  4. Grohe - Sense / Guard /Blue - Adapter
133 Beiträge 3 Kommentatoren 7.7k Aufrufe 4 Beobachtet
  • patricknitschP Online
    patricknitsch
    schrieb am zuletzt editiert von patricknitsch
    #78
    Kann ich nicht sicher beantworten. Aber letzten Endes muss ja jeder getauscht werden. Bei wie viel % stehst du aktuell in der App? Und wie viel Liter werden dir aktuell im Adapter angezeigt?
    Systeme:
    • Proxmox 1 mit ioBroker, HomeAssistant, piHole
    • Proxmox 2 mit SOLECTRUS, Mosquitto, piHole und Frigate
    • RPi4 mit Octoprint
    Eigene Adapter: grohe-smarthome, solectrus-influxdb, schlueter-thermostat
      M-A-X
      #79
      Und hier das letzte aus dem log
      grohe-smarthome.0
      2026-03-13 19:38:19.008	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T19:33:17.000+01:00
      grohe-smarthome.0
      2026-03-13 19:38:19.008	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12190,"open_close_cycles_still":12864,"operating_time":28168,"power_cut_count":41,"pump_count":19690,"pump_running_time":2906,"remaining_co2":32,"remaining_filter":66,"time_since_last_withdrawal":22,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T19:33:17.000+01:00","water_running_time_carbonated":3292,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1966,"remaining_co2_liters":18}
      grohe-smarthome.0
      2026-03-13 19:38:17.461	debug	Poll cycle #91 (status=false, command=false, pressure=false, consumption=false)
      grohe-smarthome.0
      2026-03-13 19:33:27.734	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T19:33:17.000+01:00
      grohe-smarthome.0
      2026-03-13 19:33:27.734	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T19:18:13.000+01:00, new=2026-03-13T19:33:17.000+01:00, remaining_filter=66, remaining_co2=32)
      grohe-smarthome.0
      2026-03-13 19:33:17.232	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T19:18:13.000+01:00
      grohe-smarthome.0
      2026-03-13 19:33:17.231	debug	Triggered measurement
      Und hier das aktuelle Objekt
        patricknitsch
        #80
        Nächster Versuch :) Installieren, Adapter neu starten und berichten
        Systeme:
          M-A-X
          #81
          Leider trotz 300 Sekunden warten keine Änderung. Also immer noch 66% im dem Objekten und 62 in der App. Wie ich weiter oben geschrieben habe, stört mich das nicht. Aber ich helfe gerne weiter bei der Suche /beim probieren. Habe jetzt aber Besuch und werde erst morgen wieder testen können. Macht es einen Unterschied ob ich den Adapter komplett lösche oder nur drüber installiere? Letzteres mache ich immer.
            patricknitsch
            #82
            Kannst du gerne mal machen. Dann haben wir gleich ein sauberes Bild. Melde dich einfach, wenn du bereit bist.
            Systeme:
              M-A-X
              schrieb am zuletzt editiert von M-A-X
              #83
              Es ändert sich leider nichts. Immer noch 66 %
              grohe-smarthome.0
              Zeit
              debug
              Nachricht
              grohe-smarthome.0
              2026-03-13 22:44:50.503	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:44:40.000+01:00
              grohe-smarthome.0
              2026-03-13 22:44:50.502	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
              grohe-smarthome.0
              2026-03-13 22:44:50.501	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T22:39:38.000+01:00, new=2026-03-13T22:44:40.000+01:00, remaining_filter=66, remaining_co2=32)
              grohe-smarthome.0
              2026-03-13 22:44:39.803	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:39:38.000+01:00
              grohe-smarthome.0
              2026-03-13 22:44:39.802	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
              grohe-smarthome.0
              2026-03-13 22:44:39.414	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
              grohe-smarthome.0
              2026-03-13 22:44:39.411	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12190,"open_close_cycles_still":12864,"operating_time":28171,"power_cut_count":41,"pump_count":19690,"pump_running_time":2906,"remaining_co2":32,"remaining_filter":66,"time_since_last_withdrawal":209,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T22:39:38.000+01:00","water_running_time_carbonated":3292,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1966,"remaining_co2_liters":18}
              grohe-smarthome.0
              2026-03-13 22:44:38.244	debug	Poll cycle #27 (status=false, command=true, pressure=false, consumption=false)
              grohe-smarthome.0
              2026-03-13 22:39:48.438	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:39:38.000+01:00
              grohe-smarthome.0
              2026-03-13 22:39:48.438	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
              grohe-smarthome.0
