  4. OpenKNX Adapter startet nicht mehr nach System-Update
    6.1k
23 Beiträge 3 Kommentatoren 2.0k Aufrufe 2 Beobachtet
  • R rsw2004
    Moin moin,
    ich habe Heute das System geupdatet und seitdem startet der OpenKNX Adapter nicht mehr.
    Node.js: v18.20.0
    NPM: 10.5.0
    js-controller: 5.0.19
    Das Update ist sauber durchgelaufen, allerdings habe ich irgendwann festgestellt, dass der OpenKNX Adapter nicht mehr startet.
    Hatte mal zu Testzwecken eine neue Instanz installiert, aber gleiches Problem.
    Beim Starten sagt das LOG-File folgendes:
    host.raspberrypi4
    2024-03-30 09:32:48.944	info	iobroker npm-rebuild: Rebuilding native modules ...
    host.raspberrypi4
    2024-03-30 09:32:47.583	info	iobroker rebuild
    host.raspberrypi4
    2024-03-30 09:32:47.582	warn	adapter "openknx" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
    host.raspberrypi4
    2024-03-30 09:32:47.581	info	system.adapter.openknx.0 will be rebuilt
    host.raspberrypi4
    2024-03-30 09:32:47.581	info	Adapter system.adapter.openknx.0 needs rebuild and will be restarted afterwards.
    host.raspberrypi4
    2024-03-30 09:32:47.581	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi4
    2024-03-30 09:32:47.580	error	Caught by controller[0]: Node.js v18.20.0
    host.raspberrypi4
    2024-03-30 09:32:47.580	error	Caught by controller[0]: }
    host.raspberrypi4
    2024-03-30 09:32:47.580	error	Caught by controller[0]: ]
    host.raspberrypi4
    2024-03-30 09:32:47.580	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
    host.raspberrypi4
    2024-03-30 09:32:47.579	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
    host.raspberrypi4
    2024-03-30 09:32:47.579	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
    host.raspberrypi4
    2024-03-30 09:32:47.579	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
    host.raspberrypi4
    2024-03-30 09:32:47.579	error	Caught by controller[0]: requireStack: [
    host.raspberrypi4
    2024-03-30 09:32:47.578	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.raspberrypi4
    2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
    host.raspberrypi4
    2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
    host.raspberrypi4
    2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
    host.raspberrypi4
    2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    host.raspberrypi4
    2024-03-30 09:32:47.577	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
    host.raspberrypi4
    2024-03-30 09:32:47.576	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
    host.raspberrypi4
    2024-03-30 09:32:47.576	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
    host.raspberrypi4
    2024-03-30 09:32:47.576	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
    host.raspberrypi4
    2024-03-30 09:32:47.576	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
    host.raspberrypi4
    2024-03-30 09:32:47.576	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    host.raspberrypi4
    2024-03-30 09:32:47.575	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
    host.raspberrypi4
    2024-03-30 09:32:47.575	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
    host.raspberrypi4
    2024-03-30 09:32:47.575	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
    host.raspberrypi4
    2024-03-30 09:32:47.575	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
    host.raspberrypi4
    2024-03-30 09:32:47.575	error	Caught by controller[0]: Require stack:
    host.raspberrypi4
    2024-03-30 09:32:47.575	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
    host.raspberrypi4
    2024-03-30 09:32:47.574	error	Caught by controller[0]: ^
    host.raspberrypi4
    2024-03-30 09:32:47.574	error	Caught by controller[0]: throw err;
    host.raspberrypi4
    2024-03-30 09:32:47.573	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
    host.raspberrypi4
    2024-03-30 09:32:46.315	info	instance system.adapter.openknx.0 started with pid 8774
    Hatte in einem anderen Forum die vermeintliche Lösung für das Problem gefunden, allerdings hat das bei mir nicht funktioniert mit:
    npm install iobroker/adapter-core
    Was habe ich falsch gemacht? / Was ist zu tun?
    Danke euch
    @rsw2004
    cd /opt/iobroker
    npm ls ipaddr.js
    Und die Ausgabe von
    iob diag
    R 1 Antwort Letzte Antwort
      @rsw2004
      cd /opt/iobroker
      npm ls ipaddr.js
      Und die Ausgabe von
      iob diag
      rsw2004
      @thomas-braun said in OpenKNX Adapter startet nicht mehr nach System-Update:
      cd /opt/iobroker
      npm ls ipaddr.js
      robin@raspberrypi4:~ $ cd /opt/iobroker
      npm ls ipaddr.js
      iobroker.inst@3.0.0 /opt/iobroker
      ├─┬ iobroker.admin@6.13.16
      │ └─┬ express@4.18.2
      │   └─┬ proxy-addr@2.0.7
      │     └── ipaddr.js@1.9.1
      └─┬ iobroker.openknx@0.7.2
        └─┬ knx@2.5.2
          └── ipaddr.js@1.2.0
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi4
             Icon name: computer
                Kernel: Linux 6.6.20+rpt-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       11:36:17 up  2:42,  2 users,  load average: 0.36, 0.40, 0.36
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-03-30 11:36:17 CET
                 Universal time: Sat 2024-03-30 10:36:17 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      robin
      /home/robin
      robin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.6G        1.3G        1.2M        1.2G        2.4G
      Swap:           104M          0B        104M
      Total:          4.1G        1.6G        1.4G
               3791 M total memory
               1482 M used memory
               1717 M active memory
                664 M inactive memory
               1207 M free memory
                118 M buffer memory
               1058 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  378M   1% /run
      /dev/sda2      ext4      459G  5.7G  430G   2% /
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/sda1      vfat      510M   63M  448M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sat Mar 30 08:53:19 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:26:8F:AE vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=9e253307-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Mar 30 08:53:22 2024] EXT4-fs (sda2): mounted filesystem 7909438b-2884-423e-aa05-577fdea75c97 ro with ordered data mode. Quota mode: none.
      [Sat Mar 30 08:53:23 2024] EXT4-fs (sda2): re-mounted 7909438b-2884-423e-aa05-577fdea75c97 r/w. Quota mode: none.
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.3G    /var/
      660M    /var/log
      659M    /var/log/journal/1752ab92354a4fbe8ab5b2bd3f56c61e
      369M    /var/cache
      Archived and active journals take up 658.3M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      385M    /opt/iobroker/iobroker-data/
      286M    /opt/iobroker/iobroker-data/files
      142M    /opt/iobroker/iobroker-data/files/vis-2
      81M     /opt/iobroker/iobroker-data/files/vis-2/static
      80M     /opt/iobroker/iobroker-data/files/vis-2/static/js
      22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/376.1862d3de.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231007205057-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.0
      /usr/bin/node           v18.20.0
      /usr/bin/npm            10.5.0
      /usr/bin/npx            10.5.0
      /usr/bin/corepack       0.25.2
      nodejs:
        Installed: 18.20.0-1nodesource1
        Candidate: 18.20.0-1nodesource1
        Version table:
       *** 18.20.0-1nodesource1 500
              500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
           18.19.1-1nodesource1 500
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
           18.19.0-1nodesource1 500
           18.18.2-1nodesource1 500
           18.18.1-1nodesource1 500
           18.18.0-1nodesource1 500
           18.17.1-1nodesource1 500
           18.17.0-1nodesource1 500
           18.16.1-1nodesource1 500
           18.16.0-1nodesource1 500
           18.15.0-1nodesource1 500
           18.14.2-1nodesource1 500
           18.14.1-1nodesource1 500
           18.14.0-1nodesource1 500
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.13.0-1nodesource1 500
           18.12.0-1nodesource1 500
           18.11.0-1nodesource1 500
           18.10.0-1nodesource1 500
           18.9.1-1nodesource1 500
           18.9.0-1nodesource1 500
           18.8.0-1nodesource1 500
           18.7.0-1nodesource1 500
           18.6.0-1nodesource1 500
           18.5.0-1nodesource1 500
           18.4.0-1nodesource1 500
           18.3.0-1nodesource1 500
           18.2.0-1nodesource1 500
           18.1.0-1nodesource1 500
           18.0.0-1nodesource1 500
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      admin:          6.13.16
      javascript:     7.8.0
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi4                             -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi4                             -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi4                             -  enabled
      + system.adapter.jarvis.0                 : jarvis                : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
        system.adapter.openknx.0                : openknx               : raspberrypi4                             -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi4                             -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : raspberrypi4                             -  enabled
      + system.adapter.solax.0                  : solax                 : raspberrypi4                             -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi4                             -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi4                             -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi4                             -  enabled
        system.adapter.vis-2.0                  : vis-2                 : raspberrypi4                             - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi4                             -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yahka.0                  : yahka                 : raspberrypi4                             -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231007205057-if00
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.13.16  , installed 6.13.16
      Adapter    "backitup"     : 2.10.11  , installed 2.10.11
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.8.0    , installed 7.8.0
      Controller "js-controller": 5.0.19   , installed 5.0.19
      Adapter    "openknx"      : 0.7.2    , installed 0.7.2
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "socketio"     : 6.6.1    , installed 6.6.1
      Adapter    "solax"        : 0.9.6    , installed 0.9.6
      Adapter    "valuetrackerovertime": 1.0.1, installed 1.0.1
      Adapter    "vis-2"        : 2.9.32   , installed 2.9.32
      Adapter    "vis-2-widgets-energy": 0.3.11, installed 0.3.11
      Adapter    "vis-2-widgets-material": 1.3.18, installed 1.3.18
      Adapter    "weatherunderground": 3.6.0, installed 3.6.0
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.11   , installed 2.5.11
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        2579
      States:         2188
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:40331           0.0.0.0:*               LISTEN      1001       29572      9139/io.yahka.0
      tcp        0      0 127.0.0.1:43343         0.0.0.0:*               LISTEN      1001       32228      9139/io.yahka.0
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       29544      9102/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6464       684/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31136      8646/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31129      8646/iobroker.js-co
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        4759       753/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31196      8664/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31589      9005/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6466       684/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      106        6538       800/grafana
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        1929       533/avahi-daemon: r
      udp        0      0 0.0.0.0:50513           0.0.0.0:*                           104        1931       533/avahi-daemon: r
      udp6       0      0 :::33890                :::*                                104        1932       533/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        1930       533/avahi-daemon: r
      2024-03-30 11:35:25.899  - error: host.raspberrypi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
      2024-03-30 11:35:25.899  - error: host.raspberrypi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
      2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
      2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:981:27)
      2024-03-30 11:35:25.900  - error: host.raspberrypi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19)
      2024-03-30 11:35:25.905  - error: host.raspberrypi4 Caught by controller[0]:     at require (node:internal/modules/helpers:177:18)
      2024-03-30 11:35:25.905  - error: host.raspberrypi4 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
      2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1364:14)
      2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
      2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1203:32)
      2024-03-30 11:35:25.906  - error: host.raspberrypi4 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1019:12)
      2024-03-30 11:35:25.907  - error: host.raspberrypi4 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1231:19) {
      2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
      2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:   requireStack: [
      2024-03-30 11:35:25.908  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
      2024-03-30 11:35:25.912  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
      2024-03-30 11:35:25.913  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
      2024-03-30 11:35:25.913  - error: host.raspberrypi4 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.openknx/main.js'
      2024-03-30 11:35:25.914  - error: host.raspberrypi4 Caught by controller[0]:   ]
      2024-03-30 11:35:25.914  - error: host.raspberrypi4 Caught by controller[0]: }
      2024-03-30 11:35:25.915  - error: host.raspberrypi4 Caught by controller[0]: Node.js v18.20.0
      2024-03-30 11:35:25.915  - error: host.raspberrypi4 instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-03-30 11:35:25.916  - info: host.raspberrypi4 Rebuild for adapter system.adapter.openknx.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      2024-03-30 11:35:56.805  - info: solax.0 (8803) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      2024-03-30 11:36:57.902  - info: solax.0 (8803) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
      code_text
      • R rsw2004
        cd /opt/iobroker
        npm ls ipaddr.js
        npm ls ipaddr.js
          └─┬ knx@2.5.2
            └── ipaddr.js@1.2.0
        Skript v.2023-10-10
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        Docker          : false
        Kernel          : aarch64
        Userland        : arm64
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        robin
        /home/robin
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           104M          0B        104M
                 3791 M total memory
                 1482 M used memory
                 1207 M free memory
                  118 M buffer memory
                 1058 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        1.3G    /var/
        660M    /var/log
        369M    /var/cache
        USB-Devices by-id:
        /usr/bin/npm            10.5.0
        /usr/bin/npx            10.5.0
        nodejs:
          Version table:
             18.13.0+dfsg1-1 500
        Errors in npm tree:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.13.16
        javascript:     7.8.0
        Adapter State
        + instance is alive
        Objects and States
        Objects:        2579
        States:         2188
        Pending Updates: 0
        code_text
        @rsw2004
        Nichts auffälliges.
