkt vom Type boolean z.B. ein Schalter }, };...ich habe Hoffnung, dass euch etwas auffällt :-)
Über eine Rückmeldung würde ich mich sehr freuen! -
@muuulle
ich brauche eine längeres Adapter log - aktuell sieht es aus als wenn das Panel initialisiert wird, dann wird ein Skript hingeschickt und das log endet mit der sende bestätigung -
Mehr Log nach dem ✅ wenn da aber nix mehr kommt den Adapter als Debug startet und das als log.txt hier hochladen. sollte ne ganze Menge an log sein.
@muuulle
falls ich mich missverständlich ausgedrückt habe - expert an - log level für den adapter auf debug und dann 1 Minuten warten stoppen, log downloaden und alles ab den start hier hochladen / posten. -
ich bin fest der Überzeugung das dein Berry Treiber fehlt. Mein Tasmota Start sieht so aus.
00:00:00.019 QPC: Count 1 00:00:00.050 BRY: Berry initialized, RAM used 3480 bytes 00:00:00.065 Project tasmota - Tasmota Version 15.0.1.1(tasmota32)-3_1_3(2026-03-01T19:11:45) 00:00:00.159 NXP: Initializing Driver 00:00:00.163 BRY: Successfully loaded 'autoexec.be' 00:00:01.001 WIF: Connecting to AP1 TomTom24 Channel 1 BSSId 2C:91:AB:AF:46:A7 in mode HT40 as Buero... 00:00:02.859 NXP: Screen Initialized 00:00:03.656 WIF: Connected 00:00:03.912 HTP: Web server active on Buero with IP address 192.168.178.101 09:31:55.809 MQT: Attempting connection... 09:31:55.834 MQT: ConnectedDa steht auch das die autoexec.be geladen wurde. Das fehlt bei dir.
Es gibt jetzt zwei Wege das Ganze noch einmal zu beheben. Du gehst in die NSPanel-Einstellungen und klickst auf den Bleistift in der Kachel von dem Panel
Dann den großen Button darüber an klicken und warten. Das Panel wird jetzt komplett neu initialisiert. Warte bis die TFT-Firmware fertig ist. Dann Speichern und der Adapter startet neu durch.Oder der zweite Weg ist, den Experten-Modus aktiveren, dann erscheint ein Tab "Tasmotatools" da wählst du dein Panel aus und klickst dann auf "Berry Treiber installieren" .
0.15.0 (2026-03-16)
- (ticaki) added:
ScreensaverEntityFillIfBelowMin– fills screensaver slots when too few items are visible (default: true) - (ticaki) fixed: various bug fixes and improvements in the admin UI
Änderung in kurzen Worten:
Wenn man ScreensaverEntityEnabled benutzt, wird jetzt im Default das Element trotz false angzeigt wenn sonst zu wenige Elemente da wären um alle Plätze zu füllen. Habs noch nicht mit Rotation getestet. Wer das nicht will setztScreensaverEntityFillIfBelowMin: false, dann ist es wie vorher.Das Andere sind Textanpassungen, fehlende Texte und das man im AdminTab den Screensaver ändern konnte, das aber nix geändert hat :) Und die Temperatur wird jetzt immer geschrieben und die Option ist aus dem Admin verschwunden - sind 4 Datenpunkte im Default alle 5 Minuten wem das zuviel ist, kann ja teleperiod auf was höheres setzen.
- (ticaki) added:
Moin,
die Knöpfe in der kleinen Kachel werden mir nicht dargestellt:
Nach einiger Zeit nach einem Adapter Neustart, springt es um auf Fehler.
Über Tasmotatools ist eine Installation der Berrytreiber anzustoßen. Das wird in den Logs auch quittiert, aber weder in der Konsole des Tasmotas noch im ioBroker Log ist nichts weiter dokumentiert.
Allerdings steht von den Berrytreibern auch etwas im Tasmota:
Was war das mit der autoexec.bat? Früher musste die noch händisch angelegt werden, das übernimmt jetzt aber der Adapter, oder?