              2026-03-13 22:39:48.437	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T22:34:36.000+01:00, new=2026-03-13T22:39:38.000+01:00, remaining_filter=66, remaining_co2=32)
              grohe-smarthome.0
              2026-03-13 22:39:38.020	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:34:36.000+01:00
              grohe-smarthome.0
              2026-03-13 22:39:38.019	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
              grohe-smarthome.0
              2026-03-13 22:39:37.748	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
              grohe-smarthome.0
              2026-03-13 22:39:37.747	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12190,"open_close_cycles_still":12864,"operating_time":28171,"power_cut_count":41,"pump_count":19690,"pump_running_time":2906,"remaining_co2":32,"remaining_filter":66,"time_since_last_withdrawal":204,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T22:34:36.000+01:00","water_running_time_carbonated":3292,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1966,"remaining_co2_liters":18}
              grohe-smarthome.0
              2026-03-13 22:39:36.602	debug	Poll cycle #26 (status=false, command=false, pressure=false, consumption=false)
              grohe-smarthome.0
              2026-03-13 22:34:46.841	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:34:36.000+01:00
              grohe-smarthome.0
              2026-03-13 22:34:46.841	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
              grohe-smarthome.0
              2026-03-13 22:34:46.840	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T22:29:35.000+01:00, new=2026-03-13T22:34:36.000+01:00, remaining_filter=66, remaining_co2=32)
              grohe-smarthome.0
              2026-03-13 22:34:36.326	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:29:35.000+01:00
              grohe-smarthome.0
              2026-03-13 22:34:36.325	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
              grohe-smarthome.0
              2026-03-13 22:34:36.106	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
              grohe-smarthome.0
              2026-03-13 22:34:36.105	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12190,"open_close_cycles_still":12864,"operating_time":28171,"power_cut_count":41,"pump_count":19690,"pump_running_time":2906,"remaining_co2":32,"remaining_filter":66,"time_since_last_withdrawal":199,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T22:29:35.000+01:00","water_running_time_carbonated":3292,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1966,"remaining_co2_liters":18}
              grohe-smarthome.0
              2026-03-13 22:34:35.082	debug	[auth] token refresh successful (access: eyJhbG...QIVQ)
              grohe-smarthome.0
              2026-03-13 22:34:34.928	debug	[auth] refreshing tokens
              Ich habe allerdings heute auch kaum Wasser gezapft. Morgen bin ich den ganzen Tag unterwegs und nur bis ca 10 und kurz abends zuhause. Mal schauen ob sich was ändert, wenn mehr Wasser gezapft wird.
              Ich hatte den Adapter komplett gelöscht und neu über den github link installiert
                patricknitsch
                #84
                Langsam weis ich da auch nicht weiter. Vor allem warum es nur der eine Wert ist. Ich hab halt leider auch keine Blue um es selbst zu testen.
                Systeme:
                  M-A-X
                  #85
                  Wie geschrieben ist es zumindest für mich nicht wichtig.
                  Wird irgendwo der Wert mitgeschickt, welche Art von Filter installiert ist? Ich habe im log gesehen, dass da (mittlerweile?) steht 66% von 3000l. Oder hast du das nur manuell auf 3000 eingestellt in der Testversion?
                  Wenn mitgeschickt wird welcher Filter drinnen ist, könnte man zumindest mal schauen was bei den anderen eingestellt ist, die keine Probleme haben.
                  Offtopic: mit dem s / L Filter hatten wir nie viel Kohlensäure im Wasser. Ich habe dann irgendwo in einem forum gelesen, dass jemand den Aktivkohlefilter genommen hat und plötzlich mehr Kohlensäure drinnen war. Das hat bei uns auch funktioniert (es ging gefühlt von leicht abgestandenen Medium zu starkem classic Wasser vom Kohlensäuregehalt). Daher bin ich beim Aktivkohlefilter geblieben.
                    patricknitsch
                    #86
                    Ja ich hab versucht den Wert errechnen zu lassen. Aber letztendlich alles sinnlos, weil der Wert eigentlich über die API kommen muss. Und CO2 macht das ja auch.
                    Da es unterschiedliche Filter gibt, möchte ich mich da nicht festlegen, da unterschiedliche Mengen dahinter sind. Habe auch nichts gefunden, was auf den Filtertyp hinweist.
                    Edit:
                    Es gibt tatsächlich Informationen drüber, welcher Filter verbaut ist. Die Api bietet dazu folgendes an: S_SIZE, ACTIVE_CARBON, ULTRA_SAFE, MAGNESIUM_PLUS, M_SIZE.