        Installier den openknx nochmal frisch darüber.
          @rsw2004
          Nichts auffälliges.
          rsw2004
          wie gesagt, hatte bereits eine neue Instanz installiert, brachte aber den gleichen Fehler.
          • R rsw2004
            @rsw2004
            Den ganzen Adapter, keine Instanz installieren.
              @rsw2004
              rsw2004
              also wie folgt?
              cd /opt/iobroker
              iobroker stop adapterName
              npm install iobroker.adapterName
              iobroker upload adapterName
              iobroker start adapterName
              Ändert sich nix
              • R rsw2004
                also wie folgt?
                cd /opt/iobroker
                Ändert sich nix
                @rsw2004
                Jein
                iobroker update
                iobroker upgrade openknx@0.7.2
                Rückmeldungen im Terminal hier bekannt machen.
                  @rsw2004
                  Jein
                  iobroker update
                  rsw2004
                  robin@raspberrypi4:~ $ iobroker update
                  Would you like to reinstall version 0.7.2 of openknx now? [(y)es, (n)o]: y
                  Update openknx from @0.7.2 to @0.7.2
                  NPM version: 10.5.0
                  Installing iobroker.openknx@0.7.2... (System call)
                  up to date in 7s
                  102 packages are looking for funding
                    run `npm fund` for details
                  upload [16] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/busload.png busload.png image/png
                  upload [15] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/exportGA.png exportGA.png image/png
                  upload [14] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [13] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [12] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [11] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [10] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [9] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [8] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [7] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [6] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [5] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [4] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [3] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/index_m.html index_m.html text/html
                  upload [2] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/openknx.png openknx.png image/png
                  upload [1] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/style.css style.css text/css
                  upload [0] openknx.admin /opt/iobroker/node_modules/iobroker.openknx/admin/words.js words.js application/javascript
                  • R rsw2004
                    NPM version: 10.5.0
                    up to date in 7s
                    rsw2004
                    @rsw2004
                    Also ich denke, das hat mit dem Update des Adapter angefangen, unabhängig von JS oder NPM oder was auch immer.
                    Kann ich einfach die ältere Version das drüberbügeln?
                    Einfach die Versionsnummer ändern?
                    • R rsw2004
                      @rsw2004
                      @rsw2004 sagte in OpenKNX Adapter startet nicht mehr nach System-Update:
                      Dann mach ein Issue dazu auf, wenn du dir sicher bist.
                      Wie schaut denn ein Adapter-Neustart im Log nun aus? Immer noch ein rebuild im Gange?
                      • R rsw2004
                        @rsw2004
                        @rsw2004
                        Wobei das auf meinem System direkt durchläuft:
                        echad@chet:~ $ iob add openknx
                        NPM version: 10.5.0
                        Installing iobroker.openknx@0.7.3... (System call)
                        added 15 packages in 12s
                        117 packages are looking for funding
                        host.chet install adapter openknx
                        host.chet object system.adapter.openknx created/updated
                        host.chet create instance openknx
                        host.chet object system.adapter.openknx.0.alive created
                        host.chet object system.adapter.openknx.0.connected created
                        host.chet object system.adapter.openknx.0.compactMode created
                        host.chet object system.adapter.openknx.0.cpu created
                        host.chet object system.adapter.openknx.0.cputime created
                        host.chet object system.adapter.openknx.0.memHeapUsed created
                        host.chet object system.adapter.openknx.0.memHeapTotal created
                        host.chet object system.adapter.openknx.0.memRss created
                        host.chet object system.adapter.openknx.0.uptime created
                        host.chet object system.adapter.openknx.0.inputCount created
                        host.chet object system.adapter.openknx.0.outputCount created
                        host.chet object system.adapter.openknx.0.eventLoopLag created
                        host.chet object system.adapter.openknx.0.sigKill created
                        host.chet object system.adapter.openknx.0.logLevel created
                        host.chet object openknx.0.info created
                        host.chet object openknx.0.info.connection created
                        host.chet object openknx.0.info.busload created
                        host.chet object openknx.0.info.messagecount created
                        host.chet Set default value of openknx.0.info.connection: false
                        host.chet Set default value of openknx.0.info.busload: 0
                        host.chet Set default value of openknx.0.info.messagecount: 0
                        host.chet object system.adapter.openknx.0 created
                        echad@chet:~ $
                          rsw2004
                          es hat sich meiner Meinung nach nix geändert.
                          host.raspberrypi4
                          2024-03-30 15:59:27.700	error	instance system.adapter.openknx.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          host.raspberrypi4
                          2024-03-30 15:59:27.700	error	Caught by controller[0]: Node.js v18.20.0
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: }
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: ]
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/main.js'
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js',
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js',
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js',
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: requireStack: [
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                          host.raspberrypi4
                          2024-03-30 15:59:27.699	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19) {
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1019:12)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1203:32)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1364:14)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js:8:16)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1231:19)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:981:27)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
                          host.raspberrypi4
                          2024-03-30 15:59:27.698	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/main.js
                          host.raspberrypi4
                          2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/index.js
                          host.raspberrypi4
                          2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/Connection.js
                          host.raspberrypi4
                          2024-03-30 15:59:27.697	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.openknx/lib/knx/src/FSM.js
                          host.raspberrypi4
                          2024-03-30 15:59:27.697	error	Caught by controller[0]: Require stack:
                          host.raspberrypi4
                          2024-03-30 15:59:27.697	error	Caught by controller[0]: Error: Cannot find module 'ipaddr.js'
                          host.raspberrypi4
                          2024-03-30 15:59:27.697	error	Caught by controller[0]: ^
                          host.raspberrypi4
                          2024-03-30 15:59:27.697	error	Caught by controller[0]: throw err;
                          host.raspberrypi4
                          2024-03-30 15:59:27.696	error	Caught by controller[0]: node:internal/modules/cjs/loader:1143
                          host.raspberrypi4
                          2024-03-30 15:59:26.615	info	instance system.adapter.openknx.0 started with pid 5921
                            @rsw2004
                            NPM version: 10.5.0
                            echad@chet:~ $
                            rsw2004
                            bei dir wurde die 0.7.3 installiert.
                            Habe das nun auch mal manuell geupdatet.
                            Der Log bleibt gleich.
                            • R rsw2004
                              Ich fahre auch ein 'bleeding edge'-Betasystem hier.
                                rsw2004
                                Könnte das weiterhelfen?
                                Welches Verzeichnis wäre denn hier das richtige?
                                /opt/iobroker/iobroker-data/files/openknx.admin ?
                                • R rsw2004
                                  @rsw2004
                                  cd /opt/iobroker/node_modules/iobroker.openknx
                                  npm install --omit=dev
                                  müsste das sein. Der Befehl mit --production ist veraltet.
                                    @rsw2004
                                    rsw2004
                                    Habe zumindest fürs Erste eine Lösung gefunden, damit alles wieder läuft.
                                    Erst Downgrade auf die ursprüngliche Version (laut LOG)
                                    iobroker update
                                    iobroker upgrade openknx@0.6.3
                                    danach
                                    Mit der aktuellen 0.7.2 funktioniert das nicht.
                                    Ich danke dir für deine Mühe
                                    • R rsw2004
                                      iobroker update
                                      danach
                                      Meldungen?
                                        ak68
                                        Auch wenn der Thread schon etwas älter ist:
                                        Ich bekommen nach einen Update auf 0.9.0 den OpnenKNX-Adapter nicht mehr zum Laufen, auch ein Downgrade auf 0.8.0, 0.7.3, 0.6.3 kann den Adapter nicht mehr erwecken:
                                        Hier die Fehlerbreschreibung:
                                        https://github.com/iobroker-community-adapters/ioBroker.openknx/issues/653
                                        Um Hilfe wäre ich dankbar :)
                                        ioBroker auf QNAP TVS-473
                                        Visu und Logiken mit node-red
                                        Anbindung an KNX per openKNX
                                        • A ak68
                                          @ak68
                                          Setz dein nodesource-Repo wieder auf das Gleis:
                                          iob nodejs-update 22
                                          Rückfragen bejahen.