Hier ist noch ein längerer Auszug vom Log:
2026-03-16 19:28:59.491 - info: nspanel-lovelace-ui.0 (41307) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.1, js-controller: 7.0.7 2026-03-16 19:28:59.556 - info: nspanel-lovelace-ui.0 (41307) Configured panels: name#topic -> [Panel_1#Panel_1] 2026-03-16 19:28:59.558 - info: nspanel-lovelace-ui.0 (41307) Found 1 script configs for topics: Panel_1 2026-03-16 19:28:59.558 - info: nspanel-lovelace-ui.0 (41307) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter. 2026-03-16 19:28:59.563 - debug: nspanel-lovelace-ui.0 (41307) [config-manager] Start converting configuration for Panel_1 2026-03-16 19:28:59.654 - debug: nspanel-lovelace-ui.0 (41307) [config-manager] Screensaver pageItems count: 28 2026-03-16 19:28:59.663 - debug: nspanel-lovelace-ui.0 (41307) Config for Panel_1: raw 2026-03-16 19:28:59.800 - debug: nspanel-lovelace-ui.0 (41307) [library] Load language de 2026-03-16 19:28:59.809 - debug: nspanel-lovelace-ui.0 (41307) [library] Load language de from custom 2026-03-16 19:28:59.814 - info: nspanel-lovelace-ui.0 (41307) [mqttServer] MQTT server started and listening on port 8883 2026-03-16 19:29:00.981 - debug: nspanel-lovelace-ui.0 (41307) Force an MQTT reconnect from the Nspanel with the ip 192.168.178.57 in 10 seconds! 2026-03-16 19:29:02.216 - debug: nspanel-lovelace-ui.0 (41307) [mqttServer] Client "iobroker_aee70dad-8873-4fd2-bc38-d59228e12e41" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-16 19:29:02.264 - debug: nspanel-lovelace-ui.0 (41307) [mqttClient] MQTT connected. 2026-03-16 19:29:02.365 - debug: nspanel-lovelace-ui.0 (41307) Check configuration! 2026-03-16 19:29:02.371 - debug: nspanel-lovelace-ui.0 (41307) 44459.515625k 2026-03-16 19:29:02.379 - debug: nspanel-lovelace-ui.0 (41307) [controller] controller created 2026-03-16 19:29:02.583 - debug: nspanel-lovelace-ui.0 (41307) [mqttClient] subscribe to: Panel_1/stat/RESULT 2026-03-16 19:29:02.599 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1] Panel E0_E2_E6_0B_F3_E8 is initialised! 2026-03-16 19:29:02.600 - debug: nspanel-lovelace-ui.0 (41307) [mqttClient] subscribe to: Panel_1/tele/# 2026-03-16 19:29:02.629 - debug: nspanel-lovelace-ui.0 (41307) [mqttClient] subscribe to: Panel_1/stat/# 2026-03-16 19:29:02.644 - info: nspanel-lovelace-ui.0 (41307) [Panel_1] Setting panel to offline until first message! 2026-03-16 19:29:02.664 - debug: nspanel-lovelace-ui.0 (41307) [system-notifications] Request notifications from "system.host.iobroker-iobroker" 2026-03-16 19:29:02.679 - debug: nspanel-lovelace-ui.0 (41307) [system-notifications] Received notifications from "system.host.iobroker-iobroker": {} 2026-03-16 19:29:02.680 - debug: nspanel-lovelace-ui.0 (41307) [system-notifications] Request notifications from "system.host.pi-slave" 2026-03-16 19:29:02.684 - debug: nspanel-lovelace-ui.0 (41307) [system-notifications] Received notifications from "system.host.pi-slave": {} 2026-03-16 19:29:03.223 - debug: nspanel-lovelace-ui.0 (41307) [mqttServer] Client iobroker_aee70dad-8873-4fd2-bc38-d59228e12e41 connected. 2026-03-16 19:29:06.832 - debug: nspanel-lovelace-ui.0 (41307) [controller] Panel E0_E2_E6_0B_F3_E8 created 2026-03-16 19:29:07.074 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:29:08.237 - debug: nspanel-lovelace-ui.0 (41307) [controller] No pageConfig available, skipping trash data update. 2026-03-16 19:29:08.238 - info: nspanel-lovelace-ui.0 (41307) [controller] 1 Panels initialized 2026-03-16 19:29:10.074 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:29:11.128 - debug: nspanel-lovelace-ui.0 (41307) [mqttServer] Client "Panel_1-0BF3E8" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-16 19:29:11.396 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:29:12.132 - debug: nspanel-lovelace-ui.0 (41307) [mqttServer] Client Panel_1-0BF3E8 connected. 2026-03-16 19:29:12.332 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:29:15.332 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:29:20.333 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:29:27.333 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:29:36.333 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:29:47.335 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:30:01.262 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:30:06.401 - debug: nspanel-lovelace-ui.0 (41307) {"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.2"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.2"},"id":1053,"ack":false,"time":1773685806445},"_id":60922930} 2026-03-16 19:30:11.474 - debug: nspanel-lovelace-ui.0 (41307) {"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.2"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.2"},"id":1054,"ack":false,"time":1773685811533},"_id":60922931} 2026-03-16 19:30:16.271 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:30:33.283 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:30:48.045 - info: host.pi-slave instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 41326 2026-03-16 19:30:52.292 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:31:00.010 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/STATUS0","payload":""} to panel. 2026-03-16 19:31:11.537 - info: host.pi-slave instance system.adapter.weatherunderground.0 having pid 41326 terminated with code 0 (NO_ERROR) 2026-03-16 19:31:13.301 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:31:36.311 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:31:38.663 - debug: nspanel-lovelace-ui.0 (41307) {"command":"getTasmotaDevices","message":{"ip":"192.168.178.2"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.2"},"id":1056,"ack":false,"time":1773685898723},"_id":60922933} 2026-03-16 19:31:43.195 - debug: nspanel-lovelace-ui.0 (41307) {"command":"berryInstallSendTo","message":{"tasmotaIP":"192.168.178.57"},"from":"system.adapter.admin.0","callback":{"message":{"tasmotaIP":"192.168.178.57"},"id":1057,"ack":false,"time":1773685903255},"_id":60922934} 2026-03-16 19:31:43.275 - info: nspanel-lovelace-ui.0 (41307) Installing berry on tasmota with IP 192.168.178.57 2026-03-16 19:31:54.125 - debug: nspanel-lovelace-ui.0 (41307) [mqttServer] Client "Panel_1-0BF3E8" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-16 19:31:54.385 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:31:55.128 - debug: nspanel-lovelace-ui.0 (41307) [mqttServer] Client Panel_1-0BF3E8 connected. 2026-03-16 19:31:55.330 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:31:58.330 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:32:03.331 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:32:10.331 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:32:19.332 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:32:30.332 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:32:43.340 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:32:58.351 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:33:15.360 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:33:34.369 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:33:55.378 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:34:18.387 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:34:43.397 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:35:10.771 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-16 19:35:39.779 - debug: nspanel-lovelace-ui.0 (41307) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel.Vielen tausend Dank für die Unterstützung!
Danke, ist kein Problem mit dem Adapter. Schätze mal wie TT-Tom ist das Berry Skript und du warst auf dem falschen Tab unterwegs
Da auf den Stift klicken, dann wird oben alles ausgefüllt und anschließend auf nspanel-aktualisieren klicken. (der name ändert sich)
Tasmotatools hab ich schon länger nicht mehr getestet btw. angepasst - vielleicht funktioniert da der berry teil nicht korrekt.
Moin,
Kann aber sein das der "leere" Datei bugfix da nicht drin ist. Aber einen Blick ins Dateisystem des NSPanels sollte das klären.
@muuulle sagte in Betatest Adapter NSPanel-lovelace-ui v0.13.x:
Kann ich die Daten händisch anlegen?
Ja könnte man, ist aber nicht die Lösung. Bitte versuche den Schritt über die NSPanel Einstellungen, da sollte dein Panel zu sehen sein. Schau dir das Bild von @ticaki Beitrag an, damit du im richtigen Tab bist. https://forum.iobroker.net/post/1330165. Lass den Adapter auf Debug stehen und schicke uns das Log, damit wir den Fehler finden können zu deinem Problem.
@TT-Tom
Hallo TT-Tom,vielen Dank für den Hinweis, ich war wirklich im falschen Tab. Eine autoexec wird weiterhin nicht im Tasmota angezeigt. Hier der zugehörige Log vom ioBroker:
2026-03-17 20:02:46.202 - info: host.pi-slave "system.adapter.nspanel-lovelace-ui.0" enabled 2026-03-17 20:02:46.959 - info: host.pi-slave instance system.adapter.nspanel-lovelace-ui.0 in version "0.14.0" started with pid 55160 2026-03-17 20:02:49.468 - debug: nspanel-lovelace-ui.0 (55160) Redis Objects: Use Redis connection: 192.168.178.116:9001 2026-03-17 20:02:49.541 - debug: nspanel-lovelace-ui.0 (55160) Objects client ready ... initialize now 2026-03-17 20:02:49.544 - debug: nspanel-lovelace-ui.0 (55160) Objects create System PubSub Client 2026-03-17 20:02:49.547 - debug: nspanel-lovelace-ui.0 (55160) Objects create User PubSub Client 2026-03-17 20:02:49.662 - debug: nspanel-lovelace-ui.0 (55160) Objects client initialize lua scripts 2026-03-17 20:02:49.671 - debug: nspanel-lovelace-ui.0 (55160) Objects connected to redis: 192.168.178.116:9001 2026-03-17 20:02:49.747 - debug: nspanel-lovelace-ui.0 (55160) Redis States: Use Redis connection: 192.168.178.116:9000 2026-03-17 20:02:49.793 - debug: nspanel-lovelace-ui.0 (55160) States create System PubSub Client 2026-03-17 20:02:49.795 - debug: nspanel-lovelace-ui.0 (55160) States create User PubSub Client 2026-03-17 20:02:49.920 - debug: nspanel-lovelace-ui.0 (55160) States connected to redis: 192.168.178.116:9000 2026-03-17 20:02:50.853 - info: nspanel-lovelace-ui.0 (55160) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.1, js-controller: 7.0.7 2026-03-17 20:02:50.916 - info: nspanel-lovelace-ui.0 (55160) Configured panels: name#topic -> [Panel_1#Panel_1] 2026-03-17 20:02:50.917 - info: nspanel-lovelace-ui.0 (55160) Found 1 script configs for topics: Panel_1 2026-03-17 20:02:50.918 - info: nspanel-lovelace-ui.0 (55160) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter. 2026-03-17 20:02:50.923 - debug: nspanel-lovelace-ui.0 (55160) [config-manager] Start converting configuration for Panel_1 2026-03-17 20:02:51.018 - debug: nspanel-lovelace-ui.0 (55160) [config-manager] Screensaver pageItems count: 28 2026-03-17 20:02:51.040 - debug: nspanel-lovelace-ui.0 (55160) Config for Panel_1: raw 2026-03-17 20:02:51.183 - debug: nspanel-lovelace-ui.0 (55160) [library] Load language de 2026-03-17 20:02:51.191 - debug: nspanel-lovelace-ui.0 (55160) [library] Load language de from custom 2026-03-17 20:02:51.196 - info: nspanel-lovelace-ui.0 (55160) [mqttServer] MQTT server started and listening on port 8883 2026-03-17 20:02:51.429 - debug: nspanel-lovelace-ui.0 (55160) Force an MQTT reconnect from the Nspanel with the ip 192.168.178.57 in 10 seconds! 2026-03-17 20:02:52.655 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client "iobroker_35fd1b6d-1538-4195-ba6e-619fb7091747" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-17 20:02:52.704 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] MQTT connected. 2026-03-17 20:02:52.803 - debug: nspanel-lovelace-ui.0 (55160) Check configuration! 2026-03-17 20:02:52.809 - debug: nspanel-lovelace-ui.0 (55160) 44467.40625k 2026-03-17 20:02:52.817 - debug: nspanel-lovelace-ui.0 (55160) [controller] controller created 2026-03-17 20:02:53.031 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] subscribe to: Panel_1/stat/RESULT 2026-03-17 20:02:53.047 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1] Panel E0_E2_E6_0B_F3_E8 is initialised! 2026-03-17 20:02:53.048 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] subscribe to: Panel_1/tele/# 2026-03-17 20:02:53.078 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] subscribe to: Panel_1/stat/# 2026-03-17 20:02:53.092 - info: nspanel-lovelace-ui.0 (55160) [Panel_1] Setting panel to offline until first message! 2026-03-17 20:02:53.113 - debug: nspanel-lovelace-ui.0 (55160) [system-notifications] Request notifications from "system.host.iobroker-iobroker" 2026-03-17 20:02:53.131 - debug: nspanel-lovelace-ui.0 (55160) [system-notifications] Received notifications from "system.host.iobroker-iobroker": {} 2026-03-17 20:02:53.131 - debug: nspanel-lovelace-ui.0 (55160) [system-notifications] Request notifications from "system.host.pi-slave" 2026-03-17 20:02:53.136 - debug: nspanel-lovelace-ui.0 (55160) [system-notifications] Received notifications from "system.host.pi-slave": {"system":{"categories":{"packageUpdates":{"instances":{"system.host.pi-slave":{"messages":[{"message":"libcamera-ipa/stable 0.7.0+rpt20260205-1 arm64 [upgradable from: 0.6.0+rpt20251202-1]\nlibrpicam-app1/stable 1.11.1-1 arm64 [upgradable from: 1.10.1-1]\nlinux-headers-rpi-2712/stable 1:6.12.75-1+rpt1 arm64 [upgradable from: 1:6.12.62-1+rpt1]\nlinux-headers-rpi-v8/stable 1:6.12.75-1+rpt1 arm64 [upgradable from: 1:6.12.62-1+rpt1]\nlinux-image-rpi-2712/stable 1:6.12.75-1+rpt1 arm64 [upgradable from: 1:6.12.62-1+rpt1]\nlinux-image-rpi-v8/stable 1:6.12.75-1+rpt1 arm64 [upgradable from: 1:6.12.62-1+rpt1]\nrpicam-apps-core/stable 1.11.1-1 arm64 [upgradable from: 1.10.1-1]","ts":1773774161746}]}},"description":{"en":"Some OS packages can be updated.","de":"Einige Betriebssystempakete können aktualisiert werden.","ru":"Некоторые пакеты ОС могут быть обновлены.","pt":"Alguns pacotes do sistema operativo podem ser actualizados.","nl":"Sommige OS-pakketten kunnen worden bijgewerkt.","fr":"Certains paquets du système d'exploitation peuvent être mis à jour.","it":"Alcuni pacchetti del sistema operativo possono essere aggiornati.","es":"Algunos paquetes del sistema operativo pueden actualizarse.","pl":"Niektóre pakiety systemu operacyjnego mogą zostać zaktualizowane.","uk":"Деякі пакунки ОС можна оновити.","zh-cn":"某些操作系统软件包可以更新。"},"name":{"en":"OS package updates available","de":"Betriebssystem-Paket-Updates verfügbar","ru":"Доступны обновления пакетов ОС","pt":"Actualizações de pacotes do SO disponíveis","nl":"OS-pakketupdates beschikbaar","fr":"Mises à jour du système d'exploitation disponibles","it":"Aggiornamenti del pacchetto OS disponibili","es":"Actualizaciones de paquetes del SO disponibles","pl":"Dostępne aktualizacje pakietów systemu operacyjnego","uk":"Доступні оновлення пакетів ОС","zh-cn":"提供操作系统软件包更新"},"severity":"notify"}},"description":{"en":"These notifications are collected by the ioBroker system and point to issues you should check and fix.","de":"Diese Benachrichtigungen werden vom ioBroker-System erfasst und weisen auf Probleme hin, die überprüft und behoben werden sollten.","ru":"Эти уведомления собираются системой ioBroker и указывают на проблемы, которые вы должны проверить и исправить.","pt":"Essas notificações são coletadas pelo sistema ioBroker e apontam para problemas que você deve verificar e corrigir.","nl":"Deze meldingen worden verzameld door het ioBroker-systeem en wijzen op problemen die u moet controleren en oplossen.","fr":"Ces notifications sont collectées par le système ioBroker et indiquent des problèmes que vous devez vérifier et résoudre.","it":"Queste notifiche vengono raccolte dal sistema ioBroker e indicano problemi che dovresti controllare e correggere.","es":"Estas notificaciones son recopiladas por el sistema ioBroker y señalan problemas que debe verificar y solucionar.","pl":"Te powiadomienia są zbierane przez system ioBroker i wskazują problemy, które należy sprawdzić i naprawić.","uk":"Ці сповіщення збираються системою ioBroker і вказують на проблеми, які ви повинні перевірити та виправити.","zh-cn":"这些通知由ioBroker系统收集,并指出您应检查并修复的问题"},"name":{"en":"System Notifications","de":"System-Benachrichtigungen","ru":"Системные уведомления","pt":"Notificações do sistema","nl":"Systeemmeldingen","fr":"Notifications système","it":"Notifiche di sistema","es":"Notificaciones del sistema","pl":"Powiadomienia systemowe","uk":"Системні сповіщення","zh-cn":"系统通知"}}} 2026-03-17 20:02:53.662 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client iobroker_35fd1b6d-1538-4195-ba6e-619fb7091747 connected. 2026-03-17 20:02:57.388 - debug: nspanel-lovelace-ui.0 (55160) [controller] Panel E0_E2_E6_0B_F3_E8 created 2026-03-17 20:02:57.605 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:02:58.763 - debug: nspanel-lovelace-ui.0 (55160) [controller] No pageConfig available, skipping trash data update. 