                    Systeme:
                      M-A-X
                      #87
                      Interessanter Denkanstoß von dir, daher habe ich nachgerechnet: 1966 Liter Rest von 3000 sind 66% (wie ausgelesen vom Adapter) und nicht 62% wie in der App. Evtl ist das Auslesen gar nicht falsch oder klappt nicht, sondern die App zeigt absichtlich 'früher' an. Zum Beispiel damit man den Filter rechtzeitig kauft.
                      Und bei den großen Filtern (3000l) ändert sich die Prozentzahl wesentlich langsamer als bei den kleinen. Daher könnte es wie ein Bug aussehen, dass nichts passiert, aber er zeigt halt von 66,49 bis 65,50 %, also knapp 30 Liter lang, unverändert 66% bei mir... Er müsste bei 1947 Litern umspringen auf 65%, das ist in 19 Litern. Ich würde vorschlagen, dass ich wieder die 0.2.6 installiere und bescheid gebe sobald der Wert unter 1947 Rest geht. Denn es könnte wie gesagt sein, dass alles gut ist und nur die app nicht stimmt.
                      Sorry, hab nicht dran gedacht einfach mal nachzurechnen.
                      patricknitschP 1 Antwort Letzte Antwort
                      • M M-A-X
                        patricknitsch
                        #88
                        @M-A-X sagte in Grohe - Sense / Guard /Blue - Adapter:
                        Den Weg würde ich dir auch vorschlagen. Back to Root und dann beobachten, ob sich etwas tut. Ich schaue in der Zwischenzeit trotzdem mal weiter.
                        Am Ende werden beide Werte über den selben Endpunkt abgerufen und einer passt. Fraglich, ob es dann überhaupt am Adapter liegt, oder wirklich bewusst so von der App kommttt.
                        Systeme:
                          M-A-X
                          #89
                          Filter ist soeben von 66 auf 65% runter gegangen. Es scheint also alles zu passen. Entschuldigung für die Arbeit, die ich dir gemacht habe :)
                          Evtl kannst bzw solltest du dann noch auf github dazu schreiben, dass der Adapter den korrekt errechneten Filterstand anzeigt und die app davon (warum auch immer) abweicht.
                            patricknitsch
                            #90
                            Kein Problem. Da du eben Abweichungen zwischen App und dem Adapter siehst, ist das verständlich. Bitte trotzdem mal weiter beobachten.
                            Du bist jetzt wieder auf der Latest Version?
                            Systeme:
                              M-A-X
                              #91
                              Ja genau. Hatte alles deinstalliert und dann ganz normal über iobroker den Adapter 0.2.6 installiert.
                                patricknitsch
                                #92
                                Supi. Dann gerne nächste Woche noch mal melden :)
                                Systeme:
                                  patricknitsch
                                  #93
                                  @m-a-x @jackdaniel: Haben sich eure Werte weiterhin geändert? Wie sehen diese im Vergleich zur App aus? Gerne mal unter NPM die Version 0.3.0 anschauen. Diese hat jetzt einen eigenen Tab, der euch alle Werte anschaut. Bitte davon mal einen Screenshot machen, wie es beim Blue aussieht :)
                                  Systeme:
                                    M-A-X
                                    #94
                                    Hey. Ich hab immer noch die paar % Abweichung. Da ich immer ca 30 Liter zapfen muss, damit der Filter 1% weniger hat, ist seit dem letzten 'Update' nichts passiert :) so viel trinke ich nicht.
                                    Die 0.3.0 werde ich später mal installieren und hier posten. Gleich muss ich erstmal die Kinder ins Bett bringen :)
                                    EDIT: Habs schnell installiert, aber ich sehe keinen Tab
                                      patricknitsch
                                      #95
                                      Sorry, der Tab is links auf der Hauptseite und heißt "Gerätekonfiguration".
                                      Systeme:
                                        M-A-X
                                        #96
                                        Ah. Ist mir durchgegangen :)
                                        Ohne es testen zu wollen : wenn ich den Filter oder CO2 zurücksetze, kommt da noch ne Bestätigungsabfrage? Man kann leider den Status nicht wieder umstellen, wenn man 'versehentlich' zum Beispiel den Filter resettet.
                                          patricknitsch
                                          #97
                                          Nein wird direkt ausgeführt.
                                          Edit:
                                          Ich pushe aber noch eine Version, bei der die Funktionen bestätigt werden müssen.
                                          Systeme:
