  4. [gelöst] Kann ioBroker auf Windows 10 nicht installieren
    6.3k
26 Beiträge 7 Kommentatoren 7.0k Aufrufe
  • R Offline
    rh1212
    @eric2905:
    Mit welchem Ergebnis?
    Gruß,
    Eric
    Von unterwegs getippert `
    iobroker@1.0.8 install C:\ioBroker\node_modules\iobroker
    > node lib/setup.js
    NPM version: 2.15.9
    npm install iobroker.discovery --production --save --prefix "C:/ioBroker"
    npm install iobroker.admin --production --save --prefix "C:/ioBroker"
    npm install iobroker.js-controller --production --save --prefix "C:/ioBroker"
    npm WARN deprecated localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    gyp ERR! configure error
    gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
    gyp ERR! stack     at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:449:14)
    gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11
    gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:82:15)
    gyp ERR! System Windows_NT 10.0.16299
    gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    gyp ERR! cwd C:\ioBroker\node_modules\iobroker.js-controller\node_modules\winston-syslog\node_modules\unix-dgram
    gyp ERR! node -v v4.5.0
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    npm WARN optional dep failed, continuing unix-dgram@0.2.3
    gyp ERR! cwd C:\ioBroker\node_modules\iobroker.js-controller\node_modules\greenlock\node_modules\rsa-compat\node_modules\ursa
    gyp ERR! not ok
    npm WARN optional dep failed, continuing ursa@0.9.4
    Write "iobroker start" to start the ioBroker
    npm install https://github.com/arthurblake/node-windows/tarball/f1fd60e93e2469663b99a9cf3a64086ecedfe1e4 --production --save --prefix "C:/ioBroker/"
    oder ersten Screenshot. Also leider ging auch nicht.
    • rantanplanR Offline
      rantanplanR Offline
      rantanplan
      Hallo rh1212
      Python Fehlermeldungen habe ich immer ignoriert.
      Keine Ahnung wofür Python bei ioBroker gebraucht wird.
      Ich habe es noch nie gebraucht und nie installiert.
      Rantanplan
      • R Offline
        rh1212
        @rantanplan:
        Hallo rh1212
        Grüße `
        Hallo rantanplan,
        danke für die Antwort. Das problem ist, dass nach der Installtionen öffnet die localhost seite nicht.
          Hast du mal ein sudo iobroker start gemacht?
          • eric2905E Offline
            eric2905E Offline
            eric2905
            Eh, im Log aus der Installer-Installation steht doch
            Hast Du das mal probiert?
            Gruß,
            Eric
            • R Offline
              rh1212
              @Homoran:
              Hast du mal ein sudo iobroker start gemacht? `
              @eric2905:
              Gruß,
              Eric
              ja und leider ging nicht
                rantanplanR Offline
                rantanplan
                @rh1212:
                Das problem ist, dass nach der Installtionen öffnet die localhost seite nicht. `
                Auf Windows läuft ioBroker als Dienst. Schau mal ob der läuft.
                Rantanplan
                • eric2905E Offline
                  eric2905E Offline
                  eric2905
                  Ich weiß schon, warum ich Windows nicht mag ;-)
                  • R Offline
                    rh1212
                    @rantanplan:
                    @rh1212:
                    Auf Windows läuft ioBroker als Dienst. Schau mal ob der läuft. `
                    Unter Dienste steht iobroker.exe aber ist gestopped, ich versuchte mit recht klick das zu starten aber bekam ich ein fehler Meldung. "The service cannot be started, either because it is disabled or because it has no enabled devices associated with it"
                      rantanplanR Offline
                      rantanplan
                      Dienst so einrichten.
                      Reiter "Anmelden" -> "Anmelden als: Lokales Systemkonto
                      Rantanplan
                      • R Offline
                        rh1212
                        @rantanplan:
                        Reiter "Anmelden" -> "Anmelden als: Lokales Systemkonto `
                        Ach das hat funktioniert!!!! Vielen vielen Dank!!!!
                          rantanplanR Offline
                          rantanplan
                          @rh1212:
                          Ach das hat funktioniert!!!! Vielen vielen Dank!!!! `
                          Prima.
                          Dann bitte ein [gelöst] in den Betreff des ersten Beitrags setzen.
                          Danke.
                          Rantanplan
                          • apollon77A Offline
                            @rantanplan:
                            Ich habe es noch nie gebraucht und nie installiert. `
                            ioBroker selbst braucht das nicht. Es gibt aber nodejs Libraries die ggf beim Installationsprozess gebaut werden oder sowas und da kann es nötig sein das python da ist, da sonst ggf Libraries und damit ggf Adapter nicht installierbar sind.
                              mean
                              Leider habe ich folgendes Problem mit io und win10. Hat jemand eine Lösung?
                              • sigi234S Online
                                sigi234S Online
                                  mean
                                  Wenn ich den Dienst starten will dann kommt die oben genannte Meldung.
                                  • sigi234S Online
                                    sigi234S Online
                                    viewtopic.php?f=17&t=16920
                                    viewtopic.php?f=17&t=16920&start=20#p178052
                                    http://www.iobroker.net/docu/?page_id=2291&lang=de
                                      mean
                                      Wow…. merci läuft.... Danke