2026-03-17 20:02:58.764 - info: nspanel-lovelace-ui.0 (55160) [controller] 1 Panels initialized 2026-03-17 20:03:00.604 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:03:01.746 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client "Panel_1-0BF3E8" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-17 20:03:02.026 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:03:02.668 - debug: nspanel-lovelace-ui.0 (55160) {"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.2"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.2"},"id":1105,"ack":false,"time":1773774182749},"_id":60922982} 2026-03-17 20:03:02.751 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client Panel_1-0BF3E8 connected. 2026-03-17 20:03:02.952 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:03:05.952 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:03:10.952 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:03:17.952 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:03:26.953 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:03:37.953 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:03:49.947 - debug: nspanel-lovelace-ui.0 (55160) {"command":"getAllPages","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":1106,"ack":false,"time":1773774230029},"_id":60922983} 2026-03-17 20:03:50.965 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:04:05.975 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:04:22.985 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:04:41.993 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:03.003 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:04.902 - debug: nspanel-lovelace-ui.0 (55160) {"command":"nsPanelInit","message":{"tasmotaName":"Panel_1","tasmotaIP":"192.168.178.57","tasmotaTopic":"Panel_1","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"WNsOXNbpSLDZjgX","mqttPassword":"WGH2BZtuEcI:.ek9p3aI_:p1eJZDEjhkyrvAaW=oyw1O2yxMgm","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"from":"system.adapter.admin.0","callback":{"message":{"tasmotaName":"Panel_1","tasmotaIP":"192.168.178.57","tasmotaTopic":"Panel_1","mqttServer":true,"mqttIp":"","mqttPort":8883,"mqttUsername":"WNsOXNbpSLDZjgX","mqttPassword":"WGH2BZtuEcI:.ek9p3aI_:p1eJZDEjhkyrvAaW=oyw1O2yxMgm","internalServerIp":"192.168.178.2","useBetaTFT":false,"model":"eu"},"id":1107,"ack":false,"time":1773774304989},"_id":60922984} 2026-03-17 20:05:04.903 - info: nspanel-lovelace-ui.0 (55160) Sending mqtt config & base config to tasmota: 192.168.178.57 with user WNsOXNbpSLDZjgX && *** 2026-03-17 20:05:04.904 - debug: nspanel-lovelace-ui.0 (55160) Requesting tasmota status 5 with url: http://192.168.178.57/cm?&cmnd=status%205 2026-03-17 20:05:05.056 - debug: nspanel-lovelace-ui.0 (55160) Response from tasmota status 5: {"StatusNET":{"Hostname":"Panel-1","IPAddress":"192.168.178.57","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"E0:E2:E6:0B:F3:E8","IP6Global":"fd9a:b998:ff69:481f:e2e2:e6ff:fe0b:f3e8","IP6Local":"fe80::e2e2:e6ff:fe0b:f3e8%st1","Ethernet":{"Hostname":"","IPAddress":"0.0.0.0","Gateway":"0.0.0.0","Subnetmask":"0.0.0.0","DNSServer1":"192.168.178.1","DNSServer2":"0.0.0.0","Mac":"00:00:00:00:00:00","IP6Global":"","IP6Local":""},"Webserver":2,"HTTP_API":1,"WifiConfig":4,"WifiPower":16}} 2026-03-17 20:05:05.057 - debug: nspanel-lovelace-ui.0 (55160) Sending mqtt config & base config to tasmota with IP 192.168.178.57 and name Panel_1. 2026-03-17 20:05:05.138 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] Wait for panel connect on: Panel_1/tele/INFO1 2026-03-17 20:05:05.139 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] subscribe to: Panel_1/tele/INFO1 2026-03-17 20:05:17.653 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client "Panel_1-0BF3E8" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-17 20:05:17.713 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] Panel connect detected: Panel_1/tele/INFO1 2026-03-17 20:05:17.790 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] Wait for panel connect on: Panel_1/tele/INFO1 2026-03-17 20:05:17.791 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] subscribe to: Panel_1/tele/INFO1 2026-03-17 20:05:17.913 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:18.655 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client Panel_1-0BF3E8 connected. 