  4. OpenKNX Adapter startet nicht mehr nach System-Update
    6.0k
23 Beiträge 3 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • R rsw2004
    @rsw2004
    Also ich denke, das hat mit dem Update des Adapter angefangen, unabhängig von JS oder NPM oder was auch immer.
    Kann ich einfach die ältere Version das drüberbügeln?
    Einfach die Versionsnummer ändern?
    @rsw2004
    Wobei das auf meinem System direkt durchläuft:
    echad@chet:~ $ iob add openknx
    NPM version: 10.5.0
    Installing iobroker.openknx@0.7.3... (System call)
    added 15 packages in 12s
    117 packages are looking for funding
      run `npm fund` for details
    host.chet install adapter openknx
    upload [16] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/busload.png busload.png image/png
    upload [15] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
    upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
    upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
    upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
    upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
    host.chet object system.adapter.openknx created/updated
    host.chet create instance openknx
    host.chet object system.adapter.openknx.0.alive created
    host.chet object system.adapter.openknx.0.connected created
    host.chet object system.adapter.openknx.0.compactMode created
    host.chet object system.adapter.openknx.0.cpu created
    host.chet object system.adapter.openknx.0.cputime created
    host.chet object system.adapter.openknx.0.memHeapUsed created
    host.chet object system.adapter.openknx.0.memHeapTotal created
    host.chet object system.adapter.openknx.0.memRss created
    host.chet object system.adapter.openknx.0.uptime created
    host.chet object system.adapter.openknx.0.inputCount created
    host.chet object system.adapter.openknx.0.outputCount created
    host.chet object system.adapter.openknx.0.eventLoopLag created
    host.chet object system.adapter.openknx.0.sigKill created
    host.chet object system.adapter.openknx.0.logLevel created
    host.chet object openknx.0.info created
    host.chet object openknx.0.info.connection created
    host.chet object openknx.0.info.busload created
    host.chet object openknx.0.info.messagecount created
    host.chet Set default value of openknx.0.info.connection: false
    host.chet Set default value of openknx.0.info.busload: 0
    host.chet Set default value of openknx.0.info.messagecount: 0
    host.chet object system.adapter.openknx.0 created
    echad@chet:~ $
    R 1 Antwort Letzte Antwort
      @rsw2004 sagte in OpenKNX Adapter startet nicht mehr nach System-Update:
      Dann mach ein Issue dazu auf, wenn du dir sicher bist.
      Wie schaut denn ein Adapter-Neustart im Log nun aus? Immer noch ein rebuild im Gange?
      rsw2004
      es hat sich meiner Meinung nach nix geändert.
      host.raspberrypi4
      2024-03-30 15:59:27.700	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi4
      2024-03-30 15:59:27.700	error	Caught by controller[0]: Node.js v18.20.0
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: }
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: ]
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: requireStack: [
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.raspberrypi4
      2024-03-30 15:59:27.699	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      host.raspberrypi4
      2024-03-30 15:59:27.698	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
      host.raspberrypi4
      2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
      host.raspberrypi4
      2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
      host.raspberrypi4
      2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
      host.raspberrypi4
      2024-03-30 15:59:27.697	error	Caught by controller[0]: Require stack:
      host.raspberrypi4
      2024-03-30 15:59:27.697	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
      host.raspberrypi4
      2024-03-30 15:59:27.697	error	Caught by controller[0]: ^
      host.raspberrypi4
      2024-03-30 15:59:27.697	error	Caught by controller[0]: throw err;
      host.raspberrypi4
      2024-03-30 15:59:27.696	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
      host.raspberrypi4
      2024-03-30 15:59:26.615	info	instance system.adapter.openknx.0 started with pid 5921
        @rsw2004
        NPM version: 10.5.0
        echad@chet:~ $
        rsw2004
        bei dir wurde die 0.7.3 installiert.
        Habe das nun auch mal manuell geupdatet.
        Der Log bleibt gleich.
        • R rsw2004
          Ich fahre auch ein 'bleeding edge'-Betasystem hier.
            rsw2004
            	Rebuild for adapter system.adapter.openknx.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
            Könnte das weiterhelfen?
            Welches Verzeichnis wäre denn hier das richtige?
            /opt/iobroker/iobroker-data/files/openknx.admin ?
            • R rsw2004
              @rsw2004
              cd /opt/iobroker/node_modules/iobroker.openknx
              npm install --omit=dev
              müsste das sein. Der Befehl mit --production ist veraltet.
                @rsw2004
                rsw2004
                Habe zumindest fürs Erste eine Lösung gefunden, damit alles wieder läuft.
                Erst Downgrade auf die ursprüngliche Version (laut LOG)
                iobroker update
                iobroker upgrade openknx@0.6.3
                danach
                Mit der aktuellen 0.7.2 funktioniert das nicht.
                Ich danke dir für deine Mühe
                • R rsw2004
                  iobroker update
                  danach
                  Meldungen?
                    ak68
                    Auch wenn der Thread schon etwas älter ist:
                    Ich bekommen nach einen Update auf 0.9.0 den OpnenKNX-Adapter nicht mehr zum Laufen, auch ein Downgrade auf 0.8.0, 0.7.3, 0.6.3 kann den Adapter nicht mehr erwecken:
                    Hier die Fehlerbreschreibung:
                    https://github.com/iobroker-community-adapters/ioBroker.openknx/issues/653
                    Um Hilfe wäre ich dankbar :)
                    ioBroker auf QNAP TVS-473
                    Visu und Logiken mit node-red
                    Anbindung an KNX per openKNX
                    • A ak68
                      @ak68
                      Setz dein nodesource-Repo wieder auf das Gleis:
                      iob nodejs-update 22
                      Rückfragen bejahen.
                        ak68
                        Nach dem Neustart des KNX-Gateways läuft wieder Alles- ohne weitere Änderungen :)
                        Vielen Dank
                        • A ak68
                          Vielen Dank
                          @ak68 sagte in OpenKNX Adapter startet nicht mehr nach System-Update:
                          nodejs musst du trotzdem updaten und das Repo fixen. Neustart von KNX hin oder her.