2026-03-17 20:05:18.856 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:21.857 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:26.858 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:28.467 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client "Panel_1-0BF3E8" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-17 20:05:28.525 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] Panel connect detected: Panel_1/tele/INFO1 2026-03-17 20:05:28.726 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:29.470 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client Panel_1-0BF3E8 connected. 2026-03-17 20:05:29.670 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:30.812 - info: nspanel-lovelace-ui.0 (55160) Installing berry on tasmota with IP 192.168.178.57, name Panel_1. 2026-03-17 20:05:30.813 - debug: nspanel-lovelace-ui.0 (55160) URL: http://192.168.178.57/cm?&cmnd=Backlog UfsRename autoexec.be,autoexec.old; UrlFetch https://raw.githubusercontent.com/ticaki/ioBroker.nspanel-lovelace-ui/main/tasmota/berry/10/autoexec.be; Restart 1 2026-03-17 20:05:30.917 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] Wait for panel connect on: Panel_1/tele/INFO1 2026-03-17 20:05:30.917 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] subscribe to: Panel_1/tele/INFO1 2026-03-17 20:05:30.919 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1] Received STATUS10 with sensor data, updated info and states! 2026-03-17 20:05:32.670 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:37.672 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:40.999 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client "Panel_1-0BF3E8" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-17 20:05:41.061 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] Panel connect detected: Panel_1/tele/INFO1 2026-03-17 20:05:41.261 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:42.002 - debug: nspanel-lovelace-ui.0 (55160) [mqttServer] Client Panel_1-0BF3E8 connected. 2026-03-17 20:05:42.202 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:44.063 - debug: nspanel-lovelace-ui.0 (55160) FlashNextionAdv0 http://nspanel.de/nspanel-v5.1.1.tft 2026-03-17 20:05:44.164 - info: nspanel-lovelace-ui.0 (55160) Installing tft on tasmota with IP 192.168.178.57 and name Panel_1. 2026-03-17 20:05:44.170 - debug: nspanel-lovelace-ui.0 (55160) Create/Update script script.js.nspanel-lovelace-ui_0.globalPageConfig 2026-03-17 20:05:44.189 - info: nspanel-lovelace-ui.0 (55160) Update script script.js.nspanel-lovelace-ui_0.globalPageConfig 2026-03-17 20:05:44.190 - info: nspanel-lovelace-ui.0 (55160) Update global script script.js.nspanel-lovelace-ui_0.globalPageConfig 2026-03-17 20:05:44.276 - debug: nspanel-lovelace-ui.0 (55160) Create script script.js.nspanel-lovelace-ui_0.Panel_1 2026-03-17 20:05:44.306 - info: nspanel-lovelace-ui.0 (55160) Update script script.js.nspanel-lovelace-ui_0.Panel_1 2026-03-17 20:05:45.203 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:48.025 - info: host.pi-slave instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 55180 2026-03-17 20:05:48.975 - info: host.pi-slave stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=true) 2026-03-17 20:05:48.979 - info: nspanel-lovelace-ui.0 (55160) Got terminate signal TERMINATE_YOURSELF 2026-03-17 20:05:49.162 - info: host.pi-slave stopInstance system.adapter.nspanel-lovelace-ui.0 send kill signal 2026-03-17 20:05:49.178 - debug: nspanel-lovelace-ui.0 (55160) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:05:49.179 - info: nspanel-lovelace-ui.0 (55160) [Panel_1] Goint offline because delete panel! 2026-03-17 20:05:49.269 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] unsubscribe from: Panel_1/stat/RESULT 2026-03-17 20:05:49.271 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] unsubscribe from: Panel_1/tele/# 2026-03-17 20:05:49.272 - debug: nspanel-lovelace-ui.0 (55160) [mqttClient] unsubscribe from: Panel_1/stat/# 2026-03-17 20:05:49.323 - info: nspanel-lovelace-ui.0 (55160) [mqttClient] MQTT connection closed. 2026-03-17 20:05:49.327 - info: nspanel-lovelace-ui.0 (55160) terminating 2026-03-17 20:05:49.329 - info: nspanel-lovelace-ui.0 (55160) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2026-03-17 20:05:49.482 - info: nspanel-lovelace-ui.0 (55160) terminating 2026-03-17 20:05:50.100 - info: host.pi-slave instance system.adapter.nspanel-lovelace-ui.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-03-17 20:05:53.661 - info: host.pi-slave instance system.adapter.nspanel-lovelace-ui.0 in version "0.14.0" started with pid 55196 2026-03-17 20:05:56.149 - debug: nspanel-lovelace-ui.0 (55196) Redis Objects: Use Redis connection: 192.168.178.116:9001 2026-03-17 20:05:56.222 - debug: nspanel-lovelace-ui.0 (55196) Objects client ready ... initialize now 2026-03-17 20:05:56.225 - debug: nspanel-lovelace-ui.0 (55196) Objects create System PubSub Client 2026-03-17 20:05:56.228 - debug: nspanel-lovelace-ui.0 (55196) Objects create User PubSub Client 2026-03-17 20:05:56.362 - debug: nspanel-lovelace-ui.0 (55196) Objects client initialize lua scripts 2026-03-17 20:05:56.371 - debug: nspanel-lovelace-ui.0 (55196) Objects connected to redis: 192.168.178.116:9001 2026-03-17 20:05:56.444 - debug: nspanel-lovelace-ui.0 (55196) Redis States: Use Redis connection: 192.168.178.116:9000 2026-03-17 20:05:56.490 - debug: nspanel-lovelace-ui.0 (55196) States create System PubSub Client 2026-03-17 20:05:56.492 - debug: nspanel-lovelace-ui.0 (55196) States create User PubSub Client 2026-03-17 20:05:56.620 - debug: nspanel-lovelace-ui.0 (55196) States connected to redis: 192.168.178.116:9000 2026-03-17 20:05:56.779 - info: nspanel-lovelace-ui.0 (55196) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v22.22.1, js-controller: 7.0.7 2026-03-17 20:05:56.842 - info: nspanel-lovelace-ui.0 (55196) Configured panels: name#topic -> [Panel_1#Panel_1] 2026-03-17 20:05:56.843 - info: nspanel-lovelace-ui.0 (55196) Found 1 script configs for topics: Panel_1 2026-03-17 20:05:56.843 - info: nspanel-lovelace-ui.0 (55196) Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter. 2026-03-17 20:05:56.848 - debug: nspanel-lovelace-ui.0 (55196) [config-manager] Start converting configuration for Panel_1 2026-03-17 20:05:56.942 - debug: nspanel-lovelace-ui.0 (55196) [config-manager] Screensaver pageItems count: 28 2026-03-17 20:05:56.951 - debug: nspanel-lovelace-ui.0 (55196) Config for Panel_1: raw 2026-03-17 20:05:57.093 - debug: nspanel-lovelace-ui.0 (55196) [library] Load language de 2026-03-17 20:05:57.103 - debug: nspanel-lovelace-ui.0 (55196) [library] Load language de from custom 2026-03-17 20:05:57.108 - info: nspanel-lovelace-ui.0 (55196) [mqttServer] MQTT server started and listening on port 8883 2026-03-17 20:05:57.307 - debug: nspanel-lovelace-ui.0 (55196) Force an MQTT reconnect from the Nspanel with the ip 192.168.178.57 in 10 seconds! 2026-03-17 20:05:58.533 - debug: nspanel-lovelace-ui.0 (55196) [mqttServer] Client "iobroker_77ce8a31-fb9e-457e-9fd5-17780e3856c2" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-17 20:05:58.580 - debug: nspanel-lovelace-ui.0 (55196) [mqttClient] MQTT connected. 2026-03-17 20:05:58.682 - debug: nspanel-lovelace-ui.0 (55196) Check configuration! 2026-03-17 20:05:58.690 - debug: nspanel-lovelace-ui.0 (55196) 44414.515625k 2026-03-17 20:05:58.697 - debug: nspanel-lovelace-ui.0 (55196) [controller] controller created 2026-03-17 20:05:58.902 - debug: nspanel-lovelace-ui.0 (55196) [mqttClient] subscribe to: Panel_1/stat/RESULT 2026-03-17 20:05:58.918 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1] Panel E0_E2_E6_0B_F3_E8 is initialised! 2026-03-17 20:05:58.919 - debug: nspanel-lovelace-ui.0 (55196) [mqttClient] subscribe to: Panel_1/tele/# 2026-03-17 20:05:58.948 - debug: nspanel-lovelace-ui.0 (55196) [mqttClient] subscribe to: Panel_1/stat/# 2026-03-17 20:05:58.963 - info: nspanel-lovelace-ui.0 (55196) [Panel_1] Setting panel to offline until first message! 2026-03-17 20:05:58.983 - debug: nspanel-lovelace-ui.0 (55196) [system-notifications] Request notifications from "system.host.iobroker-iobroker" 2026-03-17 20:05:58.998 - debug: nspanel-lovelace-ui.0 (55196) [system-notifications] Received notifications from "system.host.iobroker-iobroker": {} 2026-03-17 20:05:58.999 - debug: nspanel-lovelace-ui.0 (55196) [system-notifications] Request notifications from "system.host.pi-slave" 2026-03-17 20:05:59.004 - debug: nspanel-lovelace-ui.0 (55196) [system-notifications] Received notifications from "system.host.pi-slave": {"system":{"categories":{"packageUpdates":{"instances":{"system.host.pi-slave":{"messages":[{"message":"libcamera-ipa/stable 0.7.0+rpt20260205-1 arm64 [upgradable from: 0.6.0+rpt20251202-1]\nlibrpicam-app1/stable 1.11.1-1 arm64 [upgradable from: 1.10.1-1]\nlinux-headers-rpi-2712/stable 1:6.12.75-1+rpt1 arm64 [upgradable from: 1:6.12.62-1+rpt1]\nlinux-headers-rpi-v8/stable 1:6.12.75-1+rpt1 arm64 [upgradable from: 1:6.12.62-1+rpt1]\nlinux-image-rpi-2712/stable 1:6.12.75-1+rpt1 arm64 [upgradable from: 1:6.12.62-1+rpt1]\nlinux-image-rpi-v8/stable 1:6.12.75-1+rpt1 arm64 [upgradable from: 1:6.12.62-1+rpt1]\nrpicam-apps-core/stable 1.11.1-1 arm64 [upgradable from: 1.10.1-1]","ts":1773774161746}]}},"description":{"en":"Some OS packages can be updated.","de":"Einige Betriebssystempakete können aktualisiert werden.","ru":"Некоторые пакеты ОС могут быть обновлены.","pt":"Alguns pacotes do sistema operativo podem ser actualizados.","nl":"Sommige OS-pakketten kunnen worden bijgewerkt.","fr":"Certains paquets du système d'exploitation peuvent être mis à jour.","it":"Alcuni pacchetti del sistema operativo possono essere aggiornati.","es":"Algunos paquetes del sistema operativo pueden actualizarse.","pl":"Niektóre pakiety systemu operacyjnego mogą zostać zaktualizowane.","uk":"Деякі пакунки ОС можна оновити.","zh-cn":"某些操作系统软件包可以更新。"},"name":{"en":"OS package updates available","de":"Betriebssystem-Paket-Updates verfügbar","ru":"Доступны обновления пакетов ОС","pt":"Actualizações de pacotes do SO disponíveis","nl":"OS-pakketupdates beschikbaar","fr":"Mises à jour du système d'exploitation disponibles","it":"Aggiornamenti del pacchetto OS disponibili","es":"Actualizaciones de paquetes del SO disponibles","pl":"Dostępne aktualizacje pakietów systemu operacyjnego","uk":"Доступні оновлення пакетів ОС","zh-cn":"提供操作系统软件包更新"},"severity":"notify"}},"description":{"en":"These notifications are collected by the ioBroker system and point to issues you should check and fix.","de":"Diese Benachrichtigungen werden vom ioBroker-System erfasst und weisen auf Probleme hin, die überprüft und behoben werden sollten.","ru":"Эти уведомления собираются системой ioBroker и указывают на проблемы, которые вы должны проверить и исправить.","pt":"Essas notificações são coletadas pelo sistema ioBroker e apontam para problemas que você deve verificar e corrigir.","nl":"Deze meldingen worden verzameld door het ioBroker-systeem en wijzen op problemen die u moet controleren en oplossen.","fr":"Ces notifications sont collectées par le système ioBroker et indiquent des problèmes que vous devez vérifier et résoudre.","it":"Queste notifiche vengono raccolte dal sistema ioBroker e indicano problemi che dovresti controllare e correggere.","es":"Estas notificaciones son recopiladas por el sistema ioBroker y señalan problemas que debe verificar y solucionar.","pl":"Te powiadomienia są zbierane przez system ioBroker i wskazują problemy, które należy sprawdzić i naprawić.","uk":"Ці сповіщення збираються системою ioBroker і вказують на проблеми, які ви повинні перевірити та виправити.","zh-cn":"这些通知由ioBroker系统收集,并指出您应检查并修复的问题"},"name":{"en":"System Notifications","de":"System-Benachrichtigungen","ru":"Системные уведомления","pt":"Notificações do sistema","nl":"Systeemmeldingen","fr":"Notifications système","it":"Notifiche di sistema","es":"Notificaciones del sistema","pl":"Powiadomienia systemowe","uk":"Системні сповіщення","zh-cn":"系统通知"}}} 2026-03-17 20:05:59.552 - debug: nspanel-lovelace-ui.0 (55196) [mqttServer] Client iobroker_77ce8a31-fb9e-457e-9fd5-17780e3856c2 connected. 2026-03-17 20:06:04.163 - debug: nspanel-lovelace-ui.0 (55196) [controller] Panel E0_E2_E6_0B_F3_E8 created 2026-03-17 20:06:04.165 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/STATUS0","payload":""} to panel. 2026-03-17 20:06:04.493 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:06:05.681 - debug: nspanel-lovelace-ui.0 (55196) [controller] No pageConfig available, skipping trash data update. 2026-03-17 20:06:05.681 - info: nspanel-lovelace-ui.0 (55196) [controller] 1 Panels initialized 2026-03-17 20:06:06.400 - info: host.pi-slave instance system.adapter.weatherunderground.0 having pid 55180 terminated with code 0 (NO_ERROR) 2026-03-17 20:06:06.966 - debug: nspanel-lovelace-ui.0 (55196) [mqttServer] Client "Panel_1-0BF3E8" login successful (user="WNsOXNbpSLDZjgX"). 2026-03-17 20:06:07.230 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:06:07.970 - debug: nspanel-lovelace-ui.0 (55196) [mqttServer] Client Panel_1-0BF3E8 connected. 2026-03-17 20:06:08.170 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:06:11.170 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:06:16.172 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:06:23.172 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:06:32.172 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:06:43.172 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. 2026-03-17 20:06:56.184 - debug: nspanel-lovelace-ui.0 (55196) [Panel_1-SendClass] send payload: {"topic":"Panel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel. -
Kann es sein das das NSPanel keinen Internetzugang hat?
Wenn du
UrlFetch https://raw.githubusercontent.com/ticaki/ioBroker.nspanel-lovelace-ui/main/tasmota/berry/10/autoexec.bein die Tasmota Konsole eingibst sollte das Berryscript installiert werden - wenn das Panel internet hat.
